Linux/AM5728: GStreamer video pipeline issue
Part Number: AM5728
Tool/software: Linux
I have been attempting to run the TI Ducati gstreamer examples that are documented here on my AM5728 custom board:
https://developer.ridgerun.com/wiki/index.php?title=Gstreamer_pipelines_for_AM572x
I am using the TI Arago SDK with Linux Kernel version 4.4.41.
I try to run the following command:
GST_DEBUG=3 gst-launch-1.0 -e filesrc location=/am5728-gst-tests/video-samples/airshow_p352x288.yuv ! videoparse width=352 height=288 format=nv12 ! ducatijpegenc ! queue ! jpegparse ! qtmux ! filesink location=/am5728-gst-tests/tests-outputs/testmjpegenc.mov
It does not give a critical error, but stops almost immediately ( duration 0:00:00.22269... ) and after multiple runs, always produces a different sized file.
The input file is a 5MB file and the produced output from gstreamer is relatively tiny. Also, the resulting video file is only 2 seconds long and looks like random garbage ( not a good looking video ). Here is a screenshot:
There is no error reported. Why is the process ending prematurely and why is the resulting video not encoded properly?
Run with minimal debug:
root@am57xx:~# GST_DEBUG=3 gst-launch-1.0 -e filesrc location=/am5728-gst-tests/video-samples/airshow_p352x288.yuv ! >
Setting pipeline to PAUSED ...
[ 3717.894784] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
0:00:00.227159119  3248    0xece00 WARN                 basesrc gstbasesrc.c:3481:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
0:00:00.240312997  3248    0xdcc00 FIXME               basesink gstbasesink.c:3117:gst_base_sink_default_event:<filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
0:00:00.242218799  3248    0xece00 WARN                     bin gstbin.c:2524:gst_bin_do_latency_func:<pipeline0> did not really configure latency of 0:00:00.000000000
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:00.222695058
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I run it multiple times in a row and see varying results with different file sizes:
root@machine:~/am57xx/build/exported-nfs/am5728-gst-tests/tests-outputs(master)>sudo rm *
root@machine:~/am57xx/build/exported-nfs/am5728-gst-tests/tests-outputs(master)>ls -rlt
total 1096
-rw-r--r-- 1 root root 1122163 Sep 18 09:25 testmjpegenc.mov
total 1096
total 1168
-rw-r--r-- 1 root root 1195468 Sep 18 09:25 testmjpegenc.mov
total 1388
-rw-r--r-- 1 root root 1417534 Sep 18 09:25 testmjpegenc.mov
total 1440
-rw-r--r-- 1 root root 1474084 Sep 18 09:26 testmjpegenc.mov
total 1440
total 1440
total 924
-rw-r--r-- 1 root root 942203 Sep 18 09:26 testmjpegenc.mov
Here is the run with verbosity turned on:
root@am57xx:~# GST_DEBUG=3 gst-launch-1.0 -v -e filesrc location=/am5728-gst-tests/video-samples/airshow_p352x288.yuv>
[ 3704.028593] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
0:00:00.317231394  3236    0xece00 WARN                 basesrc gstbasesrc.c:3481:gst_base_src_start_complete:<filesrc0> pad not activated yet
/GstPipeline:pipeline0/GstVideoParse:videoparse0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)jpeg\,\ colorimetry\=\(string\)bt601\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstDucatiJPEGEnc:ducatijpegenc0.GstPad:src: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1\,\ pixel-aspect-ratio\=\(fraction\)1/1"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1\,\ pixel-aspect-ratio\=\(fraction\)1/1"
/GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:sink: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1\,\ pixel-aspect-ratio\=\(fraction\)1/1"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1\,\ pixel-aspect-ratio\=\(fraction\)1/1"
/GstPipeline:pipeline0/GstDucatiJPEGEnc:ducatijpegenc0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)jpeg\,\ colorimetry\=\(string\)bt601\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstDucatiJPEGEnc:ducatijpegenc0.GstPad:src: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:sink: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:src: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ format\=\(string\)I420\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:video_0: caps = "image/jpeg\,\ parsed\=\(boolean\)true\,\ format\=\(string\)I420\,\ width\=\(int\)352\,\ height\=\(int\)288\,\ framerate\=\(fraction\)25/1"
0:00:00.332682775  3236    0xdcc00 FIXME               basesink gstbasesink.c:3117:gst_base_sink_default_event:<filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = "video/quicktime\,\ variant\=\(string\)apple"
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = "video/quicktime\,\ variant\=\(string\)apple"
0:00:00.335408581  3236    0xece00 WARN                     bin gstbin.c:2524:gst_bin_do_latency_func:<pipeline0> did not really configure latency of 0:00:00.000000000
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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\ \>"
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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@-ti-am57xx:~# GST_DEBUG=3 gst-launch-1.0 -e -v filesrc location=/am5728-gst-tests/video-samples/airshow_p352x288.yuv>
[ 4004.535051] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
0:00:00.357552068  3368    0xece00 WARN                 basesrc gstbasesrc.c:3481:gst_base_src_start_complete:<filesrc0> pad not activated yet
0:00:00.373881362  3368    0xdcc00 FIXME               basesink gstbasesink.c:3117:gst_base_sink_default_event:<filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:00.376061583  3368    0xece00 WARN                     bin gstbin.c:2524:gst_bin_do_latency_func:<pipeline0> did not really configure latency of 0:00:00.000000000
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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\ \>"
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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\ \>"
Execution ended after 0:00:00.460856625
And here is the same run again with GST_DEBUG=4:
0:00:00.000372994     0x2d400 INFO               GST_INIT gst.c:510:init_pre:[00m Initializing GStreamer Core Library version 1.6.3
0:00:00.000941026     0x2d400 INFO               GST_INIT gst.c:511:init_pre:[00m Using library installed in /usr/lib
0:00:00.001053104     0x2d400 INFO               GST_INIT gst.c:522:init_pre:[00m Linux am57xx 4.4.41 #1 SMP PREEMPT Tue Sep 11 15:03:08 CDT 2018 armv7l
0:00:00.004351658     0x2d400 INFO               GST_INIT gstmessage.c:119:_priv_gst_message_initialize:[00m init messages
0:00:00.009153090     0x2d400 INFO               GST_INIT gstcontext.c:77:_priv_gst_context_initialize:[00m init contexts
0:00:00.010681669     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize:[00m registering 0 static plugins
0:00:00.011529487     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static:[00m registered static plugin "staticelements"
0:00:00.011636359     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static:[00m added static plugin "staticelements", result: 1
0:00:00.011824077     0x2d400 INFO           GST_REGISTRY gstregistry.c:1723:ensure_current_registry:[00m reading registry cache: /home/root/.cache/gstreamer-1.0/registry.arm.bin
0:00:00.105990834     0x2d400 INFO           GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache:[00m loaded /home/root/.cache/gstreamer-1.0/registry.arm.bin in 0.093699 seconds
0:00:00.106356834     0x2d400 INFO           GST_REGISTRY gstregistry.c:1579:scan_and_update_registry:[00m Validating plugins from registry cache: /home/root/.cache/gstreamer-1.0/registry.arm.bin
0:00:00.241966991     0x2d400 INFO           GST_REGISTRY gstregistry.c:1681:scan_and_update_registry:[00m Registry cache has not changed
0:00:00.242056295     0x2d400 INFO           GST_REGISTRY gstregistry.c:1758:ensure_current_registry:[00m registry reading and updating done, result = 1
0:00:00.242119409     0x2d400 INFO               GST_INIT gst.c:720:init_post:[00m GLib runtime version: 2.46.2
0:00:00.242183825     0x2d400 INFO               GST_INIT gst.c:722:init_post:[00m GLib headers version: 2.46.2
0:00:00.242243524     0x2d400 INFO               GST_INIT gst.c:723:init_post:[00m initialized GStreamer successfully
0:00:00.242420180     0x2d400 INFO           GST_PIPELINE gstparse.c:323:gst_parse_launch_full:[00m parsing pipeline description 'filesrc location=/am5728-gst-tests/video-samples/airshow_p352x288.yuv ! videoparse width=352 height=288 format=nv12 ! ducatijpegenc ! queue ! jpegparse ! qtmux ! filesink location=/am5728-gst-tests/tests-outputs/testmjpegenc.mov '
0:00:00.250750828     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.250857537     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "filesrc"
0:00:00.251505927     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstBaseSrc@0xd41d0>[00m adding pad 'src'
0:00:00.251678516     0x2d400 INFO                filesrc gstfilesrc.c:263:gst_file_src_set_location:[00m filename : /am5728-gst-tests/video-samples/airshow_p352x288.yuv
0:00:00.251747975     0x2d400 INFO                filesrc gstfilesrc.c:264:gst_file_src_set_location:[00m uri      : file:///am5728-gst-tests/video-samples/airshow_p352x288.yuv
0:00:00.270058060     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/gstreamer-1.0/libgstrawparse.so" loaded
0:00:00.270150292     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "videoparse"
0:00:00.270806815     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstRawParse@0xd8038>[00m adding pad 'sink'
0:00:00.270946220     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstRawParse@0xd8038>[00m adding pad 'src'
0:00:00.289566348     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/gstreamer-1.0/libgstducati.so" loaded
0:00:00.289656953     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "ducatijpegenc"
0:00:00.290410100     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstVideoEncoder@0xde0a8>[00m adding pad 'sink'
0:00:00.290552108     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstVideoEncoder@0xde0a8>[00m adding pad 'src'
0:00:00.290675247     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "queue"
0:00:00.291366092     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstQueue@0xe2048>[00m adding pad 'sink'
0:00:00.291546164     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstQueue@0xe2048>[00m adding pad 'src'
0:00:00.294366641     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/gstreamer-1.0/libgstjpegformat.so" loaded
0:00:00.294445047     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "jpegparse"
0:00:00.294951265     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstBaseParse@0xe6300>[00m adding pad 'sink'
0:00:00.295088393     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstBaseParse@0xe6300>[00m adding pad 'src'
0:00:00.309860479     0x2d400 INFO     GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/gstreamer-1.0/libgstisomp4.so" loaded
0:00:00.309952223     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "qtmux"
0:00:00.310709111     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstQTMux@0xef0f0>[00m adding pad 'src'
0:00:00.311241681     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "filesink"
0:00:00.311844687     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstBaseSink@0xf2228>[00m adding pad 'sink'
0:00:00.311993852     0x2d400 INFO               filesink gstfilesink.c:302:gst_file_sink_set_location:<filesink0>[00m filename : /am5728-gst-tests/tests-outputs/testmjpegenc.mov
0:00:00.312091452     0x2d400 INFO               filesink gstfilesink.c:303:gst_file_sink_set_location:<filesink0>[00m uri      : file:///am5728-gst-tests/tests-outputs/testmjpegenc.mov
0:00:00.312180105     0x2d400 INFO    GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "pipeline"
0:00:00.312715929     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking filesrc0:(any) to videoparse0:(any) (0/0) with caps "(NULL)"
0:00:00.312810276     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element filesrc0:(any) to element videoparse0:(any)
0:00:00.312892260     0x2d400 INFO               GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link filesrc0:src and videoparse0:sink
0:00:00.313012471     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m filesrc0 and videoparse0 in same bin, no need for ghost pads
0:00:00.313115601     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link filesrc0:src and videoparse0:sink
0:00:00.313227516     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked filesrc0:src and videoparse0:sink, successful
0:00:00.313296649     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.313354721     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<filesrc0:src>[00m Received event on flushing pad. Discarding
0:00:00.313451671     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking videoparse0:(any) to ducatijpegenc0:(any) (0/0) with caps "(NULL)"
0:00:00.313532191     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element videoparse0:(any) to element ducatijpegenc0:(any)
0:00:00.313607017     0x2d400 INFO               GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link videoparse0:src and ducatijpegenc0:sink
0:00:00.313775540     0x2d400 INFO               GST_PADS gstpad.c:3996:gst_pad_peer_query:<ducatijpegenc0:src>[00m pad has no peer
0:00:00.313943575     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m videoparse0 and ducatijpegenc0 in same bin, no need for ghost pads
0:00:00.314035969     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link videoparse0:src and ducatijpegenc0:sink
0:00:00.314150487     0x2d400 INFO               GST_PADS gstpad.c:3996:gst_pad_peer_query:<ducatijpegenc0:src>[00m pad has no peer
0:00:00.314291356     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked videoparse0:src and ducatijpegenc0:sink, successful
0:00:00.314361465     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.314416772     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<videoparse0:src>[00m Received event on flushing pad. Discarding
0:00:00.314506889     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking ducatijpegenc0:(any) to queue0:(any) (0/0) with caps "(NULL)"
0:00:00.314626287     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element ducatijpegenc0:(any) to element queue0:(any)
0:00:00.314706969     0x2d400 INFO               GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link ducatijpegenc0:src and queue0:sink
0:00:00.314823439     0x2d400 INFO               GST_PADS gstpad.c:3996:gst_pad_peer_query:<queue0:src>[00m pad has no peer
0:00:00.314895825     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m ducatijpegenc0 and queue0 in same bin, no need for ghost pads
0:00:00.314984479     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link ducatijpegenc0:src and queue0:sink
0:00:00.315094929     0x2d400 INFO               GST_PADS gstpad.c:3996:gst_pad_peer_query:<queue0:src>[00m pad has no peer
0:00:00.315167316     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked ducatijpegenc0:src and queue0:sink, successful
0:00:00.315235473     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.315290292     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<ducatijpegenc0:src>[00m Received event on flushing pad. Discarding
0:00:00.315501596     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking queue0:(any) to jpegparse0:(any) (0/0) with caps "(NULL)"
0:00:00.315583417     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element queue0:(any) to element jpegparse0:(any)
0:00:00.315658895     0x2d400 INFO               GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link queue0:src and jpegparse0:sink
0:00:00.315785124     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m queue0 and jpegparse0 in same bin, no need for ghost pads
0:00:00.315875404     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link queue0:src and jpegparse0:sink
0:00:00.315999031     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked queue0:src and jpegparse0:sink, successful
0:00:00.316070116     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.316125911     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<queue0:src>[00m Received event on flushing pad. Discarding
0:00:00.316217004     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking jpegparse0:(any) to qtmux0:(any) (0/0) with caps "(NULL)"
0:00:00.316296223     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element jpegparse0:(any) to element qtmux0:(any)
0:00:00.316621719     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<qtmux0>[00m adding pad 'video_0'
0:00:00.316722735     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m jpegparse0 and qtmux0 in same bin, no need for ghost pads
0:00:00.316845060     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link jpegparse0:src and qtmux0:video_0
0:00:00.316969500     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked jpegparse0:src and qtmux0:video_0, successful
0:00:00.317043839     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.317101260     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<jpegparse0:src>[00m Received event on flushing pad. Discarding
0:00:00.317190727     0x2d400 INFO           GST_PIPELINE grammar.y:571:gst_parse_perform_link:[00m linking qtmux0:(any) to filesink0:(any) (0/0) with caps "(NULL)"
0:00:00.317272548     0x2d400 INFO       GST_ELEMENT_PADS gstutils.c:1571:gst_element_link_pads_full:[00m trying to link element qtmux0:(any) to element filesink0:(any)
0:00:00.317350953     0x2d400 INFO               GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link qtmux0:src and filesink0:sink
0:00:00.317457988     0x2d400 INFO               GST_PADS gstutils.c:1444:prepare_link_maybe_ghosting:[00m qtmux0 and filesink0 in same bin, no need for ghost pads
0:00:00.317544527     0x2d400 INFO               GST_PADS gstpad.c:2234:gst_pad_link_prepare:[00m trying to link qtmux0:src and filesink0:sink
0:00:00.317654001     0x2d400 INFO               GST_PADS gstpad.c:2440:gst_pad_link_full:[00m linked qtmux0:src and filesink0:sink, successful
0:00:00.317722972     0x2d400 INFO              GST_EVENT gstevent.c:1374:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.317777791     0x2d400 INFO              GST_EVENT gstpad.c:5502:gst_pad_send_event_unchecked:<qtmux0:src>[00m Received event on flushing pad. Discarding
0:00:00.329010737     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.340703543     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesink0>[00m completed state change to READY
0:00:00.340782436     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesink0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.340912081     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 2(READY) successfully
0:00:00.341010495     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.341088087     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to READY
0:00:00.341148599     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.341237740     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 2(READY) successfully
0:00:00.341359089     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.341442049     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to READY
0:00:00.341502561     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.341590564     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 2(READY) successfully
0:00:00.341678892     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.341750303     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to READY
0:00:00.341807073     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.341893449     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 2(READY) successfully
0:00:00.341985193     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.342060508     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to READY
0:00:00.342118743     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.342203655     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 2(READY) successfully
0:00:00.342290681     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.342364207     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to READY
0:00:00.342422441     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.342506377     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 2(READY) successfully
0:00:00.342584783     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.342655705     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to READY
0:00:00.342712639     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.342794623     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 2(READY) successfully
0:00:00.342918087     0x2d400 INFO             GST_STATES gstelement.c:2305:gst_element_continue_state:<pipeline0>[00m committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.342993889     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.343172660     0x2d400 INFO             GST_STATES gstelement.c:2312:gst_element_continue_state:<pipeline0>[00m continue state change READY to PAUSED, final PAUSED
0:00:00.343313204     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.343454399     0x2d400 INFO             GST_STATES gstbin.c:2713:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' is changing state asynchronously to PAUSED
0:00:00.343543703     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.343646345     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to PAUSED
0:00:00.343706207     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.343790468     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 3(PAUSED) successfully
0:00:00.343877657     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.344392497     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to PAUSED
0:00:00.344463095     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.344553212     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 3(PAUSED) successfully
0:00:00.344644143     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.344786476     0x2d400 INFO                   task gsttask.c:450:gst_task_set_lock:[00m setting stream lock 0xd684c on task 0xfc028
0:00:00.344854959     0x2d400 INFO               GST_PADS gstpad.c:5848:gst_pad_start_task:<queue0:src>[00m created task 0xfc028
0:00:00.345178177     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to PAUSED
0:00:00.345256908     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.345452921     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 3(PAUSED) successfully
0:00:00.345551172     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.389116070     0x2d400 INFO                 ducati gstducatividenc.c:572:gst_ducati_videnc_allocate_params_default:<ducatijpegenc0>[00m started
0:00:00.389231564     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to PAUSED
0:00:00.389300860     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.389400412     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 3(PAUSED) successfully
0:00:00.389500452     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.389617409     0x2d400 INFO                filesrc gstfilesrc.c:460:gst_file_src_start:<filesrc0>[00m opening file /am5728-gst-tests/video-samples/airshow_p352x288.yuv
0:00:00.398296977     0x2d400 WARN                basesrc gstbasesrc.c:3481:gst_base_src_start_complete:<filesrc0>[00m pad not activated yet
0:00:00.398406126     0x2d400 INFO                filesrc gstfilesrc.c:460:gst_file_src_start:<filesrc0>[00m opening file /am5728-gst-tests/video-samples/airshow_p352x288.yuv
0:00:00.399322428     0x2d400 INFO              GST_EVENT gstevent.c:760:gst_event_new_segment:[00m creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 0:00:01.600000000
0:00:00.399533244     0x2d400 INFO                   task gsttask.c:450:gst_task_set_lock:[00m setting stream lock 0xd61bc on task 0xfc0d0
0:00:00.399605630     0x2d400 INFO               GST_PADS gstpad.c:5848:gst_pad_start_task:<videoparse0:sink>[00m created task 0xfc0d0
0:00:00.399857438     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to PAUSED
0:00:00.399933729     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.400031329     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 3(PAUSED) successfully
0:00:00.400048084     0xdcb50 INFO       GST_ELEMENT_PADS gstelement.c:897:gst_element_get_static_pad:[00m found pad videoparse0:sink
0:00:00.400122260     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.400225553     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to PAUSED
0:00:00.400296150     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.400399444     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 3(PAUSED) successfully
0:00:00.400483380     0xdcb50 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event video/x-raw, format=(string)NV12, width=(int)352, height=(int)288, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)25/1
0:00:00.401910292     0xdcb50 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event image/jpeg, parsed=(boolean)true, width=(int)352, height=(int)288, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
0:00:00.404345574     0xdcb50 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event image/jpeg, parsed=(boolean)true, width=(int)352, height=(int)288, framerate=(fraction)25/1
0:00:00.408492436     0xdcb50 INFO                 ducati gstducatividenc.c:442:gst_ducati_videnc_configure:<ducatijpegenc0>[00m configured
0:00:00.412288425     0xdcb50 INFO              GST_EVENT gstevent.c:760:gst_event_new_segment:[00m creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 0:00:01.600000000
0:00:00.413389353     0xdcc00 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event image/jpeg, parsed=(boolean)true, format=(string)I420, width=(int)352, height=(int)288, framerate=(fraction)25/1
0:00:00.414624318     0xdcc00 [32;01mFIXME              basesink gstbasesink.c:3117:gst_base_sink_default_event:<filesink0>[00m stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:00.414764862     0xdcc00 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event video/quicktime, variant=(string)apple
0:00:00.415701822     0xdcc00 INFO                  qtmux gstqtmux.c:2006:gst_qt_mux_downstream_is_seekable:<qtmux0>[00m downstream is seekable
0:00:00.415779740     0xdcc00 INFO              GST_EVENT gstevent.c:760:gst_event_new_segment:[00m creating segment event bytes segment start=0, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:00:00.416072214     0xdcc00 INFO             GST_STATES gstbin.c:3181:bin_handle_async_done:<pipeline0>[00m committing state from READY to PAUSED, old pending PAUSED
0:00:00.416154686     0xdcc00 INFO             GST_STATES gstbin.c:3201:bin_handle_async_done:<pipeline0>[00m completed state change, pending VOID
0:00:00.416212108     0xdcc00 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.417400713     0x2d400 INFO              GST_EVENT gstevent.c:1245:gst_event_new_latency:[00m creating latency event 0:00:00.000000000
0:00:00.417638532     0x2d400 WARN                    bin gstbin.c:2524:gst_bin_do_latency_func:<pipeline0>[00m did not really configure latency of 0:00:00.000000000
0:00:00.417797457     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.417896033     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesink0>[00m completed state change to PLAYING
0:00:00.417971022     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesink0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.418076105     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 4(PLAYING) successfully
0:00:00.418172078     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.418246905     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to PLAYING
0:00:00.418305302     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.418421772     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 4(PLAYING) successfully
0:00:00.418515630     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.418590132     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to PLAYING
0:00:00.418649830     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.418734742     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 4(PLAYING) successfully
0:00:00.418821769     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.418894969     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to PLAYING
0:00:00.418953529     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.419037790     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 4(PLAYING) successfully
0:00:00.419125468     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.419199644     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to PLAYING
0:00:00.419258366     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.419341977     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 4(PLAYING) successfully
0:00:00.419430468     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.419503342     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to PLAYING
0:00:00.419562065     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.419645513     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 4(PLAYING) successfully
0:00:00.419726196     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.419799884     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to PLAYING
0:00:00.419859094     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.419972148     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 4(PLAYING) successfully
0:00:00.420060150     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<pipeline0>[00m completed state change to PLAYING
0:00:00.420119361     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.599138419     0xdcb50 INFO                   task gsttask.c:315:gst_task_func:<videoparse0:sink>[00m Task going to paused
0:00:00.630381806     0xdcc00 INFO              GST_EVENT gstevent.c:679:gst_event_new_caps:[00m creating caps event video/quicktime, variant=(string)apple, streamheader=(buffer)< 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 >
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:src: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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\ \>"
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = "video/quicktime\,\ variant\=\(string\)apple\,\ streamheader\=\(buffer\)\<\ 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\ \>"
0:00:00.648174774     0xdcc00 INFO              GST_EVENT gstevent.c:760:gst_event_new_segment:[00m creating segment event bytes segment start=20, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:00:00.648503035     0xdcc00 INFO                   task gsttask.c:315:gst_task_func:<queue0:src>[00m Task going to paused
Execution ended after 0:00:00.228432474
0:00:00.648895387     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.648991523     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesink0>[00m completed state change to PAUSED
0:00:00.649057891     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesink0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.649165088     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 3(PAUSED) successfully
0:00:00.649258459     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.649334587     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to PAUSED
0:00:00.649394448     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.649482126     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 3(PAUSED) successfully
0:00:00.649571755     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.649645768     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to PAUSED
0:00:00.649705304     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.649791355     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 3(PAUSED) successfully
0:00:00.649880822     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.649954672     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to PAUSED
0:00:00.650013558     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.650097982     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 3(PAUSED) successfully
0:00:00.650185984     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.650261299     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to PAUSED
0:00:00.650320998     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.650441371     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 3(PAUSED) successfully
0:00:00.650533928     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.650608430     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to PAUSED
0:00:00.650667966     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.650754179     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 3(PAUSED) successfully
0:00:00.650834374     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:00.650908550     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to PAUSED
0:00:00.650968574     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.651054787     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 3(PAUSED) successfully
0:00:00.651146206     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<pipeline0>[00m completed state change to PAUSED
0:00:00.651205904     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:00.651531726     0x2d400 INFO             GST_STATES gstbin.c:1842:gst_bin_get_state_func:<pipeline0>[00m getting state
0:00:00.651765152     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.651902931     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesink0>[00m completed state change to READY
0:00:00.651966859     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesink0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.652054862     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 2(READY) successfully
0:00:00.652142702     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.652362627     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to READY
0:00:00.652428670     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.652515371     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 2(READY) successfully
0:00:00.652636883     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.652787838     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to READY
0:00:00.652851766     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.652937166     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 2(READY) successfully
0:00:00.653024355     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.653156278     0xdcc00 INFO                   task gsttask.c:317:gst_task_func:<queue0:src>[00m Task resume from paused
0:00:00.653341392     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to READY
0:00:00.653408086     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.653496576     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 2(READY) successfully
0:00:00.653586206     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.657449376     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to READY
0:00:00.657531686     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.657628310     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 2(READY) successfully
0:00:00.657725259     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.657938352     0xdcb50 INFO                   task gsttask.c:317:gst_task_func:<videoparse0:sink>[00m Task resume from paused
0:00:00.658085403     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to READY
0:00:00.658152584     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.658242051     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 2(READY) successfully
0:00:00.658325499     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current PAUSED pending VOID_PENDING, desired next READY
0:00:00.658414478     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to READY
0:00:00.658506222     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.658597315     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 2(READY) successfully
0:00:00.658692475     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<pipeline0>[00m completed state change to READY
0:00:00.658752662     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:00.658903942     0x2d400 INFO             GST_STATES gstbin.c:1842:gst_bin_get_state_func:<pipeline0>[00m getting state
Setting pipeline to NULL ...
0:00:00.659097190     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesink0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.669017579     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesink0>[00m completed state change to NULL
0:00:00.669096472     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesink0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.669192446     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesink0' changed state to 1(NULL) successfully
0:00:00.669285328     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<qtmux0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.669378862     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<qtmux0>[00m completed state change to NULL
0:00:00.669439536     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<qtmux0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.669524774     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'qtmux0' changed state to 1(NULL) successfully
0:00:00.669612288     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<jpegparse0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.669702731     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<jpegparse0>[00m completed state change to NULL
0:00:00.669762430     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<jpegparse0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.669848155     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'jpegparse0' changed state to 1(NULL) successfully
0:00:00.669936158     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<queue0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.670025462     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<queue0>[00m completed state change to NULL
0:00:00.670115742     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<queue0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.670204395     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'queue0' changed state to 1(NULL) successfully
0:00:00.670293048     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<ducatijpegenc0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.670384792     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<ducatijpegenc0>[00m completed state change to NULL
0:00:00.670444328     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<ducatijpegenc0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.670529891     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'ducatijpegenc0' changed state to 1(NULL) successfully
0:00:00.670616918     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<videoparse0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.670707360     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<videoparse0>[00m completed state change to NULL
0:00:00.670766896     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<videoparse0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.670850832     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'videoparse0' changed state to 1(NULL) successfully
0:00:00.670931840     0x2d400 INFO             GST_STATES gstbin.c:2243:gst_bin_element_set_state:<filesrc0>[00m current READY pending VOID_PENDING, desired next NULL
0:00:00.671018542     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<filesrc0>[00m completed state change to NULL
0:00:00.671078240     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<filesrc0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.671162339     0x2d400 INFO             GST_STATES gstbin.c:2707:gst_bin_change_state_func:<pipeline0>[00m child 'filesrc0' changed state to 1(NULL) successfully
0:00:00.671437571     0x2d400 INFO             GST_STATES gstelement.c:2330:gst_element_continue_state:<pipeline0>[00m completed state change to NULL
0:00:00.671502475     0x2d400 INFO             GST_STATES gstelement.c:2235:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline ...
0:00:00.671671486     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking qtmux0:src(0xd6bf0) and filesink0:sink(0xd6d40)
0:00:00.671784051     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked qtmux0:src and filesink0:sink
0:00:00.671898568     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "filesink0"
0:00:00.671987384     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<filesink0>[00m dispose
0:00:00.672075550     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<filesink0>[00m removing pad 'sink'
0:00:00.672171523     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<filesink0>[00m parent class dispose
0:00:00.672237403     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<filesink0>[00m finalize
0:00:00.672292547     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<filesink0>[00m finalize parent
0:00:00.672367211     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking jpegparse0:src(0xd6aa0) and qtmux0:video_0(0xd6e90)
0:00:00.672470179     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked jpegparse0:src and qtmux0:video_0
0:00:00.672582256     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "qtmux0"
0:00:00.672661800     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<qtmux0>[00m dispose
0:00:00.672721174     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<qtmux0>[00m removing pad 'video_0'
0:00:00.672817798     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<qtmux0>[00m removing pad 'src'
0:00:00.672900107     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<qtmux0>[00m parent class dispose
0:00:00.672992339     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<qtmux0>[00m finalize
0:00:00.673048784     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<qtmux0>[00m finalize parent
0:00:00.673121171     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking queue0:src(0xd6800) and jpegparse0:sink(0xd6950)
0:00:00.673222512     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked queue0:src and jpegparse0:sink
0:00:00.673424870     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "jpegparse0"
0:00:00.673829259     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<jpegparse0>[00m dispose
0:00:00.673890096     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<jpegparse0>[00m removing pad 'sink'
0:00:00.673973382     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<jpegparse0>[00m removing pad 'src'
0:00:00.674054878     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<jpegparse0>[00m parent class dispose
0:00:00.674196886     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<jpegparse0>[00m finalize
0:00:00.674255446     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<jpegparse0>[00m finalize parent
0:00:00.674328158     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking ducatijpegenc0:src(0xd6560) and queue0:sink(0xd66b0)
0:00:00.674430638     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked ducatijpegenc0:src and queue0:sink
0:00:00.674577688     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "queue0"
0:00:00.674660323     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<queue0>[00m dispose
0:00:00.674718395     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<queue0>[00m removing pad 'sink'
0:00:00.674806072     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<queue0>[00m removing pad 'src'
0:00:00.674893587     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<queue0>[00m parent class dispose
0:00:00.674958654     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<queue0>[00m finalize
0:00:00.675012659     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<queue0>[00m finalize parent
0:00:00.675082768     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking videoparse0:src(0xd62c0) and ducatijpegenc0:sink(0xd6410)
0:00:00.675183459     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked videoparse0:src and ducatijpegenc0:sink
0:00:00.675297814     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "ducatijpegenc0"
0:00:00.675462920     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<ducatijpegenc0>[00m dispose
0:00:00.675521318     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<ducatijpegenc0>[00m removing pad 'sink'
0:00:00.675601350     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<ducatijpegenc0>[00m removing pad 'src'
0:00:00.675682520     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<ducatijpegenc0>[00m parent class dispose
0:00:00.675746936     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<ducatijpegenc0>[00m finalize
0:00:00.675802080     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<ducatijpegenc0>[00m finalize parent
0:00:00.675874467     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:1991:gst_pad_unlink:[00m unlinking filesrc0:src(0xd6020) and videoparse0:sink(0xd6170)
0:00:00.675974832     0x2d400 INFO       GST_ELEMENT_PADS gstpad.c:2045:gst_pad_unlink:[00m unlinked filesrc0:src and videoparse0:sink
0:00:00.676088048     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "videoparse0"
0:00:00.676176864     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<videoparse0>[00m dispose
0:00:00.676234774     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<videoparse0>[00m removing pad 'sink'
0:00:00.676321800     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<videoparse0>[00m removing pad 'src'
0:00:00.676400694     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<videoparse0>[00m parent class dispose
0:00:00.676491136     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<videoparse0>[00m finalize
0:00:00.676549371     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<videoparse0>[00m finalize parent
0:00:00.676637211     0x2d400 INFO          GST_PARENTAGE gstbin.c:1559:gst_bin_remove_func:<pipeline0>[00m removed child "filesrc0"
0:00:00.676716592     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<filesrc0>[00m dispose
0:00:00.676773363     0x2d400 INFO       GST_ELEMENT_PADS gstelement.c:766:gst_element_remove_pad:<filesrc0>[00m removing pad 'src'
0:00:00.676851280     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<filesrc0>[00m parent class dispose
0:00:00.676916835     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<filesrc0>[00m finalize
0:00:00.676971003     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<filesrc0>[00m finalize parent
0:00:00.677029888     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2880:gst_element_dispose:<pipeline0>[00m dispose
0:00:00.677162950     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2924:gst_element_dispose:<pipeline0>[00m parent class dispose
0:00:00.677230456     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2955:gst_element_finalize:<pipeline0>[00m finalize
0:00:00.677285275     0x2d400 INFO   [00m [00;01;31;44m     GST_REFCOUNTING gstelement.c:2960:gst_element_finalize:<pipeline0>[00m finalize parent
0:00:00.677347251     0x2d400 INFO               GST_INIT gst.c:952:gst_deinit:[00m deinitializing GStreamer
0:00:00.687834371     0x2d400 INFO               GST_INIT gst.c:1083:gst_deinit:[00m deinitialized GStreamer
