Part Number: DRA77P
We are currently building a custom board referring to the dra77p evm.
We would like to know the initial board bring up steps ?
What all things are to be noted ?
Padmesh
Part Number: DRA77P
Padmesh
Padmesh,
First you should use the PinMux Tool:
https://dev.ti.com/pinmux/app.html#/default
There's a link to a tutorial in the upper right corner if you've never used it before. Once you're done you will download the genericFileFormatIOdelay.txt and genericFileFormatPadConf.txt files from the utility. There's a perl script that is then used to convert those files into the proper format for use in u-boot. The process is the same as what's described in this app note:
IODELAY Application Note for AM57xx Devices
http://www.ti.com/lit/pdf/sprac44
The output of the perl script will be integrated into the mux_data.h file that is part of your board data.
Next you'll want to use the EMIF tools to calculate appropriate register configurations. That's described in this app note:
AM57x, DRA7x, and TDA2x EMIF Tools
http://www.ti.com/lit/pdf/sprac36
You will need to integrate the corresponding structures into u-boot.
These are some of the key steps, so if you can get these completed and integrated, I think you'll be well on your way to a successful board bring-up.
I strongly recommend starting individual threads for specific questions/issues. In other words, please don't use this one thread for all issues encountered as you bring up your board.
Brad
