something wrong between <std.h> and <xdc/std.h>
I would like to know if have some configuration in build options for differ the includes <std.h> and <xdc/std.h>?
I am having problem with it.
I am using dm6437 and ccsV3.3.
Thank you.
  • You could adjust which file you actually use by changing your search paths in your CCS build options, or you could explicitly put the entire path in your C file to get an exact header without dealing with search paths.
     I imagine you are getting some sort of build errors? If you could post the errors you are getting it may help in finding a solution quicker, assuming adjusting your search paths does not fix it immediately.
