Part Number: AM3358
Tool/software: Linux
I am attempting to build the SDK using bitbake. I have followed the steps enumerated in section 1.2 of the SDK documentation (http://software-dl.ti.com/processor-sdk-linux/esd/docs/05_01_00_11/linux/Overview_Building_the_SDK.html
WARNING: ti-cgt-pru-native-2.2.1-r0 do_fetch: Failed to fetch URL software-dl.ti.com/.../ti_cgt_pru_2.2.1_linux_installer_x86.bin;name=cgt-pru-x86, attempting MIRRORS if available ERROR: ti-cgt-pru-native-2.2.1-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-BHwUn1NB6e,guid=5f8a696db41b1bae11c248595be04d33"; export SSH_AGENT_PID="1382"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/nextmove/tisdk/sources/oe-core/scripts/native-intercept:/home/nextmove/tisdk/sources/oe-core/scripts:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/usr/bin/x86_64-linux:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/usr/bin:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/usr/sbin:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/usr/bin:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/sbin:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/recipe-sysroot-native/bin:${DEF_TOOLCHAIN_PATH}/bin:/home/nextmove/tisdk/sources/bitbake/bin:/home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/hosttools"; export HOME="/home/nextmove"; /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/nextmove/tisdk/downloads 'software-dl.ti.com/.../ti_cgt_pru_2.2.1_linux_installer_x86.bin' --progress=dot -v failed with exit code 4, output: --2018-11-05 15:54:50-- software-dl.ti.com/.../ti_cgt_pru_2.2.1_linux_installer_x86.bin Resolving software-dl.ti.com (software-dl.ti.com)... 23.219.92.160, 23.219.92.168 Connecting to software-dl.ti.com (software-dl.ti.com)|23.219.92.160|:80... connected. HTTP request sent, awaiting response... 302 Moved Temporarily Location: www.ti.com/.../anonymousproddownload.tsp [following] --2018-11-05 15:54:50-- www.ti.com/.../anonymousproddownload.tsp Resolving www.ti.com (www.ti.com)... 96.6.191.244, 2600:141b:4:39f::b48, 2600:141b:4:3a2::b48 Connecting to www.ti.com (www.ti.com)|96.6.191.244|:443... connected. HTTP request sent, awaiting response... Read error (Connection timed out) in headers. Retrying. --2018-11-05 15:55:21-- (try: 2) www.ti.com/.../anonymousproddownload.tsp Connecting to www.ti.com (www.ti.com)|96.6.191.244|:443... connected. HTTP request sent, awaiting response... Read error (Connection timed out) in headers. Giving up. ERROR: ti-cgt-pru-native-2.2.1-r0 do_fetch: Fetcher failure for URL: 'software-dl.ti.com/.../ti_cgt_pru_2.2.1_linux_installer_x86.bin;name=cgt-pru-x86'. Unable to fetch URL from any source. ERROR: ti-cgt-pru-native-2.2.1-r0 do_fetch: Function failed: base_do_fetch ERROR: Logfile of failure stored in: /home/nextmove/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-cgt-pru-native/2.2.1-r0/temp/log.do_fetch.29670 ERROR: Task (virtual:native:/home/nextmove/tisdk/sources/meta-ti/recipes-ti/devtools/ti-cgt-pru_2.2.1.bb:do_fetch) failed with exit code '1'
