IEP will be used to capture the external signal.
To send the interrupt signal to R5 core by this external signal, IPC mechanism from PRU to R5F should be used.
Is it correct?
HaTa.
Is it correct?
HaTa.
Hello HaTa,
EDIT: I believe PRU to R5F flows through a network low-level driver instead of IPC. I will loop in the correct expert. Please mark this as unresolved.
