Linux: BT service crash
Tool/software: Linux
Hi ,
 I am trying to bring up the BT USB device on the board and it crashes with the below error :
Android O  linux platform
01-01 01:16:47.976 19851 19885 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0xa63b1ee0 (remote)
01-01 01:16:47.976  2894  2944 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_init
01-01 01:16:47.977  2894  2944 I bt_vendor: Using interface hci0
01-01 01:16:47.977  2894  2944 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 0
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 0 retval 0
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 3
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_open
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_open returning 6
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 3 retval 1
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 1
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_fw_cfg
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_wait_hcidev
01-01 01:16:47.977  2894  2944 I bt_vendor: HCI device ready
01-01 01:16:47.977  2894  2944 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
01-01 01:16:47.977  2894  2944 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.000s
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 5
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 5 retval 0
01-01 01:16:47.977  2894  2944 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 6
01-01 01:16:47.977  2894  2944 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
01-01 01:16:47.977  2894  2944 I bt_vendor: bt_vendor_op op 6 retval 0
01-01 01:16:47.977  2894  2944 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
01-01 01:16:47.978  2894  2944 I bt_vendor: bt_vendor_op op 1 retval 0
01-01 01:16:47.978 19851 19885 I bt_hci  : event_finish_startup
01-01 01:16:47.978 19851 19871 I bt_core_module: module_start_up Started module "hci_module"
01-01 01:16:47.980 19851 19888 I bt_osi_thread: run_thread: thread id 19888, thread name bt_workqueue started
01-01 01:16:47.980 19851 19888 I bt_btu  : btu_task pending for preload complete event
01-01 01:16:47.980 19851 19888 I bt_btu_task: Bluetooth chip preload is complete
01-01 01:16:47.980 19851 19888 I bt_btu  : btu_task received preload complete event
01-01 01:16:47.981 19851 19888 E bt_att  : gatt_profile_db_init:  gatt_if=1
01-01 01:16:47.981 19851 19889 I bt_osi_thread: run_thread: thread id 19889, thread name module_wrapper started
01-01 01:16:47.981 19851 19889 I bt_core_module: module_start_up Starting module "controller_module"
01-01 01:16:47.982  2894  2944 I bt_vendor: bt_vendor_op op 7
01-01 01:16:47.982  2894  2944 I bt_vendor: bt_vendor_op op 7 retval 0
01-01 01:16:47.982  2894  2944 E android.hardware.bluetooth-hci-hci_protocol: WriteSafely error writing to UART (Invalid argument)
01-01 01:16:49.983 19851 19874 E bt_hci  : command_timed_out: 1 commands pending response
01-01 01:16:49.983 19851 19874 E bt_hci  : command_timed_out: Waited 2001 ms for a response to opcode: 0xc03 *matches timer*
01-01 01:16:49.983 19851 19874 E bt_hci  : command_timed_out: Size 3 Hex 03 0c 00
01-01 01:16:49.983 19851 19874 E bt_hci  : command_timed_out: requesting a firmware dump.
01-01 01:16:49.983  2894  2944 E android.hardware.bluetooth-hci-hci_protocol: WriteSafely error writing to UART (Invalid argument)
01-01 01:16:49.983 19851 19874 E bt_hci  : command_timed_out restarting the Bluetooth process.
01-01 01:16:50.484 19851 19874 F libc    : Fatal signal 6 (SIGABRT), code -6 in tid 19874 (alarm_default_c)
01-01 01:16:50.542 19893 19893 I crash_dump32: obtaining output fd from tombstoned
01-01 01:16:50.543   274   274 I /system/bin/tombstoned: received crash request for pid 19851
01-01 01:16:50.543 19893 19893 I crash_dump32: performing dump of process 19851 (target tid = 19874)
01-01 01:16:50.544 19893 19893 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-01 01:16:50.544 19893 19893 F DEBUG   : Build fingerprint: 'TI/full_jacinto6evm/jacinto6evm:8.0.0/OPR6.170623.013/dilpre04261833:userdebug/test-keys'
01-01 01:16:50.544 19893 19893 F DEBUG   : Revision: '0'
01-01 01:16:50.544 19893 19893 F DEBUG   : ABI: 'arm'
01-01 01:16:50.544 19893 19893 F DEBUG   : pid: 19851, tid: 19874, name: alarm_default_c  >>> com.android.bluetooth <<<
01-01 01:16:50.544 19893 19893 F DEBUG   : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
01-01 01:16:50.544 19893 19893 F DEBUG   :     r0 00000000  r1 00004da2  r2 00000006  r3 00000008
01-01 01:16:50.544 19893 19893 F DEBUG   :     r4 00004d8b  r5 00004da2  r6 95929018  r7 0000010c
01-01 01:16:50.544 19893 19893 F DEBUG   :     r8 a6692668  r9 95f941d0  sl a6692668  fp 00000c03
01-01 01:16:50.544 19893 19893 F DEBUG   :     ip 00000000  sp 95929008  lr affa13c7  pc affd1a9c  cpsr 200f0010
01-01 01:16:50.609 19893 19893 F DEBUG   :
01-01 01:16:50.609 19893 19893 F DEBUG   : backtrace:
01-01 01:16:50.609 19893 19893 F DEBUG   :     #00 pc 0004aa9c  /system/lib/libc.so (tgkill+12)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #01 pc 0001a3c3  /system/lib/libc.so (abort+54)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #02 pc 000a1157  /system/lib/hw/bluetooth.default.so (_ZL17command_timed_outPv+398)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #03 pc 00128867  /system/lib/hw/bluetooth.default.so (_ZL17alarm_queue_readyP13fixed_queue_tPv+134)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #04 pc 0012b423  /system/lib/hw/bluetooth.default.so (_ZL22internal_dequeue_readyPv+46)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #05 pc 0012d9b9  /system/lib/hw/bluetooth.default.so (_ZL11run_reactorP9reactor_ti+216)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #06 pc 0012d8b5  /system/lib/hw/bluetooth.default.so (_Z13reactor_startP9reactor_t+44)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #07 pc 0012ebb1  /system/lib/hw/bluetooth.default.so (_ZL10run_threadPv+136)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #08 pc 00047dbf  /system/lib/libc.so (_ZL15__pthread_startPv+22)
01-01 01:16:50.609 19893 19893 F DEBUG   :     #09 pc 0001af7f  /system/lib/libc.so (__start_thread+32)
01-01 01:16:51.726   274   274 E /system/bin/tombstoned: Tombstone written to: /data/tombstones//tombstone_08[ 4611.735180] init: Untracked pid 19893 exited with status 0
01-01 01:16:51.731   337   357 I BootReceiver: Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
01-01 01:16:51.811  2894  2944 E android.hardware.bluetooth@1.0-impl: BluetoothDeathRecipient::serviceDied - Bluetooth service died
01-01 01:16:51.811  2894  2944 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
01-01 01:16:51.811  2894  2944 I android.hardware.bluetooth@1.0-impl: Skipping unlink call, service died.
01-01 01:16:51.811  2894  2944 I bt_vendor: bt_vendor_op op 6
01-01 01:16:51.811  2894  2944 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
01-01 01:16:51.811  2894  2944 I bt_vendor: bt_vendor_op op 6 retval 0
01-01 01:16:51.811   337   337 D BluetoothManagerService: BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
01-01 01:16:51.811   337  1575 I ActivityManager: Process com.android.bluetooth (pid 19851) has died: psvc IMPF
01-01 01:16:51.811   337  1575 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
01-01 01:16:51.811   337  1575 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
01-01 01:16:51.811   337   359 E BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
01-01 01:16:51.812   337   359 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 5 receivers.
01-01 01:16:51.812   337   359 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6bf4d9c
01-01 01:16:51.812   502   544 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6b5cb83
01-01 01:16:51.812   573  1025 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@311c5d2
01-01 01:16:51.812  1418  1436 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b4f4f3b
01-01 01:16:51.812   581   842 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@fa94c89
01-01 01:16:51.813  2894  2944 I bt_vendor: bt_vendor_op op 4
01-01 01:16:51.813  2894  2944 I bt_vendor: bt_vendor_close
01-01 01:16:51.815  2894  2944 I bt_vendor: bt_vendor_op op 4 retval 0
01-01 01:16:51.815  2894  2944 I bt_vendor: bt_vendor_op op 0
01-01 01:16:51.815  2894  2944 I bt_vendor: bt_vendor_op op 0 retval 0
01-01 01:16:51.815  2894  2944 I bt_vendor: bt_vendor_cleanup
Please let me know if you can recognise the error above. and Tell some proper solutions
