Part Number: TDA3XEVM
I would like to choose ethernet as input to display device.Is there any usecase which can send raw data over ethernet to display.
Can you pls suggest with solution.
Anil
Anil
Anil,
Probably you could use decode display as an example. It receives input from ethernet, decodes it and then displays it.
Rgds,
Brijesh
Thanks for reply Brijesh.
I'm using OV10640 camera as input too the tda3xevm.I would like to know how to stream data over ethernet.
As there is no documentation on avb rx and tx usecases,from where can I get details on these usecases.
Anil
Hi Anuj,
Thanks for the reply.
As per the network tools guide,network tx usecase will send RAW or MJEPG compressed frames from evm to pc and it requires network rx tool.
My requirement is to capture data from camera and display over ethernet (ethernet streaming instead of using HDMI).
Anil
