Part Number: AM5708
Other Parts Discussed in Thread: DRA72, DRA71, SYSCONFIG
Tool/software: Linux
Hi
I have a custom AM5708 based board. I have a DSP program that manages GPIO2, GPIO5 and GPIO6 ports.
It works fine if in the A15 is not running linux. If so, GPIO2 and GPIO5 work fine but not GPIO6.
I guess that there could be a conflict between any device in Linux and GPIO6 mangament in DSP.
Attached are the dts, config and linx log files.
Billa 5430.bridge_linux.dts.txt
* Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include "dra72-evm-common.dtsi"
#include "dra72x-mmc-iodelay.dtsi"
#include <dt-bindings/gpio/gpio.h>
compatible = "ti,dra718-evm", "ti,dra718", "ti,dra722", "ti,dra72", "ti,dra7";
model = "TI DRA718 EVM";
memory {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x20000000>; /* 512MB */
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ipu2_memory_region: ipu2-memory@95800000 {
compatible = "shared-dma-pool";
reg = <0x0 0x95800000 0x0 0x3800000>;
reusable;
status = "okay";
dsp1_memory_region: dsp1-memory@99000000 {
reg = <0x0 0x99000000 0x0 0x4000000>;
reusable;
status = "okay";
ipu1_memory_region: ipu1-memory@9d000000 {
reg = <0x0 0x9d000000 0x0 0x2000000>;
reusable;
status = "okay";
vpo_sd_1v8_3v3: gpio-regulator-TPS74801 {
compatible = "regulator-gpio";
regulator-name = "vddshv8";
regulator-okmin-microvolt = <1800000>;
regulator-max-microvolt = <3000000>;
regulator-boot-on;
vin-supply = <&evm_5v0>;
gpios = <&gpio7 11 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0
3000000 0x1>;
evm_1v8_sw: fixedregulator-evm_1v8 {
compatible = "regulator-fixed";
regulator-name = "evm_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vin-supply = <&lp8732_buck0_reg>;
regulator-always-on;
regulator-boot-on;
poweroff: gpio-poweroff {
compatible = "gpio-poweroff";
gpios = <&gpio7 30 GPIO_ACTIVE_HIGH>;
input;
&i2c1 {
status = "disabled";
clock-frequency = <400000>;
lp8733: lp8733@60 {
compatible = "ti,lp8733";
reg = <0x60>;
buck0-in-supply =<&vsys_3v3>;
buck1-in-supply =<&vsys_3v3>;
ldo0-in-supply =<&evm_5v0>;
ldo1-in-supply =<&evm_5v0>;
lp8733_regulators: regulators {
lp8733_buck0_reg: buck0 {
/* FB_B0 -> LP8733-BUCK1 - VPO_S1_AVS - VDD_CORE_AVS (core, mpu, gpu) */
regulator-name = "lp8733-buck0";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <1250000>;
regulator-boot-on;
lp8733_buck1_reg: buck1 {
/* FB_B1 -> LP8733-BUCK2 - VPO_S2_AVS - VDD_DSP_AVS (DSP/eve/iva) */
regulator-name = "lp8733-buck1";
regulator-boot-on;
lp8733_ldo0_reg: ldo0 {
/* LDO0 -> LP8733-LDO1 - VPO_L1_3V3 - VDDSHV8 (optional) */
regulator-name = "lp8733-ldo0";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
lp8733_ldo1_reg: ldo1 {
/* LDO1 -> LP8733-LDO2 - VPO_L2_3V3 - VDDA_USB3V3 */
regulator-name = "lp8733-ldo1";
regulator-boot-on;
lp8732: lp8732@61 {
compatible = "ti,lp8732";
reg = <0x61>;
ldo0-in-supply =<&vsys_3v3>;
ldo1-in-supply =<&vsys_3v3>;
lp8732_regulators: regulators {
lp8732_buck0_reg: buck0 {
/* FB_B0 -> LP8732-BUCK1 - VPO_S3_1V8 - VDDS_1V8 */
regulator-name = "lp8732-buck0";
regulator-boot-on;
lp8732_buck1_reg: buck1 {
/* FB_B1 -> LP8732-BUCK2 - VPO_S4_DDR - VDD_DDR_1V35 */
regulator-name = "lp8732-buck1";
regulator-min-microvolt = <1350000>;
regulator-max-microvolt = <1350000>;
regulator-boot-on;
lp8732_ldo0_reg: ldo0 {
/* LDO0 -> LP8732-LDO1 - VPO_L3_1V8 - VDA_1V8_PLL */
regulator-name = "lp8732-ldo0";
regulator-boot-on;
lp8732_ldo1_reg: ldo1 {
/* LDO1 -> LP8732-LDO2 - VPO_L4_1V8 - VDA_1V8_PHY */
regulator-name = "lp8732-ldo1";
regulator-boot-on;
&csi2_cam0 {
clock-lanes = <0>;
data-lanes = <1 2>;
remote-endpoint = <&csi2_phy0>;
&pcf_lcd {
interrupt-parent = <&gpio7>;
interrupts = <31 IRQ_TYPE_EDGE_FALLING>;
&pcf_gpio_21 {
&pcf_hdmi {
p0 {
* PM_OEn to High: Disable routing I2C3 to PM_I2C
* With this PM_SEL(p3) should not matter
gpio-hog;
gpios = <0 GPIO_ACTIVE_LOW>;
output-high;
line-name = "pm_oe_n";
&mmc1 {
pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_hs>;
pinctrl-2 = <&mmc1_pins_sdr12>;
pinctrl-3 = <&mmc1_pins_sdr25>;
pinctrl-4 = <&mmc1_pins_sdr50>;
pinctrl-5 = <&mmc1_pins_ddr50_rev20 &mmc1_iodelay_ddr50_conf>;
pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
vqmmc-supply = <&vpo_sd_1v8_3v3>;
&mmc2 {
status = "okay";
pinctrl-names = "default", "hs", "ddr_1_8v";
pinctrl-0 = <&mmc2_pins_default>;
pinctrl-1 = <&mmc2_pins_hs>;
pinctrl-2 = <&mmc2_pins_ddr_rev20 &mmc2_iodelay_ddr_conf>;
vmmc-supply = <&evm_3v3_sw>;
vqmmc-supply = <&evm_3v3_sw>;
&davinci_mdio {
reset-gpios = <&gpio4 31 GPIO_ACTIVE_LOW>;
reset-delay-us = <2>;
phy0:ethernet-phy@0 {
reg = <0>;
&mac {
slaves = <1>;
status = "okay";
sram = <&ocmcram1>;
&cpsw_emac0 {
phy-handle = <&phy0>;
phy-mode = "mii";
status = "okay";
&cpsw_emac1 {
/* No Sata on this device */
&sata_phy {
&sata {
/* No RTC on this device */
&rtc {
&usb2_phy1 {
phy-supply = <&lp8733_ldo1_reg>;
&usb2_phy2 {
&dss {
/* Supplied by VDA_1V8_PLL */
vdda_video-supply = <&lp8732_ldo0_reg>;
&hdmi {
/* Supplied by VDA_1V8_PHY */
vdda_video-supply = <&lp8732_ldo1_reg>;
&ipu2 {
status = "okay";
memory-region = <&ipu2_memory_region>;
&ipu1 {
status = "okay";
memory-region = <&ipu1_memory_region>;
&dsp1 {
status = "okay";
memory-region = <&dsp1_memory_region>;
&uart1 {
status = "okay";
&uart3 {
status = "okay";
&uart6 {
status = "okay";
&i2c5 {
&elm {
&usb1 {
&usb2 {
status = "okay";
&dcan1 {
&dcan2 {
status = "okay";
&atl {
&pcie1_rc {
&mcasp3 {
&keypad {
status = "okay";
#include "bridge-cmem.dtsi"
* Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
#include "dra72x.dtsi"
#include "dra7-ipu-dsp-common.dtsi"
#include <dt-bindings/clk/ti-dra7-atl.h>
compatible = "ti,dra72-evm", "ti,dra722", "ti,dra72", "ti,dra7";
aliases {
display0 = &hdmi0;
chosen {
stdout-path = &uart3;
evm_12v0: fixedregulator-evm12v0 {
/* main supply */
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-boot-on;
evm_5v0: fixedregulator-evm5v0 {
/* Output 1 of TPS43351QDAPRQ1 on dra72-evm */
/* Output 1 of LM5140QRWGTQ1 on dra71-evm */
regulator-name = "evm_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
evm_3v6: fixedregulator-evm_3v6 {
regulator-name = "evm_3v6";
regulator-min-microvolt = <3600000>;
regulator-max-microvolt = <3600000>;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output 2 of TPS43351QDAPRQ1 on dra72-evm */
/* Output 2 of LM5140QRWGTQ1 on dra71-evm */
regulator-name = "vsys_3v3";
regulator-boot-on;
evm_3v3_sw: fixedregulator-evm_3v3 {
/* TPS22965DSG */
regulator-name = "evm_3v3";
vin-supply = <&vsys_3v3>;
regulator-boot-on;
aic_dvdd: fixedregulator-aic_dvdd {
/* TPS77018DBVT */
regulator-name = "aic_dvdd";
vin-supply = <&evm_3v3_sw>;
evm_3v3_sd: fixedregulator-sd {
regulator-name = "evm_3v3_sd";
enable-active-high;
gpio = <&pcf_gpio_21 5 GPIO_ACTIVE_HIGH>;
extcon_usb1: extcon_usb1 {
compatible = "linux,extcon-usb-gpio";
id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
extcon_usb2: extcon_usb2 {
vbus-gpio = <&gpio3 30 GPIO_ACTIVE_HIGH>;
hdmi0: connector {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&tpd12s015_out>;
tpd12s015: encoder {
compatible = "ti,tpd12s015";
gpios = <&pcf_hdmi 4 GPIO_ACTIVE_HIGH>, /* P4, CT CP HPD */
<&pcf_hdmi 5 GPIO_ACTIVE_HIGH>, /* P5, LS OE */
<&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tpd12s015_in: endpoint {
remote-endpoint = <&hdmi_out>;
port@1 {
reg = <1>;
tpd12s015_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
sound0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "DRA7xx-EVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line Out",
"Microphone", "Mic Jack",
"Line", "Line In";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"Line Out", "LLOUT",
"Line Out", "RLOUT",
"MIC3L", "Mic Jack",
"MIC3R", "Mic Jack",
"Mic Jack", "Mic Bias",
"LINE1L", "Line In",
"LINE1R", "Line In";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound0_master>;
simple-audio-card,frame-master = <&sound0_master>;
simple-audio-card,bitclock-inversion;
sound0_master: simple-audio-card,cpu {
sound-dai = <&mcasp3>;
system-clock-frequency = <5644800>;
simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&atl_clkin2_ck>;
clk_ov10633_fixed: clk_ov10633_fixed {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
vmmcwl_fixed: fixedregulator-mmcwl {
regulator-name = "vmmcwl_fixed";
gpio = <&gpio5 8 GPIO_ACTIVE_HIGH>;
enable-active-high;
keypad: keypad@4ae1c000 {
compatible = "ti,omap4-keypad";
#size-cells = <1>;
reg = <0x4ae1c000 0x400>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>;
keypad,num-rows = <3>;
keypad,num-columns = <4>;
linux,keymap = <0x00000041 0x00010042 0x00020043 0x00030044
0x01000045 0x01010046 0x01020047 0x01030048
0x02000049 0x0201004a 0x0202004b 0x0203004c>;
ti,hwmods="kbd";
&dra7_pmx_core {
dcan1_pins_default: dcan1_pins_default {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x37d0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
DRA7XX_CORE_IOPAD(0x37d4, PULL_UP | MUX_MODE0) /* dcan1_rx */
dcan1_pins_sleep: dcan1_pins_sleep {
DRA7XX_CORE_IOPAD(0x37d0, MUX_MODE15 | PULL_UP) /* dcan1_tx.off */
DRA7XX_CORE_IOPAD(0x37d4, MUX_MODE15 | PULL_UP) /* dcan1_rx.off */
dcan2_pins_default: dcan2_pins_default {
DRA7XX_CORE_IOPAD(0x3688, PIN_OUTPUT_PULLUP | MUX_MODE2) /* gpio6_14.dcan2_tx */
DRA7XX_CORE_IOPAD(0x368c, PULL_UP | MUX_MODE2) /* gpio6_15.dcan2_rx */
dcan2_pins_sleep: dcan2_pins_sleep {
DRA7XX_CORE_IOPAD(0x3688, MUX_MODE15 | PULL_UP) /* dcan2_tx.off */
DRA7XX_CORE_IOPAD(0x368c, MUX_MODE15 | PULL_UP) /* dcan2_x.off */
&i2c1 {
pcf_lcd: gpio@20 {
compatible = "nxp,pcf8575";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
interrupt-controller;
#interrupt-cells = <2>;
pcf_gpio_21: gpio@21 {
compatible = "ti,pcf8575", "nxp,pcf8575";
reg = <0x21>;
lines-initial-states = <0x1408>;
gpio-controller;
#gpio-cells = <2>;
tlv320aic3106: tlv320aic3106@19 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x19>;
adc-settle-ms = <40>;
ai3x-micbias-vg = <1>; /* 2.0V */
/* Regulators */
AVDD-supply = <&evm_3v3_sw>;
IOVDD-supply = <&evm_3v3_sw>;
DRVDD-supply = <&evm_3v3_sw>;
DVDD-supply = <&aic_dvdd>;
&i2c5 {
pcf_hdmi: pcf8575@26 {
reg = <0x26>;
gpio-controller;
#gpio-cells = <2>;
* initial state is used here to keep the mdio interface
* selected on RU89 through SEL_VIN4_MUX_S0, VIN2_S1 and
* VIN2_S0 driven high otherwise Ethernet stops working
* VIN6_SEL_S0 is low, thus selecting McASP3 over VIN6
lines-initial-states = <0x0f2b>;
p1 {
/* vin6_sel_s0: high: VIN6, low: audio */
gpio-hog;
gpios = <1 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "vin6_sel_s0";
ov10633@37 {
compatible = "ovti,ov10633";
reg = <0x37>;
clocks = <&clk_ov10633_fixed>;
clock-names = "xvclk";
mux-gpios = <&pcf_hdmi 2 GPIO_ACTIVE_HIGH>, /* VIN2_S0 */
<&pcf_hdmi 6 GPIO_ACTIVE_LOW>; /* VIN2_S2 */
port {
onboardLI: endpoint {
remote-endpoint = <&vin2a>;
hsync-active = <1>;
vsync-active = <1>;
pclk-sample = <0>;
gpio_csi2_adap: tca6416@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
ov490@24 {
compatible = "ovti,ov490";
reg = <0x24>;
mux-gpios = <&gpio_csi2_adap 0 GPIO_ACTIVE_LOW>,
/* CSI2_SEL_I2C_CLK */
<&gpio_csi2_adap 1 GPIO_ACTIVE_HIGH>,
/* CSI2_SEL_REF_CLK */
<&gpio_csi2_adap 3 GPIO_ACTIVE_HIGH>,
/* CSI2_CAM0_RESETn */
<&gpio_csi2_adap 4 GPIO_ACTIVE_LOW>;
/* CSI2_CAM0_PWR_DWN */
port {
csi2_cam0: endpoint@0 {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
&uart1 {
rs485-rts-delay = <0 0>; // RTS signal delay in msec before & after sending
linux,rs485-enabled-at-boot-time;
rs485-rts-active-low;
&uart6 {
&elm {
&gpmc {
* For the existing IOdelay configuration via U-Boot we don't
* support NAND on dra72-evm. Keep it disabled. Enabling it
* requires a different configuration by U-Boot.
ranges = <0 0 0x08000000 0x01000000>; /* minimum GPMC partition = 16MB */
nand@0,0 {
/* To use NAND, DIP switch SW5 must be set like so:
* SW5.1 (NAND_SELn) = ON (LOW)
* SW5.9 (GPMC_WPN) = OFF (HIGH)
compatible = "ti,omap2-nand";
reg = <0 0 4>; /* device IO registers */
interrupt-parent = <&gpmc>;
interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
<1 IRQ_TYPE_NONE>; /* termcount */
rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */
ti,nand-xfer-type = "prefetch-dma";
ti,nand-ecc-opt = "bch8";
ti,elm-id = <&elm>;
nand-bus-width = <16>;
gpmc,device-width = <2>;
gpmc,sync-clk-ps = <0>;
gpmc,cs-on-ns = <0>;
gpmc,cs-rd-off-ns = <80>;
gpmc,cs-wr-off-ns = <80>;
gpmc,adv-on-ns = <0>;
gpmc,adv-rd-off-ns = <60>;
gpmc,adv-wr-off-ns = <60>;
gpmc,we-on-ns = <10>;
gpmc,we-off-ns = <50>;
gpmc,oe-on-ns = <4>;
gpmc,oe-off-ns = <40>;
gpmc,access-ns = <40>;
gpmc,wr-access-ns = <80>;
gpmc,rd-cycle-ns = <80>;
gpmc,wr-cycle-ns = <80>;
gpmc,bus-turnaround-ns = <0>;
gpmc,cycle2cycle-delay-ns = <0>;
gpmc,clk-activation-ns = <0>;
gpmc,wr-data-mux-bus-ns = <0>;
/* MTD partition table */
/* All SPL-* partitions are sized to minimal length
* which can be independently programmable. For
* NAND flash this is equal to size of erase-block */
#size-cells = <1>;
partition@0 {
label = "NAND.SPL";
reg = <0x00000000 0x000020000>;
partition@1 {
label = "NAND.SPL.backup1";
reg = <0x00020000 0x00020000>;
partition@2 {
label = "NAND.SPL.backup2";
reg = <0x00040000 0x00020000>;
partition@3 {
label = "NAND.SPL.backup3";
reg = <0x00060000 0x00020000>;
partition@4 {
label = "NAND.u-boot-spl-os";
reg = <0x00080000 0x00040000>;
partition@5 {
label = "NAND.u-boot";
reg = <0x000c0000 0x00100000>;
partition@6 {
label = "NAND.u-boot-env";
reg = <0x001c0000 0x00020000>;
partition@7 {
label = "NAND.u-boot-env.backup1";
reg = <0x001e0000 0x00020000>;
partition@8 {
label = "NAND.kernel";
reg = <0x00200000 0x00800000>;
partition@9 {
label = "NAND.file-system";
reg = <0x00a00000 0x0f600000>;
&omap_dwc3_1 {
extcon = <&extcon_usb1>;
&omap_dwc3_2 {
extcon = <&extcon_usb2>;
&usb1 {
dr_mode = "otg";
&usb2 {
dr_mode = "peripheral";
&mmc1 {
pinctrl-names = "default";
vmmc-supply = <&evm_3v3_sd>;
bus-width = <4>;
* SDCD signal is not being used here - using the fact that GPIO mode
* is a viable alternative
cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
max-frequency = <192000000>;
&mmc2 {
status = "okay";
bus-width = <8>;
ti,non-removable;
max-frequency = <96000000>;
no-1-8-v;
/delete-property/ mmc-hs200-1_8v;
&mac {
status = "okay";
&dcan1 {
pinctrl-names = "default", "sleep", "active";
pinctrl-0 = <&dcan1_pins_sleep>;
pinctrl-1 = <&dcan1_pins_sleep>;
pinctrl-2 = <&dcan1_pins_default>;
&dcan2 {
pinctrl-0 = <&dcan2_pins_sleep>;
pinctrl-1 = <&dcan2_pins_sleep>;
pinctrl-2 = <&dcan2_pins_default>;
&qspi {
status = "okay";
spi-max-frequency = <15000000>;
m25p80@0 {
compatible = "s25fl256s1";
reg = <0>;
spi-tx-bus-width = <1>;
spi-rx-bus-width = <4>;
#size-cells = <1>;
/* MTD partition table.
* The ROM checks the first four physical blocks
* for a valid file to boot and the flash here is
* 64KiB block size.
partition@0 {
label = "QSPI.SPL";
reg = <0x00000000 0x000010000>;
partition@1 {
label = "QSPI.SPL.backup1";
reg = <0x00010000 0x00010000>;
partition@2 {
label = "QSPI.SPL.backup2";
reg = <0x00020000 0x00010000>;
partition@3 {
label = "QSPI.SPL.backup3";
reg = <0x00030000 0x00010000>;
partition@4 {
label = "QSPI.u-boot";
reg = <0x00040000 0x00100000>;
partition@5 {
label = "QSPI.u-boot-spl-os";
reg = <0x00140000 0x00080000>;
partition@6 {
label = "QSPI.u-boot-env";
reg = <0x001c0000 0x00010000>;
partition@7 {
label = "QSPI.u-boot-env.backup1";
reg = <0x001d0000 0x0010000>;
partition@8 {
label = "QSPI.kernel";
reg = <0x001e0000 0x0800000>;
partition@9 {
label = "QSPI.file-system";
reg = <0x009e0000 0x01620000>;
&gpu {
&dss {
&bb2d {
&hdmi {
port {
hdmi_out: endpoint {
remote-endpoint = <&tpd12s015_in>;
&vip1 {
&vin2a {
endpoint@0 {
slave-mode;
remote-endpoint = <&onboardLI>;
&cal {
&csi2_0 {
csi2_phy0: endpoint@0 {
slave-mode;
remote-endpoint = <&csi2_cam0>;
&atl {
assigned-clocks = <&abe_dpll_sys_clk_mux>,
<&atl_gfclk_mux>,
<&dpll_abe_ck>,
<&dpll_abe_m2x2_ck>,
<&atl_clkin2_ck>;
assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>;
assigned-clock-rates = <0>, <0>, <180633600>, <361267200>, <5644800>;
atl2 {
bws = <DRA7_ATL_WS_MCASP2_FSX>;
aws = <DRA7_ATL_WS_MCASP3_FSX>;
&mcasp3 {
assigned-clocks = <&mcasp3_ahclkx_mux>;
assigned-clock-parents = <&atl_clkin2_ck>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializer */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 2 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
&pcie1_rc {
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.40-rt29-gd5443cbd3b (bridge@PC932) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #24 SMP PREEMPT RT T8
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI DRA718 EVM
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x0000000094000000
[ 0.000000] OMAP4: Map 0x000000009fd00000 to fe600000 for dram barrier
[ 0.000000] DRA722 ES2.1
[ 0.000000] percpu: Embedded 15 pages/cpu @d3ad7000 s31968 r8192 d21280 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 125860
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/nfs nfsroot=10.3.33.185:/home/bridge/SDK-Bridge/ti-processor-sdk-linux-rt-f
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 306544K/507904K available (8192K kernel code, 356K rwdata, 2468K rodata, 2048K init, 347K bss, 21136K reserved, 180224K )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xdf800000 - 0xff800000 ( 512 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1059360 ( 357 kB)
[ 0.000000] .bss : 0xc105b000 - 0xc10b1d84 ( 348 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000011] Switching to timer-based delay loop, resolution 162ns
[ 0.000350] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000353] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000868] Console: colour dummy device 80x30
[ 0.000987] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000989] This ensures that you still see kernel messages. Please
[ 0.000991] update your kernel commandline.
[ 0.001003] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.001010] pid_max: default: 32768 minimum: 301
[ 0.001129] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001136] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001752] CPU: Testing write buffer coherency: ok
[ 0.001995] /cpus/cpu@0 missing clock-frequency property
[ 0.002026] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039878] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079870] Hierarchical SRCU implementation.
[ 0.140336] EFI services will not be available.
[ 0.159998] smp: Bringing up secondary CPUs ...
[ 0.160008] smp: Brought up 1 node, 1 CPU
[ 0.160018] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.160025] CPU: All CPU(s) started in HYP mode.
[ 0.160032] CPU: Virtualization extensions available.
[ 0.160582] devtmpfs: initialized
[ 0.195622] random: get_random_u32 called from bucket_table_alloc+0x14c/0x288 with crng_init=0
[ 0.200203] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.200447] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.200468] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.204350] pinctrl core: initialized pinctrl subsystem
[ 0.205197] DMI not present or invalid.
[ 0.205650] NET: Registered protocol family 16
[ 0.208138] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.209039] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.251691] omap_hwmod: kbd: no dt node
[ 0.251702] ------------[ cut here ]------------
[ 0.251727] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2494 _init.constprop.21+0x1e4/0x4a8
[ 0.251735] omap_hwmod: kbd: doesn't have mpu register target base
[ 0.251742] Modules linked in:
[ 0.251759] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.40-rt29-gd5443cbd3b #24
[ 0.251762] Hardware name: Generic DRA72X (Flattened Device Tree)
[ 0.251764] Backtrace:
[ 0.251779] [<c020b2c0>] (dump_backtrace) from [<c020b5a4>] (show_stack+0x18/0x1c)
[ 0.251785] r7:00000009 r6:60000013 r5:00000000 r4:c105763c
[ 0.251794] [<c020b58c>] (show_stack) from [<c090e3bc>] (dump_stack+0x90/0xa4)
[ 0.251804] [<c090e32c>] (dump_stack) from [<c022a86c>] (__warn+0xec/0x104)
[ 0.251809] r7:00000009 r6:c0b95c18 r5:00000000 r4:d3469e20
[ 0.251818] [<c022a780>] (__warn) from [<c022a8c4>] (warn_slowpath_fmt+0x40/0x48)
[ 0.251823] r9:000000ce r8:c0e49824 r7:00000000 r6:c10133b4 r5:00000000 r4:c0b95f24
[ 0.251833] [<c022a888>] (warn_slowpath_fmt) from [<c0e0bde4>] (_init.constprop.21+0x1e4/0x4a8)
[ 0.251836] r3:c0bfc2bc r2:c0b95f24
[ 0.251838] r4:c1013370
[ 0.251848] [<c0e0bc00>] (_init.constprop.21) from [<c0e0c5dc>] (__omap_hwmod_setup_all+0x48/0x108)
[ 0.251853] r10:c105b000 r9:000000ce r8:c0e49824 r7:c105b000 r6:c0e0c594 r5:c100b648
[ 0.251855] r4:c1013370
[ 0.251863] [<c0e0c594>] (__omap_hwmod_setup_all) from [<c02017bc>] (do_one_initcall+0x4c/0x170)
[ 0.251866] r5:00000000 r4:ffffe000
[ 0.251873] [<c0201770>] (do_one_initcall) from [<c0e00fd4>] (kernel_init_freeable+0x228/0x2c4)
[ 0.251877] r8:c0e49824 r7:c105b000 r6:00000003 r5:c0e5744c r4:c0c67298
[ 0.251885] [<c0e00dac>] (kernel_init_freeable) from [<c0921708>] (kernel_init+0x10/0x110)
[ 0.251890] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c09216f8
[ 0.251892] r4:00000000
[ 0.251900] [<c09216f8>] (kernel_init) from [<c0207a40>] (ret_from_fork+0x14/0x34)
[ 0.251903] r5:c09216f8 r4:00000000
[ 0.251906] ---[ end trace 0000000000000001 ]---
[ 0.419523] OMAP GPIO hardware version 0.1
[ 0.452321] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.452334] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.452805] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.452817] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.454149] OMAP DMA hardware revision 0.0
[ 0.504293] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.506831] edma 43300000.edma: memcpy is disabled
[ 0.512824] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.513938] evm_5v0: supplied by evm_12v0
[ 0.514430] evm_3v6: supplied by evm_5v0
[ 0.514909] vsys_3v3: supplied by evm_12v0
[ 0.515385] evm_3v3: supplied by vsys_3v3
[ 0.515861] aic_dvdd: supplied by evm_3v3
[ 0.517719] vddshv8: invalid voltage constraints
[ 0.517734] gpio-regulator gpio-regulator-TPS74801: Failed to register regulator: -22
[ 0.517828] gpio-regulator: probe of gpio-regulator-TPS74801 failed with error -22
[ 0.521352] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.521858] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.522451] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.523036] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.523609] iommu: Adding device 58820000.ipu to group 1
[ 0.523798] iommu: Adding device 55020000.ipu to group 2
[ 0.524140] iommu: Adding device 40800000.dsp to group 0
[ 0.526163] media: Linux media interface: v0.10
[ 0.526212] Linux video capture interface: v2.00
[ 0.526328] pps_core: LinuxPPS API ver. 1 registered
[ 0.526336] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.526364] PTP clock support registered
[ 0.526400] EDAC MC: Ver: 3.0.0
[ 0.530794] dmi: Firmware registration failed.
[ 0.531378] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.531680] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.532230] Advanced Linux Sound Architecture Driver Initialized.
[ 0.540844] clocksource: Switched to clocksource arch_sys_counter
[ 0.554140] NET: Registered protocol family 2
[ 0.554998] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.555050] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[ 0.555187] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.555287] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.555320] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.555571] NET: Registered protocol family 1
[ 0.576113] RPC: Registered named UNIX socket transport module.
[ 0.576125] RPC: Registered udp transport module.
[ 0.576135] RPC: Registered tcp transport module.
[ 0.576144] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.577496] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.577712] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.579544] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.587657] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.598555] NFS: Registering the id_resolver key type
[ 0.598589] Key type id_resolver registered
[ 0.598599] Key type id_legacy registered
[ 0.598674] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.601238] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.601252] io scheduler noop registered
[ 0.601263] io scheduler deadline registered
[ 0.601420] io scheduler cfq registered (default)
[ 0.601432] io scheduler mq-deadline registered
[ 0.601441] io scheduler kyber registered
[ 0.607545] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.607805] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.607896] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 0.607908] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.701084] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.705699] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
[ 0.707436] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 44, base_baud = 3000000) is a 8250
[ 1.803200] console [ttyS2] enabled
[ 1.808460] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 45, base_baud = 3000000) is a 8250
[ 1.819825] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 1.844320] brd: module loaded
[ 1.858871] loop: module loaded
[ 1.867394] m25p80 spi0.0: found n25q256a, expected s25fl256s1
[ 1.873768] m25p80 spi0.0: n25q256a (32768 Kbytes)
[ 1.878667] 10 ofpart partitions found on MTD device spi0.0
[ 1.884266] Creating 10 MTD partitions on "spi0.0":
[ 1.889170] 0x000000000000-0x000000010000 : "QSPI.SPL"
[ 1.895542] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
[ 1.902527] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
[ 1.909530] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
[ 1.916508] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 1.923081] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 1.930226] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 1.937122] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 1.944727] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 1.951348] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 1.959316] libphy: Fixed MDIO Bus: probed
[ 2.020901] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.028601] libphy: 48485000.mdio: probed
[ 2.045035] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver TI DP83822 10/100 Mbps PHY
[ 2.055464] cpsw 48484000.ethernet: Detected MACID = 00:a0:de:ad:be:ef
[ 2.062029] cpsw 48484000.ethernet: GMAC port 0
[ 2.066666] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.073053] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.078315] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 2.085351] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.094315] net eth0: rpmsg goose driver init: 0
[ 2.099039] net eth0: ocmc rxbuf: pa x40300000 va e0900000 size 0xe000
[ 2.106523] omap4-keypad 4ae1c00000000400.keypad: no base address specified
[ 2.113555] omap4-keypad: probe of 4ae1c00000000400.keypad failed with error -22
[ 2.121334] i2c /dev entries driver
[ 2.126001] IR NEC protocol handler initialized
[ 2.130554] IR RC5(x/sz) protocol handler initialized
[ 2.135642] IR RC6 protocol handler initialized
[ 2.140193] IR JVC protocol handler initialized
[ 2.144746] IR Sony protocol handler initialized
[ 2.149385] IR SANYO protocol handler initialized
[ 2.154128] IR Sharp protocol handler initialized
[ 2.158854] IR MCE Keyboard/mouse protocol handler initialized
[ 2.164714] IR XMP protocol handler initialized
[ 2.183456] NET: Registered protocol family 10
[ 2.199480] Segment Routing with IPv6
[ 2.203270] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.210033] NET: Registered protocol family 17
[ 2.214989] Key type dns_resolver registered
[ 2.219432] omap_voltage_late_init: Voltage driver support not added
[ 2.225817] Power Management for TI OMAP4+ devices.
[ 2.231105] Registering SWP/SWPB emulation handler
[ 2.278548] dmm 4e000000.dmm: workaround for errata i878 in use
[ 2.287411] dmm 4e000000.dmm: initialized all PAT entries
[ 2.296209] hctosys: unable to open rtc device (rtc0)
[ 2.313024] net eth0: initializing cpsw version 1.15 (0)
[ 2.423868] TI DP83822 10/100 Mbps PHY 48485000.mdio:00: attached PHY driver [TI DP83822 10/100 Mbps PHY] (mii_bus:phy_addr=48485000.mdio:00)
[ 2.440124] cpts ptp bc clkid 0
[ 2.448729] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.486440] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Half - flow control off
[ 4.490897] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4.520902] IP-Config: Complete:
[ 4.524153] device=eth0, hwaddr=00:a0:de:ad:be:ef, ipaddr=10.3.33.186, mask=255.255.248.0, gw=255.255.255.255
[ 4.534572] host=10.3.33.186, domain=, nis-domain=(none)
[ 4.540365] bootserver=10.3.33.185, rootserver=10.3.33.185, rootpath=
[ 4.548736] aic_dvdd: disabling
[ 4.551901] vmmcwl_fixed: disabling
[ 4.555417] pbias_mmc_omap5: disabling
[ 4.559200] ALSA device list:
[ 4.562182] No soundcards found.
[ 4.584994] VFS: Mounted root (nfs filesystem) on device 0:14.
[ 4.592037] devtmpfs: mounted
[ 4.598246] Freeing unused kernel memory: 2048K
[ 5.038515] systemd[1]: System time before build time, advancing clock.
[ 5.107405] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRY)
[ 5.129127] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.04!
[ 5.162395] systemd[1]: Set hostname to <am57xx-evm>.
[ 6.159407] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.166856] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.201109] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.208242] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 6.252299] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.259639] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 6.305863] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 6.347681] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.383803] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 6.427643] systemd[1]: Mounting Kernel Debug File System...
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
Starting Create list of required st��…ce nodes for the current kernel...
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Listening on Network Service Netlink Socket.
Starting Load Kernel Modules...
[ 6.783633] cmemk: loading out-of-tree module taints kernel.
Starting Journal Service...
[ 6.794037] CMEMK module: reference Linux version 4.14.40
[ 6.803683] cmemk initialized
[ OK ] Created slice User and Session Slice.
[ 6.845646] cryptodev: driver 1.9 loaded.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ 6.913709] usbcore: registered new interface driver usbfs
[ 6.920666] usbcore: registered new interface driver hub
[ 6.927656] usbcore: registered new device driver usb
[ OK ] Listening on udev Kernel Socket.
[ 6.946851] usbcore: registered new interface driver usbserial
[ OK ] Reached target Slices.
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice system-getty.slice.
Starting Remount Root and Kernel File Systems...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
Starting udev Coldplug all Devices...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 7.965240] systemd-journald[89]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started Flush Journal to Persistent Storage.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ 10.706778] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 10.763794] remoteproc remoteproc0: 58820000.ipu is available
[ 10.807995] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 10.819869] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 10.822408] remoteproc remoteproc1: 55020000.ipu is available
[ 10.835021] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 10.837588] remoteproc remoteproc2: 40800000.dsp is available
[ 11.104254] remoteproc remoteproc0: powering up 58820000.ipu
[ 11.153291] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 11.258063] remoteproc remoteproc0: request_firmware failed: -2
[ OK ] Found device /dev/ttyS2.
[ 12.737658] CAN device driver interface
[ 12.840365] remoteproc remoteproc2: powering up 40800000.dsp
[ 12.854092] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 2214116
[ 12.885148] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 12.892394] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 12.899552] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 13.015372] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 13.067672] remoteproc remoteproc2: registered virtio0 (type 7)
[ OK ] Started udev Coldplug all Devices.
[ 13.105776] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 13.264931] c_can_platform 48480000.can: c_can_platform device registered (regs=fa480000, irq=83)
[ 13.319954] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 13.342722] omap-des 480a5000.des: will run requests pump with realtime priority
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Starting Network Service...
[ OK ] Listening on RPCbind Server Activation Socket.
[ 13.687172] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ OK ] Started Daily rotation of log files.
[ 13.732691] vpe 489d0000.vpe: Device registered as /dev/video0
[ OK ] Reached target Timers.
[ 13.864703] remoteproc remoteproc1: powering up 55020000.ipu
[ 13.880674] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743076
[ 13.925027] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 14.651975] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 14.669783] remoteproc remoteproc1: registered virtio1 (type 7)
[ 14.669789] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 14.698343] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 14.700115] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[ 14.751573] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 14.834208] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 14.993884] omap_gpio 48057000.gpio: Could not set line 30 debounce to 20000 microseconds (-22)
[ 15.043164] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 15.056001] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 15.139033] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 15.152377] omap-aes 4b700000.aes: will run requests pump with realtime priority
Starting Login Service...
[ OK ] Started Kernel Logging Service.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target Containers.
Starting Print notice about GPLv3 packages...
[ OK ] Started System Logging Service.
Starting uim-sysfs.service...
Starting RPC Bind Service...
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
Starting TI MultiCore Tools Daemon...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started RPC Bind Service.
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[ OK ] Started Network Service.
[ 24.108014] dwc3 488d0000.usb: failed to initialize core
[ 24.174374] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
[ 24.224297] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4
[ 24.229810] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
[ 24.293991] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9
[ 24.368235] dwc3 488d0000.usb: failed to initialize core
[ OK ] Started uim-sysfs.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
binutils-dev
binutils
bison-dev
bison
cifs-utils
cpio
cpp-symlinks
cpp
dosfstools
elfutils-dev
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gettext
gstreamer1.0-libav
gzip
hidapi
libasm1
libcairo-perf-utils
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm4
libgettextlib
libgettextsrc
libgmp10
libidn11
libmavconn
libmpc3
libmpfr4
libreadline-dev
libreadline7
libunistring2
m4-dev
m4
make
mavlink
mavros-extras
mavros-msgs
mavros
nettle
parted
python3-pycairo
socketcan-interface
swig-dev
swig
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started Login Service.
Starting rc.pvr.service...
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Wait for Network to be Configured...
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Permit User Sessions...
Starting Network Name Resolution...
Starting Simple Network Management Protocol (SNMP) Daemon....
[ OK ] Started Redis In-Memory Data Store.
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started rc.pvr.service.
[ OK ] Started Wait for Network to be Configured.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
Starting weston.service...
[ OK ] Started Network Name Resolution.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target Network is Online.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ OK ] Started weston.service.
Starting telnetd.service...
Starting tiipclad-daemon.service...
[ OK ] Started telnetd.service.
[ 34.146829] NET: Registered protocol family 15
[ OK ] Started tiipclad-daemon.service.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ 34.531807] Initializing XFRM netlink socket
[ OK ] Started rng-tools.service.
Starting LSB: Redis, a key-value store...
[ OK ] Started LSB: Redis, a key-value store.
Starting gdbserverproxy.service...
[ OK ] Started gdbserverproxy.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am57xx-evm ttyS2
Arago 2018.04 am57xx-evm ttyS2
am57xx-evm login: root
root@am57xx-evm:~#
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_BLK_DEV_INITRD=y CONFIG_PERF_EVENTS=y CONFIG_PARTITION_ADVANCED=y CONFIG_CMDLINE_PARTITION=y # CONFIG_ARCH_MULTI_V5 is not set # CONFIG_ARCH_MULTI_V4 is not set CONFIG_MACH_ARTPEC6=y CONFIG_MACH_ARMADA_370=y CONFIG_MACH_ARMADA_375=y CONFIG_MACH_ARMADA_38X=y CONFIG_MACH_ARMADA_39X=y CONFIG_MACH_ARMADA_XP=y CONFIG_MACH_DOVE=y CONFIG_SOC_SAMA5D2=y CONFIG_SOC_SAMA5D3=y CONFIG_SOC_SAMA5D4=y CONFIG_ARCH_BCM2835=y CONFIG_ARCH_BCM_63XX=y CONFIG_MACH_BERLIN_BG2=y CONFIG_MACH_BERLIN_BG2CD=y CONFIG_MACH_BERLIN_BG2Q=y CONFIG_SOC_IMX50=y CONFIG_SOC_IMX51=y CONFIG_SOC_IMX53=y CONFIG_SOC_IMX6Q=y CONFIG_SOC_IMX6SL=y CONFIG_SOC_IMX6SX=y CONFIG_SOC_IMX6UL=y CONFIG_SOC_IMX7D=y CONFIG_SOC_VF610=y CONFIG_SOC_LS1021A=y CONFIG_MACH_SPEAR1310=y CONFIG_MACH_SPEAR1340=y CONFIG_EXYNOS5420_MCPM=y CONFIG_ARCH_R8A7743=y CONFIG_ARCH_R8A7745=y CONFIG_ARCH_R8A7792=y CONFIG_MACH_HREFV60=y CONFIG_MACH_SNOWBALL=y CONFIG_TRUSTED_FOUNDATIONS=y CONFIG_PCI_HOST_GENERIC=y CONFIG_PCI_KEYSTONE=y CONFIG_PCI_MSI=y CONFIG_PCI_MVEBU=y CONFIG_PCI_TEGRA=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PCIE_RCAR=y CONFIG_PCIEPORTBUS=y CONFIG_HIGHPTE=y CONFIG_CMA=y CONFIG_EFI=y CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y CONFIG_ARM_IMX6Q_CPUFREQ=y CONFIG_ARM_ZYNQ_CPUIDLE=y CONFIG_ARM_EXYNOS_CPUIDLE=y CONFIG_PACKET=y CONFIG_UNIX=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y CONFIG_IPV6_ROUTER_PREF=y CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_ESP=m CONFIG_IPV6_MIP6=m CONFIG_IPV6_MULTIPLE_TABLES=y CONFIG_NET_DSA=m CONFIG_NET_SWITCHDEV=y CONFIG_CAN_RAW=y CONFIG_CAN_BCM=y CONFIG_CAN_DEV=y CONFIG_CAN_AT91=m CONFIG_CAN_RCAR=m CONFIG_CAN_XILINXCAN=y CONFIG_CAN_MCP251X=y CONFIG_B53_SPI_DRIVER=m CONFIG_B53_MDIO_DRIVER=m CONFIG_B53_MMAP_DRIVER=m CONFIG_B53_SRAB_DRIVER=m CONFIG_CAN_SUN4I=y CONFIG_BT=m CONFIG_BT_MRVL=m CONFIG_BT_MRVL_SDIO=m CONFIG_CFG80211=m CONFIG_MAC80211=m CONFIG_RFKILL=y CONFIG_RFKILL_INPUT=y CONFIG_RFKILL_GPIO=y CONFIG_DMA_CMA=y CONFIG_OMAP_OCP2SCP=y CONFIG_SIMPLE_PM_BUS=y CONFIG_SUNXI_RSB=y CONFIG_MTD=y CONFIG_MTD_BLOCK=y CONFIG_MTD_M25P80=y CONFIG_MTD_NAND=y CONFIG_MTD_NAND_DENALI_DT=y CONFIG_MTD_NAND_ATMEL=y CONFIG_MTD_NAND_BRCMNAND=y CONFIG_MTD_NAND_VF610_NFC=y CONFIG_MTD_NAND_DAVINCI=y CONFIG_MTD_SPI_NOR=y CONFIG_SPI_FSL_QUADSPI=m CONFIG_MTD_UBI=y CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_SIZE=65536 CONFIG_VIRTIO_BLK=y CONFIG_AD525X_DPOT=y CONFIG_AD525X_DPOT_I2C=y CONFIG_ATMEL_TCLIB=y CONFIG_ICS932S401=y CONFIG_ATMEL_SSC=m CONFIG_QCOM_COINCELL=m CONFIG_APDS9802ALS=y CONFIG_ISL29003=y CONFIG_EEPROM_AT24=y CONFIG_BLK_DEV_SD=y CONFIG_BLK_DEV_SR=y CONFIG_SCSI_MULTI_LUN=y CONFIG_AHCI_BRCM=y CONFIG_AHCI_DM816=y CONFIG_AHCI_ST=y CONFIG_AHCI_IMX=y CONFIG_AHCI_SUNXI=y CONFIG_AHCI_TEGRA=y CONFIG_SATA_HIGHBANK=y CONFIG_SATA_MV=y CONFIG_SATA_RCAR=y CONFIG_NETDEVICES=y CONFIG_VIRTIO_NET=y CONFIG_HIX5HD2_GMAC=y CONFIG_SUN4I_EMAC=y CONFIG_MACB=y CONFIG_BGMAC_BCMA=y CONFIG_NET_CALXEDA_XGMAC=y CONFIG_GIANFAR=y CONFIG_MV643XX_ETH=y CONFIG_MVNETA=y CONFIG_PXA168_ETH=m CONFIG_KS8851=y CONFIG_R8169=y CONFIG_SH_ETH=y CONFIG_SMSC911X=y CONFIG_STMMAC_ETH=y CONFIG_STMMAC_PLATFORM=y CONFIG_DWMAC_DWC_QOS_ETH=y CONFIG_XILINX_EMACLITE=y CONFIG_AT803X_PHY=y CONFIG_SMSC_PHY=y CONFIG_REALTEK_PHY=y CONFIG_FIXED_PHY=y CONFIG_ROCKCHIP_PHY=y CONFIG_USB_SUPPORT=y CONFIG_USB=m CONFIG_USB_PEGASUS=y CONFIG_USB_RTL8152=m CONFIG_USB_NET_SMSC75XX=y CONFIG_BRCMFMAC=m CONFIG_RT2X00=m CONFIG_RT2800USB=m CONFIG_MWIFIEX=m CONFIG_MWIFIEX_SDIO=m CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y CONFIG_KEYBOARD_QT1070=m CONFIG_KEYBOARD_GPIO=y CONFIG_KEYBOARD_TEGRA=y CONFIG_KEYBOARD_SPEAR=y CONFIG_KEYBOARD_ST_KEYSCAN=y CONFIG_KEYBOARD_CROS_EC=m CONFIG_KEYBOARD_SAMSUNG=m CONFIG_KEYBOARD_OMAP4=y CONFIG_MOUSE_PS2_ELANTECH=y CONFIG_MOUSE_CYAPA=m CONFIG_MOUSE_ELAN_I2C=y CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_ATMEL_MXT=m CONFIG_TOUCHSCREEN_MMS114=m CONFIG_TOUCHSCREEN_ST1232=m CONFIG_TOUCHSCREEN_STMPE=y CONFIG_TOUCHSCREEN_SUN4I=y CONFIG_TOUCHSCREEN_WM97XX=m CONFIG_INPUT_MISC=y CONFIG_INPUT_MAX77693_HAPTIC=m CONFIG_INPUT_MAX8997_HAPTIC=m CONFIG_INPUT_AXP20X_PEK=m CONFIG_INPUT_ADXL34X=m CONFIG_SERIO_AMBAKMI=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_MT6577=y CONFIG_SERIAL_8250_UNIPHIER=y CONFIG_SERIAL_AMBA_PL011_CONSOLE=y CONFIG_SERIAL_ATMEL=y CONFIG_SERIAL_ATMEL_CONSOLE=y CONFIG_SERIAL_ATMEL_TTYAT=y CONFIG_SERIAL_BCM63XX=y CONFIG_SERIAL_BCM63XX_CONSOLE=y CONFIG_SERIAL_MESON=y CONFIG_SERIAL_MESON_CONSOLE=y CONFIG_SERIAL_SAMSUNG=y CONFIG_SERIAL_SAMSUNG_CONSOLE=y CONFIG_SERIAL_SIRFSOC=y CONFIG_SERIAL_SIRFSOC_CONSOLE=y CONFIG_SERIAL_TEGRA=y CONFIG_SERIAL_IMX=y CONFIG_SERIAL_IMX_CONSOLE=y CONFIG_SERIAL_SH_SCI=y CONFIG_SERIAL_SH_SCI_NR_UARTS=20 CONFIG_SERIAL_SH_SCI_CONSOLE=y CONFIG_SERIAL_SH_SCI_DMA=y CONFIG_SERIAL_MSM=y CONFIG_SERIAL_MSM_CONSOLE=y CONFIG_SERIAL_VT8500=y CONFIG_SERIAL_VT8500_CONSOLE=y CONFIG_SERIAL_OF_PLATFORM=y CONFIG_SERIAL_OMAP_CONSOLE=y CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y CONFIG_SERIAL_FSL_LPUART_CONSOLE=y CONFIG_SERIAL_CONEXANT_DIGICOLOR_CONSOLE=y CONFIG_SERIAL_ST_ASC_CONSOLE=y CONFIG_HVC_DRIVER=y CONFIG_VIRTIO_CONSOLE=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_DAVINCI=y CONFIG_I2C_ARB_GPIO_CHALLENGE=m CONFIG_I2C_MUX_PCA954x=y CONFIG_I2C_MUX_PINCTRL=y CONFIG_I2C_DEMUX_PINCTRL=y CONFIG_I2C_AT91=m CONFIG_I2C_BCM2835=y CONFIG_I2C_CADENCE=y CONFIG_I2C_DIGICOLOR=m CONFIG_I2C_EMEV2=m CONFIG_I2C_EXYNOS5=y CONFIG_I2C_IMX=m CONFIG_I2C_MV64XXX=y CONFIG_I2C_RIIC=y CONFIG_I2C_S3C2410=y CONFIG_I2C_SH_MOBILE=y CONFIG_I2C_SIRF=y CONFIG_I2C_ST=y CONFIG_I2C_SUN6I_P2WI=y CONFIG_I2C_TEGRA=y CONFIG_I2C_UNIPHIER=y CONFIG_I2C_UNIPHIER_F=y CONFIG_I2C_RCAR=y CONFIG_I2C_CROS_EC_TUNNEL=m CONFIG_I2C_SLAVE_EEPROM=y CONFIG_SPI=y CONFIG_SPI_ATMEL=m CONFIG_SPI_BCM2835=y CONFIG_SPI_BCM2835AUX=y CONFIG_SPI_DAVINCI=y CONFIG_SPI_GPIO=m CONFIG_SPI_FSL_DSPI=m CONFIG_SPI_OMAP24XX=y CONFIG_SPI_ORION=y CONFIG_SPI_PL022=y CONFIG_SPI_RSPI=y CONFIG_SPI_S3C64XX=m CONFIG_SPI_SH_MSIOF=m CONFIG_SPI_SH_HSPI=y CONFIG_SPI_SIRF=y CONFIG_SPI_SUN4I=y CONFIG_SPI_SUN6I=y CONFIG_SPI_TEGRA114=y CONFIG_SPI_TEGRA20_SFLASH=y CONFIG_SPI_TEGRA20_SLINK=y CONFIG_SPMI=y CONFIG_PINCTRL_AS3722=y CONFIG_PINCTRL_PALMAS=y CONFIG_PINCTRL_BCM2835=y CONFIG_PINCTRL_APQ8064=y CONFIG_PINCTRL_APQ8084=y CONFIG_PINCTRL_IPQ8064=y CONFIG_PINCTRL_MSM8660=y CONFIG_PINCTRL_MSM8960=y CONFIG_PINCTRL_MSM8X74=y CONFIG_PINCTRL_MSM8916=y CONFIG_PINCTRL_QCOM_SPMI_PMIC=y CONFIG_PINCTRL_QCOM_SSBI_PMIC=y CONFIG_GPIO_DAVINCI=y CONFIG_GPIO_RCAR=y CONFIG_GPIO_ZYNQ=y CONFIG_GPIO_PCA953X_IRQ=y CONFIG_GPIO_TWL4030=y CONFIG_GPIO_PALMAS=y CONFIG_GPIO_SYSCON=y CONFIG_GPIO_TPS65910=y CONFIG_BATTERY_ACT8945A=y CONFIG_BATTERY_SBS=y CONFIG_BATTERY_MAX17040=m CONFIG_BATTERY_MAX17042=m CONFIG_CHARGER_MAX14577=m CONFIG_CHARGER_MAX77693=m CONFIG_CHARGER_MAX8997=m CONFIG_CHARGER_MAX8998=m CONFIG_CHARGER_TPS65090=y CONFIG_AXP20X_POWER=m CONFIG_POWER_RESET_AS3722=y CONFIG_POWER_RESET_GPIO=y CONFIG_POWER_RESET_GPIO_RESTART=y CONFIG_POWER_RESET_KEYSTONE=y CONFIG_POWER_RESET_RMOBILE=y CONFIG_POWER_RESET_ST=y CONFIG_POWER_AVS=y CONFIG_ROCKCHIP_IODOMAIN=y CONFIG_SENSORS_IIO_HWMON=y CONFIG_SENSORS_LM90=y CONFIG_SENSORS_LM95245=y CONFIG_SENSORS_NTC_THERMISTOR=m CONFIG_SENSORS_PWM_FAN=n CONFIG_SENSORS_INA2XX=m CONFIG_BRCMSTB_THERMAL=m CONFIG_ROCKCHIP_THERMAL=y CONFIG_RCAR_THERMAL=y CONFIG_ARMADA_THERMAL=y CONFIG_DAVINCI_WATCHDOG=m CONFIG_EXYNOS_THERMAL=m CONFIG_ST_THERMAL_MEMMAP=y CONFIG_DA9063_WATCHDOG=m CONFIG_ARM_SP805_WATCHDOG=y CONFIG_AT91SAM9X_WATCHDOG=y CONFIG_SAMA5D4_WATCHDOG=y CONFIG_ORION_WATCHDOG=y CONFIG_ST_LPC_WATCHDOG=y CONFIG_SUNXI_WATCHDOG=y CONFIG_IMX2_WDT=y CONFIG_TEGRA_WATCHDOG=m CONFIG_MESON_WATCHDOG=y CONFIG_DIGICOLOR_WATCHDOG=y CONFIG_BCM2835_WDT=y CONFIG_BCM47XX_WDT=y CONFIG_BCM_KONA_WDT=y CONFIG_MFD_ACT8945A=y CONFIG_MFD_AC100=y CONFIG_MFD_AXP20X_RSB=y CONFIG_MFD_QCOM_RPM=y CONFIG_MFD_SPMI_PMIC=y CONFIG_REGULATOR_ACT8945A=y CONFIG_REGULATOR_AB8500=y CONFIG_POWER_RESET_SYSCON=y CONFIG_REGULATOR_MAX8997=m CONFIG_REGULATOR_MAX8998=m CONFIG_REGULATOR_QCOM_RPM=y CONFIG_REGULATOR_QCOM_SMD_RPM=y CONFIG_REGULATOR_WM8994=m CONFIG_USB_GSPCA=y CONFIG_SOC_CAMERA=m CONFIG_SOC_CAMERA_PLATFORM=m CONFIG_VIDEO_RCAR_VIN=m CONFIG_VIDEO_ATMEL_ISI=m CONFIG_VIDEO_SAMSUNG_EXYNOS4_IS=m CONFIG_VIDEO_S5P_FIMC=m CONFIG_VIDEO_S5P_MIPI_CSIS=m CONFIG_VIDEO_EXYNOS_FIMC_LITE=m CONFIG_VIDEO_EXYNOS4_FIMC_IS=m CONFIG_VIDEO_SAMSUNG_S5P_JPEG=m CONFIG_VIDEO_SAMSUNG_S5P_MFC=m CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC=m CONFIG_VIDEO_STI_BDISP=m CONFIG_VIDEO_STI_HVA=m CONFIG_VIDEO_STI_DELTA=m CONFIG_VIDEO_RENESAS_JPU=m CONFIG_VIDEO_RENESAS_VSP1=m CONFIG_V4L_TEST_DRIVERS=y CONFIG_VIDEO_ADV7180=m CONFIG_VIDEO_ML86V7667=m CONFIG_DRM_I2C_ADV7511_AUDIO=y # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set CONFIG_DRM_DUMB_VGA_DAC=m CONFIG_DRM_EXYNOS_FIMD=y CONFIG_DRM_EXYNOS_MIXER=y CONFIG_DRM_EXYNOS_DPI=y CONFIG_DRM_EXYNOS_DSI=y CONFIG_DRM_EXYNOS_HDMI=y CONFIG_DRM_ROCKCHIP=m CONFIG_ROCKCHIP_ANALOGIX_DP=y CONFIG_ROCKCHIP_DW_HDMI=y CONFIG_ROCKCHIP_DW_MIPI_DSI=y CONFIG_ROCKCHIP_INNO_HDMI=y CONFIG_DRM_ATMEL_HLCDC=m CONFIG_DRM_RCAR_DU=m CONFIG_DRM_RCAR_LVDS=y CONFIG_DRM_SUN4I=m CONFIG_DRM_TEGRA=y CONFIG_DRM_PANEL_SAMSUNG_LD9040=m CONFIG_DRM_VC4=y CONFIG_FB_ARMCLCD=y CONFIG_FB_EFI=y CONFIG_FB_WM8505=y CONFIG_FB_SH_MOBILE_LCDC=y CONFIG_FB_SIMPLE=y CONFIG_FB_SH_MOBILE_MERAM=y CONFIG_BACKLIGHT_LCD_SUPPORT=y CONFIG_BACKLIGHT_CLASS_DEVICE=y CONFIG_LCD_PLATFORM=m CONFIG_BACKLIGHT_AS3711=y CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_HDA_TEGRA=m CONFIG_SND_HDA_INPUT_BEEP=y CONFIG_SND_HDA_PATCH_LOADER=y CONFIG_SND_HDA_CODEC_REALTEK=m CONFIG_SND_HDA_CODEC_HDMI=m CONFIG_SND_USB_AUDIO=m CONFIG_SND_ATMEL_SOC_WM8904=m CONFIG_SND_ATMEL_SOC_PDMIC=m CONFIG_SND_BCM2835_SOC_I2S=m CONFIG_SND_SOC_ROCKCHIP=m CONFIG_SND_SOC_ROCKCHIP_SPDIF=m CONFIG_SND_SOC_ROCKCHIP_MAX98090=m CONFIG_SND_SOC_ROCKCHIP_RT5645=m CONFIG_SND_SOC_SAMSUNG=m CONFIG_SND_SOC_SAMSUNG_SMDK_WM8994=m CONFIG_SND_SOC_SMDK_WM8994_PCM=m CONFIG_SND_SOC_SNOW=m CONFIG_SND_SOC_SH4_FSI=m CONFIG_SND_SOC_RCAR=m CONFIG_SND_SIMPLE_SCU_CARD=m CONFIG_SND_SUN4I_CODEC=m CONFIG_SND_SOC_TEGRA=m CONFIG_SND_SOC_TEGRA20_I2S=m CONFIG_SND_SOC_TEGRA30_I2S=m CONFIG_SND_SOC_TEGRA_RT5640=m CONFIG_SND_SOC_TEGRA_WM8753=m CONFIG_SND_SOC_TEGRA_WM8903=m CONFIG_SND_SOC_TEGRA_WM9712=m CONFIG_SND_SOC_TEGRA_TRIMSLICE=m CONFIG_SND_SOC_TEGRA_ALC5632=m CONFIG_SND_SOC_TEGRA_MAX98090=m CONFIG_SND_SOC_SPDIF=m CONFIG_SND_SOC_STI=m CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_MVEBU=y CONFIG_USB_XHCI_RCAR=m CONFIG_USB_XHCI_TEGRA=m CONFIG_USB_XHCI_PLATFORM=m CONFIG_USB_EHCI_MSM=m CONFIG_USB_EHCI_EXYNOS=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_EHCI_HCD_STI=y CONFIG_USB_EHCI_HCD_PLATFORM=y CONFIG_USB_ISP1760=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_STI=y CONFIG_USB_OHCI_HCD_PLATFORM=y CONFIG_USB_OHCI_EXYNOS=m CONFIG_USB_R8A66597_HCD=m CONFIG_USB_RENESAS_USBHS=m CONFIG_USB_STORAGE=y CONFIG_USB_MUSB_SUNXI=m CONFIG_USB_CHIPIDEA_UDC=y CONFIG_USB_CHIPIDEA_HOST=y CONFIG_AB8500_USB=y CONFIG_KEYSTONE_USB_PHY=y CONFIG_USB_GPIO_VBUS=y CONFIG_USB_ISP1301=y CONFIG_USB_MSM_OTG=m CONFIG_USB_MXS_PHY=y CONFIG_USB_FSL_USB2=y CONFIG_USB_RENESAS_USBHS_UDC=m CONFIG_MMC_BLOCK_MINORS=16 CONFIG_MMC_ARMMMCI=y CONFIG_MMC_SDHCI_OF_ARASAN=y CONFIG_MMC_SDHCI_OF_AT91=y CONFIG_MMC_SDHCI_OF_ESDHC=y CONFIG_MMC_SDHCI_ESDHC_IMX=y CONFIG_MMC_SDHCI_DOVE=y CONFIG_MMC_SDHCI_TEGRA=y CONFIG_MMC_SDHCI_PXAV3=y CONFIG_MMC_SDHCI_SPEAR=y CONFIG_MMC_SDHCI_S3C=y CONFIG_MMC_SDHCI_S3C_DMA=y CONFIG_MMC_SDHCI_BCM_KONA=y CONFIG_MMC_SDHCI_ST=y CONFIG_MMC_OMAP=y CONFIG_MMC_ATMELMCI=y CONFIG_MMC_SDHCI_MSM=y CONFIG_MMC_MVSDIO=y CONFIG_MMC_SDHI=y CONFIG_MMC_DW_PLTFM=y CONFIG_MMC_DW_EXYNOS=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SH_MMCIF=y CONFIG_MMC_SUNXI=y CONFIG_MMC_BCM2835=y CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS_FLASH=m CONFIG_LEDS_GPIO=y CONFIG_LEDS_PWM=n CONFIG_LEDS_MAX77693=m CONFIG_LEDS_MAX8997=m CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_ONESHOT=y CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_CPU=y CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y CONFIG_LEDS_TRIGGER_TRANSIENT=y CONFIG_LEDS_TRIGGER_CAMERA=y CONFIG_EDAC_HIGHBANK_MC=y CONFIG_EDAC_HIGHBANK_L2=y CONFIG_RTC_CLASS=y CONFIG_RTC_DRV_AC100=y CONFIG_RTC_DRV_AS3722=y CONFIG_RTC_DRV_MAX8907=y CONFIG_RTC_DRV_MAX8998=m CONFIG_RTC_DRV_MAX8997=m CONFIG_RTC_DRV_MAX77686=y CONFIG_RTC_DRV_RK808=m CONFIG_RTC_DRV_ST_LPC=y CONFIG_RTC_DRV_DA9063=m CONFIG_RTC_DRV_EFI=m CONFIG_RTC_DRV_DIGICOLOR=m CONFIG_RTC_DRV_S5M=m CONFIG_RTC_DRV_S3C=m CONFIG_RTC_DRV_PL031=y CONFIG_RTC_DRV_AT91RM9200=m CONFIG_RTC_DRV_AT91SAM9=m CONFIG_RTC_DRV_VT8500=y CONFIG_RTC_DRV_SUN6I=y CONFIG_RTC_DRV_SUNXI=y CONFIG_RTC_DRV_MV=y CONFIG_RTC_DRV_TEGRA=y CONFIG_DMADEVICES=y CONFIG_DW_DMAC=y CONFIG_AT_HDMAC=y CONFIG_AT_XDMAC=y CONFIG_FSL_EDMA=y CONFIG_MV_XOR=y CONFIG_TEGRA20_APB_DMA=y CONFIG_SH_DMAE=y CONFIG_RCAR_DMAC=y CONFIG_RENESAS_USB_DMAC=m CONFIG_STE_DMA40=y CONFIG_SIRF_DMA=y CONFIG_TI_EDMA=y CONFIG_PL330_DMA=y CONFIG_IMX_SDMA=y CONFIG_IMX_DMA=y CONFIG_MXS_DMA=y CONFIG_DMA_BCM2835=y CONFIG_DMA_OMAP=y CONFIG_QCOM_BAM_DMA=y CONFIG_XILINX_DMA=y CONFIG_DMA_SUN6I=y CONFIG_ST_FDMA=m CONFIG_SENSORS_ISL29018=y CONFIG_SENSORS_ISL29028=y CONFIG_MFD_NVEC=y CONFIG_KEYBOARD_NVEC=y CONFIG_SERIO_NVEC_PS2=y CONFIG_NVEC_POWER=y CONFIG_NVEC_PAZ00=y CONFIG_BCMA=y CONFIG_BCMA_HOST_SOC=y CONFIG_BCMA_DRIVER_GMAC_CMN=y CONFIG_BCMA_DRIVER_GPIO=y CONFIG_QCOM_GSBI=y CONFIG_QCOM_PM=y CONFIG_QCOM_SMEM=y CONFIG_QCOM_SMD_RPM=y CONFIG_QCOM_SMP2P=y CONFIG_QCOM_SMSM=y CONFIG_QCOM_WCNSS_CTRL=m CONFIG_ROCKCHIP_PM_DOMAINS=y CONFIG_COMMON_CLK_QCOM=y CONFIG_QCOM_CLK_RPM=y CONFIG_STAGING_BOARD=y CONFIG_CROS_EC_CHARDEV=m CONFIG_COMMON_CLK_MAX77686=y CONFIG_COMMON_CLK_RK808=m CONFIG_COMMON_CLK_S2MPS11=m CONFIG_APQ_MMCC_8084=y CONFIG_MSM_GCC_8660=y CONFIG_MSM_MMCC_8960=y CONFIG_MSM_MMCC_8974=y CONFIG_HWSPINLOCK_QCOM=y CONFIG_ROCKCHIP_IOMMU=y CONFIG_TEGRA_IOMMU_GART=y CONFIG_TEGRA_IOMMU_SMMU=y CONFIG_ST_REMOTEPROC=m CONFIG_ARM_TEGRA_DEVFREQ=m CONFIG_MEMORY=y CONFIG_TI_AEMIF=y CONFIG_IIO=y CONFIG_IIO_SW_TRIGGER=y CONFIG_AT91_ADC=m CONFIG_AT91_SAMA5D2_ADC=m CONFIG_BERLIN2_ADC=m CONFIG_EXYNOS_ADC=m CONFIG_VF610_ADC=m CONFIG_XILINX_XADC=y CONFIG_MPU3050_I2C=y CONFIG_CM36651=m CONFIG_AK8975=y CONFIG_RASPBERRYPI_POWER=y CONFIG_IIO_HRTIMER_TRIGGER=y CONFIG_PWM=n CONFIG_PWM_ATMEL=n CONFIG_PWM_ATMEL_HLCDC_PWM=n CONFIG_PWM_ATMEL_TCB=n CONFIG_PWM_FSL_FTM=n CONFIG_PWM_RENESAS_TPU=n CONFIG_PWM_ROCKCHIP=n CONFIG_PWM_SAMSUNG=n CONFIG_PWM_SUN4I=n CONFIG_PWM_TEGRA=n CONFIG_PWM_VT8500=n CONFIG_PHY_HIX5HD2_SATA=y CONFIG_PWM_STI=n CONFIG_PWM_BCM2835=n CONFIG_PWM_BRCMSTB=n CONFIG_GENERIC_PHY=y CONFIG_OMAP_USB2=y CONFIG_TI_PIPE3=y CONFIG_PHY_BERLIN_USB=y CONFIG_PHY_BERLIN_SATA=y CONFIG_PHY_ROCKCHIP_DP=m CONFIG_PHY_ROCKCHIP_USB=y CONFIG_PHY_QCOM_APQ8064_SATA=m CONFIG_PHY_MIPHY28LP=y CONFIG_PHY_RCAR_GEN2=m CONFIG_PHY_STIH407_USB=y CONFIG_PHY_SUN4I_USB=y CONFIG_PHY_SUN9I_USB=y CONFIG_PHY_SAMSUNG_USB2=m CONFIG_PHY_TEGRA_XUSB=y CONFIG_PHY_BRCM_SATA=y CONFIG_NVMEM=y CONFIG_NVMEM_SUNXI_SID=y CONFIG_BCM2835_MBOX=y CONFIG_RASPBERRYPI_FIRMWARE=y CONFIG_EFI_VARS=m CONFIG_EFI_CAPSULE_LOADER=m CONFIG_BCM47XX_NVRAM=y CONFIG_BCM47XX_SPROM=y CONFIG_EXT4_FS=y CONFIG_AUTOFS4_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_NTFS_FS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_UBIFS_FS=y CONFIG_TMPFS=y CONFIG_SQUASHFS=y CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y CONFIG_PSTORE=y CONFIG_PSTORE_CONSOLE=y CONFIG_PSTORE_PMSG=y CONFIG_PSTORE_RAM=y CONFIG_NFS_FS=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y CONFIG_ROOT_NFS=y CONFIG_NLS_CODEPAGE_437=y CONFIG_NLS_ISO8859_1=y CONFIG_NLS_UTF8=y CONFIG_PRINTK_TIME=y CONFIG_MAGIC_SYSRQ=y CONFIG_KEYSTONE_IRQ=y CONFIG_HW_RANDOM=y CONFIG_HW_RANDOM_ST=y CONFIG_CRYPTO_USER=m CONFIG_CRYPTO_USER_API_RNG=m CONFIG_CRYPTO_USER_API_AEAD=m CONFIG_CRYPTO_DEV_MARVELL_CESA=m CONFIG_CRYPTO_DEV_EXYNOS_RNG=m CONFIG_CRYPTO_DEV_S5P=m CONFIG_CRYPTO_DEV_SUN4I_SS=m CONFIG_CRYPTO_DEV_ROCKCHIP=m CONFIG_ARM_CRYPTO=y CONFIG_CRYPTO_SHA1_ARM=m CONFIG_CRYPTO_SHA1_ARM_CE=m CONFIG_CRYPTO_SHA2_ARM_CE=m CONFIG_CRYPTO_AES_ARM=m CONFIG_CRYPTO_AES_ARM_CE=m CONFIG_CRYPTO_CHACHA20_NEON=m CONFIG_CRYPTO_CRC32_ARM_CE=m CONFIG_CRYPTO_CRCT10DIF_ARM_CE=m CONFIG_CRYPTO_GHASH_ARM_CE=m CONFIG_CRYPTO_DEV_ATMEL_AES=m CONFIG_CRYPTO_DEV_ATMEL_TDES=m CONFIG_CRYPTO_DEV_ATMEL_SHA=m CONFIG_VIDEO_VIVID=m CONFIG_VIRTIO=y CONFIG_VIRTIO_PCI=y CONFIG_VIRTIO_PCI_LEGACY=y CONFIG_VIRTIO_MMIO=y # Add config flags here that only appear in the multi_v7_defconfig CONFIG_ARCH_ALPINE=n CONFIG_ARCH_ARTPEC=n CONFIG_ARCH_AT91=n CONFIG_ARCH_BCM=n CONFIG_ARCH_BCM_CYGNUS=n CONFIG_ARCH_BCM_NSP=n CONFIG_ARCH_BCM_5301X=n CONFIG_ARCH_BCM_281XX=n CONFIG_ARCH_BCM_21664=n CONFIG_ARCH_BRCMSTB=n CONFIG_ARCH_BERLIN=n CONFIG_ARCH_DIGICOLOR=n CONFIG_ARCH_HIGHBANK=n CONFIG_ARCH_HISI=n CONFIG_ARCH_HI3xxx=n CONFIG_ARCH_HIP01=n CONFIG_ARCH_HIP04=n CONFIG_ARCH_HIX5HD2=n CONFIG_ARCH_MESON=n CONFIG_ARCH_MXC=n CONFIG_ARCH_MEDIATEK=n CONFIG_ARCH_QCOM=n CONFIG_ARCH_MSM8X60=n CONFIG_ARCH_MSM8960=n CONFIG_ARCH_MSM8974=n CONFIG_ARCH_ROCKCHIP=n CONFIG_ARCH_SOCFPGA=n CONFIG_ARCH_SPEAR13XX=n CONFIG_ARCH_STI=n CONFIG_ARCH_EXYNOS=n CONFIG_ARCH_SHMOBILE_MULTI=n CONFIG_ARCH_EMEV2=n CONFIG_ARCH_R7S72100=n CONFIG_ARCH_R8A73A4=n CONFIG_ARCH_R8A7740=n CONFIG_ARCH_R8A7778=n CONFIG_ARCH_R8A7779=n CONFIG_ARCH_R8A7790=n CONFIG_ARCH_R8A7791=n CONFIG_ARCH_R8A7793=n CONFIG_ARCH_R8A7794=n CONFIG_ARCH_RENESAS=n CONFIG_ARCH_SH73A0=n CONFIG_ARCH_SUNXI=n CONFIG_ARCH_SIRF=n CONFIG_ARCH_TEGRA=n CONFIG_ARCH_TEGRA_2x_SOC=n CONFIG_ARCH_TEGRA_3x_SOC=n CONFIG_ARCH_TEGRA_114_SOC=n CONFIG_ARCH_TEGRA_124_SOC=n CONFIG_ARCH_UNIPHIER=n CONFIG_ARCH_U8500=n CONFIG_ARCH_VEXPRESS=n CONFIG_ARCH_VEXPRESS_TC2_PM=n CONFIG_ARCH_WM8850=n CONFIG_ARCH_ZYNQ=n CONFIG_ARCH_VIRT=n CONFIG_ARCH_MVEBU=n CONFIG_PLAT_SPEAR=n CONFIG_CHROME_PLATFORMS=n ################################################## # TI Baseport Config Options ################################################## # Kernel compression CONFIG_KERNEL_GZIP=n CONFIG_KERNEL_LZMA=y CONFIG_KERNEL_LZ4=n CONFIG_KERNEL_XZ=n CONFIG_KERNEL_LZO=n # Enable process accounting CONFIG_BSD_PROCESS_ACCT=y # Have some way to pick up kernel config later on # Always useful to look at /proc/config.gz CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # Add Bin2c CONFIG_BUILD_BIN2C=y # Add base Cgroups functions CONFIG_CGROUP_DEBUG=n CONFIG_CPUSETS=y CONFIG_PROC_PID_CPUSET=y CONFIG_PAGE_COUNTER=y CONFIG_MEMCG=y CONFIG_MEMCG_SWAP=y CONFIG_MEMCG_SWAP_ENABLED=y CONFIG_DEBUG_BLK_CGROUP=n CONFIG_CGROUP_WRITEBACK=y # Choose CONFIG_EMBEDDED CONFIG_EMBEDDED=y CONFIG_EXPERT=y CONFIG_ARM_PATCH_PHYS_VIRT=y # Enable all kernel symbols please CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y # Enable AEABI CONFIG_AEABI=y # How do we want kernel Modules to work? CONFIG_BASE_FULL=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y CONFIG_MODVERSIONS=y CONFIG_MODULE_SRCVERSION_ALL=y CONFIG_MODULE_SIG=n CONFIG_MODULE_COMPRESS=n CONFIG_MODULES_TREE_LOOKUP=y # Boot options CONFIG_USE_OF=y CONFIG_ATAGS=y CONFIG_DEPRECATED_PARAM_STRUCT=n CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND=n CONFIG_CMDLINE="" CONFIG_CMDLINE_FROM_BOOTLOADER=y CONFIG_CMDLINE_EXTEND=n CONFIG_CMDLINE_FORCE=n CONFIG_ATAGS_PROC=y CONFIG_CRASH_DUMP=n CONFIG_AUTO_ZRELADDR=y # Mem allocator CONFIG_SLAB=n CONFIG_SLUB=y # Enable NEON CONFIG_VFP=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # POSIX Message queue CONFIG_POSIX_MQUEUE=y # No Multi Cluster systems in TI yet.. CONFIG_MCPM=n # Serial CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y CONFIG_SERIAL_8250_NR_UARTS=10 CONFIG_SERIAL_8250_RUNTIME_UARTS=10 CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_OMAP=n CONFIG_SERIAL_8250_DW=n CONFIG_SERIAL_8250_EM=n CONFIG_SERIAL_AMBA_PL011=n CONFIG_SERIAL_XILINX_PS_UART=n CONFIG_SERIAL_FSL_LPUART=n CONFIG_SERIAL_CONEXANT_DIGICOLOR=n CONFIG_SERIAL_ST_ASC=n CONFIG_JUMP_LABEL=y # Disable Extra debug options CONFIG_TIMER_STATS=n CONFIG_DEBUG_SPINLOCK=n CONFIG_DEBUG_MUTEXES=n CONFIG_DEBUG_LOCK_ALLOC=n CONFIG_PROVE_LOCKING=n CONFIG_LOCKDEP=n CONFIG_STACKTRACE=n CONFIG_FTRACE=n CONFIG_ARM_UNWIND=n CONFIG_DEBUG_PREEMPT=n CONFIG_SLUB_DEBUG=n CONFIG_LOCKUP_DETECTOR=n CONFIG_DETECT_HUNG_TASK=n CONFIG_IRQ_DOMAIN_DEBUG=n CONFIG_DEBUG_BUGVERBOSE=n CONFIG_DEBUG_FS=y # Enable System V IPC CONFIG_SYSVIPC=y # Power management options CONFIG_SUSPEND_FREEZER=y CONFIG_SUSPEND_SKIP_SYNC=n CONFIG_HIBERNATION=n CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y CONFIG_PM_AUTOSLEEP=n CONFIG_PM_WAKELOCKS=n CONFIG_PM=y CONFIG_PM_DEBUG=y CONFIG_APM_EMULATION=n CONFIG_PM_OPP=y CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y CONFIG_WQ_POWER_EFFICIENT_DEFAULT=n CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y # Clock framework stuff we need CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y CONFIG_COMMON_CLK_SI5351=n CONFIG_COMMON_CLK_SI514=n CONFIG_COMMON_CLK_SI570=n CONFIG_COMMON_CLK_CDCE925=n CONFIG_CLK_TWL6040=n CONFIG_CLK_QORIQ=n CONFIG_COMMON_CLK_PALMAS=y CONFIG_COMMON_CLK_PWM=n CONFIG_COMMON_CLK_PXA=n CONFIG_COMMON_CLK_CDCE706=n CONFIG_CLKSRC_OF=y CONFIG_CLKSRC_PROBE=y CONFIG_CLKSRC_MMIO=y CONFIG_CLKSRC_TI_32K=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y CONFIG_ARM_GLOBAL_TIMER=n CONFIG_ARM_TIMER_SP804=n # Clock cleanup please CONFIG_OMAP_RESET_CLOCKS=y # CPU Idle CONFIG_CPU_IDLE_GOV_LADDER=y CONFIG_CPU_IDLE_GOV_MENU=y CONFIG_DT_IDLE_STATES=y # ARM CPU Idle Drivers CONFIG_ARM_CPUIDLE=y CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=n # CPU Frequency scaling CONFIG_CPU_FREQ_GOV_COMMON=y CONFIG_CPU_FREQ_STAT=y CONFIG_CPU_FREQ_STAT_DETAILS=y CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_PERFORMANCE=y CONFIG_CPU_FREQ_GOV_POWERSAVE=y CONFIG_CPU_FREQ_GOV_USERSPACE=y CONFIG_CPU_FREQ_GOV_ONDEMAND=y CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y # CPUFreq Driver Options CONFIG_CPUFREQ_DT=y CONFIG_ARM_BIG_LITTLE_CPUFREQ=n CONFIG_ARM_KIRKWOOD_CPUFREQ=n CONFIG_ARM_OMAP2PLUS_CPUFREQ=n CONFIG_ARM_TI_CPUFREQ=y CONFIG_QORIQ_CPUFREQ=n # AMx3 Power Config Options CONFIG_MAILBOX=y CONFIG_WKUP_M3_RPROC=m CONFIG_SOC_TI=y CONFIG_SOC_BRCMSTB=n CONFIG_WKUP_M3_IPC=m CONFIG_AMX3_PM=m CONFIG_SRAM=y CONFIG_TI_EMIF_SRAM=m CONFIG_SUNXI_SRAM=n CONFIG_PM_DEVFREQ=n # K2G Power config options # CONFIG_MAILBOX is enabled in AMx3 CONFIG_TI_MESSAGE_MANAGER=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_TI_SCI_PM_DOMAINS=y CONFIG_TI_SCI_CLK=y # Enable Reset Controllers CONFIG_RESET_CONTROLLER=y CONFIG_RESET_TI_SYSCON=y CONFIG_RESET_TI_SCI=y # CPUFreq and OPP drivers CONFIG_OPP_DOMAIN_TI=y # Thermal CONFIG_THERMAL=y CONFIG_THERMAL_OF=y CONFIG_THERMAL_WRITABLE_TRIPS=y CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_FAIR_SHARE=y CONFIG_THERMAL_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_BANG_BANG=y CONFIG_THERMAL_GOV_USER_SPACE=y CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y CONFIG_CPU_THERMAL=y CONFIG_TI_SOC_THERMAL=y CONFIG_TI_THERMAL=y CONFIG_OMAP4_THERMAL=y CONFIG_OMAP5_THERMAL=y CONFIG_DRA752_THERMAL=y # Since HWMON is needed by Sensors.. CONFIG_HWMON=y CONFIG_SENSORS_TMP102=y CONFIG_SENSORS_GPIO_FAN=y # Enable the reset framework CONFIG_POWER_RESET=y CONFIG_POWER_SUPPLY=y # Pinctrl CONFIG_PINCTRL_TI_IODELAY=y CONFIG_PINCTRL_SINGLE=y # # Multifunction device drivers CONFIG_MFD_CORE=y CONFIG_MFD_AS3711=n CONFIG_MFD_AS3722=n CONFIG_PMIC_ADP5520=n CONFIG_MFD_AAT2870_CORE=n CONFIG_MFD_ATMEL_FLEXCOM=n CONFIG_MFD_ATMEL_HLCDC=n CONFIG_MFD_BCM590XX=n CONFIG_MFD_AXP20X=n CONFIG_MFD_AXP20X_I2C=n CONFIG_MFD_CROS_EC=n CONFIG_MFD_CROS_EC_I2C=n CONFIG_MFD_CROS_EC_SPI=n CONFIG_MFD_ASIC3=n CONFIG_PMIC_DA903X=n CONFIG_MFD_DA9052_SPI=n CONFIG_MFD_DA9052_I2C=n CONFIG_MFD_DA9055=n CONFIG_MFD_DA9062=n CONFIG_MFD_DA9063=n CONFIG_MFD_DA9150=n CONFIG_MFD_DLN2=n CONFIG_MFD_MC13XXX_SPI=n CONFIG_MFD_MC13XXX_I2C=n CONFIG_MFD_HI6421_PMIC=n CONFIG_HTC_EGPIO=n CONFIG_HTC_PASIC3=n CONFIG_HTC_I2CPLD=n CONFIG_LPC_ICH=n CONFIG_LPC_SCH=n CONFIG_INTEL_SOC_PMIC=n CONFIG_MFD_JANZ_CMODIO=n CONFIG_MFD_KEMPLD=n CONFIG_MFD_88PM800=n CONFIG_MFD_88PM805=n CONFIG_MFD_88PM860X=n CONFIG_MFD_MAX14577=n CONFIG_MFD_MAX77686=n CONFIG_MFD_MAX77693=n CONFIG_MFD_MAX77843=n CONFIG_MFD_MAX8907=n CONFIG_MFD_MAX8925=n CONFIG_MFD_MAX8997=n CONFIG_MFD_MAX8998=n CONFIG_MFD_MT6397=n CONFIG_MFD_MENF21BMC=n CONFIG_EZX_PCAP=n CONFIG_MFD_VIPERBOARD=n CONFIG_MFD_RETU=n CONFIG_MFD_PCF50633=n CONFIG_MFD_PM8XXX=n CONFIG_MFD_PM8921_CORE=n CONFIG_MFD_RDC321X=n CONFIG_MFD_RTSX_PCI=n CONFIG_MFD_RT5033=n CONFIG_MFD_RTSX_USB=n CONFIG_MFD_RC5T583=n CONFIG_MFD_RK808=n CONFIG_MFD_RN5T618=n CONFIG_MFD_SEC_CORE=n CONFIG_MFD_SI476X_CORE=n CONFIG_MFD_SM501=n CONFIG_MFD_SKY81452=n CONFIG_MFD_SMSC=n CONFIG_ABX500_CORE=n CONFIG_AB3100_CORE=n CONFIG_MFD_STMPE=n CONFIG_STMPE_I2C=n CONFIG_STMPE_SPI=n CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=m CONFIG_MFD_LP3943=n CONFIG_MFD_LP8788=n CONFIG_MFD_OMAP_USB_HOST=y CONFIG_MFD_PALMAS=y CONFIG_TPS6105X=n CONFIG_TPS65010=n CONFIG_TPS6507X=n CONFIG_MFD_TPS65086=n CONFIG_MFD_TPS65090=y CONFIG_MFD_TPS65217=y CONFIG_MFD_TPS65218=y CONFIG_MFD_TPS6586X=y CONFIG_MFD_TPS65910=y CONFIG_MFD_TPS65912_I2C=n CONFIG_MFD_TPS65912_SPI=n CONFIG_MFD_TPS80031=n CONFIG_TWL4030_CORE=n CONFIG_TWL4030_POWER=n CONFIG_MFD_TWL4030_AUDIO=n CONFIG_TWL6040_CORE=y CONFIG_MFD_WL1273_CORE=n CONFIG_MFD_LM3533=n CONFIG_MFD_TI_LP873X=y CONFIG_MFD_TI_LP87565=y CONFIG_MFD_TC3589X=n CONFIG_MFD_TMIO=n CONFIG_MFD_T7L66XB=n CONFIG_MFD_TC6387XB=n CONFIG_MFD_TC6393XB=n CONFIG_MFD_VX855=n CONFIG_MFD_ARIZONA_I2C=n CONFIG_MFD_ARIZONA_SPI=n CONFIG_MFD_WM8400=n CONFIG_MFD_WM831X_I2C=n CONFIG_MFD_WM831X_SPI=n CONFIG_MFD_WM8350_I2C=n CONFIG_MFD_WM8994=n CONFIG_MFD_VEXPRESS_SYSREG=n # Regulators CONFIG_REGULATOR=y CONFIG_REGULATOR_FIXED_VOLTAGE=y CONFIG_REGULATOR_DEBUG=n CONFIG_REGULATOR_VIRTUAL_CONSUMER=n CONFIG_REGULATOR_USERSPACE_CONSUMER=n CONFIG_REGULATOR_ACT8865=n CONFIG_REGULATOR_AD5398=n CONFIG_REGULATOR_ANATOP=n CONFIG_REGULATOR_AS3711=n CONFIG_REGULATOR_AS3722=n CONFIG_REGULATOR_AXP20X=n CONFIG_REGULATOR_BCM590XX=n CONFIG_REGULATOR_DA9210=n CONFIG_REGULATOR_DA9211=n CONFIG_REGULATOR_FAN53555=n CONFIG_REGULATOR_GPIO=y CONFIG_REGULATOR_ISL9305=n CONFIG_REGULATOR_ISL6271A=n CONFIG_REGULATOR_LP3971=n CONFIG_REGULATOR_LP3972=n CONFIG_REGULATOR_LP872X=n CONFIG_REGULATOR_LP8755=n CONFIG_REGULATOR_LP873X=y CONFIG_REGULATOR_LP87565=y CONFIG_REGULATOR_LTC3589=n CONFIG_REGULATOR_MAX14577=n CONFIG_REGULATOR_MAX1586=n CONFIG_REGULATOR_MAX8649=n CONFIG_REGULATOR_MAX8660=n CONFIG_REGULATOR_MAX8907=n CONFIG_REGULATOR_MAX8952=n CONFIG_REGULATOR_MAX8973=n CONFIG_REGULATOR_MAX77686=n CONFIG_REGULATOR_MAX77693=n CONFIG_REGULATOR_MAX77802=n CONFIG_REGULATOR_MT6311=n CONFIG_REGULATOR_PALMAS=y CONFIG_REGULATOR_PBIAS=y CONFIG_REGULATOR_PFUZE100=n CONFIG_REGULATOR_PWM=n CONFIG_REGULATOR_RK808=n CONFIG_REGULATOR_S2MPA01=n CONFIG_REGULATOR_S2MPS11=n CONFIG_REGULATOR_S5M8767=n CONFIG_REGULATOR_TI_ABB=y CONFIG_REGULATOR_TPS51632=n CONFIG_REGULATOR_TPS62360=y CONFIG_REGULATOR_TPS65023=y CONFIG_REGULATOR_TPS6507X=y CONFIG_REGULATOR_TPS65090=y CONFIG_REGULATOR_TPS65217=y CONFIG_REGULATOR_TPS65218=y CONFIG_REGULATOR_TPS6524X=y CONFIG_REGULATOR_TPS6586X=y CONFIG_REGULATOR_TPS65910=y CONFIG_REGULATOR_TWL4030=n CONFIG_REGULATOR_VEXPRESS=n # Crypto Modules CONFIG_CRYPTO_DEV_OMAP=m CONFIG_CRYPTO_DEV_OMAP_SHAM=m CONFIG_CRYPTO_DEV_OMAP_AES=m CONFIG_CRYPTO_DEV_OMAP_DES=m CONFIG_CRYPTO_USER_API_HASH=m CONFIG_CRYPTO_USER_API_SKCIPHER=m CONFIG_CRYPTO_SHA1_ARM_NEON=m CONFIG_CRYPTO_SHA256_ARM=m CONFIG_CRYPTO_SHA512_ARM=m CONFIG_CRYPTO_AES_ARM_BS=m # # RTC drivers # CONFIG_RTC_DRV_ABB5ZES3=n CONFIG_RTC_DRV_ABX80X=n CONFIG_RTC_DRV_DS1307=m CONFIG_RTC_DRV_DS1374=n CONFIG_RTC_DRV_DS1672=n CONFIG_RTC_DRV_DS3232=n CONFIG_RTC_DRV_HYM8563=n CONFIG_RTC_DRV_MAX6900=n CONFIG_RTC_DRV_RS5C372=n CONFIG_RTC_DRV_ISL1208=n CONFIG_RTC_DRV_ISL12022=n CONFIG_RTC_DRV_ISL12057=n CONFIG_RTC_DRV_X1205=n CONFIG_RTC_DRV_PALMAS=m CONFIG_RTC_DRV_PCF2127=n CONFIG_RTC_DRV_PCF8523=n CONFIG_RTC_DRV_PCF8563=n CONFIG_RTC_DRV_PCF85063=n CONFIG_RTC_DRV_PCF8583=n CONFIG_RTC_DRV_M41T80=n CONFIG_RTC_DRV_BQ32K=n CONFIG_RTC_DRV_TPS6586X=m CONFIG_RTC_DRV_TPS65910=m CONFIG_RTC_DRV_TWL92330=y CONFIG_RTC_DRV_TWL4030=n CONFIG_RTC_DRV_S35390A=n CONFIG_RTC_DRV_FM3130=n CONFIG_RTC_DRV_RX8581=n CONFIG_RTC_DRV_RX8025=n CONFIG_RTC_DRV_EM3027=n CONFIG_RTC_DRV_RV3029C2=n CONFIG_RTC_DRV_RV8803=n CONFIG_RTC_DRV_M41T93=n CONFIG_RTC_DRV_M41T94=n CONFIG_RTC_DRV_DS1305=n CONFIG_RTC_DRV_DS1343=n CONFIG_RTC_DRV_DS1347=n CONFIG_RTC_DRV_DS1390=n CONFIG_RTC_DRV_MAX6902=n CONFIG_RTC_DRV_R9701=n CONFIG_RTC_DRV_RS5C348=n CONFIG_RTC_DRV_DS3234=n CONFIG_RTC_DRV_PCF2123=n CONFIG_RTC_DRV_RX4581=n CONFIG_RTC_DRV_MCP795=n CONFIG_RTC_DRV_CMOS=n CONFIG_RTC_DRV_DS1286=n CONFIG_RTC_DRV_DS1511=n CONFIG_RTC_DRV_DS1553=n CONFIG_RTC_DRV_DS1685_FAMILY=n CONFIG_RTC_DRV_DS1742=n CONFIG_RTC_DRV_DS2404=n CONFIG_RTC_DRV_STK17TA8=n CONFIG_RTC_DRV_M48T86=n CONFIG_RTC_DRV_M48T35=n CONFIG_RTC_DRV_M48T59=n CONFIG_RTC_DRV_MSM6242=n CONFIG_RTC_DRV_BQ4802=n CONFIG_RTC_DRV_RP5C01=n CONFIG_RTC_DRV_V3020=n CONFIG_RTC_DRV_ZYNQMP=n CONFIG_RTC_DRV_OMAP=m CONFIG_RTC_DRV_SNVS=n CONFIG_RTC_DRV_HID_SENSOR_TIME=n # WatchDog CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y CONFIG_WATCHDOG_NOWAYOUT=n # Watchdog Device Drivers CONFIG_SOFT_WATCHDOG=n CONFIG_GPIO_WATCHDOG=n CONFIG_XILINX_WATCHDOG=n CONFIG_CADENCE_WATCHDOG=n CONFIG_DW_WATCHDOG=n CONFIG_OMAP_WATCHDOG=m CONFIG_TWL4030_WATCHDOG=m CONFIG_MAX63XX_WATCHDOG=n CONFIG_ALIM7101_WDT=n CONFIG_I6300ESB_WDT=n CONFIG_BCM7038_WDT=n CONFIG_MEN_A21_WDT=n # No Staging drivers please CONFIG_STAGING=n # GPIO CONFIG_GPIOLIB=y CONFIG_GPIO_SYSFS=y CONFIG_DEBUG_GPIO=y # GPIO disable unused options CONFIG_GPIO_DWAPB=n CONFIG_GPIO_EM=n CONFIG_GPIO_GENERIC_PLATFORM=n CONFIG_GPIO_XILINX=n CONFIG_GPIO_TPS6586X=n # Enable options to facilitate testing CONFIG_CRYPTO_TEST=m CONFIG_RTC_DEBUG=y CONFIG_THERMAL_EMULATION=y # OPTEE Driver CONFIG_TEE=y CONFIG_OPTEE=y ################################################## # TI RPMsg/IPC Config Options ################################################## # HwSpinLock CONFIG_HWSPINLOCK=y CONFIG_HWSPINLOCK_OMAP=y # Mailbox CONFIG_OMAP2PLUS_MBOX=y # IOMMU CONFIG_IOMMU_SUPPORT=y CONFIG_OMAP_IOMMU=y CONFIG_OMAP_IOMMU_DEBUG=y # Remoteproc CONFIG_REMOTEPROC=m CONFIG_OMAP_REMOTEPROC=m CONFIG_KEYSTONE_REMOTEPROC=m CONFIG_DA8XX_REMOTEPROC=m CONFIG_PRUSS_REMOTEPROC=m # RPMsg CONFIG_RPMSG_VIRTIO=y CONFIG_RPMSG_PROTO=y CONFIG_RPMSG_RPC=y CONFIG_RPMSG_PRU=y # DSP Memory Mapper for Keystone MPM CONFIG_KEYSTONE_DSP_MEM=m # UIO Module CONFIG_UIO=m ################################################## # TI Connectivity Configs ################################################## # Disable unused I2C options CONFIG_I2C_MUX=n CONFIG_I2C_DESIGNWARE_PLATFORM=n CONFIG_I2C_GPIO=n CONFIG_I2C_RK3X=n CONFIG_I2C_XILINX=n # I2C GPIO expanders CONFIG_GPIO_PCF857X=y CONFIG_GPIO_TPIC2810=m #Networking drivers CONFIG_NET_VENDOR_TI=y CONFIG_KEYSTONE_NAVIGATOR_QMSS=y CONFIG_KEYSTONE_NAVIGATOR_DMA=y CONFIG_TI_KEYSTONE_NETCP=y CONFIG_TI_KEYSTONE_NETCP_ETHSS=y CONFIG_TI_DAVINCI_EMAC=y CONFIG_TI_DAVINCI_MDIO=y CONFIG_TI_DAVINCI_CPDMA=y CONFIG_TI_CPSW_PHY_SEL=y CONFIG_TI_CPSW_ALE=y CONFIG_TI_CPSW=y CONFIG_TI_CPTS=y # non-TI Net vendors CONFIG_NET_DSA_BCM_SF2=n CONFIG_B53=n CONFIG_SYSTEMPORT=n CONFIG_NET_VENDOR_3COM=n CONFIG_NET_VENDOR_ADAPTEC=n CONFIG_NET_VENDOR_AGERE=n CONFIG_NET_VENDOR_ALTEON=n CONFIG_NET_VENDOR_AMAZON=n CONFIG_NET_VENDOR_AMD=n CONFIG_NET_VENDOR_ARC=n CONFIG_NET_VENDOR_ATHEROS=n CONFIG_NET_VENDOR_BROCADE=n CONFIG_NET_VENDOR_CAVIUM=n CONFIG_NET_VENDOR_CHELSIO=n CONFIG_NET_CADENCE=n CONFIG_BCMGENET=n CONFIG_NET_VENDOR_CIRRUS=n CONFIG_NET_VENDOR_CISCO=n CONFIG_NET_VENDOR_DEC=n CONFIG_NET_VENDOR_DLINK=n CONFIG_NET_VENDOR_EMULEX=n CONFIG_NET_VENDOR_EZCHIP=n CONFIG_NET_VENDOR_EXAR=n CONFIG_NET_VENDOR_FARADAY=n CONFIG_NET_VENDOR_HISILICON=n CONFIG_NET_VENDOR_HP=n CONFIG_IGB=n CONFIG_NET_VENDOR_I825XX=n CONFIG_NET_VENDOR_MELLANOX=n CONFIG_NET_VENDOR_MICROCHIP=n CONFIG_NET_VENDOR_MYRI=n CONFIG_NET_VENDOR_NATSEMI=n CONFIG_NET_VENDOR_NETRONOME=n CONFIG_NET_VENDOR_NVIDIA=n CONFIG_NET_VENDOR_OKI=n CONFIG_NET_VENDOR_8390=n CONFIG_NET_VENDOR_QLOGIC=n CONFIG_NET_VENDOR_QUALCOMM=n CONFIG_NET_VENDOR_REALTEK=n CONFIG_NET_VENDOR_RENESAS=n CONFIG_NET_VENDOR_RDC=n CONFIG_NET_VENDOR_ROCKER=n CONFIG_NET_VENDOR_SAMSUNG=n CONFIG_NET_VENDOR_SILAN=n CONFIG_NET_VENDOR_SIS=n CONFIG_NET_VENDOR_SEEQ=n CONFIG_NET_VENDOR_STMICRO=n CONFIG_NET_VENDOR_SUN=n CONFIG_NET_VENDOR_SYNOPSYS=n CONFIG_NET_VENDOR_TEHUTI=n CONFIG_NET_VENDOR_VIA=n CONFIG_NET_VENDOR_WIZNET=n #Wireless LAN CONFIG_WLCORE=m CONFIG_WLCORE_SDIO=m CONFIG_WL18XX=m #MDIO phys CONFIG_MARVELL_PHY=y CONFIG_MICREL_PHY=y # unused PHY drivers CONFIG_BROADCOM_PHY=n CONFIG_ICPLUS_PHY=n #PRU MII PHYs for Industrial Boards CONFIG_DP83848_PHY=y # Enable phy for DRA72 evm CONFIG_DP83867_PHY=y #MTD CONFIG_OMAP_GPMC=y CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_OMAP_BCH=y CONFIG_MTD_NAND_OMAP_BCH_BUILD=y CONFIG_MTD_TESTS=m CONFIG_MTD_CMDLINE_PARTS=y #PCIE CONFIG_PCI=y CONFIG_PCI_ENDPOINT=y CONFIG_PCI_ENDPOINT_CONFIGFS=y CONFIG_PCI_EPF_TEST=y CONFIG_PCI_ENDPOINT_TEST=m CONFIG_PCI_DRA7XX=y CONFIG_PCI_DRA7XX_HOST=y CONFIG_PCI_DRA7XX_EP=y CONFIG_PCI_KEYSTONE_EP=y #These drivers have been used with DRA7x/AM57x PCIe RC with some success CONFIG_NET_VENDOR_BROADCOM=y CONFIG_NET_VENDOR_MARVELL=y CONFIG_NET_VENDOR_INTEL=y CONFIG_TIGON3=m CONFIG_SKGE=m CONFIG_E1000=m CONFIG_E1000E=m CONFIG_IWLWIFI=m CONFIG_IWLDVM=m CONFIG_IWLMVM=m #Generic Phys CONFIG_PHY_TI_KEYSTONE_SERDES=y # Networking CONFIG_HSR_PRP=y CONFIG_NF_CONNTRACK=m CONFIG_NF_CONNTRACK_IPV4=m CONFIG_IP_NF_IPTABLES=m CONFIG_IP_NF_ARPTABLES=m CONFIG_IP_NF_ARPFILTER=m CONFIG_IP_NF_ARP_MANGLE=m CONFIG_IP_NF_FILTER=m CONFIG_IP_NF_NAT=m CONFIG_NF_NAT_IPV4=m CONFIG_IP_NF_TARGET_MASQUERADE=m CONFIG_BRIDGE=m CONFIG_XFRM_USER=m CONFIG_NET_KEY=m CONFIG_INET=y CONFIG_INET_AH=m CONFIG_INET6_AH=m CONFIG_INET6_IPCOMP=m CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m CONFIG_INET_ESP=m CONFIG_INET_IPCOMP=m CONFIG_INET_XFRM_MODE_TRANSPORT=m CONFIG_INET_XFRM_MODE_TUNNEL=m CONFIG_INET_XFRM_MODE_BEET=m CONFIG_IPV6_TUNNEL=m CONFIG_NETFILTER=y CONFIG_NETFILTER_XTABLES=m CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m CONFIG_NETFILTER_XT_TARGET_MARK=m CONFIG_NETFILTER_XT_MATCH_COMMENT=m CONFIG_NETFILTER_XT_MATCH_CPU=m CONFIG_NETFILTER_XT_MATCH_IPRANGE=m CONFIG_NETFILTER_XT_MATCH_LENGTH=m CONFIG_NETFILTER_XT_MATCH_LIMIT=m CONFIG_NETFILTER_XT_MATCH_MAC=m CONFIG_NETFILTER_XT_MATCH_MARK=m CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m CONFIG_NETFILTER_XT_MATCH_POLICY=m CONFIG_NETFILTER_XT_MATCH_SCTP=m CONFIG_BRIDGE_NF_EBTABLES=m CONFIG_BRIDGE_EBT_BROUTE=m CONFIG_BRIDGE_EBT_T_FILTER=m CONFIG_BRIDGE_EBT_T_NAT=m CONFIG_BRIDGE_EBT_802_3=m CONFIG_BRIDGE_EBT_AMONG=m CONFIG_BRIDGE_EBT_ARP=m CONFIG_BRIDGE_EBT_IP=m CONFIG_BRIDGE_EBT_IP6=m CONFIG_BRIDGE_EBT_LIMIT=m CONFIG_BRIDGE_EBT_MARK=m CONFIG_BRIDGE_EBT_PKTTYPE=m CONFIG_BRIDGE_EBT_STP=m CONFIG_BRIDGE_EBT_VLAN=m CONFIG_BRIDGE_EBT_ARPREPLY=m CONFIG_BRIDGE_EBT_DNAT=m CONFIG_BRIDGE_EBT_MARK_T=m CONFIG_BRIDGE_EBT_REDIRECT=m CONFIG_BRIDGE_EBT_SNAT=m CONFIG_BRIDGE_EBT_LOG=m CONFIG_BRIDGE_EBT_NFLOG=m CONFIG_NET_SCHED=y CONFIG_NET_SCH_CBQ=m CONFIG_NET_SCH_HTB=m CONFIG_NET_SCH_HFSC=m CONFIG_NET_SCH_PRIO=m CONFIG_NET_SCH_MULTIQ=m CONFIG_NET_SCH_RED=m CONFIG_NET_SCH_SFB=m CONFIG_NET_SCH_SFQ=m CONFIG_NET_SCH_TEQL=m CONFIG_NET_SCH_TBF=m CONFIG_NET_SCH_GRED=m CONFIG_NET_SCH_DSMARK=m CONFIG_NET_SCH_NETEM=m CONFIG_NET_SCH_DRR=m CONFIG_NET_SCH_MQPRIO=m CONFIG_NET_SCH_CHOKE=m CONFIG_NET_SCH_QFQ=m CONFIG_NET_SCH_CODEL=m CONFIG_NET_SCH_FQ_CODEL=m CONFIG_NET_SCH_INGRESS=m CONFIG_NET_CLS=y CONFIG_NET_CLS_BASIC=m CONFIG_NET_CLS_TCINDEX=m CONFIG_NET_CLS_ROUTE4=m CONFIG_NET_CLS_FW=m CONFIG_NET_CLS_U32=m CONFIG_CLS_U32_MARK=y CONFIG_NET_CLS_RSVP=m CONFIG_NET_CLS_RSVP6=m CONFIG_NET_CLS_FLOW=m CONFIG_NET_EMATCH=y CONFIG_NET_EMATCH_STACK=32 CONFIG_NET_EMATCH_CMP=m CONFIG_NET_EMATCH_NBYTE=m CONFIG_NET_EMATCH_U32=m CONFIG_NET_EMATCH_META=m CONFIG_NET_EMATCH_TEXT=m CONFIG_NET_CLS_ACT=y CONFIG_NET_ACT_POLICE=m CONFIG_NET_ACT_GACT=m CONFIG_GACT_PROB=y CONFIG_NET_ACT_MIRRED=m CONFIG_NET_ACT_IPT=m CONFIG_NET_ACT_NAT=m CONFIG_NET_ACT_PEDIT=m CONFIG_NET_ACT_SIMP=m CONFIG_NET_ACT_SKBEDIT=m CONFIG_NET_ACT_CSUM=m CONFIG_NET_CLS_IND=y CONFIG_NET_SCH_FIFO=y CONFIG_IP_SCTP=m CONFIG_VLAN_8021Q=m CONFIG_IP_MULTICAST=y #PRUSS Ethernet driver CONFIG_TI_PRUETH=m #MMC/SD support CONFIG_MMC=y CONFIG_MMC_SDHCI=n CONFIG_MMC_SDHCI_PLTFM=n CONFIG_MMC_OMAP_HS=n CONFIG_MMC_SDHCI_OMAP=n CONFIG_MMC_DW=n #SPI CONFIG_SPI_CADENCE_QUADSPI=y CONFIG_SPI_TI_QSPI=y #Disable unused SPI controllers CONFIG_SPI_BITBANG=n CONFIG_SPI_CADENCE=n CONFIG_SPI_ROCKCHIP=n CONFIG_SPI_XILINX=n CONFIG_SPI_SPIDEV=n #Disable SPI NOR 4K SECTORS CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=n #SPI GPIO expanders CONFIG_GPIO_PISOSR=m #SATA CONFIG_SATA_AHCI_PLATFORM=m CONFIG_SATA_AHCI=m CONFIG_ATA=m #USB gadgets CONFIG_USB_GADGET=m CONFIG_USB_AUDIO=m CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y CONFIG_USB_G_NCM=m CONFIG_USB_GADGETFS=m CONFIG_USB_FUNCTIONFS=m CONFIG_USB_FUNCTIONFS_ETH=y CONFIG_USB_FUNCTIONFS_RNDIS=y CONFIG_USB_FUNCTIONFS_GENERIC=y CONFIG_USB_MASS_STORAGE=m CONFIG_USB_G_SERIAL=m CONFIG_USB_MIDI_GADGET=m CONFIG_USB_G_PRINTER=m CONFIG_USB_CDC_COMPOSITE=m CONFIG_USB_G_ACM_MS=m CONFIG_USB_G_MULTI=m CONFIG_USB_G_MULTI_CDC=y CONFIG_USB_G_HID=m CONFIG_USB_G_DBGP=m CONFIG_USB_G_WEBCAM=m CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32 CONFIG_USB_ZERO=m CONFIG_USB_CONFIGFS=m CONFIG_USB_CONFIGFS_SERIAL=y CONFIG_USB_CONFIGFS_ACM=y CONFIG_USB_CONFIGFS_OBEX=y CONFIG_USB_CONFIGFS_NCM=y CONFIG_USB_CONFIGFS_ECM=y CONFIG_USB_CONFIGFS_ECM_SUBSET=y CONFIG_USB_CONFIGFS_RNDIS=y CONFIG_USB_CONFIGFS_EEM=y CONFIG_USB_CONFIGFS_MASS_STORAGE=y CONFIG_USB_CONFIGFS_F_LB_SS=y CONFIG_USB_CONFIGFS_F_FS=y CONFIG_USB_CONFIGFS_F_UAC1=y CONFIG_USB_CONFIGFS_F_UAC2=y CONFIG_USB_CONFIGFS_F_MIDI=y CONFIG_USB_CONFIGFS_F_HID=y CONFIG_USB_CONFIGFS_F_UVC=y CONFIG_USB_CONFIGFS_F_PRINTER=y # USB DWC3 CONFIG_USB_DWC3=m CONFIG_USB_DWC3_DUAL_ROLE=y CONFIG_USB_DWC3_OMAP=m CONFIG_USB_DWC3_PCI=n CONFIG_USB_DWC2=n CONFIG_USB_CHIPIDEA=n #USB PHY CONFIG_NOP_USB_XCEIV=m #USB MUSB CONFIG_USB_MUSB_HDRC=m CONFIG_USB_MUSB_DUAL_ROLE=y CONFIG_USB_MUSB_OMAP2PLUS=m CONFIG_USB_MUSB_AM35X=m CONFIG_USB_MUSB_DSPS=m CONFIG_USB_MUSB_AM335X_CHILD=m CONFIG_TI_CPPI41=y CONFIG_USB_TI_CPPI41_DMA=y CONFIG_AM335X_CONTROL_USB=y CONFIG_AM335X_PHY_USB=y #USB EHCI CONFIG_USB=m CONFIG_USB_EHCI_HCD=m CONFIG_USB_EHCI_PCI=m CONFIG_USB_EHCI_HCD_OMAP=m #USB Networking CONFIG_USB_USBNET=m CONFIG_USB_NET_DRIVERS=m CONFIG_USB_NET_SMSC95XX=m #USB testing CONFIG_USB_TEST=m #USB Serial CONFIG_USB_ACM=m CONFIG_USB_SERIAL=m # Extcon drivers CONFIG_EXTCON=m CONFIG_EXTCON_PALMAS=m CONFIG_EXTCON_USB_GPIO=m # PWM CONFIG_PWM_TIECAP=n CONFIG_PWM_TIEHRPWM=n CONFIG_PWM_TIPWMSS=n # 1-wire Bus Masters CONFIG_W1=m CONFIG_HDQ_MASTER_OMAP=m # Matrix keypad CONFIG_KEYBOARD_MATRIX=m #Touchscreen/ADC CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m CONFIG_TI_AM335X_ADC=m #CAN CONFIG_CAN=m CONFIG_CAN_C_CAN=m CONFIG_CAN_C_CAN_PLATFORM=m CONFIG_CAN_M_CAN=m # Rotary Encoder CONFIG_INPUT_GPIO_DECODER=m # Filesystem extra options CONFIG_EXT4_FS_POSIX_ACL=y CONFIG_EXT4_FS_SECURITY=y CONFIG_CIFS=m CONFIG_CIFS_STATS=y CONFIG_CIFS_XATTR=y CONFIG_CIFS_POSIX=y CONFIG_CIFS_ACL=y ################################################## # TI Audio/Display config options ################################################## CONFIG_CMA_SIZE_MBYTES=24 # backlight CONFIG_LEDS_CLASS=y CONFIG_LEDS_TLC591XX=y CONFIG_BACKLIGHT_PWM=n CONFIG_BACKLIGHT_GPIO=y CONFIG_BACKLIGHT_LED=y # fbdev CONFIG_FB_SSD1307=y # drm CONFIG_DRM=y # SGX driver needs legacy support CONFIG_DRM_LEGACY=y CONFIG_DRM_VM=y # Disable unneeded features CONFIG_VGA_ARB=n CONFIG_DRM_I2C_ADV7511=n CONFIG_DRM_NOUVEAU=n CONFIG_DRM_EXYNOS=n CONFIG_DRM_PANEL_SIMPLE=n CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0=n CONFIG_DRM_NXP_PTN3460=n CONFIG_DRM_PARADE_PS8622=n CONFIG_DRM_STI=n CONFIG_LCD_CLASS_DEVICE=n # tilcdc CONFIG_DRM_I2C_NXP_TDA998X=y CONFIG_DRM_TILCDC=y # omapdrm CONFIG_DRM_OMAP=y CONFIG_DRM_OMAP_WB=y CONFIG_OMAP2_DSS=y CONFIG_OMAP2_DSS_DEBUGFS=y CONFIG_OMAP2_DSS_DPI=y CONFIG_OMAP2_DSS_VENC=n CONFIG_OMAP4_DSS_HDMI=y CONFIG_OMAP5_DSS_HDMI=y CONFIG_OMAP2_DSS_SDI=n CONFIG_OMAP2_DSS_DSI=n CONFIG_TI_DSS6=y CONFIG_DRM_OMAP_PANEL_DPI=y CONFIG_DRM_OMAP_CONNECTOR_HDMI=y CONFIG_DRM_OMAP_CONNECTOR_DVI=y CONFIG_DRM_OMAP_DRA7EVM_ENCODER_TPD12S015=y CONFIG_DRM_OMAP_ENCODER_TPD12S015=y CONFIG_DRM_OMAP_ENCODER_SII9022=y CONFIG_DRM_OMAP_ENCODER_TC358768=y CONFIG_DRM_OMAP_ENCODER_TFP410=y # sound CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_SOC=y CONFIG_SND_OMAP_SOC=y CONFIG_SND_EDMA_SOC=y CONFIG_SND_DAVINCI_SOC_MCASP=y CONFIG_SND_AM33XX_SOC_EVM=m CONFIG_SND_SIMPLE_CARD=m CONFIG_SND_SOC_TLV320AIC31XX=m CONFIG_SND_SOC_TLV320AIC3X=m CONFIG_SND_SOC_HDMI_CODEC=m CONFIG_SND_OMAP_SOC_HDMI_AUDIO=m # Disable what we don't want in our config CONFIG_SND_ARM=n CONFIG_SND_SPI=n CONFIG_SND_PCI=n CONFIG_SND_ATMEL_SOC=n CONFIG_SND_SOC_FSL_SAI=n CONFIG_SND_OMAP_SOC_OMAP3_PANDORA=n CONFIG_SND_SOC_AK4642=n CONFIG_SND_SOC_SGTL5000=n CONFIG_SND_SOC_STI_SAS=n CONFIG_SND_SOC_WM8978=n # v4l2 CONFIG_MEDIA_SUPPORT=y CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_V4L_PLATFORM_DRIVERS=y CONFIG_VIDEO_AM437X_VPFE=m CONFIG_VIDEO_TI_CAL=m CONFIG_VIDEO_TI_VIP=m CONFIG_V4L_MEM2MEM_DRIVERS=y CONFIG_VIDEO_TI_VPE=m CONFIG_MEDIA_SUBDRV_AUTOSELECT=n CONFIG_VIDEO_OV2659=m CONFIG_VIDEO_OV1063X=m CONFIG_VIDEO_MT9T11X=m CONFIG_GPIO_PCA953X=m CONFIG_VIDEO_OV490=m CONFIG_MEDIA_USB_SUPPORT=y CONFIG_USB_VIDEO_CLASS=m CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # Touchscreen CONFIG_TOUCHSCREEN_EDT_FT5X06=m CONFIG_TOUCHSCREEN_PIXCIR=m CONFIG_TOUCHSCREEN_GOODIX=m CONFIG_HID_MULTITOUCH=m ################################################## # TI Base OMAP generation SoCs generic default ################################################## CONFIG_KEYSTONE2_DMA_COHERENT=n CONFIG_ARCH_OMAP=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP_INTERCONNECT_BARRIER=y CONFIG_ARM_PSCI=n # Maximum Number of processors CONFIG_NR_CPUS=2 # Kexec CONFIG_KEXEC=y # EDAC CONFIG_EDAC=y CONFIG_EDAC_TI=m ################################################## # TI DRA7 specific config options ################################################## # Supported ARM CPUs CONFIG_ARCH_MULTI_V6=n CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=n CONFIG_CPU_V6=n # Enable CONFIG_SMP CONFIG_SMP=y # Disable Socs other than DRA7 CONFIG_ARCH_OMAP2=n CONFIG_ARCH_OMAP3=n CONFIG_ARCH_OMAP4=n CONFIG_SOC_OMAP5=n CONFIG_SOC_AM33XX=n CONFIG_SOC_AM43XX=n CONFIG_SOC_DRA7XX=y CONFIG_ARCH_KEYSTONE=n CONFIG_ARM_LPAE=y CONFIG_TI_PTP_BC=y CONFIG_TI_1PPS_DM_TIMER=y ################################################## # Real Time Linux Configs ################################################## CONFIG_PREEMPT=y CONFIG_PREEMPT_RT_BASE=y CONFIG_PREEMPT_RT_FULL=y #Disable PM features CONFIG_CPU_IDLE=n CONFIG_CPU_FREQ=n CONFIG_SUSPEND=n CONFIG_HOTPLUG_CPU=y # SCHED_DEBUG provides a lot of additional options for scheduler # tuning in /proc/sys/kernel/ and allows to see scheduler statistic in # /proc/sched_debug # CONFIG_SCHED_DEBUG # --- RCU optimization options to reduce OS jitter # RCU_BOOST : This option boosts the priority of preempted RCU readers that # block the current preemptible RCU grace period for too long. # This option also prevents heavy loads from blocking RCU # callback invocation for all flavors of RCU # CONFIG_RCU_BOOST=n # RCU_NOCB_CPU : Use this option to reduce OS jitter for aggressive HPC or # real-time workloads. It can also be used to offload RCU # callback invocation to energy-efficient CPUs in battery-powered # asymmetric multiprocessors. # CONFIG_RCU_NOCB_CPU=y # RCU_NOCB_CPU_ALL: his option forces all CPUs to be no-CBs CPUs. # The rcu_nocbs= boot parameter will be ignored. All CPUs' RCU callbacks will # be executed in the context of per-CPU rcuo kthreads created for # this purpose. # CONFIG_RCU_NOCB_CPU_ALL=y ############################################## # # Kernel options needed for systemd enabled TI SDKs # See https://cgit.freedesktop.org/systemd/systemd/tree/README#n38 for details # ############################################## CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_CGROUPS=y CONFIG_CGROUP_FREEZER=y CONFIG_CGROUP_DEVICE=y CONFIG_CGROUP_CPUACCT=y CONFIG_BLK_CGROUP=y CONFIG_CGROUP_PIDS=y CONFIG_CGROUP_PERF=y CONFIG_INOTIFY_USER=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EPOLL=y CONFIG_NET=y CONFIG_SYSFS=y CONFIG_PROC_FS=y CONFIG_FHANDLE=y # udev will fail to work with the legacy sysfs layout: CONFIG_SYSFS_DEPRECATED=n # Legacy hotplug slows down the system and confuses udev: CONFIG_UEVENT_HELPER_PATH="" # Userspace firmware loading is not supported and should # be disabled in the kernel: CONFIG_FW_LOADER_USER_HELPER=n # Some udev rules and virtualization detection relies on it: # Only for UEFI based systems # http://cateee.net/lkddb/web-lkddb/DMI.html CONFIG_DMIID=n # Support for some SCSI devices serial number retrieval, to # create additional symlinks in /dev/disk/ and /dev/tape: CONFIG_BLK_DEV_BSG=y # Required for PrivateNetwork and PrivateDevices in service units: # Note that systemd-localed.service and other systemd units use # PrivateNetwork and PrivateDevices so this is effectively required. CONFIG_NAMESPACES=y CONFIG_NET_NS=y CONFIG_DEVPTS_MULTIPLE_INSTANCES=y # Optional but strongly recommended options: those are nice to have and # indeed recommended, but not necessarily systemd required. These to be # enabled in corresponding domain fragments since they are not specific # to supporting systemd. CONFIG_SECCOMP=y # for kcmp syscall CONFIG_CHECKPOINT_RESTORE=y # Required for CPUShares= in resource control unit settings CONFIG_CGROUP_SCHED=y CONFIG_FAIR_GROUP_SCHED=y # Required for CPUQuota= in resource control unit settings CONFIG_CFS_BANDWIDTH=y # For systemd-bootchart, several proc debug interfaces are required: # Systemd-debug.cfg? CONFIG_SCHEDSTATS=y CONFIG_SCHED_DEBUG=y # We recommend to turn off Real-Time group scheduling in the # kernel when using systemd. RT group scheduling effectively # makes RT scheduling unavailable for most userspace, since it # requires explicit assignment of RT budgets to each unit whose # processes making use of RT. As there's no sensible way to # assign these budgets automatically this cannot really be # fixed, and it's best to disable group scheduling hence. CONFIG_RT_GROUP_SCHED=n # Note that kernel auditing is broken when used with systemd's # container code. When using systemd in conjunction with # containers, please make sure to either turn off auditing at # runtime using the kernel command line option "audit=0", or # turn it off at kernel compile time using: CONFIG_AUDIT=n
