Part Number: TDA2EVM5777
Tool/software: Linux
I followed this guide(
) to build the filesystem for the tda2evm5777 board and ran into the following problems:
1. The md5sum of libloki was wrong, so I followed this thread(
) to fix it.
2. The following error showed up and I couldn't manage to fix it.
[PSDKLA]> [PSDKLA]> Current Directory is /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers [PSDKLA]> PATH is /home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/:/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01//bin:/home/bmann/bin:/home/bmann/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin [PSDKLA]> Building on bmann-VirtualBox running Linux bmann-VirtualBox 4.15.0-45-generic #48~16.04.1-Ubuntu SMP Tue Jan 29 18:03:48 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux [PSDKLA]> Starting Yocto build at ש' פבר 9 19:29:03 IST 2019 [PSDKLA]> [PSDKLA]> cd build [PSDKLA]> . conf/setenv [PSDKLA]> cp conf/local.conf conf/local.conf.pristine [PSDKLA]> MACHINE=dra7xx-evm bitbake tisdk-rootfs-image NOTE: Started PRServer with DBfile: /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 42247, PID: 13920 Loading cache: 100% |################################################################################################################################################################| ETA: 00:00:00 Loaded 2849 entries from dependency cache. NOTE: Resolving any missing task queue dependencies Build Configuration: BB_VERSION = "1.30.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "Ubuntu-16.04" TARGET_SYS = "arm-linux-gnueabi" MACHINE = "dra7xx-evm" DISTRO = "arago" DISTRO_VERSION = "2016.12" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard" TARGET_FPU = "hard" meta-glsdk = "HEAD:66cfd8ef55344508d6e7b306259f34c05b828194" meta-arago-distro meta-arago-extras = "HEAD:4c01410ffde8853224567fb6078d7d9f190b942f" meta-qt5 = "HEAD:f8584d7a7c90afc71484a40279aa3df651d0e04f" meta-networking meta-ruby meta-python meta-oe = "HEAD:55c8a76da5dc099a7bc3838495c672140cedb78e" meta-ti = "HEAD:5f3a1169d307fec41626f850f5c700437dedbe93" meta-linaro-toolchain meta-optee = "HEAD:2f51d38048599d9878f149d6d15539fb97603f8f" meta = "HEAD:bfa04fa71c47e8fe9528208848cfcec2e232777d" NOTE: Preparing RunQueue NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks ERROR: qtxmlpatterns-5.6.2+gitAUTOINC+074571305e-r0 do_compile: oe_runmake failed ERROR: qtxmlpatterns-5.6.2+gitAUTOINC+074571305e-r0 do_compile: Function failed: do_compile (log file is located at /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/temp/log.do_compile.13965) ERROR: Logfile of failure stored in: /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/temp/log.do_compile.13965 Log data follows: | DEBUG: Executing shell function do_compile | NOTE: make -j 4 MAKEFLAGS=-j 4 OE_QMAKE_COMPILER=arm-linux-gnueabihf-gcc -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm OE_QMAKE_CC=arm-linux-gnueabihf-gcc -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm OE_QMAKE_CXX=arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm OE_QMAKE_CFLAGS= -isystem/home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0=/usr/src/debug/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0 -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux= -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm= OE_QMAKE_CXXFLAGS= -isystem/home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0=/usr/src/debug/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0 -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux= -fdebug-prefix-map=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm= OE_QMAKE_LINK=arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm OE_QMAKE_LDFLAGS= -L/home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu OE_QMAKE_AR=arm-linux-gnueabihf-ar OE_QMAKE_STRIP=echo OE_QMAKE_WAYLAND_SCANNER=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/wayland-scanner OE_QMAKE_INCDIR_QT=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm//usr/include/qt5 | cd src/ && ( test -e Makefile || /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/git/src/src.pro -o Makefile ) && make -f Makefile | make[1]: Entering directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/build/src' | cd xmlpatterns/ && ( test -e Makefile || /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/git/src/xmlpatterns/xmlpatterns.pro -o Makefile ) && make -f Makefile | make[2]: Entering directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/build/src/xmlpatterns' | rm -f libQt5XmlPatterns.so.5.6.2 libQt5XmlPatterns.so libQt5XmlPatterns.so.5 libQt5XmlPatterns.so.5.6 | linking ../../lib/libQt5XmlPatterns.so.5.6.2 | .obj/qboolean.o: file not recognized: File truncated | collect2: error: ld returned 1 exit status | Makefile:1415: recipe for target '../../lib/libQt5XmlPatterns.so.5.6.2' failed | make[2]: *** [../../lib/libQt5XmlPatterns.so.5.6.2] Error 1 | make[2]: Leaving directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/build/src/xmlpatterns' | Makefile:42: recipe for target 'sub-xmlpatterns-make_first' failed | make[1]: *** [sub-xmlpatterns-make_first] Error 2 | make[1]: Leaving directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/build/src' | Makefile:45: recipe for target 'sub-src-make_first' failed | make: *** [sub-src-make_first] Error 2 | ERROR: oe_runmake failed | ERROR: Function failed: do_compile (log file is located at /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2+gitAUTOINC+074571305e-r0/temp/log.do_compile.13965) ERROR: Task 4698 (/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb, do_compile) failed with exit code '1' ERROR: opencl-monitor-1.1.12.0-r0.0 do_install: oe_runmake failed ERROR: opencl-monitor-1.1.12.0-r0.0 do_install: Function failed: do_install (log file is located at /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/temp/log.do_install.13989) ERROR: Logfile of failure stored in: /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/temp/log.do_install.13989 Log data follows: | DEBUG: Executing shell function do_install | NOTE: make -j 4 DESTDIR=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/image install | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -H/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor -B/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build --check-build-system CMakeFiles/Makefile.cmake 0 | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -E cmake_progress_start /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles/progress.marks | make -f CMakeFiles/Makefile2 all | make[1]: Entering directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build' | make[1]: Nothing to be done for 'all'. | make[1]: Leaving directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build' | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -E cmake_progress_start /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles 0 | make -f CMakeFiles/Makefile2 preinstall | make[1]: Entering directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build' | make[1]: Nothing to be done for 'preinstall'. | make[1]: Leaving directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build' | Install the project... | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -P cmake_install.cmake | -- Install configuration: "" | make[1]: warning: -jN forced in submake: disabling jobserver mode. | make[1]: Entering directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor' | Linking dsp0.out | monitor0/linker.cmd | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/bin/cl6x -o3 -mv6600 --abi=eabi --gcc --mem_model:const=data --mem_model:data=far -z --priority -w -x -mdsp0.out.map --define=DDR3_FCSECTION=DDR3_FC custom_rsc_table_vayu_dsp0.obj monitor.obj util.obj dsp_rpc.obj touch.obj builtins.obj edma.obj edma_am57x_config.obj device_am57.obj ../builtins/dsp.lib ../libm/libm.lib monitor0/linker.cmd cmds/monitor.am57x.cmd /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ulm/libtiulm.ae66 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66 -I/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/lib -llibc.a -o dsp0.out | <Linking> | Linking dsp1.out | monitor1/linker.cmd | /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/bin/cl6x -o3 -mv6600 --abi=eabi --gcc --mem_model:const=data --mem_model:data=far -z --priority -w -x -mdsp1.out.map --define=DDR3_FCSECTION=DDR3_FC custom_rsc_table_vayu_dsp1.obj monitor.obj util.obj dsp_rpc.obj touch.obj builtins.obj edma.obj edma_am57x_config.obj device_am57.obj ../builtins/dsp.lib ../libm/libm.lib monitor1/linker.cmd cmds/monitor.am57x.cmd /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ulm/libtiulm.ae66 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66 -I/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/lib -llibc.a -o dsp1.out | <Linking> | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/ | monitor.am57x_pe66.src/ipc/ipc.ae66" | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/ | monitor.am57x_pe66.src/ipc/ipc.ae66" | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/ | monitor.am57x_pe66.src/utils/utils.ae66" | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/ | monitor.am57x_pe66.src/sysbios/sysbios.ae66" | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/ | monitor.am57x_pe66.src/utils/utils.ae66" | error: cannot find file | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm- | linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/ | monitor.am57x_pe66.src/sysbios/sysbios.ae66" | warning: Option --export is not valid without --dynamic or --sysv or --rom | (ignored) | "cmds/monitor.am57x.cmd", line 89: warning: absolute symbol "_argsize" being | redefined | warning: Option --export is not valid without --dynamic or --sysv or --rom | (ignored) | "cmds/monitor.am57x.cmd", line 89: warning: absolute symbol "_argsize" being | redefined | warning: output section ".fardata.2" refers to load symbol | "ti_sysbios_timers_dmtimer_Timer_stub__E" and hence cannot be compressed; | compression "rle" is ignored | warning: output section ".fardata.3" refers to load symbol | "ti_sysbios_family_c64p_EventCombiner_unused__E" and hence cannot be | compressed; compression "rle" is ignored | warning: output section ".fardata.2" refers to load symbol | "ti_sysbios_timers_dmtimer_Timer_stub__E" and hence cannot be compressed; | compression "rle" is ignored | warning: output section ".fardata.3" refers to load symbol | "ti_sysbios_family_c64p_EventCombiner_unused__E" and hence cannot be | compressed; compression "rle" is ignored | | undefined first referenced | symbol in file | --------- ---------------- | IpcMgr_callIpcStart /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | IpcMgr_ipcStartup /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | Ipc_start /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-omp-tree/packages/ti/runtime/ompbios/lib/ti_runtime_ompbios_release_e66.ae66<OpenMP.oe66> | MessageQ_Params_init__S monitor.obj | MessageQ_alloc monitor.obj | MessageQ_create monitor.obj | MessageQ_delete monitor.obj | MessageQ_free monitor.obj | MessageQ_get monitor.obj | MessageQ_put monitor.obj | MessageQ_setReplyQueue monitor.obj | MultiProc_getId device_am57.obj | MultiProc_setLocalId device_am57.obj | ti_ipc_remoteproc_Resource_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_attach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_detach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_isRegistered__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_sharedMemReq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_registerTransport__F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_unregisterTransport__F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_Notify_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_family_vayu_NotifySetup_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_gates_GateHWSpinlock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_utils_NameServer_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_getThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_BIOS_linkedWithIncorrectBootLibrary__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_setThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_start__E monitor.obj | ti_sysbios_family_c62_IntrinsicsSupport_maxbit__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_checkStack__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getCheckValueAddr__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getDefaultStackSize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getStackAlignment__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_stackUsed__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_swap__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_EventCombiner_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_EventCombiner_unused__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Exception_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Exception_dispatch__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_dispatchAlways /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_enableInterrupt__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_eventMap__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Server.obj> | ti_sysbios_family_c64p_Hwi_plug__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Server.obj> | ti_sysbios_family_c64p_TimestampProvider_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_TimestampProvider_get64__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_enable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_inv__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Util.obj> | ti_sysbios_family_c66_Cache_startup__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wait__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbInvAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbInv__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Util.obj> | ti_sysbios_family_c66_Cache_wb__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_vayu_Power_resetFxn__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_shared_vayu_IntXbar_initIntXbar__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_shared_vayu_TimerSupport_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_checkStack /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_initStackMin /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getCount__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getCurrentTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getExpiredCounts__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getExpiredTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getFreq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getMaxTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getNumTimers__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getStatus__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setNextTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setPeriodMicroSecs__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_stop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_trigger__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_init__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_getTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/trace/lib/release/ti.trace.ae66<SysMin.oe66> | ti_sysbios_knl_Clock_logTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_setTicks__E monitor.obj | ti_sysbios_knl_Clock_setTimeout__E monitor.obj | ti_sysbios_knl_Clock_start__E monitor.obj | ti_sysbios_knl_Clock_stop__E monitor.obj | ti_sysbios_knl_Clock_tick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Clock_workFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Idle_loop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Queue_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Queue_empty__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Semaphore_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Swi_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_restore__E edma.obj | ti_sysbios_knl_Swi_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66<edma3_config.oe66> | ti_sysbios_knl_Task_getModuleStateCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_getObjectCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_moduleStateCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_objectCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_restore__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66<edma3_config.oe66> | ti_sysbios_knl_Task_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_stub__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66 | | error: unresolved symbols remain | | undefined first referenced | symbol in file | --------- ---------------- | IpcMgr_callIpcStart /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | IpcMgr_ipcStartup /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | Ipc_start /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-omp-tree/packages/ti/runtime/ompbios/lib/ti_runtime_ompbios_release_e66.ae66<OpenMP.oe66> | MessageQ_Params_init__S monitor.obj | MessageQ_alloc monitor.obj | MessageQ_create monitor.obj | MessageQ_delete monitor.obj | MessageQ_free monitor.obj | MessageQ_get monitor.obj | MessageQ_put monitor.obj | MessageQ_setReplyQueue monitor.obj | MultiProc_getId device_am57.obj | MultiProc_setLocalId device_am57.obj | ti_ipc_remoteproc_Resource_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_attach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_detach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_isRegistered__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_ipc_transports_TransportRpmsgSetup_sharedMemReq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_registerTransport__F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_MessageQ_unregisterTransport__F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_Notify_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_family_vayu_NotifySetup_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_ipc_gates_GateHWSpinlock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sdo_utils_NameServer_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_getThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_BIOS_linkedWithIncorrectBootLibrary__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_setThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_BIOS_start__E monitor.obj | ti_sysbios_family_c62_IntrinsicsSupport_maxbit__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_checkStack__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getCheckValueAddr__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getDefaultStackSize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_getStackAlignment__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_stackUsed__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c62_TaskSupport_swap__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_EventCombiner_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_EventCombiner_unused__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Exception_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Exception_dispatch__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_dispatchAlways /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_enableInterrupt__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_Hwi_eventMap__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Server.obj> | ti_sysbios_family_c64p_Hwi_plug__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Server.obj> | ti_sysbios_family_c64p_TimestampProvider_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c64p_TimestampProvider_get64__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_enable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_inv__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Util.obj> | ti_sysbios_family_c66_Cache_startup__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wait__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbInvAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_Cache_wbInv__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66<Util.obj> | ti_sysbios_family_c66_Cache_wb__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_c66_vayu_Power_resetFxn__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_shared_vayu_IntXbar_initIntXbar__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_family_shared_vayu_TimerSupport_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateAll_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateHwi_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutexPri_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateMutex_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_gates_GateSwi_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_checkStack /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_initStackMin /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_Hwi_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getCount__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getCurrentTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getExpiredCounts__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getExpiredTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getFreq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getMaxTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getNumTimers__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_getStatus__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setNextTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setPeriodMicroSecs__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_setPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_stop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_hal_TimerNull_trigger__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapBuf_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_init__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_heaps_HeapMem_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_getTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/trace/lib/release/ti.trace.ae66<SysMin.oe66> | ti_sysbios_knl_Clock_logTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Clock_setTicks__E monitor.obj | ti_sysbios_knl_Clock_setTimeout__E monitor.obj | ti_sysbios_knl_Clock_start__E monitor.obj | ti_sysbios_knl_Clock_stop__E monitor.obj | ti_sysbios_knl_Clock_tick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Clock_workFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Idle_loop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Queue_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Queue_empty__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Semaphore_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Semaphore_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66<IpcPowerDsp_dra7xx.oe66> | ti_sysbios_knl_Swi_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Swi_restore__E edma.obj | ti_sysbios_knl_Swi_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66<edma3_config.oe66> | ti_sysbios_knl_Task_getModuleStateCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_getObjectCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_moduleStateCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_objectCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_knl_Task_restore__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66<edma3_config.oe66> | ti_sysbios_knl_Task_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_timers_dmtimer_Timer_stub__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateProcessSupport_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_GateThreadSupport_query__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemProcessSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_Instance_finalize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_Instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | ti_sysbios_xdcruntime_SemThreadSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66 | | error: unresolved symbols remain | error: errors encountered during linking; "dsp1.out" not built | | >> Compilation failure | Makefile.am57x:133: recipe for target 'dsp1.out' failed | make[1]: *** [dsp1.out] Error 1 | make[1]: *** Waiting for unfinished jobs.... | error: errors encountered during linking; "dsp0.out" not built | | >> Compilation failure | Makefile.am57x:128: recipe for target 'dsp0.out' failed | make[1]: Leaving directory '/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor' | make[1]: *** [dsp0.out] Error 1 | CMake Error at cmake_install.cmake:48 (file): | file INSTALL cannot find | "/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/dsp0.syms". | | | Makefile:64: recipe for target 'install' failed | make: *** [install] Error 1 | ERROR: oe_runmake failed | ERROR: Function failed: do_install (log file is located at /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/temp/log.do_install.13989) ERROR: Task 4923 (/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-ti/ocl/opencl-monitor_git.bb, do_install) failed with exit code '1' NOTE: Tasks Summary: Attempted 1780 tasks of which 1778 didn't need to be rerun and 2 failed. NOTE: Writing buildhistory Waiting for 0 running tasks to finish: Summary: 2 tasks failed: /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb, do_compile /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-ti/ocl/opencl-monitor_git.bb, do_install Summary: There were 4 ERROR messages shown, returning a non-zero exit code. [PSDKLA]> [PSDKLA]> Completed Yocto build at ש' פבר 9 19:29:40 IST 2019 [PSDKLA]>
I'd really appreciate some help with this.
Thanks!
