Part Number: TMS320C6748
The PLL0_RSTYPE register detects if the last reset was caused by a Software reset or a Power on reset, is there a way to detect a Watchdog reset?
Michael
Michael
Thanks for your response Yordan.
To clarify my problem:
When powering up, I must be able to detect the causes of the power up:
- normal power up (power was turned off and then on ), can be detected by PLL0_RSTYPE
- power up caused by Software reset , can be detected by PLL0_RSTYPE
- power up caused by watchdog, since all watchdog registers are reset when power up, is there a way to record when this happens? Is there a register that can be written when a watchdog occurs and will "survive" a power up?
Check Section 6.4 Reset of the datasheet. If you are performing a warm reset, then there are parts of the processor that don't reset. Other than that the r/w registers are reset to their default values.
Yordan
