Linux/AM3359: GPMC remapping and probing issue
Part Number: AM3359
Tool/software: Linux
Hello all,
                                  We working on am3359 ice v2 evk with SDK 4.0.Our aim is to interface a nand flash(CS0) and fpga(CS2) through gpmc.We did the pinmuxing for the gpmc in am3359-icev2.dts and disabled other devices using the gpmc pin(ethernet in case of icev2 board ).As of now no physical devices are connected to gpmc.
1)I was trying to probe gpmc_clk by probing the resistor R150.When I boot up the signal is high and at one point  I can see clock signal of about 1MHz.After few seconds it goes high again.Is this the expected behavior?
2)I also tried to probe CSn2 pin (pin 21 in connector j4) and its always high.Is this also normal?
[    1.403902] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    1.409256] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000        <---why is it disbaling CS0?
[    1.415406] gpiochip_find_base: found new base at 510
[    1.415465] gpio gpiochip4: (omap-gpmc): added GPIO chardev (254:4)
[    1.415868] gpiochip_setup_dev: registered GPIOs 510 to 511 on device: gpiochip4 (omap-gpmc)
[    1.416699] omap2-nand 8000000.nand: GPIO lookup for consumer rb
[    1.416708] omap2-nand 8000000.nand: using device tree for GPIO lookup
[    1.416746] of_get_named_gpiod_flags: parsed 'rb-gpios' property of node '/ocp/gpmc@50000000/nand@0,0[0]' - status (0)
[    1.416814] nand: No NAND device found
[    1.420719] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch      <---whats happening here?
[    1.427920] gpmc_read_settings_dt: page/burst-length set but not used!
[    1.434621] omap-gpmc 50000000.gpmc: cannot remap GPMC CS 2 to 0x18000000  <---why?
[    1.441467] omap-gpmc 50000000.gpmc: failed to probe DT child 'fpga': -22               <---why did it fail
My dts file:
 * Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
 * AM335x ICE V2 board
 * http://www.ti.com/tool/tmdsice3359
/dts-v1/;
#include "am33xx.dtsi"
	model = "TI AM3359 ICE-V2";
	compatible = "ti,am3359-icev2", "ti,am33xx";
	memory@80000000 {
		device_type = "memory";
		reg = <0x80000000 0x10000000>; /* 256 MB */
	chosen {
		stdout-path = &uart3;
	vbat: fixedregulator0 {
		compatible = "regulator-fixed";
		regulator-name = "vbat";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-boot-on;
	vtt_fixed: fixedregulator1 {
		regulator-name = "vtt";
		regulator-min-microvolt = <1500000>;
		regulator-max-microvolt = <1500000>;
		gpio = <&gpio0 18 GPIO_ACTIVE_HIGH>;
		regulator-always-on;
		regulator-boot-on;
		enable-active-high;
	leds-iio {
		status = "disabled";
		compatible = "gpio-leds";
		led-out0 {
			label = "out0";
			gpios = <&tpic2810 0 GPIO_ACTIVE_HIGH>;
			default-state = "off";
		led-out1 {
			label = "out1";
			gpios = <&tpic2810 1 GPIO_ACTIVE_HIGH>;
		led-out2 {
			label = "out2";
			gpios = <&tpic2810 2 GPIO_ACTIVE_HIGH>;
		led-out3 {
			label = "out3";
			gpios = <&tpic2810 3 GPIO_ACTIVE_HIGH>;
		led-out4 {
			label = "out4";
			gpios = <&tpic2810 4 GPIO_ACTIVE_HIGH>;
		led-out5 {
			label = "out5";
			gpios = <&tpic2810 5 GPIO_ACTIVE_HIGH>;
		led-out6 {
			label = "out6";
			gpios = <&tpic2810 6 GPIO_ACTIVE_HIGH>;
		led-out7 {
			label = "out7";
			gpios = <&tpic2810 7 GPIO_ACTIVE_HIGH>;
	/* Tricolor status LEDs */
	leds1 {
		pinctrl-names = "default";
		pinctrl-0 = <&user_leds>;
		led0 {
			label = "status0:red:cpu0";
			gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
			linux,default-trigger = "cpu0";
		led1 {
			label = "status0:green:usr";
			gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
		led2 {
			label = "status0:yellow:usr";
			gpios = <&gpio3 9 GPIO_ACTIVE_HIGH>;
		led3 {
			label = "status1:red:mmc0";
			gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>;
			linux,default-trigger = "mmc0";
		led4 {
			label = "status1:green:usr";
			gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
		led5 {
			label = "status1:yellow:usr";
			gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
	gpio-decoder {
		compatible = "gpio-decoder";
		gpios = <&pca9536 3 GPIO_ACTIVE_HIGH>,
			<&pca9536 2 GPIO_ACTIVE_HIGH>,
			<&pca9536 1 GPIO_ACTIVE_HIGH>,
			<&pca9536 0 GPIO_ACTIVE_HIGH>;
		linux,axis = <0>; /* ABS_X */
		decoder-max-value = <9>;
	/* Dual mac ethernet application node on icss */
	pruss_eth {
		compatible = "ti,am3359-prueth";
		pruss = <&pruss>;
		sram = <&ocmcram>;
		interrupt-parent = <&pruss_intc>;
		pinctrl-0 = <&pruss_eth_default>;
		pruss_emac0: ethernet-mii0 {
			phy-handle = <&pruss_eth0_phy>;
			phy-mode = "mii";
			interrupts = <20>, <22>;
			interrupt-names = "rx", "tx";
			/* Filled in by bootloader */
			local-mac-address = [00 00 00 00 00 00];
		pruss_emac1: ethernet-mii1 {
			phy-handle = <&pruss_eth1_phy>;
			phy-mode = "mii";
			interrupts = <21>, <23>;
&am33xx_pinmux {
	user_leds: user_leds {
		pinctrl-single,pins = <
			AM33XX_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE7) /* (J18) gmii1_txd3.gpio0[16] */
			AM33XX_IOPAD(0x920, PIN_OUTPUT | MUX_MODE7) /* (K15) gmii1_txd2.gpio0[17] */
			AM33XX_IOPAD(0x9b0, PIN_OUTPUT | MUX_MODE7) /* (A15) xdma_event_intr0.gpio0[19] */
			AM33XX_IOPAD(0x9b4, PIN_OUTPUT | MUX_MODE7) /* (D14) xdma_event_intr1.gpio0[20] */
			AM33XX_IOPAD(0x880, PIN_OUTPUT | MUX_MODE7) /* (U9) gpmc_csn1.gpio1[30] */
			AM33XX_IOPAD(0x92c, PIN_OUTPUT | MUX_MODE7) /* (K18) gmii1_txclk.gpio3[9] */
	mmc0_pins_default: mmc0_pins_default {
			AM33XX_IOPAD(0x8f0, PIN_INPUT_PULLUP | MUX_MODE0) /* (F17) mmc0_dat3.mmc0_dat3 */
			AM33XX_IOPAD(0x8f4, PIN_INPUT_PULLUP | MUX_MODE0) /* (F18) mmc0_dat2.mmc0_dat2 */
			AM33XX_IOPAD(0x8f8, PIN_INPUT_PULLUP | MUX_MODE0) /* (G15) mmc0_dat1.mmc0_dat1 */
			AM33XX_IOPAD(0x8fc, PIN_INPUT_PULLUP | MUX_MODE0) /* (G16) mmc0_dat0.mmc0_dat0 */
			AM33XX_IOPAD(0x900, PIN_INPUT_PULLUP | MUX_MODE0) /* (G17) mmc0_clk.mmc0_clk */
			AM33XX_IOPAD(0x904, PIN_INPUT_PULLUP | MUX_MODE0) /* (G18) mmc0_cmd.mmc0_cmd */
	i2c0_pins_default: i2c0_pins_default {
			AM33XX_IOPAD(0x988, PIN_INPUT | MUX_MODE0) /* (C17) I2C0_SDA.I2C0_SDA */
			AM33XX_IOPAD(0x98c, PIN_INPUT | MUX_MODE0) /* (C16) I2C0_SCL.I2C0_SCL */
	spi0_pins_default: spi0_pins_default {
			AM33XX_IOPAD(0x950, PIN_INPUT_PULLUP | MUX_MODE0) /* (A17) spi0_sclk.spi0_sclk */
			AM33XX_IOPAD(0x954, PIN_INPUT_PULLUP | MUX_MODE0) /* (B17) spi0_d0.spi0_d0 */
			AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE0) /* (B16) spi0_d1.spi0_d1 */
			AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE0) /* (A16) spi0_cs0.spi0_cs0 */
			AM33XX_IOPAD(0x960, PIN_INPUT_PULLUP | MUX_MODE0) /* (C15) spi0_cs1.spi0_cs1 */
			AM33XX_IOPAD(0x9a0, PIN_INPUT_PULLUP | MUX_MODE7) /* (B12) mcasp0_aclkr.gpio3[18] */
	uart3_pins_default: uart3_pins_default {
			AM33XX_IOPAD(0x934, PIN_INPUT_PULLUP | MUX_MODE1) /* (L17) gmii1_rxd3.uart3_rxd */
			AM33XX_IOPAD(0x938, PIN_OUTPUT_PULLUP | MUX_MODE1) /* (L16) gmii1_rxd2.uart3_txd */
	 uart4_pins_default: uart4_pins_default {
                        AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE6) /* (T17) gpmc_wait0.uart4_rxd */
                        AM33XX_IOPAD(0x874, PIN_OUTPUT_PULLUP | MUX_MODE6) /* (U17) gpmc_wpn.uart4_txd */
	cpsw_default: cpsw_default {
			/* Slave 1, RMII mode */
			AM33XX_IOPAD(0x90c, (PIN_INPUT_PULLUP | MUX_MODE1))	/* mii1_crs.rmii1_crs_dv */
			AM33XX_IOPAD(0x944, (PIN_INPUT_PULLUP | MUX_MODE0))	/* rmii1_refclk.rmii1_refclk */
			AM33XX_IOPAD(0x940, (PIN_INPUT_PULLUP | MUX_MODE1))	/* mii1_rxd0.rmii1_rxd0 */
			AM33XX_IOPAD(0x93c, (PIN_INPUT_PULLUP | MUX_MODE1))	/* mii1_rxd1.rmii1_rxd1 */
			AM33XX_IOPAD(0x910, (PIN_INPUT_PULLUP | MUX_MODE1))	/* mii1_rxerr.rmii1_rxerr */
			AM33XX_IOPAD(0x928, (PIN_OUTPUT_PULLDOWN | MUX_MODE1))	/* mii1_txd0.rmii1_txd0 */
			AM33XX_IOPAD(0x924, (PIN_OUTPUT_PULLDOWN | MUX_MODE1))	/* mii1_txd1.rmii1_txd1 */
			AM33XX_IOPAD(0x914, (PIN_OUTPUT_PULLDOWN | MUX_MODE1))	/* mii1_txen.rmii1_txen */
			/* Slave 2, RMII mode */
			AM33XX_IOPAD(0x870, (PIN_INPUT_PULLUP | MUX_MODE3))	/* gpmc_wait0.rmii2_crs_dv */
			AM33XX_IOPAD(0x908, (PIN_INPUT_PULLUP | MUX_MODE1))	/* mii1_col.rmii2_refclk */
			AM33XX_IOPAD(0x86c, (PIN_INPUT_PULLUP | MUX_MODE3))	/* gpmc_a11.rmii2_rxd0 */
			AM33XX_IOPAD(0x868, (PIN_INPUT_PULLUP | MUX_MODE3))	/* gpmc_a10.rmii2_rxd1 */
			AM33XX_IOPAD(0x874, (PIN_INPUT_PULLUP | MUX_MODE3))	/* gpmc_wpn.rmii2_rxerr */
			AM33XX_IOPAD(0x854, (PIN_OUTPUT_PULLDOWN | MUX_MODE3))	/* gpmc_a5.rmii2_txd0 */
			AM33XX_IOPAD(0x850, (PIN_OUTPUT_PULLDOWN | MUX_MODE3))	/* gpmc_a4.rmii2_txd1 */
			AM33XX_IOPAD(0x840, (PIN_OUTPUT_PULLDOWN | MUX_MODE3))	/* gpmc_a0.rmii2_txen */
	cpsw_sleep: cpsw_sleep {
			/* Slave 1 reset value */
			AM33XX_IOPAD(0x90c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x944, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x940, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x93c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x910, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x928, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x924, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x914, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			/* Slave 2 reset value */
			AM33XX_IOPAD(0x870, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x908, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x86c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x868, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x874, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x854, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x850, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x840, (PIN_INPUT_PULLDOWN | MUX_MODE7))
	davinci_mdio_default: davinci_mdio_default {
			/* MDIO */
			AM33XX_IOPAD(0x948, (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0))	/* mdio_data.mdio_data */
			AM33XX_IOPAD(0x94c, (PIN_OUTPUT_PULLUP | MUX_MODE0))			/* mdio_clk.mdio_clk */
	davinci_mdio_sleep: davinci_mdio_sleep {
			/* MDIO reset value */
			AM33XX_IOPAD(0x948, (PIN_INPUT_PULLDOWN | MUX_MODE7))
			AM33XX_IOPAD(0x94c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
	pruss_mdio_default: pruss_mdio_default {
			AM33XX_IOPAD(0x88c, (PIN_OUTPUT | MUX_MODE5))		/* gpmc_clk.pr1_mdio_mdclk */
			AM33XX_IOPAD(0x888, (PIN_INPUT  | MUX_MODE5))		/* gpmc_csn3.pr1_mdio_data */
			AM33XX_IOPAD(0x89c, (PIN_INPUT_PULLUP | MUX_MODE7))	/* gpmc_ben0_cle.gpio2_5 */
			/* disable CPSW MDIO */
			AM33XX_IOPAD(0x948, (PIN_INPUT_PULLUP | MUX_MODE7))	/* mdio_data.gpio0_0 */
			AM33XX_IOPAD(0x94c, (PIN_INPUT_PULLUP | MUX_MODE7))	/* mdio_clk.gpio0_1 */
	pruss_eth_default: pruss_eth_default {
			AM33XX_IOPAD(0x8a0, (PIN_INPUT  | MUX_MODE2))	/* dss_data0.pr1_mii_mt0_clk */
			AM33XX_IOPAD(0x8b4, (PIN_OUTPUT | MUX_MODE2))	/* dss_data5.pr1_mii0_txd0 */
			AM33XX_IOPAD(0x8b0, (PIN_OUTPUT | MUX_MODE2))	/* dss_data4.pr1_mii0_txd1 */
			AM33XX_IOPAD(0x8ac, (PIN_OUTPUT | MUX_MODE2))	/* dss_data3.pr1_mii0_txd2 */
			AM33XX_IOPAD(0x8a8, (PIN_OUTPUT | MUX_MODE2))	/* dss_data2.pr1_mii0_txd3 */
			AM33XX_IOPAD(0x8cc, (PIN_INPUT  | MUX_MODE5))	/* dss_data11.pr1_mii0_rxd0 */
			AM33XX_IOPAD(0x8c8, (PIN_INPUT  | MUX_MODE5))	/* dss_data10.pr1_mii0_rxd1 */
			AM33XX_IOPAD(0x8c4, (PIN_INPUT  | MUX_MODE5))	/* dss_data9.pr1_mii0_rxd2 */
			AM33XX_IOPAD(0x8c0, (PIN_INPUT  | MUX_MODE5))	/* dss_data8.pr1_mii0_rxd3 */
			AM33XX_IOPAD(0x8a4, (PIN_OUTPUT | MUX_MODE2))	/* dss_data1.pr1_mii0_txen */
			AM33XX_IOPAD(0x8d8, (PIN_INPUT  | MUX_MODE5))	/* dss_data14.pr1_mii_mr0_clk */
			AM33XX_IOPAD(0x8dc, (PIN_INPUT  | MUX_MODE5))	/* dss_data15.pr1_mii0_rxdv */
			AM33XX_IOPAD(0x8d4, (PIN_INPUT  | MUX_MODE5))	/* dss_data13.pr1_mii0_rxer */
			AM33XX_IOPAD(0x8d0, (PIN_INPUT  | MUX_MODE5))	/* dss_data12.pr1_mii0_rxlink */
			AM33XX_IOPAD(0x8e8, (PIN_INPUT  | MUX_MODE2))	/* dss_pclk.pr1_mii0_crs */
			AM33XX_IOPAD(0x840, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a0.pr1_mii_mt1_clk */
			AM33XX_IOPAD(0x850, (PIN_OUTPUT | MUX_MODE5))	/* gpmc_a4.pr1_mii1_txd0 */
			AM33XX_IOPAD(0x84c, (PIN_OUTPUT | MUX_MODE5))	/* gpmc_a3.pr1_mii1_txd1 */
			AM33XX_IOPAD(0x848, (PIN_OUTPUT | MUX_MODE5))	/* gpmc_a2.pr1_mii1_txd2 */
			AM33XX_IOPAD(0x844, (PIN_OUTPUT | MUX_MODE5))	/* gpmc_a1.pr1_mii1_txd3 */
			AM33XX_IOPAD(0x860, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a8.pr1_mii1_rxd0 */
			AM33XX_IOPAD(0x85c, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a7.pr1_mii1_rxd1 */
			AM33XX_IOPAD(0x858, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a6.pr1_mii1_rxd2 */
			AM33XX_IOPAD(0x854, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a5.pr1_mii1_rxd3 */
			AM33XX_IOPAD(0x874, (PIN_OUTPUT | MUX_MODE5))	/* gpmc_wpn.pr1_mii1_txen */
			AM33XX_IOPAD(0x864, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a9.pr1_mii_mr1_clk */
			AM33XX_IOPAD(0x868, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a10.pr1_mii1_rxdv */
			AM33XX_IOPAD(0x86c, (PIN_INPUT  | MUX_MODE5))	/* gpmc_a11.pr1_mii1_rxer */
			AM33XX_IOPAD(0x878, (PIN_INPUT  | MUX_MODE5))	/* gpmc_ben1.pr1_mii1_rxlink */
			AM33XX_IOPAD(0x8ec, (PIN_INPUT  | MUX_MODE2))	/* lcd_ac_bias_en.pr1_mii1_crs */
			AM33XX_IOPAD(0x870, (PIN_INPUT  | MUX_MODE5))	/* gpmc_wait0.pr1_mii1_col */
	gpmc_pins: gpmc_pins {
		pinctrl-single,pins=<
			AM33XX_IOPAD(0x800,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad0.gpmc.ad0*/
			AM33XX_IOPAD(0x804,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad1.gpmc.ad1*/
			AM33XX_IOPAD(0x808,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad2.gpmc.ad2*/
			AM33XX_IOPAD(0x80C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad3.gpmc.ad3*/
			AM33XX_IOPAD(0x810,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad4.gpmc.ad4*/
			AM33XX_IOPAD(0x814,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad5.gpmc.ad5*/
			AM33XX_IOPAD(0x818,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad6.gpmc.ad6*/
			AM33XX_IOPAD(0x81C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad7.gpmc.ad7*/
			AM33XX_IOPAD(0x820,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad8.gpmc.ad8*/
			AM33XX_IOPAD(0x824,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad9.gpmc.ad9*/
			AM33XX_IOPAD(0x828,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad10.gpmc.ad10*/
			AM33XX_IOPAD(0x82C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad11.gpmc.ad11*/
			AM33XX_IOPAD(0x830,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad12.gpmc.ad12*/
			AM33XX_IOPAD(0x834,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad13.gpmc.ad13*/
			AM33XX_IOPAD(0x838,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad14.gpmc.ad14*/
			AM33XX_IOPAD(0x83C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad15.gpmc.ad15*/
			AM33XX_IOPAD(0x870,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_wait0*/
			AM33XX_IOPAD(0x874,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_wpn*/
			AM33XX_IOPAD(0x878,PIN_OUTPUT|MUX_MODE0)/*gpmc_ben1*/
			AM33XX_IOPAD(0x87C,PIN_OUTPUT|MUX_MODE0)/*gpmc_csn0*/
			AM33XX_IOPAD(0x884,PIN_OUTPUT|MUX_MODE0)/*gpmc_csn2*/
			AM33XX_IOPAD(0x88C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_clk*/
			AM33XX_IOPAD(0x890,PIN_OUTPUT|MUX_MODE0)/*gpmc_advn_ale*/
			AM33XX_IOPAD(0x894,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_oen_ren*/
			AM33XX_IOPAD(0x898,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_wen*/
			AM33XX_IOPAD(0x89C,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_ben0_cle*/
&i2c0 {
	pinctrl-0 = <&i2c0_pins_default>;
	status = "okay";
	clock-frequency = <400000>;
	tps: power-controller@2d {
		reg = <0x2d>;
	tpic2810: gpio@60 {
		compatible = "ti,tpic2810";
		reg = <0x60>;
		gpio-controller;
		#gpio-cells = <2>;
	pca9536: gpio@41 {
		compatible = "ti,pca9536";
		reg = <0x41>;
		gpio-controller;
		#gpio-cells = <2>;
&spi0 {
	status = "okay";
	pinctrl-0 = <&spi0_pins_default>;
	sn65hvs882@1 {
		compatible = "pisosr-gpio";
		gpio-controller;
		#gpio-cells = <2>;
		load-gpios = <&gpio3 18 GPIO_ACTIVE_LOW>;
		reg = <1>;
		spi-max-frequency = <1000000>;
		spi-cpol;
	spi_nor: flash@0 {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "winbond,w25q64", "jedec,spi-nor";
		spi-max-frequency = <80000000>;
		m25p,fast-read;
		reg = <0>;
		partition@0 {
			label = "u-boot-spl";
			reg = <0x0 0x80000>;
			read-only;
		partition@1 {
			label = "u-boot";
			reg = <0x80000 0x100000>;
			read-only;
		partition@2 {
			label = "u-boot-env";
			reg = <0x180000 0x20000>;
			read-only;
		partition@3 {
			label = "misc";
			reg = <0x1A0000 0x660000>;
&tscadc {
	status = "okay";
	adc {
		ti,adc-channels = <1 2 3 4 5 6 7>;
#include "tps65910.dtsi"
&tps {
	vcc1-supply = <&vbat>;
	vcc2-supply = <&vbat>;
	vcc3-supply = <&vbat>;
	vcc4-supply = <&vbat>;
	vcc5-supply = <&vbat>;
	vcc6-supply = <&vbat>;
	vcc7-supply = <&vbat>;
	vccio-supply = <&vbat>;
	regulators {
		vrtc_reg: regulator@0 {
		vio_reg: regulator@1 {
		vdd1_reg: regulator@2 {
			regulator-name = "vdd_mpu";
			regulator-min-microvolt = <912500>;
			regulator-max-microvolt = <1326000>;
			regulator-boot-on;
		vdd2_reg: regulator@3 {
			regulator-name = "vdd_core";
			regulator-max-microvolt = <1144000>;
			regulator-boot-on;
		vdd3_reg: regulator@4 {
		vdig1_reg: regulator@5 {
		vdig2_reg: regulator@6 {
		vpll_reg: regulator@7 {
		vdac_reg: regulator@8 {
		vaux1_reg: regulator@9 {
		vaux2_reg: regulator@10 {
		vaux33_reg: regulator@11 {
		vmmc_reg: regulator@12 {
			regulator-min-microvolt = <1800000>;
			regulator-max-microvolt = <3300000>;
&mmc1 {
	status = "okay";
	vmmc-supply = <&vmmc_reg>;
	bus-width = <4>;
	pinctrl-0 = <&mmc0_pins_default>;
&gpio0 {
	/* Do not idle the GPIO used for holding the VTT regulator */
	ti,no-reset-on-init;
	ti,no-idle-on-init;
	p7 {
		gpio-hog;
		gpios = <7 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "FET_SWITCH_CTRL";
&uart3 {
	pinctrl-0 = <&uart3_pins_default>;
	status = "okay";
&uart4 {
        pinctrl-0 = <&uart4_pins_default>;
        status = "okay";
&gpio3 {
	p4 {
		gpio-hog;
		gpios = <4 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "PR1_MII_CTRL";
	p10 {
		gpio-hog;
		gpios = <10 GPIO_ACTIVE_HIGH>;
		/* ETH1 mux: Low for MII-PRU, high for RMII-CPSW */
		output-high;
		line-name = "MUX_MII_CTL1";
&cpsw_emac0 {
	phy_id = <&davinci_mdio>, <1>;
	phy-mode = "rmii";
	dual_emac_res_vlan = <1>;
&cpsw_emac1 {
	phy_id = <&davinci_mdio>, <3>;
	phy-mode = "rmii";
	dual_emac_res_vlan = <2>;
&mac {
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&cpsw_default>;
	pinctrl-1 = <&cpsw_sleep>;
	status = "okay";
	dual_emac;
&phy_sel {
	rmii-clock-ext;
&davinci_mdio {
	pinctrl-0 = <&davinci_mdio_default>;
	pinctrl-1 = <&davinci_mdio_sleep>;
	status = "okay";
	reset-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
	reset-delay-us = <2>;   /* PHY datasheet states 1uS min */
&pruss_soc_bus {
	status = "okay";
	pruss: pruss@4a300000 {
		status = "okay";
		pru0: pru@4a334000 {
			status = "okay";
		pru1: pru@4a338000 {
			status = "okay";
&pruss_mdio {
	pinctrl-0 = <&pruss_mdio_default>;
	pruss_eth0_phy: ethernet-phy@1 {
		 reg = <1>;
	pruss_eth1_phy: ethernet-phy@3 {
		 reg = <3>;
/*&i2c1{
        compatible = "ti,omap4-i2c";
        #size-cells = <0>;
        ti,hwmods = "i2c2";
        reg = <0x4802a000 0x1000>;
        interrupts = <71>;
        status = "okay";
		ad7414@48 {
			compatible = "analog,ad7414";
        		reg = <0x48>;
      		  	status = "okay";
&gpmc {
	status = "okay";
	pinctrl-0 = <&gpmc_pins>;
	/*ranges = <0 0 0x08000000 0x10000000>; *//* CS0: NAND */
	ranges = <0 0 0x08000000 0x10000000>,	/*CSn0 for NAND*/
        	 <2 0 0x18000000 0x08000000>;   /*CSn2 for FPGA*/
	nand@0,0 {
		  compatible = "ti,omap2-nand";
		  reg = <0 0 4>; /* CS0, offset 0 */
		  ti,nand-ecc-opt = "bch8";
		  ti,elm-id = <&elm>;
		  nand-bus-width = <16>;
		  ti,nand-xfer-type = "polled";
       		  rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */
		  gpmc,device-width = <1>;
		  gpmc,sync-clk-ps = <0>;
		  gpmc,cs-on-ns = <0>;
		  gpmc,cs-rd-off-ns = <44>;
		  gpmc,cs-wr-off-ns = <44>;
		  gpmc,adv-on-ns = <6>;
                  gpmc,adv-rd-off-ns = <34>;
                  gpmc,adv-wr-off-ns = <44>;
		  gpmc,we-on-ns = <0>;
                  gpmc,we-off-ns = <40>;
                  gpmc,oe-on-ns = <0>;
                  gpmc,oe-off-ns = <54>;
                  gpmc,access-ns = <64>;
                  gpmc,rd-cycle-ns = <82>;
                  gpmc,wr-cycle-ns = <82>;
                  gpmc,wait-on-read = "true";
                  gpmc,wait-on-write = "true";
                  gpmc,bus-turnaround-ns = <0>;
                  gpmc,cycle2cycle-delay-ns = <0>;
                  gpmc,clk-activation-ns = <0>;
                  gpmc,wait-monitoring-ns = <0>;
                  gpmc,wr-access-ns = <40>;
                  gpmc,wr-data-mux-bus-ns = <0>;
/* MTD partition table */
/* All SPL-* partitions are sized to minimal length
* which can be independently programmable. For
* NAND flash this is equal to size of erase-block */
	#size-cells = <1>;
	partition@0 {
		     label = "NAND.SPL";
		     reg = <0x00000000 0x000020000>;
	partition@1 {
		     label = "NAND.SPL.backup1";
		     reg = <0x00020000 0x00020000>;
	partition@2 {
		     label = "NAND.SPL.backup2";
		     reg = <0x00040000 0x00020000>;
	partition@3 {
		     label = "NAND.SPL.backup3";
                     reg = <0x00060000 0x00020000>;
        partition@4 {
                     label = "NAND.u-boot-spl-os";
                     reg = <0x00080000 0x00040000>;
	partition@5 {
		     label = "NAND.u-boot";
		     reg = <0x000C0000 0x00100000>;
	partition@6 {
		     label = "NAND.u-boot-env";
		     reg = <0x001C0000 0x00020000>;
	partition@7 {
		     label = "NAND.u-boot-env.backup1";
		     reg = <0x001E0000 0x00020000>;
	partition@8 {
		      label = "NAND.kernel";
		      reg = <0x00200000 0x00800000>;
	partition@9 {
		      label = "NAND.file-system";
		      reg = <0x00A00000 0x0F600000>;
	fpga{
	     reg = <2 0 0x10000000>; /*CSn2*/
             compatible = "xillybus,xillybus-1.00.a";
	     #size-cells = <0>;
             bank-width = <2>; /* GPMC_CONFIG1_DEVICESIZE(1) *//*16 bit wide*/
             /*gpmc,burst-write;*/
             /*gpmc,burst-read;*/
             /*gpmc,burst-wrap;*/
             gpmc,sync-read; /* GPMC_CONFIG1_READTYPE_ASYNC */
             gpmc,sync-write; /* GPMC_CONFIG1_WRITETYPE_ASYNC */
             gpmc,clk-activation-ns = <0>; /* GPMC_CONFIG1_CLKACTIVATIONTIME(2) */
             gpmc,burst-length = <16>; /* GPMC_CONFIG1_PAGE_LEN(2) */
             gpmc,mux-add-data = <2>; /* GPMC_CONFIG1_MUXTYPE(2) */
             gpmc,sync-clk-ps = <20000>; /* CONFIG2 */
             gpmc,cs-rd-off-ns = <100>;
             gpmc,cs-wr-off-ns = <40>;
             gpmc,adv-on-ns = <0>; /* CONFIG3 */
             gpmc,adv-rd-off-ns = <20>;
             gpmc,adv-wr-off-ns = <20>;
             gpmc,we-on-ns = <20>; /* CONFIG4 */
             gpmc,oe-on-ns = <20>;
             gpmc,oe-off-ns = <100>;
             gpmc,page-burst-access-ns = <20>; /* CONFIG 5 */
             gpmc,access-ns = <80>;
             gpmc,rd-cycle-ns = <120>;
             gpmc,wr-cycle-ns = <60>;
             gpmc,wr-access-ns = <40>; /* CONFIG 6 */
             gpmc,wr-data-mux-bus-ns = <20>;
            /*gpmc,bus-turnaround-ns = <40>;*/ /* CONFIG6:3:0 = 4 */
             gpmc,cycle2cycle-samecsen; /* CONFIG6:7 = 1 */
             gpmc,cycle2cycle-delay-ns = <20>; /* CONFIG6:11:8 = 4 */
/* not using dma engine yet, but we can get the channel number here */
             dmas = <&edma 1>;
             dma-names = "cscdma";
Murugan S
  • 1. The external signal GPMC_CLK is present only when Synchronous accesses are performed on the GPMC. What you are seeing at R150 is the PRU_ICSS MDIO clock probing for PHY's, which means that you have not disabled the PRU units.
    2. Yes, this is normal. CS signal will go low only on GPMC accesses.
    3. Please post the GPMC portion of the device tree.
  • Hi Biser,
    As always thanks for the quick response.These are my configuration related to gpmc in dts.I also made some minor modifications in the address ranges.
    &am33xx_pinmux {
    &gpmc {
    status = "okay";
    ranges = <0 0 0x08000000 0x1000000>, /*CSn0 for NAND*/
    <2 0 0x09000000 0x01000000>; /*CSn2 for FPGA*/
    nand@0,0 {
    reg = <0 0 0x01000000>; /* CS0, offset 0 */
    /*nand timing and partitions deprecated*/
    fpga@1,0{
    reg = <2 0 0x01000000>; /*CSn2*/
    #size-cells = <0>;
    /*fpga timings deprecated*/
    I also commented all pinmuxing which uses the same pins as gpmc(except a1-10):
    Under cpsw_default:
    /*AM33XX_IOPAD(0x870, (PIN_INPUT_PULLUP | MUX_MODE3))*/ /* gpmc_wait0.rmii2_crs_dv */
    /*AM33XX_IOPAD(0x874, (PIN_INPUT_PULLUP | MUX_MODE3))*/ /* gpmc_wpn.rmii2_rxerr */
    Under cpsw_sleep:
    /*AM33XX_IOPAD(0x874, (PIN_INPUT_PULLDOWN | MUX_MODE7))*/
    Under pruss_mdio_default:
    /*AM33XX_IOPAD(0x88c, (PIN_OUTPUT | MUX_MODE5))*//* gpmc_clk.pr1_mdio_mdclk */
    /*AM33XX_IOPAD(0x89c, (PIN_INPUT_PULLUP | MUX_MODE7))*/
    Under pruss_eth_default:
    /*AM33XX_IOPAD(0x874, (PIN_OUTPUT | MUX_MODE5))*/ /* gpmc_wpn.pr1_mii1_txen */
    /*AM33XX_IOPAD(0x878, (PIN_INPUT | MUX_MODE5))*/ /* gpmc_ben1.pr1_mii1_rxlink */
    /*AM33XX_IOPAD(0x870, (PIN_INPUT | MUX_MODE5))*/ /* gpmc_wait0.pr1_mii1_col */
    Now i got the following log:
    [ 1.403880] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [ 1.409229] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000             <--why is this?
    [ 1.415379] gpiochip_find_base: found new base at 510
    [ 1.415437] gpio gpiochip4: (omap-gpmc): added GPIO chardev (254:4)
    [ 1.415848] gpiochip_setup_dev: registered GPIOs 510 to 511 on device: gpiochip4 (omap-gpmc)
    [ 1.417004] omap2-nand 8000000.nand: GPIO lookup for consumer rb
    [ 1.417015] omap2-nand 8000000.nand: using device tree for GPIO lookup
    [ 1.417054] of_get_named_gpiod_flags: parsed 'rb-gpios' property of node '/ocp/gpmc@50000000/nand@0,0[0]' - status (0)
    [ 1.417123] nand: No NAND device found
    [ 1.421031] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch  <-this?
    [ 1.428565] gpmc_read_settings_dt: page/burst-length set but not used!
    [ 1.436100] xillybus_of 9000000.fpga: Failed to register IRQ handler. Aborting.
    Is possible to give interrupts=< > property for the gpmc child node? What is the interrupt number used for gpmc?
    Murugan S
  • Hi Biser,
    I added interrupt property to both child nodes and now my log is :
    [ 1.409286] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [ 1.415436] gpiochip_find_base: found new base at 510
    [ 1.415495] gpio gpiochip4: (omap-gpmc): added GPIO chardev (254:4)
    [ 1.415883] gpiochip_setup_dev: registered GPIOs 510 to 511 on device: gpiochip4 (omap-gpmc)
    [ 1.417242] omap2-nand 8000000.nand: GPIO lookup for consumer rb
    [ 1.417251] omap2-nand 8000000.nand: using device tree for GPIO lookup
    [ 1.417292] of_get_named_gpiod_flags: parsed 'rb-gpios' property of node '/ocp/gpmc@50000000/nand@0,0[0]' - status (0)
    [ 1.417359] nand: No NAND device found
    [ 1.421278] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
    [ 1.428864] gpmc_read_settings_dt: page/burst-length set but not used!
    [ 1.538738] xillybus_of 9000000.fpga: No response from FPGA. Aborting.
    Murugan S
  • Murugan,
    Seems that you were able to fix this issue. Do you have more questions regarding GPMC settings?
    Pavel
  • Hi Pavel,
    I have doubts regarding assigning interrupt numbers and dma configuration for gpmc child nodes.
    This is my dts configuration:
    &gpmc {
    status = "okay";
    dmas = <&edma 52 0>;
    dma-names = "rxtx";
    ranges = <0 0 0x08000000 0x01000000>, /*CSn0 for NAND*/
    nand@0,0 {
    /* interrupt-parent = <&gpmc>;*/
    interrupts = <0 0>, <1 0>;
    ti,elm-id = <&elm>;
    #size-cells = <1>;
    /*partitions goes here*/
    fpga@1,0{
    #size-cells = <0>;
    interrupts = <0 0>, <1 0>; ----->can interrupt number be same for both child nodes?
    dmas = <&edma 1>;
    dma-names = "rxtx"; -----> is this necessary for dma access?
    Murugan S
  • Murugan,
    Your questions seems to be related to Xillybus FPGA chip, not to AM335x GPMC controller. You need to check these with Xillybus FPGA support team.
    Regarding AM335x GPMC devicetree usage, check below pointers:
    linux-kernel/Documentation/devicetree/bindings/memory-controllers/omap-gpmc.txt
    linux-kernel/Documentation/devicetree/bindings/mtd/gpmc-nand.txt
    Pavel
