Part Number: TDA2PXEVM
I am Terence Xia who is trying to use early boot and late attach functionality in TDA2PXEVM. When I apply the earlyboot-kernel-patches for kernel that refer to section 3.4 in VisionSDK_Linux_UserGuide.pdf. There is a issue that print the following log. Could you help to have a look?
root@ubuntu:/home/xcj/share/branch_kc-2/ti_components/os_tools/linux/kernel/omap# git am ../linux-kernel-addon/earlyboot-kernel-patches/*
Applying: dra7xx: Kernel Optimizations for early-use-case enablement
error: arch/arm/boot/dts/dra7-evm.dts: does not exist in index
error: arch/arm/boot/dts/dra7.dtsi: does not exist in index
error: arch/arm/kernel/setup.c: does not exist in index
error: arch/arm/mach-omap2/Makefile: does not exist in index
error: arch/arm/mach-omap2/omap4-common.c: does not exist in index
error: arch/arm/mach-omap2/omap_hwmod.c: does not exist in index
error: init/do_mounts.c: does not exist in index
error: init/main.c: does not exist in index
error: ti_config_fragments/auto.cfg: does not exist in index
error: ti_config_fragments/defconfig_map.txt: does not exist in index
Patch failed at 0001 dra7xx: Kernel Optimizations for early-use-case enablement
The copy of the patch that failed is found in:
/home/xcj/share/branch_kc-2/.git/rebase-apply/patch
Thank you very much
Terence Xia
