RTOS/AM5728: Run NIMU Basic example on DSP1
Part Number: AM5728
Other Parts Discussed in Thread: BEAGLEBOARD-X15, , PMP, DRA752, TMP102
Tool/software: TI-RTOS
I'm trying to run the NIMU_BasicExample_evmAM572x_c66xExampleProject on the ti evm-am572x board. I could successfully run the EMAC_BasicExample_evmAM572x_c66xExampleProject so the setup seems to be fine and also the Ethernet driver, but I can't get the NIMU example to work.
I use:
RTOS / Linux SDK version 05.02.00.10
CCS 8.3.0
As Linux Image I have the one furnished with the board
The Log after loading the application on the dsp is:
root@am57xx-evm:~#
root@am57xx-evm:~#
root@am57xx-evm:~# --------------------------------------------------------------------------------------
 SetPhyMode:000021e1 Auto:1, FD10:64, HD10:32, FD100:256, HD100:128, FD1000:8192 LPBK:0
  SYS/BIOS Ethernet/IP (CPSW) Sample application, EVM IP address I/F 1: 192.168.1.4
   RX |     Good:       0 |   Bcast:       0 |    Mcast:       0 |    Oct:           0 |
  All tests have passed.
  RX |    Pause:       0 |     CRC:       0 | AlignErr:       0 | Oversz:           0 |
  RX |   Jabber:       0 | Undersz:       0 |     Frag:       0 |   Filt:           0 |
  RX |      QoS:       0 |  SOFOvr:       0 |   MOFOvr:       0 | DMAOvr:           0 |
  TX |     Good:       0 |   Bcast:       0 |    Mcast:       0 |    Oct:           0 |
  TX |    Pause:       0 | Deferred:      0 |     Coll:       0 |   Udrn:           0 |
 ENETPHY_FindingState: PhyNum: 1
 ENETPHY_FindingState: PhyNum: 2
 ENETPHY_DisablePhy(1)
 Enable Phy to negotiate external connection
 NWAY Advertising: FullDuplex-1000 FullDuplex-100 HalfDuplex-100 FullDuplex-10 HalfDuplex-10
 ENETPHY_DisablePhy(2)
 [  142.528437] omap_i2c 48070000.i2c: controller timed out
[  142.548383] palmas-gpio 48070000.i2c:tps659038@58:tps659038_gpio: Reg 0x01 read failed, -110
 Negotiated connection: FullDuplex 1000 Mbs
  RX |     Good:       1 |   Bcast:       1 |    Mcast:       0 |    Oct:          64 |
  TX |     Good:       1 |   Bcast:       1 |    Mcast:       0 |    Oct:          64 |
 [  280.661957] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[  280.670137] pgd = d564ab40
[  280.672856] [00000004] *pgd=94ceb003, *pmd=94ce7003, *pte=00000000
[  280.679288] Internal error: Oops: a07 [#1] PREEMPT SMP ARM
[  280.684798] Modules linked in: bluetooth ipv6 gdbserverproxy(O) cryptodev(O) cmemk(O) xhci_plat_hcd xhci_hcd usbcore dwc3 rpmsg_rpc ahci_platform virtio_rpmsg_bus evdev libahci_platform libahci udc_core ti_vip mt9t11x omapdrm_pvr(O) snd_soc_tlv320aic3x gpio_keys libata st_drv extcon_palmas rtc_palmas snd_soc_simple_card snd_soc_omap_hdmi_audio leds_gpio palmas_pwrbutton pixcir_i2c_ts rtc_ds1307 omap_wdt phy_omap_usb2 ti_vpe ti_vpdma dwc3_omap rtc_omap omap_rng rng_core debugss_kmodule(O) omap_remoteproc remoteproc extcon_usb_gpio virtio extcon virtio_ring
[  280.734545] CPU: 1 PID: 1207 Comm: default.script Tainted: G           O    4.1.13-g8dc6617 #1
[  280.743192] Hardware name: Generic DRA74X (Flattened Device Tree)
[  280.749311] task: eccb9900 ti: ece46000 task.ti: ece46000
[  280.754737] PC is at __module_get+0x28/0x70
[  280.758938] LR is at set_binfmt+0x4c/0x50
[  280.762964] pc : [<c00a0644>]    lr : [<c0123af8>]    psr: a0070013
[  280.762964] sp : ece47da0  ip : ece47db8  fp : ece47db4
[  280.774490] r10: b6f1ea01  r9 : ec5d2480  r8 : ed508e00
[  280.779736] r7 : ece47db8  r6 : 00000000  r5 : edbec1c0  r4 : c08e1e04
[  280.786289] r3 : 00000000  r2 : 00000002  r1 : c08c9314  r0 : 00000000
[  280.792843] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  280.800011] Control: 30c5387d  Table: 9564ab40  DAC: 55555555
[  280.805779] Process default.script (pid: 1207, stack limit = 0xece46218)
[  280.812506] Stack: (0xece47da0 to 0xece48000)
[  280.816882] 7da0: ecea5c00 ec490d00 ece47e3c ece47db8 c0168da4 c0123ab8 00000812 00000000
[  280.825094] 7dc0: 00000000 00000080 ec490d00 b6f1e000 00000006 00000001 00010000 000cacd0
[  280.833307] 7de0: 000c63c4 000b63c4 00010000 00000000 b6f46960 b6f1e000 ec5d29c0 d564a480
[  280.841518] 7e00: c08e190c 00000001 fffffff8 00000000 ece47e3c c08e1e04 ec490d00 c08e190c
[  280.849729] 7e20: 00000001 fffffff8 00000000 edbec1c0 ece47e64 ece47e40 c012435c c0168488
[  280.857940] 7e40: ec490d00 ec490d00 c08e190c 00000001 fffffff8 00000000 ece47f04 ece47e68
[  280.866152] 7e60: c0166d08 c01242d4 00000000 ec490d02 6e69622f 0068732f c00f479c c0636e2c
[  280.874364] 7e80: ef5e121c 00000021 00000000 beffff06 ef5e121c 0009fb6c ece47ec4 ece47ea8
[  280.882576] 7ea0: c00f4828 c0636dd4 00000000 00000021 00000000 beffff06 ece47ed4 ece47ec8
[  280.890787] 7ec0: 00000000 00000021 ece47f2c ece47ed8 c0123358 c00dec40 ec490d00 c08e1d68
[  280.898999] 7ee0: ec490d00 c08e190c 00000001 fffffffe c08e1de8 c08e1de8 ece47f2c ece47f08
[  280.907211] 7f00: c012435c c0166ac8 eccb9900 ee053000 000004b7 000bf030 ec490d00 00000000
[  280.915423] 7f20: ece47f74 ece47f30 c0124c68 c01242d4 c08ca814 c0914e18 00000000 edba53c0
[  280.923635] 7f40: 00000000 eccb9b80 c012c640 be9af8a0 000bf030 00000000 0000000b c000fb04
[  280.931847] 7f60: ece46000 00000000 ece47f8c ece47f78 c0124d78 c0124764 00000000 c012c604
[  280.940058] 7f80: ece47fa4 ece47f90 c0124fd8 c0124d58 be9af8a0 000bf030 00000000 ece47fa8
[  280.948269] 7fa0: c000f960 c0124fc0 be9af8a0 000bf030 0009fb6c be9af8a0 000bf030 0000000b
[  280.956480] 7fc0: be9af8a0 000bf030 00000000 0000000b 0009fb6c 000bc838 00000000 0009fc28
[  280.964692] 7fe0: 0000000b be9af824 b6e672a3 b6e0b5f6 20070030 0009fb6c 5f5f656c 67676f6c
[  280.972900] Backtrace:
[  280.975368] [<c0123aac>] (set_binfmt) from [<c0168da4>] (load_elf_binary+0x928/0x1154)
[  280.983316]  r5:ec490d00 r4:ecea5c00
[  280.986924] [<c016847c>] (load_elf_binary) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  280.995656]  r10:edbec1c0 r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ec490d00
[  281.003556]  r4:c08e1e04
[  281.006109] [<c01242c8>] (search_binary_handler) from [<c0166d08>] (load_script+0x24c/0x264)
[  281.014581]  r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ec490d00 r4:ec490d00
[  281.022399] [<c0166abc>] (load_script) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  281.030782]  r4:c08e1de8
[  281.033335] [<c01242c8>] (search_binary_handler) from [<c0124c68>] (do_execveat_common+0x510/0x5f4)
[  281.042416]  r9:00000000 r8:ec490d00 r7:000bf030 r6:000004b7 r5:ee053000 r4:eccb9900
[  281.050237] [<c0124758>] (do_execveat_common) from [<c0124d78>] (do_execve+0x2c/0x34)
[  281.058098]  r10:00000000 r9:ece46000 r8:c000fb04 r7:0000000b r6:00000000 r5:000bf030
[  281.065998]  r4:be9af8a0
[  281.068550] [<c0124d4c>] (do_execve) from [<c0124fd8>] (SyS_execve+0x24/0x28)
[  281.075721] [<c0124fb4>] (SyS_execve) from [<c000f960>] (ret_fast_syscall+0x0/0x3c)
[  281.083406]  r5:000bf030 r4:be9af8a0
[  281.087012] Code: 00000000 00000000 a89c37fb e2822001 (e5832004)
[  281.093252] ---[ end trace b94dce3495cb29fb ]---
[  310.271948] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[  310.280167] pgd = d4cbe680
[  310.282891] [00000004] *pgd=94ce7003, *pmd=94ca0003, *pte=00000000
[  310.289382] Internal error: Oops: a07 [#2] PREEMPT SMP ARM
[  310.294890] Modules linked in: bluetooth ipv6 gdbserverproxy(O) cryptodev(O) cmemk(O) xhci_plat_hcd xhci_hcd usbcore dwc3 rpmsg_rpc ahci_platform virtio_rpmsg_bus evdev libahci_platform libahci udc_core ti_vip mt9t11x omapdrm_pvr(O) snd_soc_tlv320aic3x gpio_keys libata st_drv extcon_palmas rtc_palmas snd_soc_simple_card snd_soc_omap_hdmi_audio leds_gpio palmas_pwrbutton pixcir_i2c_ts rtc_ds1307 omap_wdt phy_omap_usb2 ti_vpe ti_vpdma dwc3_omap rtc_omap omap_rng rng_core debugss_kmodule(O) omap_remoteproc remoteproc extcon_usb_gpio virtio extcon virtio_ring
[  310.344623] CPU: 0 PID: 1209 Comm: default.script Tainted: G      D    O    4.1.13-g8dc6617 #1
[  310.353270] Hardware name: Generic DRA74X (Flattened Device Tree)
[  310.359388] task: ed562300 ti: ee0be000 task.ti: ee0be000
[  310.364814] PC is at __module_get+0x28/0x70
[  310.369015] LR is at set_binfmt+0x4c/0x50
[  310.373040] pc : [<c00a0644>]    lr : [<c0123af8>]    psr: a0070013
[  310.373040] sp : ee0bfda0  ip : ee0bfdb8  fp : ee0bfdb4
[  310.384566] r10: b6fb6a01  r9 : ed4d7480  r8 : ec490300
[  310.389811] r7 : ee0bfdb8  r6 : 00000000  r5 : d5567180  r4 : c08e1e04
[  310.396364] r3 : 00000000  r2 : 00000002  r1 : c08c9314  r0 : 00000000
[  310.402919] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  310.410083] Control: 30c5387d  Table: 94cbe680  DAC: fffffffd
[  310.415851] Process default.script (pid: 1209, stack limit = 0xee0be218)
[  310.422579] Stack: (0xee0bfda0 to 0xee0c0000)
[  310.426954] fda0: ecea0d00 ed508000 ee0bfe3c ee0bfdb8 c0168da4 c0123ab8 00000812 00000000
[  310.435166] fdc0: 00000000 00000080 ed508000 b6fb6000 00000006 00000001 00010000 000cacd0
[  310.443379] fde0: 000c63c4 000b63c4 00010000 00000000 b6fde960 b6fb6000 ed4d79c0 d4cbe040
[  310.451591] fe00: c08e190c 00000001 fffffff8 00000000 ee0bfe3c c08e1e04 ed508000 c08e190c
[  310.459802] fe20: 00000001 fffffff8 00000000 d5567180 ee0bfe64 ee0bfe40 c012435c c0168488
[  310.468014] fe40: ed508000 ed508000 c08e190c 00000001 fffffff8 00000000 ee0bff04 ee0bfe68
[  310.476225] fe60: c0166d08 c01242d4 00000000 ed508002 6e69622f 0068732f c00f479c c0636e2c
[  310.484437] fe80: ef5e11d4 00000021 00000000 beffff06 ef5e11d4 0009fb6c ee0bfec4 ee0bfea8
[  310.492649] fea0: c00f4828 c0636dd4 00000000 00000021 00000000 beffff06 ee0bfed4 ee0bfec8
[  310.500861] fec0: 00000000 00000021 ee0bff2c ee0bfed8 c0123358 c00dec40 ed508000 c08e1d68
[  310.509073] fee0: ed508000 c08e190c 00000001 fffffffe c08e1de8 c08e1de8 ee0bff2c ee0bff08
[  310.517285] ff00: c012435c c0166ac8 ed562300 edbf7000 000004b9 000bf030 ed508000 00000000
[  310.525496] ff20: ee0bff74 ee0bff30 c0124c68 c01242d4 c08ca814 c0914e18 00000000 eceb0ba0
[  310.533708] ff40: 00000000 ed562580 c012c640 be9af8a0 000bf030 00000000 0000000b c000fb04
[  310.541919] ff60: ee0be000 00000000 ee0bff8c ee0bff78 c0124d78 c0124764 00000000 c012c604
[  310.550130] ff80: ee0bffa4 ee0bff90 c0124fd8 c0124d58 be9af8a0 000bf030 00000000 ee0bffa8
[  310.558342] ffa0: c000f960 c0124fc0 be9af8a0 000bf030 0009fb6c be9af8a0 000bf030 0000000b
[  310.566553] ffc0: be9af8a0 000bf030 00000000 0000000b 0009fb6c 000bc838 00000000 0009fc28
[  310.574765] ffe0: 0000000b be9af824 b6e672a3 b6e0b5f6 20070030 0009fb6c ffffffff 00000000
[  310.582973] Backtrace:
[  310.585442] [<c0123aac>] (set_binfmt) from [<c0168da4>] (load_elf_binary+0x928/0x1154)
[  310.593390]  r5:ed508000 r4:ecea0d00
[  310.597000] [<c016847c>] (load_elf_binary) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  310.605733]  r10:d5567180 r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ed508000
[  310.613635]  r4:c08e1e04
[  310.616187] [<c01242c8>] (search_binary_handler) from [<c0166d08>] (load_script+0x24c/0x264)
[  310.624658]  r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ed508000 r4:ed508000
[  310.632477] [<c0166abc>] (load_script) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  310.640861]  r4:c08e1de8
[  310.643413] [<c01242c8>] (search_binary_handler) from [<c0124c68>] (do_execveat_common+0x510/0x5f4)
[  310.652495]  r9:00000000 r8:ed508000 r7:000bf030 r6:000004b9 r5:edbf7000 r4:ed562300
[  310.660314] [<c0124758>] (do_execveat_common) from [<c0124d78>] (do_execve+0x2c/0x34)
[  310.668174]  r10:00000000 r9:ee0be000 r8:c000fb04 r7:0000000b r6:00000000 r5:000bf030
[  310.676074]  r4:be9af8a0
[  310.678625] [<c0124d4c>] (do_execve) from [<c0124fd8>] (SyS_execve+0x24/0x28)
[  310.685795] [<c0124fb4>] (SyS_execve) from [<c000f960>] (ret_fast_syscall+0x0/0x3c)
[  310.693481]  r5:000bf030 r4:be9af8a0
[  310.697087] Code: 00000000 00000000 a89c37fb e2822001 (e5832004)
[  310.703775] ---[ end trace b94dce3495cb29fc ]---
[  339.891943] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[  339.900194] pgd = d4cbe7c0
[  339.902926] [00000004] *pgd=94cec003, *pmd=94ce7003, *pte=00000000
[  339.909222] Internal error: Oops: a07 [#3] PREEMPT SMP ARM
[  339.914730] Modules linked in: bluetooth ipv6 gdbserverproxy(O) cryptodev(O) cmemk(O) xhci_plat_hcd xhci_hcd usbcore dwc3 rpmsg_rpc ahci_platform virtio_rpmsg_bus evdev libahci_platform libahci udc_core ti_vip mt9t11x omapdrm_pvr(O) snd_soc_tlv320aic3x gpio_keys libata st_drv extcon_palmas rtc_palmas snd_soc_simple_card snd_soc_omap_hdmi_audio leds_gpio palmas_pwrbutton pixcir_i2c_ts rtc_ds1307 omap_wdt phy_omap_usb2 ti_vpe ti_vpdma dwc3_omap rtc_omap omap_rng rng_core debugss_kmodule(O) omap_remoteproc remoteproc extcon_usb_gpio virtio extcon virtio_ring
[  339.964474] CPU: 0 PID: 1210 Comm: default.script Tainted: G      D    O    4.1.13-g8dc6617 #1
[  339.973120] Hardware name: Generic DRA74X (Flattened Device Tree)
[  339.979238] task: ed562300 ti: ee2b2000 task.ti: ee2b2000
[  339.984664] PC is at __module_get+0x28/0x70
[  339.988865] LR is at set_binfmt+0x4c/0x50
[  339.992891] pc : [<c00a0644>]    lr : [<c0123af8>]    psr: a0070013
[  339.992891] sp : ee2b3da0  ip : ee2b3db8  fp : ee2b3db4
[  340.004415] r10: b6f56a01  r9 : ed4d7480  r8 : ec490600
[  340.009660] r7 : ee2b3db8  r6 : 00000000  r5 : d5567180  r4 : c08e1e04
[  340.016213] r3 : 00000000  r2 : 00000002  r1 : c08c9314  r0 : 00000000
[  340.022767] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  340.029931] Control: 30c5387d  Table: 94cbe7c0  DAC: fffffffd
[  340.035700] Process default.script (pid: 1210, stack limit = 0xee2b2218)
[  340.042428] Stack: (0xee2b3da0 to 0xee2b4000)
[  340.046803] 3da0: ecea0c80 ed508e00 ee2b3e3c ee2b3db8 c0168da4 c0123ab8 00000812 00000000
[  340.055016] 3dc0: 00000000 00000080 ed508e00 b6f56000 00000006 00000001 00010000 000cacd0
[  340.063228] 3de0: 000c63c4 000b63c4 00010000 00000000 b6f7e960 b6f56000 ed4d7900 d4cbe700
[  340.071440] 3e00: c08e190c 00000001 fffffff8 00000000 ee2b3e3c c08e1e04 ed508e00 c08e190c
[  340.079651] 3e20: 00000001 fffffff8 00000000 d5567180 ee2b3e64 ee2b3e40 c012435c c0168488
[  340.087862] 3e40: ed508e00 ed508e00 c08e190c 00000001 fffffff8 00000000 ee2b3f04 ee2b3e68
[  340.096074] 3e60: c0166d08 c01242d4 00000000 ed508e02 6e69622f 0068732f c00f479c c0636e2c
[  340.104286] 3e80: ef5e121c 00000021 00000000 beffff06 ef5e121c 0009fb6c ee2b3ec4 ee2b3ea8
[  340.112497] 3ea0: c00f4828 c0636dd4 00000000 00000021 00000000 beffff06 ee2b3ed4 ee2b3ec8
[  340.120709] 3ec0: 00000000 00000021 ee2b3f2c ee2b3ed8 c0123358 c00dec40 ed508e00 c08e1d68
[  340.128920] 3ee0: ed508e00 c08e190c 00000001 fffffffe c08e1de8 c08e1de8 ee2b3f2c ee2b3f08
[  340.137132] 3f00: c012435c c0166ac8 ed562300 edbf0000 000004ba 000bf030 ed508e00 00000000
[  340.145344] 3f20: ee2b3f74 ee2b3f30 c0124c68 c01242d4 c08ca814 c0914e18 00000000 eceb0ba0
[  340.153554] 3f40: 00000000 ed562580 c012c640 be9af8a0 000bf030 00000000 0000000b c000fb04
[  340.161765] 3f60: ee2b2000 00000000 ee2b3f8c ee2b3f78 c0124d78 c0124764 00000000 c012c604
[  340.169976] 3f80: ee2b3fa4 ee2b3f90 c0124fd8 c0124d58 be9af8a0 000bf030 00000000 ee2b3fa8
[  340.178187] 3fa0: c000f960 c0124fc0 be9af8a0 000bf030 0009fb6c be9af8a0 000bf030 0000000b
[  340.186399] 3fc0: be9af8a0 000bf030 00000000 0000000b 0009fb6c 000bc838 00000000 0009fc28
[  340.194611] 3fe0: 0000000b be9af824 b6e672a3 b6e0b5f6 20070030 0009fb6c ffffffff 00000000
[  340.202818] Backtrace:
[  340.205286] [<c0123aac>] (set_binfmt) from [<c0168da4>] (load_elf_binary+0x928/0x1154)
[  340.213235]  r5:ed508e00 r4:ecea0c80
[  340.216844] [<c016847c>] (load_elf_binary) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  340.225576]  r10:d5567180 r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ed508e00
[  340.233480]  r4:c08e1e04
[  340.236032] [<c01242c8>] (search_binary_handler) from [<c0166d08>] (load_script+0x24c/0x264)
[  340.244502]  r9:00000000 r8:fffffff8 r7:00000001 r6:c08e190c r5:ed508e00 r4:ed508e00
[  340.252320] [<c0166abc>] (load_script) from [<c012435c>] (search_binary_handler+0x94/0x1d0)
[  340.260704]  r4:c08e1de8
[  340.263255] [<c01242c8>] (search_binary_handler) from [<c0124c68>] (do_execveat_common+0x510/0x5f4)
[  340.272335]  r9:00000000 r8:ed508e00 r7:000bf030 r6:000004ba r5:edbf0000 r4:ed562300
[  340.280155] [<c0124758>] (do_execveat_common) from [<c0124d78>] (do_execve+0x2c/0x34)
[  340.288015]  r10:00000000 r9:ee2b2000 r8:c000fb04 r7:0000000b r6:00000000 r5:000bf030
[  340.295915]  r4:be9af8a0
[  340.298466] [<c0124d4c>] (do_execve) from [<c0124fd8>] (SyS_execve+0x24/0x28)
[  340.305636] [<c0124fb4>] (SyS_execve) from [<c000f960>] (ret_fast_syscall+0x0/0x3c)
[  340.313322]  r5:000bf030 r4:be9af8a0
[  340.316928] Code: 00000000 00000000 a89c37fb e2822001 (e5832004)
[  340.323529] ---[ end trace b94dce3495cb29fd ]---
Any hints what could be the problem? Have I to disable network management on linux side? How would I do that?
    In general, yes, you should leave the DSP to do the ethernet configuration. This is done in the dts file.
    Could you please show the bootlog of your board first?
    Also could you clarify, this happens when remoteproc loads the DSP firmware, right? You are not trying to ping the device of connect it to a server (or host PC)?
    Yordan
    First as update, I changed the linux image to the one from the sdk. Thought there might be less problems like that.
    Then, I received the log above when I loaded the firmware with the debugger (was probably lucky that it even did run, probably a firmware with similar resource table was running at startup). I tried it also with remoteproc (see the log afterwards). By looking at it the DSP1 Core isn't even running because the ressource table is missing ([   10.850959] remoteproc remoteproc2: Failed to find resource table). So where can I find the according resource table and how do I link it?
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.11 15:07:35 =~=~=~=~=~=~=~=~=~=~=~=
    \00\00\F8
    U-Boot SPL 2018.01-g313dcd69c2 (Dec 16 2018 - 10:41:59)
    DRA752-GP ES2.0
    Trying to boot from MMC1
    no pinctrl state for default mode
    U-Boot 2018.01-g313dcd69c2 (Dec 16 2018 - 10:41:59 +0000)
    CPU  : DRA752-GP ES2.0
    Model: TI AM5728 BeagleBoard-X15
    Board: AM572x EVM REV A.3A
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    SCSI:  SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net:
    Warning: ethernet@48484000 using MAC address from ROM
    eth0: ethernet@48484000
    Hit any key to stop autoboot:  2 1 0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    ** Unable to read file boot.scr **
    1490 bytes read in 2 ms (727.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    Running uenvcmd ...
    1 bytes read in 2 ms (0 Bytes/s)
    Already setup.
    4026880 bytes read in 221 ms (17.4 MiB/s)
    147682 bytes read in 61 ms (2.3 MiB/s)
       Loading Device Tree to 8ffd8000, end 8ffff0e1 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.14.79-gbde58ab01e (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Thu Dec 20 04:51:24 UTC 2018
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: TI AM5728 EVM
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
    [    0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
    [    0.000000] DRA752 ES2.0
    [    0.000000] percpu: Embedded 15 pages/cpu @eed29000 s31372 r8192 d21876 u61440
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 472640
    [    0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=173e15da-02 rw rootfstype=ext4 rootwait
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 1675572K/1897472K available (8192K kernel code, 347K rwdata, 2628K rodata, 2048K init, 282K bss, 33484K reserved, 188416K cma-reserved, 1283072K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc0a00000   (10208 kB)
    [    0.000000]       .init : 0xc0e00000 - 0xc1000000   (2048 kB)
    [    0.000000]       .data : 0xc1000000 - 0xc1056e98   ( 348 kB)
    [    0.000000]        .bss : 0xc1058000 - 0xc109ebe0   ( 283 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]     Tasks RCU enabled.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [    0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
    [    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [    0.000017] Switching to timer-based delay loop, resolution 162ns
    [    0.000351] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000360] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000865] Console: colour dummy device 80x30
    [    0.000882] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
    [    0.000890] This ensures that you still see kernel messages. Please
    [    0.000897] update your kernel commandline.
    [    0.000918] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [    0.000934] pid_max: default: 32768 minimum: 301
    [    0.001051] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001064] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001589] CPU: Testing write buffer coherency: ok
    [    0.001625] CPU0: Spectre v2: using ICIALLU workaround
    [    0.001818] /cpus/cpu@0 missing clock-frequency property
    [    0.001837] /cpus/cpu@1 missing clock-frequency property
    [    0.001849] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.039848] Setting up static identity map for 0x80200000 - 0x80200060
    [    0.059858] Hierarchical SRCU implementation.
    [    0.080047] EFI services will not be available.
    [    0.099919] smp: Bringing up secondary CPUs ...
    [    0.170280] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.170285] CPU1: Spectre v2: using ICIALLU workaround
    [    0.170387] smp: Brought up 1 node, 2 CPUs
    [    0.170398] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [    0.170406] CPU: All CPU(s) started in HYP mode.
    [    0.170413] CPU: Virtualization extensions available.
    [    0.170947] devtmpfs: initialized
    [    0.191672] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
    [    0.191924] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.192117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.192135] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.195903] pinctrl core: initialized pinctrl subsystem
    [    0.196351] DMI not present or invalid.
    [    0.196607] NET: Registered protocol family 16
    [    0.197639] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.198567] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.308011] omap_hwmod: dcan1: _wait_target_disable failed
    [    0.406629] cpuidle: using governor ladder
    [    0.406660] cpuidle: using governor menu
    [    0.415371] OMAP GPIO hardware version 0.1
    [    0.444078] No ATAGs?
    [    0.444153] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.444167] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.444560] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.444570] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.445112] OMAP DMA hardware revision 0.0
    [    0.454907] edma 43300000.edma: memcpy is disabled
    [    0.458137] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.464955] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.466285] evm_5v0: supplied by main_12v0
    [    0.466708] com_3v6: supplied by evm_5v0
    [    0.469754] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.469955] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.470196] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.470471] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.470840] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.471047] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.471306] iommu: Adding device 58820000.ipu to group 1
    [    0.471395] iommu: Adding device 55020000.ipu to group 2
    [    0.471557] iommu: Adding device 40800000.dsp to group 0
    [    0.471827] iommu: Adding device 41000000.dsp to group 3
    [    0.474106] palmas 0-0058: Irq flag is 0x00000008
    [    0.502710] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
    [    0.504231] SMPS12: supplied by regulator-dummy
    [    0.505909] SMPS3: supplied by regulator-dummy
    [    0.507554] SMPS45: supplied by regulator-dummy
    [    0.509388] SMPS6: supplied by regulator-dummy
    [    0.510810] SMPS7: supplied by regulator-dummy
    [    0.512221] SMPS8: supplied by regulator-dummy
    [    0.513517] SMPS9: supplied by regulator-dummy
    [    0.514235] LDO1: supplied by regulator-dummy
    [    0.521307] LDO2: supplied by regulator-dummy
    [    0.521622] random: fast init done
    [    0.531177] LDO3: supplied by regulator-dummy
    [    0.541190] LDO4: supplied by regulator-dummy
    [    0.551214] LDO5: supplied by regulator-dummy
    [    0.551946] LDO6: supplied by regulator-dummy
    [    0.552695] LDO7: supplied by regulator-dummy
    [    0.553435] LDO8: supplied by regulator-dummy
    [    0.554172] LDO9: supplied by regulator-dummy
    [    0.561258] LDOLN: supplied by regulator-dummy
    [    0.571264] LDOUSB: supplied by regulator-dummy
    [    0.583960] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.584518] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.585039] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
    [    0.585236] media: Linux media interface: v0.10
    [    0.585274] Linux video capture interface: v2.00
    [    0.585354] pps_core: LinuxPPS API ver. 1 registered
    [    0.585363] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.585381] PTP clock support registered
    [    0.585408] EDAC MC: Ver: 3.0.0
    [    0.590701] dmi: Firmware registration failed.
    [    0.591103] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.591378] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.591727] Advanced Linux Sound Architecture Driver Initialized.
    [    0.600780] clocksource: Switched to clocksource arch_sys_counter
    [    0.608649] NET: Registered protocol family 2
    [    0.609171] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.609234] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.609360] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.609428] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.609461] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.609586] NET: Registered protocol family 1
    [    0.609873] RPC: Registered named UNIX socket transport module.
    [    0.609883] RPC: Registered udp transport module.
    [    0.609891] RPC: Registered tcp transport module.
    [    0.609898] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.610905] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.611080] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.612118] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.616181] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.616685] NFS: Registering the id_resolver key type
    [    0.616711] Key type id_resolver registered
    [    0.616720] Key type id_legacy registered
    [    0.616760] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.618074] bounce: pool size: 64 pages
    [    0.618122] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.618132] io scheduler noop registered
    [    0.618141] io scheduler deadline registered
    [    0.618231] io scheduler cfq registered (default)
    [    0.618241] io scheduler mq-deadline registered
    [    0.618250] io scheduler kyber registered
    [    0.622838] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.626218] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
    [    0.626587] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
    [    0.626622] OF: PCI:    IO 0x20003000..0x20012fff -> 0x00000000
    [    0.626644] OF: PCI:   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    1.626904] dra7-pcie 51000000.pcie: phy link never came up
    [    1.627038] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [    1.627052] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.627063] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    1.627073] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    1.627384] PCI: bus0: Fast back to back transfers disabled
    [    1.627473] PCI: bus1: Fast back to back transfers enabled
    [    1.627510] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
    [    1.627529] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    1.627845] pcieport 0000:00:00.0: Signaling PME with IRQ 174
    [    1.627970] pcieport 0000:00:00.0: AER enabled with IRQ 174
    [    1.628853] pwm-backlight backlight: backlight supply power not found, using dummy regulator
    [    1.631685] vdd_3v3: supplied by regen1
    [    1.631947] aic_dvdd_fixed: supplied by vdd_3v3
    [    1.632023] vtt_fixed: supplied by smps3
    [    1.674708] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    1.677375] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
    [    2.784627] console [ttyS2] enabled
    [    2.788943] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 46, base_baud = 3000000) is a 8250
    [    2.799661] omap_rng 48090000.rng: Random Number Generator ver. 20
    [    2.806800] DSS: OMAP DSS rev 6.1
    [    2.811872] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [    2.820279] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
    [    2.830693] panel-dpi display: display supply vcc not found, using dummy regulator
    [    2.848751] brd: module loaded
    [    2.857260] loop: module loaded
    [    2.863557] libphy: Fixed MDIO Bus: probed
    [    2.920805] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    2.928500] libphy: 48485000.mdio: probed
    [    2.937453] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
    [    2.947207] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
    [    2.957499] cpsw 48484000.ethernet: Detected MACID = 7c:38:66:80:74:7e
    [    2.964158] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [    2.970542] cpsw 48484000.ethernet: ALE Table size 1024
    [    2.975842] cpsw 48484000.ethernet: device node lookup for pps timer failed
    [    2.982911] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [    2.990803] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:38:66:80:74:7f
    [    2.999016] i2c /dev entries driver
    [    3.003501] IR NEC protocol handler initialized
    [    3.008053] IR RC5(x/sz) protocol handler initialized
    [    3.013152] IR RC6 protocol handler initialized
    [    3.017701] IR JVC protocol handler initialized
    [    3.022287] IR Sony protocol handler initialized
    [    3.026926] IR SANYO protocol handler initialized
    [    3.032110] IR Sharp protocol handler initialized
    [    3.036836] IR MCE Keyboard/mouse protocol handler initialized
    [    3.042710] IR XMP protocol handler initialized
    [    3.049672] gpio-fan gpio_fan: GPIO fan initialized
    [    3.055778] tmp102 0-0048: initialized
    [    3.063929] sdhci: Secure Digital Host Controller Interface driver
    [    3.070140] sdhci: Copyright(c) Pierre Ossman
    [    3.075441] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.082050] sdhci-omap 4809c000.mmc: Got CD GPIO
    [    3.087429] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
    [    3.094107] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
    [    3.160992] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
    [    3.230812] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
    [    3.238490] mmc0: host does not support reading read-only switch, assuming write-enable
    [    3.238677] sdhci-omap 480ad000.mmc: no pinctrl state for sdr104 mode
    [    3.238684] sdhci-omap 480ad000.mmc: no pinctrl state for ddr50 mode
    [    3.238691] sdhci-omap 480ad000.mmc: no pinctrl state for hs200_1_8v mode
    [    3.268165] ti-iodelay 4844a000.padconf: Set reg 0x620 Delay(a: 600 g: 400), Elements(C=1 F=10)0x2902a
    [    3.277613] ti-iodelay 4844a000.padconf: Set reg 0x628 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.286623] ti-iodelay 4844a000.padconf: Set reg 0x62c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.290850] mmc2: SDHCI controller on 480ad000.mmc [480ad000.mmc] using PIO
    [    3.295604] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.304911] NET: Registered protocol family 10
    [    3.313499] ti-iodelay 4844a000.padconf: Set reg 0x634 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.315507] Segment Routing with IPv6
    [    3.315544] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    3.315862] NET: Registered protocol family 17
    [    3.316015] Key type dns_resolver registered
    [    3.316104] omap_voltage_late_init: Voltage driver support not added
    [    3.316107] Power Management for TI OMAP4+ devices.
    [    3.316304] Registering SWP/SWPB emulation handler
    [    3.332965] dmm 4e000000.dmm: workaround for errata i878 in use
    [    3.341134] dmm 4e000000.dmm: initialized all PAT entries
    [    3.369092] ti-iodelay 4844a000.padconf: Set reg 0x638 Delay(a: 30 g: 0), Elements(C=0 F=0)0x29000
    [    3.378193] ti-iodelay 4844a000.padconf: Set reg 0x640 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.387132] ti-iodelay 4844a000.padconf: Set reg 0x644 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.396065] ti-iodelay 4844a000.padconf: Set reg 0x64c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.404992] ti-iodelay 4844a000.padconf: Set reg 0x650 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.405784] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.405787] [drm] No driver support for vblank timestamp query.
    [    3.413999] [drm] Enabling DMM ywrap scrolling
    [    3.431056] ti-iodelay 4844a000.padconf: Set reg 0x658 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.431062] ti-iodelay 4844a000.padconf: Set reg 0x65c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
    [    3.435282] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
    [    3.435505] mmcblk0: mmc0:59b4 USD00 14.7 GiB
    [    3.436186]  mmcblk0: p1 p2
    [    3.439700] mmc1: new DDR MMC card at address 0001
    [    3.440004] mmcblk1: mmc1:0001 S10004 3.56 GiB
    [    3.440142] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
    [    3.440289] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
    [    3.440422] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB
    [    3.441002]  mmcblk1: p1 p2 p3
    [    3.501426] Console: switching to colour frame buffer device 100x30
    [    3.575777] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [    3.582309] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
    [    3.591504] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [    3.598554] hctosys: unable to open rtc device (rtc0)
    [    3.604139] aic_dvdd_fixed: disabling
    [    3.607971] ldousb: disabling
    [    3.611320] ALSA device list:
    [    3.614315]   No soundcards found.
    [    6.033637] EXT4-fs (mmcblk0p2): recovery complete
    [    6.040558] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    6.048744] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    6.057706] devtmpfs: mounted
    [    6.061614] Freeing unused kernel memory: 2048K
    [    6.197853] systemd[1]: System time before build time, advancing clock.
    [    6.227477] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
    [    6.249013] systemd[1]: Detected architecture arm.
    Welcome to [1mArago 2018.10[0m!
    [    6.282141] systemd[1]: Set hostname to <am57xx-evm>.
    [    6.564215] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.571158] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [[0;32m  OK  [0m] Started Forward Password Requests to Wall Directory Watch.
    [    6.610919] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.617705] systemd[1]: Listening on Syslog Socket.
    [[0;32m  OK  [0m] Listening on Syslog Socket.
    [    6.651052] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.664867] systemd[1]: Listening on Process Core Dump Socket.
    [[0;32m  OK  [0m] Listening on Process Core Dump Socket.
    [    6.701394] systemd[1]: Listening on udev Kernel Socket.
    [[0;32m  OK  [0m] Listening on udev Kernel Socket.
    [    6.730995] systemd[1]: Listening on udev Control Socket.
    [[0;32m  OK  [0m] Listening on udev Control Socket.
    [    6.785442] systemd[1]: Listening on Network Service Netlink Socket.
    [[0;32m  OK  [0m] Listening on Network Service Netlink Socket.
    [    6.820905] systemd[1]: Reached target Remote File Systems.
    [[0;32m  OK  [0m] Reached target Remote File Systems.
    [[0;32m  OK  [0m] Listening on /dev/initctl Compatibility Named Pipe.
    [[0;32m  OK  [0m] Started Dispatch Password Requests to Console Directory Watch.
    [[0;32m  OK  [0m] Created slice User and Session Slice.
    [[0;32m  OK  [0m] Reached target Paths.
    [[0;32m  OK  [0m] Listening on Journal Socket (/dev/log).
    [[0;32m  OK  [0m] Reached target Swap.
    [[0;32m  OK  [0m] Listening on Journal Socket.
    [[0;32m  OK  [0m] Created slice System Slice.
             Mounting Kernel Debug File System...
    [[0;32m  OK  [0m] Created slice system-getty.slice.
             Starting Journal Service...
             Starting Load Kernel Modules...
    [    7.200878] cmemk: loading out-of-tree module taints kernel.
    [    7.207127] CMEMK module: reference Linux version 4.14.79
             [    7.215771] allocated heap buffer 0x40500000 of size 0x100000
    Starting Remount Root and Kernel File Systems...
    [    7.224660] cmemk initialized
    [    7.252471] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    7.255375] cryptodev: driver 1.9 loaded.
             Starting Create list of required st…ce nodes for the current kernel...
    [    7.283195] usbcore: registered new interface driver usbfs
    [    7.288736] usbcore: registered new interface driver hub
    [    7.294513] usbcore: registered new device driver usb
             Mounting Temporary Directory (/tmp)...
    [    7.306809] usbcore: registered new interface driver usbserial
    [    7.321590] usbcore: registered new interface driver ftdi_sio
    [    7.327391] usbserial: USB Serial support registered for FTDI USB Serial Device
             Mounting POSIX Message Queue File System...
    [[0;32m  OK  [0m] Created slice system-serial\x2dgetty.slice.
    [[0;32m  OK  [0m] Reached target Slices.
    [[0;32m  OK  [0m] Mounted Kernel Debug File System.
    [[0;32m  OK  [0m] Mounted POSIX Message Queue File System.
    [[0;32m  OK  [0m] Mounted Temporary Directory (/tmp).
    [[0;32m  OK  [0m] Started Journal Service.
    [[0;32m  OK  [0m] Started Load Kernel Modules.
    [[0;32m  OK  [0m] Started Remount Root and Kernel File Systems.
    [[0;32m  OK  [0m] Started Create list of required sta…vice nodes for the current kernel.
             Starting Rebuild Hardware Database...
             Starting Create System Users...
             Starting Apply Kernel Variables...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [[0;32m  OK  [0m] Mounted Kernel Configuration File System.
    [[0;32m  OK  [0m] Started Create System Users.
    [[0;32m  OK  [0m] Started Apply Kernel Variables.
             Starting Create Static Device Nodes in /dev...
    [    7.923881] systemd-journald[87]: Received request to flush runtime journal from PID 1
    [[0;32m  OK  [0m] Started Create Static Device Nodes in /dev.
    [[0;32m  OK  [0m] Started Flush Journal to Persistent Storage.
    [[0;32m  OK  [0m] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [[0;32m  OK  [0m] Mounted /var/volatile.
    [[0;32m  OK  [0m] Mounted /media/ram.
    [[0;32m  OK  [0m] Started udev Kernel Device Manager.
             Starting Load/Save Random Seed...
    [[0;32m  OK  [0m] Reached target Local File Systems.
             Starting Rebuild Journal Catalog...
             Starting Create Volatile Files and Directories...
             Starting Rebuild Dynamic Linker Cache...
    [[0;32m  OK  [0m] Started Load/Save Random Seed.
    [[0;32m  OK  [0m] Started Rebuild Journal Catalog.
    [[0;32m  OK  [0m] Started Create Volatile Files and Directories.
    [[0;32m  OK  [0m] Started Rebuild Dynamic Linker Cache.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Time Synchronization...
    [[0;32m  OK  [0m] Started Rebuild Hardware Database.
             Starting Update is Completed...
             Starting udev Coldplug all Devices...
    [[0;32m  OK  [0m] Started Update UTMP about System Boot/Shutdown.
    [[0;32m  OK  [0m] Started Update is Completed.
    [[0;32m  OK  [0m] Started Network Time Synchronization.
    [[0;32m  OK  [0m] Reached target System Time Synchronized.
    [[0;32m  OK  [0m] Started udev Coldplug all Devices.
    [[0;32m  OK  [0m] Reached target System Initialization.
    [[0;32m  OK  [0m] Started Daily rotation of log files.
             Starting Network Service...
    [[0;32m  OK  [0m] Listening on RPCbind Server Activation Socket.
    [[0;32m  OK  [0m] Started Daily Cleanup of Temporary Directories.
    [[0;32m  OK  [0m] Reached target Timers.
    [[0;32m  OK  [0m] Listening on D-Bus System Message Bus Socket.
    [[0;32m  OK  [0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [[0;32m  OK  [0m] Listening on dropbear.socket.
    [[0;32m  OK  [0m] Reached target Sockets.
    [[0;32m  OK  [0m] Reached target Basic System.
             Starting Login Service...
    [[0;32m  OK  [0m] Started Kernel Logging Service.
    [   10.139988] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
    [   10.149452] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc1
    [   10.151755] rtc-ds1307 2-006f: SET TIME!
    [   10.192629] rtc-ds1307 2-006f: registered as rtc0
    [   10.202478] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
    [   10.274512] remoteproc remoteproc0: 58820000.ipu is available
             Starting TI IPC Daemon...
    [   10.295589] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
    [   10.322475] remoteproc remoteproc1: 55020000.ipu is available
    [   10.344027] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [   10.353684] omap-des 480a5000.des: will run requests pump with realtime priority
    [   10.371788] pixcir_ts 4-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
    [   10.383088] pixcir_ts 4-005c: Failed to set IDLE mode
    [   10.399872] pixcir_ts: probe of 4-005c failed with error -121
    [   10.421312] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
    [   10.437291] remoteproc remoteproc2: 40800000.dsp is available
    [[0;32m  OK  [0m] Started Periodic Command Scheduler.
    [   10.461308] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
    [   10.510502] remoteproc remoteproc3: 41000000.dsp is available
             Starting Avahi mDNS/DNS-SD Stack...
    [[0;32m  OK  [0m] Started Hardware RNG Entropy Gatherer Daemon.
    [   10.533833] omap_rtc 48838000.rtc: registered as rtc2
             Starting TI MultiCore Tools Daemon...
    [   10.561945] remoteproc remoteproc1: powering up 55020000.ipu
    [   10.571837] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220
    [[   10.597812] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [0;32m  OK  [0m] Started D-Bus System Message Bus.
    [   10.705060] remoteproc remoteproc0: powering up 58820000.ipu
    [   10.721802] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6680920
    [   10.742350] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
    [   10.814820] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   10.830181] remoteproc remoteproc1: registered virtio0 (type 7)
    [   10.840153] remoteproc remoteproc2: powering up 40800000.dsp
    [   10.840168] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 3212660
    [   10.846924] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [   10.846956] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [   10.847037] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [   10.857618] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [   10.895410] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [   10.920563] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [   10.952156] SCSI subsystem initialized
    [   10.953226] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [   10.955146] random: crng init done
    [   10.955149] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.964528] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [   11.005799] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [   11.013755] omap-aes 4b700000.aes: will run requests pump with realtime priority
    [   11.046271] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.gpu on minor 1
    [   11.047223] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [   11.061072] vpe 489d0000.vpe: Device registered as /dev/video0
    [   11.181964] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [   11.181983] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [   11.181989] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [   11.274343] remoteproc remoteproc1: remote processor 55020000.ipu is now up
    [   11.291196] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
    [   11.299441] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x66
    [   11.312440] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   11.318001] remoteproc remoteproc0: registered virtio1 (type 7)
    [   11.324856] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
    [   11.324862] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
    [   11.355939] scsi host0: ahci
    [   11.356159] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 82
    [   11.432983] remoteproc remoteproc3: powering up 41000000.dsp
    [   11.432995] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20392652
    [   11.439706] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    [   11.439747] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [   11.439821] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [   11.546618] net eth1: initializing cpsw version 1.15 (0)
    [   11.586984] remoteproc remoteproc0: remote processor 58820000.ipu is now up
    [   11.587984] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
    [   11.598088] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
    [   11.598125] asoc-simple-card sound0: ASoC: no DMI vendor name!
    [   11.644440] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   11.644501] remoteproc remoteproc3: registered virtio2 (type 7)
    [   11.644506] remoteproc remoteproc3: remote processor 41000000.dsp is now up
    [   11.647010] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
    [   11.676153] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
    [   11.682377] ata1: SATA link down (SStatus 0 SControl 300)
    [   11.703301] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   11.757027] net eth0: initializing cpsw version 1.15 (0)
    [   11.884115] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
    [   11.889049] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [[0;32m  OK  [0m] Started Avahi mDNS/DNS-SD Stack.
    [   12.209726] FAT-fs (mmcblk1p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   12.224902] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   12.225139] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   12.228464] FAT-fs (mmcblk1p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [[0;32m  OK  [0m] Started System Logging Service.
             Starting uim-sysfs.service...
    [[0;32m  OK  [0m] Started Job spooling tools.
             Starting RPC Bind Service...
    [[0;32m  OK  [0m] Reached target Containers.
             Starting Save/Restore Sound Card State...
             Starting Print notice about GPLv3 packages...
    [[0;32m  OK  [0m] Started Network Service.
    [[0;32m  OK  [0m] Started TI IPC Daemon.
    [[0;32m  OK  [0m] Started TI MultiCore Tools Daemon.
    [[0;32m  OK  [0m] Started RPC Bind Service.
    [[0;32m  OK  [0m] Started Save/Restore Sound Card State.
    [[0;32m  OK  [0m] Found device /dev/ttyS2.
    [   13.154862] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
    [   13.170647] pruss 4b200000.pruss: creating PRU cores and other child platform devices
    [   13.173824] pruss 4b280000.pruss: creating PRU cores and other child platform devices
    [   13.181129] NET: Registered protocol family 44
    [   13.232325] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [   13.232350] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [   13.244829] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
    [   13.244877] xhci-hcd xhci-hcd.1.auto: irq 189, io mem 0x48890000
    [   13.247791] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [   13.247796] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.247800] usb usb1: Product: xHCI Host Controller
    [   13.247803] usb usb1: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd
    [   13.247806] usb usb1: SerialNumber: xhci-hcd.1.auto
    [   13.248375] hub 1-0:1.0: USB hub found
    [   13.248412] hub 1-0:1.0: 1 port detected
    [   13.248858] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [   13.248873] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [   13.248884] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0  SuperSpeed
    [   13.249061] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   13.249148] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [   13.249153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.249156] usb usb2: Product: xHCI Host Controller
    [   13.249159] usb usb2: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd
    [   13.249162] usb usb2: SerialNumber: xhci-hcd.1.auto
    [   13.249690] hub 2-0:1.0: USB hub found
    [   13.249713] hub 2-0:1.0: 1 port detected
    [   13.258588] remoteproc remoteproc4: 4b234000.pru is available
    [   13.258645] pru-rproc 4b234000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@34000 probed successfully
    [   13.259031] remoteproc remoteproc5: 4b238000.pru is available
    [   13.259070] pru-rproc 4b238000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@38000 probed successfully
    [   13.259387] remoteproc remoteproc6: 4b2b4000.pru is available
    [   13.259463] pru-rproc 4b2b4000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@34000 probed successfully
    [   13.259770] remoteproc remoteproc7: 4b2b8000.pru is available
    [   13.259814] pru-rproc 4b2b8000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@38000 probed successfully
    [   13.617133] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
    [[   13.645053] usb 2-1: New USB device found, idVendor=0451, idProduct=8140
    [0;32m  OK  [0m] Started uim-sysfs.service.
    [   13.652764] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
    [   13.660833] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 4
    [   13.660856] rpmsg_rpc virtio0.rpmsg-rpc.-1.102: published functions = 9
    [   13.680919] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [   13.697096] hub 2-1:1.0: USB hub found
    [   13.701746] hub 2-1:1.0: 4 ports detected
    [   13.790824] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   13.971111] usb 1-1: New USB device found, idVendor=0451, idProduct=8142
    [   13.977856] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   13.986500] usb 1-1: SerialNumber: BC0728410AF3
    [   14.017364] hub 1-1:1.0: USB hub found
    [   14.021252] hub 1-1:1.0: 4 ports detected
    [[0;32m  OK  [0m] Reached target Sound Card.
             Starting rc.pvr.service...
    [[0;32m  OK  [0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [[0;32m  OK  [0m] Created slice system-systemd\x2dbacklight.slice.
             Starting Load/Save Screen Backlight…ightness of backlight:backlight...
    [[0;32m  OK  [0m] Reached target Network.
             Starting Lightning Fast Webserver With Light System Requirements...
    [[0;32m  OK  [0m] Started Redis In-Memory Data Store.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Network Name Resolution...
             Starting Permit User Sessions...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting Wait for Network to be Configured...
    [[0;32m  OK  [0m] Started Load/Save Screen Backlight Brightness of backlight:backlight.
    [[0;32m  OK  [0m] Started Login Service.
    [[0;32m  OK  [0m] Started Permit User Sessions.
    [[0;32m  OK  [0m] Started Serial Getty on ttyS2.
    [[0;32m  OK  [0m] Started Getty on tty1.
    [[0;32m  OK  [0m] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [[0;32m  OK  [0m] Started Lightning Fast Webserver With Light System Requirements.
    [[0;32m  OK  [0m] Started Synchronize System and HW clocks.
    [   14.754763] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [[0;32m  OK  [0m] Started rc.pvr.service.
             Starting weston.service...
    [[0;32m  OK  [0m] Started weston.service.
             Starting Matrix GUI...
             Starting telnetd.service...
    [[0;32m  OK  [0m] Started Simple Network Management Protocol (SNMP) Daemon..
    [[0;32m  OK  [0m] Started telnetd.service.
             Starting thttpd.service...
    [[0;32m  OK  [0m] Started Matrix GUI.
    [[0;32m  OK  [0m] Started thttpd.service.
             Starting rng-tools.service...
    [[0;32m  OK  [0m] Started Network Name Resolution.
    [[0;32m  OK  [0m] Reached target Host and Network Name Lookups.
    [[0;32m  OK  [0m] Started NFS status monitor for NFSv2/3 locking..
    [[0;32m  OK  [0m] Started rng-tools.service.
    NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        binutils-dev
        binutils
        bison-dev
        bison
        cifs-utils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils-dev
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbc6x
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        hidapi
        libasm1
        libcairo-perf-utils
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm4
        libgettextlib
        libgettextsrc
        libgmp10
        libidn11
        libmavconn
        libmpc3
        libmpfr4
        libreadline-dev
        libreadline7
        libunistring2
        m4-dev
        m4
        make
        mavlink
        mavros-extras
        mavros-msgs
        mavros
        nettle
        parted
        python3-pycairo
        socketcan-interface
        swig-dev
        swig
        which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [[0;32m  OK  [0m] Started Print notice about GPLv3 packages.
    [[0;32m  OK  [0m] Started Enable and configure wl18xx bluetooth stack.
    [   20.009440] cpsw 48484000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
    [   20.017193] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am57xx-evm ttyS2
    Arago 2018.10 am57xx-evm ttyS2
    am57xx-evm login: [   22.238225] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    root
    7[r[999;999H[6n8root@am57xx-evm:~#
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    Would it be enough to disable the "cpsw_emac0" / "cpsw_emac1" or should I disable "mac" altogether?
    As for the IPC resource table, it is provided with the IPC package included in AM57xx Processor SDK RTOS (you need both RTOS & Linux SDK to build custom IPC). Here are some useful links regarding resource table:
    e2e.ti.com/.../712332
    e2e.ti.com/.../2649011
    e2e.ti.com/.../2662640
    processors.wiki.ti.com/.../IPC_Resource_customTable
    Yes, try disabling both.
    Yordan
