TDA3XEVM: TIDL Import tool
Part Number: TDA3XEVM
I'm facing the same issue with tidl import tool.May I know the solution to fix this.
Please find the bellow attached error.
TF Model File : D:\TIDL\pb0192\mobilenet_v1_0.50_192_final.pb
Could not find the requested input Data : MobilenetV1/MobilenetV1/Conv2d_0/Relu6
Thanks for your support in advance
Anil
  • Hi Anil,
    Which version of TIDL release you are using? TIDL 01.01.02.00 is the latest release, please use this release if you are not using it already.
    Also, please share complete import tool console log for review.
    Praveen
  • Hi Praveen,
    Currently I'm using TIDL 01.01.01.00.
    We are trying to import mobilenet model using TIDL import. We get the following error:
    tidl_model_import.out D:\TIDL\modules\ti_dl\test\testvecs\config\import\tidl_import_mobileNet1.txt > tidl_log.txt
    We get the following error lines in tidl_log.txt
    Anil
  • Hi Praveen,
    I'm trying to download the newer version of TIDL but I didn't get it.Can you please share the TIDL new version for windows?
    Anil
  • Hi Anil,
    Can you try from this link - www.ti.com/.../PROCESSOR-SDK-TDAX
    TIDL releases are part of TI’s processor software development (SDK) for vision. So, the latest TIDL release will be part of VSDK 3.5 release.
    Also, can you share the tidl_log.txt file from import tool?
    Praveen
  • TF Model File : ..\..\test\testvecs\config\tensorflow_models\mobilenet\mobilenet_1_224.pb
    Could not find the requested input Data : MobilenetV1/MobilenetV1/Conv2d_0/Relu6 !!
    Hi Praveen,
    Please find the attached log file with tidl import tool error.
    Anil
  • Hi Anil,
    This error is because of not having support for Relu6 in tensor flow import tool, but TIDL library has support for Relu6.
    So, you can modify tf import tool to import this Relu6 layer as the import tool source code is publicly available. You can refer to other layers import functions to do this.
    Praveen
