Hello All,
When a customer use the H.264 codec provided for DM6467 (DVSDK_2_00_00_18) to process a static video stream , the performance of the codec seems to be not so 'static'.
There can be some 23fps or 15 fps displayed among lots of 30 fps , even if there is no change to the input. And the timeval can jump from 128 to 349.
The information printed in the terminal are as follows.
Encode demo ARM Load: 1% DSP Load: 60% Display Type: 720P 50Hz Video Codec: H.264 BP Video fps: 30 fps Video bit rate: 299 kbps Video resolution: 1280x720 Sound codec: N/A Sound bit rate: 31 kbps Sampling freq: 16000 Time: 00:01:43
timeval = 128
timeval = 128
timeval = 128
timeval = 128
timeval = 128
timeval = 128
timeval = 128
timeval = 128
timeval = 127
Encode demo ARM Load: 4% DSP Load: 59% Display Type: 720P 50Hz Video Codec: H.264 BP Video fps: 30 fps Video bit rate: 423 kbps Video resolution: 1280x720 Sound codec: N/A Sound bit rate: 31 kbps Sampling freq: 16000 Time: 00:01:44
timeval = 129
timeval = 349
timeval = 6
timeval = 27
timeval = 128
timeval = 127
timeval = 128
timeval = 127
timeval = 129
timeval = 128
Encode demo ARM Load: 5% DSP Load: 56% Display Type: 720P 50Hz Video Codec: H.264 BP Video fps: 23 fps Video bit rate: 237 kbps Video resolution: 1280x720 Sound codec: N/A Sound bit rate: 34 kbps Sampling
Is it normal? Or what can lead to such a unregular performance?
Thanks in advance!
Willian
