What is the default frequence of the DSP core runing with the defalut SYS/BIOS setup? And where to find this info?
Its seem nothing is realte to the freq setting in the project cfg file
below is my sample project cfg file that change from the ipc sample project
//BWC, add Program var
/* root of the configuration object model */
var Program = xdc.useModule('xdc.cfg.Program');
/* ================ General configuration ================ */
var Memory = xdc.useModule('xdc.runtime.Memory');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Log = xdc.useModule('xdc.runtime.Log');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var System = xdc.useModule('xdc.runtime.System');
SysStd = xdc.useModule('xdc.runtime.SysStd');
var Edma = xdc.loadPackage ("ti.sdo.edma3.drv.sample");
var drv = xdc.loadPackage ("ti.sdo.edma3.drv");
var rm = xdc.loadPackage ("ti.sdo.edma3.rm");
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
System.SupportProxy = SysStd;
/* Add Shared Region module */
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
//SharedRegion.cacheLineSize = 32;
//SharedRegion.numEntries = 4;
//SharedRegion.translate = true;
/* Create a default system heap using ti.bios.HeapMem. */
var heapMemParams1 = new HeapMem.Params;
heapMemParams1.size = 8192 * 25;
heapMemParams1.sectionName = "systemHeap";
Program.global.heap0 = HeapMem.create(heapMemParams1);
/* This is the default memory heap. */
Memory.defaultHeapInstance = Program.global.heap0;
Program.sectMap["systemHeap"] = Program.platform.stackMemory;
* Enable Event Groups here and registering of ISR for specific GEM INTC is done
* using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs
var exception = xdc.useModule('ti.sysbios.family.c64p.Exception');
exception.enablePrint = true;
/* ================ BIOS configuration ================ */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
/* Enable BIOS Task Scheduler */
BIOS.taskEnabled = true;
/* ================ Task configuration ================ */
/* No runtime stack checking is performed */
Task.checkStackFlag = false;
/* Reduce the number of task priorities */
Task.numPriorities = 4;
var task0Params = new Task.Params();
task0Params.instance.name = "echo";
task0Params.stackSize = 0x1000;
Program.global.echo = Task.create("&gpio_test", task0Params);
/* ================ Driver configuration ================ */
/* Load the Osal package */
var osType = "tirtos";
var Osal = xdc.loadPackage('ti.osal');
Osal.Settings.osType = osType;
/* Load the Board package and set the board name */
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "evmAM572x";
/* ================ Memory sections configuration ================ */
//BWC, comment next three lines
//Program.sectMap[".text"] = "EXT_RAM";
//Program.sectMap[".const"] = "EXT_RAM";
//Program.sectMap[".plt"] = "EXT_RAM";
/* Program.sectMap["BOARD_IO_DELAY_DATA"] = "OCMC_RAM1"; */
/* Program.sectMap["BOARD_IO_DELAY_CODE"] = "OCMC_RAM1"; */
/* allocate a config-params object */
var HeapParam = new HeapMem.Params;
/* optionally assign per-instance configs */
//HeapParam.size = 200000;
HeapParam.size = 0x100000;
//HeapParam.sectionName = "L2_SRAM"
//HeapParam.sectionName = "OCMC_RAM1"
/* create an instance-object */
Program.global.myHeap = HeapMem.create(HeapParam);
task0Params.priority = 3;
task0Params.instance.name = "task_audio";
Program.global.task0 = Task.create("&Audio_echo_Task", task0Params);
* Copyright (c) 2013-2015 Texas Instruments Incorporated - http://www.ti.com
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== Dsp1.cfg ========
* Platform: DRA7XX_linux_elf
* Target: ti.targets.elf.C66
/* application uses the following modules and packages */
xdc.useModule('xdc.runtime.Assert');
xdc.useModule('xdc.runtime.Diags');
xdc.useModule('xdc.runtime.Error');
xdc.useModule('xdc.runtime.Registry');
* ======== IPC Configuration ========
xdc.useModule('ti.ipc.ipcmgr.IpcMgr');
/* load the configuration shared across cores */
Program.global.procName = "DSP1";
//BWC, no longer have shared folder
//var ipc_cfg = xdc.loadCapsule("../shared/ipc.cfg.xs");
var ipc_cfg = xdc.loadCapsule("ipc.cfg.xs");
//BWC comment, will call from main instead
//BIOS.addUserStartupFunction('&IpcMgr_ipcStartup');
* ======== SYS/BIOS Configuration ========
if (Program.build.profile == "debug") {
BIOS.libType = BIOS.LibType_Debug;
} else {
BIOS.libType = BIOS.LibType_Custom;
/* no rts heap */
Program.argSize = 100; /* minimum size */
//BWC increase stack size
//Program.stack = 0x1000;
Program.stack = 0x8000;
Task.common$.namedInstance = true;
/* default memory heap */
var heapMemParams = new HeapMem.Params();
heapMemParams.size = 0x8000;
Memory.defaultHeapInstance = HeapMem.create(heapMemParams);
/* create a heap for MessageQ messages */
var params = new HeapBuf.Params;
params.align = 8;
params.blockSize = 512;
params.numBlocks = 256;
var msgHeap = HeapBuf.create(params);
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
MessageQ.registerHeapMeta(msgHeap, 0);
/* Setup MessageQ transport */
var VirtioSetup = xdc.useModule('ti.ipc.transports.TransportRpmsgSetup');
MessageQ.SetupTransportProxy = VirtioSetup;
/* Setup NameServer remote proxy */
var NameServer = xdc.useModule("ti.sdo.utils.NameServer");
var NsRemote = xdc.useModule("ti.ipc.namesrv.NameServerRemoteRpmsg");
NameServer.SetupProxy = NsRemote;
/* Enable Memory Translation module that operates on the BIOS Resource Table */
var Resource = xdc.useModule('ti.ipc.remoteproc.Resource');
Resource.loadSegment = "EXT_CODE";
/* Use SysMin because trace buffer address is required for Linux/QNX
* trace debug driver, plus provides better performance.
var SysMin = xdc.useModule('ti.trace.SysMin');
System.SupportProxy = SysMin;
SysMin.bufSize = 0x8000;
Program.sectMap[".tracebuf"] = "TRACE_BUF";
Program.sectMap[".errorbuf"] = "EXC_DATA";
//Program.sectMap["BOARD_IO_DELAY_DATA"] = "OCMC_RAM1";
//Program.sectMap["BOARD_IO_DELAY_CODE"] = "OCMC_RAM1";
/* --------------------------- TICK --------------------------------------*/
//BWC comment out this whle tick section
// var Clock = xdc.useModule('ti.sysbios.knl.Clock');
// Clock.tickSource = Clock.TickSource_NULL;
// //Clock.tickSource = Clock.TickSource_USER;
// /* Configure BIOS clock source as GPTimer5 */
// //Clock.timerId = 0;
// var Timer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer');
// /* Skip the Timer frequency verification check. Need to remove this later */
// Timer.checkFrequency = false;
// /* Match this to the SYS_CLK frequency sourcing the dmTimers.
// * Not needed once the SYS/BIOS family settings is updated. */
// Timer.intFreq.hi = 0;
// Timer.intFreq.lo = 19200000;
// //var timerParams = new Timer.Params();
// //timerParams.period = Clock.tickPeriod;
// //timerParams.periodType = Timer.PeriodType_MICROSECS;
// /* Switch off Software Reset to make the below settings effective */
// //timerParams.tiocpCfg.softreset = 0x0;
// /* Smart-idle wake-up-capable mode */
// //timerParams.tiocpCfg.idlemode = 0x3;
// /* Wake-up generation for Overflow */
// //timerParams.twer.ovf_wup_ena = 0x1;
// //Timer.create(Clock.timerId, Clock.doTick, timerParams);
// var Idle = xdc.useModule('ti.sysbios.knl.Idle');
// var Deh = xdc.useModule('ti.deh.Deh');
// /* Must be placed before pwr mgmt */
// Idle.addFunc('&ti_deh_Deh_idleBegin');
* ======== Instrumentation Configuration ========
/* system logger */
var LoggerSys = xdc.useModule('xdc.runtime.LoggerSys');
var LoggerSysParams = new LoggerSys.Params();
var Defaults = xdc.useModule('xdc.runtime.Defaults');
Defaults.common$.logger = LoggerSys.create(LoggerSysParams);
/* enable runtime Diags_setMask() for non-XDC spec'd modules */
var Diags = xdc.useModule('xdc.runtime.Diags');
Diags.setMaskEnabled = true;
/* override diags mask for selected modules */
xdc.useModule('xdc.runtime.Main');
Diags.setMaskMeta("xdc.runtime.Main",
Diags.ENTRY | Diags.EXIT | Diags.INFO, Diags.RUNTIME_ON);
var Registry = xdc.useModule('xdc.runtime.Registry');
Registry.common$.diags_ENTRY = Diags.RUNTIME_OFF;
Registry.common$.diags_EXIT = Diags.RUNTIME_OFF;
Registry.common$.diags_INFO = Diags.RUNTIME_OFF;
Registry.common$.diags_USER1 = Diags.RUNTIME_OFF;
Registry.common$.diags_LIFECYCLE = Diags.RUNTIME_OFF;
Registry.common$.diags_STATUS = Diags.RUNTIME_OFF;
var Main = xdc.useModule('xdc.runtime.Main');
Main.common$.diags_ASSERT = Diags.ALWAYS_ON;
Main.common$.diags_INTERNAL = Diags.ALWAYS_ON;
//BWC, added to use custom resource table
/* Override the default resource table with my own */
//var Resource = xdc.useModule('ti.ipc.remoteproc.Resource');
Resource.customTable = true;
