Part Number: AM5746
Hello, TI Experts,
Our customer sent us questions about "how to enable FatFs" with PROCESSOR-SDK-RTOS-AM57X.
We found related description like below in spruhd4m.pdf.
http://www.ti.com/lit/ug/spruhd4m/spruhd4m.pdf
"You can modify this default by changing the definition of _VOLUMES in the ffconf.h file in the FatFS module."
So, we tried to modify "ffconf.h" & rebuild like below "Detail Procedure".
But we found Errors like below;
"src/ff.c", line 3918: error #137: struct "<unnamed>" has no field "sclust"
"src/ff.c", line 3925: error #169: argument of type "FATFS *" is incompatible with parameter of type "_FDID *"
"src/ff.c", line 3941: error #137: struct "<unnamed>" has no field "fsize"
"src/ff.c", line 3942: error #137: struct "<unnamed>" has no field "fsize"
4 errors detected in the compilation of "src/ff.c".
Detail Procedure:
- Modify "C:\ti\pdk_am57xx_1_0_11\packages\ti\fs\fatfs\ffconf.h" like below;
_USE_FIND=1
_USE_FASTSEEK=1
_USE_EXPAND=1
_USE_CHMOD=1
_USE_LABEL=1
_FS_RPATH=2
_FS_LOCK=1
- Bulid
- cd C:\ti\pdk_am57xx_1_0_11\packages
- pdksetenv.bat
- gmake
Question:
- Is there same experience?
- Is this procedure is correct for enabling & configuring FatFs?
We would appreciate if you tell us how to solve this problem.
