Linux/PROCESSOR-SDK-AM335X: install the mysql ipk files error
Part Number: PROCESSOR-SDK-AM335X
Tool/software: Linux
I have successfully cross compiled the nginx, php, mysql. As you can see in the picture below I try to run install all the ipk files but it gives some errors about mariadb ipk files installation. How could I resolve it? thank you.
  • Hello XYZ,
    You need to install the perl-module-parent, perl-module-file-temp, perl-module-io-pipe, perl-module-ipc-open3, perl-module-sys-hostname, perl-module-benchmark, perl-module-file-spec-functions, perl-module-io-select, perl-module-io-socket-inet --force-depends, perl-module-socket, perl-module-io-socket --force-depends, perl-module-io-socket-unix, perl-module-lib, perl-module-sigtrap, libdbd-mysql-perl and coreutils runtime dependencies on that board.
    Beset regards,
    Kemal
