Part Number: TDA3
Tool/software: TI-RTOS
Hi, experts,
I followed the steps of VisionSDK_UserGuide_NetworkTools.pdf, and remove FATFS, and enable the NDK. When I boot from the QSPI, I could find the EVM IP is 0.0.0.0 (DHCPC is enbled)
the log as Below:
***************************************************************** Jumping to IPU1 CPU1 App Jumping to IPU1 CPU0 App [IPU1-0] 0.877569 s: ***** IPU1_0 Firmware build time 19:08:44 Jan 2 2019 [IPU1-0] 0.877722 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [IPU1-0] 1.347709 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15... [IPU1-0] 1.347861 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [IPU1-0] 1.347983 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [IPU1-0] 1.348105 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [IPU1-0] 1.348349 s: *** UTILS: CPU MHz = 20 Mhz *** [IPU1-0] 1.348471 s: SYSTEM: System Common Init in progress !!! [IPU1-0] 1.357683 s: UTILS: CIO: Init Done !!! [IPU1-0] 1.357774 s: SYSTEM: IPC init in progress !!! [IPU1-0] 1.357866 s: SYSTEM: Notify init done !!! [IPU1-0] 1.358049 s: SYSTEM: MsgQ init done !!! [IPU1-0] 1.358110 s: SYSTEM: IPC init DONE !!! [IPU1-0] 1.360306 s: SYSTEM: System Common Init Done !!! [IPU1-0] 1.360367 s: SYSTEM: System Init in progress !!! [IPU1-0] 1.360428 s: SYSTEM: BSP Common Init in progress !!! [IPU1-0] 1.360519 s: SYSTEM: BSP Common Init Done !!! [IPU1-0] 1.360611 s: SYSTEM: BSP Platform Init in progress !!! [IPU1-0] 1.360733 s: SYSTEM: BSP Platform Init Done !!! [IPU1-0] 1.360794 s: SYSTEM: FVID2 Init in progress !!! [IPU1-0] 1.360946 s: SYSTEM: FVID2 Init Done !!! [IPU1-0] 1.361038 s: SYSTEM: VPS Init in progress !!! [IPU1-0] 1.361099 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000] [IPU1-0] 1.363661 s: *** VPDMA Firmware Loading... *** [IPU1-0] 1.363752 s: VPDMA Firmware Address = 0x9ffc7800 [IPU1-0] 1.363844 s: VPDMA Load Address = 0x4897d004 [IPU1-0] 1.363966 s: VPDMA Firmware Version = 0x4d0001b8 [IPU1-0] 1.364057 s: VPDMA List Busy Status = 0x00000000 [IPU1-0] 1.364149 s: *** VPDMA Firmware Load Success *** [IPU1-0] 1.400140 s: SYSTEM: VPS Init Done !!! [IPU1-0] 1.400902 s: UTILS: DMA: HWI Create for INT34 !!! [IPU1-0] 1.401177 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [IPU1-0] 1.401268 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257272 B (251 KB) [IPU1-0] 1.401451 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 1.401665 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x85703000, Total size = 369086464 B (351 MB), Free size = 369086464 B (351 MB) [IPU1-0] 1.401878 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfe00000, Total size = 915712 B (0 MB), Free size = 908032 B (0 MB) [IPU1-0] 1.402061 s: SYSTEM: Initializing Links !!! [IPU1-0] 1.481577 s: SYSTEM: Initializing Links ... DONE !!! [IPU1-0] 1.504880 s: BOARD: Board Init in progress !!! [IPU1-0] 1.505215 s: BOARD: Board Init Done !!! [IPU1-0] 1.511041 s: Initializing Multi-Deserializer Setup ...!! [IPU1-0] 1.511132 s: MultiDes Board Init Done [IPU1-0] 1.511163 s: [IPU1-0] 1.511193 s: Vision SDK Version : [REL_VISION_SDK_03_05_00_00] [IPU1-0] 1.511285 s: FVID2 Version : [FVID_02_01_00_01] [IPU1-0] 1.511346 s: BSP Version : [PDK_01_10_01_xx] [IPU1-0] 1.511407 s: Platform : [EVM] [IPU1-0] 1.511468 s: SOC : [TDA3XX] [IPU1-0] 1.511559 s: SOC Revision : [ES1.0] [IPU1-0] 1.511651 s: Board Detected : [MULTIDES] [IPU1-0] 1.518788 s: EEPROM Base Board Name: [ADAS-LOW] [IPU1-0] 1.518849 s: Base Board Revision : [REV C] [IPU1-0] 1.518910 s: Daughter Card Revision: [REV A] [IPU1-0] 1.518971 s: [IPU1-0] 1.521594 s: SYSTEM: UART: INTERRUPT Mode is Selected [IPU1-1] 0.889007 s: ***** IPU1_1 Firmware build time 19:06:51 Jan 2 2019 [IPU1-1] 0.889160 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [IPU1-1] 1.348746 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15... [IPU1-1] 1.348929 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [IPU1-1] 1.349020 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [IPU1-1] 1.349142 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [IPU1-1] 1.355761 s: SYSTEM: System Common Init in progress !!! [IPU1-1] 1.356737 s: UTILS: CIO: Init Done !!! [IPU1-1] 1.356829 s: SYSTEM: IPC init in progress !!! [IPU1-1] 1.356890 s: SYSTEM: Notify init done !!! [IPU1-1] 1.357073 s: SYSTEM: MsgQ init done !!! [IPU1-1] 1.357134 s: SYSTEM: IPC init DONE !!! [IPU1-1] 1.359238 s: SYSTEM: System Common Init Done !!! [IPU1-1] 1.359330 s: SYSTEM: System IPU1_1 Init in progress !!! [IPU1-1] 1.360062 s: UTILS: DMA: HWI Create for INT25 !!! [IPU1-1] 1.360245 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [IPU1-1] 1.360367 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 232112 B (226 KB) [IPU1-1] 1.360550 s: SYSTEM: Initializing Links !!! [IPU1-1] 1.403861 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 #### [IPU1-1] 1.405325 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 #### [IPU1-1] 1.406972 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 #### [IPU1-1] 1.408467 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 #### [IPU1-1] 1.410083 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 #### [IPU1-1] 1.411730 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 #### [IPU1-1] 1.413530 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 #### [IPU1-1] 1.415329 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 #### [IPU1-1] 1.417220 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 #### [IPU1-1] 1.419172 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 #### [IPU1-1] 1.421155 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 #### [IPU1-1] 1.421277 s: SYSTEM: Initializing Links ... DONE !!! [IPU1-1] 1.421826 s: SYSTEM: System IPU1_1 Init Done !!! [IPU1-1] 1.650796 s: NSP GMAC: PHY 0 Found on MAC Port 0 [DSP1 ] 0.898371 s: ***** DSP1 Firmware build time 19:07:17 Jan 2 2019 [DSP1 ] 0.898462 s: *** SYSTEM: CPU Frequency <ORG = 500000000 Hz>, <NEW = 500000000 Hz> [DSP1 ] 1.349508 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15... [DSP1 ] 1.349569 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15... [DSP1 ] 1.349630 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [DSP1 ] 1.349661 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [DSP1 ] 1.349752 s: *** UTILS: CPU MHz = 20 Mhz *** [DSP1 ] 1.349813 s: SYSTEM: System Common Init in progress !!! [DSP1 ] 1.349996 s: UTILS: CIO: Init Done !!! [DSP1 ] 1.350027 s: SYSTEM: IPC init in progress !!! [DSP1 ] 1.350057 s: SYSTEM: Notify init done !!! [DSP1 ] 1.350118 s: SYSTEM: MsgQ init done !!! [DSP1 ] 1.350149 s: SYSTEM: IPC init DONE !!! [DSP1 ] 1.350881 s: SYSTEM: System Common Init Done !!! [DSP1 ] 1.350911 s: SYSTEM: System DSP Init in progress !!! [DSP1 ] 1.351094 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [DSP1 ] 1.351125 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP1 ] 1.351186 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519608 B (507 KB) [DSP1 ] 1.351247 s: SYSTEM: Initializing Links !!! [DSP1 ] 1.357744 s: SYSTEM: Initializing Links ... DONE !!! [DSP1 ] 1.357805 s: lz4CompDecomp Init [DSP1 ] 1.357805 s: SYSTEM: System DSP Init Done !!! [DSP1 ] 1.489599 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [DSP1 ] 1.489629 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [DSP2 ] 0.898462 s: ***** DSP2 Firmware build time 19:07:18 Jan 2 2019 [DSP2 ] 0.898523 s: *** SYSTEM: CPU Frequency <ORG = 500000000 Hz>, <NEW = 500000000 Hz> [DSP2 ] 1.350332 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15... [DSP2 ] 1.350393 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15... [DSP2 ] 1.350454 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [DSP2 ] 1.350484 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [DSP2 ] 1.350576 s: *** UTILS: CPU MHz = 20 Mhz *** [DSP2 ] 1.350637 s: SYSTEM: System Common Init in progress !!! [DSP2 ] 1.350820 s: UTILS: CIO: Init Done !!! [DSP2 ] 1.350850 s: SYSTEM: IPC init in progress !!! [DSP2 ] 1.350881 s: SYSTEM: Notify init done !!! [DSP2 ] 1.350942 s: SYSTEM: MsgQ init done !!! [DSP2 ] 1.350972 s: SYSTEM: IPC init DONE !!! [DSP2 ] 1.351735 s: SYSTEM: System Common Init Done !!! [DSP2 ] 1.351765 s: SYSTEM: System DSP Init in progress !!! [DSP2 ] 1.351949 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [DSP2 ] 1.352010 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP2 ] 1.352071 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 519608 B (507 KB) [DSP2 ] 1.352101 s: SYSTEM: Initializing Links !!! [DSP2 ] 1.358659 s: SYSTEM: Initializing Links ... DONE !!! [DSP2 ] 1.358689 s: lz4CompDecomp Init [DSP2 ] 1.358720 s: SYSTEM: System DSP Init Done !!! [DSP2 ] 1.491581 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [DSP2 ] 1.491642 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [EVE1 ] 1.343744 s: ***** EVE1 Firmware build time 19:06:28 Jan 2 2019 [EVE1 ] 1.344964 s: *** SYSTEM: CPU Frequency <ORG = 250000000 Hz>, <NEW = 250000000 Hz> [EVE1 ] 1.350362 s: SYSTEM: Notify register to [IPU1-0] line 0, event 15... [EVE1 ] 1.351369 s: SYSTEM: Notify register to [IPU1-1] line 0, event 15... [EVE1 ] 1.352498 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [EVE1 ] 1.353535 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [EVE1 ] 1.354846 s: SYSTEM: System Common Init in progress !!! [EVE1 ] 1.356615 s: UTILS: CIO: Init Done !!! [EVE1 ] 1.357317 s: SYSTEM: IPC init in progress !!! [EVE1 ] 1.358049 s: SYSTEM: Notify init done !!! [EVE1 ] 1.359025 s: SYSTEM: MsgQ init done !!! [EVE1 ] 1.359665 s: SYSTEM: IPC init DONE !!! [EVE1 ] 1.369913 s: SYSTEM: System Common Init Done !!! [EVE1 ] 1.370615 s: SYSTEM: System EVE Init in progress !!! [EVE1 ] 1.371683 s: UTILS: DMA: HWI Create for INT8 !!! [EVE1 ] 1.372537 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [EVE1 ] 1.373482 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE1 ] 1.375282 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257432 B (251 KB) [EVE1 ] 1.376929 s: SYSTEM: Initializing Links !!! [EVE1 ] 1.445495 s: SYSTEM: Initializing Links ... DONE !!! [EVE1 ] 1.446257 s: SYSTEM: System EVE Init Done !!! [IPU1-0] 2.525071 s: QSPI Init Started [IPU1-0] 2.525315 s: MID - 1 [IPU1-0] 2.525376 s: DID - 18 [IPU1-0] 2.525407 s: QSPI Init Completed Sucessfully [IPU1-0] 2.533245 s: UTILS: DMM: API NOT supported in TDA3xx !!! [IPU1-0] 2.533337 s: UTILS: DMM: API NOT supported in TDA3xx !!! [IPU1-0] 2.534496 s: [IPU1-0] 2.534587 s: Current System Settings, [IPU1-0] 2.534648 s: ======================== [IPU1-0] 2.534709 s: Display Type : HDMI 1920x1080 @ 60fps [IPU1-0] 2.534770 s: Capture Source : Sensor OV10635 1280x720 @ 30fps - VIP, YUV422 [IPU1-0] 2.534831 s: My IP address : 0.0.0.0 [IPU1-0] 2.534892 s: ISS Settings : LDC=[OFF] VTNF=[OFF] WDR=[OFF] [IPU1-0] 2.534984 s: [IPU1-0] 2.535014 s: ============ [IPU1-0] 2.535045 s: Usecase Menu [IPU1-0] 2.535106 s: ============ [IPU1-0] 2.535136 s: [IPU1-0] [IPU1-0] Vision SDK Usecases, [IPU1-0] -------------------- [IPU1-0] 1: Single Camera Usecases [IPU1-0] 2: Multi-Camera LVDS Usecases [IPU1-0] 3: AVB RX Usecases, (TDA2x & TDA2Ex ONLY) [IPU1-0] 4: Dual Display Usecases, (TDA2x EVM ONLY) [IPU1-0] 5: ISS Usecases, (TDA3x ONLY) [IPU1-0] 6: TDA2x Stereo Usecases [IPU1-0] 9: RADAR Usecases [IPU1-0] a: Miscellaneous test's [IPU1-0] f: TIDL Usecase [IPU1-0] g: Camera Radar Combo Usecases [IPU1-0] [IPU1-0] s: System Settings [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-1] 6.421673 s: NETWORK_CTRL: Starting Server (port=5000) !!! [IPU1-1] 6.421765 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [IPU1-1] 27.152168 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 27.351674 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 62.853108 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 63.152687 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 97.854084 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 98.053589 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 127.254864 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 127.454370 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 164.755871 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 164.855426 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 169.359391 s: Service Status: DHCPC : Enabled : Fault : 002 [IPU1-1] 200.656835 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 200.956383 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 230.057646 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 230.357164 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 260.258433 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 260.657994 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 310.359818 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 310.559324 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 339.560605 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 339.660098 s: NDK: Link Status: No Link on PHY 0 [IPU1-1] 370.361404 s: NDK: Link Status: 10Mb/s Full Duplex on PHY 0 [IPU1-1] 370.560971 s: NDK: Link Status: No Link on PHY 0
Please help to check, and guide me to completed the Network issue.
Widic
