Questionable disparity computation performance using VLIB?
Hi Gagan (or someone whoever can answer),
I've waited for another reply for a week, still waiting for a reply to my additional comments.
Regarding your questioins,
* What device are you using?
    =>  We obtained the results using PC (Windows XP), but eventually targeting at C6748 EVM.
* What version of library are you using?
    =>  We are using VLIB 2.1
* Did you run the example out of the box or did you do any modification?
    => We changed only some parameters, such as WINDOW_SIZE and BLOCK_SIZE
         for tests.
* What do you mean when you say results are not good?
   => We hope that the disparity map will be a decent result, but the results from using
        the example "VLIB_testDisparity8" were not good (for a variety of parameters).
        The disparity map has big white spots (probably due to using signed char for the disparity?),
         as well as unknown bar-like artifacts (probably due to using block-wise data-reading?).
        It would be nice to have a description about the "VLIB_testDisparity8" test esample.
