Part Number: TDA2PXEVM
Refer to VisionSDK_Linux_UserGuide,and applied the patch of early boot, and we had debuged to make system boot normal.But we are not sure that how to make sure the early boot and late attach is normal, are there any other documents for reference?
Find the boot log in below, please. Could you help us to make sure the boot log is normal?
===================================boot log============================================
Welcome to Arago 2016.12!
[ SKIP ] Ordering cycle found, skipping D-Bus System Message Bus Socket
[ SKIP ] Ordering cycle found, skipping alignment.service
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Created slice System Slice.
Starting Setup Virtual Console...
Starting Create list of required st... nodes for the current kernel...
Starting Load Kernel Modules...
Mounting Temporary Directory...
Mounting POSIX Message Queue File System...
Mounting Debug File System...
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Reached target Swap.
Starting Remount Root and Kernel File Systems...
[ OK ] Reached target Sockets.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Journal Service.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Found device /dev/ttyS0.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyS9.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Basic System.
Starting rc.pvr.service...
[ OK ] Started Kernel Logging Service.
Starting Network Service...
Starting Permit User Sessions...
[ OK ] Started System Logging Service.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Started Permit User Sessions.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS9.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
Starting tiipclad-daemon.service...
[ OK ] Started telnetd.service.
[ OK ] Started tiipclad-daemon.service.
Starting ecarxinit.service...
[ OK ] Started ecarxinit.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS9
Arago 2016.12 dra7xx-evm ttyS9
dra7xx-evm login: root
root@dra7xx-evm:~#
root@dra7xx-evm:~# ls
apps.sh decode_ipumm.sh init-demo.sh
root@dra7xx-evm:~#
