Part Number: AM5728
Tool/software: Linux
hi,
we have interfaced AM5728 with KSZ9031 for 1Gbps communication.
PHY not detected and unable to ping data.
please suggest what to be done.
find the attached
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.32-gadde2ca9f8 (ums@ums) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #2 SMP PREEMPT Tue Feb 12 13:27:44 IST 2019
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI AM572x EVM Rev A3
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @eed32000 s14848 r8192 d22016 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=603d28a9-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1680724K/1897472K available (6523K kernel code, 358K rwdata, 2392K rodata, 336K init, 286K bss, 28332K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08bd044 (8917 kB)
[ 0.000000] .init : 0xc08be000 - 0xc0912000 ( 336 kB)
[ 0.000000] .data : 0xc0912000 - 0xc096ba70 ( 359 kB)
[ 0.000000] .bss : 0xc096d000 - 0xc09b4900 ( 287 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000326] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000334] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000732] Console: colour dummy device 80x30
[ 0.000749] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000756] This ensures that you still see kernel messages. Please
[ 0.000761] update your kernel commandline.
[ 0.000774] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000787] pid_max: default: 32768 minimum: 301
[ 0.000879] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000888] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001421] Initializing cgroup subsys io
[ 0.001437] Initializing cgroup subsys memory
[ 0.001460] Initializing cgroup subsys devices
[ 0.001473] Initializing cgroup subsys freezer
[ 0.001484] Initializing cgroup subsys perf_event
[ 0.001494] Initializing cgroup subsys pids
[ 0.001519] CPU: Testing write buffer coherency: ok
[ 0.001718] /cpus/cpu@0 missing clock-frequency property
[ 0.001734] /cpus/cpu@1 missing clock-frequency property
[ 0.001744] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001778] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.080067] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080129] Brought up 2 CPUs
[ 0.080141] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080148] CPU: All CPU(s) started in HYP mode.
[ 0.080153] CPU: Virtualization extensions available.
[ 0.080521] devtmpfs: initialized
[ 0.107704] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.108626] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.306770] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.310718] pinctrl core: initialized pinctrl subsystem
[ 0.311554] NET: Registered protocol family 16
[ 0.312461] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.340234] cpuidle: using governor ladder
[ 0.370254] cpuidle: using governor menu
[ 0.378376] OMAP GPIO hardware version 0.1
[ 0.384849] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.407445] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.407455] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.407899] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.407908] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.408465] OMAP DMA hardware revision 0.0
[ 0.451186] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452268] edma 43300000.edma: memcpy is disabled
[ 0.456923] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.460847] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.461031] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.461191] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.461343] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.461611] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.461799] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.464575] palmas 0-0058: Irq flag is 0x00000008
[ 0.482699] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.564198] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.564796] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 0.564980] media: Linux media interface: v0.10
[ 0.565033] Linux video capture interface: v2.00
[ 0.565074] pps_core: LinuxPPS API ver. 1 registered
[ 0.565081] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.565111] PTP clock support registered
[ 0.565162] EDAC MC: Ver: 3.0.0
[ 0.565877] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.566158] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.566490] Advanced Linux Sound Architecture Driver Initialized.
[ 0.567282] clocksource: Switched to clocksource arch_sys_counter
[ 0.578024] NET: Registered protocol family 2
[ 0.578514] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.578577] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.578702] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.578749] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.578780] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.578986] NET: Registered protocol family 1
[ 0.579248] RPC: Registered named UNIX socket transport module.
[ 0.579257] RPC: Registered udp transport module.
[ 0.579264] RPC: Registered tcp transport module.
[ 0.579269] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.580193] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.582531] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.590138] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.590768] NFS: Registering the id_resolver key type
[ 0.590800] Key type id_resolver registered
[ 0.590807] Key type id_legacy registered
[ 0.590871] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.592813] bounce: pool size: 64 pages
[ 0.592966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.592982] io scheduler noop registered
[ 0.592996] io scheduler deadline registered
[ 0.593031] io scheduler cfq registered (default)
[ 0.595154] ldousb: supplied by VMAIN
[ 0.598457] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.658254] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.661558] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 299, base_baud = 3000000) is a 8250
[ 1.510054] console [ttyS2] enabled
[ 1.514382] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 300, base_baud = 3000000) is a 8250
[ 1.524367] [drm] Initialized drm 1.1.0 20060810
[ 1.530565] ldoln: supplied by VMAIN
[ 1.534734] OMAP DSS rev 6.1
[ 1.538801] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 1.547323] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 1.562156] loop: module loaded
[ 1.568000] libphy: Fixed MDIO Bus: probed
[ 1.617314] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.623438] davinci_mdio 48485000.mdio: no live phy, scanning all
[ 1.727285] davinci_mdio 48485000.mdio: timed out waiting for user access
[ 1.827281] davinci_mdio 48485000.mdio: timed out waiting for idle
[ 1.833512] davinci_mdio: probe of 48485000.mdio failed with error -5
[ 1.840624] cpsw 48484000.ethernet: Detected MACID = 34:15:13:ac:6e:3a
[ 1.847296] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 1.854237] cpsw 48484000.ethernet: cpsw: Detected MACID = 34:15:13:ac:6e:3b
[ 1.862685] mousedev: PS/2 mouse device common for all mice
[ 1.868830] i2c /dev entries driver
[ 1.874983] gpio-fan gpio_fan: GPIO fan initialized
[ 1.883327] vdd_3v3: supplied by regen1
[ 1.887505] ldo1: supplied by VMAIN
[ 1.937786] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 1.944169] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.007975] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.019676] NET: Registered protocol family 10
[ 2.034977] sit: IPv6 over IPv4 tunneling driver
[ 2.040266] NET: Registered protocol family 17
[ 2.044939] Key type dns_resolver registered
[ 2.049372] omap_voltage_late_init: Voltage driver support not added
[ 2.056242] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.062467] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.069189] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.075400] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.082273] cpu cpu0: _opp_add_static_v2: Multiple suspend OPPs found (1000000000 200000000)
[ 2.090858] cpu cpu0: _opp_add_static_v2: Multiple suspend OPPs found (1000000000 800000000)
[ 2.099430] cpu cpu0: _opp_add_static_v2: Multiple suspend OPPs found (1000000000 600000000)
[ 2.108009] cpu cpu0: _opp_add_static_v2: Multiple suspend OPPs found (1000000000 400000000)
[ 2.119532] Power Management for TI OMAP4+ devices.
[ 2.125154] Registering SWP/SWPB emulation handler
[ 2.140569] dmm 4e000000.dmm: initialized all PAT entries
[ 2.147831] ldo4: supplied by VMAIN
[ 2.172308] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.179108] [drm] No driver support for vblank timestamp query.
[ 2.196065] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.310173] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[ 2.324926] EDID block is all zeroes
[ 2.329023] mmcblk0: mmc0:59b4 NCard 15.0 GiB
[ 2.336428] mmcblk0: p1 p2
[ 2.348026] [drm] Enabling DMM ywrap scrolling
[ 2.353469] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 2.390872] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.400529] hctosys: unable to open rtc device (rtc0)
[ 2.421341] mmc1: MAN_BKOPS_EN bit is not set
[ 2.436074] mmc1: new DDR MMC card at address 0001
[ 2.453550] mmcblk1: mmc1:0001 R1J56L 13.8 GiB
[ 2.469566] mmcblk1boot0: mmc1:0001 R1J56L partition 1 4.00 MiB
[ 2.472340] aic_dvdd_fixed: disabling
[ 2.480843] ALSA device list:
[ 2.483972] No soundcards found.
[ 2.490815] mmcblk1boot1: mmc1:0001 R1J56L partition 2 4.00 MiB
[ 2.499308] mmcblk1: p1 p2
[ 2.537889] EDID block is all zeroes
[ 2.593777] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.602161] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.614831] devtmpfs: mounted
[ 2.619816] Freeing unused kernel memory: 336K (c08be000 - c0912000)
[ 2.626238] This architecture does not have kernel memory protection.
[ 2.901022] systemd[1]: System time before build time, advancing clock.
[ 2.959362] random: systemd: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
[ 2.980608] random: systemd: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
[ 3.002251] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.022439] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.10!
[ 3.049515] systemd[1]: Set hostname to <am57xx-evm>.
[ 3.185936] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 3.214161] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 3.225205] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 3.246524] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 3.263976] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[ 3.379212] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 3.392474] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 3.405240] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 4.312686] systemd[1]: basic.target: Found ordering cycle on basic.target/start
[ 4.320321] systemd[1]: basic.target: Found dependency on sysinit.target/start
[ 4.327792] systemd[1]: basic.target: Found dependency on alignment.service/start
[ 4.335394] systemd[1]: basic.target: Found dependency on basic.target/start
[ 4.342639] systemd[1]: basic.target: Breaking ordering cycle by deleting job alignment.service/start
[ 4.352102] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with basic.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 4.401179] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.429373] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.468944] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.498478] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.535181] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.568657] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.599142] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.628335] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.659459] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.688676] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.718458] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.792836] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.818715] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.851824] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.881784] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.918953] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.988518] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.047958] systemd[1]: Starting Load Kernel Modules...
[ 5.086498] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.116318] CMEMK module: reference Linux version 4.4.32
Starting Create list of required st... nodes for the current kernel...[ 5.128586] allocated heap buffer 0x40500000 of size 0x100000
[ 5.142118] cmemk initialized
[ 5.166315] cryptodev: driver 1.8 loaded.
[ 5.189717] systemd[1]: Starting Journal Service...
[ 5.240492] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.290096] systemd[1]: Mounting Debug File System...
[ 5.342163] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.375286] systemd[1]: Starting Setup Virtual Console...
[ 5.472170] systemd[1]: Mounting Temporary Directory...
[ 5.509263] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 5.644732] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 5.658927] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 5.688551] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 5.725808] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 5.763628] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ 5.803687] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 5.844746] systemd[1]: Started Setup Virtual Console.
[ OK ] Started Setup Virtual Console.
[ 5.882722] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
Starting udev Coldplug all Devices...
Starting Flush Journal to Persistent Storage...
Starting Create Static Device Nodes in /dev...
Starting Apply Kernel Variables...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 8.178178] systemd-journald[119]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Mounting /media/ram...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Load/Save Random Seed...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ 11.169577] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[ 11.194267] remoteproc0: 58820000.ipu is available
[ 11.221978] remoteproc0: Note: remoteproc is still under development and considered experimental.
Starting Update UTMP about System Boot/Shutdown...
[ 11.268072] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 11.345537] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
Starting Network Time Synchronization...
[ 11.443539] remoteproc1: 55020000.ipu is available
[ 11.459639] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 11.528941] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 11.559381] remoteproc0: registered virtio0 (type 7)
[ 11.588666] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 11.673869] remoteproc2: 40800000.dsp is available
[ 11.705572] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 11.757830] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 11.818739] remoteproc1: registered virtio1 (type 7)
[ 11.893491] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 11.942476] remoteproc3: 41000000.dsp is available
[ 12.008909] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 12.074134] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Network Time Synchronization.
[ OK ] Started udev Coldplug all Devices.
[ 12.792064] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 12.858637] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 12.883106] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 12.908232] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ OK ] Found device /dev/ttyS2.
[ 13.019095] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 13.315123] adv7180 1-0020: chip found @ 0x20 (OMAP I2C adapter)
[ 13.442386] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
[ 13.457660] aic_dvdd_fixed: supplied by vdd_3v3
[ 13.887780] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
[ 14.044237] remoteproc2: registered virtio2 (type 7)
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 14.289767] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 14.318513] vpe 489d0000.vpe: Device registered as /dev/video0
[ 14.412422] remoteproc3: registered virtio3 (type 7)
[ 14.736537] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 14.765082] vip 48990000.vip: VPDMA firmware loaded
[ 14.788170] vip2-s0: Port A: Using subdev adv7180 1-0020 for capture
[ 14.838518] vip2-s0: device registered as video1
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 16.063812] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 16.109072] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 16.974559] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 17.535603] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 17.655944] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 17.754358] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting Login Service...
[ 17.924268] asoc-simple-card sound@0: cannot find the slot for index 0 (range 0-0), error: -16
Starting Permit User Sessions...[ 17.991346] asoc-simple-card sound@0: ASoC: can't create sound card for card BeagleBoard-X15: -16
Starting uim-sysfs.service...
[ 18.111189] asoc-simple-card: probe of sound@0 failed with error -16
[ 18.191139] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
Starting Print notice about GPLv3 packages...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Started D-Bus System Message Bus.
[ 18.992348] random: nonblocking pool is initialized
[ 19.239453] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 19.271111] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ OK ] Started System Logging Service.
[ 20.143124] NET: Registered protocol family 15
Starting Telephony service...
[ OK ] Started Kernel Logging Service.
Starting Avahi mDNS/DNS-SD Stack...
Starting Save/Restore Sound Card State...
Starting Network Service...
[ 20.980571] Bluetooth: Core ver 2.21
[ 20.984498] NET: Registered protocol family 31
[ 21.044044] Bluetooth: HCI device and connection manager initialized
[ 21.087706] Bluetooth: HCI socket layer initialized
[ 21.092819] Bluetooth: L2CAP socket layer initialized
[ 21.158110] Bluetooth: SCO socket layer initialized
[ OK ] Started Permit User Sessions.
[ OK ] Started Save/Restore Sound Card State.
[ 21.576231] Initializing XFRM netlink socket
[ OK ] Started Network Service.
[ 21.597594] net eth1: initializing cpsw version 1.15 (0)
[ 21.603085] net eth0: initialized cpsw ale version 1.4
[ 21.627825] net eth0: ALE Table size 1024
[ 21.673969] libphy: PHY 48485000.mdio:05 not found
[ 21.716721] net eth1: phy "48485000.mdio:05" not found on slave 1, err -19
[ 21.818524] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 21.892861] net eth0: initializing cpsw version 1.15 (0)
[ 21.946876] libphy: PHY 48485000.mdio:01 not found
[ 21.999242] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
[ 22.095721] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 23.423291] remoteproc0: powering up 58820000.ipu
[ 23.592096] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4890352
[ 23.658028] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 23.854630] remoteproc0: remote processor 58820000.ipu is now up
[ 23.929392] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 23.935167] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 23.969387] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 24.015735] remoteproc1: powering up 55020000.ipu
[ 24.021474] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 24.062808] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 24.187102] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743072
[ 24.246488] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 25.866670] remoteproc1: remote processor 55020000.ipu is now up
[ 26.015010] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 26.018369] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 26.019392] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[ 26.100220] remoteproc2: powering up 40800000.dsp
[ 26.706525] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 21998880
[ 26.761966] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 26.768020] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 26.774204] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 26.993541] remoteproc2: remote processor 40800000.dsp is now up
[ 27.092681] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 27.092842] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ 27.135289] remoteproc3: powering up 41000000.dsp
[ 27.535257] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 21998880
[ 27.573869] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 27.579894] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 27.586160] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 27.824435] remoteproc3: remote processor 41000000.dsp is now up
[ 27.910951] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 27.911123] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 28.054760] usbcore: registered new interface driver usbfs
[ 28.107890] usbcore: registered new interface driver hub
[ 28.142679] NET: Registered protocol family 41
[ 28.143010] rpmsg_rpc rpmsg3: probing service rpc_example_2 with src 1024 dst 101
[ 28.149309] usbcore: registered new device driver usb
[ 28.165673] rpmsg_rpc rpmsg4: probing service dce-callback with src 1024 dst 101
[ 28.165962] rpmsg_rpc rpmsg3: published functions = 8
[ 28.272623] rpmsg_rpc rpmsg5: probing service rpmsg-dce with src 1025 dst 102
[ 28.280326] rpmsg_rpc rpmsg4: published functions = 4
[ 28.286888] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 28.325872] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 28.335265] rpmsg_rpc rpmsg5: published functions = 9
[ 28.388600] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[ 28.424352] xhci-hcd xhci-hcd.1.auto: irq 426, io mem 0x48890000
[ 28.466609] hub 1-0:1.0: USB hub found
[ 28.477923] hub 1-0:1.0: 1 port detected
[ 28.499330] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 28.504953] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 28.537903] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 28.578326] hub 2-0:1.0: USB hub found
[ 28.588636] hub 2-0:1.0: 1 port detected
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils-dev
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
parted
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started Telephony service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Login Service.
[ OK ] Reached target Sound Card.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Network Name Resolution.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ 35.549534] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ OK ] Started rc.pvr.service.
Starting tiipclad-daemon.service...
Starting telnetd.service...
[ OK ] Started tiipclad-daemon.service.
[ OK ] Started telnetd.service.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting gdbserverproxy.service...
[ 37.099631] omap_hwmod: mmu1_dsp1: _wait_target_disable failed
[ 37.122831] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 38.049735] omap_hwmod: mmu1_dsp2: _wait_target_disable failed
[ 38.080555] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am57xx-evm ttyS2
Arago 2016.10 am57xx-evm ttyS2
am57xx-evm login: root
root@am57xx-evm:~# poweroffdmesg | grep sound
[ 17.924082] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound@0[0]'
[ 17.924153] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound@0[0]'
root@am57xx-evm:~#
