Linux: Compile Linux-c6x 2.0
Tool/software: Linux
I compiled linux-c6x 2.0 as follows:
http://www.linux-c6x.org/wiki/index.php/Linux-c6x_2.0_Release
Compile using the following command:
./prj build
But the compilation does not pass.
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1239: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1241: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1243: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1245: undefined reference to `xdr_u_int'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o):/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1247: more undefined references to `xdr_u_int' follow
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_get_msg_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1249: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1251: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1253: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1255: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1257: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1259: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1261: undefined reference to `xdr_u_int'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_get_reply_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1272: undefined reference to `xdr_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1274: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1276: undefined reference to `xdr_bytes'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_pget_msg_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1287: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1289: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1291: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1293: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1295: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1297: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1299: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1301: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1303: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1305: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1307: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1309: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1311: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1313: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1315: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1317: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1319: undefined reference to `xdr_u_int'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_pget_reply_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1330: undefined reference to `xdr_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1332: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1334: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1336: undefined reference to `xdr_bytes'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_put_msg_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1347: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1349: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1351: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1353: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1355: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1357: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1359: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1361: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1363: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1365: undefined reference to `xdr_u_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1367: undefined reference to `xdr_bytes'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1369: undefined reference to `xdr_u_int'
./rpmdb/.libs/librpmdb.a(db_server_xdr.o): In function `xdr___dbc_put_reply_rpmdb':
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1380: undefined reference to `xdr_int'
/home/llr/linux-c6x/Build/rpm-4.0.4/db3/../db/dist/../rpc_server/db_server_xdr.c:1382: undefined reference to `xdr_bytes'
collect2: ld returned 1 exit status
make[4]: *** [rpm] 错误 1
make[3]: *** [all-recursive] 错误 1
make[2]: *** [all-recursive-am] 错误 2
make[1]: *** [/home/llr/linux-c6x/sdk/rpm/cross-rpm/pkg_build] 错误 2
make: *** [rpm] 错误 2
How should I solve this problem?
