Part Number: TDA2
Tool/software: Linux
I got similar error while executing build command for SDK.
command: make -s
Error:
dispDistSrcLink_tsk.c:81:45: fatal error: vdrm_controller/v_controller_if.h: No such file or directory
compilation terminated.
make[6]: *** [depend] Error 1
make[5]: *** [links_a15_dispDistSrc] Error 2
make[4]: *** [vision_sdk_linux_lib] Error 2
make[3]: *** [links_fw_libs_hlos] Error 2
make[2]: *** [apps_hlos] Error 2
make[1]: *** [apps] Error 2
make: *** [vision_sdk] Error 2
I checked git commit also for kernel, u-boot, sgx
u-boot:
839f3f2 (HEAD, origin/ti_2.12_release, ti_2.12_release) updated library and binaries added
2e3691d debug renamed to debug
35e203d Makefile and header files added
002bee1 itsapp.mk added
d9bc44b nwmanager initial version added
6619725 Debug renamed to debug , and Ipc renamed to ipc
34b4ac8 Debug renamed to debug , and Ipc renamed to ipc
21d98c8 controlapp initial version version added
fad591e json,ffmpeg Dependency added
764c7cb its directory added in rootfs file sytsem
3713f24 itsapp new directory added
cd424bd makefile renamed to datalogger.mk
de8a247 its renamed to datalogger in rootfs
003ce5f .
429efbf read failed error fixed for wifi_reader
Kernel:
SGX:
fd47e44 (HEAD, origin/ti-img-sgx/1.14.3699939/k4.4, sgx_dev) Revert "km: build: remove dependency on user-mode builds"
8d5305b km: remove update of sysconfig register in driver
bc31285 km: fix error in calculating size of page array
e68719b km: build: remove dependency on user-mode builds
a5a0fe1 km: Resolve Linux build warnings
c13efb7 km: disable active power management
c8d280c km : use CONFIG_ZONE_DMA for LPAE
106ddd5 km: use platform specific reset APIs only for AM3/AM4 platform
fed0756 (origin/ti-img-sgx/1.14.3699939/k4.1) KM: Make kernel configuration variable SUPPORT_LISR_MISR_SYNC conditional
3d5e9c9 KM: Enhance OMAP-based platform code to support AM3/4/5 devices
2d4a2cf KM: Invoke platform-specific reset API calls if available
Is all source code have old version/tags??
Have i taken any wrong process?
Please help to solve my problem?
Anand Kumar
