Linux/TDA2EVM5777: Linux/TDA2xx: fail while building Vision SDK 3.05
Part Number: TDA2EVM5777
Other Parts Discussed in Thread: TEST2, INA226, TPS659037, SYSCONFIG, TVP5158, TLC59108, PGA460, SYSBIOS
Tool/software: Linux
make -s depend is ok,
make -s  is fail.
# Invoking configuro...
# Configuro done!
# Making tda2xx-evm:c66xdsp_1:release:vision_sdk_lib...
# Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
abnormal termination of /home/work/vision_sdk_test2/ti_components/cg_tools/linux/C6000_7.4.2/bin/cmp6x
make[7]: *** [/home/work/vision_sdk_test2/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.oe66] Error 1
make[6]: *** [c66xdsp_1] Error 2
make[5]: *** [apps_dsp1] Error 2
make[4]: *** [apps] Error 2
make[3]: *** [apps] Error 2
make[2]: *** [apps_exe] Error 2
make[1]: *** [apps] Error 2
make: *** [vision_sdk] Error 2
    Can you share the complete log in a text file.
    Rishabh
  • root@ubuntu:/home/work/vision_sdk_test/vision_sdk/build# make -s depend
    # makeconfig: Config is [ tda2xx_evm_linux_all ]
    # makeconfig: Output file is @ /home/work/vision_sdk_test/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all/system_cfg.h
    # makeconfig: Input file is @ /home/work/vision_sdk_test/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk
    # makeconfig: Generating header ...
    # makeconfig: Generating alg plugin config ...
    # makeconfig: Generating usecase config ...
    # makeconfig: Generating footer ...
    # makeconfig: Done !!!
    # CPUs that are NOT required but included in config [ tda2xx_evm_linux_all ],
    # CPUs that are required but not included in config [ tda2xx_evm_linux_all ],
    # ERROR: IPU1_0 MUST be included in application
    # Edit /home/work/vision_sdk_test/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk to include or exclude CPUs in an application
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:ipu2:release:edma3lld_drv
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:ipu2:release:edma3lld_rm
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:c66xdsp_1:release:edma3lld_drv
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:c66xdsp_1:release:edma3lld_rm
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:arp32_1:release:edma3lld_drv
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:arp32_1:release:edma3lld_rm
    Nothing to be done for tda2xx ipu1_0 csl_init
    Nothing to be done for tda2xx csl_intc
    # Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/interrupt.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ipu_wugen.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ammu.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/unicache.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:ipu1_0:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/m4/release/ti.csl.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:ipu1_0:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/m4/release/csl_utils_common.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:ipu1_0:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/m4/release/csl_uart_console.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:ipu1_0:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/m4/release/csl_utils_i2c.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:ipu1_0:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_hal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:ipu1_0:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_hal_optimized.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_m4.c
    # Archiving tda2xx:ipu1_0:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_m4.c
    # Archiving tda2xx:ipu1_0:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_lib_optimized.aem4 ...
    Nothing to be done for tda2xx pm_rtos
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_common.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_board.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_weak.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_platform.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_prcm_dpll.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_hs.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/lib/tda2xx-evm/m4/release/sbl_lib.aem4 ...
    Nothing to be done for tda2xx ipu1_0 sbl_utils
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_utils.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_ecc.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_eccEmif.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_eccOcmc.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_mcspi.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_can.c
    # Archiving tda2xx:ipu1_0:release:diag into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/diag/lib/tda2xx/m4/release/diag.aem4 ...
    # Compiling tda2xx:ipu1_0:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:ipu1_0:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:ipu1_0:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/m4/release/firewall_l3l4.aem4 ...
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu1_0:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu1_0/release/ipc_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:norflash_lib: src/nor_flash.c
    # Compiling tda2xx:ipu1_0:release:norflash_lib: src/debug.c
    # Archiving tda2xx:ipu1_0:release:norflash_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/norflash/lib/tda2xx/m4/release/norflash_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:qspiflash_lib: src/qspi_cmd_init.c
    # Compiling tda2xx:ipu1_0:release:qspiflash_lib: src/qspi_flash.c
    # Archiving tda2xx:ipu1_0:release:qspiflash_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/qspiflash/lib/tda2xx/m4/release/qspiflash_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda2xx:ipu1_0:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda2xx:ipu1_0:release:i2c_lld into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2xx/m4/release/i2c_lld.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/platform.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:ipu1_0:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/m4/release/stw_platform.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:ipu1_0:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:ipu1_0:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/m4/release/stw_uartconsole.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/fat_mmcsd.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: fatfs/ff.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/hs_mmcsdlib.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/mmcsd_proto.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/hsmmcsd_API.c
    # Archiving tda2xx:ipu1_0:release:stw_fatlib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2xx/m4/release/stw_fatlib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_fatlib_edma: fatlib_edma/hsmmcsd_edma.c
    # Archiving tda2xx:ipu1_0:release:stw_fatlib_edma into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2xx/m4/release/stw_fatlib_edma.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_board.c
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_boardTda2xx.c
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
    # Archiving tda2xx:ipu1_0:release:stw_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2xx/m4/release/stw_boards.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/stw_device.c
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda2xx:ipu1_0:release:stw_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2xx/m4/release/stw_devices.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:ipu1_0:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/m4/release/stw_examples_utility.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu1_0:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu1_0:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu1_0/release/vps_osal_baremetal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_common.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_utils.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_utilsQue.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/trace.c
    # Archiving tda2xx:ipu1_0:release:vps_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_common.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_csc.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_sc.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vpdma.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vipPort.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vipTop.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vpeTop.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dei.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_chrus.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcVid.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcOvly.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssHdmi.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_evtMgr.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_resrcMgr.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_graph.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vpslib_init.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vip.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipDefaults.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipVipControl.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeDei.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeApi.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeCommon.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeHal.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeWb.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dss.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrl.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlDefaults.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlGraph.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dssWb.c
    # Archiving tda2xx:ipu1_0:release:vpslib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpslib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_initDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_vipDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dctrlDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dssDrv.c
    # Archiving tda2xx:ipu1_0:release:vpsdrv_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpsdrv_baremetal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:fvid2: src/fvid2_drvMgr.c
    # Archiving tda2xx:ipu1_0:release:fvid2 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/fvid2.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:ipu1_0:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_osal_tirtos.aem4 ...
    Nothing to be done for tda2xx ipu1_0 vps_osal_tirtos_smp
    # Compiling tda2xx:ipu1_0:release:vpsdrv: src/vpsdrv_init.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: src/vpsdrv_control.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_capturePriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vps_mlm.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mSlice.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeFmd.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpePriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeReq.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayPriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_dctrl.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssPriv.c
    # Archiving tda2xx:ipu1_0:release:vpsdrv into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpsdrv.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_platforms: src/bsp_platform.c
    # Compiling tda2xx:ipu1_0:release:vps_platforms: src/bsp_platformTda2xx.c
    # Archiving tda2xx:ipu1_0:release:vps_platforms into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_platforms.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_devices: src/bsp_device.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: src/bsp_deviceI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov10x3xReg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_lcdCtrlApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_tc358778Ctrl.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tlc59108/src/bsp_tlc59108.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccReg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9022a/src/bspdrv_sii9022a.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ioexp/src/bspdrv_ioexpTca64xx.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: pga450/src/bspdrv_pga450.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: pga460/src/bspdrv_pga460.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_DOL_MIPI_4Lane.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_Linear.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx290/src/bspdrv_imx290Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xx.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxMcspiCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxGpioCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxOsalPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxUartCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxFmwPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar1243cfg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxCrc.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxInternal.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Reg.c
    # Archiving tda2xx:ipu1_0:release:vps_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_devices.aem4 ...
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_board.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda2xx.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda2ex.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda3xx.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:vps_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx-evm/m4/release/vps_boards.aem4 ...
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_app.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_buf.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mbx.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_tsk.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_prf.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem_default.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_tiler.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub960.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub95x.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_lvds.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_fileio.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_uart.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx-evm/m4/release/vps_examples_utility.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_i2c: src/bsp_i2cdrv.c
    # Archiving tda2xx:ipu1_0:release:bsp_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/i2c/lib/tda2xx/m4/release/bsp_i2c.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_uart: src/bspdrv_uart.c
    # Compiling tda2xx:ipu1_0:release:bsp_uart: src/bspdrv_uartEdma.c
    # Archiving tda2xx:ipu1_0:release:bsp_uart into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/uart/lib/tda2xx/m4/release/bsp_uart.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspi.c
    # Compiling tda2xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspiEdma.c
    # Archiving tda2xx:ipu1_0:release:bsp_mcspi into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/mcspi/lib/tda2xx/m4/release/bsp_mcspi.aem4 ...
    Nothing to be done for tda2xx ipu1_1 csl_init
    Nothing to be done for tda2xx ipu1_1 csl_utils_common
    Nothing to be done for tda2xx ipu1_1 csl_uart_console
    Nothing to be done for tda2xx ipu1_1 csl_utils_i2c
    Nothing to be done for tda2xx ipu1_1 pm_hal
    Nothing to be done for tda2xx ipu1_1 pm_hal_optimized
    Nothing to be done for tda2xx ipu1_1 pm_lib
    Nothing to be done for tda2xx ipu1_1 pm_lib_optimized
    Nothing to be done for tda2xx ipu1_1 sbl_lib
    Nothing to be done for tda2xx ipu1_1 sbl_utils
    Nothing to be done for tda2xx ipu1_1 diag
    Nothing to be done for tda2xx ipu1_1 firewall_l3l4
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu1_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu1_1/release/ipc_lib.aem4 ...
    Nothing to be done for tda2xx ipu1_1 norflash_lib
    Nothing to be done for tda2xx ipu1_1 qspiflash_lib
    Nothing to be done for tda2xx ipu1_1 i2c_lld
    Nothing to be done for tda2xx ipu1_1 stw_platform
    Nothing to be done for tda2xx ipu1_1 stw_uartconsole
    Nothing to be done for tda2xx ipu1_1 stw_fatlib
    Nothing to be done for tda2xx ipu1_1 stw_fatlib_edma
    Nothing to be done for tda2xx ipu1_1 stw_boards
    Nothing to be done for tda2xx ipu1_1 stw_devices
    Nothing to be done for tda2xx ipu1_1 stw_examples_utility
    # Compiling tda2xx:ipu1_1:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu1_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu1_1:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu1_1/release/vps_osal_baremetal.aem4 ...
    Nothing to be done for tda2xx ipu1_1 vps_common
    Nothing to be done for tda2xx ipu1_1 vpslib
    Nothing to be done for tda2xx ipu1_1 vpsdrv_baremetal
    Nothing to be done for tda2xx ipu1_1 fvid2
    Nothing to be done for tda2xx ipu1_1 vps_osal_tirtos
    Nothing to be done for tda2xx ipu1_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx ipu1_1 vps_platforms
    Nothing to be done for tda2xx ipu1_1 vps_devices
    Nothing to be done for tda2xx ipu1_1 vps_boards
    Nothing to be done for tda2xx ipu1_1 vps_examples_utility
    Nothing to be done for tda2xx ipu1_1 bsp_i2c
    Nothing to be done for tda2xx ipu1_1 bsp_uart
    Nothing to be done for tda2xx ipu1_1 bsp_mcspi
    Nothing to be done for tda2xx ipu2_0 csl_init
    Nothing to be done for tda2xx ipu2_0 csl_utils_common
    Nothing to be done for tda2xx ipu2_0 csl_uart_console
    Nothing to be done for tda2xx ipu2_0 csl_utils_i2c
    Nothing to be done for tda2xx ipu2_0 pm_hal
    Nothing to be done for tda2xx ipu2_0 pm_hal_optimized
    Nothing to be done for tda2xx ipu2_0 pm_lib
    Nothing to be done for tda2xx ipu2_0 pm_lib_optimized
    Nothing to be done for tda2xx ipu2_0 sbl_lib
    Nothing to be done for tda2xx ipu2_0 sbl_utils
    Nothing to be done for tda2xx ipu2_0 diag
    Nothing to be done for tda2xx ipu2_0 firewall_l3l4
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu2_0:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu2_0/release/ipc_lib.aem4 ...
    Nothing to be done for tda2xx ipu2_0 norflash_lib
    Nothing to be done for tda2xx ipu2_0 qspiflash_lib
    Nothing to be done for tda2xx ipu2_0 i2c_lld
    Nothing to be done for tda2xx ipu2_0 stw_platform
    Nothing to be done for tda2xx ipu2_0 stw_uartconsole
    Nothing to be done for tda2xx ipu2_0 stw_fatlib
    Nothing to be done for tda2xx ipu2_0 stw_fatlib_edma
    Nothing to be done for tda2xx ipu2_0 stw_boards
    Nothing to be done for tda2xx ipu2_0 stw_devices
    Nothing to be done for tda2xx ipu2_0 stw_examples_utility
    # Compiling tda2xx:ipu2_0:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu2_0:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu2_0:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu2_0/release/vps_osal_baremetal.aem4 ...
    Nothing to be done for tda2xx ipu2_0 vps_common
    Nothing to be done for tda2xx ipu2_0 vpslib
    Nothing to be done for tda2xx ipu2_0 vpsdrv_baremetal
    Nothing to be done for tda2xx ipu2_0 fvid2
    Nothing to be done for tda2xx ipu2_0 vps_osal_tirtos
    Nothing to be done for tda2xx ipu2_0 vps_osal_tirtos_smp
    Nothing to be done for tda2xx ipu2_0 vps_platforms
    Nothing to be done for tda2xx ipu2_0 vps_devices
    Nothing to be done for tda2xx ipu2_0 vps_boards
    Nothing to be done for tda2xx ipu2_0 vps_examples_utility
    Nothing to be done for tda2xx ipu2_0 bsp_i2c
    Nothing to be done for tda2xx ipu2_0 bsp_uart
    Nothing to be done for tda2xx ipu2_0 bsp_mcspi
    Nothing to be done for tda2xx c66x csl_init
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/intvecs.asm
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/swenr.asm
    # Compiling tda2xx:c66x:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:c66x:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/interrupt.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_wugen.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_config.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_ecc.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_icfg.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_usrSpvSupport.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_xmc.c
    # Compiling tda2xx:c66x:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:c66x:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:c66x:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:c66x:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:c66x:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:c66x:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:c66x:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:c66x:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:c66x:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:c66x:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:c66x:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:c66x:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:c66x:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:c66x:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:c66x:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:c66x:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:c66x:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/c66/release/ti.csl.ae66 ...
    # Compiling tda2xx:c66x:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:c66x:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/c66/release/csl_utils_common.ae66 ...
    # Compiling tda2xx:c66x:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:c66x:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/c66/release/csl_uart_console.ae66 ...
    # Compiling tda2xx:c66x:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:c66x:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/c66/release/csl_utils_i2c.ae66 ...
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:c66x:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_hal.ae66 ...
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:c66x:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_hal_optimized.ae66 ...
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda2xx:c66x:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_lib.ae66 ...
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda2xx:c66x:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_lib_optimized.ae66 ...
    Nothing to be done for tda2xx c66x sbl_lib
    Nothing to be done for tda2xx c66x sbl_utils
    Nothing to be done for tda2xx c66x diag
    # Compiling tda2xx:c66x:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:c66x:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:c66x:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/c66/release/firewall_l3l4.ae66 ...
    Nothing to be done for tda2xx c66x ipc_lib
    Nothing to be done for tda2xx c66x norflash_lib
    Nothing to be done for tda2xx c66x qspiflash_lib
    # Compiling tda2xx:c66x:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda2xx:c66x:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda2xx:c66x:release:i2c_lld into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2xx/c66/release/i2c_lld.ae66 ...
    # Compiling tda2xx:c66x:release:stw_platform: src/platform.c
    # Compiling tda2xx:c66x:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:c66x:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/c66/release/stw_platform.ae66 ...
    # Compiling tda2xx:c66x:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:c66x:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:c66x:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/c66/release/stw_uartconsole.ae66 ...
    Nothing to be done for tda2xx c66x stw_fatlib
    Nothing to be done for tda2xx c66x stw_fatlib_edma
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_board.c
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_boardTda2xx.c
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
    # Archiving tda2xx:c66x:release:stw_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2xx/c66/release/stw_boards.ae66 ...
    # Compiling tda2xx:c66x:release:stw_devices: src/stw_device.c
    # Compiling tda2xx:c66x:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda2xx:c66x:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda2xx:c66x:release:stw_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2xx/c66/release/stw_devices.ae66 ...
    # Compiling tda2xx:c66x:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:c66x:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/c66/release/stw_examples_utility.ae66 ...
    Nothing to be done for tda2xx c66x vps_osal_baremetal
    Nothing to be done for tda2xx c66x vps_common
    Nothing to be done for tda2xx c66x vpslib
    Nothing to be done for tda2xx c66x vpsdrv_baremetal
    Nothing to be done for tda2xx c66x fvid2
    # Compiling tda2xx:c66x:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:c66x:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66/release/vps_osal_tirtos.ae66 ...
    Nothing to be done for tda2xx c66x vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66x vps_platforms
    Nothing to be done for tda2xx c66x vps_devices
    Nothing to be done for tda2xx c66x vps_boards
    Nothing to be done for tda2xx c66x vps_examples_utility
    Nothing to be done for tda2xx c66x bsp_i2c
    Nothing to be done for tda2xx c66x bsp_uart
    Nothing to be done for tda2xx c66x bsp_mcspi
    Nothing to be done for tda2xx c66xdsp_1 csl_init
    Nothing to be done for tda2xx c66xdsp_1 csl_utils_common
    Nothing to be done for tda2xx c66xdsp_1 csl_uart_console
    Nothing to be done for tda2xx c66xdsp_1 csl_utils_i2c
    Nothing to be done for tda2xx c66xdsp_1 pm_hal
    Nothing to be done for tda2xx c66xdsp_1 pm_hal_optimized
    Nothing to be done for tda2xx c66xdsp_1 pm_lib
    Nothing to be done for tda2xx c66xdsp_1 pm_lib_optimized
    Nothing to be done for tda2xx c66xdsp_1 sbl_lib
    Nothing to be done for tda2xx c66xdsp_1 sbl_utils
    Nothing to be done for tda2xx c66xdsp_1 diag
    Nothing to be done for tda2xx c66xdsp_1 firewall_l3l4
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:c66xdsp_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/c66xdsp_1/release/ipc_lib.ae66 ...
    Nothing to be done for tda2xx c66xdsp_1 norflash_lib
    Nothing to be done for tda2xx c66xdsp_1 qspiflash_lib
    Nothing to be done for tda2xx c66xdsp_1 i2c_lld
    Nothing to be done for tda2xx c66xdsp_1 stw_platform
    Nothing to be done for tda2xx c66xdsp_1 stw_uartconsole
    Nothing to be done for tda2xx c66xdsp_1 stw_fatlib
    Nothing to be done for tda2xx c66xdsp_1 stw_fatlib_edma
    Nothing to be done for tda2xx c66xdsp_1 stw_boards
    Nothing to be done for tda2xx c66xdsp_1 stw_devices
    Nothing to be done for tda2xx c66xdsp_1 stw_examples_utility
    # Compiling tda2xx:c66xdsp_1:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:c66xdsp_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:c66xdsp_1:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66xdsp_1/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda2xx c66xdsp_1 vps_common
    Nothing to be done for tda2xx c66xdsp_1 vpslib
    Nothing to be done for tda2xx c66xdsp_1 vpsdrv_baremetal
    Nothing to be done for tda2xx c66xdsp_1 fvid2
    Nothing to be done for tda2xx c66xdsp_1 vps_osal_tirtos
    Nothing to be done for tda2xx c66xdsp_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66xdsp_1 vps_platforms
    Nothing to be done for tda2xx c66xdsp_1 vps_devices
    Nothing to be done for tda2xx c66xdsp_1 vps_boards
    Nothing to be done for tda2xx c66xdsp_1 vps_examples_utility
    Nothing to be done for tda2xx c66xdsp_1 bsp_i2c
    Nothing to be done for tda2xx c66xdsp_1 bsp_uart
    Nothing to be done for tda2xx c66xdsp_1 bsp_mcspi
    Nothing to be done for tda2xx c66xdsp_2 csl_init
    Nothing to be done for tda2xx c66xdsp_2 csl_utils_common
    Nothing to be done for tda2xx c66xdsp_2 csl_uart_console
    Nothing to be done for tda2xx c66xdsp_2 csl_utils_i2c
    Nothing to be done for tda2xx c66xdsp_2 pm_hal
    Nothing to be done for tda2xx c66xdsp_2 pm_hal_optimized
    Nothing to be done for tda2xx c66xdsp_2 pm_lib
    Nothing to be done for tda2xx c66xdsp_2 pm_lib_optimized
    Nothing to be done for tda2xx c66xdsp_2 sbl_lib
    Nothing to be done for tda2xx c66xdsp_2 sbl_utils
    Nothing to be done for tda2xx c66xdsp_2 diag
    Nothing to be done for tda2xx c66xdsp_2 firewall_l3l4
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:c66xdsp_2:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/c66xdsp_2/release/ipc_lib.ae66 ...
    Nothing to be done for tda2xx c66xdsp_2 norflash_lib
    Nothing to be done for tda2xx c66xdsp_2 qspiflash_lib
    Nothing to be done for tda2xx c66xdsp_2 i2c_lld
    Nothing to be done for tda2xx c66xdsp_2 stw_platform
    Nothing to be done for tda2xx c66xdsp_2 stw_uartconsole
    Nothing to be done for tda2xx c66xdsp_2 stw_fatlib
    Nothing to be done for tda2xx c66xdsp_2 stw_fatlib_edma
    Nothing to be done for tda2xx c66xdsp_2 stw_boards
    Nothing to be done for tda2xx c66xdsp_2 stw_devices
    Nothing to be done for tda2xx c66xdsp_2 stw_examples_utility
    # Compiling tda2xx:c66xdsp_2:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:c66xdsp_2:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:c66xdsp_2:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66xdsp_2/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda2xx c66xdsp_2 vps_common
    Nothing to be done for tda2xx c66xdsp_2 vpslib
    Nothing to be done for tda2xx c66xdsp_2 vpsdrv_baremetal
    Nothing to be done for tda2xx c66xdsp_2 fvid2
    Nothing to be done for tda2xx c66xdsp_2 vps_osal_tirtos
    Nothing to be done for tda2xx c66xdsp_2 vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66xdsp_2 vps_platforms
    Nothing to be done for tda2xx c66xdsp_2 vps_devices
    Nothing to be done for tda2xx c66xdsp_2 vps_boards
    Nothing to be done for tda2xx c66xdsp_2 vps_examples_utility
    Nothing to be done for tda2xx c66xdsp_2 bsp_i2c
    Nothing to be done for tda2xx c66xdsp_2 bsp_uart
    Nothing to be done for tda2xx c66xdsp_2 bsp_mcspi
    Nothing to be done for tda2xx arp32_1 csl_init
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/boot_arp32.asm
    # Compiling tda2xx:arp32_1:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:arp32_1:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/arp32_wugen.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/intctl.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/interrupt.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/inth.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:arp32_1:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/arp32/release/ti.csl.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:arp32_1:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/arp32/release/csl_utils_common.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:arp32_1:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/arp32/release/csl_uart_console.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:arp32_1:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/arp32/release/csl_utils_i2c.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:arp32_1:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_hal.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:arp32_1:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_hal_optimized.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda2xx:arp32_1:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_lib.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda2xx:arp32_1:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_lib_optimized.aearp32F ...
    Nothing to be done for tda2xx arp32_1 sbl_lib
    Nothing to be done for tda2xx arp32_1 sbl_utils
    Nothing to be done for tda2xx arp32_1 diag
    # Compiling tda2xx:arp32_1:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:arp32_1:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:arp32_1:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/arp32/release/firewall_l3l4.aearp32F ...
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_1/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_1 norflash_lib
    Nothing to be done for tda2xx arp32_1 qspiflash_lib
    Nothing to be done for tda2xx arp32_1 i2c_lld
    # Compiling tda2xx:arp32_1:release:stw_platform: src/platform.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:arp32_1:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/arp32/release/stw_platform.aearp32F ...
    # Compiling tda2xx:arp32_1:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:arp32_1:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:arp32_1:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/arp32/release/stw_uartconsole.aearp32F ...
    Nothing to be done for tda2xx arp32_1 stw_fatlib
    Nothing to be done for tda2xx arp32_1 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_1 stw_boards
    Nothing to be done for tda2xx arp32_1 stw_devices
    # Compiling tda2xx:arp32_1:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:arp32_1:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/arp32/release/stw_examples_utility.aearp32F ...
    Nothing to be done for tda2xx arp32_1 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_1 vps_common
    Nothing to be done for tda2xx arp32_1 vpslib
    Nothing to be done for tda2xx arp32_1 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_1 fvid2
    # Compiling tda2xx:arp32_1:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:arp32_1:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/arp32/release/vps_osal_tirtos.aearp32F ...
    Nothing to be done for tda2xx arp32_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_1 vps_platforms
    Nothing to be done for tda2xx arp32_1 vps_devices
    Nothing to be done for tda2xx arp32_1 vps_boards
    Nothing to be done for tda2xx arp32_1 vps_examples_utility
    Nothing to be done for tda2xx arp32_1 bsp_i2c
    Nothing to be done for tda2xx arp32_1 bsp_uart
    Nothing to be done for tda2xx arp32_1 bsp_mcspi
    Nothing to be done for tda2xx arp32_2 csl_init
    Nothing to be done for tda2xx csl_intc
    Nothing to be done for tda2xx arp32_2 csl_utils_common
    Nothing to be done for tda2xx arp32_2 csl_uart_console
    Nothing to be done for tda2xx arp32_2 csl_utils_i2c
    Nothing to be done for tda2xx arp32_2 pm_hal
    Nothing to be done for tda2xx arp32_2 pm_hal_optimized
    Nothing to be done for tda2xx arp32_2 pm_lib
    Nothing to be done for tda2xx arp32_2 pm_lib_optimized
    Nothing to be done for tda2xx arp32_2 sbl_lib
    Nothing to be done for tda2xx arp32_2 sbl_utils
    Nothing to be done for tda2xx arp32_2 diag
    Nothing to be done for tda2xx arp32_2 firewall_l3l4
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_2:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_2/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_2 norflash_lib
    Nothing to be done for tda2xx arp32_2 qspiflash_lib
    Nothing to be done for tda2xx arp32_2 i2c_lld
    Nothing to be done for tda2xx arp32_2 stw_platform
    Nothing to be done for tda2xx arp32_2 stw_uartconsole
    Nothing to be done for tda2xx arp32_2 stw_fatlib
    Nothing to be done for tda2xx arp32_2 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_2 stw_boards
    Nothing to be done for tda2xx arp32_2 stw_devices
    Nothing to be done for tda2xx arp32_2 stw_examples_utility
    Nothing to be done for tda2xx arp32_2 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_2 vps_common
    Nothing to be done for tda2xx arp32_2 vpslib
    Nothing to be done for tda2xx arp32_2 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_2 fvid2
    Nothing to be done for tda2xx arp32_2 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_2 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_2 vps_platforms
    Nothing to be done for tda2xx arp32_2 vps_devices
    Nothing to be done for tda2xx arp32_2 vps_boards
    Nothing to be done for tda2xx arp32_2 vps_examples_utility
    Nothing to be done for tda2xx arp32_2 bsp_i2c
    Nothing to be done for tda2xx arp32_2 bsp_uart
    Nothing to be done for tda2xx arp32_2 bsp_mcspi
    Nothing to be done for tda2xx arp32_3 csl_init
    Nothing to be done for tda2xx arp32_3 csl_utils_common
    Nothing to be done for tda2xx arp32_3 csl_uart_console
    Nothing to be done for tda2xx arp32_3 csl_utils_i2c
    Nothing to be done for tda2xx arp32_3 pm_hal
    Nothing to be done for tda2xx arp32_3 pm_hal_optimized
    Nothing to be done for tda2xx arp32_3 pm_lib
    Nothing to be done for tda2xx arp32_3 pm_lib_optimized
    Nothing to be done for tda2xx arp32_3 sbl_lib
    Nothing to be done for tda2xx arp32_3 sbl_utils
    Nothing to be done for tda2xx arp32_3 diag
    Nothing to be done for tda2xx arp32_3 firewall_l3l4
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_3:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_3/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_3 norflash_lib
    Nothing to be done for tda2xx arp32_3 qspiflash_lib
    Nothing to be done for tda2xx arp32_3 i2c_lld
    Nothing to be done for tda2xx arp32_3 stw_platform
    Nothing to be done for tda2xx arp32_3 stw_uartconsole
    Nothing to be done for tda2xx arp32_3 stw_fatlib
    Nothing to be done for tda2xx arp32_3 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_3 stw_boards
    Nothing to be done for tda2xx arp32_3 stw_devices
    Nothing to be done for tda2xx arp32_3 stw_examples_utility
    Nothing to be done for tda2xx arp32_3 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_3 vps_common
    Nothing to be done for tda2xx arp32_3 vpslib
    Nothing to be done for tda2xx arp32_3 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_3 fvid2
    Nothing to be done for tda2xx arp32_3 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_3 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_3 vps_platforms
    Nothing to be done for tda2xx arp32_3 vps_devices
    Nothing to be done for tda2xx arp32_3 vps_boards
    Nothing to be done for tda2xx arp32_3 vps_examples_utility
    Nothing to be done for tda2xx arp32_3 bsp_i2c
    Nothing to be done for tda2xx arp32_3 bsp_uart
    Nothing to be done for tda2xx arp32_3 bsp_mcspi
    Nothing to be done for tda2xx arp32_4 csl_init
    Nothing to be done for tda2xx arp32_4 csl_utils_common
    Nothing to be done for tda2xx arp32_4 csl_uart_console
    Nothing to be done for tda2xx arp32_4 csl_utils_i2c
    Nothing to be done for tda2xx arp32_4 pm_hal
    Nothing to be done for tda2xx arp32_4 pm_hal_optimized
    Nothing to be done for tda2xx arp32_4 pm_lib
    Nothing to be done for tda2xx arp32_4 pm_lib_optimized
    Nothing to be done for tda2xx pm_rtos
    Nothing to be done for tda2xx arp32_4 sbl_lib
    Nothing to be done for tda2xx arp32_4 sbl_utils
    Nothing to be done for tda2xx arp32_4 diag
    Nothing to be done for tda2xx arp32_4 firewall_l3l4
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_4:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_4/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_4 norflash_lib
    Nothing to be done for tda2xx arp32_4 qspiflash_lib
    Nothing to be done for tda2xx arp32_4 i2c_lld
    Nothing to be done for tda2xx arp32_4 stw_platform
    Nothing to be done for tda2xx arp32_4 stw_uartconsole
    Nothing to be done for tda2xx arp32_4 stw_fatlib
    Nothing to be done for tda2xx arp32_4 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_4 stw_boards
    Nothing to be done for tda2xx arp32_4 stw_devices
    Nothing to be done for tda2xx arp32_4 stw_examples_utility
    Nothing to be done for tda2xx arp32_4 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_4 vps_common
    Nothing to be done for tda2xx arp32_4 vpslib
    Nothing to be done for tda2xx arp32_4 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_4 fvid2
    Nothing to be done for tda2xx arp32_4 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_4 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_4 vps_platforms
    Nothing to be done for tda2xx arp32_4 vps_devices
    Nothing to be done for tda2xx arp32_4 vps_boards
    Nothing to be done for tda2xx arp32_4 vps_examples_utility
    Nothing to be done for tda2xx arp32_4 bsp_i2c
    Nothing to be done for tda2xx arp32_4 bsp_uart
    Nothing to be done for tda2xx arp32_4 bsp_mcspi
    # Depend tda2xx-evm:ipu2:release:links_common_algorithm
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_algorithm
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_1:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_2:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_3:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_4:release:links_common_algorithm
    # Depend tda2xx-evm:ipu2:release:links_common_dup
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_dup
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_dup
    # Depend tda2xx-evm:arp32_1:release:links_common_dup
    # Depend tda2xx-evm:arp32_2:release:links_common_dup
    # Depend tda2xx-evm:arp32_3:release:links_common_dup
    # Depend tda2xx-evm:arp32_4:release:links_common_dup
    # Depend tda2xx-evm:ipu2:release:links_common_gate
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_gate
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_gate
    # Depend tda2xx-evm:arp32_1:release:links_common_gate
    # Depend tda2xx-evm:arp32_2:release:links_common_gate
    # Depend tda2xx-evm:arp32_3:release:links_common_gate
    # Depend tda2xx-evm:arp32_4:release:links_common_gate
    # Depend tda2xx-evm:ipu2:release:links_common_ipcIn
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_1:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_2:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_3:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_4:release:links_common_ipcIn
    # Depend tda2xx-evm:ipu2:release:links_common_ipcOut
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_1:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_2:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_3:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_4:release:links_common_ipcOut
    # Depend tda2xx-evm:ipu2:release:links_common_merge
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_merge
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_merge
    # Depend tda2xx-evm:arp32_1:release:links_common_merge
    # Depend tda2xx-evm:arp32_2:release:links_common_merge
    # Depend tda2xx-evm:arp32_3:release:links_common_merge
    # Depend tda2xx-evm:arp32_4:release:links_common_merge
    # Depend tda2xx-evm:ipu2:release:links_common_null
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_null
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_null
    # Depend tda2xx-evm:arp32_1:release:links_common_null
    # Depend tda2xx-evm:arp32_2:release:links_common_null
    # Depend tda2xx-evm:arp32_3:release:links_common_null
    # Depend tda2xx-evm:arp32_4:release:links_common_null
    # Depend tda2xx-evm:ipu2:release:links_common_network_tx
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_network_tx
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_1:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_2:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_3:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_4:release:links_common_network_tx
    # Depend tda2xx-evm:ipu2:release:links_common_network_rx
    # Depend tda2xx-evm:ipu2:release:links_common_nullSrc
    # Depend tda2xx-evm:ipu2:release:links_common_select
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_select
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_select
    # Depend tda2xx-evm:arp32_1:release:links_common_select
    # Depend tda2xx-evm:arp32_2:release:links_common_select
    # Depend tda2xx-evm:arp32_3:release:links_common_select
    # Depend tda2xx-evm:arp32_4:release:links_common_select
    # Depend tda2xx-evm:ipu2:release:links_common_sync
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_sync
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_sync
    # Depend tda2xx-evm:arp32_1:release:links_common_sync
    # Depend tda2xx-evm:arp32_2:release:links_common_sync
    # Depend tda2xx-evm:arp32_3:release:links_common_sync
    # Depend tda2xx-evm:arp32_4:release:links_common_sync
    # Depend tda2xx-evm:ipu2:release:links_ipu_display
    # Depend tda2xx-evm:ipu2:release:links_ipu_display_ctrl
    # Depend tda2xx-evm:ipu2:release:links_ipu_iva
    # Depend tda2xx-evm:ipu2:release:links_ipu_vip_capture
    # Depend tda2xx-evm:ipu2:release:links_ipu_vpe
    # Depend tda2xx-evm:ipu2:release:links_ipu_dssM2mWb
    # Depend tda2xx-evm:ipu2:release:utils_common
    # Depend tda2xx-evm:c66xdsp_1:release:utils_common
    # Depend tda2xx-evm:c66xdsp_2:release:utils_common
    # Depend tda2xx-evm:arp32_1:release:utils_common
    # Depend tda2xx-evm:arp32_2:release:utils_common
    # Depend tda2xx-evm:arp32_3:release:utils_common
    # Depend tda2xx-evm:arp32_4:release:utils_common
    # Depend tda2xx-evm:ipu2:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_system
    # Depend tda2xx-evm:arp32_1:release:links_common_system
    # Depend tda2xx-evm:arp32_2:release:links_common_system
    # Depend tda2xx-evm:arp32_3:release:links_common_system
    # Depend tda2xx-evm:arp32_4:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_1:release:links_dsp_system
    # Depend tda2xx-evm:c66xdsp_2:release:links_dsp_system
    # Depend tda2xx-evm:arp32_1:release:links_eve_system
    # Depend tda2xx-evm:arp32_2:release:links_eve_system
    # Depend tda2xx-evm:arp32_3:release:links_eve_system
    # Depend tda2xx-evm:arp32_4:release:links_eve_system
    # Depend tda2xx-evm:ipu2:release:links_ipu_system
    root@ubuntu:/home/work/vision_sdk_test/vision_sdk/build# make -s
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_algorithm
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_algorithm
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_algorithm
    # Compiling tda2xx-evm:ipu2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_dup
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_dup
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_dup
    # Compiling tda2xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_dup
    # Compiling tda2xx-evm:arp32_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_dup
    # Compiling tda2xx-evm:arp32_3:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_dup
    # Compiling tda2xx-evm:arp32_4:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_dup
    # Compiling tda2xx-evm:ipu2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_gate
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_gate
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_gate
    # Compiling tda2xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_gate
    # Compiling tda2xx-evm:arp32_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_gate
    # Compiling tda2xx-evm:arp32_3:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_gate
    # Compiling tda2xx-evm:arp32_4:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_gate
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_ipcIn
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_ipcIn
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_ipcOut
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_ipcOut
    # Compiling tda2xx-evm:ipu2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_merge
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_merge
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_merge
    # Compiling tda2xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_merge
    # Compiling tda2xx-evm:arp32_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_merge
    # Compiling tda2xx-evm:arp32_3:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_merge
    # Compiling tda2xx-evm:arp32_4:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_merge
    # Compiling tda2xx-evm:ipu2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:ipu2:release:links_common_null
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_null
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_null
    # Compiling tda2xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_null
    # Compiling tda2xx-evm:arp32_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_null
    # Compiling tda2xx-evm:arp32_3:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_null
    # Compiling tda2xx-evm:arp32_4:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_null
    # Compiling tda2xx-evm:ipu2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_common_network_tx
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_network_tx
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_3:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_4:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_network_tx
    # Compiling tda2xx-evm:ipu2:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_common_network_rx
    # Compiling tda2xx-evm:ipu2:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda2xx-evm:ipu2:release:links_common_nullSrc
    # Compiling tda2xx-evm:ipu2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_select
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_select
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_select
    # Compiling tda2xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_select
    # Compiling tda2xx-evm:arp32_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_select
    # Compiling tda2xx-evm:arp32_3:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_select
    # Compiling tda2xx-evm:arp32_4:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_select
    # Compiling tda2xx-evm:ipu2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_sync
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_sync
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_sync
    # Compiling tda2xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_sync
    # Compiling tda2xx-evm:arp32_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_sync
    # Compiling tda2xx-evm:arp32_3:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_sync
    # Compiling tda2xx-evm:arp32_4:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_sync
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display: displayLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display: displayLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_display
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_display_ctrl
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/iresman_hdvicp2_fwif.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/utils_encdec.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/iresman_tiledmemory.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/hdvicp2_config.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_control.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_create.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_malloc.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_common.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_common.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_jpeg.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_h264.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_jpeg.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_h264.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_iva
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_subframe_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_vip_capture
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_drvCommon.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_vpe
    # Compiling tda2xx-evm:ipu2:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_dssM2mWb
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_l3_emif_bw.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_execp_trace_local_m4.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_uart.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_cbuf_ocmc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_qspi.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_idle_m4.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_temperature.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_stat_collector.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_prcm_stats.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_emif_ecc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mcspi.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mem_ipu1_0.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_cfg_ipu2.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/sci_config_dra7xx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_eveloader.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: eveloader/utils_eve_boot.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: file_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: file_api_dma.c
    # Archiving tda2xx-evm:ipu2:release:utils_common
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: network_api.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
    # Archiving tda2xx-evm:c66xdsp_1:release:utils_common
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
    # Archiving tda2xx-evm:c66xdsp_2:release:utils_common
    # Compiling tda2xx-evm:arp32_1:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_1:release:utils_common
    # Compiling tda2xx-evm:arp32_2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_2:release:utils_common
    # Compiling tda2xx-evm:arp32_3:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_3:release:utils_common
    # Compiling tda2xx-evm:arp32_4:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_4:release:utils_common
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:ipu2:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_system
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_system
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_system
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_system
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_dsp_system
    # Compiling tda2xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_dsp_system
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_eve_system
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_eve_system
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_eve_system
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_eve_system
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: system_bsp_init.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: system_ipu1_0.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_system
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font01.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font03.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font04.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font05.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font06.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font07.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font08.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font09.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font14.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_1.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_small.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo_small.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_3d_perception_sfm_logo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_220x330.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_228x432.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_288x432.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_suv_topView_348x480.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_tda2x.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_tda3x.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_left.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_right.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_left.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_right.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_green.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_red.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_echo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_device_comm.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_calib_image_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_dynamic_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_iss_raw_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_object_detect_set_dynamic_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_ipc.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:ipu2:release:app_alg_plugins
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignLUT_tda2xx.oe66' given more than once in the same rule
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignExt_tda2xx.oe66' given more than once in the same rule
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/acDetectLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/pEstimateLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/calMatGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyAlgoLocalDma.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmMainLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/dumpedSOFtestdata.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmLinearTwoViewLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmMapLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/synthesisLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignLUT_tda2xx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignExt_tda2xx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/pAlignLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/uFusionLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusionExt.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusion_bufferZonesLUT.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlignLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlign3DLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svLutGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svBlendTableGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/adaptiveBowlLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: commonutils/calmat.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:c66xdsp_1:release:app_alg_plugins
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/sample_vcop_array_add_uns_short_kernel.k
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyAlgoEve.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: sparseopticalflow/sparseOpticalFlowLink_algPlugin.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:arp32_1:release:app_alg_plugins
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_bios.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_linux.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_srv_calib_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sved_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sv_sof_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_OF_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_multiFCalg_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_stereo_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout2.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_fcAnalytics2_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sfm.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x2D3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3xRearView3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_metadata_draw.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_rvp_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_single_mbx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/link_stats_monitor/link_stats_monitor.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/lcd.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/hdmi_tx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/eth_cam.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_drv.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/devcontrol/devControl_handler.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_common_srv_calib.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_common_surround_view.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_lens.c
    # Archiving tda2xx-evm:ipu2:release:app_libs
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/ov10635/vid_sensor_ov10635.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/vid_sensor.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/hdmiRec/hdmi_recvr.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/tvp5158/video_decdr.c
    # Archiving tda2xx-evm:ipu2:release:video_sensor_libs
    # Invoking configuro...
    making package.mak (because of package.bld) ...
    # !!! Current build platform is [tda2xx-evm] !!!
    # !!! Core is [arp32_1] !!!
    generating interfaces for package vision_sdk_configuro (because package/package.xdc.inc is older than package.xdc) ...
    configuring MAIN_APP_eve1.xearp32F from package/cfg/MAIN_APP_eve1_pearp32F.cfg ...
    Loading Eve1.cfg for tda2xx-evm
    # !!! Including CPU #0 [ HOST ] in build !!!
    # !!! Including CPU #1 [ IPU2 ] in build !!!
    # !!! Including CPU #2 [ DSP1 ] in build !!!
    # !!! Including CPU #3 [ DSP2 ] in build !!!
    # !!! Including CPU #4 [ EVE1 ] in build !!!
    # !!! Including CPU #5 [ EVE2 ] in build !!!
    # !!! Including CPU #6 [ EVE3 ] in build !!!
    # !!! Including CPU #7 [ EVE4 ] in build !!!
    # !!! Host Proc ID is [1] !!!
    generating custom ti.sysbios library makefile ...
    generating custom ti.sdo.utils library makefile ...
    generating custom ti.sdo.ipc library makefile ...
    Starting build of library sources ...
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
    arearp32F Ipc.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
    arearp32F UTILS.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_switch_asm.sarp32 ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_disp_always.sarp32 ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/TaskSupport_asm.sarp32 ...
    arearp32F BIOS.obj arp32_Hwi_switch_asm.obj arp32_Hwi_disp_always.obj arp32_TaskSupport_asm.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
    Build of libraries done.
    # Configuro done!
    # Making tda2xx-evm:arp32_1:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: src/main_common_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: src/tlb_config_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve1/src/main_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve1_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F created.
    WARNING: The runtime version supported by this application is unavailable.
    Using default runtime: v4.0.30319
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.
    File conversion complete!
    # !!! Core is [arp32_2] !!!
    configuring MAIN_APP_eve2.xearp32F from package/cfg/MAIN_APP_eve2_pearp32F.cfg ...
    Loading Eve2.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_2:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: src/main_common_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: src/tlb_config_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve2/src/main_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve2_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.
    # !!! Core is [arp32_3] !!!
    configuring MAIN_APP_eve3.xearp32F from package/cfg/MAIN_APP_eve3_pearp32F.cfg ...
    Loading Eve3.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_3:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: src/main_common_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: src/tlb_config_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve3/src/main_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve3_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.
    # !!! Core is [arp32_4] !!!
    configuring MAIN_APP_eve4.xearp32F from package/cfg/MAIN_APP_eve4_pearp32F.cfg ...
    Loading Eve4.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_4:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: src/main_common_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: src/tlb_config_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve4/src/main_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve4_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.
    # !!! Core is [c66xdsp_1] !!!
    configuring MAIN_APP_c6xdsp1.xe66 from package/cfg/MAIN_APP_c6xdsp1_pe66.cfg ...
    Loading Dsp1.cfg for tda2xx-evm
    warning: xdc.cfg.Program: "/home/work/vision_sdk_test/ti_components/os_tools/linux/xdctools_3_32_01_22_core/packages/xdc/cfg/Program.xs", line 110: xdc.cfg.Program.SectionSpec#0 : Entry for the section '.bss:heapMemL2' in Program.sectMap is set to 'undefined'. This section allocation will be ignored.
    Warning: xdc.cfg.INCOMPATIBLE_TARGET_VERSION: the compiler version [7.4.2] used by the current target 'ti.targets.elf.C66' is not compatible with compiler version of targets used to build the following packages; package ti.deh [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/deh/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.ipc.ipcmgr [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/ipc/ipcmgr/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.ipc.rpmsg [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/ipc/rpmsg/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.trace [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/trace/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.pm [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/pm/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
    are66 Ipc.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
    are66 UTILS.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
    are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj c62_TaskSupport_asm.obj ti_tls_get_tp.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:c66xdsp_1:release:vision_sdk_lib...
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/dsp1/src/main_c6xdsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_dsp.c
    # Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
    abnormal termination of /home/work/vision_sdk_test/ti_components/cg_tools/linux/C6000_7.4.2/bin/cmp6x
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:334: recipe for target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.oe66' failed
    make[7]: *** [/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.oe66] Error 1
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/common.mk:271: recipe for target 'c66xdsp_1' failed
    make[6]: *** [c66xdsp_1] Error 2
    MAKEFILE.MK:116: recipe for target 'apps_dsp1' failed
    make[5]: *** [apps_dsp1] Error 2
    MAKEFILE.MK:31: recipe for target 'apps' failed
    make[4]: *** [apps] Error 2
    MAKEFILE.MK:298: recipe for target 'apps' failed
    make[3]: *** [apps] Error 2
    Makefile:171: recipe for target 'apps_exe' failed
    make[2]: *** [apps_exe] Error 2
    Makefile:36: recipe for target 'apps' failed
    make[1]: *** [apps] Error 2
    Makefile:12: recipe for target 'vision_sdk' failed
    make: *** [vision_sdk] Error 2
  • setenv bootfile zImage
    setenv server_ip 172.16.34.104
    setenv client_ip 172.16.34.10
    setenv root_dir /home/nfs_hlos
    setenv gw_ip 172.16.34.1
    setenv netmask 255.255.255.0
    setenv nfsrootfstype ext4 rootwait fixrtc
    setenv nfsroot ${server_ip}:${root_dir}${nfs_options};
    setenv ip ${client_ip}:${server_ip}:${gw_ip}:${netmask}:${hostname}:eth0:off;
    setenv serverip ${server_ip};
    setenv ipaddr ${client_ip};
    setenv fdtfile dra7-evm-infoadas.dtb
    setenv ethaddr 00:00:0a:00:00:c5
    setenv nfsargs setenv bootargs console=${console} ${optargs} ${cape_disable} ${cape_enable} root=/dev/nfs rw rootfstype=${nfsrootfstype} nfsroot=${nfsroot} ip=${ip} ${cmdline}
    setenv nfsboot "echo Booting from ${server_ip}...;setenv autoload no;tftp ${loadaddr} ${bootfile};tftp ${fdtaddr} ${fdtfile};run nfsargs;bootz ${loadaddr} - ${fdtaddr}"
    run nfsboot
  • root@ubuntu:/home/work/vision_sdk_test/vision_sdk/build# make -s depend
    # makeconfig: Config is [ tda2xx_evm_linux_all ]
    # makeconfig: Output file is @ /home/work/vision_sdk_test/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all/system_cfg.h
    # makeconfig: Input file is @ /home/work/vision_sdk_test/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk
    # makeconfig: Generating header ...
    # makeconfig: Generating alg plugin config ...
    # makeconfig: Generating usecase config ...
    # makeconfig: Generating footer ...
    # makeconfig: Done !!!
    # CPUs that are NOT required but included in config [ tda2xx_evm_linux_all ],
    # CPUs that are required but not included in config [ tda2xx_evm_linux_all ],
    # ERROR: IPU1_0 MUST be included in application
    # Edit /home/work/vision_sdk_test/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk to include or exclude CPUs in an application
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:ipu2:release:edma3lld_drv
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:ipu2:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:ipu2:release:edma3lld_rm
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:c66xdsp_1:release:edma3lld_drv
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:c66xdsp_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:c66xdsp_1:release:edma3lld_rm
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda2xx-evm:arp32_1:release:edma3lld_drv
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda2xx-evm:arp32_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
    # Archiving tda2xx-evm:arp32_1:release:edma3lld_rm
    Nothing to be done for tda2xx ipu1_0 csl_init
    Nothing to be done for tda2xx csl_intc
    # Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:ipu1_0:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/interrupt.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ipu_wugen.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/ammu.c
    # Compiling tda2xx:ipu1_0:release:csl: ./arch/m4/src/unicache.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:ipu1_0:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:ipu1_0:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/m4/release/ti.csl.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:ipu1_0:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/m4/release/csl_utils_common.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:ipu1_0:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/m4/release/csl_uart_console.aem4 ...
    # Compiling tda2xx:ipu1_0:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:ipu1_0:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/m4/release/csl_utils_i2c.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:ipu1_0:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:ipu1_0:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_hal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:ipu1_0:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_hal_optimized.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_m4.c
    # Archiving tda2xx:ipu1_0:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_m4.c
    # Archiving tda2xx:ipu1_0:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/m4/release/pm_lib_optimized.aem4 ...
    Nothing to be done for tda2xx pm_rtos
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_common.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_board.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/sbl_lib_weak.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_platform.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_prcm_dpll.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_hs.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:sbl_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/lib/tda2xx-evm/m4/release/sbl_lib.aem4 ...
    Nothing to be done for tda2xx ipu1_0 sbl_utils
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_utils.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_ecc.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_eccEmif.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_eccOcmc.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_mcspi.c
    # Compiling tda2xx:ipu1_0:release:diag: src/diagLib_can.c
    # Archiving tda2xx:ipu1_0:release:diag into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/diag/lib/tda2xx/m4/release/diag.aem4 ...
    # Compiling tda2xx:ipu1_0:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:ipu1_0:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:ipu1_0:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/m4/release/firewall_l3l4.aem4 ...
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu1_0:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu1_0:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu1_0/release/ipc_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:norflash_lib: src/nor_flash.c
    # Compiling tda2xx:ipu1_0:release:norflash_lib: src/debug.c
    # Archiving tda2xx:ipu1_0:release:norflash_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/norflash/lib/tda2xx/m4/release/norflash_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:qspiflash_lib: src/qspi_cmd_init.c
    # Compiling tda2xx:ipu1_0:release:qspiflash_lib: src/qspi_flash.c
    # Archiving tda2xx:ipu1_0:release:qspiflash_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/qspiflash/lib/tda2xx/m4/release/qspiflash_lib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda2xx:ipu1_0:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda2xx:ipu1_0:release:i2c_lld into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2xx/m4/release/i2c_lld.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/platform.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:ipu1_0:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:ipu1_0:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/m4/release/stw_platform.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:ipu1_0:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:ipu1_0:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/m4/release/stw_uartconsole.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/fat_mmcsd.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: fatfs/ff.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/hs_mmcsdlib.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/mmcsd_proto.c
    # Compiling tda2xx:ipu1_0:release:stw_fatlib: src/hsmmcsd_API.c
    # Archiving tda2xx:ipu1_0:release:stw_fatlib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2xx/m4/release/stw_fatlib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_fatlib_edma: fatlib_edma/hsmmcsd_edma.c
    # Archiving tda2xx:ipu1_0:release:stw_fatlib_edma into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2xx/m4/release/stw_fatlib_edma.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_board.c
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_boardTda2xx.c
    # Compiling tda2xx:ipu1_0:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
    # Archiving tda2xx:ipu1_0:release:stw_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2xx/m4/release/stw_boards.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/stw_device.c
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda2xx:ipu1_0:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda2xx:ipu1_0:release:stw_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2xx/m4/release/stw_devices.aem4 ...
    # Compiling tda2xx:ipu1_0:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:ipu1_0:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/m4/release/stw_examples_utility.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu1_0:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu1_0:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu1_0/release/vps_osal_baremetal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_common.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_utils.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/bsp_utilsQue.c
    # Compiling tda2xx:ipu1_0:release:vps_common: src/trace.c
    # Archiving tda2xx:ipu1_0:release:vps_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_common.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_csc.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_sc.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vpdma.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vipPort.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vipTop.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_vpeTop.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dei.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_chrus.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcVid.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcOvly.c
    # Compiling tda2xx:ipu1_0:release:vpslib: hal/src/vpshal_dssHdmi.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_evtMgr.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_resrcMgr.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vps_graph.c
    # Compiling tda2xx:ipu1_0:release:vpslib: common/src/vpslib_init.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vip.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipDefaults.c
    # Compiling tda2xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipVipControl.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeDei.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeApi.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeCommon.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeHal.c
    # Compiling tda2xx:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeWb.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dss.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrl.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlDefaults.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlGraph.c
    # Compiling tda2xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dssWb.c
    # Archiving tda2xx:ipu1_0:release:vpslib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpslib.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_initDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_vipDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dctrlDrv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dssDrv.c
    # Archiving tda2xx:ipu1_0:release:vpsdrv_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpsdrv_baremetal.aem4 ...
    # Compiling tda2xx:ipu1_0:release:fvid2: src/fvid2_drvMgr.c
    # Archiving tda2xx:ipu1_0:release:fvid2 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/fvid2.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:ipu1_0:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_osal_tirtos.aem4 ...
    Nothing to be done for tda2xx ipu1_0 vps_osal_tirtos_smp
    # Compiling tda2xx:ipu1_0:release:vpsdrv: src/vpsdrv_init.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: src/vpsdrv_control.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_capturePriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vps_mlm.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mSlice.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeFmd.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpePriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeReq.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayPriv.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_dctrl.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssApi.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssCore.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssProc.c
    # Compiling tda2xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssPriv.c
    # Archiving tda2xx:ipu1_0:release:vpsdrv into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vpsdrv.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_platforms: src/bsp_platform.c
    # Compiling tda2xx:ipu1_0:release:vps_platforms: src/bsp_platformTda2xx.c
    # Archiving tda2xx:ipu1_0:release:vps_platforms into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_platforms.aem4 ...
    # Compiling tda2xx:ipu1_0:release:vps_devices: src/bsp_device.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: src/bsp_deviceI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov10x3xReg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_lcdCtrlApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_tc358778Ctrl.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: tlc59108/src/bsp_tlc59108.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccApi.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccI2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccReg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: sii9022a/src/bspdrv_sii9022a.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ioexp/src/bspdrv_ioexpTca64xx.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: pga450/src/bspdrv_pga450.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: pga460/src/bspdrv_pga460.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_DOL_MIPI_4Lane.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_Linear.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: imx290/src/bspdrv_imx290Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Reg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xx.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxMcspiCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxGpioCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxOsalPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxUartCfgPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxFmwPriv.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar1243cfg.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxCrc.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxInternal.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Api.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490I2c.c
    # Compiling tda2xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Reg.c
    # Archiving tda2xx:ipu1_0:release:vps_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/m4/release/vps_devices.aem4 ...
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_board.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda2xx.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda2ex.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_boards: src/bsp_boardTda3xx.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:vps_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx-evm/m4/release/vps_boards.aem4 ...
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_app.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_buf.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mbx.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_tsk.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_prf.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem_default.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_tiler.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub960.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub95x.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_lvds.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_fileio.c
    # Compiling tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility: src/bsputils_uart.c
    # Archiving tda2xx-evm:tda2xx:ipu1_0:release:vps_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx-evm/m4/release/vps_examples_utility.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_i2c: src/bsp_i2cdrv.c
    # Archiving tda2xx:ipu1_0:release:bsp_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/i2c/lib/tda2xx/m4/release/bsp_i2c.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_uart: src/bspdrv_uart.c
    # Compiling tda2xx:ipu1_0:release:bsp_uart: src/bspdrv_uartEdma.c
    # Archiving tda2xx:ipu1_0:release:bsp_uart into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/uart/lib/tda2xx/m4/release/bsp_uart.aem4 ...
    # Compiling tda2xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspi.c
    # Compiling tda2xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspiEdma.c
    # Archiving tda2xx:ipu1_0:release:bsp_mcspi into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/mcspi/lib/tda2xx/m4/release/bsp_mcspi.aem4 ...
    Nothing to be done for tda2xx ipu1_1 csl_init
    Nothing to be done for tda2xx ipu1_1 csl_utils_common
    Nothing to be done for tda2xx ipu1_1 csl_uart_console
    Nothing to be done for tda2xx ipu1_1 csl_utils_i2c
    Nothing to be done for tda2xx ipu1_1 pm_hal
    Nothing to be done for tda2xx ipu1_1 pm_hal_optimized
    Nothing to be done for tda2xx ipu1_1 pm_lib
    Nothing to be done for tda2xx ipu1_1 pm_lib_optimized
    Nothing to be done for tda2xx ipu1_1 sbl_lib
    Nothing to be done for tda2xx ipu1_1 sbl_utils
    Nothing to be done for tda2xx ipu1_1 diag
    Nothing to be done for tda2xx ipu1_1 firewall_l3l4
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu1_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu1_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu1_1/release/ipc_lib.aem4 ...
    Nothing to be done for tda2xx ipu1_1 norflash_lib
    Nothing to be done for tda2xx ipu1_1 qspiflash_lib
    Nothing to be done for tda2xx ipu1_1 i2c_lld
    Nothing to be done for tda2xx ipu1_1 stw_platform
    Nothing to be done for tda2xx ipu1_1 stw_uartconsole
    Nothing to be done for tda2xx ipu1_1 stw_fatlib
    Nothing to be done for tda2xx ipu1_1 stw_fatlib_edma
    Nothing to be done for tda2xx ipu1_1 stw_boards
    Nothing to be done for tda2xx ipu1_1 stw_devices
    Nothing to be done for tda2xx ipu1_1 stw_examples_utility
    # Compiling tda2xx:ipu1_1:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu1_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu1_1:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu1_1/release/vps_osal_baremetal.aem4 ...
    Nothing to be done for tda2xx ipu1_1 vps_common
    Nothing to be done for tda2xx ipu1_1 vpslib
    Nothing to be done for tda2xx ipu1_1 vpsdrv_baremetal
    Nothing to be done for tda2xx ipu1_1 fvid2
    Nothing to be done for tda2xx ipu1_1 vps_osal_tirtos
    Nothing to be done for tda2xx ipu1_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx ipu1_1 vps_platforms
    Nothing to be done for tda2xx ipu1_1 vps_devices
    Nothing to be done for tda2xx ipu1_1 vps_boards
    Nothing to be done for tda2xx ipu1_1 vps_examples_utility
    Nothing to be done for tda2xx ipu1_1 bsp_i2c
    Nothing to be done for tda2xx ipu1_1 bsp_uart
    Nothing to be done for tda2xx ipu1_1 bsp_mcspi
    Nothing to be done for tda2xx ipu2_0 csl_init
    Nothing to be done for tda2xx ipu2_0 csl_utils_common
    Nothing to be done for tda2xx ipu2_0 csl_uart_console
    Nothing to be done for tda2xx ipu2_0 csl_utils_i2c
    Nothing to be done for tda2xx ipu2_0 pm_hal
    Nothing to be done for tda2xx ipu2_0 pm_hal_optimized
    Nothing to be done for tda2xx ipu2_0 pm_lib
    Nothing to be done for tda2xx ipu2_0 pm_lib_optimized
    Nothing to be done for tda2xx ipu2_0 sbl_lib
    Nothing to be done for tda2xx ipu2_0 sbl_utils
    Nothing to be done for tda2xx ipu2_0 diag
    Nothing to be done for tda2xx ipu2_0 firewall_l3l4
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:ipu2_0:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:ipu2_0:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/ipu2_0/release/ipc_lib.aem4 ...
    Nothing to be done for tda2xx ipu2_0 norflash_lib
    Nothing to be done for tda2xx ipu2_0 qspiflash_lib
    Nothing to be done for tda2xx ipu2_0 i2c_lld
    Nothing to be done for tda2xx ipu2_0 stw_platform
    Nothing to be done for tda2xx ipu2_0 stw_uartconsole
    Nothing to be done for tda2xx ipu2_0 stw_fatlib
    Nothing to be done for tda2xx ipu2_0 stw_fatlib_edma
    Nothing to be done for tda2xx ipu2_0 stw_boards
    Nothing to be done for tda2xx ipu2_0 stw_devices
    Nothing to be done for tda2xx ipu2_0 stw_examples_utility
    # Compiling tda2xx:ipu2_0:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:ipu2_0:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:ipu2_0:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/ipu2_0/release/vps_osal_baremetal.aem4 ...
    Nothing to be done for tda2xx ipu2_0 vps_common
    Nothing to be done for tda2xx ipu2_0 vpslib
    Nothing to be done for tda2xx ipu2_0 vpsdrv_baremetal
    Nothing to be done for tda2xx ipu2_0 fvid2
    Nothing to be done for tda2xx ipu2_0 vps_osal_tirtos
    Nothing to be done for tda2xx ipu2_0 vps_osal_tirtos_smp
    Nothing to be done for tda2xx ipu2_0 vps_platforms
    Nothing to be done for tda2xx ipu2_0 vps_devices
    Nothing to be done for tda2xx ipu2_0 vps_boards
    Nothing to be done for tda2xx ipu2_0 vps_examples_utility
    Nothing to be done for tda2xx ipu2_0 bsp_i2c
    Nothing to be done for tda2xx ipu2_0 bsp_uart
    Nothing to be done for tda2xx ipu2_0 bsp_mcspi
    Nothing to be done for tda2xx c66x csl_init
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/intvecs.asm
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/swenr.asm
    # Compiling tda2xx:c66x:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:c66x:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/interrupt.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_wugen.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_config.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_ecc.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_icfg.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_usrSpvSupport.c
    # Compiling tda2xx:c66x:release:csl: ./arch/c66x/src/dsp_xmc.c
    # Compiling tda2xx:c66x:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:c66x:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:c66x:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:c66x:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:c66x:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:c66x:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:c66x:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:c66x:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:c66x:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:c66x:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:c66x:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:c66x:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:c66x:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:c66x:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:c66x:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:c66x:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:c66x:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:c66x:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/c66/release/ti.csl.ae66 ...
    # Compiling tda2xx:c66x:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:c66x:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/c66/release/csl_utils_common.ae66 ...
    # Compiling tda2xx:c66x:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:c66x:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/c66/release/csl_uart_console.ae66 ...
    # Compiling tda2xx:c66x:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:c66x:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/c66/release/csl_utils_i2c.ae66 ...
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:c66x:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:c66x:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_hal.ae66 ...
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:c66x:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_hal_optimized.ae66 ...
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:c66x:release:pm_lib: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda2xx:c66x:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_lib.ae66 ...
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:c66x:release:pm_lib_optimized: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda2xx:c66x:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/c66/release/pm_lib_optimized.ae66 ...
    Nothing to be done for tda2xx c66x sbl_lib
    Nothing to be done for tda2xx c66x sbl_utils
    Nothing to be done for tda2xx c66x diag
    # Compiling tda2xx:c66x:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:c66x:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:c66x:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/c66/release/firewall_l3l4.ae66 ...
    Nothing to be done for tda2xx c66x ipc_lib
    Nothing to be done for tda2xx c66x norflash_lib
    Nothing to be done for tda2xx c66x qspiflash_lib
    # Compiling tda2xx:c66x:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda2xx:c66x:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda2xx:c66x:release:i2c_lld into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2xx/c66/release/i2c_lld.ae66 ...
    # Compiling tda2xx:c66x:release:stw_platform: src/platform.c
    # Compiling tda2xx:c66x:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:c66x:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:c66x:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/c66/release/stw_platform.ae66 ...
    # Compiling tda2xx:c66x:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:c66x:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:c66x:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/c66/release/stw_uartconsole.ae66 ...
    Nothing to be done for tda2xx c66x stw_fatlib
    Nothing to be done for tda2xx c66x stw_fatlib_edma
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_board.c
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_boardTda2xx.c
    # Compiling tda2xx:c66x:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
    # Archiving tda2xx:c66x:release:stw_boards into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2xx/c66/release/stw_boards.ae66 ...
    # Compiling tda2xx:c66x:release:stw_devices: src/stw_device.c
    # Compiling tda2xx:c66x:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda2xx:c66x:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda2xx:c66x:release:stw_devices into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2xx/c66/release/stw_devices.ae66 ...
    # Compiling tda2xx:c66x:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:c66x:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/c66/release/stw_examples_utility.ae66 ...
    Nothing to be done for tda2xx c66x vps_osal_baremetal
    Nothing to be done for tda2xx c66x vps_common
    Nothing to be done for tda2xx c66x vpslib
    Nothing to be done for tda2xx c66x vpsdrv_baremetal
    Nothing to be done for tda2xx c66x fvid2
    # Compiling tda2xx:c66x:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:c66x:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66/release/vps_osal_tirtos.ae66 ...
    Nothing to be done for tda2xx c66x vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66x vps_platforms
    Nothing to be done for tda2xx c66x vps_devices
    Nothing to be done for tda2xx c66x vps_boards
    Nothing to be done for tda2xx c66x vps_examples_utility
    Nothing to be done for tda2xx c66x bsp_i2c
    Nothing to be done for tda2xx c66x bsp_uart
    Nothing to be done for tda2xx c66x bsp_mcspi
    Nothing to be done for tda2xx c66xdsp_1 csl_init
    Nothing to be done for tda2xx c66xdsp_1 csl_utils_common
    Nothing to be done for tda2xx c66xdsp_1 csl_uart_console
    Nothing to be done for tda2xx c66xdsp_1 csl_utils_i2c
    Nothing to be done for tda2xx c66xdsp_1 pm_hal
    Nothing to be done for tda2xx c66xdsp_1 pm_hal_optimized
    Nothing to be done for tda2xx c66xdsp_1 pm_lib
    Nothing to be done for tda2xx c66xdsp_1 pm_lib_optimized
    Nothing to be done for tda2xx c66xdsp_1 sbl_lib
    Nothing to be done for tda2xx c66xdsp_1 sbl_utils
    Nothing to be done for tda2xx c66xdsp_1 diag
    Nothing to be done for tda2xx c66xdsp_1 firewall_l3l4
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:c66xdsp_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:c66xdsp_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/c66xdsp_1/release/ipc_lib.ae66 ...
    Nothing to be done for tda2xx c66xdsp_1 norflash_lib
    Nothing to be done for tda2xx c66xdsp_1 qspiflash_lib
    Nothing to be done for tda2xx c66xdsp_1 i2c_lld
    Nothing to be done for tda2xx c66xdsp_1 stw_platform
    Nothing to be done for tda2xx c66xdsp_1 stw_uartconsole
    Nothing to be done for tda2xx c66xdsp_1 stw_fatlib
    Nothing to be done for tda2xx c66xdsp_1 stw_fatlib_edma
    Nothing to be done for tda2xx c66xdsp_1 stw_boards
    Nothing to be done for tda2xx c66xdsp_1 stw_devices
    Nothing to be done for tda2xx c66xdsp_1 stw_examples_utility
    # Compiling tda2xx:c66xdsp_1:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:c66xdsp_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:c66xdsp_1:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66xdsp_1/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda2xx c66xdsp_1 vps_common
    Nothing to be done for tda2xx c66xdsp_1 vpslib
    Nothing to be done for tda2xx c66xdsp_1 vpsdrv_baremetal
    Nothing to be done for tda2xx c66xdsp_1 fvid2
    Nothing to be done for tda2xx c66xdsp_1 vps_osal_tirtos
    Nothing to be done for tda2xx c66xdsp_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66xdsp_1 vps_platforms
    Nothing to be done for tda2xx c66xdsp_1 vps_devices
    Nothing to be done for tda2xx c66xdsp_1 vps_boards
    Nothing to be done for tda2xx c66xdsp_1 vps_examples_utility
    Nothing to be done for tda2xx c66xdsp_1 bsp_i2c
    Nothing to be done for tda2xx c66xdsp_1 bsp_uart
    Nothing to be done for tda2xx c66xdsp_1 bsp_mcspi
    Nothing to be done for tda2xx c66xdsp_2 csl_init
    Nothing to be done for tda2xx c66xdsp_2 csl_utils_common
    Nothing to be done for tda2xx c66xdsp_2 csl_uart_console
    Nothing to be done for tda2xx c66xdsp_2 csl_utils_i2c
    Nothing to be done for tda2xx c66xdsp_2 pm_hal
    Nothing to be done for tda2xx c66xdsp_2 pm_hal_optimized
    Nothing to be done for tda2xx c66xdsp_2 pm_lib
    Nothing to be done for tda2xx c66xdsp_2 pm_lib_optimized
    Nothing to be done for tda2xx c66xdsp_2 sbl_lib
    Nothing to be done for tda2xx c66xdsp_2 sbl_utils
    Nothing to be done for tda2xx c66xdsp_2 diag
    Nothing to be done for tda2xx c66xdsp_2 firewall_l3l4
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:c66xdsp_2:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:c66xdsp_2:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/c66xdsp_2/release/ipc_lib.ae66 ...
    Nothing to be done for tda2xx c66xdsp_2 norflash_lib
    Nothing to be done for tda2xx c66xdsp_2 qspiflash_lib
    Nothing to be done for tda2xx c66xdsp_2 i2c_lld
    Nothing to be done for tda2xx c66xdsp_2 stw_platform
    Nothing to be done for tda2xx c66xdsp_2 stw_uartconsole
    Nothing to be done for tda2xx c66xdsp_2 stw_fatlib
    Nothing to be done for tda2xx c66xdsp_2 stw_fatlib_edma
    Nothing to be done for tda2xx c66xdsp_2 stw_boards
    Nothing to be done for tda2xx c66xdsp_2 stw_devices
    Nothing to be done for tda2xx c66xdsp_2 stw_examples_utility
    # Compiling tda2xx:c66xdsp_2:release:vps_osal_baremetal: osal.c
    # Compiling tda2xx:c66xdsp_2:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda2xx:c66xdsp_2:release:vps_osal_baremetal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/c66xdsp_2/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda2xx c66xdsp_2 vps_common
    Nothing to be done for tda2xx c66xdsp_2 vpslib
    Nothing to be done for tda2xx c66xdsp_2 vpsdrv_baremetal
    Nothing to be done for tda2xx c66xdsp_2 fvid2
    Nothing to be done for tda2xx c66xdsp_2 vps_osal_tirtos
    Nothing to be done for tda2xx c66xdsp_2 vps_osal_tirtos_smp
    Nothing to be done for tda2xx c66xdsp_2 vps_platforms
    Nothing to be done for tda2xx c66xdsp_2 vps_devices
    Nothing to be done for tda2xx c66xdsp_2 vps_boards
    Nothing to be done for tda2xx c66xdsp_2 vps_examples_utility
    Nothing to be done for tda2xx c66xdsp_2 bsp_i2c
    Nothing to be done for tda2xx c66xdsp_2 bsp_uart
    Nothing to be done for tda2xx c66xdsp_2 bsp_mcspi
    Nothing to be done for tda2xx arp32_1 csl_init
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/boot_arp32.asm
    # Compiling tda2xx:arp32_1:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda2xx:arp32_1:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/arp32_wugen.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/intctl.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/interrupt.c
    # Compiling tda2xx:arp32_1:release:csl: ./arch/arp32/src/inth.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/uart/V1/priv/uart.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
    # Compiling tda2xx:arp32_1:release:csl: src/ip/pcie/V1/priv/pcie.c
    # Archiving tda2xx:arp32_1:release:csl into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2xx/arp32/release/ti.csl.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda2xx:arp32_1:release:csl_utils_common into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2xx/arp32/release/csl_utils_common.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda2xx:arp32_1:release:csl_uart_console into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2xx/arp32/release/csl_uart_console.aearp32F ...
    # Compiling tda2xx:arp32_1:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda2xx:arp32_1:release:csl_utils_i2c into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2xx/arp32/release/csl_utils_i2c.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pm_utils.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_ina226.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps659039.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda2xx:arp32_1:release:pm_hal: prcm/pmhal_tps659037.c
    # Archiving tda2xx:arp32_1:release:pm_hal into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_hal.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_vmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_data_names.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_bgap_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_prmdata.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_clocktree_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/pmhal_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/V0/hw_pmhal_ina226data.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_ina226.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps659039.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda2xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps659037.c
    # Archiving tda2xx:arp32_1:release:pm_hal_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_hal_optimized.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:arp32_1:release:pm_lib: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda2xx:arp32_1:release:pm_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_lib.aearp32F ...
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_boardconfig.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_videopll_data.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/V0/pmlib_clk_rate_data_tda2xx.c
    # Compiling tda2xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda2xx:arp32_1:release:pm_lib_optimized into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2xx/arp32/release/pm_lib_optimized.aearp32F ...
    Nothing to be done for tda2xx arp32_1 sbl_lib
    Nothing to be done for tda2xx arp32_1 sbl_utils
    Nothing to be done for tda2xx arp32_1 diag
    # Compiling tda2xx:arp32_1:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda2xx:arp32_1:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda2xx:arp32_1:release:firewall_l3l4 into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2xx/arp32/release/firewall_l3l4.aearp32F ...
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_1:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_1/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_1 norflash_lib
    Nothing to be done for tda2xx arp32_1 qspiflash_lib
    Nothing to be done for tda2xx arp32_1 i2c_lld
    # Compiling tda2xx:arp32_1:release:stw_platform: src/platform.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/stw_platform.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/irq_xbar.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/dma_xbar.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/chip_config.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
    # Compiling tda2xx:arp32_1:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
    # Archiving tda2xx:arp32_1:release:stw_platform into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2xx/arp32/release/stw_platform.aearp32F ...
    # Compiling tda2xx:arp32_1:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda2xx:arp32_1:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda2xx:arp32_1:release:stw_uartconsole into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2xx/arp32/release/stw_uartconsole.aearp32F ...
    Nothing to be done for tda2xx arp32_1 stw_fatlib
    Nothing to be done for tda2xx arp32_1 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_1 stw_boards
    Nothing to be done for tda2xx arp32_1 stw_devices
    # Compiling tda2xx:arp32_1:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda2xx:arp32_1:release:stw_examples_utility into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2xx/arp32/release/stw_examples_utility.aearp32F ...
    Nothing to be done for tda2xx arp32_1 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_1 vps_common
    Nothing to be done for tda2xx arp32_1 vpslib
    Nothing to be done for tda2xx arp32_1 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_1 fvid2
    # Compiling tda2xx:arp32_1:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda2xx:arp32_1:release:vps_osal_tirtos into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2xx/arp32/release/vps_osal_tirtos.aearp32F ...
    Nothing to be done for tda2xx arp32_1 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_1 vps_platforms
    Nothing to be done for tda2xx arp32_1 vps_devices
    Nothing to be done for tda2xx arp32_1 vps_boards
    Nothing to be done for tda2xx arp32_1 vps_examples_utility
    Nothing to be done for tda2xx arp32_1 bsp_i2c
    Nothing to be done for tda2xx arp32_1 bsp_uart
    Nothing to be done for tda2xx arp32_1 bsp_mcspi
    Nothing to be done for tda2xx arp32_2 csl_init
    Nothing to be done for tda2xx csl_intc
    Nothing to be done for tda2xx arp32_2 csl_utils_common
    Nothing to be done for tda2xx arp32_2 csl_uart_console
    Nothing to be done for tda2xx arp32_2 csl_utils_i2c
    Nothing to be done for tda2xx arp32_2 pm_hal
    Nothing to be done for tda2xx arp32_2 pm_hal_optimized
    Nothing to be done for tda2xx arp32_2 pm_lib
    Nothing to be done for tda2xx arp32_2 pm_lib_optimized
    Nothing to be done for tda2xx arp32_2 sbl_lib
    Nothing to be done for tda2xx arp32_2 sbl_utils
    Nothing to be done for tda2xx arp32_2 diag
    Nothing to be done for tda2xx arp32_2 firewall_l3l4
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_2:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_2:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_2/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_2 norflash_lib
    Nothing to be done for tda2xx arp32_2 qspiflash_lib
    Nothing to be done for tda2xx arp32_2 i2c_lld
    Nothing to be done for tda2xx arp32_2 stw_platform
    Nothing to be done for tda2xx arp32_2 stw_uartconsole
    Nothing to be done for tda2xx arp32_2 stw_fatlib
    Nothing to be done for tda2xx arp32_2 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_2 stw_boards
    Nothing to be done for tda2xx arp32_2 stw_devices
    Nothing to be done for tda2xx arp32_2 stw_examples_utility
    Nothing to be done for tda2xx arp32_2 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_2 vps_common
    Nothing to be done for tda2xx arp32_2 vpslib
    Nothing to be done for tda2xx arp32_2 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_2 fvid2
    Nothing to be done for tda2xx arp32_2 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_2 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_2 vps_platforms
    Nothing to be done for tda2xx arp32_2 vps_devices
    Nothing to be done for tda2xx arp32_2 vps_boards
    Nothing to be done for tda2xx arp32_2 vps_examples_utility
    Nothing to be done for tda2xx arp32_2 bsp_i2c
    Nothing to be done for tda2xx arp32_2 bsp_uart
    Nothing to be done for tda2xx arp32_2 bsp_mcspi
    Nothing to be done for tda2xx arp32_3 csl_init
    Nothing to be done for tda2xx arp32_3 csl_utils_common
    Nothing to be done for tda2xx arp32_3 csl_uart_console
    Nothing to be done for tda2xx arp32_3 csl_utils_i2c
    Nothing to be done for tda2xx arp32_3 pm_hal
    Nothing to be done for tda2xx arp32_3 pm_hal_optimized
    Nothing to be done for tda2xx arp32_3 pm_lib
    Nothing to be done for tda2xx arp32_3 pm_lib_optimized
    Nothing to be done for tda2xx arp32_3 sbl_lib
    Nothing to be done for tda2xx arp32_3 sbl_utils
    Nothing to be done for tda2xx arp32_3 diag
    Nothing to be done for tda2xx arp32_3 firewall_l3l4
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_3:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_3:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_3/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_3 norflash_lib
    Nothing to be done for tda2xx arp32_3 qspiflash_lib
    Nothing to be done for tda2xx arp32_3 i2c_lld
    Nothing to be done for tda2xx arp32_3 stw_platform
    Nothing to be done for tda2xx arp32_3 stw_uartconsole
    Nothing to be done for tda2xx arp32_3 stw_fatlib
    Nothing to be done for tda2xx arp32_3 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_3 stw_boards
    Nothing to be done for tda2xx arp32_3 stw_devices
    Nothing to be done for tda2xx arp32_3 stw_examples_utility
    Nothing to be done for tda2xx arp32_3 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_3 vps_common
    Nothing to be done for tda2xx arp32_3 vpslib
    Nothing to be done for tda2xx arp32_3 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_3 fvid2
    Nothing to be done for tda2xx arp32_3 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_3 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_3 vps_platforms
    Nothing to be done for tda2xx arp32_3 vps_devices
    Nothing to be done for tda2xx arp32_3 vps_boards
    Nothing to be done for tda2xx arp32_3 vps_examples_utility
    Nothing to be done for tda2xx arp32_3 bsp_i2c
    Nothing to be done for tda2xx arp32_3 bsp_uart
    Nothing to be done for tda2xx arp32_3 bsp_mcspi
    Nothing to be done for tda2xx arp32_4 csl_init
    Nothing to be done for tda2xx arp32_4 csl_utils_common
    Nothing to be done for tda2xx arp32_4 csl_uart_console
    Nothing to be done for tda2xx arp32_4 csl_utils_i2c
    Nothing to be done for tda2xx arp32_4 pm_hal
    Nothing to be done for tda2xx arp32_4 pm_hal_optimized
    Nothing to be done for tda2xx arp32_4 pm_lib
    Nothing to be done for tda2xx arp32_4 pm_lib_optimized
    Nothing to be done for tda2xx pm_rtos
    Nothing to be done for tda2xx arp32_4 sbl_lib
    Nothing to be done for tda2xx arp32_4 sbl_utils
    Nothing to be done for tda2xx arp32_4 diag
    Nothing to be done for tda2xx arp32_4 firewall_l3l4
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xx.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxMailboxCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxProcCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/tda2xx/ipclib_interruptTda2xxXbarCfg.c
    # Compiling tda2xx:arp32_4:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda2xx:arp32_4:release:ipc_lib into /home/work/vision_sdk_test/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2xx/arp32_4/release/ipc_lib.aearp32F ...
    Nothing to be done for tda2xx arp32_4 norflash_lib
    Nothing to be done for tda2xx arp32_4 qspiflash_lib
    Nothing to be done for tda2xx arp32_4 i2c_lld
    Nothing to be done for tda2xx arp32_4 stw_platform
    Nothing to be done for tda2xx arp32_4 stw_uartconsole
    Nothing to be done for tda2xx arp32_4 stw_fatlib
    Nothing to be done for tda2xx arp32_4 stw_fatlib_edma
    Nothing to be done for tda2xx arp32_4 stw_boards
    Nothing to be done for tda2xx arp32_4 stw_devices
    Nothing to be done for tda2xx arp32_4 stw_examples_utility
    Nothing to be done for tda2xx arp32_4 vps_osal_baremetal
    Nothing to be done for tda2xx arp32_4 vps_common
    Nothing to be done for tda2xx arp32_4 vpslib
    Nothing to be done for tda2xx arp32_4 vpsdrv_baremetal
    Nothing to be done for tda2xx arp32_4 fvid2
    Nothing to be done for tda2xx arp32_4 vps_osal_tirtos
    Nothing to be done for tda2xx arp32_4 vps_osal_tirtos_smp
    Nothing to be done for tda2xx arp32_4 vps_platforms
    Nothing to be done for tda2xx arp32_4 vps_devices
    Nothing to be done for tda2xx arp32_4 vps_boards
    Nothing to be done for tda2xx arp32_4 vps_examples_utility
    Nothing to be done for tda2xx arp32_4 bsp_i2c
    Nothing to be done for tda2xx arp32_4 bsp_uart
    Nothing to be done for tda2xx arp32_4 bsp_mcspi
    # Depend tda2xx-evm:ipu2:release:links_common_algorithm
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_algorithm
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_1:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_2:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_3:release:links_common_algorithm
    # Depend tda2xx-evm:arp32_4:release:links_common_algorithm
    # Depend tda2xx-evm:ipu2:release:links_common_dup
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_dup
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_dup
    # Depend tda2xx-evm:arp32_1:release:links_common_dup
    # Depend tda2xx-evm:arp32_2:release:links_common_dup
    # Depend tda2xx-evm:arp32_3:release:links_common_dup
    # Depend tda2xx-evm:arp32_4:release:links_common_dup
    # Depend tda2xx-evm:ipu2:release:links_common_gate
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_gate
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_gate
    # Depend tda2xx-evm:arp32_1:release:links_common_gate
    # Depend tda2xx-evm:arp32_2:release:links_common_gate
    # Depend tda2xx-evm:arp32_3:release:links_common_gate
    # Depend tda2xx-evm:arp32_4:release:links_common_gate
    # Depend tda2xx-evm:ipu2:release:links_common_ipcIn
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_1:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_2:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_3:release:links_common_ipcIn
    # Depend tda2xx-evm:arp32_4:release:links_common_ipcIn
    # Depend tda2xx-evm:ipu2:release:links_common_ipcOut
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_1:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_2:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_3:release:links_common_ipcOut
    # Depend tda2xx-evm:arp32_4:release:links_common_ipcOut
    # Depend tda2xx-evm:ipu2:release:links_common_merge
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_merge
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_merge
    # Depend tda2xx-evm:arp32_1:release:links_common_merge
    # Depend tda2xx-evm:arp32_2:release:links_common_merge
    # Depend tda2xx-evm:arp32_3:release:links_common_merge
    # Depend tda2xx-evm:arp32_4:release:links_common_merge
    # Depend tda2xx-evm:ipu2:release:links_common_null
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_null
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_null
    # Depend tda2xx-evm:arp32_1:release:links_common_null
    # Depend tda2xx-evm:arp32_2:release:links_common_null
    # Depend tda2xx-evm:arp32_3:release:links_common_null
    # Depend tda2xx-evm:arp32_4:release:links_common_null
    # Depend tda2xx-evm:ipu2:release:links_common_network_tx
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_network_tx
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_1:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_2:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_3:release:links_common_network_tx
    # Depend tda2xx-evm:arp32_4:release:links_common_network_tx
    # Depend tda2xx-evm:ipu2:release:links_common_network_rx
    # Depend tda2xx-evm:ipu2:release:links_common_nullSrc
    # Depend tda2xx-evm:ipu2:release:links_common_select
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_select
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_select
    # Depend tda2xx-evm:arp32_1:release:links_common_select
    # Depend tda2xx-evm:arp32_2:release:links_common_select
    # Depend tda2xx-evm:arp32_3:release:links_common_select
    # Depend tda2xx-evm:arp32_4:release:links_common_select
    # Depend tda2xx-evm:ipu2:release:links_common_sync
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_sync
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_sync
    # Depend tda2xx-evm:arp32_1:release:links_common_sync
    # Depend tda2xx-evm:arp32_2:release:links_common_sync
    # Depend tda2xx-evm:arp32_3:release:links_common_sync
    # Depend tda2xx-evm:arp32_4:release:links_common_sync
    # Depend tda2xx-evm:ipu2:release:links_ipu_display
    # Depend tda2xx-evm:ipu2:release:links_ipu_display_ctrl
    # Depend tda2xx-evm:ipu2:release:links_ipu_iva
    # Depend tda2xx-evm:ipu2:release:links_ipu_vip_capture
    # Depend tda2xx-evm:ipu2:release:links_ipu_vpe
    # Depend tda2xx-evm:ipu2:release:links_ipu_dssM2mWb
    # Depend tda2xx-evm:ipu2:release:utils_common
    # Depend tda2xx-evm:c66xdsp_1:release:utils_common
    # Depend tda2xx-evm:c66xdsp_2:release:utils_common
    # Depend tda2xx-evm:arp32_1:release:utils_common
    # Depend tda2xx-evm:arp32_2:release:utils_common
    # Depend tda2xx-evm:arp32_3:release:utils_common
    # Depend tda2xx-evm:arp32_4:release:utils_common
    # Depend tda2xx-evm:ipu2:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_1:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_2:release:links_common_system
    # Depend tda2xx-evm:arp32_1:release:links_common_system
    # Depend tda2xx-evm:arp32_2:release:links_common_system
    # Depend tda2xx-evm:arp32_3:release:links_common_system
    # Depend tda2xx-evm:arp32_4:release:links_common_system
    # Depend tda2xx-evm:c66xdsp_1:release:links_dsp_system
    # Depend tda2xx-evm:c66xdsp_2:release:links_dsp_system
    # Depend tda2xx-evm:arp32_1:release:links_eve_system
    # Depend tda2xx-evm:arp32_2:release:links_eve_system
    # Depend tda2xx-evm:arp32_3:release:links_eve_system
    # Depend tda2xx-evm:arp32_4:release:links_eve_system
    # Depend tda2xx-evm:ipu2:release:links_ipu_system
    root@ubuntu:/home/work/vision_sdk_test/vision_sdk/build# make -s
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_algorithm
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_algorithm
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_algorithm
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_algorithm
    # Compiling tda2xx-evm:ipu2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_dup
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_dup
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_dup
    # Compiling tda2xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_dup
    # Compiling tda2xx-evm:arp32_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_dup
    # Compiling tda2xx-evm:arp32_3:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_dup
    # Compiling tda2xx-evm:arp32_4:release:links_common_dup: dupLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_dup
    # Compiling tda2xx-evm:ipu2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_gate
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_gate
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_gate
    # Compiling tda2xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_gate
    # Compiling tda2xx-evm:arp32_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_gate
    # Compiling tda2xx-evm:arp32_3:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_gate
    # Compiling tda2xx-evm:arp32_4:release:links_common_gate: gateLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_gate
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_ipcIn
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_ipcIn
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_ipcIn
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_ipcOut
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_ipcOut
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_ipcOut
    # Compiling tda2xx-evm:ipu2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_merge
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_merge
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_merge
    # Compiling tda2xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_merge
    # Compiling tda2xx-evm:arp32_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_merge
    # Compiling tda2xx-evm:arp32_3:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_merge
    # Compiling tda2xx-evm:arp32_4:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_merge
    # Compiling tda2xx-evm:ipu2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:ipu2:release:links_common_null
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_null
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_null
    # Compiling tda2xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_null
    # Compiling tda2xx-evm:arp32_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_null
    # Compiling tda2xx-evm:arp32_3:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_null
    # Compiling tda2xx-evm:arp32_4:release:links_common_null: nullLink_tsk.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_null
    # Compiling tda2xx-evm:ipu2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_common_network_tx
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_network_tx
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_3:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_network_tx
    # Compiling tda2xx-evm:arp32_4:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_network_tx
    # Compiling tda2xx-evm:ipu2:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_common_network_rx
    # Compiling tda2xx-evm:ipu2:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda2xx-evm:ipu2:release:links_common_nullSrc
    # Compiling tda2xx-evm:ipu2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_select
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_select
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_select
    # Compiling tda2xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_select
    # Compiling tda2xx-evm:arp32_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_select
    # Compiling tda2xx-evm:arp32_3:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_select
    # Compiling tda2xx-evm:arp32_4:release:links_common_select: selectLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_select
    # Compiling tda2xx-evm:ipu2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda2xx-evm:ipu2:release:links_common_sync
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_sync
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_sync
    # Compiling tda2xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_sync
    # Compiling tda2xx-evm:arp32_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_sync
    # Compiling tda2xx-evm:arp32_3:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_sync
    # Compiling tda2xx-evm:arp32_4:release:links_common_sync: syncLink_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_sync
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display: displayLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display: displayLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_display
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_display_ctrl
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/iresman_hdvicp2_fwif.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/utils_encdec.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/iresman_tiledmemory.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/hdvicp2_config.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_control.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_create.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: codec_utils/src/alg_malloc.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_common.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_common.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_jpeg.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_enc/encLink_h264.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_jpeg.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_iva: iva_dec/decLink_h264.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_iva
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_subframe_drv.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_vip_capture
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_drvCommon.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_vpe: vpeLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_vpe
    # Compiling tda2xx-evm:ipu2:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_dssM2mWb
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: tda2xx/utils_l3_emif_bw.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_execp_trace_local_m4.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_uart.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_cbuf_ocmc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_qspi.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_idle_m4.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_temperature.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_stat_collector.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_prcm_stats.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_emif_ecc.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mcspi.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_mem_ipu1_0.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: dma_cfg/utils_dma_cfg_ipu2.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: stat_collector_utils/sci_config_dra7xx.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: utils_eveloader.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: eveloader/utils_eve_boot.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: file_api.c
    # Compiling tda2xx-evm:ipu2:release:utils_common: file_api_dma.c
    # Archiving tda2xx-evm:ipu2:release:utils_common
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: network_api.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
    # Compiling tda2xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
    # Archiving tda2xx-evm:c66xdsp_1:release:utils_common
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
    # Compiling tda2xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
    # Archiving tda2xx-evm:c66xdsp_2:release:utils_common
    # Compiling tda2xx-evm:arp32_1:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_1:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_1:release:utils_common
    # Compiling tda2xx-evm:arp32_2:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_2:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_2:release:utils_common
    # Compiling tda2xx-evm:arp32_3:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_3:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_3:release:utils_common
    # Compiling tda2xx-evm:arp32_4:release:utils_common: tda2xx/utils_clk.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: tda2xx/utils_prcm.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_remote_log_server.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_buf.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_mem.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_prf.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_que.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_ipc_que.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_remote_log_client.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_global_time.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_buf_ext.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_timer_reconfig.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_link_stats_collector.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_pm.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_spinlock.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: safety_osal.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_cio.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_dma.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_vip_interrupt.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: network_api.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: network_tfdtp_api.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_idle_arp32.c
    # Compiling tda2xx-evm:arp32_4:release:utils_common: utils_l3fw.c
    # Archiving tda2xx-evm:arp32_4:release:utils_common
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:ipu2:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:ipu2:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_ipc_bios_ipc.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_common_system: system_rpmsg.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_common_system
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_1:release:links_common_system
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_2:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_2:release:links_common_system
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_3:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_3:release:links_common_system
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_linkApi.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_linkApi_local.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_common.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc_msgq.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_openvxipc.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_if.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda2xx-evm:arp32_4:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda2xx-evm:arp32_4:release:links_common_system
    # Compiling tda2xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda2xx-evm:c66xdsp_1:release:links_dsp_system
    # Compiling tda2xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda2xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda2xx-evm:c66xdsp_2:release:links_dsp_system
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_1:release:links_eve_system
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_2:release:links_eve_system
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_3:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_3:release:links_eve_system
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: system_eve.c
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda2xx-evm:arp32_4:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda2xx-evm:arp32_4:release:links_eve_system
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: system_bsp_init.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: system_ipu1_0.c
    # Compiling tda2xx-evm:ipu2:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda2xx-evm:ipu2:release:links_ipu_system
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font01.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font03.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font04.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font05.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font06.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font07.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font08.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font09.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font14.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_1.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_small.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo_small.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_3d_perception_sfm_logo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_220x330.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_228x432.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_288x432.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_suv_topView_348x480.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_tda2x.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_tda3x.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_left.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_right.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_left.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_right.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_green.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_red.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_echo.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_device_comm.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_calib_image_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_dynamic_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_iss_raw_save.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_object_detect_set_dynamic_params.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_ipc.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda2xx-evm:ipu2:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:ipu2:release:app_alg_plugins
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignLUT_tda2xx.oe66' given more than once in the same rule
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignExt_tda2xx.oe66' given more than once in the same rule
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/acDetectLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/pEstimateLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/calMatGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyAlgoLocalDma.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmMainLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/dumpedSOFtestdata.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmLinearTwoViewLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: structurefrommotion/sfmMapLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/synthesisLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignLUT_tda2xx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignExt_tda2xx.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/pAlignLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/uFusionLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusionExt.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusion_bufferZonesLUT.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlignLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlign3DLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svLutGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svBlendTableGen_If.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/adaptiveBowlLink_algPlugin.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: commonutils/calmat.c
    # Compiling tda2xx-evm:c66xdsp_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:c66xdsp_1:release:app_alg_plugins
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/sample_vcop_array_add_uns_short_kernel.k
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/radar/src/alg_plugins/alg_fxns/common/alg_functions.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyAlgoEve.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: sparseopticalflow/sparseOpticalFlowLink_algPlugin.c
    # Compiling tda2xx-evm:arp32_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda2xx-evm:arp32_1:release:app_alg_plugins
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_bios.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common/chains_main_linux.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_srv_calib_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sved_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sv_sof_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_OF_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_multiFCalg_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_stereo_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout2.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_fcAnalytics2_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sfm.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x2D3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3xRearView3DSv_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_metadata_draw.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_rvp_layout.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_multi_mbx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_single_mbx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/link_stats_monitor/link_stats_monitor.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/lcd.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/hdmi_tx.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/devices/eth_cam.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_tsk.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_drv.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/modules/devcontrol/devControl_handler.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_common_srv_calib.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_common_surround_view.c
    # Compiling tda2xx-evm:ipu2:release:app_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/common_srv/chains_lens.c
    # Archiving tda2xx-evm:ipu2:release:app_libs
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/ov10635/vid_sensor_ov10635.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/vid_sensor.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/hdmiRec/hdmi_recvr.c
    # Compiling tda2xx-evm:ipu2:release:video_sensor_libs: /home/work/vision_sdk_test/vision_sdk/apps/src/rtos/video_sensor/src/tvp5158/video_decdr.c
    # Archiving tda2xx-evm:ipu2:release:video_sensor_libs
    # Invoking configuro...
    making package.mak (because of package.bld) ...
    # !!! Current build platform is [tda2xx-evm] !!!
    # !!! Core is [arp32_1] !!!
    generating interfaces for package vision_sdk_configuro (because package/package.xdc.inc is older than package.xdc) ...
    configuring MAIN_APP_eve1.xearp32F from package/cfg/MAIN_APP_eve1_pearp32F.cfg ...
    Loading Eve1.cfg for tda2xx-evm
    # !!! Including CPU #0 [ HOST ] in build !!!
    # !!! Including CPU #1 [ IPU2 ] in build !!!
    # !!! Including CPU #2 [ DSP1 ] in build !!!
    # !!! Including CPU #3 [ DSP2 ] in build !!!
    # !!! Including CPU #4 [ EVE1 ] in build !!!
    # !!! Including CPU #5 [ EVE2 ] in build !!!
    # !!! Including CPU #6 [ EVE3 ] in build !!!
    # !!! Including CPU #7 [ EVE4 ] in build !!!
    # !!! Host Proc ID is [1] !!!
    generating custom ti.sysbios library makefile ...
    generating custom ti.sdo.utils library makefile ...
    generating custom ti.sdo.ipc library makefile ...
    Starting build of library sources ...
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
    arearp32F Ipc.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
    arearp32F UTILS.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
    clearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_switch_asm.sarp32 ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_disp_always.sarp32 ...
    asmearp32F /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/TaskSupport_asm.sarp32 ...
    arearp32F BIOS.obj arp32_Hwi_switch_asm.obj arp32_Hwi_disp_always.obj arp32_TaskSupport_asm.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
    Build of libraries done.
    # Configuro done!
    # Making tda2xx-evm:arp32_1:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: src/main_common_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: src/tlb_config_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve1/src/main_eve1.c
    # Compiling tda2xx-evm:arp32_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve1_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F created.
    WARNING: The runtime version supported by this application is unavailable.
    Using default runtime: v4.0.30319
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.
    File conversion complete!
    # !!! Core is [arp32_2] !!!
    configuring MAIN_APP_eve2.xearp32F from package/cfg/MAIN_APP_eve2_pearp32F.cfg ...
    Loading Eve2.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_2:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: src/main_common_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: src/tlb_config_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve2/src/main_eve2.c
    # Compiling tda2xx-evm:arp32_2:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve2_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.
    # !!! Core is [arp32_3] !!!
    configuring MAIN_APP_eve3.xearp32F from package/cfg/MAIN_APP_eve3_pearp32F.cfg ...
    Loading Eve3.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_3/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve3_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_3:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: src/main_common_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: src/tlb_config_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve3/src/main_eve3.c
    # Compiling tda2xx-evm:arp32_3:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve3_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.
    # !!! Core is [arp32_4] !!!
    configuring MAIN_APP_eve4.xearp32F from package/cfg/MAIN_APP_eve4_pearp32F.cfg ...
    Loading Eve4.cfg for tda2xx-evm
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios/sysbios.aearp32F ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios'
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/arp32_4/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve4_pearp32F.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:arp32_4:release:vision_sdk_lib...
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: src/main_common_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: src/tlb_config_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: ../eve_common/main_eve_common.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/eve4/src/main_eve4.c
    # Compiling tda2xx-evm:arp32_4:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_eve.c
    # Compiling generated MAIN_APP_eve4_pearp32F.oearp32F
    # Linking into /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F...
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 7: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 8: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 13: warning:
    no matching section
    "/home/work/vision_sdk_test/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 14: warning:
    no matching section
    # /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F created.
    Parsing the input object file, /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.
    # !!! Core is [c66xdsp_1] !!!
    configuring MAIN_APP_c6xdsp1.xe66 from package/cfg/MAIN_APP_c6xdsp1_pe66.cfg ...
    Loading Dsp1.cfg for tda2xx-evm
    warning: xdc.cfg.Program: "/home/work/vision_sdk_test/ti_components/os_tools/linux/xdctools_3_32_01_22_core/packages/xdc/cfg/Program.xs", line 110: xdc.cfg.Program.SectionSpec#0 : Entry for the section '.bss:heapMemL2' in Program.sectMap is set to 'undefined'. This section allocation will be ignored.
    Warning: xdc.cfg.INCOMPATIBLE_TARGET_VERSION: the compiler version [7.4.2] used by the current target 'ti.targets.elf.C66' is not compatible with compiler version of targets used to build the following packages; package ti.deh [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/deh/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.ipc.ipcmgr [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/ipc/ipcmgr/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.ipc.rpmsg [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/ipc/rpmsg/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.trace [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/trace/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    ; package ti.pm [in /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/pm/] was built using the target 'ti.targets.elf.C66' with compiler version [8.1.0].
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
    are66 Ipc.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
    are66 UTILS.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
    making /home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
    gmake[1]: Entering directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
    cle66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
    asme66 /home/work/vision_sdk_test/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
    are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj c62_TaskSupport_asm.obj ti_tls_get_tp.obj ...
    gmake[1]: Leaving directory `/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
    # Configuro done!
    # Making tda2xx-evm:c66xdsp_1:release:vision_sdk_lib...
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/main_app/tda2xx/dsp1/src/main_c6xdsp1.c
    # Compiling tda2xx-evm:c66xdsp_1:release:vision_sdk: /home/work/vision_sdk_test/vision_sdk/apps/src/common/app_init/app_init_dsp.c
    # Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
    abnormal termination of /home/work/vision_sdk_test/ti_components/cg_tools/linux/C6000_7.4.2/bin/cmp6x
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/rules_66.mk:334: recipe for target '/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.oe66' failed
    make[7]: *** [/home/work/vision_sdk_test/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.oe66] Error 1
    /home/work/vision_sdk_test/vision_sdk/build/rtos/makerules/common.mk:271: recipe for target 'c66xdsp_1' failed
    make[6]: *** [c66xdsp_1] Error 2
    MAKEFILE.MK:116: recipe for target 'apps_dsp1' failed
    make[5]: *** [apps_dsp1] Error 2
    MAKEFILE.MK:31: recipe for target 'apps' failed
    make[4]: *** [apps] Error 2
    MAKEFILE.MK:298: recipe for target 'apps' failed
    make[3]: *** [apps] Error 2
    Makefile:171: recipe for target 'apps_exe' failed
    make[2]: *** [apps_exe] Error 2
    Makefile:36: recipe for target 'apps' failed
    make[1]: *** [apps] Error 2
    Makefile:12: recipe for target 'vision_sdk' failed
    make: *** [vision_sdk] Error 2
    Please follow the instructions given in PROCESSOR_SDK_VISION_03_05_00_00\vision_sdk\docs\Linux\VisionSDK_Linux_UserGuide.pdf
    Rishabh
    I will build OK when I creat a new ubuntu Vmware,but the above isssues still happen when I make clean, and build again.why? I tryed three times .
    What is the error message on doing make clean? Kindly share the log as a file (use "Insert Code, Attach Files and more..." option).
    Rishabh
