Part Number: TDA2
Hi there,
I have installed vision sdk using PROCESSOR_SDK_VISION_03_00_00_00_setuplinux.bin. My compile host machine is win10.
I compiled visionSDK follow "visionsdk userguide tda2xx.pdf":
MAKECONFIG=tda2xx_evm_rtos_all
make -s depend;
make -s;
They all run successfully. And then I want to compile the other compents of visionSDK, so i execute :
make -s all,
the i get these errors:
$ gmake -s all
process_begin: CreateProcess(NULL, s gmake -fMAKEFILE.MK -CE:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/src/rtos/alg_plugins clean, ...) failed.
make (e=2): ϵͳ▒Ҳ▒▒▒ָ▒▒▒▒▒ļ▒▒▒
/cygdrive/e/PROCESSOR_SDK_VISION_03_05_00_00/ti_components/os_tools/windows/xdctools_3_32_01_22_core/bin/cat: E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/l
# Compiling tda2xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
"algorithmLink_cfg.c", line 79: fatal error: cannot open source file "system_cfg.h"
1 catastrophic error detected in the compilation of "algorithmLink_cfg.c".
Compilation terminated.
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/ipu1_0/release/algorithmLink_cfg.oem4] Error 1
gmake[6]: *** [ipu1_0] Error 2
# Compiling tda2xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/ipu1_1/release/algorithmLink_cfg.oem4] Error 1
gmake[6]: *** [ipu1_1] Error 2
# Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:ipu2:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/ipu2/release/algorithmLink_cfg.oem4] Error 1
gmake[6]: *** [ipu2] Error 2
# Compiling tda2xx-evm:a15_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:a15_0:release:links_common_algorithm: algorithmLink_cfg.c
algorithmLink_cfg.c:79:24: fatal error: system_cfg.h: No such file or directory
#include <system_cfg.h>
compilation terminated.
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/a15_0/release/algorithmLink_cfg.oa15fg] Error 1
gmake[6]: *** [a15_0] Error 2
# Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
"algorithmLink_cfg.c", line 79: fatal error: could not open source file "system_cfg.h"
1 fatal error detected in the compilation of "algorithmLink_cfg.c".
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/c66xdsp_1/release/algorithmLink_cfg.oe66] Error 1
gmake[6]: *** [c66xdsp_1] Error 2
# Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/c66xdsp_2/release/algorithmLink_cfg.oe66] Error 1
gmake[6]: *** [c66xdsp_2] Error 2
# Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/arp32_1/release/algorithmLink_cfg.oearp32F] Error 1
gmake[6]: *** [arp32_1] Error 2
# Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:arp32_2:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/arp32_2/release/algorithmLink_cfg.oearp32F] Error 1
gmake[6]: *** [arp32_2] Error 2
# Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:arp32_3:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/arp32_3/release/algorithmLink_cfg.oearp32F] Error 1
gmake[6]: *** [arp32_3] Error 2
# Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2xx-evm:arp32_4:release:links_common_algorithm: algorithmLink_cfg.c
>> Compilation failure
gmake[7]: *** [E:/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/binaries/apps/tda2xx_evm_bios_all/obj/links_common_algorithm/tda2xx-evm/arp32_4/release/algorithmLink_cfg.oearp32F] Error 1
gmake[6]: *** [arp32_4] Error 2
gmake[5]: *** [links_common_algorithm] Error 2
gmake[4]: *** [libs] Error 2
gmake[3]: *** [links_fw_libs] Error 2
gmake[2]: *** [apps] Error 2
gmake[1]: *** [vision_sdk] Error 2
gmake: *** [all] Error 2
so, what can i do to fix this?\
Thanks!
