I am using TIDL 01.01.00.00 for importing tensorflow model as per mentioned in the TIDL User guide.
I have downloaded MobileNet v1 and MobileNet v2 (.tgz file containing checkpoints as well as frozen pb graph) from the given link : https://github.com/tensorflow/models/tree/master/research/slim
As graph is already frozen, I just ran "tensorflow\python\tools\optimize_for_inference.py" and got the final pb file.
From TIDL User Guide , I understood that MobileNet v1 is validated and I also want to check whether I am able to import MobileNet v1 and generate NET.BIN and PARAM.BIN.
But, Import Tool is giving some error
> Could not find the requested input Data : MobilenetV1/MobilenetV1/Conv2d_0/Relu6 !!
I came across the same query in e2e forum . and solution for this is to modify TIDL Import Tool / tidl_tfImport.cpp file. But, I do not know the exact changes ? Which function to add or modify ? It will be helpful for me if you tell exactly which file to modify and location?
Also after above changes , If i am able to import MobileNet v1, Can i assume MobileNet v2 will also be able to import ?
Have you validated MobileNet v2 on any TILD Version ?
Sagar
