Part Number: AM5728
Other Parts Discussed in Thread: XIO2001
Tool/software: Linux
hi Rex,
after giving the command lspci -v in the terminal
we got the following in the terminal
0000:00:00.0 PCI bridge: Texas Instruments Device 8888 (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 461
Memory at 20100000 (32-bit, non-prefetchable) [size=1M]
Memory at 20020000 (32-bit, non-prefetchable) [size=64K]
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 20200000-202fffff
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: pcieport
0000:01:00.0 PCI bridge: Texas Instruments XIO2001 PCI Express-to-PCI Bridge (prog-if 00 [Normal decode])
Bus: primary=01, secondary=02, subordinate=02, sec-latency=0
Capabilities: [40] Subsystem: Device 0000:0000
Capabilities: [48] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/16 Maskable- 64bit+
Capabilities: [70] Express PCI-Express to PCI/PCI-X Bridge, MSI 00
0000:02:00.0 Communication controller: ILC Data Device Corp Device 1a00 (rev 10)
Subsystem: ILC Data Device Corp Device 1a00
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 461
Memory at 20200000 (32-bit, non-prefetchable) [size=256K]
Memory at 20240000 (32-bit, non-prefetchable) [size=4K]
0001:00:00.0 PCI bridge: Texas Instruments Device 8888 (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 462
Memory at 30100000 (32-bit, non-prefetchable) [size=1M]
Memory at 30020000 (32-bit, non-prefetchable) [size=64K]
Memory behind bridge: 30200000-302fffff
0001:01:00.0 PCI bridge: Texas Instruments XIO2001 PCI Express-to-PCI Bridge (prog-if 00 [Normal decode])
0001:02:00.0 Communication controller: ILC Data Device Corp Device 1a00 (rev 10)
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 494
Memory at 30200000 (32-bit, non-prefetchable) [size=256K]
Memory at 30240000 (32-bit, non-prefetchable) [size=4K]
root@am57xx-evm:~#
we were unable to do memory mapping of our ep and the pcie
when we checked the boot log we found the following
dra7_pcie 51000000.pcie_ep:pm_runtime_get_sync failed
dra7-pcie: probe of 5100000.pcie_ep failed with eroor -22
Kumari
