Other Parts Discussed in Thread: DRA742
CPU : DRA752-GP ES1.1
Model: TI DRA742
Board: DRA74x EVM REV G.0
DRAM: 1.5 GiB
I am building the AFS source by enabling the Car HMI mentioned in the page http://omappedia.org/wiki/6AO.1.0_Engineering_Drop
But it gives the below error,
[ 0% 6/14555] target R.java/Manifest.java: framework-res__auto_genera.../obj/APPS/framework-res__auto_generated_rro_intermediates/src/R.stamp)
FAILED: out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src/R.stamp
/bin/bash -c "(rm -rf out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src/R.stamp && mkdir -p out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src/ ) && (mkdir -p out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src ) && (mkdir -p out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/ ) && (out/host/linux-x86/bin/aapt package --auto-add-overlay -z --pseudo-localize -m -J out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src -M out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/AndroidManifest.xml -P out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/public_resources.xml -S device/sample/overlays/location/frameworks/base/core/res/res -S packages/services/Car/car_product/overlay/frameworks/base/core/res/res -S device/ti/jacinto6evm/overlay/frameworks/base/core/res/res -I out/target/common/obj/APPS/framework-res_intermediates/package-export.apk -I out/target/common/obj/APPS/framework-res_intermediates/package-export.apk -G out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/proguard_options --min-sdk-version 26 --target-sdk-version 26 --version-code 26 --version-name 8.0.0 --skip-symbols-without-default-localization ) && (for GENERATED_MANIFEST_FILE in \`find out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src -name Manifest.java 2> /dev/null\`; do dir=\`awk '/package/{gsub(/\\./,\"/\",\$2);gsub(/;/,\"\",\$2);print \$2;exit}' \$GENERATED_MANIFEST_FILE\`; mkdir -p out/target/common/R/\$dir; prebuilts/build-tools/linux-x86/bin/acp -fp \$GENERATED_MANIFEST_FILE out/target/common/R/\$dir; done ) && (for GENERATED_R_FILE in \`find out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src -name R.java 2> /dev/null\`; do dir=\`awk '/package/{gsub(/\\./,\"/\",\$2);gsub(/;/,\"\",\$2);print \$2;exit}' \$GENERATED_R_FILE\`; mkdir -p out/target/common/R/\$dir; prebuilts/build-tools/linux-x86/bin/acp -fp \$GENERATED_R_FILE out/target/common/R/\$dir || exit 31; prebuilts/build-tools/linux-x86/bin/acp -fp \$GENERATED_R_FILE out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src/R.stamp || exit 32; done ) && (touch out/target/common/obj/APPS/framework-res__auto_generated_rro_intermediates/src/R.stamp )"
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:21: error: Error retrieving parent for item: No resource found that matches the given name 'TextAppearance'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:22: error: Error: No resource found that matches the given name: attr 'fontFamily'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:23: error: Error: No resource found that matches the given name: attr 'textSize'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:30: error: Error retrieving parent for item: No resource found that matches the given name 'Animation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:34: error: Error: No resource found that matches the given name: attr 'activityCloseEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:35: error: Error: No resource found that matches the given name: attr 'activityCloseExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:31: error: Error: No resource found that matches the given name: attr 'activityOpenEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:32: error: Error: No resource found that matches the given name: attr 'activityOpenExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:65: error: Error: No resource found that matches the given name: attr 'fragmentCloseEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:66: error: Error: No resource found that matches the given name: attr 'fragmentCloseExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:67: error: Error: No resource found that matches the given name: attr 'fragmentFadeEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:68: error: Error: No resource found that matches the given name: attr 'fragmentFadeExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:63: error: Error: No resource found that matches the given name: attr 'fragmentOpenEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:64: error: Error: No resource found that matches the given name: attr 'fragmentOpenExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:41: error: Error: No resource found that matches the given name: attr 'launchTaskBehindSourceAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:40: error: Error: No resource found that matches the given name: attr 'launchTaskBehindTargetAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:43: error: Error: No resource found that matches the given name: attr 'taskCloseEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:44: error: Error: No resource found that matches the given name: attr 'taskCloseExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:37: error: Error: No resource found that matches the given name: attr 'taskOpenEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:38: error: Error: No resource found that matches the given name: attr 'taskOpenExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:49: error: Error: No resource found that matches the given name: attr 'taskToBackEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:50: error: Error: No resource found that matches the given name: attr 'taskToBackExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:46: error: Error: No resource found that matches the given name: attr 'taskToFrontEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:47: error: Error: No resource found that matches the given name: attr 'taskToFrontExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:55: error: Error: No resource found that matches the given name: attr 'wallpaperCloseEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:56: error: Error: No resource found that matches the given name: attr 'wallpaperCloseExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:60: error: Error: No resource found that matches the given name: attr 'wallpaperIntraCloseEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:61: error: Error: No resource found that matches the given name: attr 'wallpaperIntraCloseExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:58: error: Error: No resource found that matches the given name: attr 'wallpaperIntraOpenEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:59: error: Error: No resource found that matches the given name: attr 'wallpaperIntraOpenExitAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:52: error: Error: No resource found that matches the given name: attr 'wallpaperOpenEnterAnimation'.
packages/services/Car/car_product/overlay/frameworks/base/core/res/res/values/styles.xml:53: error: Error: No resource found that matches the given name: attr 'wallpaperOpenExitAnimation'.
[ 0% 8/14555] Ensuring Jack server is installed and started
Jack server already installed in "/home/itdtpadmin/.jack-server"
Server is already running
[ 0% 9/14555] target R.java/Manifest.java: CarDialerApp (out/target/common/obj/APPS/CarDialerApp_intermediates/src/R.stamp)
ninja: build stopped: subcommand failed.
15:47:50 ninja failed with: exit status 1
build/core/main.mk:21: recipe for target 'run_soong_ui' failed
make: *** [run_soong_ui] Error 1
Can you please help me out to overcome the above error.
Note: I got the android file system source from processors.wiki.ti.com/.../6AO.1.0_Release_Notes
Shareen.
