CCS/TMS320C6748: Function meaning
Part Number: TMS320C6748
HI ti TEAM:
1. SPRUG82A ->Touch(); Touch  function parameter definition? I can not fine it? how to use it?
2.whitch defined   "cachelinesize"  in the header file?
tks!
  • David,
    Please continue reading SPRUG82A for further information on the definition of the term "touch" and the assembly function "touch()" as provided in the document. The document explains the term in good detail. And the document includes the assembly function with comments to show its use.
    Your second question will require more information or clarification.
    RandyP
  • hi Randyp:
    1. Touch function parameter definition in which file? such as :#include <*****.h>
    2. cache line size function parameter definition in which file? such as :#include <*****.h>
  • David,
    I apologize that I will not be of much help. Your questions do not match my understanding of this. All I know of this is from the document you named in your original post. I did a pdf search for the keyword 'touch' and read each place it appeared, finding the definition of the term, explanation of the underlying operation, reason for needing this operation, and the source code as I described above.
    Sorry I was not able to understand the cache question.
    RandyP
