Other Parts Discussed in Thread: DA8XX
Tool/software: Linux
Booting with HDMI monitor connected hangs the boot process. This is independent on the state of the SW13 and SW14 switches (either both on or both off). I include below the boot log. I have LCD panel installed (in case it matters).
I am using the latest k2g-evm-linux-05.02.00.10.img.
On software-dl.ti.com/.../Foundational_Components_Graphics.html I have found that modetest can be used to test the display driver.
WhenI boot without HDMI monitor connected and execute modetest I obtain:
id encoder status name size (mm) modes encoders
35 0 disconnected HDMI-A-1 0x0 0 34
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
Then I connect HDMI monitor and run modetest again:
35 0 connected HDMI-A-1 530x300 8 34
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1280x720 60 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver
1280x720 60 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver
1280x720 50 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type: driver
1024x768 70 1024 1048 1184 1328 768 771 777 806 75000 flags: nhsync, nvsync; type: driver
1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
832x624 75 832 864 928 1152 624 625 628 667 57284 flags: nhsync, nvsync; type: driver
800x600 75 800 816 896 1056 600 601 604 625 49500 flags: phsync, pvsync; type: driver
800x600 72 800 856 976 1040 600 637 643 666 50000 flags: phsync, pvsync; type: driver
props:
1 EDID:
blobs:
value:
00ffffffffffff004c2d920d31515a5a
181b010380351e782a9ff5a555509e26
105054bfef80714f81c0810081809500
a9c0b3000101023a801871382d40582c
4500132b2100001e011d007251d01e20
6e285500132b2100001e000000fd0032
4b1e5111000a202020202020000000fc
00533234443333300a202020202001cd
020311b14690041f13031265030c0010
00011d00bc52d01e20b8285540132b21
00001e8c0ad090204031200c40550013
2b210000188c0ad08a20e02d10103e96
00132b21000018000000000000000000
00000000000000000000000000000000
00000000000000000000000000000021
2 DPMS:
flags: enum
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
Then I run modetest again and the system hangs.
The courious thing is that I obtain the same results independently on the state of the SW13 and SW14 switches (that theoretically choose between onboard LCD and HDMI)
Thank you and best regards
Adam
---- boot log ---
U-Boot 2018.01-g313dcd69c2 (Dec 16 2018 - 07:15:30 +0000)
CPU: 66AK2Gx-60 SR1.0
Model: Texas Instruments K2G General Purpose EVM
DRAM:
Clear entire DDR3 memory to enable ECC
2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net: eth0: netcp@4000000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
** Unable to read file uEnv.txt **
32832 bytes read in 13 ms (2.4 MiB/s)
K2_BM_15.07-53-ge1f885a SoC:k2g built:05:44:19, Dec 16 2018
## installed monitor @ 0xc0f7000, freq [24000000], status 202338304
33620 bytes read in 19 ms (1.7 MiB/s)
0 - Name:'pmmc@2900000' type:'internal memory mapped' supports: load start
Load Remote Processor 0 with data@addr=0x82000000 33620 bytes: Success!
3916288 bytes read in 204 ms (18.3 MiB/s)
34793 bytes read in 18 ms (1.8 MiB/s)
29386 bytes read in 11 ms (2.5 MiB/s)
Loading Ramdisk to 8fff7000, end 8ffff7e9 ... OK
Loading Device Tree to 8ffec000, end 8fff62c9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-gbde58ab01e (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Thu Dec 20 03:57:44 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Texas Instruments K2G General Purpose EVM
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Switching physical address space to 0x800000000
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp-common-memory@81f800000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 48 MiB at 0x000000087cc00000
[ 0.000000] percpu: Embedded 15 pages/cpu @eedce000 s31308 r8192 d21940 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 491840
[ 0.000000] Kernel command line: console=ttyS0,115200n8 video=HDMI-A-1:1024x768 root=PARTUUID=7408e099-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1883588K/1974272K available (8192K kernel code, 289K rwdata, 2544K rodata, 2048K init, 280K bss, 33340K reserved, 57344K cma-reserved, 1261568K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1048678 ( 290 kB)
[ 0.000000] .bss : 0xc104a000 - 0xc1090320 ( 281 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000027] Switching to timer-based delay loop, resolution 41ns
[ 0.000219] keystone_timer_init: failed to get clock
[ 0.000247] Failed to initialize '/soc/timer@2210000': -517
[ 0.000645] Console: colour dummy device 80x30
[ 0.000696] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000722] pid_max: default: 32768 minimum: 301
[ 0.000897] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000919] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001791] CPU: Testing write buffer coherency: ok
[ 0.001846] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[ 0.002169] /cpus/cpu@0 missing clock-frequency property
[ 0.002191] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.040006] Setting up static identity map for 0x80200000 - 0x80200138
[ 0.060016] Hierarchical SRCU implementation.
[ 0.080323] EFI services will not be available.
[ 0.100110] smp: Bringing up secondary CPUs ...
[ 0.100128] smp: Brought up 1 node, 1 CPU
[ 0.100144] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.100158] CPU: All CPU(s) started in HYP mode.
[ 0.100169] CPU: Virtualization extensions available.
[ 0.100993] devtmpfs: initialized
[ 0.110393] random: get_random_u32 called from bucket_table_alloc+0x104/0x22c with crng_init=0
[ 0.120343] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.120689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.120717] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.122731] pinctrl core: initialized pinctrl subsystem
[ 0.123486] DMI not present or invalid.
[ 0.123894] NET: Registered protocol family 16
[ 0.131650] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.132949] cpuidle: using governor ladder
[ 0.133004] cpuidle: using governor menu
[ 0.133551] No ATAGs?
[ 0.133618] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.133638] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.141419] davinci_gpio 2603000.gpio: Error -517 getting gpio clock
[ 0.143191] davinci_gpio 260a000.gpio: Error -517 getting gpio clock
[ 0.196924] i2c_davinci 2530000.i2c: could not find pctldev for node /soc/pinmux@02621000/pinmux_i2c0_pins, deferring probe
[ 0.196994] i2c_davinci 2530400.i2c: could not find pctldev for node /soc/pinmux@02621000/pinmux_i2c1_pins, deferring probe
[ 0.197304] media: Linux media interface: v0.10
[ 0.197370] Linux video capture interface: v2.00
[ 0.197500] pps_core: LinuxPPS API ver. 1 registered
[ 0.197515] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.197545] PTP clock support registered
[ 0.197574] EDAC MC: Ver: 3.0.0
[ 0.198092] dmi: Firmware registration failed.
[ 0.198305] Advanced Linux Sound Architecture Driver Initialized.
[ 0.200771] clocksource: Switched to clocksource arch_sys_counter
[ 0.212235] NET: Registered protocol family 2
[ 0.213057] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.213164] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.213374] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.213492] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.213547] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.213762] NET: Registered protocol family 1
[ 0.250927] RPC: Registered named UNIX socket transport module.
[ 0.250947] RPC: Registered udp transport module.
[ 0.250962] RPC: Registered tcp transport module.
[ 0.250975] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.251297] Trying to unpack rootfs image as initramfs...
[ 0.255250] Freeing initrd memory: 36K
[ 0.255646] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.255897] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.257140] platform alarmtimer: set dma_pfn_offset00780000
[ 0.258266] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.265634] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.281347] NFS: Registering the id_resolver key type
[ 0.281393] Key type id_resolver registered
[ 0.281410] Key type id_legacy registered
[ 0.281475] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.284408] bounce: pool size: 64 pages
[ 0.284491] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.284512] io scheduler noop registered
[ 0.284527] io scheduler deadline registered
[ 0.284704] io scheduler cfq registered (default)
[ 0.284722] io scheduler mq-deadline registered
[ 0.284736] io scheduler kyber registered
[ 0.285206] keystone_irq soc:keystone_irq@026202a0: irqchip registered, nr_irqs 28
[ 0.287077] pinctrl-single 2621000.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.287691] pinctrl-single 2621000.pinmux: 260 pins at pa f0854000 size 1040
[ 0.385154] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.385281] platform serial8250: set dma_pfn_offset00780000
[ 0.393764] connector-hdmi connector: failed to find video source
[ 0.409664] brd: module loaded
[ 0.419266] loop: module loaded
[ 0.424098] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
[ 0.424437] libphy: Fixed MDIO Bus: probed
[ 0.427450] i2c /dev entries driver
[ 0.428257] IR NEC protocol handler initialized
[ 0.428274] IR RC5(x/sz) protocol handler initialized
[ 0.428288] IR RC6 protocol handler initialized
[ 0.428301] IR JVC protocol handler initialized
[ 0.428313] IR Sony protocol handler initialized
[ 0.428325] IR SANYO protocol handler initialized
[ 0.428339] IR Sharp protocol handler initialized
[ 0.428351] IR MCE Keyboard/mouse protocol handler initialized
[ 0.428363] IR XMP protocol handler initialized
[ 0.430724] sdhci: Secure Digital Host Controller Interface driver
[ 0.430737] sdhci: Copyright(c) Pierre Ossman
[ 0.431464] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.433472] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.436472] platform snd-soc-dummy: set dma_pfn_offset00780000
[ 0.438679] NET: Registered protocol family 10
[ 0.451285] Segment Routing with IPv6
[ 0.451400] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.452196] NET: Registered protocol family 17
[ 0.452506] Key type dns_resolver registered
[ 0.452745] Registering SWP/SWPB emulation handler
[ 0.455734] davinci_gpio 2603000.gpio: Error -517 getting gpio clock
[ 0.457259] davinci_gpio 260a000.gpio: Error -517 getting gpio clock
[ 0.465773] connector-hdmi connector: failed to find video source
[ 0.470692] ti-sci 2921c00.pmmc: ABI: 2.4 (firmware rev 0x0011 '0.1.1-50-g129ef (Eagle)')
[ 0.484542] random: fast init done
[ 0.544359] ti-sci-clk 2921c00.pmmc:clocks: get-parent failed for dev=76, clk=11, ret=-19
[ 0.544553] ti-sci-clk 2921c00.pmmc:clocks: get-parent failed for dev=76, clk=11, ret=-19
[ 0.544917] ti-sci-clk 2921c00.pmmc:clocks: get-parent failed for dev=76, clk=11, ret=-19
[ 0.554496] keystone timer clock @100000000 Hz
[ 0.574224] edma 2700000.edma: TI EDMA DMA engine driver
[ 0.574994] edma 2728000.edma: memcpy is disabled
[ 0.580538] edma 2728000.edma: TI EDMA DMA engine driver
[ 0.583708] sii9022 1-003b: failed to find video source
[ 0.585078] ti,keystone-serdes 2320000.phy: init fw ks2_pcie_serdes.bin: version 3.3.0.2c
[ 0.587224] OF: PCI: host bridge /soc/pcie@21800000 ranges:
[ 0.587250] OF: PCI: No bus range found for /soc/pcie@21800000, using [bus 00-ff]
[ 0.587297] OF: PCI: IO 0x23250000..0x23253fff -> 0x00000000
[ 0.587338] OF: PCI: MEM 0x70000000..0x7fffffff -> 0x70000000
[ 1.588969] keystone-pcie 21800000.pcie: phy link never came up
[ 1.589202] keystone-pcie 21800000.pcie: PCI host bridge to bus 0000:00
[ 1.589226] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.589245] pci_bus 0000:00: root bus resource [io 0x0000-0x3fff]
[ 1.589263] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fffffff]
[ 1.589709] PCI: bus0: Fast back to back transfers disabled
[ 1.589857] PCI: bus1: Fast back to back transfers enabled
[ 1.589910] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.590210] pcieport 0000:00:00.0: limiting MRRS to 256
[ 1.590539] pcieport 0000:00:00.0: Signaling PME with IRQ 320
[ 1.590856] pcieport 0000:00:00.0: AER enabled with IRQ 320
[ 1.591496] keystone-navigator-qmss soc:qmss@4020000: qmgr start queue 0, number of queues 128
[ 1.591686] keystone-navigator-qmss soc:qmss@4020000: added qmgr start queue 0, num of queues 128, reg_peek f0e77000, reg_status (null), reg_config f0e79000, reg_region f0e7b000, reg_push f0e7d000, reg_pop f0e7d000
[ 1.593299] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 53 logical channels, flows 32, tx chans: 21, rx chans: 32
[ 1.595029] console [ttyS0] disabled
[ 1.595091] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 23, base_baud = 12000000) is a TI DA8xx/66AK2x
[ 2.687505] console [ttyS0] enabled
[ 2.693097] 2531400.serial: ttyS2 at MMIO 0x2531400 (irq = 24, base_baud = 12000000) is a TI DA8xx/66AK2x
[ 2.703883] omap_dss6 2540000.dss: bound 2550000.dispc (ops dispc6_component_ops)
[ 2.711541] platform omapdrm.0: set dma_pfn_offset00780000
[ 2.717766] connector-hdmi connector: failed to find video source
[ 2.725745] cadence-qspi 2940000.qspi: non-uniform erase sector maps are not supported yet.
[ 2.734163] cadence-qspi 2940000.qspi: s25fl512s (65536 Kbytes)
[ 2.740168] 6 ofpart partitions found on MTD device 2940000.qspi.0
[ 2.746372] Creating 6 MTD partitions on "2940000.qspi.0":
[ 2.751880] 0x000000000000-0x000000100000 : "QSPI.u-boot-spl-os"
[ 2.759135] 0x000000100000-0x000000140000 : "QSPI.u-boot-env"
[ 2.766011] 0x000000140000-0x000000180000 : "QSPI.skern"
[ 2.772440] 0x000000180000-0x0000001c0000 : "QSPI.pmmc-firmware"
[ 2.779495] 0x0000001c0000-0x0000009c0000 : "QSPI.kernel"
[ 2.786004] 0x0000009c0000-0x000004000000 : "QSPI.file-system"
[ 2.794216] spi_davinci 21805400.spi: DMA is not supported (-19)
[ 2.800715] spi_davinci 21805400.spi: Controller at 0xf0e99400
[ 2.807764] spi_davinci 21805800.spi: DMA is not supported (-19)
[ 2.815666] m25p80 spi1.0: n25q128a13 (16384 Kbytes)
[ 2.820672] 2 ofpart partitions found on MTD device spi1.0
[ 2.826210] Creating 2 MTD partitions on "spi1.0":
[ 2.831032] 0x000000000000-0x000000100000 : "u-boot-spl"
[ 2.837597] 0x000000100000-0x000001000000 : "misc"
[ 2.843577] spi_davinci 21805800.spi: Controller at 0xf0e9b800
[ 2.850541] spi_davinci 21805c00.spi: DMA is not supported (-19)
[ 2.857069] spi_davinci 21805c00.spi: Controller at 0xf0e9dc00
[ 2.863998] spi_davinci 21806000.spi: DMA is not supported (-19)
[ 2.870453] spi_davinci 21806000.spi: Controller at 0xf0e9f000
[ 2.930815] davinci_mdio 4200f00.mdio: davinci mdio revision 1.7, bus freq 2500000
[ 2.938381] libphy: 4200f00.mdio: probed
[ 2.943428] davinci_mdio 4200f00.mdio: phy[0]: device 4200f00.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[ 2.953899] netcp-1.0 2620110.netcp: ALE enabled
[ 2.958722] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.4
[ 2.965263] netcp-1.0 2620110.netcp: ALE Table size 64
[ 2.970510] netcp-1.0 2620110.netcp: cpts: overflow check period 500 (jiffies)
[ 2.977830] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 2.989528] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
[ 2.997519] sdhci-omap 23000000.mmc: Got CD GPIO
[ 3.061043] mmc0: SDHCI controller on 23000000.mmc [23000000.mmc] using ADMA
[ 3.119073] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.129997] mmc0: new high speed SDHC card at address 0007
[ 3.136017] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[ 3.140871] mmc1: SDHCI controller on 23100000.mmc [23100000.mmc] using ADMA
[ 3.151413] mmcblk0: p1 p2
[ 3.157523] sii9022 1-003b: SiI902xA HDMI device b0, rev 2, tpi 3
[ 3.167218] omapdrm omapdrm.0: DMM not available, disable DMM support
[ 3.177481] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.184187] [drm] No driver support for vblank timestamp query.
