RTOS/CCSTUDIO-SITARA: Linux vs. RTOS
Part Number: CCSTUDIO-SITARA
Tool/software: TI-RTOS
For a given user application, what would be the difference (just a ballpark comparison) of the memory footprint between having the application running in an RTOS environment or a linux environment
Combined footprint of the application and the OS
  • Hi Kenneth,
    It is hard to compare both OSs (Linux vs RTOS) because they can be compared in many aspects.
    If your app using same variables and same data arrays should not be expected various memory footprint between both OSs.
    Nevertheless TI-RTOS can be considered as more memory footprint optimized. As it is described in TI-RTOS introduction at:
    dev.ti.com/.../tirtos_basics.html
    TI-RTOS scales from a minimal footprint real-time multitasking kernel - TI-RTOS Kernel (formerly known as SYS/BIOS) - to a complete RTOS solution including protocol stacks, multicore communications, device drivers and power management.
    Also you can read the linked below presentation:
    www.ti.com/.../sprt646a.pdf
    On other hand Linux OS is general use OS and you can find in the net many open source example projects and you can refer your source cod development on them.
    Tsvetolin Shulev
  • Thanks for the info. We're going to go the RTOS route.
