TDA2PXEVM: About early boot based on TI visionSDK 03 05
Part Number: TDA2PXEVM
Hi Shravan,
It still  crashes.It may be caused by the memory we changed.Our maximum memory is 512M, so,we modified necessary memory address and size according to our memory configuration.Could you help to have a look? Please find the failed boot log in attachment.
Thanks a lot
Terence
Welcome to Arago 2016.12!
[    3.281918] systemd[1]: Set hostname to <dra7xx-evm>.
[    3.287119] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.296448] systemd[1]: Initializing machine ID from random generator.
[    3.400741] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.412122] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.420853] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.423983] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.442289] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.573089] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    3.582677] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    3.795847] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
[    3.803685] systemd[1]: sockets.target: Found dependency on dbus.socket/start
[    3.810885] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[    3.818321] systemd[1]: sockets.target: Found dependency on alignment.service/start
[    3.826051] systemd[1]: sockets.target: Found dependency on basic.target/start
[    3.833334] systemd[1]: sockets.target: Found dependency on sockets.target/start
[    3.840770] systemd[1]: sockets.target: Breaking ordering cycle by deleting job dbus.socket/start
[    3.849725] systemd[1]: dbus.socket: Job dbus.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping D-Bus System Message Bus Socket
[    3.881047] systemd[1]: alignment.service: Found ordering cycle on alignment.service/start
[    3.889356] systemd[1]: alignment.service: Found dependency on sysinit.target/start
[    3.897082] systemd[1]: alignment.service: Found dependency on alignment.service/start
[    3.905334] systemd[1]: alignment.service: Breaking ordering cycle by deleting job alignment.service/start
[    3.915063] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    3.954579] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    3.971647] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    3.993808] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    4.021671] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.041049] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.071084] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    4.090975] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.110919] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.130949] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.151058] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.201210] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    4.233450] systemd[1]: Mounting POSIX Message Queue File System...
[    4.263410] systemd[1]: Starting Setup Virtual Console...
[    4.283509] systemd[1]: Mounting Debug File System...
[    4.305190] systemd[1]: Starting Load Kernel Modules...
[    4.333270] systemd[1]: Mounting Temporary Directory...
[    4.361226] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.391044] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.441194] systemd[1]: Starting Journal Service...
[    4.463466] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.488619] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.494483] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    4.521019] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    4.541086] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.561814] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.580948] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    4.600936] systemd[1]: Reached target Sockets.
[  OK  ] Reached target Sockets.
[    4.656140] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    4.681026] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    4.700994] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    4.721190] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Setup Virtual Console.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting udev Coldplug all Devices...
         Starting Load/Save Random Seed...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[    5.531479] systemd-journald[115]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started udev Coldplug all Devices.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[    7.303459] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
[    7.312330]  remoteproc0: 58820000.ipu is available
[    7.317513]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    7.331094]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    7.343367] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
[    7.352003]  remoteproc1: 55020000.ipu is available
[    7.356928]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[    7.366521]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[  OK  ] Started Network Time Synchronization.
[    7.386687] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
[    7.398456]  remoteproc2: 40800000.dsp is available
[  OK  ] Reached target System Time Synchronized.
[    7.409699]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[    7.426359]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    7.444049] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    7.453382] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
         Starting Synchronize System and HW clocks...
[    7.467342]  remoteproc3: 41000000.dsp is available
[    7.472711]  remoteproc3: Note: remoteproc is still under development and considered experimental.
[    7.496102]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Reached target System Initialization.
[  OK  ] Reached target Basic System.
[    7.660053]  remoteproc0: registered virtio0 (type 7)
         Starting Permit User Sessions...
         Starting rc.pvr.service...
[    7.723651] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
         Starting Network Service...
[  OK  ] Started Permit User Sessions.
[  OK  ] Found device /dev/ttyS9.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS9.
[  OK  ] Started Serial Getty on ttyS0.
[    8.782856] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    8.829220] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    8.847443] omap-aes 4b500000.aes: Unable to request in DMA channel
[    8.909925] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    8.919674] omap-aes 4b700000.aes: Unable to request in DMA channel
[    9.567907] SCSI subsystem initialized
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started Network Service.
[    9.995531] net eth1: initializing cpsw version 1.15 (0)
[   10.002839] net eth0: initialized cpsw ale version 1.4
[   10.008002] net eth0: ALE Table size 1024
[  OK  ] Reached target Network.
[   10.036209]  remoteproc0: powering up 58820000.ipu
[   10.041926]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 589684
[   10.049157] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[   10.057083]  remoteproc0: remote processor 58820000.ipu is now up
[   10.064280] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.069819] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
         Starting Network Name Resolution...
[   10.172579] net eth1: phy found : id is : 0x1ccb00
[   10.184493] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   10.192539] net eth0: initializing cpsw version 1.15 (0)
[   10.201234] libphy: PHY 48485000.mdio:01 not found
[   10.206124] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
[   10.219046] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.289798]  remoteproc2: powering up 40800000.dsp
[   10.294655]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583987
[   10.301837] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   10.307760] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   10.315136]  remoteproc2: remote processor 40800000.dsp is now up
[   10.325615] virtio_rpmsg_bus virtio1: rpmsg host is online
[   10.332887]  remoteproc2: registered virtio1 (type 7)
[   10.338987] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[   10.368636]  remoteproc3: powering up 41000000.dsp
[   10.374516]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583987
[   10.383498] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   10.389454] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   10.399776]  remoteproc3: remote processor 41000000.dsp is now up
[   10.406349] virtio_rpmsg_bus virtio2: rpmsg host is online
[   10.416055]  remoteproc3: registered virtio2 (type 7)
[   10.422990] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
[   10.547610] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
[   10.600705] NET: Registered protocol family 41
[  OK  ] Started Network Name Resolution.
[   11.062719] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
[   11.068359] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   11.079550] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[   11.093030]  remoteproc1: powering up 55020000.ipu
[   11.097855]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9392404
[   11.111602] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[   11.120093] omap_rproc_request_timer: request for timer node df619d10 failed
[   11.129486] omap-rproc 55020000.ipu: request for timer df619d10 failed: -16
[   11.137908] omap-rproc 55020000.ipu: omap_rproc_enable_timers failed: -16
[   11.144836] scsi host0: ahci
[   11.148123] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
[   11.159390]  remoteproc1: can't start rproc 55020000.ipu: -16
[   11.172759]  remoteproc1: rproc_boot() failed -16
[   11.177527] virtio_rpmsg_bus: probe of virtio3 failed with error -16
[   11.183989]  remoteproc1: registered virtio3 (type 7)
[   11.236294] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
[   11.520846] ata1: SATA link down (SStatus 0 SControl 300)
[   11.537745] usbcore: registered new interface driver usbfs
[   11.545028] usbcore: registered new interface driver hub
[   11.550534] usbcore: registered new device driver usb
[  OK  ] Started weston.service.
         Starting telnetd.service...
         Starting tiipclad-daemon.service...
[  OK  ] Started telnetd.service.
[  OK  ] Started tiipclad-daemon.service.
[   11.714663] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   11.725596] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   11.736898] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[   11.746545] xhci-hcd xhci-hcd.2.auto: irq 462, io mem 0x488d0000
[   11.753602] hub 1-0:1.0: USB hub found
[   11.757408] hub 1-0:1.0: 1 port detected
         [   11.763017] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
Starting ecarxinit.service...
[   11.768948] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   11.779579] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   11.788766] hub 2-0:1.0: USB hub found
[   11.792733] hub 2-0:1.0: 1 port detected
[   11.893686] DMA: Module install successful, device major num = 242
[   11.900291] DRV: Module install successful
[  OK  ] Started ecarxinit.service.
[   13548653] omap8250 4806a000.serial: failed to request DMA
[   13.555622] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[   13.562703] pgd = d2c98000
[   13.565421] [00000000] *pgd=00000000
[   13.569025] Internal error: : 1406 [#1] PREEMPT SMP ARM
[   13.574273] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore bc_example(O) ahci_platform libahci_platform libahci dwc3 libata rpmsg_proto pvrsrvkm(O) udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio omap_aes_driver dwc3_omap omap_sham extcon omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[   13.604827] CPU: 0 PID: 396 Comm: (agetty) Tainted: G           O    4.4.84 #1
[   13.612080] Hardware name: Generic DRA74X (Flattened Device Tree)
[   13.618200] task: db2da400 ti: d2c92000 task.ti: d2c92000
[   13.623626] PC is at pcs_readl+0x14/0x18
[   13.627566] LR is at pcs_irq_mask+0x78/0xa4
[   13.631769] pc : [<c02ec65c>]    lr : [<c02ec6e8>]    psr: a0010093
[   13.631769] sp : d2c93d30  ip : d2c93d40  fp : d2c93d3c
[   13.643296] r10: c0350760  r9 : 01000000  r8 : df3e9440
[   13.648543] r7 : df3e942c  r6 : 000001cd  r5 : df3e94b4  r4 : dc93e0dc
[   13.655099] r3 : c02ec648  r2 : 00000000  r1 : fc0037e0  r0 : 00000000
[   13.661655] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   13.668908] Control: 10c5387d  Table: 92c9806a  DAC: 00000051
[   13.674678] Process (agetty) (pid: 396, stack limit = 0xd2c92210)
[   13.680798] Stack: (0xd2c93d30 to 0xd2c94000)
[   13.685175] 3d20:                                     d2c93d64 d2c93d40 c02ec6e8 c02ec654
[   13.693391] 3d40: dc810180 dc810190 dc8101e0 000001cd 60010013 d2eebe40 d2c93d7c d2c93d68
[   13.701606] 3d60: c008926c c02ec67c d2eeb980 dc810180 d2c93da4 d2c93d80 c00866b0 c0089200
[   13.709821] 3d80: 00000000 dc810180 000001cd d2eebe40 00000000 c0350a30 d2c93dc4 d2c93da8
[   13.718036] 3da0: c008677c c0086444 d2eebe40 df244610 df244674 a0010013 d2c93de4 d2c93dc8
[   13.726252] 3dc0: c03f6c70 c0086744 c09c1880 c09c1880 df056088 00010013 d2c93dfc d2c93de8
[   13.734467] 3de0: c0377a98 c03f6c10 df056000 c09c1880 d2c93e0c d2c93e00 c0371990 c03779b8
[   13.742682] 3e00: d2c93e2c d2c93e10 c036c4a4 c0371980 df056000 df056090 dc72cc00 df056064
[   13.750896] 3e20: d2c93e54 d2c93e30 c036e294 c036c3dc 00000000 dc72cc00 dc72cd5c 00000001
[   13.759111] 3e40: 00000000 c0350a30 d2c93e94 d2c93e58 c03505bc c036e250 dc6d9600 00000000
[   13.767325] 3e60: 00000000 00000000 d2c93e84 dc72cc00 00005437 dc6d9600 80000000 00000000
[   13.775539] 3e80: dc72cc00 00000000 d2c93f14 d2c93e98 c035197c c0350224 dc6d9600 d2c93eb0
[   13.783753] 3ea0: d2c93f4c d2c93eb0 c01328a4 c012ca54 dcad8410 dcc432a8 80080005 00000005
[   13.791967] 3ec0: df0dd015 c02e15a4 00000000 dcd40b28 dc93a7d0 df001900 df0dd000 c0131bfc
[   13.800182] 3ee0: d2c92000 dfaa5e60 d2c93f00 0004600e 80000000 dc93a7d0 dc6d9600 00000003
[   13.808397] 3f00: 80000000 d2c92000 d2c93f7c d2c93f18 c013500c c0350ec8 00000020 dc93a7d0
[   13.816611] 3f20: dc6d9608 00000000 d2c93f4c d2c93f38 c0131bfc c0113ecc 00000003 dc6d9600
[   13.824824] 3f40: d2c93f94 d2c93f50 c01234e4 c0131b9c 00000000 dc6d9600 00000003 dc6d9600
[   13.833039] 3f60: 00005437 80000000 d2c92000 00000000 d2c93fa4 d2c93f80 c01352c4 c0134bb8
[   13.841254] 3f80: 006397b8 00642628 b6ffdce0 00000036 c000fe24 d2c92000 00000000 d2c93fa8
[   13.849469] 3fa0: c000fc60 c0135294 006397b8 00642628 00000003 00005437 80000000 00000000
[   13.857684] 3fc0: 006397b8 00642628 b6ffdce0 00000036 00000003 00000000 befff718 befff5b4
[   13.865899] 3fe0: 005fcc54 befff33c 00542b00 b6f634d6 20010030 00000003 ffffffff ffffffff
[   13.874108] Backtrace:
[   13.876578] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
[   13.883922] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
[   13.891523]  r9:d2eebe40 r8:60010013 r7:000001cd r6:dc8101e0 r5:dc810190 r4:dc810180
[   13.899354] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
[   13.901182] thermal thermal_zone0: failed to read out thermal zone (-5)
[   13.901207] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[   13.901211] pgd = dc568000
[   13.901221] [00000000] *pgd=9c6d0831, *pte=00000000, *ppte=00000000
[   13.929671]  r5:dc810180 r4:d2eeb980
[   13.933285] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
[   13.940363]  r9:c0350a30 r8:00000000 r7:d2eebe40 r6:000001cd r5:dc810180 r4:00000000
[   13.948193] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
[   13.956230]  r7:a0010013 r6:df244674 r5:df244610 r4:d2eebe40
[   13.961960] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
[   13.970868]  r7:00010013 r6:df056088 r5:c09c1880 r4:c09c1880
[   13.976592] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
[   13.985326]  r5:c09c1880 r4:df056000
[   13.988937] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
[   13.997329] [<c036c3d0>] (uart_shutdown) from [<c036e294>] (uart_hangup+0x50/0x104)
[   14.005016]  r7:df056064 r6:dc72cc00 r5:df056090 r4:df056000
[   14.010745] [<c036e244>] (uart_hangup) from [<c03505bc>] (__tty_hangup+0x3a4/0x3b4)
[   14.018434]  r9:c0350a30 r8:00000000 r7:00000001 r6:dc72cd5c r5:dc72cc00 r4:00000000
[   14.026262] [<c0350218>] (__tty_hangup) from [<c035197c>] (tty_ioctl+0xac0/0xe8c)
[   14.033776]  r10:00000000 r9:dc72cc00 r8:00000000 r7:80000000 r6:dc6d9600 r5:00005437
[   14.041684]  r4:dc72cc00
[   14.044244] [<c0350ebc>] (tty_ioctl) from [<c013500c>] (do_vfs_ioctl+0x460/0x6dc)
[   14.051756]  r9:d2c92000 r8:80000000 r7:00000003 r6:dc6d9600 r5:dc93a7d0 r4:80000000
[   14.059583] [<c0134bac>] (do_vfs_ioctl) from [<c01352c4>] (SyS_ioctl+0x3c/0x64)
[   14.066923]  r10:00000000 r9:d2c92000 r8:80000000 r7:00005437 r6:dc6d9600 r5:00000003
[   14.074832]  r4:dc6d9600
[   14.077391] [<c0135288>] (SyS_ioctl) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
[   14.084992]  r9:d2c92000 r8:c000fe24 r7:00000036 r6:b6ffdce0 r5:00642628 r4:006397b8
[   14.092820] Code: e92dd800 e24cb004 e5900000 f57ff04f (e89da800)
[   14.098944] ---[ end trace 6dea70dc4dfd41c3 ]---
[   14.103584] note: (agetty)[396] exited with preempt_count 2
[   14.109233] ------------[ cut here ]------------
[   14.113882] WARNING: CPU: 0 PID: 396 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[   14.123410] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
[   14.135200] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore bc_example(O) ahci_platform libahci_platform libahci dwc3 libata rpmsg_proto pvrsrvkm(O) udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio omap_aes_driver dwc3_omap omap_sham extcon omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[   14.165757] CPU: 0 PID: 396 Comm: (agetty) Tainted: G      D    O    4.4.84 #1
[   14.173010] Hardware name: Generic DRA74X (Flattened Device Tree)
[   14.179127] Backtrace:
[   14.181601] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[   14.189203]  r7:c02e3bb0 r6:20010193 r5:00000000 r4:c0959350
[   14.194933] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
[   14.202191] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
[   14.210315]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:d2c93818
[   14.216041] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
[   14.224775]  r8:00000017 r7:c084c280 r6:00000000 r5:c084c340 r4:c084c3e4
[   14.231556] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
[   14.240465]  r3:df20a940 r2:c084c3e4
[   14.244071]  r4:80080003
[   14.246634] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
[   14.255979]  r10:c0988e4b r9:df208240 r8:00000017 r7:00000000 r6:00000000 r5:df2082a0
[   14.263889]  r4:df20ae40
[   14.266447] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
[   14.275355]  r10:c081ef94 r9:c02ec65e r8:df008000 r7:00000000 r6:c0941c8c r5:df2082a0
[   14.283264]  r4:df208240
[   14.285821] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
[   14.294380]  r7:00000000 r6:c0941c8c r5:df2082a0 r4:df208240
[   14.300105] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
[   14.308751]  r7:00000000 r6:d2c93af0 r5:00000017 r4:c093640c
[   14.314476] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
[   14.323216] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[   14.331601]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d2c939d8 r5:fa21200c r4:c093c8e4
[   14.339428] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[   14.346943] Exception stack(0xd2c939d8 to 0xd2c93a20)
[   14.352016] 39c0:                                                       00000000 c098c2c0
[   14.360231] 39e0: 00000000 00000000 00000282 00000012 d2c92000 00000000 df008000 c02ec65e
[   14.368448] 3a00: c081ef94 d2c93a84 d2c93a88 d2c93a28 c003d464 c003cfd0 60010113 ffffffff
[   14.376659]  r9:c02ec65e r8:df008000 r7:d2c93a0c r6:ffffffff r5:60010113 r4:c003cfd0
[   14.384488] [<c003cf3c>] (__do_softirq) from [<c003d464>] (irq_exit+0xbc/0x11c)
[   14.391827]  r10:c081ef94 r9:c02ec65e r8:df008000 r7:00000000 r6:00000000 r5:00000012
[   14.399736]  r4:ffffe000[   14.400822] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[   14.400826] pgd = c0004000
[   14.400830] [00000000] *pgd=00000000
[   14.400838] Internal error: : 1406 [#2] PREEMPT SMP ARM
[   14.400842] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore bc_example(O) ahci_platform libahci_platform libahci dwc3 libata rpmsg_proto pvrsrvkm(O) udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio omap_aes_driver dwc3_omap omap_sham extcon omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[   14.400910] CPU: 1 PID: 137 Comm: kworker/1:3 Tainted: G      D    O    4.4.84 #1
[   14.400913] Hardware name: Generic DRA74X (Flattened Device Tree)
[   14.400922] Workqueue: events_freezable thermal_zone_device_check
[   14.400927] task: dca7b600 ti: dc5b0000 task.ti: dc5b0000
[   14.400936] PC is at ti_bandgap_force_single_read+0x4c/0x188
[   14.400942] LR is at ti_bandgap_read_temperature+0xb8/0xf8
[   14.400947] pc : [<c04d1ff4>]    lr : [<c04d379c>]    psr: 40000013
[   14.400947] sp : dc5b1df8  ip : dc5b1e20  fp : dc5b1e1c
[   14.400950] r10: df5d89c0  r9 : 00000000  r8 : 00000000
[   14.400954] r7 : 00000000  r6 : 00000000  r5 : dca36b10  r4 : 00000000
[   14.400958] r3 : 0000014c  r2 : fc00232c  r1 : c0977ab8  r0 : dca36b10
[   14.400963] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   14.400968] Control: 10c5387d  Table: 9c68c06a  DAC: 00000051
[   14.400972] Process kworker/1:3 (pid: 137, stack limit = 0xdc5b0210)
[   14.400976] Stack: (0xdc5b1df8 to 0xdc5b2000)
[   14.400980] 1de0:                                                       dca36b10 00000000
[   14.400989] 1e00: dc5b1e40 dca54010 dca36b10 00000000 dc5b1e3c dc5b1e20 c04d379c c04d1fb4
[   14.400996] 1e20: 00000000 dc5b1eb4 c06f7450 dca54010 dc5b1e6c dc5b1e40 c04d3b6c c04d36f0
[   14.401003] 1e40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc5b1eb4 df5dc300 00000000
[   14.401010] 1e60: dc5b1e7c dc5b1e70 c04cef6c c04d3b3c dc5b1eac dc5b1e80 c04cb5fc c04cef50
[   14.401017] 1e80: 7fffffff df5d8e40 dca7b600 df312a2c df312800 df5d89c0 00000000 df5dc300
[   14.401023] 1ea0: dc5b1ecc dc5b1eb0 c04ccde0 c04cb5ac dc5b1edc dc5b1ec0 df312a2c dc5df980
[   14.401031] 1ec0: dc5b1edc dc5b1ed0 c04ccecc c04ccdd0 dc5b1f1c dc5b1ee0 c004f330 c04ccea0
[   14.401037] 1ee0: df5d89c0 df5d89d4 dc5b0000 00000008 dc5df980 df5d89c0 dc5df998 df5d89d4
[   14.401044] 1f00: dc5b0000 00000008 dc5df980 df5d89c0 dc5b1f54 dc5b1f20 c004f64c c004f218
[   14.401051] 1f20: dc5df980 c093c100 00000000 00000000 dc405d40 dc5b0000 dc5df980 c004f600
[   14.401058] 1f40: 00000000 00000000 dc5b1fac dc5b1f58 c0055184 c004f60c dc5b1f58 00000000
[   14.401065] 1f60: dc5b1f8c dc5df980 00000000 00000000 dc5b1f70 dc5b1f70 00000000 00000000
[   14.401071] 1f80: dc5b1f80 dc5b1f80 dc5b1fac dc405d40 c0055084 00000000 00000000 00000000
[   14.401077] 1fa0: 00000000 dc5b1fb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
[   14.401085] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.401091] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000001
[   14.401093] Backtrace:
[   14.401106] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
[   14.401109]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc5b1e40 r5:00000000 r4:dca36b10
[   14.401131] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
[   14.401134]  r7:dca54010 r6:c06f7450 r5:dc5b1eb4 r4:00000000
[   14.401152] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
[   14.401155]  r9:00000000 r8:df5dc300 r7:dc5b1eb4 r6:df312a0c r5:df312800 r4:df312800
[   14.401176] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
[   14.401185] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
[   14.401188]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
[   14.401205] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
[   14.401208]  r5:dc5df980 r4:df312a2c
[   14.401220] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
[   14.401226] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
[   14.401230]  r10:df5d89c0 r9:dc5df980 r8:00000008 r7:dc5b0000 r6:df5d89d4 r5:dc5df998
[   14.401242]  r4:df5d89c0
[   14.401251] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
[   14.401254]  r10:00000000 r9:00000000 r8:c004f600 r7:dc5df980 r6:dc5b0000 r5:dc405d40
[   14.401265]  r4:00000000
[   14.401275] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[   14.401277]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc405d40
[   14.401295] Code: e5913000 e0822003 e5928000 f57ff04f (e5913008)
[   14.401301] ---[ end trace 6dea70dc4dfd41c4 ]---
[   14.401389] Unable to handle kernel paging request at virtual address ffffffec
[   14.401393] pgd = c0004000
[   14.401396] [ffffffec] *pgd=9face861, *pte=00000000, *ppte=00000000
[   14.401410] Internal error: Oops: 37 [#3] PREEMPT SMP ARM
[   14.401413] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore bc_example(O) ahci_platform libahci_platform libahci dwc3 libata rpmsg_proto pvrsrvkm(O) udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio omap_aes_driver dwc3_omap omap_sham extcon omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[   14.401476] CPU: 1 PID: 137 Comm: kworker/1:3 Tainted: G      D    O    4.4.84 #1
[   14.401479] Hardware name: Generic DRA74X (Flattened Device Tree)
[   14.401492] task: dca7b600 ti: dc5b0000 task.ti: dc5b0000
[   14.401498] PC is at kthread_data+0x10/0x18
[   14.401503] LR is at wq_worker_sleeping+0x14/0xd8
[   14.401508] pc : [<c00555d4>]    lr : [<c00503fc>]    psr: 20000193
[   14.401508] sp : dc5b1ba0  ip : dc5b1bb0  fp : dc5b1bac
[   14.401511] r10: 00000001  r9 : df5d8e40  r8 : dca7b9a8
[   14.401515] r7 : c093c6d4  r6 : c0937e40  r5 : dca7b600  r4 : 00000001
[   14.401518] r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : dca7b600
[   14.401523] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   14.401527] Control: 10c5387d  Table: 9c68c06a  DAC: 00000051
[   14.401530] Process kworker/1:3 (pid: 137, stack limit = 0xdc5b0210)
[   14.401533] Stack: (0xdc5b1ba0 to 0xdc5b2000)
[   14.401542] 1ba0: dc5b1bc4 dc5b1bb0 c00503fc c00555d0 df5d8e40 dca7b600 dc5b1c1c dc5b1bc8
[   14.401549] 1bc0: c0687680 c00503f4 c098be14 dc5b6900 dc5b1bec dc5b1be0 c00918f8 c009167c
[   14.401556] 1be0: dc5b1c34 c06878b8 00000000 c00918ec c003a300 dc5b0000 dc5b1904 df080000
[   14.401562] 1c00: dc5b1c40 dca7b920 c04d1ff6 c081ef94 dc5b1c34 dc5b1c20 c06878b8 c0687204
[   14.401570] 1c20: dca7b600 dc5b1904 dc5b1c5c dc5b1c38 c003c258 c0687870 00000001 00000000
[   14.401577] 1c40: dc5b1c40 dc5b1c40 c00393a8 c04d1ff8 dc5b1ce4 dc5b1c60 c0013f68 c003bc24
[   14.401583] 1c60: dc5b0210 0000000b c081ef9c 00000008 00000000 dc5b0000 00000000 60000193
[   14.401591] 1c80: 655b1ca4 33313935 20303030 32383065 33303032 39356520 30303832 35662030
[   14.401597] 1ca0: 30666637 28206634 31393565 38303033 c0002029 c0004000 dc5b1cf4 c0940fb4
[   14.401604] 1cc0: 00001406 00000007 00000000 dc5b1da8 00000000 df5d89c0 dc5b1cf4 dc5b1ce8
[   14.401610] 1ce0: c0014198 c0013d28 dc5b1da4 dc5b1cf8 c0009370 c0014184 00000000 dc5b1d08
[   14.401618] 1d00: 00000007 00000000 00030003 00000000 00006dee 00000000 00006dee 00000000
[   14.401624] 1d20: dc5b1d54 dc5b1d30 c0067188 c007c7a4 df5d8e80 dca7b648 df5d8e80 dca7b648
[   14.401632] 1d40: 00000001 00000000 dc5b1dd4 dc5b1d58 c0068f0c c0067210 c009cb88 c05012fc
[   14.401639] 1d60: ffffffff 00ffffff 35debf60 000bea9e 00000003 df5d6e50 00000001 dca71900
[   14.401646] 1d80: 00000800 c04d1ff4 40000013 ffffffff dc5b1ddc 00000000 dc5b1e1c dc5b1da8
[   14.401653] 1da0: c00147e0 c00092c0 dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
[   14.401659] 1dc0: 00000000 00000000 00000000 00000000 df5d89c0 dc5b1e1c dc5b1e20 dc5b1df8
[   14.401666] 1de0: c04d379c c04d1ff4 40000013 ffffffff 00000051 df05a500 dca36b10 00000000
[   14.401673] 1e00: dc5b1e40 dca54010 dca36b10 00000000 dc5b1e3c dc5b1e20 c04d379c c04d1fb4
[   14.401680] 1e20: 00000000 dc5b1eb4 c06f7450 dca54010 dc5b1e6c dc5b1e40 c04d3b6c c04d36f0
[   14.401686] 1e40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc5b1eb4 df5dc300 00000000
[   14.401694] 1e60: dc5b1e7c dc5b1e70 c04cef6c c04d3b3c dc5b1eac dc5b1e80 c04cb5fc c04cef50
[   14.401700] 1e80: 7fffffff df5d8e40 dca7b600 df312a2c df312800 df5d89c0 00000000 df5dc300
[   14.401707] 1ea0: dc5b1ecc dc5b1eb0 c04ccde0 c04cb5ac dc5b1edc dc5b1ec0 df312a2c dc5df980
[   14.401713] 1ec0: dc5b1edc dc5b1ed0 c04ccecc c04ccdd0 dc5b1f1c dc5b1ee0 c004f330 c04ccea0
[   14.401721] 1ee0: df5d89c0 df5d89d4 dc5b0000 00000008 dc5df980 df5d89c0 dc5df998 df5d89d4
[   14.401727] 1f00: dc5b0000 00000008 dc5df980 df5d89c0 dc5b1f54 dc5b1f20 c004f64c c004f218
[   14.401735] 1f20: dc5df980 c093c100 00000000 00000000 dc405d40 dc5b0000 dc5df980 c004f600
[   14.401741] 1f40: 00000000 00000000 dc5b1fac dc5b1f58 c0055184 c004f60c dc5b1f58 00000000
[   14.401748] 1f60: dc5b1f8c dc5df980 00000000 00000000 dc5b1f70 dc5b1f70 00000001 00010001
[   14.401756] 1f80: dc5b1f80 dc5b1f80 dc5b1fac dc405d40 c0055084 00000000 00000000 00000000
[   14.401762] 1fa0: 00000000 dc5b1fb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
[   14.401767] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   14.401773] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000001
[   14.401775] Backtrace:
[   14.401785] [<c00555c4>] (kthread_data) from [<c00503fc>] (wq_worker_sleeping+0x14/0xd8)
[   14.401795] [<c00503e8>] (wq_worker_sleeping) from [<c0687680>] (__schedule+0x488/0x66c)
[   14.401799]  r5:dca7b600 r4:df5d8e40
[   14.401811] [<c06871f8>] (__schedule) from [<c06878b8>] (schedule+0x54/0xc4)
[   14.401814]  r10:c081ef94 r9:c04d1ff6 r8:dca7b920 r7:dc5b1c40 r6:df080000 r5:dc5b1904
[   14.401826]  r4:dc5b0000
[   14.401836] [<c0687864>] (schedule) from [<c003c258>] (do_exit+0x640/0x9b8)
[   14.401839]  r5:dc5b1904 r4:dca7b600
[   14.401849] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
[   14.401851]  r7:c04d1ff8
[   14.401859] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
[   14.401861]  r10:df5d89c0 r9:00000000 r8:dc5b1da8 r7:00000000 r6:00000007 r5:00001406
[   14.401875]  r4:c0940fb4
[   14.401882] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
[   14.401888] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
[   14.401891] Exception stack(0xdc5b1da8 to 0xdc5b1df0)
[   14.401898] 1da0:                   dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
[   14.401904] 1dc0: 00000000 00000000 00000000 00000000 df5d89c0 dc5b1e1c dc5b1e20 dc5b1df8
[   14.401910] 1de0: c04d379c c04d1ff4 40000013 ffffffff
[   14.401912]  r8:00000000 r7:dc5b1ddc r6:ffffffff r5:40000013 r4:c04d1ff4
[   14.401932] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
[   14.401934]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc5b1e40 r5:00000000 r4:dca36b10
[   14.401952] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
[   14.401954]  r7:dca54010 r6:c06f7450 r5:dc5b1eb4 r4:00000000
[   14.401969] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
[   14.401972]  r9:00000000 r8:df5dc300 r7:dc5b1eb4 r6:df312a0c r5:df312800 r4:df312800
[   14.401990] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
[   14.401998] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
[   14.402001]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
[   14.402017] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
[   14.402019]  r5:dc5df980 r4:df312a2c
[   14.402030] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
[   14.402036] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
[   14.402039]  r10:df5d89c0 r9:dc5df980 r8:00000008 r7:dc5b0000 r6:df5d89d4 r5:dc5df998
[   14.402052]  r4:df5d89c0
[   14.402060] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
[   14.402062]  r10:00000000 r9:00000000 r8:c004f600 r7:dc5df980 r6:dc5b0000 r5:dc405d40
[   14.402074]  r4:00000000
[   14.402083] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[   14.402085]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc405d40
[   14.402105] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
[   14.402112] ---[ end trace 6dea70dc4dfd41c5 ]---
[   14.402114] Fixing recursive fault but reboot is needed!
[   15.556562]
[   15.558246] [<c003d3a8>] (irq_exit) from [<c00853d0>] (__handle_domain_irq+0x68/0xbc)
[   15.566108]  r5:00000012 r4:c093640c
[   15.569721] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[   15.578107]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d2c93af0 r5:fa21200c r4:c093c8e4
[   15.585935] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[   15.593448] Exception stack(0xd2c93af0 to 0xd2c93b38)
[   15.598522] 3ae0:                                     d4cd8504 00000000 00000000 000000a8
[   15.606738] 3b00: dc5b2fc0 0000000b 000011dc c02ec660 00000001 c02ec65e c081ef94 d2c93b4c
[   15.614953] 3b20: d2c93b50 d2c93b40 c00b36a0 c068b5d8 40010113 ffffffff
[   15.621593]  r9:c02ec65e r8:00000001 r7:d2c93b24 r6:ffffffff r5:40010113 r4:c068b5d8
[   15.629424] [<c068b5b0>] (_raw_spin_unlock_irq) from [<c00b36a0>] (acct_collect+0x198/0x1b8)
[   15.637901] [<c00b3508>] (acct_collect) from [<c003c2b8>] (do_exit+0x6a0/0x9b8)
[   15.645238]  r7:c02ec660 r6:00000001 r5:0000000b r4:db2da400
[   15.650962] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
[   15.657515]  r7:c02ec660
[   15.660068] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
[   15.667059]  r10:c0350760 r9:01000000 r8:d2c93ce0 r7:00000000 r6:00000007 r5:00001406
[   15.674967]  r4:c0940fb4
[   15.677522] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
[   15.685300] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
[   15.692726] Exception stack(0xd2c93ce0 to 0xd2c93d28)
[   15.697801] 3ce0: 00000000 fc0037e0 00000000 c02ec648 dc93e0dc df3e94b4 000001cd df3e942c
[   15.706016] 3d00: df3e9440 01000000 c0350760 d2c93d3c d2c93d40 d2c93d30 c02ec6e8 c02ec65c
[   15.714229] 3d20: a0010093 ffffffff
[   15.717730]  r8:df3e9440 r7:d2c93d14 r6:ffffffff r5:a0010093 r4:c02ec65c
[   15.724510] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
[   15.731854] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
[   15.739454]  r9:d2eebe40 r8:60010013 r7:000001cd r6:dc8101e0 r5:dc810190 r4:dc810180
[   15.747278] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
[   15.754877]  r5:dc810180 r4:d2eeb980
[   15.758487] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
[   15.765564]  r9:c0350a30 r8:00000000 r7:d2eebe40 r6:000001cd r5:dc810180 r4:00000000
[   15.773393] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
[   15.781429]  r7:a0010013 r6:df244674 r5:df244610 r4:d2eebe40
[   15.787158] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
[   15.796066]  r7:00010013 r6:df056088 r5:c09c1880 r4:c09c1880
[   15.801791] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
[   15.810524]  r5:c09c1880 r4:df056000
[   15.814138] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
[   15.822530] [<c036c3d0>] (uart_shutdown) from [<c036e294>] (uart_hangup+0x50/0x104)
[   15.830217]  r7:df056064 r6:dc72cc00 r5:df056090 r4:df056000
[   15.835947] [<c036e244>] (uart_hangup) from [<c03505bc>] (__tty_hangup+0x3a4/0x3b4)
[   15.843635]  r9:c0350a30 r8:00000000 r7:00000001 r6:dc72cd5c r5:dc72cc00 r4:00000000
[   15.851465] [<c0350218>] (__tty_hangup) from [<c035197c>] (tty_ioctl+0xac0/0xe8c)
[   15.858978]  r10:00000000 r9:dc72cc00 r8:00000000 r7:80000000 r6:dc6d9600 r5:00005437
[   15.866889]  r4:dc72cc00
[   15.869447] [<c0350ebc>] (tty_ioctl) from [<c013500c>] (do_vfs_ioctl+0x460/0x6dc)
[   15.876961]  r9:d2c92000 r8:80000000 r7:00000003 r6:dc6d9600 r5:dc93a7d0 r4:80000000
[   15.884788] [<c0134bac>] (do_vfs_ioctl) from [<c01352c4>] (SyS_ioctl+0x3c/0x64)
[   15.892128]  r10:00000000 r9:d2c92000 r8:80000000 r7:00005437 r6:dc6d9600 r5:00000003
[   15.900036]  r4:dc6d9600
[   15.902592] [<c0135288>] (SyS_ioctl) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
[   15.910192]  r9:d2c92000 r8:c000fe24 r7:00000036 r6:b6ffdce0 r5:00642628 r4:006397b8
[   15.918014] ---[ end trace 6dea70dc4dfd41c6 ]---
[   15.923022] ------------[ cut here ]------------
[   15.927668] WARNING: CPU: 0 PID: 18 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[   15.937105] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Read): Data Access in User mode during Functional access
[   15.948366] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore bc_example(O) ahci_platform libahci_platform libahci dwc3 libata rpmsg_proto pvrsrvkm(O) udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio omap_aes_driver dwc3_omap omap_sham extcon omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[   15.978915] CPU: 0 PID: 18 Comm: kworker/0:1 Tainted: G      D W  O    4.4.84 #1
[   15.986341] Hardware name: Generic DRA74X (Flattened Device Tree)
[   15.992464] Workqueue: events_freezable thermal_zone_device_check
[   15.998589] Backtrace:
[   16.001062] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[   16.008663]  r7:c02e3bb0 r6:20070193 r5:00000000 r4:c0959350
[   16.014393] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
[   16.021651] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
[   16.029775]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:df233be8
[   16.035500] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
[   16.044234]  r8:00000017 r7:c084c280 r6:00000002 r5:c084c340 r4:c084c3e4
[   16.051016] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
[   16.059925]  r3:df20a940 r2:c084c3e4
[   16.063533]  r4:80080003
[   16.066091] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
[   16.075436]  r10:c0988e4b r9:df208240 r8:00000017 r7:00000000 r6:00000000 r5:df2082a0
[   16.083348]  r4:df20ae40
[   16.085907] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
[   16.094815]  r10:df5cd9c0 r9:00000000 r8:df008000 r7:00000000 r6:c0941c8c r5:df2082a0
[   16.102727]  r4:df208240
[   16.105284] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
[   16.113844]  r7:00000000 r6:c0941c8c r5:df2082a0 r4:df208240
[   16.119570] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
[   16.128216]  r7:00000000 r6:00000000 r5:00000017 r4:c093640c
[   16.133944] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
[   16.142682] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[   16.151069]  r9:00000000 r8:fa213000 r7:fa212000 r6:df233da8 r5:fa21200c r4:c093c8e4
[   16.158897] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[   16.166412] Exception stack(0xdf233da8 to 0xdf233df0)
[   16.171489] 3da0:                   dca36b10 c0977990 fc002330 00000150 00000024 dca36b10
[   16.179704] 3dc0: 00000008 00000001 00000000 00000000 df5cd9c0 df233e1c df233e20 df233df8
[   16.187918] 3de0: c04d379c c04d1ff4 40070013 ffffffff
[   16.192988]  r9:00000000 r8:00000000 r7:df233ddc r6:ffffffff r5:40070013 r4:c04d1ff4
[   16.200819] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
[   16.211123]  r9:00000000 r8:dca36b10 r7:dca54050 r6:df233e40 r5:00000001 r4:dca36b10
[   16.218952] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
[   16.228646]  r7:dca54050 r6:c06f7450 r5:df233eb4 r4:00000001
[   16.234372] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
[   16.243367]  r9:00000000 r8:df5d1300 r7:df233eb4 r6:df312e0c r5:df312c00 r4:df312c00
[   16.251197] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
[   16.260287] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
[   16.270504]  r8:df5d1300 r7:00000000 r6:df5cd9c0 r5:df312c00 r4:df312e2c
[   16.277284] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
[   16.287849]  r5:df222a80 r4:df312e2c
[   16.291461] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
[   16.300722] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
[   16.308846]  r10:df5cd9c0 r9:df222a80 r8:00000008 r7:df232000 r6:df5cd9d4 r5:df222a98
[   16.316757]  r4:df5cd9c0
[   16.319314] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
[   16.326739]  r10:00000000 r9:00000000 r8:c004f600 r7:df222a80 r6:df232000 r5:df227180
[   16.334649]  r4:00000000
[   16.337206] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[   16.344458]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:df227180
[   16.351233] ---[ end trace 6dea70dc4dfd41c7 ]---
[   16.355923] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[   16.363002] pgd = d41f4000
[   16.365720] [00000000] *pgd=00000000
  • Hi Terence,
    Can you please provide the DTB being used. Also which all cores are you trying to bootstrap from u-boot?
    Are you accessing UART from the remote-cores? I notice a failure in UART from the logs provided.
    Shravan
  • Hi Shravan,
    1.we want to boot the cores of "dsp1,dsp2,ipu1,ipu2" from u-boot, and then the ipu is used to bootstrap  eve1. But I can't find the EVE binary in  targetfs.
    2.Yes,  I also notice a failure in UART, does it will  affect startup?  I deleted the ipu1 binary in boot partition, it could startup normal, there is still have a failure in UART. Please find the log  in attachment.
    3.Below is the dts file.
    Thanks a lot for your help
    Terence
    ====================================dra76-evm-infoadas.dts========================================
    #include "dra76-evm.dts"
    #define DISABLE_PRCM(label) &label { ti,no-idle; ti,no-reset-on-init; }
    #define DISABLE_COMPLETE(label) &label { status = "disabled"; ti,no-idle; ti,no-reset-on-init; }
    #define LATE_ATTACH(label) &label { ti,late-attach; ti,no-idle; ti,no-reset-on-init; }
    chosen {
    bootargs = "console=ttyO9,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait earlyprintk=ttyO9,115200n8 fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=16M rootfstype=ext4 snd.slots_reserved=1,1 loglevel=7 clk_ignore_unused init=/home/root/init-demo.sh";
    /* modules used by BIOS, disable from Linux */
    DISABLE_COMPLETE(vip1);
    DISABLE_COMPLETE(vip2);
    DISABLE_COMPLETE(cal);
    DISABLE_COMPLETE(i2c5);
    DISABLE_COMPLETE(wdt2);
    DISABLE_COMPLETE(vpe);
    DISABLE_COMPLETE(ocmcram1);
    DISABLE_COMPLETE(hdmi);
    DISABLE_COMPLETE(hdmi0);
    DISABLE_COMPLETE(dss);
    DISABLE_COMPLETE(dispc);
    DISABLE_COMPLETE(m_can0);
    DISABLE_COMPLETE(uart5);
    /* modules shared between BIOS and Linux, Do not reset or cutoff clks */
    DISABLE_PRCM(gpio1);
    DISABLE_PRCM(gpio2);
    DISABLE_PRCM(gpio3);
    DISABLE_PRCM(gpio4);
    DISABLE_PRCM(gpio5);
    DISABLE_PRCM(gpio6);
    /* Remote cores loaded by bootloader */
    LATE_ATTACH(ipu1);
    LATE_ATTACH(mmu_ipu1);
    LATE_ATTACH(ipu2);
    LATE_ATTACH(mmu_ipu2);
    LATE_ATTACH(dsp1);
    LATE_ATTACH(mmu0_dsp1);
    LATE_ATTACH(mmu1_dsp1);
    LATE_ATTACH(dsp2);
    LATE_ATTACH(mmu0_dsp2);
    LATE_ATTACH(mmu1_dsp2);
    /* timers used by the remote cores */
    LATE_ATTACH(timer3);
    LATE_ATTACH(timer4);
    LATE_ATTACH(timer5);
    LATE_ATTACH(timer6);
    LATE_ATTACH(timer7);
    LATE_ATTACH(timer9);
    LATE_ATTACH(timer11);
    LATE_ATTACH(timer13);
    LATE_ATTACH(timer14);
    LATE_ATTACH(mailbox5);
    LATE_ATTACH(mailbox6);
    LATE_ATTACH(mailbox7);
    /* Linux uses first 32 channels, BIOS uses last 32 */
    &edma {
    dma-requests = <32>;
    /* Update the CMA regions for Vision SDK binaries */
    &ipu2_cma_pool {
    reg = <0x0 0x96000000 0x0 0x2000000>;
    &dsp1_cma_pool {
    reg = <0x0 0x98000000 0x0 0x1000000>;
    &ipu1_cma_pool {
    reg = <0x0 0x9a000000 0x0 0x1000000>;
    &dsp2_cma_pool {
    reg = <0x0 0x99000000 0x0 0x1000000>;
    /* Additional memory regions required for Vision SDK
    * Keep this in sync with VSDK apps/build/tda2px/mem_segment_definition_linux.xs
    &reserved_mem {
    cmem_ocmc: cmem@40300000 {
    compatible = "shared-dma-pool";
    reg = <0x0 0x40300000 0x0 0x300000>;
    sram = <&ocmcram1>;
    no-map;
    status = "okay";
    cmem_pool: cmem@9e000000 {
    reg = <0x0 0x9e000000 0x0 0x1000000>;
    no-map;
    status = "okay";
    vsdk_sr1_mem: vsdk_sr1_mem@86000000 {
    reg = <0x0 0x86000000 0x0 0x9E00000>;
    status = "okay";
    vsdk_sr0_mem: vsdk_sr0_mem@9fb00000 {
    reg = <0x0 0x9fb00000 0x0 0x500000>;
    status = "okay";
    vsdk_eve_mem: vsdk_eve_mem@84000000 {
    reg = <0x0 0x84000000 0x0 0x1000000>;
    status = "okay";
    latea_pagetbl: late_pgtbl@90000000 {
    reg = <0x0 0x90000000 0x0 0x100000>;
    no-map;
    status = "okay";
    &ipu2 {
    /delete-property/ watchdog-timers;
    timers= <&timer9>,<&timer11>;
    &ipu1 {
    status = "okay";
    &dsp1 {
    &dsp2 {
    [BEGIN] 2018/12/14 10:48:37
    [    1.389664] console [ttyS9] enabled
    [    1.395799] bootconsole [earlycon0] disabled
    [    1.404502] [drm] Initialized drm 1.1.0 20060810
    [    1.410018] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.416679] [drm] No driver support for vblank timestamp query.
    [    1.422813] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.435874] loop: module loaded
    [    1.441725] vmemexp device MAJOR num = 245
    [    1.445879] vmemexp class registered
    [    1.449601] /dev/vmemexp device registered
    [    1.453716] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.462016] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.469705] libphy: Fixed MDIO Bus: probed
    [    1.524040] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.530165] libphy: 48485000.mdio: probed
    [    1.537499] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver RTL9000A Gigabit Ethernet
    [    1.547761] cpsw 48484000.ethernet: Detected MACID = f4:84:4c:14:9b:7e
    [    1.554428] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.561396] cpsw 48484000.ethernet: cpsw: Detected MACID = f4:84:4c:14:9b:7f
    [    1.570048] mousedev: PS/2 mouse device common for all mice
    [    1.576284] i2c /dev entries driver
    [    1.585049] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.589886] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.596379] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.602763] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.609163] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.615558] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.622201] vsys_3v3: supplied by vsys_12v0
    [    1.626472] vio_3v3: supplied by vsys_3v3
    [    1.630532] vio_3v3_sd: supplied by vio_3v3
    [    1.635024] ldo4: supplied by vsys_5v0
    [    1.684446] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.690831] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.714183] smps5: supplied by vsys_3v3
    [    1.718232] vio_1v8: supplied by smps5
    [    1.764950] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.776151] hwspinlock_user gatemp: requested 20 hwspinlocks
    [    1.783088] aic_dvdd: supplied by vio_3v3
    [    1.788393] davinci-mcasp 48464000.mcasp: DAI is shared
    [    1.793721] davinci-mcasp 48464000.mcasp: Can't verify DMA configuration (-19)
    [    1.801014] davinci-mcasp 48464000.mcasp: No DMA controller found (-19)
    [    1.808210] davinci-mcasp 48468000.mcasp: Can't verify DMA configuration (-19)
    [    1.815520] davinci-mcasp 48468000.mcasp: No DMA controller found (-19)
    [    1.822367] davinci-mcasp 48474000.mcasp: DAI is shared
    [    1.827720] davinci-mcasp 48474000.mcasp: Can't verify DMA configuration (-19)
    [    1.835009] davinci-mcasp 48474000.mcasp: No DMA controller found (-19)
    [    1.842783] NET: Registered protocol family 10
    [    1.858121] sit: IPv6 over IPv4 tunneling driver
    [    1.863307] NET: Registered protocol family 17
    [    1.868064] Key type dns_resolver registered
    [    1.872535] omap_voltage_late_init: Voltage driver support not added
    [    1.879440] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.885686] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.891968] buck10: supplied by vsys_3v3
    [    1.896554] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.902764] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.910098] Power Management for TI OMAP4+ devices.
    [    1.915222] Registering SWP/SWPB emulation handler
    [    1.921322] dmm 4e000000.dmm: workaround for errata i878 in use
    [    1.928717] dmm 4e000000.dmm: initialized all PAT entries
    [    1.935206] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    1.942894] hctosys: unable to open rtc device (rtc0)
    [    1.959635] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.960136] aic_dvdd: disabling
    [    1.960171] clk: Not disabling unused clocks
    [    1.960178] ALSA device list:
    [    1.960181]   No soundcards found.
    [    .981629] mmc0: new SDHC card at address 0001
    [    1.986255] Waiting for root device /dev/mmcblk0p2...
    [    2.001569] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
    [    2.007686]  mmcblk0: p1 p2
    [    2.068588] mmc1: MAN_BKOPS_EN bit is not set
    [    2.081083] mmc1: mmc_select_hs200 failed, error -74
    [    2.086090] : switch to mmc1 failed
    [    2.091059] mmc1: new MMC card at address 0001
    [    2.096006] mmcblk1: mmc1:0001 DG4008 7.28 GiB
    [    2.110886] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
    [    2.127188] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
    [    3.063116] EXT4-fs (mmcblk0p2): recovery complete
    [    3.074968] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.083126] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    3.100413] devtmpfs: mounted
    [    3.103609] Freeing unused kernel memory: 340K
    [    3.108091] This architecture does not have kernel memory protection.
    [    3.144659] Kernel Entry time 230936 ticks
    mount: unknown filesystem type 'dev'
    [    3.807033] systemd[1]: System time before build time, advancing clock.
    [    3.832838] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.846039] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    CCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    3.882307] systemd[1]: Detected architecture arm.
    [    3.905187] systemd[1]: Set hostname to <dra7xx-evm>.
    [    3.994231] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    4.027415] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    4.037694] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    4.059463] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    4.077628] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
    [    4.204345] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    4.213872] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    4.224096] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    4.440593] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    4.448440] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    4.456187] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    4.463450] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    4.470954] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
    [    4.478176] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    4.485630] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    4.495089] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [    4.526316] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [    4.554266] systemd[1]: Listening on udev Control Socket.
    [    4.576662] systemd[1]: Created slice User and Session Slice.
    [    4.594268] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.614203] systemd[1]: Listening on Syslog Socket.
    [    4.634353] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.664197] systemd[1]: Listening on udev Kernel Socket.
    [    4.687081] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.714379] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.744844] systemd[1]: Created slice System Slice.
    [    4.764892] systemd[1]: Created slice system-getty.slice.
    [    4.784841] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    4.804149] systemd[1]: Reached target Slices.
    [    4.824159] systemd[1]: Reached target Paths.
    [    4.844264] systemd[1]: Listening on Journal Socket.
    [    4.894264] systemd[1]: Mounting Debug File System...
    [    4.916551] systemd[1]: Starting Setup Virtual Console...
    [    4.936770] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [    4.966673] systemd[1]: Starting Journal Service...
    [    4.989033] systemd[1]: Mounting Temporary Directory...
    [    5.019580] systemd[1]: Starting Load Kernel Modules...
    [    5.041568] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.067223] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.078888] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.104206] systemd[1]: Reached target Remote File Systems.
    [    5.124180] systemd[1]: Reached target Swap.
    [    5.179485] systemd[1]: Mounted Debug File System.
    [    5.204258] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.224192] systemd[1]: Mounted Temporary Directory.
    [    5.244384] systemd[1]: Started Journal Service.
    [    6.021697] systemd-journald[101]: Received request to flush runtime journal from PID 1
    [    6.664142] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
    [    6.671997]  remoteproc0: 58820000.ipu is available
    [    6.680670]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    6.710275]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    6.726190] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
    [    6.748139]  remoteproc1: 55020000.ipu is available
    [    6.757186]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    6.789627]  remoteproc0: registered virtio0 (type 7)
    [    6.795043]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    6.840053] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
    [    6.854674]  remoteproc2: 40800000.dsp is available
    [    6.868943]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    6.902858]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    6.947935] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    6.968469] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
    [    7.006714]  remoteproc3: 41000000.dsp is available
    [    7.011643]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    7.026713]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [FAILED] Failed to start Synchronize System and HW c[    7.237388] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    locks.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [    7.682204] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    7.754467] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    7.760316] omap-aes 4b500000.aes: Unable to request in DMA channel
    [    7.803524] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    7.812584] omap-aes 4b700000.aes: Unable to request in DMA channel
    [  OK  ] Started D-Bus System Message Bus.
    [    9.105620]  remoteproc0: powering up 58820000.ipu
    [    9.111222]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 589684
    [    9.118282] ------------[ cut here ]------------
    [    9.122932] WARNING: CPU: 0 PID: 166 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
    [    9.132456] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET IPU1 (Read Link): At Address: 0x0008204C : Data Access in User mode during Functional access
    [    9.163940] CPU: 0 PID: 166 Comm: systemd-udevd Not tainted 4.4.84 #1
    [    9.170408] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.176526] Backtrace:
    [    9.178999] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [    9.186600]  r7:c02e3bb0 r6:20090193 r5:00000000 r4:c0959350
    [    9.192326] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
    [    9.199585] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
    [    9.207707]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:dc58f8f0
    [    9.213433] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
    [    9.222167]  r8:00000017 r7:c084c280 r6:00000004 r5:c084c334 r4:c084c3e4
    [    9.228947] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
    [    9.237856]  r3:df20a940 r2:c084c3e4
    [    9.241461]  r4:80080001
    [    9.244019] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
    [    9.253363]  r10:c0988e4b r9:df208240 r8:00000017 r7:00000000 r6:00000000 r5:df2082a0
    [    9.261272]  r4:df20ae40
    [    9.263830] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
    [    9.272739]  r10:00000000 r9:00000000 r8:df008000 r7:00000000 r6:c0941c8c r5:df2082a0
    [    9.280651]  r4:df208240
    [    9.283208] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
    [    9.291767]  r7:00000000 r6:c0941c8c r5:df2082a0 r4:df208240
    [    9.297492] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
    [    9.306139]  r7:00000000 r6:00000000 r5:00000017 r4:c093640c
    [    9.311864] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
    [    9.320604] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [    9.328989]  r9:00000000 r8:fa213000 r7:fa212000 r6:dc58fab0 r5:fa21200c r4:c093c8e4
    [    9.336813] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [    9.344326] Exception stack(0xdc58fab0 to 0xdc58faf8)
    [    9.349400] faa0:                                     df26aa10 00000000 00008000 00000000
    [    9.357615] fac0: d357c000 df2ef840 d351b800 d351b7d4 df2f4e10 00000000 00000000 dc58fb0c
    [    9.365828] fae0: dc58fb10 dc58fb00 c02ce9d4 c02ce944 20090013 ffffffff
    [    9.372470]  r9:00000000 r8:df2f4e10 r7:dc58fae4 r6:ffffffff r5:20090013 r4:c02ce944
    [    9.380299] [<c02ce9c4>] (devm_ioremap) from [<c037fe18>] (omap_iommu_attach_dev+0x304/0x3b4)
    [    9.388864] [<c037fb14>] (omap_iommu_attach_dev) from [<c037da2c>] (iommu_attach_device+0x8c/0xac)
    [    9.397860]  r10:d351b680 r9:df257410 r8:dc6bd420 r7:dc6bd5ac r6:dc6bd5b4 r5:d351b7d4
    [    9.405769]  r4:00000000
    [    9.408336] [<c037d9a0>] (iommu_attach_device) from [<bf05ab98>] (rproc_boot+0x2e0/0x55c [remoteproc])
    [    9.417681]  r7:dc6bd5ac r6:dc6bd5b4 r5:00000000 r4:dc6bd400
    [    9.423423] [<bf05a8b8>] (rproc_boot [remoteproc]) from [<bf05bae4>] (rproc_virtio_find_vqs+0x18c/0x1f0 [remoteproc])
    [    9.434074]  r10:dc6bd420 r9:00000002 r8:bf126d5c r7:dc6bd810 r6:dc6bd9f0 r5:dc58fc44
    [    9.441982]  r4:00000002
    [    9.444558] [<bf05b958>] (rproc_virtio_find_vqs [remoteproc]) from [<bf1262f0>] (rpmsg_probe+0xbc/0x474 [virtio_rpmsg_bus])
    [    9.455734]  r10:00000000 r9:00000000 r8:dc6bd810 r7:dc58fc38 r6:dc6bd400 r5:d4909e80
    [    9.463643]  r4:bf05b958
    [    9.466212] [<bf126234>] (rpmsg_probe [virtio_rpmsg_bus]) from [<bf03585c>] (virtio_dev_probe+0x230/0x310 [virtio])
    [    9.476689]  r10:00000000 r9:00000000 r8:00000000 r7:dc6bd820 r6:dc6bd810 r5:00000000
    [    9.484596]  r4:00000000
    [    9.487158] [<bf03562c>] (virtio_dev_probe [virtio]) from [<c03ec44c>] (driver_probe_device+0x204/0x2f8)
    [    9.496677]  r10:00000000 r9:d351b3c8 r8:0000000f r7:bf126dfc r6:00000000 r5:dc6bd820
    [    9.504584]  r4:c09c5a44
    [    9.507138] [<c03ec248>] (driver_probe_device) from [<c03ec5d4>] (__driver_attach+0x94/0x98)
    [    9.515610]  r9:d351b3c8 r8:2cae4c5c r7:00000000 r6:dc6bd854 r5:bf126dfc r4:dc6bd820
    [    9.523438] [<c03ec540>] (__driver_attach) from [<c03ea6d4>] (bus_for_each_dev+0x70/0xa4)
    [    9.531648]  r7:00000000 r6:c03ec540 r5:bf126dfc r4:00000000
    [    9.537375] [<c03ea664>] (bus_for_each_dev) from [<c03ebd38>] (driver_attach+0x24/0x28)
    [    9.545412]  r6:bf035d58 r5:d4909f00 r4:bf126dfc
    [    9.550077] [<c03ebd14>] (driver_attach) from [<c03eb974>] (bus_add_driver+0x1a8/0x220)
    [    9.558117] [<c03eb7cc>] (bus_add_driver) from [<c03ecd74>] (driver_register+0x80/0x100)
    [    9.566240]  r7:d351b4c0 r6:c093f6f0 r5:bf12a000 r4:bf126dfc
    [    9.571966] [<c03eccf4>] (driver_register) from [<bf035aa4>] (register_virtio_driver+0x30/0x44 [virtio])
    [    9.581486]  r5:bf12a000 r4:00000000
    [    9.585110] [<bf035a74>] (register_virtio_driver [virtio]) from [<bf12a044>] (rpmsg_init+0x44/0x84 [virtio_rpmsg_bus])
    [    9.595865] [<bf12a000>] (rpmsg_init [virtio_rpmsg_bus]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [    9.605297]  r5:bf12a000 r4:c093f6f0
    [    9.608914] [<c00097f4>] (do_one_initcall) from [<c00d46f0>] (do_init_module+0x68/0x398)
    [    9.617038]  r10:bf126f00 r9:d351b3c8 r8:2cae4c5c r7:00000001 r6:d351b480 r5:00000001
    [    9.624946]  r4:bf126f00
    [    9.627504] [<c00d4688>] (do_init_module) from [<c00b10e0>] (load_module+0x1df8/0x2068)
    [    9.635541]  r6:d351b3c0 r5:00000001 r4:dc58ff44
    [    9.640207] [<c00af2e8>] (load_module) from [<c00b153c>] (SyS_finit_module+0x88/0x98)
    [    9.648069]  r10:00000000 r9:dc58e000 r8:c000fe24 r7:0000017b r6:b6e06d90 r5:0000000f
    [    9.655980]  r4:00000000
    [    9.658537] [<c00b14b4>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [    9.666748]  r6:00000000 r5:004db928 r4:00000000
    [    9.671412] ---[ end trace 44820c8366073f3b ]---
    [    9.676144] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [    9.683224] pgd = dc5b0000
    [    9.685943] [00000000] *pgd=00000000
    [    9.689547] Internal error: : 1406 [#1] PREEMPT SMP ARM
    [    9.712393] CPU: 0 PID: 166 Comm: systemd-udevd Tainted: G        W       4.4.84 #1
    [    9.720083] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.726203] task: dca2e000 ti: dc58e000 task.ti: dc58e000
    [    9.731627] PC is at devm_ioremap_nocache+0x0/0x80
    [    9.736440] LR is at devm_ioremap+0x10/0x14
    [    9.740643] pc : [<c02ce944>]    lr : [<c02ce9d4>]    psr: 20090013
    [    9.740643] sp : dc58fb00  ip : dc58fb10  fp : dc58fb0c
    [    9.752170] r10: 00000000  r9 : 00000000  r8 : df2f4e10
    [    9.757418] r7 : d351b7d4  r6 : d351b800  r5 : df2ef840  r4 : d357c000
    [    9.763973] r3 : 00000000  r2 : 00008000  r1 : 00000000  r0 : df26aa10
    [    9.770530] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    9.777695] Control: 10c5387d  Table: 9c5b006a  DAC: 00000051
    [    9.783466] Process systemd-udevd (pid: 166, stack limit = 0xdc58e210)
    [    9.790023] Stack: (0xdc58fb00 to 0xdc590000)
    [    9.794402] fb00: dc58fb4c dc58fb10 c037fe18 c02ce9d0 d351b7d0 df257410 c037fec8 00000000
    [    9.802616] fb20: dc6bd5b4 00000000 d351b7d4 dc6bd5b4 dc6bd5ac dc6bd420 df257410 d351b680
    [    9.810832] fb40: dc58fb6c dc58fb50 c037da2c c037fb20 dc6bd400 00000000 dc6bd5b4 dc6bd5ac
    [    9.819046] fb60: dc58fbb4 dc58fb70 bf05ab98 c037d9ac 00000000 d351b7d4 dc58fbb4 d351b680
    [    9.827262] fb80: bf0055a4 c01158f4 dc6bd810 00000002 dc58fc44 dc6bd9f0 dc6bd810 bf126d5c
    [    9.835475] fba0: 00000002 dc6bd420 dc58fc1c dc58fbb8 bf05bae4 bf05a8c4 00000000 da004000
    [    9.843691] fbc0: bf05b724 bf125f7c bf126d5c d351c5f0 00000100 dc6bd400 bf05b724 da004000
    [    9.851905] fbe0: dc6bd800 bf125f7c dc58fc3c bf126838 c02b9030 bf05b958 d4909e80 dc6bd400
    [    9.860119] fc00: dc58fc38 dc6bd810 00000000 00000000 dc58fc84 dc58fc20 bf1262f0 bf05b964
    [    9.868334] fc20: bf126834 df18d960 dc58fc6c dc58fc38 c01879b8 c01877bc bf125fa8 bf125f7c
    [    9.876550] fc40: df3e5000 df3e5800 dc58fc6c dc58fc58 bf05bc48 bf006420 dc6bd810 00000000
    [    9.884764] fc60: 00000000 dc6bd810 dc6bd820 00000000 00000000 00000000 dc58fce4 dc58fc88
    [    9.892978] fc80: bf03585c bf126240 c0189fb0 c018677c dc6bd820 00000000 dc6bd810 bf126dfc
    [    9.901193] fca0: 00000001 00000000 dc6bd820 bf126dfc c018a02c c0189f44 dc58fce4 c09c5a44
    [    9.909409] fcc0: dc6bd820 00000000 bf126dfc 0000000f d351b3c8 00000000 dc58fd0c dc58fce8
    [    9.917624] fce0: c03ec44c bf035638 dc6bd820 bf126dfc dc6bd854 00000000 2cae4c5c d351b3c8
    [    9.925838] fd00: dc58fd2c dc58fd10 c03ec5d4 c03ec254 00000000 bf126dfc c03ec540 00000000
    [    9.934053] fd20: dc58fd54 dc58fd30 c03ea6d4 c03ec54c db03005c dc608ab4 db030070 bf126dfc
    [    9.942266] fd40: d4909f00 bf035d58 dc58fd64 dc58fd58 c03ebd38 c03ea670 dc58fd8c dc58fd68
    [    9.950481] fd60: c03eb974 c03ebd20 bf126d64 dc58fd78 bf126dfc bf12a000 c093f6f0 d351b4c0
    [    9.958695] fd80: dc58fda4 dc58fd90 c03ecd74 c03eb7d8 00000000 bf12a000 dc58fdb4 dc58fda8
    [    9.966909] fda0: bf035aa4 c03ecd00 dc58fdcc dc58fdb8 bf12a044 bf035a80 c093f6f0 bf12a000
    [    9.975124] fdc0: dc58fe4c dc58fdd0 c000988c bf12a00c 00000000 00080000 00000001 df92a9d8
    [    9.983339] fde0: d4846740 c0109ab0 dc58e000 df001e40 dc58fe08 0001c5b2 dc58fe3c dc58fe08
    [    9.991555] fe00: c01146b4 c0113b5c 00000001 c0109ab0 2cae4c5c 0000002c d4846740 e4256000
    [    9.999770] fe20: 00000001 bf126f00 00000001 d351b480 00000001 2cae4c5c d351b3c8 bf126f00
    [   10.007984] fe40: dc58fe74 dc58fe50 c00d46f0 c0009800 dc58fe74 dc58fe60 c0109b9c dc58ff44
    [   10.016200] fe60: 00000001 d351b3c0 dc58ff3c dc58fe78 c00b10e0 c00d4694 bf126f0c 00007fff
    [   10.024414] fe80: bf126f00 c00ae2dc dc535540 c082c060 c082c038 c082c02c c082c090 c0691768
    [   10.032630] fea0: 00000000 bf126f0c e4281c88 bf1270a0 c093c4ac bf1270c8 bf126f48 c00adc4c
    [   10.040846] fec0: bf1268a2 00020001 00000187 00000000 0b300002 bf126774 00000008 00000000
    [   10.049060] fee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   10.057276] ff00: 00000000 00000000 00000000 00000000 00000160 00000000 0000000f b6e06d90
    [   10.065491] ff20: 0000017b c000fe24 dc58e000 00000000 dc58ffa4 dc58ff40 c00b153c c00af2f4
    [   10.073706] ff40: 00000002 e4256000 0002bcd8 e42815a8 e427533a e42765c4 000020c8 00002b08
    [   10.081921] ff60: 00000000 00000000 00000000 00001da8 0000002c 0000002d 00000017 00000013
    [   10.090137] ff80: 00000010 00000000 00000000 00000000 004db928 00000000 00000000 dc58ffa8
    [   10.098351] ffa0: c000fc60 c00b14c0 00000000 004db928 0000000f b6e06d90 00000000 004deb10
    [   10.106566] ffc0: 00000000 004db928 00000000 0000017b 004eb3b8 00000000 004eb3b8 004eb630
    [   10.114780] ffe0: befe09d8 befe09c8 b6dffc08 b6f02df2 600f0030 0000000f 9face861 9facec61
    [   10.122989] Backtrace:
    [   10.125461] [<c02ce9c4>] (devm_ioremap) from [<c037fe18>] (omap_iommu_attach_dev+0x304/0x3b4)
    [   10.134026] [<c037fb14>] (omap_iommu_attach_dev) from [<c037da2c>] (iommu_attach_device+0x8c/0xac)
    [   10.143023]  r10:d351b680 r9:df257410 r8:dc6bd420 r7:dc6bd5ac r6:dc6bd5b4 r5:d351b7d4
    [   10.150932]  r4:00000000
    [   10.153503] [<c037d9a0>] (iommu_attach_device) from [<bf05ab98>] (rproc_boot+0x2e0/0x55c [remoteproc])
    [   10.162849]  r7:dc6bd5ac r6:dc6bd5b4 r5:00000000 r4:dc6bd400
    [   10.168590] [<bf05a8b8>] (rproc_boot [remoteproc]) from [<bf05bae4>] (rproc_virtio_find_vqs+0x18c/0x1f0 [remoteproc])
    [   10.179244]  r10:dc6bd420 r9:00000002 r8:bf126d5c r7:dc6bd810 r6:dc6bd9f0 r5:dc58fc44
    [   10.187154]  r4:00000002
    [   10.189729] [<bf05b958>] (rproc_virtio_find_vqs [remoteproc]) from [<bf1262f0>] (rpmsg_probe+0xbc/0x474 [virtio_rpmsg_bus])
    [   10.200905]  r10:00000000 r9:00000000 r8:dc6bd810 r7:dc58fc38 r6:dc6bd400 r5:d4909e80
    [   10.208813]  r4:bf05b958
    [   10.211382] [<bf126234>] (rpmsg_probe [virtio_rpmsg_bus]) from [<bf03585c>] (virtio_dev_probe+0x230/0x310 [virtio])
    [   10.221860]  r10:00000000 r9:00000000 r8:00000000 r7:dc6bd820 r6:dc6bd810 r5:00000000
    [   10.229767]  r4:00000000
    [   10.232329] [<bf03562c>] (virtio_dev_probe [virtio]) from [<c03ec44c>] (driver_probe_device+0x204/0x2f8)
    [   10.241847]  r10:00000000 r9:d351b3c8 r8:0000000f r7:bf126dfc r6:00000000 r5:dc6bd820
    [   10.249755]  r4:c09c5a44
    [   10.252308] [<c03ec248>] (driver_probe_device) from [<c03ec5d4>] (__driver_attach+0x94/0x98)
    [   10.260782]  r9:d351b3c8 r8:2cae4c5c r7:00000000 r6:dc6bd854 r5:bf126dfc r4:dc6bd820
    [   10.268612] [<c03ec540>] (__driver_attach) from [<c03ea6d4>] (bus_for_each_dev+0x70/0xa4)
    [   10.276822]  r7:00000000 r6:c03ec540 r5:bf126dfc r4:00000000
    [   10.282546] [<c03ea664>] (bus_for_each_dev) from [<c03ebd38>] (driver_attach+0x24/0x28)
    [   10.290583]  r6:bf035d58 r5:d4909f00 r4:bf126dfc
    [   10.295250] [<c03ebd14>] (driver_attach) from [<c03eb974>] (bus_add_driver+0x1a8/0x220)
    [   10.303291] [<c03eb7cc>] (bus_add_driver) from [<c03ecd74>] (driver_register+0x80/0x100)
    [   10.311413]  r7:d351b4c0 r6:c093f6f0 r5:bf12a000 r4:bf126dfc
    [   10.317140] [<c03eccf4>] (driver_register) from [<bf035aa4>] (register_virtio_driver+0x30/0x44 [virtio])
    [   10.326660]  r5:bf12a000 r4:00000000
    [   10.330283] [<bf035a74>] (register_virtio_driver [virtio]) from [<bf12a044>] (rpmsg_init+0x44/0x84 [virtio_rpmsg_bus])
    [   10.341036] [<bf12a000>] (rpmsg_init [virtio_rpmsg_bus]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [   10.350467]  r5:bf12a000 r4:c093f6f0
    [   10.354082] [<c00097f4>] (do_one_initcall) from [<c00d46f0>] (do_init_module+0x68/0x398)
    [   10.362206]  r10:bf126f00 r9:d351b3c8 r8:2cae4c5c r7:00000001 r6:d351b480 r5:00000001
    [   10.370113]  r4:bf126f00
    [   10.372670] [<c00d4688>] (do_init_module) from [<c00b10e0>] (load_module+0x1df8/0x2068)
    [   10.380706]  r6:d351b3c0 r5:00000001 r4:dc58ff44
    [   10.385373] [<c00af2e8>] (load_module) from [<c00b153c>] (SyS_finit_module+0x88/0x98)
    [   10.393235]  r10:00000000 r9:dc58e000 r8:c000fe24 r7:0000017b r6:b6e06d90 r5:0000000f
    [   10.401146]  r4:00000000
    [   10.403701] [<c00b14b4>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   10.411912]  r6:00000000 r5:004db928 r4:00000000
    [   10.416581] Code: e24cb004 e5910000 ebf53e2c e89da800 (e1a0c00d)
    [   10.422703] ---[ end trace 44820c8366073f3c ]---
    [   10.427342] note: systemd-udevd[166] exited with preempt_count 1
    [   10.473498] SCSI subsystem initialized
    [   11.030506]  remoteproc2: powering up 40800000.dsp
    [   11.035394]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583987
    [   11.042416] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [   11.048374] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [   11.055814]  remoteproc2: remote processor 40800000.dsp is now up
    [   11.062170] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   11.069335]  remoteproc2: registered virtio1 (type 7)
    [   11.236673]  remoteproc3: powering up 41000000.dsp
    [   11.241501]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583987
    [   11.248606] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [   11.254568] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [   11.261722]  remoteproc3: remote processor 41000000.dsp is now up
    [   11.268155] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   11.275704]  remoteproc3: registered virtio2 (type 7)
    [   11.608441] libata version 3.00 loaded.
    [   11.631306] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [   11.859510]  remoteproc1: powering up 55020000.ipu
    [   11.864390]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9392404
    [   11.871389] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [   11.882280]  remoteproc1: remote processor 55020000.ipu is now up
    [   11.888720] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   11.897727]  remoteproc1: registered virtio3 (type 7)
    [   11.921702] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [   11.927829] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [   11.937115] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [   11.949202] scsi host0: ahci
    [   11.952910] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
    [   12.182399] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [   12.304093] ata1: SATA link down (SStatus 0 SControl 300)
    [   12.330286] usbcore: registered new interface driver usbfs
    [   12.338964] usbcore: registered new interface driver hub
    [   12.346127] usbcore: registered new device driver usb
             Starting Login Service...
             Starting Network Service...
    [  OK  ] Started rc.pvr.service.
    [   12.491952] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Found device /dev/ttyS9.
    [   12.582698] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.588572] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.597083] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [   12.606061] xhci-hcd xhci-hcd.2.auto: irq 462, io mem 0x488d0000
    [   12.613325] hub 1-0:1.0: USB hub found
    [   12.617991] hub 1-0:1.0: 1 port detected
    [   12.626660] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.632206] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.640068] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.649100] hub 2-0:1.0: USB hub found
    [   12.652920] hub 2-0:1.0: 1 port detected
    [  OK  ] Started Network Service.
    [   12.691382] net eth1: initializing cpsw version 1.15 (0)
    [   12.700391] net eth0: initialized cpsw ale version 1.4
    [   12.708728] net eth0: ALE Table size 1024
    [   12.876011] net eth1: phy found : id is : 0x1ccb00
    [   12.889363] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   12.897350] net eth0: initializing cpsw version 1.15 (0)
    [   12.908005] libphy: PHY 48485000.mdio:01 not found
    [   12.912828] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
    [   12.927125] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Reached target Network.
             Starting Network Name Resolution...
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Started Serial Getty on ttyS9.
    [  OK  ] Started Getty on tty1.
             Starting weston.service...
    [  OK  ] Started Login Service.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started weston.service.
             Starting tiipclad-daemon.service...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started tiipclad-daemon.service.
             Starting ecarxinit.service...
    [   13.844775] DMA: Module install successful, device major num = 242
    [   13.851076] DRV: Module install successful
    [  OK  ] Started ecarxinit.service.
    [  18.402809] omap8250 4806a000.serial: failed to request DMA
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dra7xx-evm ttyS9
    Arago 2016.12 dra7xx-evm ttyS9
    dra7xx-evm login: root
    root@dra7xx-evm:~#
    root@dra7xx-evm:~# cd /opt/vision_sdk/
    root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh
    insmod: ERROR: could not insert module ./bin/memcache.ko: File exists
    insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory
    mknod: /dev/memcache: File exists
    Error: I2C Read failed
    ./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
    updated  value is
    COMMANDS
    	### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
    	No address check done, may generate:
    	  - bus error (invalid or not accessible <physical address>,
    	  - platform crash/hang (bad <value>).
    	    Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Dump a range of OMAP memory addresses, from <start address> to <end address>.
    	    Note all addresses within given range must be valid and accessible.
    	### WARNING ###: use the following I2C [read | write] commands at your own risk!
    	  - I2C bus error (invalid or not accessible <physical address>,
    	    Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    	    Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    root@dra7xx-evm:/opt/vision_sdk# vi vision_sdk_load.sh
    root@dra7xx-evm:/opt/vision_sdk# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib/
    root@dra7xx-evm:/opt/vision_sdk# ./apps.out &
    [1] 694
    root@dra7xx-evm:/opt/vision_sdk#  [HOST]  OSA: MEM: 0: Mapped 0x9fc00000 to 0xb5e74000 of size 0x00100000
     [HOST]  OSA: MEM: 1: Mapped 0x86203000 to 0xac374000 of size 0x09b00000
     [HOST]  OSA: MEM: 2: Mapped 0x9fd00000 to 0xac2b4000 of size 0x00040000
     [HOST]  OSA: MEM: 3: Mapped 0x9fdc0000 to 0xac2f4000 of size 0x00080000
     [HOST]  OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
     [HOST]  OSA: IPU1-0 Remote Log Shared Memory @ 0x9fd00000
     [HOST]  OSA: HOST Remote Log Shared Memory @ 0x9fd4f140
     [HOST]  OSA: DSP1 Remote Log Shared Memory @ 0x9fd769e0
     [HOST]  OSA: DSP2 Remote Log Shared Memory @ 0x9fd9e280
     [HOST]  OSA: IPU2 Remote Log Shared Memory @ 0x9fe63da0
     [HOST] [DSP1  ]    110.853230 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    111.865247 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    112.888183 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    115.853352 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    115.865369 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    117.888336 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    119.853474 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    120.865491 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    121.888427 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    123.853596 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    124.865613 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    125.888549 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    127.853687 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    128.865704 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    129.888641 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    132.865826 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    140.854053 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    142.889007 s:  SYSTEM: Attaching to [IPU1-0] ...
    [  139.241918] random: nonblocking pool is initialized
    root@dra7xx-evm:/opt/vision_sdk#  [HOST] [DSP1  ]    149.854297 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    150.854297 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    150.866314 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    150.889221 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    151.854328 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    151.866345 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    151.889251 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    152.854358 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    152.889282 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    153.866375 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    154.854419 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    154.889343 s:  SYSTEM: Attaching to [IPU1-0] ...
    [END] 2018/12/14 10:51:22
  • Hi Terence,
    I notice you've modified the cma regions for IPU and DSP. You need to make this modification in Vision-SDK and in u-boot.
    In Vision-SDK please modify apps/build/tda2px/mem_segment_definition_linux.xs and in u-boot you need to modify board/ti/dra7xx/lateattach.c the macros DRA7_RPROC_CMA_BASE for each core.
    Please perform a clean build after making all these changes.
    Shravan
  • Hi Shravan,
    1. Yes,we changed it, but I'm confirmed that we have modified the same memory regions in Vision-SDK(apps/build/tda2px/mem_segment_definition_linux.xs)and in u-boot(board/ti/dra7xx/lateattach.c ) before.  Now, We try it again, system crash  remains.Please find the early_boot.log in attachment.
    2. In boot partition of my SD card,there are seven binaries include uImage, single-stage-boot.dtb, MLO, dra7-ipu2-fw.lzop, dra7-ipu1-fw.lzop, dra7-dsp2-fw.lzop,  dra7-dsp1-fw.lzop.
    3.The other problem, I delete the dra7-ipu1-fw.lzop in my boot partition of sd card, it does’t crash,  but it may be failure, because I see the log said “SYSTEM: Attaching to [IPU1-0]”, when running the app.out to test. Please find the early_boot_no_ipu1_in_boot_partition.log in attachment.
    Thanks a lot for your support
    Terence
    [BEGIN] 2018/12/17 10:44:09
    �� 1.423142] console [ttyS9] enabled
    [    1.429241] bootconsole [earlycon0] disabled
    [    1.437941] [drm] Initialized drm 1.1.0 20060810
    [    1.443495] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.450139] [drm] No driver support for vblank timestamp query.
    [    1.456307] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.469258] loop: module loaded
    [    1.475217] vmemexp device MAJOR num = 245
    [    1.479348] vmemexp class registered
    [    1.483092] /dev/vmemexp device registered
    [    1.487206] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.495487] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.503159] libphy: Fixed MDIO Bus: probed
    [    1.550495] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.556619] libphy: 48485000.mdio: probed
    [    1.564172] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver RTL9000A Gigabit Ethernet
    [    1.574456] cpsw 48484000.ethernet: Detected MACID = f4:84:4c:14:9b:7e
    [    1.581147] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.588102] cpsw 48484000.ethernet: cpsw: Detected MACID = f4:84:4c:14:9b:7f
    [    1.596790] mousedev: PS/2 mouse device common for all mice
    [    1.603052] i2c /dev entries driver
    [    1.611878] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.616719] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.623235] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.629618] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.636016] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.642412] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.649056] vsys_3v3: supplied by vsys_12v0
    [    1.653324] vio_3v3: supplied by vsys_3v3
    [    1.657384] vio_3v3_sd: supplied by vio_3v3
    [    1.662216] ldo4: supplied by vsys_5v0
    [    1.710901] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.717288] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.740634] smps5: supplied by vsys_3v3
    [    1.744681] vio_1v8: supplied by smps5
    [    1.791403] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.802604] hwspinlock_user gatemp: requested 20 hwspinlocks
    [    1.809535] aic_dvdd: supplied by vio_3v3
    [    1.814816] davinci-mcasp 48464000.mcasp: DAI is shared
    [    1.820142] davinci-mcasp 48464000.mcasp: Can't verify DMA configuration (-19)
    [    1.827414] davinci-mcasp 48464000.mcasp: No DMA controller found (-19)
    [    1.834595] davinci-mcasp 48468000.mcasp: Can't verify DMA configuration (-19)
    [    1.841892] davinci-mcasp 48468000.mcasp: No DMA controller found (-19)
    [    1.848739] davinci-mcasp 48474000.mcasp: DAI is shared
    [    1.854073] davinci-mcasp 48474000.mcasp: Can't verify DMA configuration (-19)
    [    1.861342] davinci-mcasp 48474000.mcasp: No DMA controller found (-19)
    [    1.869118] NET: Registered protocol family 10
    [    1.884433] sit: IPv6 over IPv4 tunneling driver
    [    1.889623] NET: Registered protocol family 17
    [    1.894371] Key type dns_resolver registered
    [    1.898842] omap_voltage_late_init: Voltage driver support not added
    [    1.905734] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.911961] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.918246] buck10: supplied by vsys_3v3
    [    1.922830] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.929039] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.936351] Power Management for TI OMAP4+ devices.
    [    1.941455] Registering SWP/SWPB emulation handler
    [    1.947527] dmm 4e000000.dmm: workaround for errata i878 in use
    [    1.954908] dmm 4e000000.dmm: initialized all PAT entries
    [    1.961356] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    1.969014] hctosys: unable to open rtc device (rtc0)
    [    1.985970] aic_dvdd: disabling
    [    1.986052] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.986135] mmc0: new SDHC card at address 0001
    [    1.996751] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
    [    1.998657]  mmcblk0: p1 p2
    [    2.009053] clk: Not disabling unused clocks
    [    2.013362] ALSA device list:
    [    2.016342]   No soundcards found.
    [    2.065062] mmc1: MAN_BKOPS_EN bit is not set
    [    2.077161] mmc1: mmc_select_hs200 failed, error -74
    [    2.082258] : switch to mmc1 failed
    [    2.087225] mmc1: new MMC card at address 0001
    [    2.092145] mmcblk1: mmc1:0001 DG4008 7.28 GiB
    [    2.097814] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
    [    2.104764] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
    [    2.769819] EXT4-fs (mmcblk0p2): recovery complete
    [    2.779065] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.787242] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.794826] devtmpfs: mounted
    [    2.798018] Freeing unused kernel memory: 340K
    [    2.802498] This architecture does not have kernel memory protection.
    [    2.838871] Kernel Entry time 234082 ticks
    [    3.465031] systemd[1]: System time before build time, advancing clock.
    [    3.511214] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.524416] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.542029] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    3.560691] systemd[1]: Detected architecture arm.
    Welcome to Arago 2016.12!
    [    3.581574] systemd[1]: Set hostname to <dra7xx-evm>.
    [    3.587587] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.596898] systemd[1]: Initializing machine ID from random generator.
    [    3.684952] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    3.724483] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    3.729085] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    3.736282] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    3.754621] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    4.601158] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    4.610743] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    4.824165] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    4.832002] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    4.839703] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    4.846989] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    4.854454] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    4.863919] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [    4.902890] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.930951] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    4.950707] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.970673] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.990588] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.010793] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    5.040663] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.060705] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [    5.090691] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.110840] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    5.143229] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    5.162201] systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    [    5.220845] systemd[1]: Starting Load Kernel Modules...
    [    5.241410] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    5.261388] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    5.283189] systemd[1]: Starting Create list of required static device nodes for the current kernel...
             Starting Create list of required st... nodes for the current kernel...
    [    5.340865] systemd[1]: Starting Journal Service...
    [    5.370111] systemd[1]: Mounting Temporary Directory...
    [    5.390739] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    5.411422] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    5.440629] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    5.490885] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.511348] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.513497] systemd[1]: Starting Setup Virtual Console...
    [    5.543848] systemd[1]: Mounting Debug File System...
    [    5.573107] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.609652] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    5.630724] systemd[1]: Mounted Debug File System.
    [  OK  ] Mounted Debug File System.
    [    5.650653] systemd[1]: Mounted Temporary Directory.
    [  OK  ] Mounted Temporary Directory.
    [    5.670873] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Setup Virtual Console.
             Starting udev Coldplug all Devices...
             Starting Load/Save Random Seed...
             Starting Create Static Device Nodes in /dev...
             Starting Apply Kernel Variables...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started Apply Kernel Variables.
    [    6.503203] systemd-journald[99]: Received request to flush runtime journal from PID 1
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Time Synchronization...
    [    7.177123] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
    [    7.198494]  remoteproc0: 58820000.ipu is available
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    7.222273]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [  OK  ] Started Network Time Synchronization.
    [    7.257816]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    7.309630] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
    [    7.335054]  remoteproc1: 55020000.ipu is available
    [   7.356665]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    7.374996]  remoteproc0: registered virtio0 (type 7)
    [  OK  ] Found device /dev/ttyS0.
    [    7.389928]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    7.406840] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    7.418026] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
    [    7.431223]  remoteproc2: 40800000.dsp is available
    [    7.436140]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    7.436143]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    7.440344] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
    [    7.440414]  remoteproc3: 41000000.dsp is available
    [    7.440418]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    7.440421]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    7.448141] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
             Starting Synchronize System and HW clocks...
    [  OK  ] Reached target System Time Synchronized.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started System Logging Service.
    [    8.251980] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    8.257853] omap-aes 4b500000.aes: Unable to request in DMA channel
    [    8.283241] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    8.299898] omap-aes 4b700000.aes: Unable to request in DMA channel
    [    8.311471] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    9.390746] SCSI subsystem initialized
    [    9.529421]  remoteproc0: powering up 58820000.ipu
    [    9.535038]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 589684
    [    9.542356] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
    [    9.549319]  remoteproc0: remote processor 58820000.ipu is now up
    [    9.556559] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.562685] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
    [    9.923239]  remoteproc2: powering up 40800000.dsp
    [    9.928070]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583987
    [    9.935484] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    9.941436] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    9.949051]  remoteproc2: remote processor 40800000.dsp is now up
    [    9.955442] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.962485]  remoteproc2: registered virtio1 (type 7)
    [    9.968454] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
    [   10.011863]  remoteproc3: powering up 41000000.dsp
    [   10.017143]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583987
    [   10.024278] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [   10.030196] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [   10.037869]  remoteproc3: remote processor 41000000.dsp is now up
    [   10.044313] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   10.051962]  remoteproc3: registered virtio2 (type 7)
    [   10.057948] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
    [   10.173416] NET: Registered protocol family 41
    [   10.576167] libata version 3.00 loaded.
    [   10.661026] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [   10.869481]  remoteproc1: powering up 55020000.ipu
    [   10.875978]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9392404
    [   10.883601] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [   10.892304]  remoteproc1: remote processor 55020000.ipu is now up
    [   10.900306] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [   10.907375] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   10.913137] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [   10.923352]  remoteproc1: registered virtio3 (type 7)
    [   10.923375] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [   10.939022] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x50
    [   10.962576] scsi host0: ahci
    [   10.965866] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
             Starting Permit User Sessions...
    [  OK  ] Started Kernel Logging Service.
             Starting rc.pvr.service...
    [   11.320516] ata1: SATA link down (SStatus 0 SControl 300)
    [   11.437506] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   11.449453] usbcore: registered new interface driver usbfs
    [   11.468408] usbcore: registered new interface driver hub
    [   11.481562] usbcore: registered new device driver usb
    [   11.502688] net eth1: initializing cpsw version 1.15 (0)
    [[   11.512870] net eth0: initialized cpsw ale version 1.4
    [   11.521986] net eth0: ALE Table size 1024
    [   11.538441] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [   11.712201] net eth1: phy found : id is : 0x1ccb00
    [   11.724556] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   11.732758] net eth0: initializing cpsw version 1.15 (0)
    [   11.741215] libphy: PHY 48485000.mdio:01 not found
    [   11.746059] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
    [   11.758284] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   12.159375] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.165874] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   12.174766] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [   12.184195] xhci-hcd xhci-hcd.2.auto: irq 462, io mem 0x488d0000
    [   12.193487] hub 1-0:1.0: USB hub found
    [   12.198360] hub 1-0:1.0: 1 port detected
    [   12.205797] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   12.211527] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   12.211616] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   12.213328] hub 2-0:1.0: USB hub found
    [   12.213363] hub 2-0:1.0: 1 port detected
    [   13.403038] DMA: Module install successful, device major num = 242
    [   13.409346] DRV: Module install successful
    [   17.872425] omap8250 4806a000.serial: failed to request DMA
    [   17.878822] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   17.885904] pgd = dc584000
    [   17.888623] [00000000] *pgd=00000000
    [   17.892229] Internal error: : 1406 [#1] PREEMPT SMP ARM
    [   17.897475] Modules linked in: memcache(O) xhci_plat_hcd bc_example(O) xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio dwc3_omap omap_sham omap_aes_driver extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [   17.928036] CPU: 0 PID: 586 Comm: (agetty) Tainted: G           O    4.4.84 #1
    [   17.930506] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   17.930510] pgd = c0004000
    [   17.930516] [00000000] *pgd=00000000
    [   17.948660] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   17.954779] task: d4948600 ti: dc722000 task.ti: dc722000
    [   17.960207] PC is at pcs_readl+0x14/0x18
    [   17.964146] LR is at pcs_irq_mask+0x78/0xa4
    [   17.968348] pc : [<c02ec65c>]    lr : [<c02ec6e8>]    psr: a0010093
    [   17.968348] sp : dc723d30  ip : dc723d40  fp : dc723d3c
    [   17.979875] r10: c0350760  r9 : 01000000  r8 : df3ef440
    [   17.985122] r7 : df3ef42c  r6 : 000001cd  r5 : df3ef4b4  r4 : dc93e0dc
    [   17.991677] r3 : c02ec648  r2 : 00000000  r1 : fc0037e0  r0 : 00000000
    [   17.998234] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.005487] Control: 10c5387d  Table: 9c58406a  DAC: 00000051
    [   18.011257] Process (agetty) (pid: 586, stack limit = 0xdc722210)
    [   18.017376] Stack: (0xdc723d30 to 0xdc724000)
    [   18.021754] 3d20:                                     dc723d64 dc723d40 c02ec6e8 c02ec654
    [   18.029970] 3d40: dc810180 dc810190 dc8101e0 000001cd 60010013 d4f92e00 dc723d7c dc723d68
    [   18.038184] 3d60: c008926c c02ec67c d4f92e40 dc810180 dc723da4 dc723d80 c00866b0 c0089200
    [   18.046400] 3d80: 00000000 dc810180 000001cd d4f92e00 00000000 c0350a30 dc723dc4 dc723da8
    [   18.054615] 3da0: c008677c c0086444 d4f92e00 df244610 df244674 a0010013 dc723de4 dc723dc8
    [   18.062831] 3dc0: c03f6c70 c0086744 c09c1880 c09c1880 df056088 00010013 dc723dfc dc723de8
    [   18.071047] 3de0: c0377a98 c03f6c10 df056000 c09c1880 dc723e0c dc723e00 c0371990 c03779b8
    [   18.079262] 3e00: dc723e2c dc723e10 c036c4a4 c0371980 df056000 df056090 dc6f2600 df056064
    [   18.087477] 3e20: dc723e54 dc723e30 c036e294 c036c3dc 00000000 dc6f2600 dc6f275c 00000001
    [   18.095692] 3e40: 00000000 c0350a30 dc723e94 dc723e58 c03505bc c036e250 d48a0e40 00000000
    [   18.103907] 3e60: 00000000 00000000 dc723e84 dc6f2600 00005437 d48a0e40 80000000 00000000
    [   18.112122] 3e80: dc6f2600 00000000 dc723f14 dc723e98 c035197c c0350224 d48a0e40 dc723eb0
    [   18.120336] 3ea0: dc723f4c dc723eb0 c01328a4 c012ca54 dca75610 dcc432a8 ef451844 00000005
    [   18.128551] 3ec0: d59e0015 c02e15a4 00000000 dcd43000 dc93a7d0 00000101 00000004 000002c0
    [   18.136765] 3ee0: 00000000 00000000 00000000 dc723ef0 80000000 dc93a7d0 d48a0e40 00000003
    [   18.144981] 3f00: 80000000 dc722000 dc723f7c dc723f18 c013500c c0350ec8 00000020 dc93a7d0
    [   18.153196] 3f20: d48a0e48 00000000 dc723f4c dc723f38 c0131bfc c0113ecc 00000003 d48a0e40
    [   18.161410] 3f40: dc723f94 dc723f50 c01234e4 c0131b9c 00000000 d48a0e40 00000003 d48a0e40
    [   18.169625] 3f60: 00005437 80000000 dc722000 00000000 dc723fa4 dc723f80 c01352c4 c0134bb8
    [   18.177841] 3f80: 005ef618 005f8380 b6f31ce0 00000036 c000fe24 dc722000 00000000 dc723fa8
    [   18.186056] 3fa0: c000fc60 c0135294 005ef618 005f8380 00000003 00005437 80000000 00000000
    [   18.194271] 3fc0: 005ef618 005f8380 b6f31ce0 00000036 00000003 00000000 becd8718 becd85b4
    [   18.202486] 3fe0: 005b4c54 becd833c 004fab00 b6e974d6 20010030 00000003 00000000 00000000
    [   18.210696] Backtrace:
    [   18.213166] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
    [   18.220513] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
    [   18.228114]  r9:d4f92e00 r8:60010013 r7:000001cd r6:dc8101e0 r5:dc810190 r4:dc810180
    [   18.235941] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
    [   18.243541]  r5:dc810180 r4:d4f92e40
    [   18.247148] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
    [   18.254225]  r9:c0350a30 r8:00000000 r7:d4f92e00 r6:000001cd r5:dc810180 r4:00000000
    [   18.262057] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
    [   18.270093]  r7:a0010013 r6:df244674 r5:df244610 r4:d4f92e00
    [   18.275819] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
    [   18.284726]  r7:00010013 r6:df056088 r5:c09c1880 r4:c09c1880
    [   18.290451] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
    [   18.299186]  r5:c09c1880 r4:df056000
    [   18.302796] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
    [   18.311187] [<c036c3d0>] (uart_shutdown) from [<c036e294>] (uart_hangup+0x50/0x104)
    [   18.318874]  r7:df056064 r6:dc6f2600 r5:df056090 r4:df056000
    [   18.324602] [<c036e244>] (uart_hangup) from [<c03505bc>] (__tty_hangup+0x3a4/0x3b4)
    [   18.332289]  r9:c0350a30 r8:00000000 r7:00000001 r6:dc6f275c r5:dc6f2600 r4:00000000
    [   18.340118] [<c0350218>] (__tty_hangup) from [<c035197c>] (tty_ioctl+0xac0/0xe8c)
    [   18.347630]  r10:00000000 r9:dc6f2600 r8:00000000 r7:80000000 r6:d48a0e40 r5:00005437
    [   18.355539]  r4:dc6f2600
    [   18.358097] [<c0350ebc>] (tty_ioctl) from [<c013500c>] (do_vfs_ioctl+0x460/0x6dc)
    [   18.365609]  r9:dc722000 r8:80000000 r7:00000003 r6:d48a0e40 r5:dc93a7d0 r4:80000000
    [   18.373438] [<c0134bac>] (do_vfs_ioctl) from [<c01352c4>] (SyS_ioctl+0x3c/0x64)
    [   18.380778]  r10:00000000 r9:dc722000 r8:80000000 r7:00005437 r6:d48a0e40 r5:00000003
    [   18.388687]  r4:d48a0e40
    [   18.391244] [<c0135288>] (SyS_ioctl) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   18.398845]  r9:dc722000 r8:c000fe24 r7:00000036 r6:b6f31ce0 r5:005f8380 r4:005ef618
    [   18.406670] Code: e92dd800 e24cb004 e5900000 f57ff04f (e89da800)
    [   18.412794] ---[ end trace 3a26f80914700636 ]---
    [   18.412797] Internal error: : 1406 [#2] PREEMPT SMP ARM
    [   18.412862] Modules linked in: memcache(O) xhci_plat_hcd bc_example(O) xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio dwc3_omap omap_sham omap_aes_driver extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [   18.412870] CPU: 1 PID: 108 Comm: kworker/1:2 Tainted: G      D    O    4.4.84 #1
    [   18.412872] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.412884] Workqueue: events_freezable thermal_zone_device_check
    [   18.412889] task: dc42d400 ti: dc5c2000 task.ti: dc5c2000
    [   18.412896] PC is at ti_bandgap_force_single_read+0x4c/0x188
    [   18.412902] LR is at ti_bandgap_read_temperature+0xb8/0xf8
    [   18.412907] pc : [<c04d1ff4>]    lr : [<c04d379c>]    psr: 400f0013
    [   18.412907] sp : dc5c3df8  ip : dc5c3e20  fp : dc5c3e1c
    [   18.412910] r10: df5d89c0  r9 : 00000000  r8 : 00000000
    [   18.412914] r7 : 00000000  r6 : 00000000  r5 : dca36b10  r4 : 00000000
    [   18.412917] r3 : 0000014c  r2 : fc00232c  r1 : c0977ab8  r0 : dca36b10
    [   18.412922] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.412927] Control: 10c5387d  Table: 9c63c06a  DAC: 00000051
    [   18.412931] Process kworker/1:2 (pid: 108, stack limit = 0xdc5c2210)
    [   18.412935] Stack: (0xdc5c3df8 to 0xdc5c4000)
    [   18.412939] 3de0:                                                       dca36b10 00000000
    [   18.412947] 3e00: dc5c3e40 dca54010 dca36b10 00000000 dc5c3e3c dc5c3e20 c04d379c c04d1fb4
    [   18.412954] 3e20: 00000000 dc5c3eb4 c06f7450 dca54010 dc5c3e6c dc5c3e40 c04d3b6c c04d36f0
    [   18.412962] 3e40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc5c3eb4 df5dc300 00000000
    [   18.412968] 3e60: dc5c3e7c dc5c3e70 c04cef6c c04d3b3c dc5c3eac dc5c3e80 c04cb5fc c04cef50
    [   18.412975] 3e80: 7fffffff df5d8e40 dc42d400 df312a2c df312800 df5d89c0 00000000 df5dc300
    [   18.412982] 3ea0: dc5c3ecc dc5c3eb0 c04ccde0 c04cb5ac dc5c3edc dc5c3ec0 df312a2c dc532f80
    [   18.412989] 3ec0: dc5c3edc dc5c3ed0 c04ccecc c04ccdd0 dc5c3f1c dc5c3ee0 c004f330 c04ccea0
    [   18.412996] 3ee0: df5d89c0 df5d89d4 dc5c2000 00000008 dc532f80 df5d89c0 dc532f98 df5d89d4
    [   18.413003] 3f00: dc5c2000 00000008 dc532f80 df5d89c0 dc5c3f54 dc5c3f20 c004f64c c004f218
    [   18.413010] 3f20: dc532f80 c093c100 00000000 00000000 dc56b880 dc5c2000 dc532f80 c004f600
    [   18.413016] 3f40: 00000000 00000000 dc5c3fac dc5c3f58 c0055184 c004f60c 00000000 00000000
    [   18.413023] 3f60: 00000000 dc532f80 00000000 00000000 dc5c3f70 dc5c3f70 00000000 00000000
    [   18.413029] 3f80: dc5c3f80 dc5c3f80 dc5c3fac dc56b880 c0055084 00000000 00000000 00000000
    [   18.413037] 3fa0: 00000000 dc5c3fb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [   18.413043] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   18.413049] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [   18.413054] Backtrace:
    [   18.413063] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [   18.413077]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc5c3e40 r5:00000000 r4:dca36b10
    [   18.413086] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [   18.413098]  r7:dca54010 r6:c06f7450 r5:dc5c3eb4 r4:00000000
    [   18.413106] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [   18.413121]  r9:00000000 r8:df5dc300 r7:dc5c3eb4 r6:df312a0c r5:df312800 r4:df312800
    [   18.413130] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [   18.413138] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [   18.413151]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
    [   18.413158] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [   18.413165]  r5:dc532f80 r4:df312a2c
    [   18.413172] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [   18.413178] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [   18.413192]  r10:df5d89c0 r9:dc532f80 r8:00000008 r7:dc5c2000 r6:df5d89d4 r5:dc532f98
    [   18.413195]  r4:df5d89c0
    [   18.413203] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [   18.413217]  r10:00000000 r9:00000000 r8:c004f600 r7:dc532f80 r6:dc5c2000 r5:dc56b880
    [   18.413220]  r4:00000000
    [   18.413230] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [   18.413241]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc56b880
    [   18.413250] Code: e5913000 e0822003 e5928000 f57ff04f (e5913008)
    [   18.413257] ---[ end trace 3a26f80914700637 ]---
    [   18.430596] Unable to handle kernel paging request at virtual address ffffffec
    [   18.430599] pgd = c0004000
    [   18.430609] [ffffffec] *pgd=9face861, *pte=00000000, *ppte=00000000
    [   18.430616] Internal error: Oops: 37 [#3] PREEMPT SMP ARM
    [   18.430678] Modules linked in: memcache(O) xhci_plat_hcd bc_example(O) xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core virtio_rpmsg_bus scsi_mod extcon_usb_gpio dwc3_omap omap_sham omap_aes_driver extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [   18.430684] CPU: 1 PID: 108 Comm: kworker/1:2 Tainted: G      D    O    4.4.84 #1
    [   18.430687] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.430700] task: dc42d400 ti: dc5c2000 task.ti: dc5c2000
    [   18.430709] PC is at kthread_data+0x10/0x18
    [   18.430713] LR is at wq_worker_sleeping+0x14/0xd8
    [   18.430719] pc : [<c00555d4>]    lr : [<c00503fc>]    psr: 20070193
    [   18.430719] sp : dc5c3ba0  ip : dc5c3bb0  fp : dc5c3bac
    [   18.430721] r10: 00000001  r9 : df5d8e40  r8 : dc42d7a8
    [   18.430725] r7 : c093c6d4  r6 : c0937e40  r5 : dc42d400  r4 : 00000001
    [   18.430729] r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : dc42d400
    [   18.430734] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.430738] Control: 10c5387d  Table: 9c58006a  DAC: 00000051
    [   18.430741] Process kworker/1:2 (pid: 108, stack limit = 0xdc5c2210)
    [   18.430745] Stack: (0xdc5c3ba0 to 0xdc5c4000)
    [   18.430753] 3ba0: dc5c3bc4 dc5c3bb0 c00503fc c00555d0 df5d8e40 dc42d400 dc5c3c1c dc5c3bc8
    [   18.430761] 3bc0: c0687680 c00503f4 c098be14 dca5dd40 dc5c3bec dc5c3be0 c00918f8 c009167c
    [   18.430768] 3be0: dc5c3c34 c06878b8 00000000 c00918ec c003a300 dc5c2000 dc5c3904 df080000
    [   18.430775] 3c00: dc5c3c40 dc42d720 c04d1ff6 c081ef94 dc5c3c34 dc5c3c20 c06878b8 c0687204
    [   18.430782] 3c20: dc42d400 dc5c3904 dc5c3c5c dc5c3c38 c003c258 c0687870 00000001 00000000
    [   18.430788] 3c40: dc5c3c40 dc5c3c40 c00393a8 c04d1ff8 dc5c3ce4 dc5c3c60 c0013f68 c003bc24
    [   18.430795] 3c60: dc5c2210 0000000b c081ef9c 00000008 00000000 dc5c2000 00000000 600f0193
    [   18.430802] 3c80: 655c3ca4 33313935 20303030 32383065 33303032 39356520 30303832 35662030
    [   18.430810] 3ca0: 30666637 28206634 31393565 38303033 c0002029 c0004000 dc5c3cf4 c0940fb4
    [   18.430818] 3cc0: 00001406 00000007 00000000 dc5c3da8 00000000 df5d89c0 dc5c3cf4 dc5c3ce8
    [   18.430824] 3ce0: c0014198 c0013d28 dc5c3da4 dc5c3cf8 c0009370 c0014184 00000000 df5d8e40
    [   18.430831] 3d00: 00000007 00000000 00030003 00000000 c0067658 c005b73c c00674fc dc42d400
    [   18.430838] 3d20: df5d8e40 c093c5b8 df08005c ffff91bf 00000000 df5cde40 dc5c3d5c dc5c3d48
    [   18.430845] 3d40: c005c328 c0067508 df5d8e40 df080000 dc5c3d74 dc5c3d60 c0066e58 c005c2a8
    [   18.430851] 3d60: 00000001 df080000 dc5c3e34 dc5c3d78 c006f2c4 c068b508 df5d6338 c0937e40
    [   18.430858] 3d80: 00000001 c04d1ff4 400f0013 ffffffff dc5c3ddc 00000000 dc5c3e1c dc5c3da8
    [   18.430865] 3da0: c00147e0 c00092c0 dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
    [   18.430872] 3dc0: 00000000 00000000 00000000 00000000 df5d89c0 dc5c3e1c dc5c3e20 dc5c3df8
    [   18.430879] 3de0: c04d379c c04d1ff4 400f0013 ffffffff 00000051 00000000 dca36b10 00000000
    [   18.430886] 3e00: dc5c3e40 dca54010 dca36b10 00000000 dc5c3e3c dc5c3e20 c04d379c c04d1fb4
    [   18.430893] 3e20: 00000000 dc5c3eb4 c06f7450 dca54010 dc5c3e6c dc5c3e40 c04d3b6c c04d36f0
    [   18.430899] 3e40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc5c3eb4 df5dc300 00000000
    [   18.430906] 3e60: dc5c3e7c dc5c3e70 c04cef6c c04d3b3c dc5c3eac dc5c3e80 c04cb5fc c04cef50
    [   18.430913] 3e80: 7fffffff df5d8e40 dc42d400 df312a2c df312800 df5d89c0 00000000 df5dc300
    [   18.430920] 3ea0: dc5c3ecc dc5c3eb0 c04ccde0 c04cb5ac dc5c3edc dc5c3ec0 df312a2c dc532f80
    [   18.430926] 3ec0: dc5c3edc dc5c3ed0 c04ccecc c04ccdd0 dc5c3f1c dc5c3ee0 c004f330 c04ccea0
    [   18.430933] 3ee0: df5d89c0 df5d89d4 dc5c2000 00000008 dc532f80 df5d89c0 dc532f98 df5d89d4
    [   18.430940] 3f00: dc5c2000 00000008 dc532f80 df5d89c0 dc5c3f54 dc5c3f20 c004f64c c004f218
    [   18.430947] 3f20: dc532f80 c093c100 00000000 00000000 dc56b880 dc5c2000 dc532f80 c004f600
    [   18.430953] 3f40: 00000000 00000000 dc5c3fac dc5c3f58 c0055184 c004f60c 00000000 00000000
    [   18.430961] 3f60: 00000000 dc532f80 00000000 00000000 dc5c3f70 dc5c3f70 00000001 00010001
    [   18.430968] 3f80: dc5c3f80 dc5c3f80 dc5c3fac dc56b880 c0055084 00000000 00000000 00000000
    [   18.430974] 3fa0: 00000000 dc5c3fb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [   18.430979] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   18.430987] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [   18.430991] Backtrace:
    [   18.430999] [<c00555c4>] (kthread_data) from [<c00503fc>] (wq_worker_sleeping+0x14/0xd8)
    [   18.431010] [<c00503e8>] (wq_worker_sleeping) from [<c0687680>] (__schedule+0x488/0x66c)
    [   18.431018]  r5:dc42d400 r4:df5d8e40
    [   18.431025] [<c06871f8>] (__schedule) from [<c06878b8>] (schedule+0x54/0xc4)
    [   18.431039]  r10:c081ef94 r9:c04d1ff6 r8:dc42d720 r7:dc5c3c40 r6:df080000 r5:dc5c3904
    [   18.431043]  r4:dc5c2000
    [   18.431052] [<c0687864>] (schedule) from [<c003c258>] (do_exit+0x640/0x9b8)
    [   18.431059]  r5:dc5c3904 r4:dc42d400
    [   18.431067] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
    [   18.431071]  r7:c04d1ff8
    [   18.431077] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
    [   18.431090]  r10:df5d89c0 r9:00000000 r8:dc5c3da8 r7:00000000 r6:00000007 r5:00001406
    [   18.431094]  r4:c0940fb4
    [   18.431100] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
    [   18.431107] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
    [   18.431110] Exception stack(0xdc5c3da8 to 0xdc5c3df0)
    [   18.431117] 3da0:                   dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
    [   18.431123] 3dc0: 00000000 00000000 00000000 00000000 df5d89c0 dc5c3e1c dc5c3e20 dc5c3df8
    [   18.431129] 3de0: c04d379c c04d1ff4 400f0013 ffffffff
    [   18.431143]  r8:00000000 r7:dc5c3ddc r6:ffffffff r5:400f0013 r4:c04d1ff4
    [   18.431152] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [   18.431165]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc5c3e40 r5:00000000 r4:dca36b10
    [   18.431173] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [   18.431184]  r7:dca54010 r6:c06f7450 r5:dc5c3eb4 r4:00000000
    [   18.431191] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [   18.431203]  r9:00000000 r8:df5dc300 r7:dc5c3eb4 r6:df312a0c r5:df312800 r4:df312800
    [   18.431211] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [   18.431219] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [   18.431234]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
    [   18.431240] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [   18.431247]  r5:dc532f80 r4:df312a2c
    [   18.431254] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [   18.431260] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [   18.431272]  r10:df5d89c0 r9:dc532f80 r8:00000008 r7:dc5c2000 r6:df5d89d4 r5:dc532f98
    [   18.431276]  r4:df5d89c0
    [   18.431282] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [   18.431296]  r10:00000000 r9:00000000 r8:c004f600 r7:dc532f80 r6:dc5c2000 r5:dc56b880
    [   18.431299]  r4:00000000
    [   18.431307] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [   18.431320]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc56b880
    [   18.431328] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
    [   18.431333] ---[ end trace 3a26f80914700638 ]---
    [   18.431336] Fixing recursive fault but reboot is needed!
    [   19.557334] note: (agetty)[586] exited with preempt_count 2
    [END] 2018/12/17 11:18:55
    dra7xx-evm login: ��  1.435739] console [ttyS9] enabled
    [    1.441838] bootconsole [earlycon0] disabled
    [    1.450521] [drm] Initialized drm 1.1.0 20060810
    [    1.456044] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.462690] [drm] No driver support for vblank timestamp query.
    [    1.468843] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.481841] loop: module loaded
    [    1.487684] vmemexp device MAJOR num = 245
    [    1.491814] vmemexp class registered
    [    1.495556] /dev/vmemexp device registered
    [    1.499671] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.507959] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.515631] libphy: Fixed MDIO Bus: probed
    [    1.563510] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.569633] libphy: 48485000.mdio: probed
    [    1.577164] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver RTL9000A Gigabit Ethernet
    [    1.587429] cpsw 48484000.ethernet: Detected MACID = f4:84:4c:14:9b:7e
    [    1.594099] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.601059] cpsw 48484000.ethernet: cpsw: Detected MACID = f4:84:4c:14:9b:7f
    [    1.609704] mousedev: PS/2 mouse device common for all mice
    [    1.615947] i2c /dev entries driver
    [    1.624729] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.629569] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.636061] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.642445] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.648843] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.655240] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.661881] vsys_3v3: supplied by vsys_12v0
    [    1.666152] vio_3v3: supplied by vsys_3v3
    [    1.670211] vio_3v3_sd: supplied by vio_3v3
    [    1.674688] ldo4: supplied by vsys_5v0
    [    1.723912] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.730299] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.753652] smps5: supplied by vsys_3v3
    [    1.757701] vio_1v8: supplied by smps5
    [    1.804428] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.815617] hwspinlock_user gatemp: requested 20 hwspinlocks
    [    1.822558] aic_dvdd: supplied by vio_3v3
    [    1.827860] davinci-mcasp 48464000.mcasp: DAI is shared
    [    1.833187] davinci-mcasp 48464000.mcasp: Can't verify DMA configuration (-19)
    [    1.840480] davinci-mcasp 48464000.mcasp: No DMA controller found (-19)
    [    1.847680] davinci-mcasp 48468000.mcasp: Can't verify DMA configuration (-19)
    [    1.854990] davinci-mcasp 48468000.mcasp: No DMA controller found (-19)
    [    1.861839] davinci-mcasp 48474000.mcasp: DAI is shared
    [    1.867189] davinci-mcasp 48474000.mcasp: Can't verify DMA configuration (-19)
    [    1.874477] davinci-mcasp 48474000.mcasp: No DMA controller found (-19)
    [    1.882255] NET: Registered protocol family 10
    [    1.897588] sit: IPv6 over IPv4 tunneling driver
    [    1.902771] NET: Registered protocol family 17
    [    1.907526] Key type dns_resolver registered
    [    1.911995] omap_voltage_late_init: Voltage driver support not added
    [    1.918899] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.925145] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.931427] buck10: supplied by vsys_3v3
    [    1.936029] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.942240] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.949586] Power Management for TI OMAP4+ devices.
    [    1.954708] Registering SWP/SWPB emulation handler
    [    1.960790] dmm 4e000000.dmm: workaround for errata i878 in use
    [    1.968185] dmm 4e000000.dmm: initialized all PAT entries
    [    1.974664] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    1.982343] hctosys: unable to open rtc device (rtc0)
    [    1.999108] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.999656] aic_dvdd: disabling
    [    1.999689] clk: Not disabling unused clocks
    [    1.999696] ALSA device list:
    [    1.999699]   No soundcards found.
    [    2.021087] mmc0: new SDHC card at address 0001
    [    2.025794] Waiting for root device /dev/mmcblk0p2...
    [    2.041112] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
    [    2.047217]  mmcblk0: p1 p2
    [    2.108046] mmc1: MAN_BKOPS_EN bit is not set
    [    2.120505] mmc1: mmc_select_hs200 failed, error -74
    [    2.125513] : switch to mmc1 failed
    [    2.130480] mmc1: new MMC card at address 0001
    [    2.145441] mmcblk1: mmc1:0001 DG4008 7.28 GiB
    [    2.160285] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
    [    2.176521] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
    [    4.439711] EXT4-fs (mmcblk0p2): recovery complete
    [    4.448022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.456200] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    4.475577] devtmpfs: mounted
    [    4.478771] Freeing unused kernel memory: 340K
    [    4.483234] This architecture does not have kernel memory protection.
    [    4.519738] Kernel Entry time 231946 ticks
    mount: unknown filesystem type 'dev'
    [    5.176576] systemd[1]: System time before build time, advancing clock.
    [    5.231349] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    5.244581] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    5.262253] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    5.280873] systemd[1]: Detected architecture arm.
    [    5.304609] systemd[1]: Set hostname to <dra7xx-evm>.
    [    5.374508] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    5.422677] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    5.433001] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    5.448961] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    5.467470] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
    [    5.618740] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    5.628280] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    5.638424] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    5.852434] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    5.860261] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    5.867981] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    5.875276] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    5.882710] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
    [    5.889900] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    5.897373] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    5.906833] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [    5.945978] systemd[1]: Reached target Remote File Systems.
    [    5.963734] systemd[1]: Listening on udev Control Socket.
    [    5.983826] systemd[1]: Listening on Network Service Netlink Socket.
    [    6.013823] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    6.043601] systemd[1]: Reached target Swap.
    [    6.063719] systemd[1]: Listening on Syslog Socket.
    [    6.085175] systemd[1]: Created slice System Slice.
    [    6.104331] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    6.124320] systemd[1]: Created slice system-getty.slice.
    [    6.143701] systemd[1]: Listening on udev Kernel Socket.
    [    6.163693] systemd[1]: Listening on Journal Socket (/dev/log).
    [    6.183724] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [    6.216456] systemd[1]: Listening on Journal Socket.
    [    6.263914] systemd[1]: Starting Load Kernel Modules...
    [    6.286316] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [    6.316139] systemd[1]: Starting Journal Service...
    [    6.338500] systemd[1]: Mounting Temporary Directory...
    [    6.366383] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.386367] systemd[1]: Starting Setup Virtual Console...
    [    6.389215] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    6.436207] systemd[1]: Mounting POSIX Message Queue File System...
    [    6.464485] systemd[1]: Created slice User and Session Slice.
    [    6.483641] systemd[1]: Reached target Slices.
    [    6.543723] systemd[1]: Mounting Debug File System...
    [    6.563877] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    6.593631] systemd[1]: Reached target Paths.
    [    6.622772] systemd[1]: Mounted POSIX Message Queue File System.
    [    6.643676] systemd[1]: Mounted Debug File System.
    [    6.663651] systemd[1]: Mounted Temporary Directory.
    [    6.683857] systemd[1]: Started Journal Service.
    [    7.498165] systemd-journald[98]: Received request to flush runtime journal from PID 1
    [    8.180464] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
    [    8.208246]  remoteproc0: 58820000.ipu is available
    [    8.228384]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    8.239510]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    8.271091] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
    [    8.294656]  remoteproc1: 55020000.ipu is available
    [    8.307570]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [  OK  [    8.343808]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    8.364357] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
    [    8.372426]  remoteproc0: registered virtio0 (type 7)
    [    8.394137]  remoteproc2: 40800000.dsp is available
    [    8.407830]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [    8.422169]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    8.441972] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
    [    8.466773]  remoteproc3: 41000000.dsp is available
    [    8.472135]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    8.483890]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    8.503715] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    8.555799] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [    9.158747] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    9.209705] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    9.224181] omap-aes 4b500000.aes: Unable to request in DMA channel
    [    9.282475] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    9.290662] omap-aes 4b700000.aes: Unable to request in DMA channel
    [  OK  ] Started D-Bus System Message Bus.
    [   10.513714] SCSI subsystem initialized
    [   10.541277]  remoteproc0: powering up 58820000.ipu
    [   10.546939]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 589684
    [   10.554225] ------------[ cut here ]------------
    [   10.558877] WARNING: CPU: 0 PID: 161 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
    [   10.568400] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET IPU1 (Read Link): At Address: 0x0008204C : Data Access in User mode during Functional access
    [   10.582280] Modules linked in: virtio_rpmsg_bus(+) scsi_mod dwc3_omap extcon_usb_gpio omap_aes_driver omap_sham extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [   10.600680] CPU: 0 PID: 161 Comm: systemd-udevd Not tainted 4.4.84 #1
    [   10.607147] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.613264] Backtrace:
    [   10.615740] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [   10.623341]  r7:c02e3bb0 r6:200d0193 r5:00000000 r4:c0959350
    [   10.629072] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
    [   10.636330] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
    [   10.644454]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:dc5558f0
    [   10.650180] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
    [   10.658915]  r8:00000017 r7:c084c280 r6:00000004 r5:c084c334 r4:c084c3e4
    [   10.665695] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
    [   10.674603]  r3:df20a940 r2:c084c3e4
    [   10.678208]  r4:80080001
    [   10.680768] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
    [   10.690114]  r10:c0988e4b r9:df208240 r8:00000017 r7:00000000 r6:00000000 r5:df2082a0
    [   10.698022]  r4:df20ae40
    [   10.700579] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
    [   10.709487]  r10:00000000 r9:00000000 r8:df008000 r7:00000000 r6:c0941c8c r5:df2082a0
    [   10.717395]  r4:df208240
    [   10.719953] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
    [   10.728513]  r7:00000000 r6:c0941c8c r5:df2082a0 r4:df208240
    [   10.734238] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
    [   10.742884]  r7:00000000 r6:00000000 r5:00000017 r4:c093640c
    [   10.748610] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
    [   10.757350] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [   10.765736]  r9:00000000 r8:fa213000 r7:fa212000 r6:dc555ab0 r5:fa21200c r4:c093c8e4
    [   10.773563] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [   10.781078] Exception stack(0xdc555ab0 to 0xdc555af8)
    [   10.786151] 5aa0:                                     df26aa10 00000000 00008000 00000000
    [   10.794367] 5ac0: d48e8000 df2ef840 d4916c80 d356abd4 df2f4e10 00000000 00000000 dc555b0c
    [   10.802580] 5ae0: dc555b10 dc555b00 c02ce9d4 c02ce944 200d0013 ffffffff
    [   10.809220]  r9:00000000 r8:df2f4e10 r7:dc555ae4 r6:ffffffff r5:200d0013 r4:c02ce944
    [   10.817051] [<c02ce9c4>] (devm_ioremap) from [<c037fe18>] (omap_iommu_attach_dev+0x304/0x3b4)
    [   10.825615] [<c037fb14>] (omap_iommu_attach_dev) from [<c037da2c>] (iommu_attach_device+0x8c/0xac)
    [   10.834612]  r10:d4b7dec0 r9:df257410 r8:dc6c3420 r7:dc6c35ac r6:dc6c35b4 r5:d356abd4
    [   10.842519]  r4:00000000
    [   10.845087] [<c037d9a0>] (iommu_attach_device) from [<bf05ab98>] (rproc_boot+0x2e0/0x55c [remoteproc])
    [   10.854433]  r7:dc6c35ac r6:dc6c35b4 r5:00000000 r4:dc6c3400
    [   10.860173] [<bf05a8b8>] (rproc_boot [remoteproc]) from [<bf05bae4>] (rproc_virtio_find_vqs+0x18c/0x1f0 [remoteproc])
    [   10.870826]  r10:dc6c3420 r9:00000002 r8:bf158d5c r7:dc6c2410 r6:dc6c25f0 r5:dc555c44
    [   10.878733]  r4:00000002
    [   10.881309] [<bf05b958>] (rproc_virtio_find_vqs [remoteproc]) from [<bf1582f0>] (rpmsg_probe+0xbc/0x474 [virtio_rpmsg_bus])
    [   10.892484]  r10:00000000 r9:00000000 r8:dc6c2410 r7:dc555c38 r6:dc6c3400 r5:d4945f80
    [   10.900393]  r4:bf05b958
    [   10.902961] [<bf158234>] (rpmsg_probe [virtio_rpmsg_bus]) from [<bf03585c>] (virtio_dev_probe+0x230/0x310 [virtio])
    [   10.913439]  r10:00000000 r9:00000000 r8:00000000 r7:dc6c2420 r6:dc6c2410 r5:00000000
    [   10.921347]  r4:00000000
    [   10.923908] [<bf03562c>] (virtio_dev_probe [virtio]) from [<c03ec44c>] (driver_probe_device+0x204/0x2f8)
    [   10.933426]  r10:00000000 r9:d4b7dc08 r8:0000000f r7:bf158dfc r6:00000000 r5:dc6c2420
    [   10.941332]  r4:c09c5a44
    [   10.943888] [<c03ec248>] (driver_probe_device) from [<c03ec5d4>] (__driver_attach+0x94/0x98)
    [   10.952360]  r9:d4b7dc08 r8:2b48241c r7:00000000 r6:dc6c2454 r5:bf158dfc r4:dc6c2420
    [   10.960188] [<c03ec540>] (__driver_attach) from [<c03ea6d4>] (bus_for_each_dev+0x70/0xa4)
    [   10.968398]  r7:00000000 r6:c03ec540 r5:bf158dfc r4:00000000
    [   10.974122] [<c03ea664>] (bus_for_each_dev) from [<c03ebd38>] (driver_attach+0x24/0x28)
    [   10.982160]  r6:bf035d58 r5:d4945d80 r4:bf158dfc
    [   10.986826] [<c03ebd14>] (driver_attach) from [<c03eb974>] (bus_add_driver+0x1a8/0x220)
    [   10.994866] [<c03eb7cc>] (bus_add_driver) from [<c03ecd74>] (driver_register+0x80/0x100)
    [   11.002989]  r7:d4b7dd00 r6:c093f6f0 r5:bf15c000 r4:bf158dfc
    [   11.008716] [<c03eccf4>] (driver_register) from [<bf035aa4>] (register_virtio_driver+0x30/0x44 [virtio])
    [   11.018234]  r5:bf15c000 r4:00000000
    [   11.021857] [<bf035a74>] (register_virtio_driver [virtio]) from [<bf15c044>] (rpmsg_init+0x44/0x84 [virtio_rpmsg_bus])
    [   11.032609] [<bf15c000>] (rpmsg_init [virtio_rpmsg_bus]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [   11.042041]  r5:bf15c000 r4:c093f6f0
    [   11.045662] [<c00097f4>] (do_one_initcall) from [<c00d46f0>] (do_init_module+0x68/0x398)
    [   11.053786]  r10:bf158f00 r9:d4b7dc08 r8:2b48241c r7:00000001 r6:d4b7dcc0 r5:00000001
    [   11.061692]  r4:bf158f00
    [   11.064251] [<c00d4688>] (do_init_module) from [<c00b10e0>] (load_module+0x1df8/0x2068)
    [   11.072288]  r6:d4b7dc00 r5:00000001 r4:dc555f44
    [   11.076958] [<c00af2e8>] (load_module) from [<c00b153c>] (SyS_finit_module+0x88/0x98)
    [   11.084820]  r10:00000000 r9:dc554000 r8:c000fe24 r7:0000017b r6:b6d83d90 r5:00000007
    [   11.092729]  r4:00000000
    [   11.095286] [<c00b14b4>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   11.103496]  r6:00000000 r5:004ef928 r4:00000000
    [   11.108160] ---[ end trace b21868089aac6789 ]---
    [   11.112887] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   11.119972] pgd = dc550000
    [   11.122691] [00000000] *pgd=00000000
    [   11.126293] Internal error: : 1406 [#1] PREEMPT SMP ARM
    [   11.131539] Modules linked in: virtio_rpmsg_bus(+) scsi_mod dwc3_omap extcon_usb_gpio omap_aes_driver omap_sham extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [   11.149938] CPU: 0 PID: 161 Comm: systemd-udevd Tainted: G        W       4.4.84 #1
    [   11.157626] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   11.163747] task: dca2f800 ti: dc554000 task.ti: dc554000
    [   11.169173] PC is at devm_ioremap_nocache+0x0/0x80
    [   11.173984] LR is at devm_ioremap+0x10/0x14
    [   11.178186] pc : [<c02ce944>]    lr : [<c02ce9d4>]    psr: 200d0013
    [   11.178186] sp : dc555b00  ip : dc555b10  fp : dc555b0c
    [   11.189713] r10: 00000000  r9 : 00000000  r8 : df2f4e10
    [   11.194959] r7 : d356abd4  r6 : d4916c80  r5 : df2ef840  r4 : d48e8000
    [   11.201513] r3 : 00000000  r2 : 00008000  r1 : 00000000  r0 : df26aa10
    [   11.208070] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   11.215237] Control: 10c5387d  Table: 9c55006a  DAC: 00000051
    [   11.221006] Process systemd-udevd (pid: 161, stack limit = 0xdc554210)
    [   11.227560] Stack: (0xdc555b00 to 0xdc556000)
    [   11.231938] 5b00: dc555b4c dc555b10 c037fe18 c02ce9d0 d356abd0 df257410 c037fec8 00000000
    [   11.240153] 5b20: dc6c35b4 00000000 d356abd4 dc6c35b4 dc6c35ac dc6c3420 df257410 d4b7dec0
    [   11.248368] 5b40: dc555b6c dc555b50 c037da2c c037fb20 dc6c3400 00000000 dc6c35b4 dc6c35ac
    [   11.256582] 5b60: dc555bb4 dc555b70 bf05ab98 c037d9ac 00000000 d356abd4 dc555bb4 d4b7dec0
    [   11.264796] 5b80: bf0055a4 c01158f4 dc6c2410 00000002 dc555c44 dc6c25f0 dc6c2410 bf158d5c
    [   11.273012] 5ba0: 00000002 dc6c3420 dc555c1c dc555bb8 bf05bae4 bf05a8c4 00000000 da004000
    [   11.281227] 5bc0: bf05b724 bf157f7c bf158d5c d4b76730 00000100 dc6c3400 bf05b724 da004000
    [   11.289441] 5be0: dc6c2400 bf157f7c dc555c3c bf158838 c02b9030 bf05b958 d4945f80 dc6c3400
    [   11.297657] 5c00: dc555c38 dc6c2410 00000000 00000000 dc555c84 dc555c20 bf1582f0 bf05b964
    [   11.305870] 5c20: bf158834 d5a3d0a0 dc555c6c dc555c38 c01879b8 c01877bc bf157fa8 bf157f7c
    [   11.314086] 5c40: df3f6800 df3f7000 dc555c6c dc555c58 bf05bc48 bf006420 dc6c2410 00000000
    [   11.322299] 5c60: 00000000 dc6c2410 dc6c2420 00000000 00000000 00000000 dc555ce4 dc555c88
    [   11.330513] 5c80: bf03585c bf158240 c0189fb0 c018677c dc6c2420 00000000 dc6c2410 bf158dfc
    [   11.338727] 5ca0: 00000001 00000000 dc6c2420 bf158dfc c018a02c c0189f44 dc555ce4 c09c5a44
    [   11.346941] 5cc0: dc6c2420 00000000 bf158dfc 0000000f d4b7dc08 00000000 dc555d0c dc555ce8
    [   11.355155] 5ce0: c03ec44c bf035638 dc6c2420 bf158dfc dc6c2454 00000000 2b48241c d4b7dc08
    [   11.363369] 5d00: dc555d2c dc555d10 c03ec5d4 c03ec254 00000000 bf158dfc c03ec540 00000000
    [   11.371583] 5d20: dc555d54 dc555d30 c03ea6d4 c03ec54c dc40185c dc627bb4 dc401870 bf158dfc
    [   11.379797] 5d40: d4945d80 bf035d58 dc555d64 dc555d58 c03ebd38 c03ea670 dc555d8c dc555d68
    [   11.388013] 5d60: c03eb974 c03ebd20 bf158d64 dc555d78 bf158dfc bf15c000 c093f6f0 d4b7dd00
    [   11.396228] 5d80: dc555da4 dc555d90 c03ecd74 c03eb7d8 00000000 bf15c000 dc555db4 dc555da8
    [   11.404442] 5da0: bf035aa4 c03ecd00 dc555dcc dc555db8 bf15c044 bf035a80 c093f6f0 bf15c000
    [   11.412656] 5dc0: dc555e4c dc555dd0 c000988c bf15c00c 00000000 00080000 00000001 df92c718
    [   11.420870] 5de0: d4916a80 c0109ab0 dc554000 df001e40 dc555e08 000165b6 dc555e3c dc555e08
    [   11.429085] 5e00: c01146b4 c0113b5c 00000001 c0109ab0 2b48241c 0000002c d4916a80 e425f000
    [   11.437300] 5e20: 00000001 bf158f00 00000001 d4b7dcc0 00000001 2b48241c d4b7dc08 bf158f00
    [   11.445516] 5e40: dc555e74 dc555e50 c00d46f0 c0009800 dc555e74 dc555e60 c0109b9c dc555f44
    [   11.453731] 5e60: 00000001 d4b7dc00 dc555f3c dc555e78 c00b10e0 c00d4694 bf158f0c 00007fff
    [   11.461946] 5e80: bf158f00 c00ae2dc dcb913c0 c082c060 c082c038 c082c02c c082c090 c0691768
    [   11.470160] 5ea0: 00000000 bf158f0c e428ac88 bf1590a0 c093c4ac bf1590c8 bf158f48 c00adc4c
    [   11.478374] 5ec0: bf1588a2 00020001 00000187 00000000 0b300002 bf158774 00000008 00000000
    [   11.486588] 5ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   11.494804] 5f00: 00000000 00000000 00000000 00000000 00000160 00000000 00000007 b6d83d90
    [   11.503019] 5f20: 0000017b c000fe24 dc554000 00000000 dc555fa4 dc555f40 c00b153c c00af2f4
    [   11.511234] 5f40: 00000002 e425f000 0002bcd8 e428a5a8 e427e33a e427f5c4 000020c8 00002b08
    [   11.519450] 5f60: 00000000 00000000 00000000 00001da8 0000002c 0000002d 00000017 00000013
    [   11.527664] 5f80: 00000010 00000000 00000000 00000000 004ef928 00000000 00000000 dc555fa8
    [   11.535878] 5fa0: c000fc60 c00b14c0 00000000 004ef928 00000007 b6d83d90 00000000 004f35d0
    [   11.544093] 5fc0: 00000000 004ef928 00000000 0000017b 004f3538 00000000 004f3538 004ffc00
    [   11.552308] 5fe0: be9049d8 be9049c8 b6d7cc08 b6e7fdf2 600f0030 00000007 00000000 00000000
    [   11.560518] Backtrace:
    [   11.562988] [<c02ce9c4>] (devm_ioremap) from [<c037fe18>] (omap_iommu_attach_dev+0x304/0x3b4)
    [   11.571554] [<c037fb14>] (omap_iommu_attach_dev) from [<c037da2c>] (iommu_attach_device+0x8c/0xac)
    [   11.580550]  r10:d4b7dec0 r9:df257410 r8:dc6c3420 r7:dc6c35ac r6:dc6c35b4 r5:d356abd4
    [   11.588457]  r4:00000000
    [   11.591026] [<c037d9a0>] (iommu_attach_device) from [<bf05ab98>] (rproc_boot+0x2e0/0x55c [remoteproc])
    [   11.600371]  r7:dc6c35ac r6:dc6c35b4 r5:00000000 r4:dc6c3400
    [   11.606114] [<bf05a8b8>] (rproc_boot [remoteproc]) from [<bf05bae4>] (rproc_virtio_find_vqs+0x18c/0x1f0 [remoteproc])
    [   11.616767]  r10:dc6c3420 r9:00000002 r8:bf158d5c r7:dc6c2410 r6:dc6c25f0 r5:dc555c44
    [   11.624674]  r4:00000002
    [   11.627250] [<bf05b958>] (rproc_virtio_find_vqs [remoteproc]) from [<bf1582f0>] (rpmsg_probe+0xbc/0x474 [virtio_rpmsg_bus])
    [   11.638425]  r10:00000000 r9:00000000 r8:dc6c2410 r7:dc555c38 r6:dc6c3400 r5:d4945f80
    [   11.646334]  r4:bf05b958
    [   11.648902] [<bf158234>] (rpmsg_probe [virtio_rpmsg_bus]) from [<bf03585c>] (virtio_dev_probe+0x230/0x310 [virtio])
    [   11.659381]  r10:00000000 r9:00000000 r8:00000000 r7:dc6c2420 r6:dc6c2410 r5:00000000
    [   11.667291]  r4:00000000
    [   11.669851] [<bf03562c>] (virtio_dev_probe [virtio]) from [<c03ec44c>] (driver_probe_device+0x204/0x2f8)
    [   11.679370]  r10:00000000 r9:d4b7dc08 r8:0000000f r7:bf158dfc r6:00000000 r5:dc6c2420
    [   11.687276]  r4:c09c5a44
    [   11.689831] [<c03ec248>] (driver_probe_device) from [<c03ec5d4>] (__driver_attach+0x94/0x98)
    [   11.698304]  r9:d4b7dc08 r8:2b48241c r7:00000000 r6:dc6c2454 r5:bf158dfc r4:dc6c2420
    [   11.706131] [<c03ec540>] (__driver_attach) from [<c03ea6d4>] (bus_for_each_dev+0x70/0xa4)
    [   11.714342]  r7:00000000 r6:c03ec540 r5:bf158dfc r4:00000000
    [   11.720066] [<c03ea664>] (bus_for_each_dev) from [<c03ebd38>] (driver_attach+0x24/0x28)
    [   11.728102]  r6:bf035d58 r5:d4945d80 r4:bf158dfc
    [   11.732770] [<c03ebd14>] (driver_attach) from [<c03eb974>] (bus_add_driver+0x1a8/0x220)
    [   11.740811] [<c03eb7cc>] (bus_add_driver) from [<c03ecd74>] (driver_register+0x80/0x100)
    [   11.748935]  r7:d4b7dd00 r6:c093f6f0 r5:bf15c000 r4:bf158dfc
    [   11.754661] [<c03eccf4>] (driver_register) from [<bf035aa4>] (register_virtio_driver+0x30/0x44 [virtio])
    [   11.764180]  r5:bf15c000 r4:00000000
    [   11.767803] [<bf035a74>] (register_virtio_driver [virtio]) from [<bf15c044>] (rpmsg_init+0x44/0x84 [virtio_rpmsg_bus])
    [   11.778556] [<bf15c000>] (rpmsg_init [virtio_rpmsg_bus]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [   11.787988]  r5:bf15c000 r4:c093f6f0
    [   11.791601] [<c00097f4>] (do_one_initcall) from [<c00d46f0>] (do_init_module+0x68/0x398)
    [   11.799724]  r10:bf158f00 r9:d4b7dc08 r8:2b48241c r7:00000001 r6:d4b7dcc0 r5:00000001
    [   11.807634]  r4:bf158f00
    [   11.810192] [<c00d4688>] (do_init_module) from [<c00b10e0>] (load_module+0x1df8/0x2068)
    [   11.818229]  r6:d4b7dc00 r5:00000001 r4:dc555f44
    [   11.822898] [<c00af2e8>] (load_module) from [<c00b153c>] (SyS_finit_module+0x88/0x98)
    [   11.830760]  r10:00000000 r9:dc554000 r8:c000fe24 r7:0000017b r6:b6d83d90 r5:00000007
    [   11.838667]  r4:00000000
    [   11.841223] [<c00b14b4>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   11.849434]  r6:00000000 r5:004ef928 r4:00000000
    [   11.854101] Code: e24cb004 e5910000 ebf53e2c e89da800 (e1a0c00d)
    [   11.860224] ---[ end trace b21868089aac678a ]---
    [   11.864862] note: systemd-udevd[161] exited with preempt_count 1
    [   12.440483]  remoteproc2: powering up 40800000.dsp
    [   12.445354]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583987
    [   12.452377] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [   12.458326] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [   12.468799]  remoteproc2: remote processor 40800000.dsp is now up
    [   12.475241] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   12.480869]  remoteproc2: registered virtio1 (type 7)
    [   12.508531]  remoteproc3: powering up 41000000.dsp
    [   12.513363]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583987
    [   12.522406] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [   12.528369] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [   12.539264]  remoteproc3: remote processor 41000000.dsp is now up
    [   12.546734] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   12.552277]  remoteproc3: registered virtio2 (type 7)
    [   12.943657] libata version 3.00 loaded.
    [   13.011653] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [   13.190218]  remoteproc1: powering up 55020000.ipu
    [   13.195170]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9392404
    [   13.203284] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [   13.214454]  remoteproc1: remote processor 55020000.ipu is now up
    [   13.220804] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   13.228932]  remoteproc1: registered virtio3 (type 7)
    [   13.244754] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [   13.250845] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [   13.261280] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [   13.281246] scsi host0: ahci
    [   13.285003] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
    [   13.534496] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [   13.633521] ata1: SATA link down (SStatus 0 SControl 300)
             Starting Network Service...
    [   13.702352] usbcore: registered new interface driver usbfs
    [   13.713012] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   13.715890] usbcore: registered new interface driver hub
    [   13.716017] usbcore: registered new device driver usb
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Found device /dev/ttyS9.
    [   13.924543] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   13.930082] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   13.939070] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [   13.948451] xhci-hcd xhci-hcd.2.auto: irq 463, io mem 0x488d0000
    [   13.957441] hub 1-0:1.0: USB hub found
    [  OK  ] Started Network Service.
    [   13.968483] hub 1-0:1.0: 1 port detected
    [   13.968957] net eth1: initializing cpsw version 1.15 (0)
    [   13.968982] net eth0: initialized cpsw ale version 1.4
    [   13.968986] net eth0: ALE Table size 1024
    [   14.000128] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   14.005691] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   14.016198] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   14.025547] hub 2-0:1.0: USB hub found
    [   14.029352] hub 2-0:1.0: 1 port detected
    [   14.135569] net eth1: phy found : id is : 0x1ccb00
    [   14.149236] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   14.157443] net eth0: initializing cpsw version 1.15 (0)
    [   14.166105] libphy: PHY 48485000.mdio:01 not found
    [   14.170925] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
    [   14.183141] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Reached target Network.
             Starting Network Name Resolution...
             Starting weston.service...
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS9.
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started weston.service.
    [  OK  ] Started Login Service.
             Starting telnetd.service...
             Starting tiipclad-daemon.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started tiipclad-daemon.service.
             Starting ecarxinit.service...
    [   15.129542] DMA: Module install successful, device major num = 242
    [   15.136543] DRV: Module install successful
    [  OK  ] Started ecarxinit.service.
    [  19.695303] omap8250 4806a000.serial: failed to request DMA
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dra7xx-evm ttyS9
    Arago 2016.12 dra7xx-evm ttyS9
    dra7xx-evm login: root
    root@dra7xx-evm:~#
    root@dra7xx-evm:~# cd /opt/vision_sdk/
    root@dra7xx-evm:/opt/vision_sdk# ls
    FragShader.fsh                avm_qt_app_res                enableIpu2CCSConectivity.sh   models                        ub964Init.sh
    FragShader3Dsfm.fsh           bin                           hdmiReceiverConfig.sh         opencl_env.sh                 vision_sdk_load.sh
    VertShader.vsh                car.pod                       jeep2.bmp                     ov106x3Config.sh              vision_sdk_ov490_pinmux.sh
    VertShader3Dsfm.vsh           cmemk.ko                      load_ocl_kos.sh               pvrscope                      vision_sdk_unload.sh
    VipClockInversion.sh          disableDssInterruptsOnA15.sh  memcache_load.sh              setupUltrasonicPinMux.sh
    apps.out                      enableImx290.sh               memcache_unload.sh            tda2exEnableAVB.sh
    root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh
    insmod: ERROR: could not insert module ./bin/memcache.ko: File exists
    insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory
    mknod: /dev/memcache: File exists
    Error: I2C Read failed
    ./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
    updated  value is
    COMMANDS
    	### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
    	No address check done, may generate:
    	  - bus error (invalid or not accessible <physical address>,
    	  - platform crash/hang (bad <value>).
    	    Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    	    Dump a range of OMAP memory addresses, from <start address> to <end address>.
    	    Note all addresses within given range must be valid and accessible.
    	### WARNING ###: use the following I2C [read | write] commands at your own risk!
    	  - I2C bus error (invalid or not accessible <physical address>,
    	    Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    	    Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    root@dra7xx-evm:/opt/vision_sdk# vi vision_sdk_load.sh
    root@dra7xx-evm:/opt/vision_sdk# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib/
    root@dra7xx-evm:/opt/vision_sdk# ./apps.out
     [HOST]  OSA: MEM: 0: Mapped 0x9fc00000 to 0xb5ec8000 of size 0x00100000
     [HOST]  OSA: MEM: 1: Mapped 0x86203000 to 0xac3c8000 of size 0x09b00000
     [HOST]  OSA: MEM: 2: Mapped 0x9fd00000 to 0xac308000 of size 0x00040000
     [HOST]  OSA: MEM: 3: Mapped 0x9fdc0000 to 0xac348000 of size 0x00080000
     [HOST]  OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
     [HOST]  OSA: IPU1-0 Remote Log Shared Memory @ 0x9fd00000
     [HOST]  OSA: HOST Remote Log Shared Memory @ 0x9fd4f140
     [HOST]  OSA: DSP1 Remote Log Shared Memory @ 0x9fd769e0
     [HOST]  OSA: DSP2 Remote Log Shared Memory @ 0x9fd9e280
     [HOST]  OSA: IPU2 Remote Log Shared Memory @ 0x9fe63da0
     [HOST] [DSP1  ]    224.859391 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    224.871378 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    224.893033 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    225.871408 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    225.893064 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    226.859421 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    227.859452 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    227.871469 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    228.859482 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    228.871500 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    228.893155 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    229.871500 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    229.893155 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    230.859543 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    230.893186 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    231.859574 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    231.871561 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    232.859604 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    232.871591 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    232.893247 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    233.859635 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    233.871622 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    233.893277 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    234.871652 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    234.893308 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    235.859665 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    235.871683 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]    236.859696 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    236.871713 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    236.893369 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    237.859726 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    237.871713 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    237.893399 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP2  ]    238.871744 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    238.893399 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    239.859787 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    239.893430 s:  SYSTEM: Attaching to [IPU1-0][  232.504097] random: nonblocking pool is initialized
     [HOST] [DSP1  ]    240.859818 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    240.871805 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    240.893460 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    241.859848 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    241.871835 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    241.893491 s:  SYSTEM: Attaching to [IPU1-0] ...
     [HOST] [DSP1  ]    242.859848 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]    242.871866 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [IPU2  ]    242.893521 s:  SYSTEM: Attaching to [IPU1-0] ...
    ^C
    [END] 2018/12/17 12:02:02
  • Hi Terence,
    Can you add the below line to your DTB and let us know if it works.
    &ipu1 {
    timers = <&timer9>, <&timer11>;
    Shravan
  • Hi Shravan,
    Bad news, it doesn't work. Please find the early_boot_12_17_2018.log in attachment. I'm not sure that if the value of IPU1_LOAD_ADDR changed  in "u-boot\include\configs\ti_omap5_common.h" will lead to the system crash. I changed it from 0xb0000000 to 0x86000000, Because  the size of DDR is only 512M in the borad.
    Thanks a lot for your support
    Terence
    [BEGIN] 2018/12/17 17:27:42
    [    1.423990] console [ttyS9] enabled
    [    1.430091] bootconsole [earlycon0] disabled
    [    1.438793] [drm] Initialized drm 1.1.0 20060810
    [    1.444348] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.451009] [drm] No driver support for vblank timestamp query.
    [    1.457160] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.470136] loop: module loaded
    [    1.476060] vmemexp device MAJOR num = 245
    [    1.480189] vmemexp class registered
    [    1.483931] /dev/vmemexp device registered
    [    1.488046] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.496334] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.504005] libphy: Fixed MDIO Bus: probed
    [    1.551033] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.557158] libphy: 48485000.mdio: probed
    [    1.564500] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver RTL9000A Gigabit Ethernet
    [    1.574789] cpsw 48484000.ethernet: Detected MACID = f4:84:4c:14:9b:7e
    [    1.581481] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.588438] cpsw 48484000.ethernet: cpsw: Detected MACID = f4:84:4c:14:9b:7f
    [    1.597130] mousedev: PS/2 mouse device common for all mice
    [    1.603387] i2c /dev entries driver
    [    1.612169] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.617008] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.623506] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.629890] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.636293] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.642692] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.649334] vsys_3v3: supplied by vsys_12v0
    [    1.653602] vio_3v3: supplied by vsys_3v3
    [    1.657662] vio_3v3_sd: supplied by vio_3v3
    [    1.662543] ldo4: supplied by vsys_5v0
    [    1.711442] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.717829] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.741175] smps5: supplied by vsys_3v3
    [    1.745225] vio_1v8: supplied by smps5
    [    1.791951] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.803144] hwspinlock_user gatemp: requested 20 hwspinlocks
    [    1.810081] aic_dvdd: supplied by vio_3v3
    [    1.815376] davinci-mcasp 48464000.mcasp: DAI is shared
    [    1.820704] davinci-mcasp 48464000.mcasp: Can't verify DMA configuration (-19)
    [    1.827996] davinci-mcasp 48464000.mcasp: No DMA controller found (-19)
    [    1.835198] davinci-mcasp 48468000.mcasp: Can't verify DMA configuration (-19)
    [    1.842509] davinci-mcasp 48468000.mcasp: No DMA controller found (-19)
    [    1.849358] davinci-mcasp 48474000.mcasp: DAI is shared
    [    1.854707] davinci-mcasp 48474000.mcasp: Can't verify DMA configuration (-19)
    [    1.861996] davinci-mcasp 48474000.mcasp: No DMA controller found (-19)
    [    1.869778] NET: Registered protocol family 10
    [    1.885100] sit: IPv6 over IPv4 tunneling driver
    [    1.890282] NET: Registered protocol family 17
    [    1.895042] Key type dns_resolver registered
    [    1.899513] omap_voltage_late_init: Voltage driver support not added
    [    1.906420] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.912668] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.918950] buck10: supplied by vsys_3v3
    [    1.923542] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.929752] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.937083] Power Management for TI OMAP4+ devices.
    [    1.942206] Registering SWP/SWPB emulation handler
    [    1.948278] dmm 4e000000.dmm: workaround for errata i878 in use
    [    1.955669] dmm 4e000000.dmm: initialized all PAT entries
    [    1.962151] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    1.979848] hctosys: unable to open rtc device (rtc0)
    [    1.996638] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.997105] aic_dvdd: disabling
    [    1.997137] clk: Not disabling unused clocks
    [    1.997145] ALSA device list:
    [    1.997147]   No soundcards found.
    [    .018631] mmc0: new SDHC card at address 0001
    [    2.023255] Waiting for root device /dev/mmcblk0p2...
    [    2.038564] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
    [    2.044668]  mmcblk0: p1 p2
    [    2.105539] mmc1: MAN_BKOPS_EN bit is not set
    [    2.117595] mmc1: mmc_select_hs200 failed, error -74
    [    2.122601] : switch to mmc1 failed
    [    2.127572] mmc1: new MMC card at address 0001
    [    2.142538] mmcblk1: mmc1:0001 DG4008 7.28 GiB
    [    2.157343] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
    [    2.163590] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
    [    2.496905] EXT4-fs (mmcblk0p2): recovery complete
    [    2.507982] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.516157] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.523726] devtmpfs: mounted
    [    2.526922] Freeing unused kernel memory: 340K
    [    2.531404] This architecture does not have kernel memory protection.
    [    2.567850] Kernel Entry time 234426 ticks
    [    3.215739] systemd[1]: System time before build time, advancing clock.
    [    3.270086] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.283358] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    3.300979] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    3.319590] systemd[1]: Detected architecture arm.
    Welcome to Arago 2016.12!
    [    3.342125] systemd[1]: Set hostname to <dra7xx-evm>.
    [    3.442272] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    3.453517] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    3.461149] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    3.464370] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
    [    3.483701] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [    3.614387] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    3.623965] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    3.634116] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [    3.845785] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    3.853623] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    3.861349] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    3.868610] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [    3.876130] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
    [    3.883342] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    3.890779] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    3.900244] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [    3.933391] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.952796] systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    [    3.971891] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.991258] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.013985] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    4.041354] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    4.071142] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    4.091262] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.151214] systemd[1]: Mounting Debug File System...
    [    4.186637] systemd[1]: Starting Load Kernel Modules...
    [    4.213642] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.233591] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.241361] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [    4.271260] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    4.331440] systemd[1]: Starting Journal Service...
    [    4.353876] systemd[1]: Starting Create list of required static device nodes for the current kernel...
             Starting Create list of required st... nodes for the current kernel...
    [    4.381393] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.441449] systemd[1]: Starting Setup Virtual Console...
    [    4.461187] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    4.484673] systemd[1]: Mounting Temporary Directory...
    [    4.511909] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.531171] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    4.581252] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.611232] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.631178] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.651939] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    4.706293] systemd[1]: Mounted Debug File System.
    [  OK  ] Mounted Debug File System.
    [    4.731214] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    4.751201] systemd[1]: Mounted Temporary Directory.
    [  OK  ] Mounted Temporary Directory.
    [    4.771414] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [  OK  ] Started Setup Virtual Console.
             Starting Create Static Device Nodes in /dev...
             Starting Load/Save Random Seed...
             Starting udev Coldplug all Devices...
             Starting Apply Kernel Variables...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Apply Kernel Variables.
    [    5.561873] systemd-journald[106]: Received request to flush runtime journal from PID 1
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [    6.352545] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
    [    6.375769]  remoteproc0: 58820000.ipu is available
    [    6.395878]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    6.442788]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [  OK  ] Started Network Time Synchronization.
    [    6.480739] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
    [    6.513231]  remoteproc1: 55020000.ipu is available
    [    6.532749]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [[    6.542282]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
      OK  ] Found device /dev/ttyS0.
    [    6.573539] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
    [  OK  ] Reached target System Time Synchronized.
    [    6.589954]  remoteproc2: 40800000.dsp is available
    [    6.617080]  remoteproc2: Note: remoteproc is still under development and considered experimental.
             Starting Synchronize System and HW clocks...
    [    6.634338]  remoteproc0: registered virtio0 (type 7)
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    6.657429]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    6.686281] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
    [FAILED] Failed to start Synchronize System and HW c[    6.701421]  remoteproc3: 41000000.dsp is available
    locks.
    See 'systemctl status sync-clocks.service' for details.[    6.716937]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [    6.765090]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [  OK  ] Reached target System Initialization.
    [    6.850922] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Permit User Sessions...
             Starting Login Service...
    [    7.057464] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    7.572871] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [    7.602375] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    7.608234] omap-aes 4b500000.aes: Unable to request in DMA channel
    [    7.627965] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    7.640642] omap-aes 4b700000.aes: Unable to request in DMA channel
    [    8.774157]  remoteproc0: powering up 58820000.ipu
    [    8.779746]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 589684
    [    8.786730] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
    [    8.793890]  remoteproc0: remote processor 58820000.ipu is now up
    [    8.800345] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.805921] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
    [    8.936983] SCSI subsystem initialized
    [    9.330273]  remoteproc2: powering up 40800000.dsp
    [    9.335139]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583987
    [    9.344594] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [    9.350507] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [    9.357705]  remoteproc2: remote processor 40800000.dsp is now up
    [    9.364612] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.367956] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
    [    9.377248]  remoteproc2: registered virtio1 (type 7)
    [    9.418045] NET: Registered protocol family 41
    [   10.263445]  remoteproc3: powering up 41000000.dsp
    [   10.268724]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583987
    [   10.275793] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [   10.281741] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [   10.301929]  remoteproc3: remote processor 41000000.dsp is now up
    [   10.308277] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   10.317955] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
    [   10.321047]  remoteproc3: registered virtio2 (type 7)
    [   10.621230] libata version 3.00 loaded.
    [   10.644318] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [   10.825961]  remoteproc1: powering up 55020000.ipu
    [   10.831414]  remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9392404
    [   10.839960] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [   10.848027] omap_rproc_request_timer: request for timer node df61991c failed
    [   10.855395] omap-rproc 55020000.ipu: request for timer df61991c failed: -16
    [   10.862442] omap-rproc 55020000.ipu: omap_rproc_enable_timers failed: -16
    [   10.869274]  remoteproc1: can't start rproc 55020000.ipu: -16
    [   10.880109]  remoteproc1: rproc_boot() failed -16
    [   10.884918] virtio_rpmsg_bus: probe of virtio3 failed with error -16
    [   10.891351]  remoteproc1: registered virtio3 (type 7)
    [   10.920987] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
    [   10.926668] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [   10.936417] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
    [   10.947342] scsi host0: ahci
    [   10.950784] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
    [   11.190298] usbcore: registered new interface driver usbfs
    [   11.197964] usbcore: registered new interface driver hub
    [  OK  ] Started Daily Cleanup of Temporary Directorie[   11.206593] usbcore: registered new device driver usb
    s.
    [  OK  ] Reached target Timers.
             Starting rc.pvr.service...
    [   11.301092] ata1: SATA link down (SStatus 0 SControl 300)
    [   11.396975] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [  OK  ] Started System Logging Service.
    [  OK  ] Started Kernel Logging Service.
    [   11.434327] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   11.451093] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   11.462521] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [   11.473783] xhci-hcd xhci-hcd.2.auto: irq 463, io mem 0x488d000
    [   11.480986] hub 1-0:1.0: USB hub found
    [   11.485178] hub 1-0:1.0: 1 port detected
    [   11.487045] net eth1: initializing cpsw version 1.15 (0)
    [   11.494810] net eth0: initialized cpsw ale version 1.4
    [   11.499976] net eth0: ALE Table size 1024
    [   11.508528] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   11.519122] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   11.528030] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [   11.528176] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   11.529128] hub 2-0:1.0: USB hub found
    [   11.529175] hub 2-0:1.0: 1 port detected
    [   11.673023] net eth1: phy found : id is : 0x1ccb00
    [   11.697372] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   11.726632] net eth0: initializing cpsw version 1.15 (0)
    [   11.745905] libphy: PHY 48485000.mdio:01 not found
    [   11.752678] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
    [   11.767628] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   13.149122] DMA: Module install successful, device major num = 242
    [   13.155463] DRV: Module install successful
    [   17521588] omap8250 4806a000.serial: failed to request DMA
    [   17.527438] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   17.534519] pgd = dc720000
    [   17.537236] [00000000] *pgd=00000000
    [  17.540840] Internal error: : 1406 [#1] PREEMPT SMP ARM
    [   17.546001] Modules linked in: memcache(O) bc_example(O) xhci_plat_hcd xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core scsi_mod virtio_rpmsg_bus omap_aes_driver omap_sham dwc3_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring extcon_usb_gpio extcon sch_fq_codel
    [   17.576565] CPU: 0 PID: 587 Comm: (agetty) Tainted: G           O    4.4.84 #1
    [   17.583818] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   17.589938] task: dc778600 ti: d48ae000 task.ti: d48ae000
    [   17.595366] PC is at pcs_readl+0x14/0x18
    [   17.599306] LR is at pcs_irq_mask+0x78/0xa4
    [   17.603508] pc : [<c02ec65c>]    lr : [<c02ec6e8>]    psr: a0010093
    [   17.603508] sp : d48afd30  ip : d48afd40  fp : d48afd3c
    [   17.615035] r10: c0350760  r9 : 01000000  r8 : df3ef440
    [   17.620282] r7 : df3ef42c  r6 : 000001cd  r5 : df3ef4b4  r4 : dc93e0dc
    [   17.626837] r3 : c02ec648  r2 : 00000000  r1 : fc0037e0  r0 : 00000000
    [   17.633393] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   17.640646] Control: 10c5387d  Table: 9c72006a  DAC: 00000051
    [   17.646416] Process (agetty) (pid: 587, stack limit = 0xd48ae210)
    [   17.652536] Stack: (0xd48afd30 to 0xd48b0000)
    [   17.656914] fd20:                                     d48afd64 d48afd40 c02ec6e8 c02ec654
    [   17.665129] fd40: dc810180 dc810190 dc8101e0 000001cd 60010013 db189a00 d48afd7c d48afd68
    [   17.673344] fd60: c008926c c02ec67c db1899c0 dc810180 d48afda4 d48afd80 c00866b0 c0089200
    [   17.681559] fd80: 00000000 dc810180 000001cd db189a00 00000000 c0350a30 d48afdc4 d48afda8
    [   17.689774] fda0: c008677c c0086444 db189a00 df244610 df244674 a0010013 d48afde4 d48afdc8
    [   17.697990] fdc0: c03f6c70 c0086744 c09c1880 c09c1880 df056088 00010013 d48afdfc d48afde8
    [   17.706205] fde0: c0377a98 c03f6c10 df056000 c09c1880 d48afe0c d48afe00 c0371990 c03779b8
    [   17.714419] fe00: d48afe2c d48afe10 c036c4a4 c0371980 df056000 df056090 d4850c00 df056064
    [   17.722634] fe20: d48afe54 d48afe30 c036e294 c036c3dc 00000000 d4850c00 d4850d5c 00000001
    [   17.730849] fe40: 00000000 c0350a30 d48afe94 d48afe58 c03505bc c036e250 dc602cc0 00000000
    [   17.739064] fe60: 00000000 00000000 d48afe84 d4850c00 00005437 dc602cc0 80000000 00000000
    [   17.747280] fe80: d4850c00 00000000 d48aff14 d48afe98 c035197c c0350224 dc602cc0 d48afeb0
    [   17.755495] fea0: d48aff4c d48afeb0 c01328a4 c012ca54 dca75610 dcc432a8 80080007 00000005
    [   17.763710] fec0: dc446015 c02e15a4 00000000 dcd433b8 dc93a7d0 df001900 dc446000 c0131bfc
    [   17.771926] fee0: d48ae000 dfa41900 d48aff00 0004e7ea 80000000 dc93a7d0 dc602cc0 00000003
    [   17.780140] ff00: 80000000 d48ae000 d48aff7c d48aff18 c013500c c0350ec8 00000020 dc93a7d0
    [   17.788354] ff20: dc602cc8 00000000 d48aff4c d48aff38 c0131bfc c0113ecc 00000003 dc602cc0
    [   17.796569] ff40: d48aff94 d48aff50 c01234e4 c0131b9c 00000000 dc602cc0 00000003 dc602cc0
    [   17.804785] ff60: 00005437 80000000 d48ae000 00000000 d48affa4 d48aff80 c01352c4 c0134bb8
    [   17.813001] ff80: 0065a7b0 0065ce20 b6fdace0 00000036 c000fe24 d48ae000 00000000 d48affa8
    [   17.821215] ffa0: c000fc60 c0135294 0065a7b0 0065ce20 00000003 00005437 80000000 00000000
    [   17.829431] ffc0: 0065a7b0 0065ce20 b6fdace0 00000036 00000003 00000000 bec58718 bec585b4
    [   17.837645] ffe0: 00625c54 bec5833c 0056bb00 b6f404d6 20010030 00000003 00000000 00000000
    [   17.845855] Backtrace:
    [   17.848325] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
    [   17.855670] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
    [   17.863269]  r9:db189a00 r8:60010013 r7:000001cd r6:dc8101e0 r5:dc810190 r4:dc810180
    [   17.871098] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
    [   17.878697]  r5:dc810180 r4:db1899c0
    [   17.882308] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
    [   17.889385]  r9:c0350a30 r8:00000000 r7:db189a00 r6:000001cd r5:dc810180 r4:00000000
    [   17.897215] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
    [   17.905251]  r7:a0010013 r6:df244674 r5:df244610 r4:db189a00
    [   17.910978] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
    [   17.919886]  r7:00010013 r6:df056088 r5:c09c1880 r4:c09c1880
    [   17.925609] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
    [   17.931365] thermal thermal_zone0: failed to read out thermal zone (-5)
    [   17.931393] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   17.931396] pgd = d2c00000
    [   17.931408] [00000000] *pgd=9c6d1831, *pte=00000000, *ppte=00000000
    [   17.957052]  r5:c09c1880 r4:df056000
    [   17.960665] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
    [   17.969057] [<c036c3d0>] (uart_shutdown) from [<c036e294>] (uart_hangup+0x50/0x104)
    [   17.976744]  r7:df056064 r6:d4850c00 r5:df056090 r4:df056000
    [   17.982472] [<c036e244>] (uart_hangup) from [<c03505bc>] (__tty_hangup+0x3a4/0x3b4)
    [   17.990158]  r9:c0350a30 r8:00000000 r7:00000001 r6:d4850d5c r5:d4850c00 r4:00000000
    [   17.997987] [<c0350218>] (__tty_hangup) from [<c035197c>] (tty_ioctl+0xac0/0xe8c)
    [   18.005501]  r10:00000000 r9:d4850c00 r8:00000000 r7:80000000 r6:dc602cc0 r5:00005437
    [   18.013410]  r4:d4850c00
    [   18.015968] [<c0350ebc>] (tty_ioctl) from [<c013500c>] (do_vfs_ioctl+0x460/0x6dc)
    [   18.023480]  r9:d48ae000 r8:80000000 r7:00000003 r6:dc602cc0 r5:dc93a7d0 r4:80000000
    [   18.031305] [<c0134bac>] (do_vfs_ioctl) from [<c01352c4>] (SyS_ioctl+0x3c/0x64)
    [   18.038644]  r10:00000000 r9:d48ae000 r8:80000000 r7:00005437 r6:dc602cc0 r5:00000003
    [   18.046554]  r4:dc602cc0
    [   18.049112] [<c0135288>] (SyS_ioctl) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   18.056712]  r9:d48ae000 r8:c000fe24 r7:00000036 r6:b6fdace0 r5:0065ce20 r4:0065a7b0
    [   18.064541] Code: e92dd800 e24cb004 e5900000 f57ff04f (e89da800)
    [   18.070664] ---[ end trace 4307e6d07cae3713 ]---
    [   18.070668] Internal error: : 1406 [#2] PREEMPT SMP ARM
    [   18.070733] Modules linked in: memcache(O) bc_example(O) xhci_plat_hcd xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core scsi_mod virtio_rpmsg_bus omap_aes_driver omap_sham dwc3_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring extcon_usb_gpio extcon sch_fq_codel
    [   18.070739] CPU: 1 PID: 646 Comm: apps.out Tainted: G      D    O    4.4.84 #1
    [   18.070743] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.070747] task: dc5a3600 ti: dc766000 task.ti: dc766000
    [   18.070757] PC is at ret_fast_syscall+0x0/0x3c
    [   18.070764] LR is at SyS_read+0x94/0xa8
    [   18.070771] pc : [<c000fc60>]    lr : [<c0124b58>]    psr: 200c0013
    [   18.070771] sp : dc767fa8  ip : dc767f80  fp : 00000000
    [   18.070774] r10: 00000000  r9 : dc766000  r8 : c000fe24
    [   18.070778] r7 : 00000003  r6 : 000ad200  r5 : b628fc04  r4 : b6290650
    [   18.070782] r3 : dc6cecdc  r2 : 00000001  r1 : 00000000  r0 : 00000000
    [   18.070786] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.070790] Control: 10c5387d  Table: 92c0006a  DAC: 00000051
    [   18.070793] Process apps.out (pid: 646, stack limit = 0xdc766210)
    [   18.070796] Stack: (0xdc767fa8 to 0xdc768000)
    [   18.070804] 7fa0:                   b6290650 b628fc04 00000000 b6fb6000 00001000 00000000
    [   18.070812] 7fc0: b6290650 b628fc04 000ad200 00000003 00000000 00000000 b6fbb000 00000000
    [   18.070819] 7fe0: 00000000 bea85c60 00000000 b62304f2 800c0030 00000000 00000000 00000000
    [   18.070825] Backtrace: no frame pointer
    [   18.070832] Code: e89da800 00000000 00000000 00000000 (f10c0080)
    [   18.070838] ---[ end trace 4307e6d07cae3714 ]---
    [   18.230368] note: (agetty)[587] exited with preempt_count 2
    [   18.236014] ------------[ cut here ]------------
    [   18.240661] WARNING: CPU: 0 PID: 587 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
    [   18.250184] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
    [   18.261972] Modules linked in: memcache(O) bc_example(O) xhci_plat_hcd xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core scsi_mod virtio_rpmsg_bus omap_aes_driver omap_sham dwc3_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring extcon_usb_gpio extcon sch_fq_codel
    [   18.292527] CPU: 0 PID: 587 Comm: (agetty) Tainted: G      D    O    4.4.84 #1
    [   18.299780] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.305898] Backtrace:
    [   18.308373] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [   18.315975]  r7:c02e3bb0 r6:20010193 r5:00000000 r4:c0959350
    [   18.321702] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
    [   18.328961] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
    [   18.337084]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:d48af818
    [   18.342807] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
    [   18.351541]  r8:00000017 r7:c084c280 r6:00000000 r5:c084c340 r4:c084c3e4
    [   18.358322] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
    [   18.367230]  r3:df20a940 r2:c084c3e4
    [   18.370838]  r4:80080003
    [   18.373401] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
    [   18.382745]  r10:c0988e4b r9:df208240 r8:00000017 r7:00000000 r6:00000000 r5:df2082a0
    [   18.390658]  r4:df20ae40
    [   18.393215] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
    [   18.402124]  r10:c081ef94 r9:c02ec65e r8:df008000 r7:00000000 r6:c0941c8c r5:df2082a0
    [   18.410033]  r4:df208240
    [   18.412591] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
    [   18.421151]  r7:00000000 r6:c0941c8c r5:df2082a0 r4:df208240
    [   18.426878] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
    [   18.431025] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [   18.431029] pgd = c0004000
    [   18.431035] [00000000] *pgd=00000000
    [   18.431042] Internal error: : 1406 [#3] PREEMPT SMP ARM
    [   18.431104] Modules linked in: memcache(O) bc_example(O) xhci_plat_hcd xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core scsi_mod virtio_rpmsg_bus omap_aes_driver omap_sham dwc3_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring extcon_usb_gpio extcon sch_fq_codel
    [   18.431111] CPU: 1 PID: 92 Comm: kworker/1:2 Tainted: G      D    O    4.4.84 #1
    [   18.431114] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.431125] Workqueue: events_freezable thermal_zone_device_check
    [   18.431130] task: dca2ec00 ti: dc42a000 task.ti: dc42a000
    [   18.431137] PC is at ti_bandgap_force_single_read+0x4c/0x188
    [   18.431143] LR is at ti_bandgap_read_temperature+0xb8/0xf8
    [   18.431149] pc : [<c04d1ff4>]    lr : [<c04d379c>]    psr: 400b0013
    [   18.431149] sp : dc42bdf8  ip : dc42be20  fp : dc42be1c
    [   18.431152] r10: df5d89c0  r9 : 00000000  r8 : 00000000
    [   18.431156] r7 : 00000000  r6 : 00000000  r5 : dca36b10  r4 : 00000000
    [   18.431160] r3 : 0000014c  r2 : fc00232c  r1 : c0977ab8  r0 : dca36b10
    [   18.431166] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.431170] Control: 10c5387d  Table: 9c57006a  DAC: 00000051
    [   18.431175] Process kworker/1:2 (pid: 92, stack limit = 0xdc42a210)
    [   18.431178] Stack: (0xdc42bdf8 to 0xdc42c000)
    [   18.431183] bde0:                                                       dca36b10 00000000
    [   18.431190] be00: dc42be40 dca54010 dca36b10 00000000 dc42be3c dc42be20 c04d379c c04d1fb4
    [   18.431198] be20: 00000000 dc42beb4 c06f7450 dca54010 dc42be6c dc42be40 c04d3b6c c04d36f0
    [   18.431204] be40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc42beb4 df5dc300 00000000
    [   18.431211] be60: dc42be7c dc42be70 c04cef6c c04d3b3c dc42beac dc42be80 c04cb5fc c04cef50
    [   18.431218] be80: 7fffffff df5d8e40 dca2ec00 df312a2c df312800 df5d89c0 00000000 df5dc300
    [   18.431225] bea0: dc42becc dc42beb0 c04ccde0 c04cb5ac dc42bedc dc42bec0 df312a2c dc420880
    [   18.431231] bec0: dc42bedc dc42bed0 c04ccecc c04ccdd0 dc42bf1c dc42bee0 c004f330 c04ccea0
    [   18.431239] bee0: df5d89c0 df5d89d4 dc42a000 00000008 dc420880 df5d89c0 dc420898 df5d89d4
    [   18.431245] bf00: dc42a000 00000008 dc420880 df5d89c0 dc42bf54 dc42bf20 c004f64c c004f218
    [   18.431252] bf20: dc420880 c093c100 00000000 00000000 dc51fe40 dc42a000 dc420880 c004f600
    [   18.431258] bf40: 00000000 00000000 dc42bfac dc42bf58 c0055184 c004f60c dc42bf58 00000000
    [   18.431266] bf60: dc42a000 dc420880 00000000 00000000 dc42bf70 dc42bf70 00000000 00000000
    [   18.431272] bf80: dc42bf80 dc42bf80 dc42bfac dc51fe40 c0055084 00000000 00000000 00000000
    [   18.431278] bfa0: 00000000 dc42bfb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [   18.431285] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   18.431291] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [   18.431296] Backtrace:
    [   18.431305] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [   18.431320]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc42be40 r5:00000000 r4:dca36b10
    [   18.431330] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [   18.431343]  r7:dca54010 r6:c06f7450 r5:dc42beb4 r4:00000000
    [   18.431351] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [   18.431365]  r9:00000000 r8:df5dc300 r7:dc42beb4 r6:df312a0c r5:df312800 r4:df312800
    [   18.431373] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [   18.431382] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [   18.431394]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
    [   18.431400] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [   18.431407]  r5:dc420880 r4:df312a2c
    [   18.431414] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [   18.431420] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [   18.431435]  r10:df5d89c0 r9:dc420880 r8:00000008 r7:dc42a000 r6:df5d89d4 r5:dc420898
    [   18.431438]  r4:df5d89c0
    [   18.431447] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [   18.431460]  r10:00000000 r9:00000000 r8:c004f600 r7:dc420880 r6:dc42a000 r5:dc51fe40
    [   18.431464]  r4:00000000
    [   18.431472] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [   18.431484]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc51fe40
    [   18.431493] Code: e5913000 e0822003 e5928000 f57ff04f (e5913008)
    [   18.431499] ---[ end trace 4307e6d07cae3715 ]---
    [   18.431596] Unable to handle kernel paging request at virtual address ffffffec
    [   18.431601] pgd = c0004000
    [   18.431612] [ffffffec] *pgd=9face861, *pte=00000000, *ppte=00000000
    [   18.431617] Internal error: Oops: 37 [#4] PREEMPT SMP ARM
    [   18.431678] Modules linked in: memcache(O) bc_example(O) xhci_plat_hcd xhci_hcd usbcore ahci_platform libahci_platform libahci pvrsrvkm(O) libata dwc3 rpmsg_proto udc_core scsi_mod virtio_rpmsg_bus omap_aes_driver omap_sham dwc3_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring extcon_usb_gpio extcon sch_fq_codel
    [   18.431685] CPU: 1 PID: 92 Comm: kworker/1:2 Tainted: G      D    O    4.4.84 #1
    [   18.431688] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   18.431701] task: dca2ec00 ti: dc42a000 task.ti: dc42a000
    [   18.431707] PC is at kthread_data+0x10/0x18
    [   18.431711] LR is at wq_worker_sleeping+0x14/0xd8
    [   18.431716] pc : [<c00555d4>]    lr : [<c00503fc>]    psr: 200b0193
    [   18.431716] sp : dc42bba0  ip : dc42bbb0  fp : dc42bbac
    [   18.431719] r10: 00000001  r9 : df5d8e40  r8 : dca2efa8
    [   18.431722] r7 : c093c6d4  r6 : c0937e40  r5 : dca2ec00  r4 : 00000001
    [   18.431725] r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : dca2ec00
    [   18.431731] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [   18.431735] Control: 10c5387d  Table: 9c57006a  DAC: 00000051
    [   18.431739] Process kworker/1:2 (pid: 92, stack limit = 0xdc42a210)
    [   18.431742] Stack: (0xdc42bba0 to 0xdc42c000)
    [   18.431750] bba0: dc42bbc4 dc42bbb0 c00503fc c00555d0 df5d8e40 dca2ec00 dc42bc1c dc42bbc8
    [   18.431757] bbc0: c0687680 c00503f4 dc42bbf4 dc42bbd8 c0299794 c0113ecc 00000000 db266dc0
    [   18.431764] bbe0: db266dcc c06878b8 00000000 dc42bbf8 c0299aac dc42a000 dc42b904 df080000
    [   18.431770] bc00: dc42bc40 dca2ef20 c04d1ff6 c081ef94 dc42bc34 dc42bc20 c06878b8 c0687204
    [   18.431777] bc20: dca2ec00 dc42b904 dc42bc5c dc42bc38 c003c258 c0687870 00000001 00000000
    [   18.431783] bc40: dc42bc40 dc42bc40 c00393a8 c04d1ff8 dc42bce4 dc42bc60 c0013f68 c003bc24
    [   18.431791] bc60: dc42a210 0000000b c081ef9c 00000008 00000000 dc42a000 00000000 600b0193
    [   18.431797] bc80: 6542bca4 33313935 20303030 32383065 33303032 39356520 30303832 35662030
    [   18.431804] bca0: 30666637 28206634 31393565 38303033 c0002029 c0004000 dc42bcf4 c0940fb4
    [   18.431812] bcc0: 00001406 00000007 00000000 dc42bda8 00000000 df5d89c0 dc42bcf4 dc42bce8
    [   18.431819] bce0: c0014198 c0013d28 dc42bda4 dc42bcf8 c0009370 c0014184 00000000 00000409
    [   18.431826] bd00: 00000007 00000000 00030003 00000000 00000001 00000000 00000000 00000000
    [   18.431832] bd20: 00000000 00000000 00000000 00000400 000000a3 00000000 00000000 00000001
    [   18.431839] bd40: 00000000 00000000 dc42bdd4 c0935338 00000409 000003fc c093c5b8 dc77865c
    [   18.431846] bd60: c093c6d4 00000064 dc42be34 dc42bd78 c006f18c c068b508 df5d6338 c0937e40
    [   18.431853] bd80: 00000001 c04d1ff4 400b0013 ffffffff dc42bddc 00000000 dc42be1c dc42bda8
    [   18.431859] bda0: c00147e0 c00092c0 dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
    [   18.431867] bdc0: 00000000 00000000 00000000 00000000 df5d89c0 dc42be1c dc42be20 dc42bdf8
    [   18.431874] bde0: c04d379c c04d1ff4 400b0013 ffffffff 00000051 00000000 dca36b10 00000000
    [   18.431880] be00: dc42be40 dca54010 dca36b10 00000000 dc42be3c dc42be20 c04d379c c04d1fb4
    [   18.431888] be20: 00000000 dc42beb4 c06f7450 dca54010 dc42be6c dc42be40 c04d3b6c c04d36f0
    [   18.431894] be40: df5d8e80 c0937e40 df312800 df312800 df312a0c dc42beb4 df5dc300 00000000
    [   18.431901] be60: dc42be7c dc42be70 c04cef6c c04d3b3c dc42beac dc42be80 c04cb5fc c04cef50
    [   18.431907] be80: 7fffffff df5d8e40 dca2ec00 df312a2c df312800 df5d89c0 00000000 df5dc300
    [   18.431915] bea0: dc42becc dc42beb0 c04ccde0 c04cb5ac dc42bedc dc42bec0 df312a2c dc420880
    [   18.431921] bec0: dc42bedc dc42bed0 c04ccecc c04ccdd0 dc42bf1c dc42bee0 c004f330 c04ccea0
    [   18.431929] bee0: df5d89c0 df5d89d4 dc42a000 00000008 dc420880 df5d89c0 dc420898 df5d89d4
    [   18.431935] bf00: dc42a000 00000008 dc420880 df5d89c0 dc42bf54 dc42bf20 c004f64c c004f218
    [   18.431942] bf20: dc420880 c093c100 00000000 00000000 dc51fe40 dc42a000 dc420880 c004f600
    [   18.431949] bf40: 00000000 00000000 dc42bfac dc42bf58 c0055184 c004f60c dc42bf58 00000000
    [   18.431956] bf60: dc42a000 dc420880 00000000 00000000 dc42bf70 dc42bf70 00000001 00010001
    [   18.431962] bf80: dc42bf80 dc42bf80 dc42bfac dc51fe40 c0055084 00000000 00000000 00000000
    [   18.431969] bfa0: 00000000 dc42bfb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [   18.431975] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   18.431981] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [   18.431985] Backtrace:
    [   18.431993] [<c00555c4>] (kthread_data) from [<c00503fc>] (wq_worker_sleeping+0x14/0xd8)
    [   18.432003] [<c00503e8>] (wq_worker_sleeping) from [<c0687680>] (__schedule+0x488/0x66c)
    [   18.432010]  r5:dca2ec00 r4:df5d8e40
    [   18.432018] [<c06871f8>] (__schedule) from [<c06878b8>] (schedule+0x54/0xc4)
    [   18.432032]  r10:c081ef94 r9:c04d1ff6 r8:dca2ef20 r7:dc42bc40 r6:df080000 r5:dc42b904
    [   18.432037]  r4:dc42a000
    [   18.432045] [<c0687864>] (schedule) from [<c003c258>] (do_exit+0x640/0x9b8)
    [   18.432052]  r5:dc42b904 r4:dca2ec00
    [   18.432059] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
    [   18.432062]  r7:c04d1ff8
    [   18.432068] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
    [   18.432082]  r10:df5d89c0 r9:00000000 r8:dc42bda8 r7:00000000 r6:00000007 r5:00001406
    [   18.432086]  r4:c0940fb4
    [   18.432092] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
    [   18.432098] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
    [   18.432101] Exception stack(0xdc42bda8 to 0xdc42bdf0)
    [   18.432108] bda0:                   dca36b10 c0977ab8 fc00232c 0000014c 00000000 dca36b10
    [   18.432114] bdc0: 00000000 00000000 00000000 00000000 df5d89c0 dc42be1c dc42be20 dc42bdf8
    [   18.432119] bde0: c04d379c c04d1ff4 400b0013 ffffffff
    [   18.432132]  r8:00000000 r7:dc42bddc r6:ffffffff r5:400b0013 r4:c04d1ff4
    [   18.432140] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [   18.432152]  r9:00000000 r8:dca36b10 r7:dca54010 r6:dc42be40 r5:00000000 r4:dca36b10
    [   18.432160] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [   18.432170]  r7:dca54010 r6:c06f7450 r5:dc42beb4 r4:00000000
    [   18.432177] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [   18.432189]  r9:00000000 r8:df5dc300 r7:dc42beb4 r6:df312a0c r5:df312800 r4:df312800
    [   18.432197] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [   18.432205] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [   18.432218]  r8:df5dc300 r7:00000000 r6:df5d89c0 r5:df312800 r4:df312a2c
    [   18.432224] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [   18.432229]  r5:dc420880 r4:df312a2c
    [   18.432235] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [   18.432242] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [   18.432255]  r10:df5d89c0 r9:dc420880 r8:00000008 r7:dc42a000 r6:df5d89d4 r5:dc420898
    [   18.432259]  r4:df5d89c0
    [   18.432265] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [   18.432278]  r10:00000000 r9:00000000 r8:c004f600 r7:dc420880 r6:dc42a000 r5:dc51fe40
    [   18.432282]  r4:00000000
    [   18.432290] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [   18.432302]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:dc51fe40
    [   18.432309] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
    [   18.432314] ---[ end trace 4307e6d07cae3716 ]---
    [   18.432317] Fixing recursive fault but reboot is needed!
    [   19.588422]  r7:00000000 r6:d48afaf0 r5:00000017 r4:c093640c
    [   19.594149] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
    [   19.602889] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [   19.611273]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d48af9d8 r5:fa21200c r4:c093c8e4
    [   19.619100] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [   19.626614] Exception stack(0xd48af9d8 to 0xd48afa20)
    [   19.631686] f9c0:                                                       00000000 c098c2c0
    [   19.639901] f9e0: 00000000 00000000 00000282 00000012 d48ae000 00000000 df008000 c02ec65e
    [   19.648116] fa00: c081ef94 d48afa84 d48afa88 d48afa28 c003d464 c003cfd0 60010113 ffffffff
    [   19.656327]  r9:c02ec65e r8:df008000 r7:d48afa0c r6:ffffffff r5:60010113 r4:c003cfd0
    [   19.664157] [<c003cf3c>] (__do_softirq) from [<c003d464>] (irq_exit+0xbc/0x11c)
    [   19.671496]  r10:c081ef94 r9:c02ec65e r8:df008000 r7:00000000 r6:00000000 r5:00000012
    [   19.679408]  r4:ffffe000
    [   19.681966] [<c003d3a8>] (irq_exit) from [<c00853d0>] (__handle_domain_irq+0x68/0xbc)
    [   19.689827]  r5:00000012 r4:c093640c
    [   19.693440] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [   19.701825]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d48afaf0 r5:fa21200c r4:c093c8e4
    [   19.709655] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [   19.717169] Exception stack(0xd48afaf0 to 0xd48afb38)
    [   19.722242] fae0:                                     dc61bec4 00000000 00000000 0000015f
    [   19.730457] fb00: dc436000 0000000b 000012cc c02ec660 00000001 c02ec65e c081ef94 d48afb4c
    [   19.738670] fb20: d48afb50 d48afb40 c00b36a0 c068b5d8 40010113 ffffffff
    [   19.745310]  r9:c02ec65e r8:00000001 r7:d48afb24 r6:ffffffff r5:40010113 r4:c068b5d8
    [   19.753146] [<c068b5b0>] (_raw_spin_unlock_irq) from [<c00b36a0>] (acct_collect+0x198/0x1b8)
    [   19.761625] [<c00b3508>] (acct_collect) from [<c003c2b8>] (do_exit+0x6a0/0x9b8)
    [   19.768964]  r7:c02ec660 r6:00000001 r5:0000000b r4:dc778600
    [   19.774689] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
    [   19.781241]  r7:c02ec660
    [   19.783795] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
    [   19.790785]  r10:c0350760 r9:01000000 r8:d48afce0 r7:00000000 r6:00000007 r5:00001406
    [   19.798696]  r4:c0940fb4
    [   19.801251] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
    [   19.809031] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
    [   19.816458] Exception stack(0xd48afce0 to 0xd48afd28)
    [   19.821535] fce0: 00000000 fc0037e0 00000000 c02ec648 dc93e0dc df3ef4b4 000001cd df3ef42c
    [   19.829749] fd00: df3ef440 01000000 c0350760 d48afd3c d48afd40 d48afd30 c02ec6e8 c02ec65c
    [   19.837961] fd20: a0010093 ffffffff
    [   19.841462]  r8:df3ef440 r7:d48afd14 r6:ffffffff r5:a0010093 r4:c02ec65c
    [   19.848244] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
    [   19.855587] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
    [   19.863186]  r9:db189a00 r8:60010013 r7:000001cd r6:dc8101e0 r5:dc810190 r4:dc810180
    [   19.871013] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
    [   19.878612]  r5:dc810180 r4:db1899c0
    [   19.882221] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
    [   19.889298]  r9:c0350a30 r8:00000000 r7:db189a00 r6:000001cd r5:dc810180 r4:00000000
    [   19.897128] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
    [   19.905164]  r7:a0010013 r6:df244674 r5:df244610 r4:db189a00
    [   19.910891] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
    [   19.919799]  r7:00010013 r6:df056088 r5:c09c1880 r4:c09c1880
    [   19.925523] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
    [   19.934257]  r5:c09c1880 r4:df056000
    [   19.937872] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
    [   19.946263] [<c036c3d0>] (uart_shutdown) from [<c036e294>] (uart_hangup+0x50/0x104)
    [   19.953950]  r7:df056064 r6:d4850c00 r5:df056090 r4:df056000
    [   19.959678] [<c036e244>] (uart_hangup) from [<c03505bc>] (__tty_hangup+0x3a4/0x3b4)
    [   19.967366]  r9:c0350a30 r8:00000000 r7:00000001 r6:d4850d5c r5:d4850c00 r4:00000000
    [   19.975197] [<c0350218>] (__tty_hangup) from [<c035197c>] (tty_ioctl+0xac0/0xe8c)
    [   19.982710]  r10:00000000 r9:d4850c00 r8:00000000 r7:80000000 r6:dc602cc0 r5:00005437
    [   19.990621]  r4:d4850c00
    [   19.993180] [<c0350ebc>] (tty_ioctl) from [<c013500c>] (do_vfs_ioctl+0x460/0x6dc)
    [   20.000692]  r9:d48ae000 r8:80000000 r7:00000003 r6:dc602cc0 r5:dc93a7d0 r4:80000000
    [   20.008519] [<c0134bac>] (do_vfs_ioctl) from [<c01352c4>] (SyS_ioctl+0x3c/0x64)
    [   20.015858]  r10:00000000 r9:d48ae000 r8:80000000 r7:00005437 r6:dc602cc0 r5:00000003
    [   20.023769]  r4:dc602cc0
    [   20.026326] [<c0135288>] (SyS_ioctl) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [   20.033927]  r9:d48ae000 r8:c000fe24 r7:00000036 r6:b6fdace0 r5:0065ce20 r4:0065a7b0
    [   20.041751] ---[ end trace 4307e6d07cae3717 ]---
    [END] 2018/12/17 17:28:18
  • Hi Terence,
    If you have only 512MB then you need to modify your load address to be less than 0xA0000000. An address you can use is 0x90000000. Don't use 0x84000000 as first 96MB is reserved for kernel.
    As a debug step, before you load kernel please make sure all the remote-core firmware is loaded by halting in SPL/MLO. You can do this by attaching a debugger and connecting all cores through CCS. Once this is confirmed please load kernel.
    Shravan
  • Hi Shravan,
    1.According to VisionSDK_UserGuide_MemoryMap, it said "DDR3_LINUX_MEM_OFFSET = 64*MB", so we use first 64M for kernel. We use this memory map more than one year, it is normal. We modify the load address to 0x86000000 now just for debugging early boot.
    2.For early boot/late attach, I think that the most important problem is IPU1 loading failure. Because, if no ipu1 in the boot partition, it's normal now. For visionSDK 03 05 from TI, Do you sure that it's support to load ipu1 itself? We need IPU1 in early boot, so,we really need your help.
    Terence
  • Hi Terence,
    1. For TDA2PX, we reserve 96MB for Linux kernel. This is because, we enable LPAE for TDA2PX since we have 4GB DDR on our EVMS. So we reserve 96MB for kernel data-structures and page-tables. Please refer to apps/build/tda2px/mem_segment_definition_linux.xs for this change.
    2. Yes, we do support Early-boot of IPU-1 in Vision-SDK. This has been tested as well. As indicated in previous posts, please halt at MLO without loading SPL and check if the IPU-1 firmware has been successfully loaded (you should be able to connect IPU-1 using JTAG and CCS).
    Shravan
  • Hi Shravan,
    I 'm sorry. I don't understand that how to halt at MLO without loading SPL, and how to check if the IPU-1 firmware has been successfully loaded? Is there any document for reference?
    Thanks a lot for your support.
    Terence
  • Hi Terence,
    Please add the below change to halt at SPL/MLO.
    diff --git a/common/spl/spl.c b/common/spl/spl.c
    index 7dbf434..5212244 100644
    --- a/common/spl/spl.c
    +++ b/common/spl/spl.c
    @@ -594,7 +594,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
    debug("Jumping to Linux\n");
    spl_fixup_fdt();
    spl_board_prepare_for_linux();
    + while(1)
    + mdelay(100);
    jump_to_image_linux((void *)CONFIG_SYS_SPL_ARGS_ADDR);
    #endif
    default:
    To check if IPU-1 is running, connect using CCS and a debugger. More instructions can be found in the CCS_Debug_Trace.pdf under docs/TrainingSlides folder in Vision-SDK.
    Shravan
  • Hi Shravan,
    Refer to CCS_Debug_Trace.pdf,I'm now installing Code Composer Studio v5.5, but there is a issue when I run ccs_setup_5.5.0.xxxxx.bin.
    Terence
    root@ubuntu:/home/xcj/share/CCS5.5.0.00066_linux# ./ccs_setup_5.5.0.00077.bin
    Please set DISPLAY. Code Composer Studio v5 cannot be installed in console mode.
  • Hi Shravan,
    For early boot/late attach, I don't understand the relationship between the address of DRA7_RPROC_CMA_BASE_IPU1 in "u-boot/u-boot/board/ti/dra7xx/lateattach.c" and IPU1_LOAD_ADDR in "/u-boot/u-boot/include/configs/ti_omap5_common.h". Do we need to set them the same?
    Thanks a lot
    Terence
  • Hi Terence,
    The IPU1_LOAD_ADDR is the address to which the compressed lzop firmware is loaded to DDR (from the boot media). From here the firmware is uncompressed to DRA7_RPROC_CMA_BASE_IPU1.
    Regarding the CCS issue, please refer the documents in Vision-SDK. There are also plenty of other E2E threads you may find helpful. If the issue still persists please raise another E2E ticket, an expert will be able to help you .
    Shravan
  • Hi Shravan,
    For early boot/late attach, the ipu1 may be load failure, the log said " failed to get resource section header".Below is the log, Could you help to have a look?
    Terence
    ===================================log=======================================
    U-Boot SPL 2016.05 (Jan 03 2019 - 12:11:23)
    DRA762-GP ES1.0
    no pinctrl for hs200_1_8v
    no pinctrl for ddr_1_8v
    ** First descriptor is NOT a primary desc on 1:1 **
    *** Warning - bad CRC, using default environment
    Trying to boot from MMC1
    reading dra7-ipu2-fw.lzop
    reading dra7-dsp1-fw.lzop
    reading dra7-dsp2-fw.lzop
    reading dra7-ipu1-fw.lzop
    find_resource_table: failed to get resource section header
    load_elf_image_phdr_rproc : failed to find resource table
    load_elf_image_phdr returned error for core IPU1
    Error loading remotecore IPU1!,Continuing with boot ...
    reading u-boot.img
    spl_load_image_fat: error reading image u-boot.img, err - -1
    Failed to mount ext2 filesystem...
    spl_load_image_ext: ext4fs mount err - 0
  • Hi Shravan,
    I had fixed the problem of " failed to get resource section header", but I don't understand why does it will read u-boot.img , and then failed to mount ext2 filesystem. Below is the new log. Could you help to have a look?
    Terence
    U-Boot SPL 2016.05 (Jan 03 2019 - 16:02:43)
    DRA762-GP ES1.0
    i2c_write: error waiting for data ACK (status=0x116)
    reading u-boot.img
  • Hi Terence,
    Are you building IPU-1 FW along with Vision-SDK Linux? The error couldn't find resource header implies, you've not built Vision-SDK with IPU1_0=yes. Where are you building the IPU-1 firwmare?
    If built with Vision-SDK Linux configuration (tda2px_evm_linux_all), then the resource headers are automatically added to the firmware. The absence of resource header indicates that the firmware wasn't built as part of Vision-SDK and/or for a Linux configuration.
    The resource header is necessary to setup the MMU for IPU, which is necessary for Linux builds.
    Shravan
  • Hi Shravan,
    Yes, We are building IPU-1 FW along with Vision-SDK Linux. Now, it could startup. According to your suggest,I changed the code to halt at SPL/MLO.Below is the log, it seems IPU1 is loaded successfully. But, when it jumps to kernel, it still scrash.For the log, why are the core entry point of ipu1 and ipu2 the same?
    Thanks a lot
    Terence
    U-Boot SPL 2016.05 (Jan 04 2019 - 13:40:52)
    DRA762-GP ES1.0
    Core 1 ELF Image is valid
    Loading ELF Image
    Core entry point is 0x00000011
    Starting the remote core
    loading remote core IPU2 successful
    Core 4 ELF Image is valid
    Loading ELF Image
    Core entry point is 0x9898e000
    loading remote core DSP1 successful
    Core 3 ELF Image is valid
    Loading ELF Image
    Core entry point is 0x9998e000
    loading remote core DSP2 successful
    Core 2 ELF Image is valid
    Loading ELF Image
    loading remote core IPU1 successful
    spl: mmc boot mode: fs
    spl: falcon_args_file not set in environment, falling back to default
    reading single-stage-boot.dtb
    reading uImage
    reading uImage
    ##################err=0
    Jumping to Linux
  • Hi  Shravan,
    The remote cores are all loaded successfully, But kernel panic still  remains. Please find the log in the attachment,could you help to have a look?
    Thanks a lot
    Terence
    [BEGIN] 2019/1/5 15:21:04
    U-Boot SPL 2016.05 (Jan 05 2019 - 14:33:57)
    DRA762-GP ES1.0
    Loading ELF Image
    Loading ELF Image
    Loading ELF Image
    Loading ELF Image
    reading uImage
    reading uImage
    Jumping to Linux
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.84 (xiachunjiang@ecarx-5288-V3) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Sat Jan 5 14:35:02 CST 2019
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA762 EVM
    [    0.000000] bootconsole [earlycon0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x40300000, size 3 MiB
    [    0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: regions without no-map are not yet supported
    [    0.000000] Reserved memory: created CMA memory pool at 0x96000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@96000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 16 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@98000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 16 MiB
    [    0.000000] Reserved memory: initialized node dsp2_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x9a000000, size 16 MiB
    [    0.000000] Reserved memory: initialized node ipu1_cma@9a000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x9db00000, size 32 MiB
    [    0.000000] Reserved memory: initialized node cmem@9db00000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 32 MiB at 0x9b800000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] OMAP4: Map 0x9fe00000 to fe600000 for dram barrier
    [    0.000000] On node 0 totalpages: 121088
    [    0.000000] free_area_init_node: node 0, pgdat c0987540, node_mem_map db380000
    [    0.000000]   Normal zone: 1152 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 121088 pages, LIFO batch:31
    [    0.000000] DRA762 ES1.0
    [    0.000000] PERCPU: Embedded 11 pages/cpu @dda43000 s14912 r8192 d21952 u45056
    [    0.000000] pcpu-alloc: s14912 r8192 d21952 u45056 alloc=11*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 119936
    0 cma=32M rootfstype=ext4 snd.slots_reserved=1,1 loglevel=8 clk_ignore_unused init=/home/root/init-demo.sh
    [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Memory: 172804K/484352K available (6675K kernel code, 318K rwdata, 2396K rodata, 340K init, 286K bss, 196860K reserved, 114688K cma-reserved, 0K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc08e400c   (9073 kB)
    [    0.000000]       .init : 0xc08e5000 - 0xc093a000   ( 340 kB)
    [    0.000000]       .data : 0xc093a000 - 0xc0989be0   ( 319 kB)
    [    0.000000]        .bss : 0xc098b000 - 0xc09d2980   ( 287 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] 	Build-time adjustment of leaf fanout to 32.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [    0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [    0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
    [    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [    0.008306] Switching to timer-based delay loop, resolution 162ns
    [    0.014983] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.025242] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.030996] Console: colour dummy device 80x30
    [    0.035652] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [    0.046285] pid_max: default: 32768 minimum: 301
    [    0.051192] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.058079] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.065930] Initializing cgroup subsys io
    [    0.070151] Initializing cgroup subsys memory
    [    0.074720] Initializing cgroup subsys devices
    [    0.079369] Initializing cgroup subsys freezer
    [    0.084027] Initializing cgroup subsys perf_event
    [    0.088940] Initializing cgroup subsys pids
    [    0.093338] CPU: Testing write buffer coherency: ok
    [    0.098631] /cpus/cpu@0 missing clock-frequency property
    [    0.104176] /cpus/cpu@1 missing clock-frequency property
    [    0.109729] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.115658] Setting up static identity map for 0x80008340 - 0x800083a0
    [    0.202783] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.202852] Brought up 2 CPUs
    [    0.211867] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [    0.218306] CPU: All CPU(s) started in HYP mode.
    [    0.223127] CPU: Virtualization extensions available.
    [    0.229438] devtmpfs: initialized
    [    0.263223] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.271944] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.290476] omap_hwmod: dcan1: _wait_target_disable failed
    [    0.382108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.392304] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.401075] pinctrl core: initialized pinctrl subsystem
    [    0.407370] NET: Registered protocol family 16
    [    0.413046] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.450264] cpuidle: using governor ladder
    [    0.480290] cpuidle: using governor menu
    [    0.491392] platform 43300000.edma: Cannot lookup hwmod 'tpcc'
    [    0.497749] platform 43400000.tptc: Cannot lookup hwmod 'tptc0'
    [    0.504210] platform 43500000.tptc: Cannot lookup hwmod 'tptc1'
    [    0.511465] OMAP GPIO hardware version 0.1
    [    0.519903] GPIO line 161 (radio_rst) hogged as output/low
    [    0.528145] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [    0.560636] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.568951] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.575512] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.583203] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.591362] OMAP DMA hardware revision 0.0
    [    0.636960] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.647266] edma3-tptc 43400000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [    0.656499] edma3-tptc 43500000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [    0.665943] edma 43300000.edma: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [    0.674600] edma 43300000.edma: pm_runtime_get_sync() failed
    [    0.685342] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.691432] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.697505] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.703577] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.709743] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.715834] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.724749] palmas 0-0058: IRQ missing: skipping irq request
    [    0.750991] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
    [    0.811528] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 !
    [    0.819033] pcf857x: probe of 0-0020 failed with error -121
    [    0.825101] pcf857x: probe of 0-0021 failed with error -121
    [    0.831119] pcf857x: probe of 0-0026 failed with error -121
    [    0.837090] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.843295] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.869214] pcf857x: probe of 3-0021 failed with error -121
    [    0.875045] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.881051] media: Linux media interface: v0.10
    [    0.885827] Linux video capture interface: v2.00
    [    0.890679] pps_core: LinuxPPS API ver. 1 registered
    [    0.895870] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.905345] PTP clock support registered
    [    0.909506] EDAC MC: Ver: 3.0.0
    [    0.913561] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.920193] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.926845] Advanced Linux Sound Architecture Driver Initialized.
    [    0.934103] clocksource: Switched to clocksource arch_sys_counter
    [    0.950904] NET: Registered protocol family 2
    [    0.955969] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.963321] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.970090] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.976741] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    0.982822] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    0.989478] NET: Registered protocol family 1
    [    0.994305] RPC: Registered named UNIX socket transport module.
    [    1.000465] RPC: Registered udp transport module.
    [    1.005397] RPC: Registered tcp transport module.
    [    1.010308] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.017029] PCI: CLS 0 bytes, default 64
    [    1.022226] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    1.039644] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.046416] NFS: Registering the id_resolver key type
    [    1.051700] Key type id_resolver registered
    [    1.056095] Key type id_legacy registered
    [    1.060342] ntfs: driver 2.1.32 [Flags: R/O].
    [    1.066333] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    1.074013] io scheduler noop registered (default)
    [    1.079057] io scheduler deadline registered
    [    1.083547] io scheduler cfq registered
    [    1.090015] vsys_5v0: supplied by vsys_12v0
    [    1.094470] ldo3: supplied by vsys_5v0
    [    1.102120] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    1.112845] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
    [    1.119050]   No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
    [    1.127048]    IO 0x20003000..0x20012fff -> 0x00000000
    [    1.132419]   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    1.171040] dra7-pcie 51000000.pcie_rc: link is not up
    [    1.176576] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
    [    1.183366] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.189100] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    1.195542] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    1.202706] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
    [    1.209002] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
    [    1.215547] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
    [    1.222125] pci 0000:00:00.0: supports D1
    [    1.226341] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    1.232543] PCI: bus0: Fast back to back transfers disabled
    [    1.238482] PCI: bus1: Fast back to back transfers enabled
    [    1.244286] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    1.251344] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    1.258418] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    1.263805] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [    1.271056] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
    [    1.278141] aer 0000:00:00.0:pcie02: service driver aer loaded
    [    1.345400] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    1.355003] omap8250 4806a000.serial: Can't verify DMA configuration (-19)
    [    1.362636] console [ttyS0] disabled
    [    1.366475] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.375676] console [ttyS0] enabled
    [    1.382835] bootconsole [earlycon0] disabled
    [    1.392059] omap8250 4806c000.serial: Can't verify DMA configuration (-19)
    [    1.399436] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.408698] omap8250 48020000.serial: Can't verify DMA configuration (-19)
    [    1.416079] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
    [    1.425740] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 304, base_baud = 3000000) is a 8250
    [    1.435800] [drm] Initialized drm 1.1.0 20060810
    [    1.441294] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.447981] [drm] No driver support for vblank timestamp query.
    [    1.454138] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.467147] loop: module loaded
    [    1.472937] vmemexp device MAJOR num = 245
    [    1.477085] vmemexp class registered
    [    1.480801] /dev/vmemexp device registered
    [    1.484931] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.493181] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.500860] libphy: Fixed MDIO Bus: probed
    [    1.554137] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [    1.560259] libphy: 48485000.mdio: probed
    [    1.567221] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver RTL9000A Gigabit Ethernet
    [    1.577482] cpsw 48484000.ethernet: Detected MACID = f8:36:9b:97:4f:e8
    [    1.584142] cpsw 48484000.ethernet: cpts: overflow check period 800
    [    1.591107] cpsw 48484000.ethernet: cpsw: Detected MACID = f8:36:9b:97:4f:e9
    [    1.599756] mousedev: PS/2 mouse device common for all mice
    [    1.606001] i2c /dev entries driver
    [    1.614787] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.619626] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.626112] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.632493] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.638890] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.645285] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.651917] vsys_3v3: supplied by vsys_12v0
    [    1.656186] vio_3v3: supplied by vsys_3v3
    [    1.660244] vio_3v3_sd: supplied by vio_3v3
    [    1.665132] ldo4: supplied by vsys_5v0
    [    1.714539] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.720924] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.744273] smps5: supplied by vsys_3v3
    [    1.748339] vio_1v8: supplied by smps5
    [    1.795047] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.806231] hwspinlock_user gatemp: requested 20 hwspinlocks
    [    1.813166] aic_dvdd: supplied by vio_3v3
    [    1.818459] davinci-mcasp 48464000.mcasp: DAI is shared
    [    1.823784] davinci-mcasp 48464000.mcasp: Can't verify DMA configuration (-19)
    [    1.831074] davinci-mcasp 48464000.mcasp: No DMA controller found (-19)
    [    1.838273] davinci-mcasp 48468000.mcasp: Can't verify DMA configuration (-19)
    [    1.845581] davinci-mcasp 48468000.mcasp: No DMA controller found (-19)
    [    1.852425] davinci-mcasp 48474000.mcasp: DAI is shared
    [    1.857775] davinci-mcasp 48474000.mcasp: Can't verify DMA configuration (-19)
    [    1.865064] davinci-mcasp 48474000.mcasp: No DMA controller found (-19)
    [    1.872837] NET: Registered protocol family 10
    [    1.888169] sit: IPv6 over IPv4 tunneling driver
    [    1.893346] NET: Registered protocol family 17
    [    1.898108] Key type dns_resolver registered
    [    1.902578] omap_voltage_late_init: Voltage driver support not added
    [    1.909481] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.915726] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.922009] buck10: supplied by vsys_3v3
    [    1.926589] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    1.932797] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    1.940928] Power Management for TI OMAP4+ devices.
    [    1.945985] Registering SWP/SWPB emulation handler
    [    1.951557] dmm 4e000000.dmm: workaround for errata i878 in use
    [    1.958588] dmm 4e000000.dmm: initialized all PAT entries
    [    1.964631] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    1.981581] hctosys: unable to open rtc device (rtc0)
    [    1.993575] aic_dvdd: disabling
    [    1.996779] clk: Not disabling unused clocks
    [    2.001065] ALSA device list:
    [    2.004038]   No soundcards found.
    [    2.007861] omap8250 4806a000.serial: failed to request DMA
    [    2.013563] Waiting for root device /dev/mmcblk0p2...
    [    2.029614] mmc0: host does not support reading read-only switch, assuming write-enable
    [    2.037701] mmc0: new SDHC card at address 0001
    [    2.042524] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
    [    2.048450]  mmcblk0: p1 p2
    [    2.087805] mmc1: MAN_BKOPS_EN bit is not set
    [    2.100658] mmc1: new HS200 MMC card at address 0001
    [    2.106618] mmcblk1: mmc1:0001 DG4008 7.28 GiB
    [    2.111301] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
    [    2.117502] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
    [    2.265618] EXT4-fs (mmcblk0p2): recovery complete
    [    2.270433] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.278597] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.292667] devtmpfs: mounted
    [    2.295806] Freeing unused kernel memory: 340K
    [    2.300263] This architecture does not have kernel memory protection.
    [    2.376633] Kernel Entry time 237429 ticks
    mount: unknown filesystem type 'dev'
    [    4.856813] systemd[1]: System time before build time, advancing clock.
    [    4.897371] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
    [    4.910794] random: systemd: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
    CCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    4.947354] systemd[1]: Detected architecture arm.
    Welcome to Arago 2016.12!
    [    4.975252] systemd[1]: Set hostname to <dra7xx-evm>.
    [    4.981589] random: systemd: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
    [    4.990912] systemd[1]: Initializing machine ID from random generator.
    [    5.084859] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    5.096809] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    5.108013] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    5.126730] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    5.142991] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [    5.293150] random: systemd: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
    [    5.302625] random: systemd: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
    [    5.487479] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    5.495324] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    5.503017] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [    5.510298] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    5.517968] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    5.527469] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [    5.567438] systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    [    5.584481] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    5.614254] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.634251] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    5.654387] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    5.704475] systemd[1]: Starting Setup Virtual Console...
    [    5.726640] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.756444] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.769969] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.787622] systemd[1]: Mounting Temporary Directory...
    [    5.814389] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.834472] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    5.864343] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.884536] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.914286] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    5.964317] systemd[1]: Mounting Debug File System...
    [    5.988852] systemd[1]: Starting Create list of required static device nodes for the current kernel...
             Starting Create list of required st... nodes for the current kernel...
    [    6.024667] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [    6.054915] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    6.074332] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    6.124470] systemd[1]: Starting Journal Service...
    [    6.144427] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    6.170693] systemd[1]: Starting Load Kernel Modules...
    [    6.195175] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.215017] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    6.234359] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    6.298838] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    6.324338] systemd[1]: Mounted Debug File System.
    [  OK  ] Mounted Debug File System.
    [    6.344311] systemd[1]: Mounted Temporary Directory.
    [  OK  ] Mounted Temporary Directory.
    [    6.364485] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
             Starting Load/Save Random Seed...
             Starting udev Coldplug all Devices...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    7.037031] systemd-journald[138]: Received request to flush runtime journal from PID 1
    [  OK  ] Started Flush Journal to Persistent Storage.
    [    7.084346] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [    7.091426] pgd = d5390000
    [    7.094140] [00000000] *pgd=00000000
    [    7.097736] Internal error: : 1406 [#1] PREEMPT SMP ARM
    [    7.102980] Modules linked in: sch_fq_codel
    [    7.107194] CPU: 0 PID: 1 Comm: systemd Not tainted 4.4.84 #1
    [    7.112960] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.119076] task: d5c78000 ti: d5c80000 task.ti: d5c80000
    [    7.124500] PC is at pcs_readl+0x14/0x18
    [    7.128435] LR is at pcs_irq_mask+0x78/0xa4
    [    7.132631] pc : [<c02ec65c>]    lr : [<c02ec6e8>]    psr: a0060093
    [    7.132631] sp : d5c81db8  ip : d5c81dc8  fp : d5c81dc4
    [    7.144155] r10: 00000000  r9 : 01000000  r8 : d5feb240
    [    7.149398] r7 : d5feb22c  r6 : 000001cd  r5 : d5feb2b4  r4 : d513e0dc
    [    7.155948] r3 : c02ec648  r2 : 00000000  r1 : fc0037e0  r0 : 00000000
    [    7.162500] Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.169749] Control: 10c5387d  Table: 9539006a  DAC: 00000051
    [    7.175516] Process systemd (pid: 1, stack limit = 0xd5c80210)
    [    7.181370] Stack: (0xd5c81db8 to 0xd5c82000)
    [    7.185742] 1da0:                                                       d5c81dec d5c81dc8
    [    7.193951] 1dc0: c02ec6e8 c02ec654 d5010180 d5010190 d50101e0 000001cd 60060013 d5364780
    [    7.202161] 1de0: d5c81e04 d5c81df0 c008926c c02ec67c d5364e00 d5010180 d5c81e2c d5c81e08
    [    7.210371] 1e00: c00866b0 c0089200 00000000 d5010180 000001cd d5364780 d5c56090 d4e23c00
    [    7.218582] 1e20: d5c81e4c d5c81e30 c008677c c0086444 d5364780 d5e48410 d5e48474 a0060013
    [    7.226792] 1e40: d5c81e6c d5c81e50 c03f6c70 c0086744 c09c1880 c09c1880 d5c56088 00060013
    [    7.235001] 1e60: d5c81e84 d5c81e70 c0377a98 c03f6c10 d5c56000 c09c1880 d5c81e94 d5c81e88
    [    7.243209] 1e80: c0371990 c03779b8 d5c81eb4 d5c81e98 c036c4a4 c0371980 d5c56000 d4d21400
    [    7.251421] 1ea0: d5c56064 c09c1880 d5c81edc d5c81eb8 c036d218 c036c3dc d4d21400 00000000
    [    7.259632] 1ec0: 00000000 d526f610 d580e660 d4e23c00 d5c81f24 d5c81ee0 c03520ec c036d1b8
    [    7.267842] 1ee0: 00000000 00000000 00000008 d5c81ef0 00000000 00000000 d4e23c00 d4e23c00
    [    7.276052] 1f00: d5cc7288 00000000 d526f610 d580e660 00000008 d4e23c08 d5c81f5c d5c81f28
    [    7.284266] 1f20: c012543c c0352000 00000000 00000000 d5c81f54 d5c78460 c098c7a8 00000000
    [    7.292476] 1f40: d5c78000 c000fe24 d5c80000 00000000 d5c81f6c d5c81f60 c01255e4 c01253c0
    [    7.300685] 1f60: d5c81f8c d5c81f70 c0053598 c01255e0 d5c80000 c000fe24 d5c81fb0 00000006
    [    7.308894] 1f80: d5c81fac d5c81f90 c00136f0 c005350c 00000022 b6fd5534 00000000 00000006
    [    7.317103] 1fa0: 00000000 d5c81fb0 c000fcb4 c0013640 00000000 becaa4ec 00000005 00000074
    [    7.325312] 1fc0: 00000022 b6fd5534 00000000 00000006 00000003 00000000 00000002 00000005
    [    7.333522] 1fe0: 00000000 becaa4ac 0051e0cc b6fb1d06 60060030 00000022 ffffffff ffffffff
    [    7.341729] Backtrace:
    [    7.344194] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
    [    7.351535] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
    [    7.359131]  r9:d5364780 r8:60060013 r7:000001cd r6:d50101e0 r5:d5010190 r4:d5010180
    [    7.366937] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
    [    7.374533]  r5:d5010180 r4:d5364e00
    [    7.378131] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
    [    7.385204]  r9:d4e23c00 r8:d5c56090 r7:d5364780 r6:000001cd r5:d5010180 r4:00000000
    [    7.393011] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
    [    7.401043]  r7:a0060013 r6:d5e48474 r5:d5e48410 r4:d5364780
    [    7.406752] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
    [    7.415657]  r7:00060013 r6:d5c56088 r5:c09c1880 r4:c09c1880
    [    7.421362] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
    [    7.430092]  r5:c09c1880 r4:d5c56000
    [    7.433693] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
    [    7.442078] [<c036c3d0>] (uart_shutdown) from [<c036d218>] (uart_close+0x6c/0x1c8)
    [    7.444118] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
    [    7.444121] pgd = c0004000
    [    7.444125] [00000000] *pgd=00000000
    [    7.463033]  r7:c09c1880 r6:d5c56064 r5:d4d21400 r4:d5c56000
    [    7.468743] [<c036d1ac>] (uart_close) from [<c03520ec>] (tty_release+0xf8/0x4d4)
    [    7.476165]  r9:d4e23c00 r8:d580e660 r7:d526f610 r6:00000000 r5:00000000 r4:d4d21400
    [    7.483972] [<c0351ff4>] (tty_release) from [<c012543c>] (__fput+0x88/0x1d0)
    [    7.491045]  r10:d4e23c08 r9:00000008 r8:d580e660 r7:d526f610 r6:00000000 r5:d5cc7288
    [    7.498935]  r4:d4e23c00
    [    7.501481] [<c01253b4>] (__fput) from [<c01255e4>] (____fput+0x10/0x14)
    [    7.508205]  r10:00000000 r9:d5c80000 r8:c000fe24 r7:d5c78000 r6:00000000 r5:c098c7a8
    [    7.516093]  r4:d5c78460
    [    7.518640] [<c01255d4>] (____fput) from [<c0053598>] (task_work_run+0x98/0xcc)
    [    7.525980] [<c0053500>] (task_work_run) from [<c00136f0>] (do_work_pending+0xbc/0xc0)
    [    7.533925]  r7:00000006 r6:d5c81fb0 r5:c000fe24 r4:d5c80000
    [    7.539630] [<c0013634>] (do_work_pending) from [<c000fcb4>] (slow_work_pending+0xc/0x20)
    [    7.547836]  r7:00000006 r6:00000000 r5:b6fd5534 r4:00000022
    [    7.553541] Code: e92dd800 e24cb004 e5900000 f57ff04f (e89da800)
    [    7.559658] ---[ end trace 6fcf00ca8233377a ]---
    [    7.559660] Internal error: : 1406 [#2] PREEMPT SMP ARM
    [    7.559668] Modules linked in: sch_fq_codel
    [    7.559673] CPU: 1 PID: 56 Comm: kworker/1:1 Tainted: G      D         4.4.84 #1
    [    7.559675] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.559683] Workqueue: events_freezable thermal_zone_device_check
    [    7.559686] task: d5260000 ti: d525c000 task.ti: d525c000
    [    7.559692] PC is at ti_bandgap_force_single_read+0x4c/0x188
    [    7.559696] LR is at ti_bandgap_read_temperature+0xb8/0xf8
    [    7.559700] pc : [<c04d1ff4>]    lr : [<c04d379c>]    psr: 400f0013
    [    7.559700] sp : d525ddf8  ip : d525de20  fp : d525de1c
    [    7.559702] r10: dda509c0  r9 : 00000000  r8 : 00000000
    [    7.559704] r7 : 00000000  r6 : 00000000  r5 : d5236b10  r4 : 00000000
    [    7.559707] r3 : 0000014c  r2 : fc00232c  r1 : c0977ab8  r0 : d5236b10
    [    7.559710] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.559713] Control: 10c5387d  Table: 94dc806a  DAC: 00000051
    [    7.559715] Process kworker/1:1 (pid: 56, stack limit = 0xd525c210)
    [    7.559718] Stack: (0xd525ddf8 to 0xd525e000)
    [    7.559721] dde0:                                                       d5236b10 00000000
    [    7.559726] de00: d525de40 d524a010 d5236b10 00000000 d525de3c d525de20 c04d379c c04d1fb4
    [    7.559730] de20: 00000000 d525deb4 c06f7450 d524a010 d525de6c d525de40 c04d3b6c c04d36f0
    [    7.559735] de40: dda50e80 c0937e40 d5f12c00 d5f12c00 d5f12e0c d525deb4 dda54300 00000000
    [    7.559740] de60: d525de7c d525de70 c04cef6c c04d3b3c d525deac d525de80 c04cb5fc c04cef50
    [    7.559744] de80: 7fffffff dda50e40 d5260000 d5f12e2c d5f12c00 dda509c0 00000000 dda54300
    [    7.559749] dea0: d525decc d525deb0 c04ccde0 c04cb5ac d525dedc d525dec0 d5f12e2c d5cc0280
    [    7.559753] dec0: d525dedc d525ded0 c04ccecc c04ccdd0 d525df1c d525dee0 c004f330 c04ccea0
    [    7.559757] dee0: dda509c0 dda509d4 d525c000 00000008 d5cc0280 dda509c0 d5cc0298 dda509d4
    [    7.559762] df00: d525c000 00000008 d5cc0280 dda509c0 d525df54 d525df20 c004f64c c004f218
    [    7.559766] df20: d5cc0280 c093c100 00000000 00000000 d5cbe340 d525c000 d5cc0280 c004f600
    [    7.559770] df40: 00000000 00000000 d525dfac d525df58 c0055184 c004f60c 00000000 00000000
    [    7.559775] df60: 00000000 d5cc0280 00000000 00000000 d525df70 d525df70 00000000 00000000
    [    7.559779] df80: d525df80 d525df80 d525dfac d5cbe340 c0055084 00000000 00000000 00000000
    [    7.559783] dfa0: 00000000 d525dfb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [    7.559788] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.559792] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [    7.559795] Backtrace:
    [    7.559801] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [    7.559811]  r9:00000000 r8:d5236b10 r7:d524a010 r6:d525de40 r5:00000000 r4:d5236b10
    [    7.559816] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [    7.559823]  r7:d524a010 r6:c06f7450 r5:d525deb4 r4:00000000
    [    7.559829] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [    7.559837]  r9:00000000 r8:dda54300 r7:d525deb4 r6:d5f12e0c r5:d5f12c00 r4:d5f12c00
    [    7.559844] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [    7.559849] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [    7.559857]  r8:dda54300 r7:00000000 r6:dda509c0 r5:d5f12c00 r4:d5f12e2c
    [    7.559862] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [    7.559866]  r5:d5cc0280 r4:d5f12e2c
    [    7.559871] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [    7.559874] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [    7.559883]  r10:dda509c0 r9:d5cc0280 r8:00000008 r7:d525c000 r6:dda509d4 r5:d5cc0298
    [    7.559886]  r4:dda509c0
    [    7.559891] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [    7.559900]  r10:00000000 r9:00000000 r8:c004f600 r7:d5cc0280 r6:d525c000 r5:d5cbe340
    [    7.559903]  r4:00000000
    [    7.559908] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [    7.559917]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:d5cbe340
    [    7.559922] Code: e5913000 e0822003 e5928000 f57ff04f (e5913008)
    [    7.559926] ---[ end trace 6fcf00ca8233377b ]---
    [    7.567634] Unable to handle kernel paging request at virtual address ffffffec
    [    7.567637] pgd = c0004000
    [    7.567644] [ffffffec] *pgd=9dac6861, *pte=00000000, *ppte=00000000
    [    7.567647] Internal error: Oops: 37 [#3] PREEMPT SMP ARM
    [    7.567651] Modules linked in: sch_fq_codel
    [    7.567656] CPU: 1 PID: 56 Comm: kworker/1:1 Tainted: G      D         4.4.84 #1
    [    7.567658] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.567667] task: d5260000 ti: d525c000 task.ti: d525c000
    [    7.567672] PC is at kthread_data+0x10/0x18
    [    7.567674] LR is at wq_worker_sleeping+0x14/0xd8
    [    7.567678] pc : [<c00555d4>]    lr : [<c00503fc>]    psr: 20070093
    [    7.567678] sp : d525dba0  ip : d525dbb0  fp : d525dbac
    [    7.567680] r10: 00000001  r9 : dda50e40  r8 : d52603a8
    [    7.567682] r7 : c093c6d4  r6 : c0937e40  r5 : d5260000  r4 : 00000001
    [    7.567685] r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : d5260000
    [    7.567688] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
    [    7.567691] Control: 10c5387d  Table: 94dc806a  DAC: 00000051
    [    7.567693] Process kworker/1:1 (pid: 56, stack limit = 0xd525c210)
    [    7.567696] Stack: (0xd525dba0 to 0xd525e000)
    [    7.567700] dba0: d525dbc4 d525dbb0 c00503fc c00555d0 dda50e40 d5260000 d525dc1c d525dbc8
    [    7.567706] dbc0: c0687680 c00503f4 c098be14 d5fcbd40 d525dbec d525dbe0 c00918f8 c009167c
    [    7.567710] dbe0: d525dc34 c06878b8 00000000 c00918ec c003a300 d525c000 d525d904 d5c78000
    [    7.567716] dc00: d525dc40 d5260320 c04d1ff6 c081ef94 d525dc34 d525dc20 c06878b8 c0687204
    [    7.567720] dc20: d5260000 d525d904 d525dc5c d525dc38 c003c258 c0687870 00000001 00000000
    [    7.567725] dc40: d525dc40 d525dc40 c00393a8 c04d1ff8 d525dce4 d525dc60 c0013f68 c003bc24
    [    7.567729] dc60: d525c210 0000000b c081ef9c 00000008 00000000 d525c000 00000000 600f0193
    [    7.567734] dc80: 6525dca4 33313935 20303030 32383065 33303032 39356520 30303832 35662030
    [    7.567738] dca0: 30666637 28206634 31393565 38303033 c0002029 c0004000 d525dcf4 c0940fb4
    [    7.567743] dcc0: 00001406 00000007 00000000 d525dda8 00000000 dda509c0 d525dcf4 d525dce8
    [    7.567747] dce0: c0014198 c0013d28 d525dda4 d525dcf8 c0009370 c0014184 00000000 d525dd08
    [    7.567752] dd00: 00000007 00000000 00030003 00000000 00002808 00000000 00002808 00000000
    [    7.567756] dd20: d525dd54 d525dd30 c0067188 c007c7a4 dda50e80 d5260048 dda50e80 d5260048
    [    7.567761] dd40: 00000001 00000000 d525ddd4 d525dd58 c0068f0c c0067210 99bf4724 00000001
    [    7.567766] dd60: 01dcd48b c06878b8 99bfb6fa 00000001 00000025 d525c000 d525de7c d525de78
    [    7.567770] dd80: 00000800 c04d1ff4 400f0013 ffffffff d525dddc 00000000 d525de1c d525dda8
    [    7.567774] dda0: c00147e0 c00092c0 d5236b10 c0977ab8 fc00232c 0000014c 00000000 d5236b10
    [    7.567780] ddc0: 00000000 00000000 00000000 00000000 dda509c0 d525de1c d525de20 d525ddf8
    [    7.567784] dde0: c04d379c c04d1ff4 400f0013 ffffffff 00000051 d525de00 d5236b10 00000000
    [    7.567789] de00: d525de40 d524a010 d5236b10 00000000 d525de3c d525de20 c04d379c c04d1fb4
    [    7.567793] de20: 00000000 d525deb4 c06f7450 d524a010 d525de6c d525de40 c04d3b6c c04d36f0
    [    7.567798] de40: dda50e80 c0937e40 d5f12c00 d5f12c00 d5f12e0c d525deb4 dda54300 00000000
    [    7.567802] de60: d525de7c d525de70 c04cef6c c04d3b3c d525deac d525de80 c04cb5fc c04cef50
    [    7.567806] de80: 7fffffff dda50e40 d5260000 d5f12e2c d5f12c00 dda509c0 00000000 dda54300
    [    7.567811] dea0: d525decc d525deb0 c04ccde0 c04cb5ac d525dedc d525dec0 d5f12e2c d5cc0280
    [    7.567815] dec0: d525dedc d525ded0 c04ccecc c04ccdd0 d525df1c d525dee0 c004f330 c04ccea0
    [    7.567820] dee0: dda509c0 dda509d4 d525c000 00000008 d5cc0280 dda509c0 d5cc0298 dda509d4
    [    7.567824] df00: d525c000 00000008 d5cc0280 dda509c0 d525df54 d525df20 c004f64c c004f218
    [    7.567828] df20: d5cc0280 c093c100 00000000 00000000 d5cbe340 d525c000 d5cc0280 c004f600
    [    7.567833] df40: 00000000 00000000 d525dfac d525df58 c0055184 c004f60c 00000000 00000000
    [    7.567837] df60: 00000000 d5cc0280 00000000 00000000 d525df70 d525df70 00000001 00010001
    [    7.567841] df80: d525df80 d525df80 d525dfac d5cbe340 c0055084 00000000 00000000 00000000
    [    7.567846] dfa0: 00000000 d525dfb0 c000fd18 c0055090 00000000 00000000 00000000 00000000
    [    7.567849] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.567854] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
    [    7.567857] Backtrace:
    [    7.567862] [<c00555c4>] (kthread_data) from [<c00503fc>] (wq_worker_sleeping+0x14/0xd8)
    [    7.567871] [<c00503e8>] (wq_worker_sleeping) from [<c0687680>] (__schedule+0x488/0x66c)
    [    7.567875]  r5:d5260000 r4:dda50e40
    [    7.567881] [<c06871f8>] (__schedule) from [<c06878b8>] (schedule+0x54/0xc4)
    [    7.567890]  r10:c081ef94 r9:c04d1ff6 r8:d5260320 r7:d525dc40 r6:d5c78000 r5:d525d904
    [    7.567892]  r4:d525c000
    [    7.567899] [<c0687864>] (schedule) from [<c003c258>] (do_exit+0x640/0x9b8)
    [    7.567903]  r5:d525d904 r4:d5260000
    [    7.567907] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
    [    7.567910]  r7:c04d1ff8
    [    7.567914] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
    [    7.567923]  r10:dda509c0 r9:00000000 r8:d525dda8 r7:00000000 r6:00000007 r5:00001406
    [    7.567925]  r4:c0940fb4
    [    7.567930] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
    [    7.567934] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
    [    7.567936] Exception stack(0xd525dda8 to 0xd525ddf0)
    [    7.567940] dda0:                   d5236b10 c0977ab8 fc00232c 0000014c 00000000 d5236b10
    [    7.567944] ddc0: 00000000 00000000 00000000 00000000 dda509c0 d525de1c d525de20 d525ddf8
    [    7.567947] dde0: c04d379c c04d1ff4 400f0013 ffffffff
    [    7.567956]  r8:00000000 r7:d525dddc r6:ffffffff r5:400f0013 r4:c04d1ff4
    [    7.567962] [<c04d1fa8>] (ti_bandgap_force_single_read) from [<c04d379c>] (ti_bandgap_read_temperature+0xb8/0xf8)
    [    7.567970]  r9:00000000 r8:d5236b10 r7:d524a010 r6:d525de40 r5:00000000 r4:d5236b10
    [    7.567976] [<c04d36e4>] (ti_bandgap_read_temperature) from [<c04d3b6c>] (__ti_thermal_get_temp+0x3c/0xd4)
    [    7.567983]  r7:d524a010 r6:c06f7450 r5:d525deb4 r4:00000000
    [    7.567988] [<c04d3b30>] (__ti_thermal_get_temp) from [<c04cef6c>] (of_thermal_get_temp+0x28/0x34)
    [    7.567996]  r9:00000000 r8:dda54300 r7:d525deb4 r6:d5f12e0c r5:d5f12c00 r4:d5f12c00
    [    7.568001] [<c04cef44>] (of_thermal_get_temp) from [<c04cb5fc>] (thermal_zone_get_temp+0x5c/0x118)
    [    7.568007] [<c04cb5a0>] (thermal_zone_get_temp) from [<c04ccde0>] (thermal_zone_device_update.part.4+0x1c/0x98)
    [    7.568016]  r8:dda54300 r7:00000000 r6:dda509c0 r5:d5f12c00 r4:d5f12e2c
    [    7.568020] [<c04ccdc4>] (thermal_zone_device_update.part.4) from [<c04ccecc>] (thermal_zone_device_check+0x38/0x3c)
    [    7.568024]  r5:d5cc0280 r4:d5f12e2c
    [    7.568028] [<c04cce94>] (thermal_zone_device_check) from [<c004f330>] (process_one_work+0x124/0x3f4)
    [    7.568032] [<c004f20c>] (process_one_work) from [<c004f64c>] (worker_thread+0x4c/0x524)
    [    7.568042]  r10:dda509c0 r9:d5cc0280 r8:00000008 r7:d525c000 r6:dda509d4 r5:d5cc0298
    [    7.568044]  r4:dda509c0
    [    7.568049] [<c004f600>] (worker_thread) from [<c0055184>] (kthread+0x100/0x118)
    [    7.568058]  r10:00000000 r9:00000000 r8:c004f600 r7:d5cc0280 r6:d525c000 r5:d5cbe340
    [    7.568060]  r4:00000000
    [    7.568066] [<c0055084>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [    7.568073]  r8:00000000 r7:00000000 r6:00000000 r5:c0055084 r4:d5cbe340
    [    7.568078] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
    [    7.568081] ---[ end trace 6fcf00ca8233377c ]---
    [    7.568083] Fixing recursive fault but reboot is needed!
    [    8.651248] note: systemd[1] exited with preempt_count 2
    [    8.656611] ------------[ cut here ]------------
    [    8.661249] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
    [    8.670592] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
    [    8.682373] Modules linked in: sch_fq_codel
    [    8.686585] CPU: 0 PID: 1 Comm: systemd Tainted: G      D         4.4.84 #1
    [    8.693571] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    8.699684] Backtrace:
    [    8.702146] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [    8.709742]  r7:c02e3bb0 r6:20060193 r5:00000000 r4:c0959350
    [    8.715451] [<c0013d00>] (show_stack) from [<c02b7428>] (dump_stack+0x8c/0xa0)
    [    8.722702] [<c02b739c>] (dump_stack) from [<c003929c>] (warn_slowpath_common+0x88/0xb8)
    [    8.730821]  r7:c02e3bb0 r6:00000093 r5:00000009 r4:d5c818a0
    [    8.736526] [<c0039214>] (warn_slowpath_common) from [<c0039304>] (warn_slowpath_fmt+0x38/0x40)
    [    8.745255]  r8:00000017 r7:c084c280 r6:00000000 r5:c084c340 r4:c084c3e4
    [    8.752014] [<c00392d0>] (warn_slowpath_fmt) from [<c02e3bb0>] (l3_interrupt_handler+0x25c/0x368)
    [    8.760918]  r3:d5e0e940 r2:c084c3e4
    [    8.764513]  r4:80080003
    [    8.767063] [<c02e3954>] (l3_interrupt_handler) from [<c0085ac8>] (handle_irq_event_percpu+0xb4/0x160)
    [    8.776404]  r10:c0988e4b r9:d5e0c240 r8:00000017 r7:00000000 r6:00000000 r5:d5e0c2a0
    [    8.784292]  r4:d5e0ee40
    [    8.786842] [<c0085a14>] (handle_irq_event_percpu) from [<c0085bb4>] (handle_irq_event+0x40/0x64)
    [    8.795747]  r10:c081ef94 r9:c02ec65e r8:d5c08000 r7:00000000 r6:c0941c8c r5:d5e0c2a0
    [    8.803634]  r4:d5e0c240
    [    8.806181] [<c0085b74>] (handle_irq_event) from [<c0088ef8>] (handle_fasteoi_irq+0xc0/0x194)
    [    8.814736]  r7:00000000 r6:c0941c8c r5:d5e0c2a0 r4:d5e0c240
    [    8.820442] [<c0088e38>] (handle_fasteoi_irq) from [<c00850f4>] (generic_handle_irq+0x2c/0x3c)
    [    8.829084]  r7:00000000 r6:d5c81b78 r5:00000017 r4:c093640c
    [    8.834791] [<c00850c8>] (generic_handle_irq) from [<c00853cc>] (__handle_domain_irq+0x64/0xbc)
    [    8.843524] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [    8.851905]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d5c81a60 r5:fa21200c r4:c093c8e4
    [    8.859708] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [    8.867218] Exception stack(0xd5c81a60 to 0xd5c81aa8)
    [    8.872288] 1a60: 00000000 c098c2c0 00000000 00000000 00000282 00000012 d5c80000 00000000
    [    8.880497] 1a80: d5c08000 c02ec65e c081ef94 d5c81b0c d5c81b10 d5c81ab0 c003d464 c003cfd0
    [    8.888704] 1aa0: 60060113 ffffffff
    [    8.892200]  r9:c02ec65e r8:d5c08000 r7:d5c81a94 r6:ffffffff r5:60060113 r4:c003cfd0
    [    8.900007] [<c003cf3c>] (__do_softirq) from [<c003d464>] (irq_exit+0xbc/0x11c)
    [    8.907341]  r10:c081ef94 r9:c02ec65e r8:d5c08000 r7:00000000 r6:00000000 r5:00000012
    [    8.915230]  r4:ffffe000
    [    8.917778] [<c003d3a8>] (irq_exit) from [<c00853d0>] (__handle_domain_irq+0x68/0xbc)
    [    8.925634]  r5:00000012 r4:c093640c
    [    8.929234] [<c0085368>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
    [    8.937615]  r9:c02ec65e r8:fa213000 r7:fa212000 r6:d5c81b78 r5:fa21200c r4:c093c8e4
    [    8.945420] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
    [    8.952929] Exception stack(0xd5c81b78 to 0xd5c81bc0)
    [    8.957997] 1b60:                                                       d5c84504 00000023
    [    8.966207] 1b80: 00000023 0000013d d5c82000 0000000b 0000123c c02ec660 00000001 c02ec65e
    [    8.974416] 1ba0: c081ef94 d5c81bd4 d5c81bd8 d5c81bc8 c00b36a0 c068b5d8 40060113 ffffffff
    [    8.982622]  r9:c02ec65e r8:00000001 r7:d5c81bac r6:ffffffff r5:40060113 r4:c068b5d8
    [    8.990431] [<c068b5b0>] (_raw_spin_unlock_irq) from [<c00b36a0>] (acct_collect+0x198/0x1b8)
    [    8.998903] [<c00b3508>] (acct_collect) from [<c003c2b8>] (do_exit+0x6a0/0x9b8)
    [    9.006237]  r7:c02ec660 r6:00000001 r5:0000000b r4:d5c78000
    [    9.011943] [<c003bc18>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
    [    9.018492]  r7:c02ec660
    [    9.021038] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
    [    9.028024]  r10:00000000 r9:01000000 r8:d5c81d68 r7:00000000 r6:00000007 r5:00001406
    [    9.035912]  r4:c0940fb4
    [    9.038457] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
    [    9.046230] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
    [    9.053651] Exception stack(0xd5c81d68 to 0xd5c81db0)
    [    9.058721] 1d60:                   00000000 fc0037e0 00000000 c02ec648 d513e0dc d5feb2b4
    [    9.066930] 1d80: 000001cd d5feb22c d5feb240 01000000 00000000 d5c81dc4 d5c81dc8 d5c81db8
    [    9.075137] 1da0: c02ec6e8 c02ec65c a0060093 ffffffff
    [    9.080204]  r8:d5feb240 r7:d5c81d9c r6:ffffffff r5:a0060093 r4:c02ec65c
    [    9.086962] [<c02ec648>] (pcs_readl) from [<c02ec6e8>] (pcs_irq_mask+0x78/0xa4)
    [    9.094300] [<c02ec670>] (pcs_irq_mask) from [<c008926c>] (irq_shutdown+0x78/0x7c)
    [    9.101896]  r9:d5364780 r8:60060013 r7:000001cd r6:d50101e0 r5:d5010190 r4:d5010180
    [    9.109700] [<c00891f4>] (irq_shutdown) from [<c00866b0>] (__free_irq+0x278/0x2b0)
    [    9.117295]  r5:d5010180 r4:d5364e00
    [    9.120894] [<c0086438>] (__free_irq) from [<c008677c>] (free_irq+0x44/0x78)
    [    9.127965]  r9:d4e23c00 r8:d5c56090 r7:d5364780 r6:000001cd r5:d5010180 r4:00000000
    [    9.135770] [<c0086738>] (free_irq) from [<c03f6c70>] (dev_pm_clear_wake_irq+0x6c/0x7c)
    [    9.143802]  r7:a0060013 r6:d5e48474 r5:d5e48410 r4:d5364780
    [    9.149508] [<c03f6c04>] (dev_pm_clear_wake_irq) from [<c0377a98>] (omap_8250_shutdown+0xec/0xf0)
    [    9.158412]  r7:00060013 r6:d5c56088 r5:c09c1880 r4:c09c1880
    [    9.164117] [<c03779ac>] (omap_8250_shutdown) from [<c0371990>] (serial8250_shutdown+0x1c/0x28)
    [    9.172847]  r5:c09c1880 r4:d5c56000
    [    9.176447] [<c0371974>] (serial8250_shutdown) from [<c036c4a4>] (uart_shutdown+0xd4/0x11c)
    [    9.184832] [<c036c3d0>] (uart_shutdown) from [<c036d218>] (uart_close+0x6c/0x1c8)
    [    9.192429]  r7:c09c1880 r6:d5c56064 r5:d4d21400 r4:d5c56000
    [    9.198135] [<c036d1ac>] (uart_close) from [<c03520ec>] (tty_release+0xf8/0x4d4)
    [    9.205556]  r9:d4e23c00 r8:d580e660 r7:d526f610 r6:00000000 r5:00000000 r4:d4d21400
    [    9.213361] [<c0351ff4>] (tty_release) from [<c012543c>] (__fput+0x88/0x1d0)
    [    9.220433]  r10:d4e23c08 r9:00000008 r8:d580e660 r7:d526f610 r6:00000000 r5:d5cc7288
    [    9.228322]  r4:d4e23c00
    [    9.230869] [<c01253b4>] (__fput) from [<c01255e4>] (____fput+0x10/0x14)
    [    9.237593]  r10:00000000 r9:d5c80000 r8:c000fe24 r7:d5c78000 r6:00000000 r5:c098c7a8
    [    9.245480]  r4:d5c78460
    [    9.248027] [<c01255d4>] (____fput) from [<c0053598>] (task_work_run+0x98/0xcc)
    [    9.255366] [<c0053500>] (task_work_run) from [<c00136f0>] (do_work_pending+0xbc/0xc0)
    [    9.263311]  r7:00000006 r6:d5c81fb0 r5:c000fe24 r4:d5c80000
    [    9.269015] [<c0013634>] (do_work_pending) from [<c000fcb4>] (slow_work_pending+0xc/0x20)
    [    9.277222]  r7:00000006 r6:00000000 r5:b6fd5534 r4:00000022
    [    9.282925] ---[ end trace 6fcf00ca8233377d ]---
    [END] 2019/1/5 15:21:32
  • Hi Shravan
    I had found the cause of kernel panic. Due to the additional serial port settings in our application code. Now, after early boot, and late attach is normal.
    Thanks a lot
    Terence
