Linux/DRA72: Kernel crash when temperature is lower then -25 degrees Celsius
Part Number: DRA72
Tool/software: Linux
Hi TIs:
We have two borads with J6ECO(DRA72x) module
They have kernel crash problem when chamber temperature is lower than -25 degrees Celsius
After back to room temperature, the problem has disappeared.
Before kernel crash, we do memory test and result is fail.(See the log below)
Is there better way to distinguish the problem is releated to module or DDR ram?
Thanks!
Kenny
root@dra7xx-evm:~# memtester 300M 1
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 300MB (314572800 bytes)
got  300MB (314572800 bytes), trying mlock ...locked.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
FAILURE: 0x28620662 != 0x7fefa193 at offset 0x016cf34c.
FAILURE: 0xa8a0eebc != 0xdf59477d at offset 0x016cf350.
FAILURE: 0x2ae3c6b6 != 0xdff6d770 at offset 0x016cf354.
FAILURE: 0x4de4723b != 0x6ffbec43 at offset 0x016cf358.
FAILURE: 0x8ce1980f != 0xfafee9cc at offset 0x070cc94c.
FAILURE: 0x04d936ba != 0xfff41268 at offset 0x070cc950.
FAILURE: 0x4080d435 != 0x7e77b252 at offset 0x070cc954.
FAILURE: 0x8060dc2e != 0x5f97ce8b at offset 0x070cc958.
  Compare XOR         : FAILURE: 0xace23c77 != 0x046fd7a8 at offset 0x016cf34c.
FAILURE: 0x2d2124d1 != 0x63d97d92 at offset 0x016cf350.
FAILURE: 0xaf63fccb != 0x64770d85 at offset 0x016cf354.
FAILURE: 0xd264a850 != 0xf47c2258 at offset 0x016cf358.
FAILURE: 0xc5011aae != 0x0bc54668 at offset 0x0241a64c.
FAILURE: 0x20d10b0b != 0x27c12f71 at offset 0x0241a650.
FAILURE: 0x8d03f934 != 0x11d554aa at offset 0x0241a654.
FAILURE: 0x8751f327 != 0x2405201d at offset 0x0241a658.
FAILURE: 0x1161ce24 != 0x7f7f1fe1 at offset 0x070cc94c.
FAILURE: 0x89596ccf != 0x8474487d at offset 0x070cc950.
FAILURE: 0xc5010a4a != 0x02f7e867 at offset 0x070cc954.
FAILURE: 0x04e11243 != 0xe41804a0 at offset 0x070cc958.
  Compare SUB         : FAILURE: 0x2ae734d0 != 0x34620b80 at offset 0x016cf34c.
FAILURE: 0x4ec794b0 != 0x7c538e60 at offset 0x016cf350.
FAILURE: 0x4458d290 != 0x7010d470 at offset 0x016cf354.
FAILURE: 0x32bc4700 != 0xae9bd480 at offset 0x016cf358.
FAILURE: 0x0f3a5da0 != 0x044bef80 at offset 0x0241a64c.
FAILURE: 0xb105de90 != 0x526202b0 at offset 0x0241a650.
FAILURE: 0x99df17c0 != 0x126766e0 at offset 0x0241a654.
FAILURE: 0x32d73dd0 != 0xcd7f14f0 at offset 0x0241a658.
FAILURE: 0xdec890b0 != 0x36ae2100 at offset 0x0379254c.
FAILURE: 0x73fd6be0 != 0xe793d500 at offset 0x03792550.
FAILURE: 0x7e762be0 != 0xe67bd400 at offset 0x03792554.
FAILURE: 0x95fe7720 != 0xc33ee300 at offset 0x03792558.
FAILURE: 0x91b33dc0 != 0x001af600 at offset 0x0478f84c.
FAILURE: 0xd4192240 != 0xb5732600 at offset 0x0478f850.
FAILURE: 0x09fbb500 != 0xdfe45000 at offset 0x0478f854.
FAILURE: 0x1838b380 != 0xa4c5c500 at offset 0x0478f858.
FAILURE: 0x8f872cc0 != 0x0c4e7fb0 at offset 0x070cc94c.
FAILURE: 0xe202a950 != 0xe6e6b6f0 at offset 0x070cc950.
FAILURE: 0x456e64e0 != 0xd77619d0 at offset 0x070cc954.
FAILURE: 0x98d16d10 != 0x42d84e00 at offset 0x070cc958.
  Compare MUL         : FAILURE: 0x00000000 != 0x00000001 at offset 0x016cf350.
FAILURE: 0x00000000 != 0x00000001 at offset 0x016cf354.
FAILURE: 0x00000000 != 0x00000001 at offset 0x016cf358.
FAILURE: 0x00000001 != 0x00000000 at offset 0x0241a650.
FAILURE: 0x00000001 != 0x00000000 at offset 0x0241a654.
FAILURE: 0x00000000 != 0x00000002 at offset 0x0241a658.
FAILURE: 0x00000002 != 0x00000000 at offset 0x0379254c.
FAILURE: 0x00000001 != 0x00000002 at offset 0x03792550.
FAILURE: 0x00000001 != 0x00000002 at offset 0x03792554.
FAILURE: 0x00000001 != 0x00000002 at offset 0x03792558.
FAILURE: 0x00000001 != 0x00000000 at offset 0x0478f84c.
FAILURE: 0x00000002 != 0x00000001 at offset 0x0478f850.
FAILURE: 0x00000000 != 0x00000002 at offset 0x0478f854.
FAILURE: 0x00000000 != 0x00000001 at offset 0x0478f858.
FAILURE: 0x00000001 != 0x00000000 at offset 0x070cc94c.
FAILURE: 0x00000000 != 0x00000002 at offset 0x070cc954.
FAILURE: 0x00000001 != 0x00000000 at offset 0x070cc958.
  Compare DIV         : FAILURE: 0xefb23c62 != 0xefb23c63 at offset 0x016cf350.
FAILURE: 0xefb23c62 != 0xefb23c63 at offset 0x016cf354.
FAILURE: 0xefb23c62 != 0xefb23c63 at offset 0x016cf358.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x0241a650.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x0241a654.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x03792550.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x03792554.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x03792558.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x0478f84c.
FAILURE: 0xefb23c62 != 0xefb23c63 at offset 0x0478f850.
FAILURE: 0xefb23c62 != 0xefb23c63 at offset 0x0478f858.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x070cc94c.
FAILURE: 0xefb23c63 != 0xefb23c62 at offset 0x070cc958.
  Compare OR          :   Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : ok
  Walking Ones        : ok
  Walking Zeroes      : ok
Done.
