Part Number: TCI6630K2L
Tool/software: Linux
Hi All!
We have a custom board with TCI6630K2L and Marvell 88E1512 PHY connected to SGMII0.
Linux is loaded from UBI partition on SPI NOR flash. UBIFS layout is as follows (board name is k10sv):
/boot/zImage
/boot/keystone-k10sv.dtb
/boot/k2-fw-initrd.cpio.gz
/boot/skern-k2l.bin
I'm able to use Ethernet port in U-Boot and ping PC host at 1Gbps (according to ethtool).
keystone-k10sv.dtb holds custom device tree based on k2l-evm. Especially - I've disabled gbe1 and ethphy1 in board's dts.
The main problem is that Ethernet does not work under Linux.
Here is full boot log:
U-Boot SPL 2018.01-00459-gfa8e4577e7-dirty (Jan 01 2019 - 19:28:31) Trying to boot from SPI U-Boot 2018.01-00459-gfa8e4577e7-dirty (Jan 01 2019 - 19:28:31 +0300) CPU: 66AK2Lx SR1.0 Model: k10sv board I2C: ready DRAM: DRAM: 2 GiB Clear entire DDR3 memory to enable ECC 2 GiB SF: Detected s25fl128s_64k with page size 256 Bytes, erase size 64 KiB, total 16 MiB *** Warning - bad CRC, using default environment Net: Warning: netcp@26000000 using MAC address from ROM eth0: netcp@26000000Could not get PHY for ethernet-mdio: addr 1 Warning: netcp@slave-1 (eth1) using random MAC address - 66:fc:4b:b4:7e:98 , eth1: netcp@slave-1 Warning: netcp@slave-2 (eth2) using random MAC address - 06:b5:d2:3e:7d:eb , eth2: netcp@slave-2 Warning: netcp@slave-3 (eth3) using random MAC address - c6:6d:17:13:ef:e5 , eth3: netcp@slave-3 Hit any key to stop autoboot: 0 SF: Detected s25fl128s_64k with page size 256 Bytes, erase size 64 KiB, total 16 MiB ubi0: attaching mtd2 ubi0: scanning is finished ubi0: attached mtd2 (name "mtd=3", size 15 MiB) ubi0: PEB size: 65536 bytes (64 KiB), LEB size: 65408 bytes ubi0: min./max. I/O unit sizes: 1/256, sub-page size 1 ubi0: VID header offset: 64 (aligned 64), data offset: 128 ubi0: good PEBs: 240, bad PEBs: 0, corrupted PEBs: 0 ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128 ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1910823204 ubi0: available PEBs: 0, total reserved PEBs: 240, PEBs reserved for bad PEB handling: 0 Loading file '/boot/skern-k2l.bin' to addr 0x87000000... Done K2_BM_15.07-53-ge1f885a SoC:k2l built:03:07:15, Oct 6 2018 ## installed monitor @ 0xc1f8000, freq [200000000], status 203390976 Loading file '/boot/zImage' to addr 0x82000000... Done Loading file '/boot/k2-fw-initrd.cpio.gz' to addr 0x88080000... Done Loading file '/boot/keystone-k10sv.dtb' to addr 0x88000000... Done ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Ramdisk to 8ffef000, end 8ffff162 ... OK Loading Device Tree to 8ffe3000, end 8ffee2a0 ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.67-gd315a9bb00 (ghost@ghost-desktop) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #17 SMP PREEMPT Tue Jan 1 23:09:56 MSK 2019 [ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: Kontur-NIIRS k10sv processing module [ 0.000000] bootconsole [earlycon0] enabled [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Switching physical address space to 0x800000000 [ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp-common-memory@81f800000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x000000087e400000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 15 pages/cpu @de5bb000 s29964 r8192 d23284 u61440 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 359296 [ 0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 earlyprintk rootfstype=ubifs mtdparts=spi0.0:64k(u-boot-spl)ro,896k(u-boot-img)ro,64k(u-boot-env),-(ubifs) root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 1384932K/1441792K available (6144K kernel code, 149K rwdata, 1340K rodata, 2048K init, 235K bss, 24092K reserved, 32768K cma-reserved, 892928K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB) [ 0.000000] .init : 0xc0a00000 - 0xc0c00000 (2048 kB) [ 0.000000] .data : 0xc0c00000 - 0xc0c25540 ( 150 kB) [ 0.000000] .bss : 0xc0c27000 - 0xc0c61fe4 ( 236 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] of_psc_clk_init: error registering clk clkpcie1 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008174] Switching to timer-based delay loop, resolution 5ns [ 0.014393] keystone timer clock @200000000 Hz [ 0.019169] Console: colour dummy device 80x30 [ 0.023756] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=2000000) [ 0.034486] pid_max: default: 32768 minimum: 301 [ 0.039320] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.046098] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.053735] CPU: Testing write buffer coherency: ok [ 0.058964] /cpus/cpu@0 missing clock-frequency property [ 0.064430] /cpus/cpu@1 missing clock-frequency property [ 0.069897] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.109971] Setting up static identity map for 0x80200000 - 0x80200138 [ 0.116731] Hierarchical SRCU implementation. [ 0.161279] smp: Bringing up secondary CPUs ... [ 0.212699] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.212810] smp: Brought up 1 node, 2 CPUs [ 0.222843] SMP: Total of 2 processors activated (800.00 BogoMIPS). [ 0.229256] CPU: All CPU(s) started in HYP mode. [ 0.234011] CPU: Virtualization extensions available. [ 0.239563] devtmpfs: initialized [ 0.248232] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0 [ 0.257172] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.265119] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.275151] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.282034] pinctrl core: initialized pinctrl subsystem [ 0.287632] NET: Registered protocol family 16 [ 0.292954] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.300681] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.308851] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.330066] EDAC MC: Ver: 3.0.0 [ 0.333916] clocksource: Switched to clocksource arch_sys_counter [ 0.345970] NET: Registered protocol family 2 [ 0.350890] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.358157] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.364834] TCP: Hash tables configured (established 4096 bind 4096) [ 0.371392] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.377412] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.383962] NET: Registered protocol family 1 [ 0.388610] Trying to unpack rootfs image as initramfs... [ 0.398188] Freeing initrd memory: 68K [ 0.402257] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.409752] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.418637] platform alarmtimer: set dma_pfn_offset00780000 [ 0.424923] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.434574] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.440315] bounce: pool size: 64 pages [ 0.444356] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) [ 0.451911] io scheduler noop registered [ 0.455974] io scheduler deadline registered [ 0.460493] io scheduler cfq registered (default) [ 0.465348] io scheduler mq-deadline registered [ 0.470007] io scheduler kyber registered [ 0.474416] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28 [ 0.482558] ti,keystone-serdes 232a000.phy: init fw ks2_gbe_serdes.bin: version 3.3.0.2c [ 0.493878] registered dspmem misc device [ 0.498164] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192 [ 0.507171] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek e0940000, reg_status e0925000, reg_config e0927000, reg_region e0929000, reg_push e0980000, reg_pop e09c0000 [ 0.526922] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_acc48.bin downloaded for PDSP [ 0.539345] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 149 logical channels, flows 128, tx chans: 21, rx chans: 91 [ 0.552254] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled [ 0.558828] platform serial8250: set dma_pfn_offset00780000 [ 0.565375] console [ttyS0] disabled [ 0.569102] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 12500000) is a TI DA8xx/66AK2x [ 0.578907] console [ttyS0] enabled [ 0.578907] console [ttyS0] enabled [ 0.586022] bootconsole [earlycon0] disabled [ 0.586022] bootconsole [earlycon0] disabled [ 0.608060] brd: module loaded [ 0.612369] loop: module loaded [ 0.615962] spi_davinci 21000400.spi: DMA is not supported (-19) [ 0.622506] m25p80 spi0.0: s25fl128s (16384 Kbytes) [ 0.627434] 4 cmdlinepart partitions found on MTD device spi0.0 [ 0.633374] Creating 4 MTD partitions on "spi0.0": [ 0.638201] 0x000000000000-0x000000010000 : "u-boot-spl" [ 0.644161] 0x000000010000-0x0000000f0000 : "u-boot-img" [ 0.650027] 0x0000000f0000-0x000000100000 : "u-boot-env" [ 0.655916] 0x000000100000-0x000001000000 : "ubifs" [ 0.661365] spi_davinci 21000400.spi: Controller at 0xe097d400 [ 0.667487] spi_davinci 21000600.spi: DMA is not supported (-19) [ 0.673794] spi_davinci 21000600.spi: Controller at 0xe09a1600 [ 0.679875] platform Fixed MDIO bus.0: set dma_pfn_offset00780000 [ 0.686120] libphy: Fixed MDIO Bus: probed [ 0.743944] davinci_mdio 26200f00.mdio: davinci mdio revision 1.7, bus freq 2500000 [ 0.751630] libphy: 26200f00.mdio: probed [ 0.756405] davinci_mdio 26200f00.mdio: phy[0]: device 26200f00.mdio:00, driver Marvell 88E1510 [ 1.273918] ti,keystone-serdes 232a000.phy: init_lane_rx wait sd valid FAILED -110 [ 3.293397] serdes PLL not locked [ 5.819916] serdes PLL not locked [ 6.334395] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.4 [ 6.340860] netcp-1.0 2620110.netcp: ALE Table size 1024 [ 6.346952] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device [ 6.355021] EDAC MC0: Giving out device to module ti-emif-edac controller ti,emif-keystone: DEV 21010000.emif (INTERRUPT) [ 6.368066] keystone-rproc 10800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 6.377129] remoteproc remoteproc0: 10800000.dsp is available [ 6.384689] keystone-rproc 11800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 6.393734] remoteproc remoteproc1: 11800000.dsp is available [ 6.401239] keystone-rproc 12800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 6.410298] remoteproc remoteproc2: 12800000.dsp is available [ 6.417800] keystone-rproc 13800000.dsp: assigned reserved memory node dsp-common-memory@81f800000 [ 6.426860] remoteproc remoteproc3: 13800000.dsp is available [ 6.433235] NET: Registered protocol family 17 [ 6.437725] NET: Registered protocol family 44 [ 6.442258] Registering SWP/SWPB emulation handler [ 6.450330] ubi0: attaching mtd3 [ 6.454728] random: fast init done [ 6.512698] random: crng init done [ 6.598178] ubi0: scanning is finished [ 6.764304] ubi0: attached mtd3 (name "ubifs", size 15 MiB) [ 6.769899] ubi0: PEB size: 65536 bytes (64 KiB), LEB size: 65408 bytes [ 6.776557] ubi0: min./max. I/O unit sizes: 1/256, sub-page size 1 [ 6.782759] ubi0: VID header offset: 64 (aligned 64), data offset: 128 [ 6.789323] ubi0: good PEBs: 240, bad PEBs: 0, corrupted PEBs: 0 [ 6.795362] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 6.802611] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1910823204 [ 6.811790] ubi0: available PEBs: 0, total reserved PEBs: 240, PEBs reserved for bad PEB handling: 0 [ 6.820985] ubi0: background thread "ubi_bgt0d" started, PID 42 [ 6.841740] UBIFS: parse sync [ 6.854503] (NULL net_device): Link is Down [ 6.858701] (NULL net_device): Link is Down [ 6.863090] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 43 [ 7.853498] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 7.860943] UBIFS (ubi0:0): LEB size: 65408 bytes (63 KiB), min./max. I/O unit sizes: 8 bytes/256 bytes [ 7.870387] UBIFS (ubi0:0): FS size: 14782208 bytes (14 MiB, 226 LEBs), journal size 2158464 bytes (2 MiB, 33 LEBs) [ 7.880947] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB) [ 7.886815] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID A925CC02-07D2-4D01-81DA-9661F5B09EEC, small LPT model [ 7.902027] VFS: Mounted root (ubifs filesystem) on device 0:14. [ 7.911222] devtmpfs: mounted [ 7.915281] Freeing unused kernel memory: 2048K Starting logging: OK Initializing random number generator... done. Starting network: OK Starting sshd: OK Welcome to k10sv k10sv login:
ifconfig gives two ethernet ports eth0 and eth1. Trying to configure eth0 with static IP results in kernel panic.
What can be wrong with this setup?
Yurii
