Other Parts Discussed in Thread: INA226
Tool/software: TI-RTOS
I'm running the TIDL usecase, the system is booted OK, and I put the required files in my sd card, I generated our own data into inData_OD and inHeaderOD based on the instructions I found from the forum , but the dimension of our original data is 1920*1080, so I compress the video dimension to 768*320 according to the original TIDL_SSD_CFG.TXT , but when I tried to run the use case, I got the decode error.
And below is the log from my terminal:
TDA2xx SBL Boot
DPLL Configuration Completed
Clock Domain Configuration Completed
Module Enable Configuration Completed
TI EVM PAD Config Completed
DDR Config Completed
App Image Download Begins
SD Boot - file open completed successfully
MPU CPU0 Image Load Completed
IPU1 CPU0 Image Load Completed
IPU1 CPU1 Image Load Completed
IPU2 CPU0 and CPU1 Image Load Completed
DSP1 Image Load Completed
DSP2 Image Load Completed
EVE1 Image Load Completed
EVE2 Image Load Completed
EVE3 Image Load Completed
EVE4 Image Load Completed
App Image Download Completed
Putting MPU CPU1 in Off mode
EVE MMU configuration completed
PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
SBL Initial Config Cycles - 144537 (12.33 ms)
SOC Init Cycles - 263987 (22.52 ms)
DDR Config Clock Cycles - 67644 (5.77 ms)
App Image Load Cycles - 190820787 (16283.37 ms)
Slave Core Bootup Cycles - 322861 (27.55 ms)
SBL Boot-up Cycles - 191621149 (16351.67 ms)
Time at which SBL started IPU1_0 - 352088 (30.4 ms)
Jumping to MPU CPU0 App
[IPU1-0] 10.744708 s: ***** IPU1_0 Firmware build time 12:23:57 Nov 22 2018
[IPU1-0] 10.744891 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-0] 11.512627 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[IPU1-0] 11.512810 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[IPU1-0] 11.512932 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[IPU1-0] 11.513023 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[IPU1-0] 11.513145 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[IPU1-0] 11.513237 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[IPU1-0] 11.513359 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[IPU1-0] 11.513481 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[IPU1-0] 11.513572 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[IPU1-0] 11.515524 s: *** UTILS: CPU MHz = 20 Mhz ***
[IPU1-0] 11.515738 s: SYSTEM: System Common Init in progress !!!
[IPU1-0] 11.529219 s: UTILS: CIO: Init Done !!!
[IPU1-0] 11.529341 s: SYSTEM: IPC init in progress !!!
[IPU1-0] 11.529402 s: SYSTEM: Notify init done !!!
[IPU1-0] 11.531202 s: SYSTEM: MsgQ init done !!!
[IPU1-0] 11.531293 s: SYSTEM: IPC init DONE !!!
[IPU1-0] 11.535197 s: SYSTEM: System Common Init Done !!!
[IPU1-0] 11.535289 s: SYSTEM: System Init in progress !!!
[IPU1-0] 11.535350 s: SYSTEM: BSP Common Init in progress !!!
[IPU1-0] 11.535441 s: SYSTEM: BSP Common Init Done !!!
[IPU1-0] 11.535502 s: SYSTEM: BSP Platform Init in progress !!!
[IPU1-0] 11.535655 s: SYSTEM: BSP Platform Init Done !!!
[IPU1-0] 11.535777 s: SYSTEM: FVID2 Init in progress !!!
[IPU1-0] 11.535929 s: SYSTEM: FVID2 Init Done !!!
[IPU1-0] 11.536021 s: SYSTEM: VPS Init in progress !!!
[IPU1-0] 11.536082 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[IPU1-0] 11.540078 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 11.540200 s: VPDMA Firmware Address = 0x9fd1c4c0
[IPU1-0] 11.540291 s: VPDMA Load Address = 0x4897d004
[IPU1-0] 11.540413 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 11.540535 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 11.540627 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 11.541481 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 11.541603 s: VPDMA Firmware Address = 0x9fd1c4c0
[IPU1-0] 11.541755 s: VPDMA Load Address = 0x4899d004
[IPU1-0] 11.541877 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 11.541969 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 11.542030 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 11.542457 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 11.542548 s: VPDMA Firmware Address = 0x9fd1c4c0
[IPU1-0] 11.542640 s: VPDMA Load Address = 0x489bd004
[IPU1-0] 11.542914 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 11.543006 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 11.543097 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 11.543799 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 11.543921 s: VPDMA Firmware Address = 0x9fd1c4c0
[IPU1-0] 11.544012 s: VPDMA Load Address = 0x489dd004
[IPU1-0] 11.544134 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 11.544226 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 11.544317 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 11.608277 s: SYSTEM: VPS Init Done !!!
[IPU1-0] 11.609253 s: UTILS: DMA: HWI Create for INT34 !!!
[IPU1-0] 11.609467 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-0] 11.609589 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252328 B (246 KB)
[IPU1-0] 11.609833 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0] 11.610046 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x89d03000, Total size = 368037888 B (350 MB), Free size = 368037888 B (350 MB)
[IPU1-0] 11.610260 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 127360 B (0 MB), Free size = 92800 B (0 MB)
[IPU1-0] 11.610412 s: SYSTEM: Initializing Links !!!
[IPU1-0] 11.877325 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-0] 11.972732 s: BOARD: Board Init in progress !!!
[IPU1-0] 11.973128 s: BOARD: Board Init Done !!!
[IPU1-0] 11.984475 s:
[IPU1-0] 11.984566 s: Vision SDK Version : [REL_VISION_SDK_03_04_00_00]
[IPU1-0] 11.984627 s: FVID2 Version : [FVID_02_01_00_01]
[IPU1-0] 11.984719 s: BSP Version : [PDK_01_10_00_xx]
[IPU1-0] 11.984780 s: Platform : [EVM]
[IPU1-0] 11.984841 s: SOC : [TDA2XX]
[IPU1-0] 11.984902 s: SOC Revision : [ES2.0]
[IPU1-0] 11.984963 s: Board Detected : [Vision]
[IPU1-0] 11.990971 s: EEPROM Base Board Name: [5777xCPU-DDR3]
[IPU1-0] 11.991063 s: Base Board Revision : [REV E]
[IPU1-0] 11.992374 s: Daughter Card Revision: [REV D]
[IPU1-0] 11.992435 s:
[IPU1-0] 11.996187 s: SYSTEM: UART: INTERRUPT Mode is Selected
[IPU1-1] 10.761880 s: ***** IPU1_1 Firmware build time 12:20:32 Nov 22 2018
[IPU1-1] 10.762063 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-1] 11.515311 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[IPU1-1] 11.515555 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[IPU1-1] 11.515707 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[IPU1-1] 11.515860 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[IPU1-1] 11.515982 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[IPU1-1] 11.516104 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[IPU1-1] 11.516226 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[IPU1-1] 11.516348 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[IPU1-1] 11.516470 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[IPU1-1] 11.526017 s: SYSTEM: System Common Init in progress !!!
[IPU1-1] 11.527176 s: UTILS: CIO: Init Done !!!
[IPU1-1] 11.527267 s: SYSTEM: IPC init in progress !!!
[IPU1-1] 11.527359 s: SYSTEM: Notify init done !!!
[IPU1-1] 11.529128 s: SYSTEM: MsgQ init done !!!
[IPU1-1] 11.529219 s: SYSTEM: IPC init DONE !!!
[IPU1-1] 11.533062 s: SYSTEM: System Common Init Done !!!
[IPU1-1] 11.533184 s: SYSTEM: System IPU1_1 Init in progress !!!
[IPU1-1] 11.534069 s: UTILS: DMA: HWI Create for INT25 !!!
[IPU1-1] 11.534313 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-1] 11.534404 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 620344 B (605 KB)
[IPU1-1] 11.534587 s: SYSTEM: Initializing Links !!!
[IPU1-1] 11.651009 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU1-1] 11.654059 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU1-1] 11.657140 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU1-1] 11.660800 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU1-1] 11.664063 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU1-1] 11.667785 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU1-1] 11.670987 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU1-1] 11.674342 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU1-1] 11.677850 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU1-1] 11.681052 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU1-1] 11.685048 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU1-1] 11.685170 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-1] 11.686482 s: SYSTEM: System IPU1_1 Init Done !!!
[IPU1-1] 11.820045 s: NSP GMAC: PHY 2 Found on MAC Port 0
[IPU1-1] 11.820594 s: NSP GMAC: PHY 3 Found on MAC Port 1
[HOST ] 10.821997 s: ***** A15_0 Firmware build time 12:22:36 Nov 22 2018
[HOST ] 10.822027 s: *** SYSTEM: CPU Frequency <ORG = 750000000 Hz>, <NEW = 1176000000 Hz>
[HOST ] 11.513633 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[HOST ] 11.513633 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[HOST ] 11.513633 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST ] 11.513664 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST ] 11.513664 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST ] 11.513664 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST ] 11.513694 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST ] 11.513694 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST ] 11.513694 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST ] 11.513755 s: SYSTEM: System Common Init in progress !!!
[HOST ] 11.513786 s: SYSTEM: IPC init in progress !!!
[HOST ] 11.513786 s: SYSTEM: Notify init done !!!
[HOST ] 11.513847 s: SYSTEM: MsgQ init done !!!
[HOST ] 11.513847 s: SYSTEM: IPC init DONE !!!
[HOST ] 11.514213 s: SYSTEM: System Common Init Done !!!
[HOST ] 11.514213 s: SYSTEM: System A15 Init in progress !!!
[HOST ] 11.514243 s: UTILS: DMA: HWI Create for INT66 !!!
[HOST ] 11.514274 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST ] 11.514274 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6280568 B (6133 KB)
[HOST ] 11.514304 s: SYSTEM: Initializing Links !!!
[HOST ] 11.516287 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[HOST ] 11.516348 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[HOST ] 11.516409 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[HOST ] 11.516470 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[HOST ] 11.516531 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[HOST ] 11.516592 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[HOST ] 11.516653 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[HOST ] 11.516714 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[HOST ] 11.516775 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[HOST ] 11.516836 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[HOST ] 11.516897 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[HOST ] 11.516897 s: SYSTEM: Initializing Links ... DONE !!!
[HOST ] 11.516897 s: SYSTEM: System A15 Init Done !!!
[DSP1 ] 10.813334 s: ***** DSP1 Firmware build time 12:16:11 Nov 22 2018
[DSP1 ] 10.813426 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 700000000 Hz>
[DSP1 ] 11.517720 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[DSP1 ] 11.517781 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[DSP1 ] 11.517812 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[DSP1 ] 11.517842 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[DSP1 ] 11.517873 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[DSP1 ] 11.517903 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[DSP1 ] 11.517934 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[DSP1 ] 11.517964 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[DSP1 ] 11.517995 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[DSP1 ] 11.518147 s: *** UTILS: CPU MHz = 20 Mhz ***
[DSP1 ] 11.518178 s: SYSTEM: System Common Init in progress !!!
[DSP1 ] 11.518361 s: UTILS: CIO: Init Done !!!
[DSP1 ] 11.518391 s: SYSTEM: IPC init in progress !!!
[DSP1 ] 11.518422 s: SYSTEM: Notify init done !!!
[DSP1 ] 11.518544 s: SYSTEM: MsgQ init done !!!
[DSP1 ] 11.518575 s: SYSTEM: IPC init DONE !!!
[DSP1 ] 11.519246 s: SYSTEM: System Common Init Done !!!
[DSP1 ] 11.519276 s: SYSTEM: System DSP Init in progress !!!
[DSP1 ] 11.519490 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP1 ] 11.519520 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1 ] 11.519551 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514784 B (502 KB)
[DSP1 ] 11.519581 s: SYSTEM: Initializing Links !!!
[DSP1 ] 11.527542 s: SYSTEM: Initializing Links ... DONE !!!
[DSP1 ] 11.527572 s: lz4CompDecomp Init
[DSP1 ] 11.527603 s: SYSTEM: System DSP Init Done !!!
[DSP1 ] 11.891295 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP1 ] 11.891325 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[DSP2 ] 10.813304 s: ***** DSP2 Firmware build time 12:18:29 Nov 22 2018
[DSP2 ] 10.813395 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 700000000 Hz>
[DSP2 ] 11.518849 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[DSP2 ] 11.518910 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[DSP2 ] 11.518941 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[DSP2 ] 11.518971 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[DSP2 ] 11.519002 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[DSP2 ] 11.519032 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[DSP2 ] 11.519063 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[DSP2 ] 11.519093 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[DSP2 ] 11.519124 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[DSP2 ] 11.519276 s: *** UTILS: CPU MHz = 20 Mhz ***
[DSP2 ] 11.519337 s: SYSTEM: System Common Init in progress !!!
[DSP2 ] 11.519520 s: UTILS: CIO: Init Done !!!
[DSP2 ] 11.519551 s: SYSTEM: IPC init in progress !!!
[DSP2 ] 11.519581 s: SYSTEM: Notify init done !!!
[DSP2 ] 11.519703 s: SYSTEM: MsgQ init done !!!
[DSP2 ] 11.519734 s: SYSTEM: IPC init DONE !!!
[DSP2 ] 11.520435 s: SYSTEM: System Common Init Done !!!
[DSP2 ] 11.520466 s: SYSTEM: System DSP Init in progress !!!
[DSP2 ] 11.520679 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP2 ] 11.520710 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP2 ] 11.520740 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514784 B (502 KB)
[DSP2 ] 11.520771 s: SYSTEM: Initializing Links !!!
[DSP2 ] 11.528640 s: SYSTEM: Initializing Links ... DONE !!!
[DSP2 ] 11.528670 s: lz4CompDecomp Init
[DSP2 ] 11.528701 s: SYSTEM: System DSP Init Done !!!
[DSP2 ] 11.893308 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP2 ] 11.893338 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[EVE1 ] 11.502013 s: ***** EVE Firmware build time 12:10:47 Nov 22 2018
[EVE1 ] 11.503812 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
[EVE1 ] 11.522845 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[EVE1 ] 11.524553 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[EVE1 ] 11.526139 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[EVE1 ] 11.527725 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[EVE1 ] 11.529189 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[EVE1 ] 11.530592 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[EVE1 ] 11.531995 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[EVE1 ] 11.533398 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[EVE1 ] 11.534831 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[EVE1 ] 11.537058 s: SYSTEM: System Common Init in progress !!!
[EVE1 ] 11.539437 s: UTILS: CIO: Init Done !!!
[EVE1 ] 11.540413 s: SYSTEM: IPC init in progress !!!
[EVE1 ] 11.541877 s: SYSTEM: Notify init done !!!
[EVE1 ] 11.543951 s: SYSTEM: MsgQ init done !!!
[EVE1 ] 11.544927 s: SYSTEM: IPC init DONE !!!
[EVE1 ] 11.560910 s: SYSTEM: System Common Init Done !!!
[EVE1 ] 11.562038 s: SYSTEM: System EVE Init in progress !!!
[EVE1 ] 11.563685 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE1 ] 11.565027 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE1 ] 11.566369 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1 ] 11.568901 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252592 B (246 KB)
[EVE1 ] 11.571188 s: SYSTEM: Initializing Links !!!
[EVE1 ] 11.664917 s: SYSTEM: Initializing Links ... DONE !!!
[EVE1 ] 11.666046 s: SYSTEM: System EVE Init Done !!!
[EVE2 ] 11.482980 s: ***** EVE Firmware build time 12:12:03 Nov 22 2018
[EVE2 ] 11.484902 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
[EVE2 ] 11.525102 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[EVE2 ] 11.526718 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[EVE2 ] 11.528304 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[EVE2 ] 11.529707 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[EVE2 ] 11.531110 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[EVE2 ] 11.532513 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[EVE2 ] 11.533947 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[EVE2 ] 11.535380 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[EVE2 ] 11.536966 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[EVE2 ] 11.539163 s: SYSTEM: System Common Init in progress !!!
[EVE2 ] 11.541969 s: UTILS: CIO: Init Done !!!
[EVE2 ] 11.543067 s: SYSTEM: IPC init in progress !!!
[EVE2 ] 11.544195 s: SYSTEM: Notify init done !!!
[EVE2 ] 11.546178 s: SYSTEM: MsgQ init done !!!
[EVE2 ] 11.547154 s: SYSTEM: IPC init DONE !!!
[EVE2 ] 11.562374 s: SYSTEM: System Common Init Done !!!
[EVE2 ] 11.563502 s: SYSTEM: System EVE Init in progress !!!
[EVE2 ] 11.565088 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE2 ] 11.566369 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE2 ] 11.567803 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE2 ] 11.570243 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252592 B (246 KB)
[EVE2 ] 11.572652 s: SYSTEM: Initializing Links !!!
[EVE2 ] 11.666503 s: SYSTEM: Initializing Links ... DONE !!!
[EVE2 ] 11.667541 s: SYSTEM: System EVE Init Done !!!
[EVE3 ] 11.500518 s: ***** EVE Firmware build time 12:13:16 Nov 22 2018
[EVE3 ] 11.502440 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
[EVE3 ] 11.527237 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[EVE3 ] 11.528792 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[EVE3 ] 11.530195 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[EVE3 ] 11.531629 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[EVE3 ] 11.533032 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[EVE3 ] 11.534465 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[EVE3 ] 11.535838 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[EVE3 ] 11.537455 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[EVE3 ] 11.539071 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[EVE3 ] 11.541542 s: SYSTEM: System Common Init in progress !!!
[EVE3 ] 11.544134 s: UTILS: CIO: Init Done !!!
[EVE3 ] 11.545110 s: SYSTEM: IPC init in progress !!!
[EVE3 ] 11.546239 s: SYSTEM: Notify init done !!!
[EVE3 ] 11.548465 s: SYSTEM: MsgQ init done !!!
[EVE3 ] 11.549441 s: SYSTEM: IPC init DONE !!!
[EVE3 ] 11.564356 s: SYSTEM: System Common Init Done !!!
[EVE3 ] 11.565454 s: SYSTEM: System EVE Init in progress !!!
[EVE3 ] 11.567071 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE3 ] 11.568352 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE3 ] 11.569694 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE3 ] 11.572195 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252592 B (246 KB)
[EVE3 ] 11.574788 s: SYSTEM: Initializing Links !!!
[EVE3 ] 11.667388 s: SYSTEM: Initializing Links ... DONE !!!
[EVE3 ] 11.668486 s: SYSTEM: System EVE Init Done !!!
[EVE4 ] 11.492679 s: ***** EVE Firmware build time 12:14:23 Nov 22 2018
[EVE4 ] 11.494509 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
[EVE4 ] 11.527237 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[EVE4 ] 11.528792 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[EVE4 ] 11.530195 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[EVE4 ] 11.531629 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[EVE4 ] 11.533032 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[EVE4 ] 11.534465 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[EVE4 ] 11.535838 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[EVE4 ] 11.537394 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[EVE4 ] 11.539010 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[EVE4 ] 11.541450 s: SYSTEM: System Common Init in progress !!!
[EVE4 ] 11.543982 s: UTILS: CIO: Init Done !!!
[EVE4 ] 11.544958 s: SYSTEM: IPC init in progress !!!
[EVE4 ] 11.546178 s: SYSTEM: Notify init done !!!
[EVE4 ] 11.548374 s: SYSTEM: MsgQ init done !!!
[EVE4 ] 11.549380 s: SYSTEM: IPC init DONE !!!
[EVE4 ] 11.564234 s: SYSTEM: System Common Init Done !!!
[EVE4 ] 11.565332 s: SYSTEM: System EVE Init in progress !!!
[EVE4 ] 11.566979 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE4 ] 11.568260 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE4 ] 11.569602 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE4 ] 11.572073 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252592 B (246 KB)
[EVE4 ] 11.574544 s: SYSTEM: Initializing Links !!!
[EVE4 ] 11.667266 s: SYSTEM: Initializing Links ... DONE !!!
[EVE4 ] 11.668364 s: SYSTEM: System EVE Init Done !!!
[IPU2 ] 10.742481 s: ***** IPU2 Firmware build time 12:26:35 Nov 22 2018
[IPU2 ] 10.742664 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU2 ] 11.516714 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[IPU2 ] 11.516927 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[IPU2 ] 11.517019 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[IPU2 ] 11.517141 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[IPU2 ] 11.517232 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[IPU2 ] 11.517354 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[IPU2 ] 11.517476 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[IPU2 ] 11.517568 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[IPU2 ] 11.517690 s: SYSTEM: Notify register to [HOST] line 0, event 15...
[IPU2 ] 11.520405 s: SYSTEM: System Common Init in progress !!!
[IPU2 ] 11.521838 s: UTILS: CIO: Init Done !!!
[IPU2 ] 11.521960 s: SYSTEM: IPC init in progress !!!
[IPU2 ] 11.522052 s: SYSTEM: Notify init done !!!
[IPU2 ] 11.523973 s: SYSTEM: MsgQ init done !!!
[IPU2 ] 11.524095 s: SYSTEM: IPC init DONE !!!
[IPU2 ] 11.529280 s: SYSTEM: System Common Init Done !!!
[IPU2 ] 11.529402 s: SYSTEM: System IPU2 Init in progress !!!
[IPU2 ] 11.530226 s: UTILS: DMA: HWI Create for INT25 !!!
[IPU2 ] 11.530500 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU2 ] 11.530622 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252424 B (246 KB)
[IPU2 ] 11.530836 s: SYSTEM: Initializing Links !!!
[IPU2 ] 11.643109 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU2 ] 11.646068 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU2 ] 11.649027 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU2 ] 11.652138 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU2 ] 11.655218 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU2 ] 11.658421 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU2 ] 11.661501 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU2 ] 11.664765 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU2 ] 11.667876 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU2 ] 11.670957 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU2 ] 11.674068 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU2 ] 11.674190 s: SYSTEM: Initializing Links ... DONE !!!
[IPU2 ] 11.674281 s: SYSTEM: System IPU2 Init Done !!!
[IPU1-0] 13.131489 s: UTILS_PRCM_STATS: INA226 Setup Failed. Check if INA226 is connected on I2C3 Lines
[IPU1-0] 13.135881 s: QSPI Init Started
[IPU1-0] 13.136155 s: MID - 1
[IPU1-0] 13.136186 s: DID - 18
[IPU1-0] 13.136247 s: QSPI Init Completed Sucessfully
[IPU1-0] 13.149301 s:
[IPU1-0] 13.149362 s: Current System Settings,
[IPU1-0] 13.149423 s: ========================
[IPU1-0] 13.149484 s: Display Type : HDMI 1920x1080 @ 60fps
[IPU1-0] 13.149545 s: Capture Source : Sensor OV10635 1280x720 @ 30fps - VIP, YUV422
[IPU1-0] 13.149637 s: My IP address : 0.0.0.0
[IPU1-0] 13.149698 s: ISS Settings : LDC=[OFF] VTNF=[OFF] WDR=[OFF]
[IPU1-0] 13.149789 s:
[IPU1-0] 13.149820 s: ============
[IPU1-0] 13.149881 s: Usecase Menu
[IPU1-0] 13.149911 s: ============
[IPU1-0] 13.149972 s:
[IPU1-0]
[IPU1-0] Vision SDK Usecases,
[IPU1-0] --------------------
[IPU1-0] 1: Single Camera Usecases
[IPU1-0] 2: Multi-Camera LVDS Usecases
[IPU1-0] 3: AVB RX Usecases, (TDA2x & TDA2Ex ONLY)
[IPU1-0] 4: Dual Display Usecases, (TDA2x EVM ONLY)
[IPU1-0] 5: ISS Usecases, (TDA3x ONLY)
[IPU1-0] 6: TDA2x Stereo Usecases
[IPU1-0] 7: Network RX/TX Usecases
[IPU1-0] 9: RADAR Usecases
[IPU1-0] a: Miscellaneous test's
[IPU1-0] f: TIDL Usecase
[IPU1-0] g: Camera Radar Combo Usecases
[IPU1-0]
[IPU1-0] s: System Settings
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0] Enter Choice:
[IPU1-0]
[IPU1-1] 16.685841 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[IPU1-1] 16.686116 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[IPU1-0] 19.804977 s:
[IPU1-0] 19.805099 s:
[IPU1-0]
[IPU1-0] TIDL Usecases
[IPU1-0] 1: TIDL File I/O Usecase
[IPU1-0] 2: Semantic Segmentation Usecase
[IPU1-0] 3: TIDL OD Usecase
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0] 21.062648 s:
[IPU1-0] 21.104556 s: TIDL Configuration parameters
[IPU1-0] 21.104617 s: -----------------------------
[IPU1-0] 21.104678 s: inputWidth = 768
[IPU1-0] 21.104739 s: inputHeight = 320
[IPU1-0] 21.104800 s: inputFile = inData_OD
[IPU1-0] 21.104861 s: inputFile = inHeader_OD
[IPU1-0] 21.104922 s: netFileName = tidl_net_jdetNet_ssd.bin
[IPU1-0] 21.105014 s: paramFileName = tidl_param_jdetNet_ssd.bin
[IPU1-0] 21.105105 s: inputfps = 30
[IPU1-0] 21.105166 s: threshold = 0.300000
[IPU1-0] 21.105258 s: -----------------------------
[IPU1-0] 22.229030 s: FILE: Reading file [inHeader_OD
[IPU1-0] ] ...
[IPU1-0] 22.233300 s: FILE: File read Done. [120 bytes]
[IPU1-0] 22.262429 s: DECODE: Create in progress ... !!!
[IPU1-0] 22.516195 s: DECODE: Creating CH0 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 22.516927 s: DECODE: All CH Create ... DONE !!!
[IPU1-0] 22.518758 s: DECODE: Create ... DONE !!!
[IPU1-0] 22.519185 s: VPE: Create in progress !!!
[IPU1-0] 22.612365 s: VPE: Loading Down-scaling Co-effs
[IPU1-0] 22.612609 s: VPE: Co-effs Loading ... DONE !!!
[IPU1-0] 22.612822 s: VPE: Create Done !!!
[IPU1-0] 22.613890 s: IPC_OUT_0 : Create in progress !!!
[IPU1-0] 22.614286 s: IPC_OUT_0 : Create Done !!!
[HOST ] 22.614469 s: IPC_IN_0 : Create in progress !!!
[HOST ] 22.614744 s: IPC_IN_0 : Create Done !!!
[HOST ] 22.614896 s: ALGORITHM: Create in progress (algId = 12) !!!
[HOST ] 22.621027 s: UTILS: DMA: Allocated CH (TCC) = 0 (0)
[HOST ] 22.621057 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 0 (0x43305600)
[HOST ] 22.621057 s: ALGORITHM: Create Done (algId = 12) !!!
[HOST ] 22.621149 s: IPC_OUT_3 : Create in progress !!!
[HOST ] 22.621179 s: IPC_OUT_3 : Create Done !!!
[EVE4 ] 22.621454 s: IPC_IN_0 : Create in progress !!!
[EVE4 ] 22.622399 s: IPC_IN_0 : Create Done !!!
[EVE4 ] 22.622948 s: ALGORITHM: Create in progress (algId = 14) !!!
[HOST ] 24.283291 s: IPC_OUT_2 : Create in progress !!!
[HOST ] 24.283322 s: IPC_OUT_2 : Create Done !!!
[DSP1 ] 24.282681 s: IPC_IN_3 : Create in progress !!!
[DSP1 ] 24.283139 s: IPC_IN_3 : Create Done !!!
[EVE3 ] 24.283596 s: IPC_IN_0 : Create in progress !!!
[EVE3 ] 24.284450 s: IPC_IN_0 : Create Done !!!
[EVE3 ] 24.284999 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE4 ] 24.281187 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE4 ] 24.281766 s: IPC_OUT_0 : Create in progress !!!
[EVE4 ] 24.282285 s: IPC_OUT_0 : Create Done !!!
[HOST ] 25.946166 s: IPC_OUT_1 : Create in progress !!!
[HOST ] 25.946196 s: IPC_OUT_1 : Create Done !!!
[DSP1 ] 25.945617 s: IPC_IN_2 : Create in progress !!!
[DSP1 ] 25.946044 s: IPC_IN_2 : Create Done !!!
[EVE2 ] 25.946471 s: IPC_IN_0 : Create in progress !!!
[EVE2 ] 25.947355 s: IPC_IN_0 : Create Done !!!
[EVE2 ] 25.947904 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE3 ] 25.944000 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE3 ] 25.944793 s: IPC_OUT_0 : Create in progress !!!
[EVE3 ] 25.945220 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 27.617001 s: IPC_IN_1 : Create in progress !!!
[DSP1 ] 27.617458 s: IPC_IN_1 : Create Done !!!
[EVE1 ] 27.617855 s: IPC_IN_0 : Create in progress !!!
[EVE1 ] 27.618739 s: IPC_IN_0 : Create Done !!!
[EVE1 ] 27.619471 s: ALGORITHM: Create in progress (algId = 14) !!!
[EVE2 ] 27.615537 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE2 ] 27.616147 s: IPC_OUT_0 : Create in progress !!!
[EVE2 ] 27.616604 s: IPC_OUT_0 : Create Done !!!
[HOST ] 27.617580 s: IPC_OUT_0 : Create in progress !!!
[HOST ] 27.617611 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 29.286006 s: IPC_IN_0 : Create in progress !!!
[DSP1 ] 29.286585 s: IPC_IN_0 : Create Done !!!
[DSP1 ] 29.286921 s: ALGORITHM: Create in progress (algId = 36) !!!
[DSP1 ] 29.294119 s: ALGORITHM: Create Done (algId = 36) !!!
[DSP1 ] 29.294271 s: IPC_OUT_0 : Create in progress !!!
[DSP1 ] 29.294332 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 29.870432 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP1 ] 29.870493 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 65600 B (64 KB)
[DSP1 ] 29.870524 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 497720 B (486 KB)
[DSP2 ] 29.870676 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP2 ] 29.870707 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP2 ] 29.870737 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514584 B (502 KB)
[EVE1 ] 29.284572 s: ALGORITHM: Create Done (algId = 14) !!!
[EVE1 ] 29.285182 s: IPC_OUT_0 : Create in progress !!!
[EVE1 ] 29.285609 s: IPC_OUT_0 : Create Done !!!
[EVE1 ] 29.871073 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE1 ] 29.871347 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
[EVE1 ] 29.871835 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235672 B (230 KB)
[EVE2 ] 29.872811 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE2 ] 29.873086 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
[EVE2 ] 29.873574 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235672 B (230 KB)
[EVE3 ] 29.874428 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE3 ] 29.874702 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
[EVE3 ] 29.875190 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235672 B (230 KB)
[EVE4 ] 29.875983 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE4 ] 29.876258 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
[EVE4 ] 29.876746 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235672 B (230 KB)
[IPU2 ] 29.877478 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU2 ] 29.877600 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250104 B (244 KB)
[IPU1-0] 29.294454 s: IPC_IN_0 : Create in progress !!!
[IPU1-0] 29.295491 s: IPC_IN_0 : Create Done !!!
[IPU1-0] 29.296559 s: ALGORITHM: Create in progress (algId = 1) !!!
[IPU1-0] 29.297779 s: UTILS: DMA: Allocated CH (TCC) = 48 (48)
[IPU1-0] 29.297901 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 48 (0x63304800)
[IPU1-0] 29.315104 s: ALGORITHM: Create Done (algId = 1) !!!
[IPU1-0] 29.315348 s: DISPLAY: Create in progress !!!
[IPU1-0] 29.315897 s: DISPLAY: Create Done !!!
[IPU1-0] 29.316263 s: GRPXSRC: Create in progress !!!
[IPU1-0] 29.867595 s: GRPXSRC: Create Done !!!
[IPU1-0] 29.867992 s: DISPLAY: Create in progress !!!
[IPU1-0] 29.868510 s: DISPLAY: Create Done !!!
[IPU1-0] 29.868815 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-0] 29.868937 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 242664 B (236 KB)
[IPU1-0] 29.869090 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0] 29.869273 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x89d03000, Total size = 368037888 B (350 MB), Free size = 163697664 B (156 MB)
[IPU1-0] 29.869456 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 127360 B (0 MB), Free size = 92800 B (0 MB)
[IPU1-0] 29.877874 s: DISPLAY: Start in progress !!!
[IPU1-0] 29.878027 s: DISPLAY: Start Done !!!
[IPU1-0] 29.887482 s: DISPLAY: Start in progress !!!
[IPU1-0] 29.887543 s: DISPLAY: Start Done !!!
[IPU1-0] 29.895534 s:
[IPU1-0]
[IPU1-0] ====================
[IPU1-0] Chains Run-time Menu
[IPU1-0]
[IPU1-0] 0: Stop Chain
[IPU1-0]
[IPU1-0] 1: Pause Chain
[IPU1-0] 2: Resume Chain
[IPU1-0]
[IPU1-0] p: Print Statistics
[IPU1-0]
[IPU1-0]
[IPU1-0] 29.926432 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 29.926554 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 29.926645 s: DEC_LINK: Sequence called number 1
[IPU1-0] 29.959403 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 29.959525 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 29.959616 s: DEC_LINK: Sequence called number 2
[IPU1-0] 29.992405 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 29.992649 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 29.992771 s: DEC_LINK: Sequence called number 3
[IPU1-0] 30.025407 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.025529 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.025620 s: DEC_LINK: Sequence called number 4
[IPU1-0] 30.058409 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.058531 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.058653 s: DEC_LINK: Sequence called number 5
[IPU1-0] 30.091410 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.091532 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.091624 s: DEC_LINK: Sequence called number 6
[IPU1-0] 30.124412 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.124534 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.124626 s: DEC_LINK: Sequence called number 7
[IPU1-0] 30.157414 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.157506 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.157628 s: DEC_LINK: Sequence called number 8
[IPU1-0] 30.190416 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.190538 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.190630 s: DEC_LINK: Sequence called number 9
[IPU1-0] 30.223418 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.223540 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.223632 s: DEC_LINK: Sequence called number 10
[IPU1-0] 30.256420 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.256511 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.256633 s: DEC_LINK: Sequence called number 11
[IPU1-0] 30.289483 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.289605 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.289696 s: DEC_LINK: Sequence called number 12
[IPU1-0] 30.322454 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.322576 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.322668 s: DEC_LINK: Sequence called number 13
[IPU1-0] 30.355456 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.355578 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.355700 s: DEC_LINK: Sequence called number 14
[IPU1-0] 30.388427 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.388519 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.388641 s: DEC_LINK: Sequence called number 15
[IPU1-0] 30.421490 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.421612 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.421704 s: DEC_LINK: Sequence called number 16
[IPU1-0] 30.454431 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.454523 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.454645 s: DEC_LINK: Sequence called number 17
[IPU1-0] 30.487403 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.487525 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.487647 s: DEC_LINK: Sequence called number 18
[IPU1-0] 30.520435 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.520527 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.520649 s: DEC_LINK: Sequence called number 19
[IPU1-0] 30.553467 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.553589 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.553681 s: DEC_LINK: Sequence called number 20
[IPU1-0] 30.586408 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00004400) !!!
[IPU1-0] 30.586530 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x4400
[IPU1-0] 30.586622 s: DEC_LINK: Sequence called number 21
Any solution on this problem?
Thanks!!
