Part Number: TDA3
Hi,I have some questions about programing in tda3x
1.How should I use EDMA in tda3x,do you give some examples of the usage of edma for tda3x?
2.When I use C66x_DSPLIB in tda3x,I find out that the running cycle is different from the number given in the Cycle Benchmarks of <<Texas Instruments Test Results DSPLIB 3.4.0.0 C66x>>.
The time recorded for length of 128 DSPF_sp_fftSPxSP is 816,while in my case, the clock number is almost four times of that.All the data is in L2_SRAM. Can we use C66x_DSPLIB in tda3x and if we can,how should we make it the same clock as is described in the <<Texas Instruments Test Results DSPLIB 3.4.0.0 C66x>>.
Thank you!
