Part Number: AM6548
Tool/software: Linux
Hi TI,
SDK version: ti-processor-sdk-linux-am65xx-evm-05.02.00.10
Board: AM65xx EVM
Now I want to mount rootfs on usb storage, but I build the usb driver into kernel (default it is be built into kernel as module), I encounter below error:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79+ (gaonian@gaonian-SIMATIC-IPC3000-SMART) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Thu Jan 24 09:44:34 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Texas Instruments AM654 Base Board
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002810000 (options '')
[ 0.000000] bootconsole [ns16550a0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f1-dma-memory@9b000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f1-memory@9b100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f0-dma-memory@9c000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c100000, size 7 MiB
[ 0.000000] OF: reserved mem: initialized node r5f0-memory@9c100000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 512 MiB at 0x00000000c0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 2 pages/cpu @ffff80007feb0000 s38936 r8192 d83944 u131072
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 31968
[ 0.000000] Kernel command line: console=ttyS3,115200n8 earlycon=ns16550a,mmio32,0x02810000 mtdparts=47040000.ospi.0:512k(ospi.tiboot3),2m(ospi.tispl),5m(ospi.u-boot),128k(ospi.env),-@8m(ospi.rootfs) root=PARTUUID=a7777607-01 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: -1, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 5, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 4, 1048576 bytes)
[ 0.000000] Memory: 1493312K/2048000K available (7486K kernel code, 662K rwdata, 2752K rodata, 448K init, 652K bss, 30400K reserved, 524288K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7bdfffff0000 (126847 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff0000087d0000 ( 7488 KB)
[ 0.000000] .rodata : 0xffff0000087d0000 - 0xffff000008a90000 ( 2816 KB)
[ 0.000000] .init : 0xffff000008a90000 - 0xffff000008b00000 ( 448 KB)
[ 0.000000] .data : 0xffff000008b00000 - 0xffff000008ba5808 ( 663 KB)
[ 0.000000] .bss : 0xffff000008ba5808 - 0xffff000008c48b60 ( 653 KB)
[ 0.000000] fixed : 0xffff7fdffe7b0000 - 0xffff7fdffec00000 ( 4416 KB)
[ 0.000000] PCI I/O : 0xffff7fdffee00000 - 0xffff7fdfffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7fe000000000 - 0xffff800000000000 ( 128 GB maximum)
[ 0.000000] 0xffff7fe000000000 - 0xffff7fe000200000 ( 2 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff800080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @a0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x00000000a00c0000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] CPU0: using LPI pending table @0x00000000a00d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008627] Console: colour dummy device 80x25
[ 0.013202] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023891] pid_max: default: 32768 minimum: 301
[ 0.028740] Security Framework initialized
[ 0.032994] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes)
[ 0.039876] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
[ 0.063293] ASID allocator initialised with 32768 entries
[ 0.068934] Hierarchical SRCU implementation.
[ 0.081497] PCI/MSI: /soc0/interrupt-controller@1800000/gic-its@1000000 domain created
[ 0.089897] Platform MSI: /soc0/interrupt-controller@1800000/gic-its@1000000 domain created
[ 0.106480] smp: Bringing up secondary CPUs ...
[ 0.139613] Detected VIPT I-cache on CPU1
[ 0.139649] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.139697] CPU1: using LPI pending table @0x00000000a03b0000
[ 0.139741] CPU1: Booted secondary processor [410fd034]
[ 0.196630] Detected VIPT I-cache on CPU2
[ 0.196670] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[ 0.196721] CPU2: using LPI pending table @0x00000000a0420000
[ 0.196768] CPU2: Booted secondary processor [410fd034]
[ 0.225041] Detected VIPT I-cache on CPU3
[ 0.225067] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[ 0.225114] CPU3: using LPI pending table @0x00000000a0480000
[ 0.225146] CPU3: Booted secondary processor [410fd034]
[ 0.225279] smp: Brought up 1 node, 4 CPUs
[ 0.296936] SMP: Total of 4 processors activated.
[ 0.301753] CPU features: detected feature: GIC system register CPU interface
[ 0.309057] CPU features: detected feature: 32-bit EL0 Support
[ 0.315028] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.345835] CPU: All CPU(s) started at EL2
[ 0.350054] alternatives: patching kernel code
[ 0.355999] devtmpfs: initialized
[ 0.368705] random: get_random_u32 called from bucket_table_alloc+0x108/0x258 with crng_init=0
[ 0.378319] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.388314] futex hash table entries: 1024 (order: 1, 131072 bytes)
[ 0.396287] pinctrl core: initialized pinctrl subsystem
[ 0.402548] NET: Registered protocol family 16
[ 0.409070] vdso: 2 pages (1 code @ ffff0000087e0000, 1 data @ ffff000008b20000)
[ 0.423324] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.433984] davinci_gpio 600000.main_gpio0: could not find pctldev for node /soc0/pinmux@11c000/arduino_io_d4_to_d9_pins_default, deferring probe
[ 0.447549] davinci_gpio 601000.main_gpio1: IRQ not populated, err = -517
[ 0.454667] davinci_gpio 42110000.wkup_gpio0: could not find pctldev for node /soc0/pinmux@4301c000/arduino_io_d2_to_d3_pins_default, deferring probe
[ 0.479723] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.486605] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.495066] omap_i2c 42120000.i2c: could not find pctldev for node /soc0/pinmux@4301c000/wkup_i2c0_pins_default, deferring probe
[ 0.506980] omap_i2c 40b00000.i2c: could not find pctldev for node /soc0/pinmux@4301c000/mcu_i2c0_pins_default, deferring probe
[ 0.518770] omap_i2c 2000000.i2c: could not find pctldev for node /soc0/pinmux@11c2e8/main_i2c0_pins_default, deferring probe
[ 0.530377] omap_i2c 2010000.i2c: could not find pctldev for node /soc0/pinmux@11c2e8/main_i2c1_pins_default, deferring probe
[ 0.541979] omap_i2c 2030000.i2c: could not find pctldev for node /soc0/pinmux@11c000/main_i2c3_pins_default, deferring probe
[ 0.553686] media: Linux media interface: v0.10
[ 0.558351] Linux video capture interface: v2.00
[ 0.563114] pps_core: LinuxPPS API ver. 1 registered
[ 0.568198] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.577558] PTP clock support registered
[ 0.581595] EDAC MC: Ver: 3.0.0
[ 0.585684] Advanced Linux Sound Architecture Driver Initialized.
[ 0.592573] clocksource: Switched to clocksource arch_sys_counter
[ 0.598989] VFS: Disk quotas dquot_6.6.0
[ 0.603114] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.616936] NET: Registered protocol family 2
[ 0.621914] TCP established hash table entries: 16384 (order: 1, 131072 bytes)
[ 0.629475] TCP bind hash table entries: 16384 (order: 2, 262144 bytes)
[ 0.636537] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.643339] UDP hash table entries: 2048 (order: 0, 65536 bytes)
[ 0.649603] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
[ 0.656452] NET: Registered protocol family 1
[ 0.661370] RPC: Registered named UNIX socket transport module.
[ 0.667447] RPC: Registered udp transport module.
[ 0.672264] RPC: Registered tcp transport module.
[ 0.677080] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.683875] Unpacking initramfs...
[ 0.687380] Initramfs unpacking failed: junk in compressed archive
[ 0.697000] Freeing initrd memory: 11328K
[ 0.706189] workingset: timestamp_bits=46 max_order=15 bucket_order=0
[ 0.718044] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.724631] NFS: Registering the id_resolver key type
[ 0.729833] Key type id_resolver registered
[ 0.734119] Key type id_legacy registered
[ 0.738244] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.745284] 9p: Installing v9fs 9p2000 file system support
[ 0.755375] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.762979] io scheduler noop registered
[ 0.767104] io scheduler cfq registered (default)
[ 0.771926] io scheduler mq-deadline registered
[ 0.776564] io scheduler kyber registered
[ 0.782039] [4294966779] evm_clk_get(wkupclk); ................................
[ 0.789539] omap-usb2 4100000.phy: unable to get wkupclk, trying old name
[ 0.796506] omap-usb2 4100000.phy: unable to get usb_phy_cm_clk32k
[ 0.802911] omap-usb2: probe of 4100000.phy failed with error -2
[ 0.809198] [4294966779] evm_clk_get(wkupclk); ................................
[ 0.816685] omap-usb2 4110000.phy: unable to get wkupclk, trying old name
[ 0.823645] omap-usb2 4110000.phy: unable to get usb_phy_cm_clk32k
[ 0.830031] omap-usb2: probe of 4110000.phy failed with error -2
[ 0.837365] pinctrl-single 11c000.pinmux: 185 pins at pa ffff000009c7c000 size 740
[ 0.845258] pinctrl-single 11c2e8.pinmux: 9 pins at pa ffff000009c9c2e8 size 36
[ 0.852962] pinctrl-single 4301c000.pinmux: 70 pins at pa ffff000009cbc000 size 280
[ 0.868013] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.877360] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 10, base_baud = 6000000) is a 8250
[ 0.886869] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 11, base_baud = 3000000) is a 8250
[ 0.896129] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 12, base_baud = 3000000) is a 8250
[ 0.904942] console [ttyS3] enabled
[ 0.912053] bootconsole [ns16550a0] disabled
[ 0.932318] loop: module loaded
[ 0.937437] libphy: Fixed MDIO Bus: probed
[ 0.942059] tun: Universal TUN/TAP device driver, 1.6
[ 0.947312] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.955140] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.961106] sky2: driver version 1.30
[ 0.965934] VFIO - User Level meta-driver version: 0.3
[ 0.971826] i2c /dev entries driver
[ 0.976290] sdhci: Secure Digital Host Controller Interface driver
[ 0.982476] sdhci: Copyright(c) Pierre Ossman
[ 0.986852] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.993873] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.999965] ti-sci soc0:dmsc: invalid resource
[ 1.005158] optee: probing for conduit method from DT.
[ 1.013186] optee: initialized driver
[ 1.018087] NET: Registered protocol family 17
[ 1.022623] 9pnet: Installing 9P2000 support
[ 1.026988] Key type dns_resolver registered
[ 1.031884] registered taskstats version 1
[ 1.036679] davinci_gpio 600000.main_gpio0: IRQ not populated, err = -517
[ 1.043886] davinci_gpio 601000.main_gpio1: IRQ not populated, err = -517
[ 1.050940] davinci_gpio 42110000.wkup_gpio0: IRQ not populated, err = -517
[ 1.063385] ti-sci soc0:dmsc: invalid resource
[ 1.068018] ti-sci soc0:dmsc: ABI: 2.5 (firmware rev 0x0012 '18.10.0-v2018.10 (Curious Crow)')
[ 1.093751] random: fast init done
[ 1.410936] davinci_gpio 600000.main_gpio0: IRQ not populated, err = -517
[ 1.418132] davinci_gpio 601000.main_gpio1: IRQ not populated, err = -517
[ 1.425186] davinci_gpio 42110000.wkup_gpio0: IRQ not populated, err = -517
[ 1.457152] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.463516] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.493148] rtc-pcf8563 2-0051: low voltage detected, date/time is not reliable.
[ 1.500676] rtc-pcf8563 2-0051: rtc core: registered rtc-pcf8563 as rtc0
[ 1.508222] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.514558] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.520765] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.527780] ti-sci-inta 33d00000.interrupt-controller: ti,sci-dst-irq-type resource type ids not available
[ 1.540109] keystone-pcie 5600000.pcie-rc: Linked as a consumer to phy-910000.serdes.2
[ 1.550564] OF: PCI: host bridge /soc0/pcie-rc@5600000 ranges:
[ 1.556415] OF: PCI: IO 0x18020000..0x1802ffff -> 0x00000000
[ 1.562343] OF: PCI: MEM 0x18030000..0x1fffffff -> 0x18030000
[ 2.568532] keystone-pcie 5600000.pcie-rc: phy link never came up
[ 2.574745] keystone-pcie 5600000.pcie-rc: PCI host bridge to bus 0000:00
[ 2.581539] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.587026] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.593205] pci_bus 0000:00: root bus resource [mem 0x18030000-0x1fffffff]
[ 2.600529] pci 0000:00:00.0: BAR 6: assigned [mem 0x18030000-0x1803ffff pref]
[ 2.607763] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.613160] pcieport 0000:00:00.0: limiting MRRS to 256
[ 2.618605] pcieport 0000:00:00.0: Signaling PME with IRQ 29
[ 2.624366] pcieport 0000:00:00.0: AER enabled with IRQ 29
[ 2.630860] k3-navss-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
[ 2.641232] k3-navss-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled
[ 2.648282] k3-navss-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[ 2.656318] k3-navss-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,255] sci-dev-id:195
[ 2.666580] k3-navss-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled
[ 2.673632] k3-navss-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[ 2.682554] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.689182] [drm] No driver support for vblank timestamp query.
[ 2.696367] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 3.208567] cadence-qspi 47040000.ospi: Indirect read completion error (-110)
[ 3.215712] cadence-qspi 47040000.ospi: n25q064 (8192 Kbytes)
[ 3.221473] mtd: 47040000.ospi.0: skipping zero sized partition
[ 3.227391] 4 cmdlinepart partitions found on MTD device 47040000.ospi.0
[ 3.234086] Creating 4 MTD partitions on "47040000.ospi.0":
[ 3.239662] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 3.246134] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 3.252162] 0x000000280000-0x000000780000 : "ospi.u-boot"
[ 3.258182] 0x000000780000-0x0000007a0000 : "ospi.env"
[ 3.328796] cadence-qspi 47040000.ospi: Cadence QSPI NOR probe failed -517
[ 3.337328] spi spi3.0: not using DMA for McSPI (-19)
[ 3.344528] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4
[ 3.354407] mmc0: Unknown controller version (4). You may experience problems.
[ 3.404583] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 3.417038] mmc1: Unknown controller version (4). You may experience problems.
[ 3.468582] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
[ 3.492427] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900
[ 3.499395] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900
[ 3.506790] ti-udma 31150000.udmap: Channels: 267 (tchan: 120, echan: 32, rchan: 150, rflow: 300)
[ 3.530791] ti-udma 285c0000.udmap: Channels: 96 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
[ 4.052571] cadence-qspi 47040000.ospi: Indirect read completion error (-110)
[ 4.059719] cadence-qspi 47040000.ospi: n25q064 (8192 Kbytes)
[ 4.065468] 4 cmdlinepart partitions found on MTD device 47040000.ospi.0
[ 4.072164] Creating 4 MTD partitions on "47040000.ospi.0":
[ 4.077739] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.084023] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.089944] 0x000000280000-0x000000780000 : "ospi.u-boot"
[ 4.095959] 0x000000780000-0x0000007a0000 : "ospi.env"
[ 4.105405] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.112896] rtc-pcf8563 2-0051: low voltage detected, date/time is not reliable.
[ 4.120296] rtc-pcf8563 2-0051: hctosys: unable to read the hardware clock
[ 4.224599] tps62363-vout: disabling
[ 4.228172] ALSA device list:
[ 4.231148] No soundcards found.
[ 4.234998] Waiting for root device PARTUUID=a7777607-01...
But kernel startup hang in this line: "[ 4.234998] Waiting for root device PARTUUID=a7777607-01..."
After I debug this issue, I found this reason is can't get the clock named "wkupclk" when the driver phy-omap-usb2.c be probe
