Other Parts Discussed in Thread: CCSTUDIO
Hi, I want to measure the interrupt latency of my code.I thought of using the "C6000 Interrupt Latency Detection Feature on the Simulator" available in CCS. I am using 'C64x+ Cycle Accurate Simulator, Little Endian' on CCS v3.3.38.2.I see that this feature is not supported on this simulator (driver cfg file – simc64plus.cfg).I am referring to a document 'ug_interrupt_latency_c64plus.doc' obtained with CCS v3.3 for the procedure. There is nothing mentioned about the simulator types on which this feature is supported. Please let me know if this feature is supported only on particular simulators or I need to install anything else to use this feature on my simulator.Also, is there a way to measure the interrupt latency of my code on Codec Engine framework? If so, please share the information. Awaiting your response.Thanks & regards,Akshatha
