Hi all,
I want to restore the NAND flash file system on DM365 EVM,
so I followed the document of DM365 "getting started guide" on A.5.2.
1. Flash_eraseall /dev/mtd3
2. Mount -t yaffs2 /dev/mtdblock3 /mnt/nand
3. tar xf /target-reduced-dm365.tar
But for 2. When "tar xf /target-reduced-dm365.tar" There are thousands of lines like **>> yaffs chunk xx was not erased **>> yaffs write required 2 attempt.
My error that i run step A.5.2 befor A.5.1
i tried to run encode sapl the it works well befor but i have a screen purple in the tv and empty test.mpeg4 file.
How i fix this problem.
you find here some error :
tar: sbin/fdisk: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
yaffs tragedy: no more eraased blocks
tar: sbin/shutdown: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: sbin/hdparm: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/udev: Cannot open: No such file or diryaffs tragedy: no more eraased s
ectory
tar: sbin/makedevs: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: sbin/init: Cannot open: No such file or diryaffs tragedy: no more eraased s
ectory
tar: sbin/telinit: Cannot create symlink to `iniyaffs tragedy: no more eraased s
t': No such file or directory
tar: sbin/mkswapyaffs tragedy: no more eraased blocks
: Cannot open: No such file or directory
tar: sbin/dhcpcd: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/pivot_root: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: sbin/ifdown: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/vconfig: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/swapoff: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/sysctl: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/insmod: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/killall5: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: sbin/ifconfig: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: sbin/rmmod: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: sbin/fsck: Cannot open: No such file or diryaffs tragedy: no more eraased s
ectory
tar: sbin/mount.smb: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: sbin/hwclock: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/udevstart: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: sbin/switch_root: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: sbin/route: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: sbin/portmap: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/reboot: Cannot create symlink to `haltyaffs tragedy: no more eraased s
tar: sbin/loadkmyaffs tragedy: no more eraased blocks
ap: Cannot open: No such file or directory
tar: sbin/hotplug: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/halt: yaffs tragedy: no more eraased blocks
tar: sbin/udevtrigger: Cannot open: No such file or directory
tar: sbin/losetup: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/sulogin: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: sbin/start-stop-daemon: Cannot open: No sucyaffs tragedy: no more eraased s
h file or directory
tar: sbin/pmap_set: Cannot open:yaffs tragedy: no more eraased blocks
tar: sbin/udevsettle: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: sbin/modprobe: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: sbin/klogd: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: sbin/getty: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: sbin/ifup: Cannot open: No such file or diryaffs tragedy: no more eraased s
ectory
tar: sbin/modprobe-bin: Cannot open: No such filyaffs tragedy: no more eraased s
e or directory
tar: sbin/poweroff: Cannot create symlink to `hayaffs tragedy: no more eraased s
lt': No such file or directory
tar: sbin/udevd: Cannot open: Noyaffs tragedy: no more eraased blocks
tar: sbin/nameif: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/swapon: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sbin/dhcpcd-bin: Cannot open: No such file or directory
tar: sbin/pmap_dump: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: sbin/devfsd: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: sys: Cannot mkdir: Cannot allocate memory
tar: tmp: Cannot mkdir: Cannot allocate memory
tar: usr: Cannot mkdir: Cannot allocate memory
tar: usr/lib: Cannot mkdir: No such file or direyaffs tragedy: no more eraased s
ctory
tar: usr/lib/libreadline.so.5: Cannot create symyaffs tragedy: no more eraased s
link to `libreadline.so.5.0': No such file or directory
tar: usr/lib/libreadline.so.5.0: Cannot open: No such file or directory
tar: usr/lib/libpng.so.3: Cannot open: No such file or directory
tar: usr/lib/libjpeg.so.62: Cannot open: No such file or directory
tar: usr/lib/libfreetype.so.6: Cannot open: No syaffs tragedy: no more eraased s
tar: usr/lib/libasound.so.2: Cannot open: No such file or directory
tar: usr/lib/libz.so.1: Cannot open: No such filyaffs tragedy: no more eraased s
e or directory
tar: usr/share: Cannot mkdir: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/share/udhcpc: Cannot mkdir: No such filyaffs tragedy: no more eraased s
e or directory
tar: usr/share/udhcpc/sample.bound: Cannot open:yaffs tragedy: no more eraased s
tar: usr/share/uyaffs tragedy: no more eraased blocks
dhcpc/sample.deconfig: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/share/udhcpc/default.script: Cannot opeyaffs tragedy: no more eraased s
tar: usr/share/syaffs tragedy: no more eraased blocks
amba: Cannot mkdir: No such file or directory
tar: usr/share/samba/codepages: Cannot mkdir: Noyaffs tragedy: no more eraased s
tar: usr/sbin: Cannot mkdir: No yaffs tragedy: no more eraased blocks
tar: usr/sbin/inetd: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/sbin/fbset: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/sbin/in.telnetd: Cannot open: No such fyaffs tragedy: no more eraased s
ile or directory
tar: usr/sbin/telnetd: Cannot open: Nyaffs tragedy: no more eraased blocks
tar: usr/sbin/in.rexecd: Cannot open: No such fiyaffs tragedy: no more eraased s
le or directory
tar: usr/sbin/rdate: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/sbin/udhcpd: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/sbin/chroot: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/sbin/httpd: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/sbin/in.rlogind: Cannot open: No such fyaffs tragedy: no more eraased s
ile or directory
tar: usr/bin: Cannot mkdir: No such fyaffs tragedy: no more eraased blocks
ile or directory
tar: usr/bin/od: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/bunzip2: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/wc: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/yes: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/rsh: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/renice: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/smbmount: Cannot open: No such file or directory
tar: usr/bin/xargs: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/head: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/time: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/md5sum: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/tail: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/crontab: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/cut: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/ftp: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/telnet: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/unzip: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/basename: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/sha1sum: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/unix2dos: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/tr: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/reset: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/which: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/nc: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/seq: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/rlogin: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/udevinfo: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/uptime: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/bzcat: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/hexdump: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/realpath: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/install: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/openvt: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/rcp: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/hostid: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/strings: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/test: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/passwd: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/chvt: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/uniq: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/killall: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/sort: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/dc: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/udevtest: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/top: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/printf: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/mesg: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/whoami: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/rx: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/logname: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/rpm2cpio: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/env: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/uudecode: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/wget: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/readlink: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/find: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/expr: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/arping: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/ttyyaffs tragedy: no more eraased blocks
tar: usr/bin/uuencode: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/rexec: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/[: Cannot open: No such file or diryaffs tragedy: no more eraased s
ectory
tar: usr/bin/tee: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/last: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/vlock: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/clear: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/dos2unix: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/dirname: Cannot open: No such file yaffs tragedy: no more eraased s
or directory
tar: usr/bin/deallocvt: Cannot open: No such filyaffs tragedy: no more eraased s
e or directory
tar: usr/bin/traceroute: Cannot open: No such fiyaffs tragedy: no more eraased s
le or directory
tar: usr/bin/pftp: Cannot create symlink to `ftpyaffs tragedy: no more eraased s
tar: usr/bin/awkyaffs tragedy: no more eraased blocks
tar: usr/bin/du: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/fold: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/dumpleases: Cannot open: No such fiyaffs tragedy: no more eraased s
le or directory
tar: usr/bin/mkfifo: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/smbmnt: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/length: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: usr/bin/who: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/patch: Cannot open: No such file oryaffs tragedy: no more eraased s
directory
tar: usr/bin/tftp: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/cmp: Cannot open: No such file or dyaffs tragedy: no more eraased s
irectory
tar: usr/bin/id: Cannot open: No such file or diyaffs tragedy: no more eraased s
rectory
tar: usr/bin/nslookup: Cannot open: No such fileyaffs tragedy: no more eraased s
or directory
tar: usr/bin/free: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: usr/bin/logger: Cannot open: No such file oyaffs tragedy: no more eraased s
r directory
tar: var: Cannot mkdir: Cannot allocate memory
tar: var/run: Cannot mkdir: No such file or direyaffs tragedy: no more eraased s
ctory
tar: var/run/usb: Cannot mkdir: No such file or yaffs tragedy: no more eraased s
directory
tar: var/run/utmp: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: var/log: Cannot mkdir: No such file or direyaffs tragedy: no more eraased s
ctory
tar: var/log/wtmp: Cannot open: No such file or yaffs tragedy: no more eraased s
directory
tar: var/log/hotplug: Cannot mkdir: No such fileyaffs tragedy: no more eraased s
or directory
tar: var/log/lastlog: Cannot open: No such file or directory
tar: Error exit delayed from previous errors
Thank you !
