Can the DM647 PCI interface be a host?
Can the DM647 device be a host PCI device?? If not is there another device that can and also have a GigE port??
-Tom-
  • It looks like the DM6467T has PCI Host capability, BUT this part shares pins between PCI and EMIF busses. Is there something that has separate PCI and EMIF busses and can act as a PCI host?
  • Tom,
    Yes, the DM647 PCI peripheral can act as a PCI bus master, according to the DM647 datasheet.
    Brad
  • Does PCI bus master equate to a PCI - Host??
    -Tom-
    Tom,
    You are correct.  Being a PCI Host encompasses more than just being a PCI bus master.  SPRU581 describes how the DSP can be a PCI host, along with several limitations.  I've reproduced the applicable text from that document below.
    Brad
    8.3 DSP as System Host
    The PCI port can perform master configuration cycles regardless of the master
    bit setting in the PCI configuration registers. Also, the internal slave and master
    can run concurrently, allowing the DSP to read and write its own configuration
    registers over the PCI bus. These capabilities allow the PCI port to act as a
    system host by configuring itself and the rest of the PCI bus. This is subject
    to the following limitations:
    -IDSELs must be under DSP control.
    -There is just one PCI bus segment, that is, the DSP cannot generate type 1 configuration cycles.
    -External logic to arbitrate the bus.
    8.3.1 Generating IDSEL
    To properly configure the bus, the DSP must be able to assert the IDSEL line
    of each device at the appropriate time. The PCI interface does not directly
    provide for this; it must be accomplished by indirect means. The following
    sections provide two different procedures to generate IDSEL.
    8.3.1.1 Resistively Coupled IDSEL
    Resistively coupling IDSEL is a common and easy method of generating
    IDSELs; however, you must be careful to adhere to PCI specification with this
    method. Using coupled IDSELs requires the host to step the address phase
    onto the bus to allow IDSEL sufficient time to propagate to the target device.
    The PCI interface does not do address stepping. The compact nature of most
    systems where the DSP is the host should allow for a functional coupling
    without address stepping. Regardless, it is your responsibility to ensure the
    IDSEL signal propagates through the resistive coupling in time to meet PCI’s
    timing specification.
    When using resistive coupling for IDSEL generation, the procedure to read or
    write a configuration word is as follows:
    1) Set PCIMA:
    a) PCIMA[31−11] = one bit set to select appropriate device’s IDSEL
    (important: only one bit should be set at a time)
    b) PCIMA[10−8] = device function to be addressed
    c) PCIMA[7−0] = 32-bit configuration word address (See PCI
    specification for type 0 configuration access details)
    2) Set DSPMA to point to a local buffer (buffer contains source data for writes,
    space for data for reads)
    3) Set PCIMC for 4 bytes, desired function
    4) Poll for START==0 or wait for MASTEROK interrupt
    8.3.1.2 GPIO Generated IDSEL
    An alternate and fully-compliant method of generating IDSEL is to attach the
    IDSEL lines to GPIO pins and control them directly. The procedure is only
    slightly different from above:
    1) Set GPIO to enable one IDSEL only (important: only one IDSEL should be
    enabled at a time) You should read back new values written to GPIO pins
    to avoid race conditions.
    2) Set PCIMA:
    a) PCIMA[11−8] = device function to be addressed
    b) PCIMA[7−0] = 32-bit configuration word address (See PCI
    3) Set DSPMA to point to a local buffer (buffer contains source data for writes,
    4) Set PCIMC for 4 bytes, desired function
    5) Poll for START==0 or wait for MASTEROK interrupt
    6) Set GPIO to turn off IDSEL
  • Tom,
    It turns out that these instructions have to be updated in a few places in order to apply to the DM647.  We'll post the requried changes to the above procedure ASAP.
    Brad
  • Brad,
    Thanks, PLEASE post the info on the DM647 because it looks as though that will be targeted.
    -Tom-
  • Tom,
    Here is the text, updated for DM648/7.
    Brad
    _ IDSELs must be under DSP control.
    _ There is just one PCI bus segment, that is, the DSP cannot generate
    _ External logic to arbitrate the bus.
    1) For writes, load the data value in PCIMCFGDAT. For reads, skip this step.
    2) Set PCIMCFGADR:
    a) PCIMCFGADR [31−11] = one bit set to select appropriate device’s IDSEL
    b) PCIMCFGADR [10−8] = device function to be addressed
    c) PCIMCFGADR [7−0] = 32-bit configuration word address (See PCI
    3) Use PCIMCFGCMD to initiate a single read/write configuration access.
    4) Poll for READY==1 to ensure the configuration access is complete
    5) For reads, read the received data from PCIMCFGDAT.
    2) For writes, load the data value in PCIMCFGDAT. For reads, skip this step.
    3) Set PCIMA:
    a) PCIMCFGADR[11−8] = device function to be addressed
    b) PCIMCFGADR [7−0] = 32-bit configuration word address (See PCI
    4) Use PCIMCFGCMD to initiate a single read/write configuration access.
    5) Poll for READY==1 to ensure the configuration access is complete
    6) For reads, read the received data from PCIMCFGDAT.
    7) Set GPIO to turn off IDSEL
