Part Number: TDA2
Tool/software: Linux
i am using SDK_VISION_03_04_00_00 .
i am thy to add a usecases in sample_app\src\hlos\usecases
chains_nullSrc_eveDisplay.txt is
UseCase: chains_null_eveSrcDisplay
NullSource (A15) -> Alg_FrameCopy (EVE1) ->Display
cfg.mk is
ALG_framecopy=yes
NEED_PROC_IPU1_0=yes
NEED_PROC_A15_0=yes
NEED_PROC_EVE1=yes
but when i run the usecases it failed ,i donot know what is the problem!
follow is the log
HOST] [HOST ] Sample Application Usecases,
[HOST] [HOST ] ---------------------------
[HOST] [HOST ] 1: Null Source -> Display (Supports only 1920x1080 HDMI display)
[HOST] [HOST ] 2: Null Source_eve -> Display (Supports only 1920x1080 HDMI display)
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
2
[HOST] [HOST ] 688.765357 s: #### ENTERING SAMPLE_APP:NULL SOURCE_eve -> DISPLAY USE CASE ####
ASSERT (system_ipc_msgq.c|System_ipcMsgQTskMain|218)
[HOST] [HOST ] 689.779296 s: IPC_OUT_0 : Create in progress !!!
[HOST] [HOST ] 689.779357 s: IPC_OUT_0 : Create Done !!!
[HOST] [HOST ] 689.780424 s: IPC_IN_0 : Create in progress !!!
[HOST] [HOST ] 689.780455 s: IPC_IN_0 : Create Done !!!
[HOST] [HOST ] 689.780485 s: SYSTEM: IPC: [HOST] Notify send failed (Socket operation on non-socket, 88) !!!
[HOST] [EVE1 ] 689.779723 s: IPC_IN_0 : Create in progress !!!
in PROCESSOR_SDK_VISION_03_04_00_00/ti_components/os_tools/linux/targetfs/lib/firmware$ have
dra7-dsp1-fw.lzop dra7-dsp2-fw.xe66.rsc dra7-ipu2-fw.xem4.rsc
dra7-dsp1-fw.xe66 dra7-ipu2-fw.lzop goodix_9271_cfg.bin
dra7-dsp1-fw.xe66.rsc dra7-ipu2-fw.xem4 tigon
dra7-dsp2-fw.lzop dra7-ipu2-fw.xem4.ipumm-fw vpdma-1b8.bin
dra7-dsp2-fw.xe66 dra7-ipu2-fw.xem4.map
but no files for arp32.
