Linux: Keystone2 image tree blob support
Tool/software: Linux
    I'd like to know if for c66ak2h is possible boot with a multifile containing monitor+kernel+ramdisk+fdt+fpga+etc...
I have created this its file:
 * U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs
/dts-v1/;
    description = "Various kernels, ramdisks and FDT blobs";
    #address-cells = <1>;
    images {
        uboot {
            description = "U-Boot";
            type = "standalone";
            arch = "arm";
            compression = "none";
            load = <0x0C000000>;
        atf {
            description = "ARM Trusted Firmware";
            type = "firmware";
            arch = "arm";
            load = <0x18000>;
            entry = <0x18000>;
        firmware@1 {
            description = "Boot monitor";
            data = /incbin/("./board-support/boot-monitor-4.0+gitAUTOINC+e1f885ab6d/skern-k2hk");
            type = "firmware";
            arch = "arm";
            load = <0x0c5f0000>;
            entry = <0x0c5f0000>;
            hash@1 {
                algo = "md5";
            hash@2 {
                algo = "sha1";
        firmware@1 {
            description = "Boot monitor2";
            data = /incbin/("./board-support/boot-monitor-4.0+gitAUTOINC+e1f885ab6d/soc/k2hk/s-kernel.out");
            type = "firmware";
            arch = "arm";
            hash@1 {
                algo = "md5";
            hash@2 {
                algo = "sha1";
        firmware@2 {
            description = "Boot monitor3";
            data = /incbin/("./board-support/boot-monitor-4.0+gitAUTOINC+e1f885ab6d/soc/k2hk/nonsec.out");
            type = "firmware";
            arch = "arm";
            hash@1 {
                algo = "md5";
            hash@2 {
                algo = "sha1";
        kernel@1 {
            description = "Board Kernel";
            data = /incbin/("./board-support/linux-rt-4.14.40+gitAUTOINC+d5443cbd3b-gd5443cbd3b/arch/arm/boot/zImage");
            type = "kernel";
            arch = "arm";
            os = "linux";
            load = <0x80000000>;
            entry = <0x80000000>;
            hash@1 {
                algo = "md5";
            hash@2 {
                algo = "sha1";
        kernel@2 {
            description = "Kernel 2.4.25";
            data = /incbin/("./2.4.25Image");
            type = "kernel";
            arch = "arm";
            os = "linux";
            compression = "gzip";
            load = <00000000>;
            entry = <00000000>;
            hash@1 {
                algo = "md5";
        ramdisk@1 {
            description = "Linux ramdisk";
            data = /incbin/("./ramdisk");
            type = "ramdisk";
            arch = "arm";
            os = "linux";
            load = <0x???00000>;
            entry = <0x???00000>;
            hash@1 {
                algo = "sha1";
        initrd {
            description = "Linux initrd";
            type = "ramdisk";
            load = <0x??00000>;
            arch = "arm";
        fdt@1 {
            description = "Board fdt";
            data = /incbin/("./board-support/linux-rt-4.14.40+gitAUTOINC+d5443cbd3b-gd5443cbd3b/arch/arm/boot/dts/keystone-k2hk-evm.dtb");
            type = "flat_dt";
            load = <0x87000000>;
            arch = "arm";
            hash@1 {
                algo = "crc32";
        fpga@1 {
            description = "FPGA";
            data = /incbin/("/tftpboot/download.bit");
            type = "fpga";
            arch = "arm";
            load = <0x90000000>;
            hash@1 {
                algo = "md5";
    configurations {
        default = "config@1";
        config@1{
            description ="Board conf1";
            /*loadables = "uboot", "atf", "kernel", "initrd";*/
            loadables = "firmware@1", "kernel@1", "fdt@1";
            kernel = "kernel@1";
            firmware = "firmware@1";
            /*ramdisk = "ramdisk@1";*/
            fdt = "fdt@1";
            /*fpga = "fpga@1";*/
The output file is:
@@@@@@@@@@@@@@@@@@@@@@@ Multi @@@@@@@@@@@@@@@@@@@@@@@@
Warning (unit_address_vs_reg): Node /images/firmware@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/firmware@1/hash@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/firmware@1/hash@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/kernel@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/kernel@1/hash@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/kernel@1/hash@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /images/fdt@1/hash@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /configurations/config@1 has a unit name, but no reg property
FIT description: Various kernels, ramdisks and FDT blobs
Created:         Fri Feb 15 13:49:07 2019
 Image 0 (firmware@1)
  Description:  Boot monitor
  Type:         Firmware
  Compression:  uncompressed
  Data Size:    32768 Bytes = 32.00 KiB = 0.03 MiB
  Architecture: ARM
  Load Address: 0x0c5f0000
  Hash algo:    md5
  Hash value:   00b5d2d6da793f96d5bc392d14382e05
  Hash algo:    sha1
  Hash value:   29bdfafd03f3075ead0cd69382e22e22bbc46e00
 Image 1 (kernel@1)
  Description:  Board Kernel
  Type:         Kernel Image
  Data Size:    3850752 Bytes = 3760.50 KiB = 3.67 MiB
  Architecture: ARM
  OS:           Linux
  Load Address: 0x80000000
  Entry Point:  0x80000000
  Hash algo:    md5
  Hash value:   1ca6cff3788a8eb9561469d34c468ef2
  Hash algo:    sha1
  Hash value:   a75ccc5e86990e863e9d7388f87550e2c4af2b3d
 Image 2 (fdt@1)
  Description:  Board fdt
  Type:         Flat Device Tree
  Data Size:    39118 Bytes = 38.20 KiB = 0.04 MiB
  Architecture: ARM
  Load Address: 0x87000000
  Hash algo:    crc32
  Hash value:   dea8228d
 Default Configuration: 'config@1'
 Configuration 0 (config@1)
  Description:  Board conf1
  Kernel:       kernel@1
  FDT:          fdt@1
  Loadables:    firmware@1
                kernel@1
                fdt@1
The image is created and downloaded on board, but I can't find any command to use to run before the firmware (boot monitor) and then Linux.
Is it possible have a u-boot script to load monitor (and others parts)? and the command to do in u-boot shell to start thet script?
The Uboot version is:
U-Boot 2018.01-gc02be9e (Feb 14 2019 - 17:43:37 +0100)
env default -f -a
setenv ipaddr 192.168.99.23
setenv serverip 192.168.99.24
setenv nfs_root 192.168.99.24
setenv boot net
setenv tftp_root /tftpboot
setenv nfs_root /export..../targetNFS
setenv fdtaddr 0x87000000
setenv addr_mon 0x0c5f0000
setenv loadaddr 0x88000000
setenv get_kern_net tftpboot \${loadaddr} \${tftp_root}/\${name_kern}
run get_kern_net
setenv name_kern Board_multi.itb
boot
I have tried the following boot commands:
bootm ${addr_mon}
bootm ${loadaddr} - ${fdtaddr}
And that the command is not supported (I suppose):
bootm {addr_mon}:firmware@1#config@1
=> run get_kern_net
netcp@2000000 Waiting for SGMII auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
*** Unhandled DHCP Option in OFFER/ACK: 44
DHCP client bound to address 192.168.99.23 (355 ms)
Using netcp@2000000 device
TFTP from server 192.168.99.24; our IP address is 192.168.99.23
Filename '/tftpboot/Board_multi.itb'.
Load address: 0x88000000
Loading: #################################################################
         3 MiB/s
done
Bytes transferred = 3924714 (3be2ea hex)
=> bootm 0x80000000:kernel@1#config@1
Wrong Image Format for bootm command
ERROR: can't get kernel image!
=> bootm 0x88000000:kernel@1
## Loading kernel from FIT Image at 88000000 ...
   Trying 'kernel@1' kernel subimage
     Description:  DRSP Kernel
     Created:      2019-02-15  12:49:07 UTC
     Type:         Kernel Image
     Data Start:   0x880081f0
     Data Size:    3850752 Bytes = 3.7 MiB
     Architecture: ARM
     OS:           Linux
     Hash algo:    md5
     Hash algo:    sha1
   Verifying Hash Integrity ... md5+ sha1+ OK
   Loading Kernel Image ... OK
Starting kernel ...
Nothing else.
Dario
    Could you share which Processor SDK Linux is this?
    Yordan
    I'm sorry I have forgotten this info:
    ti-processor-sdk-linux-rt-k2hk-evm-05.00.00.15
    Is enought? I think so.
    I have forgotten this command:
    setenv name_kern /tftpboot/Board_multi.itb
    I have also tried the following commands but fails anyway :
    => bootm 0x0c5f0000:firmware@1
    => bootm 0x0c5f0000:firmware@1#kernel@1
    => bootm 0x0c5f0000:firmware@1#config@1
    => bootm 0x0c5f0000#config@1
    Dario
    I think to have found the correct sequence:
    setenv default -f -a
    setenv hostname EVM
    setenv boot net
    setenv nfs_root /export/..../targetNFS
    setenv autostart no
    #monitor compileld with DEBUG=1
    setenv image_name Image_multi.itb
    setenv get_mon_net tftpboot \${loadaddr} \${tftp_root}/\${image_name}; imxtract \${loadaddr} firmware@1 \${addr_mon}
    setenv get_fdt_net imxtract \${loadaddr} fdt@1 \${fdtaddr}
    setenv get_kern_net imxtract \${loadaddr} kernel@1 0x80000000
    setenv run_mon_net go \${addr_mon}
    setenv run_kern_net bootm \${loadaddr} - \${fdtaddr}
    run init_${boot}
    run get_mon_net
    run run_mon_net
    run get_fdt_net
    run get_kern_net
    run run_kern_net
    The its ffile is:
    /dts-v1/;
    images {
    uboot {
    arch = "arm";
    firmware@1 {
    type = "firmware";
    arch = "arm";
    hash@1 {
    algo = "md5";
    hash@2 {
    algo = "sha1";
    kernel@1 {
    type = "kernel";
    arch = "arm";
    os = "linux";
    hash@1 {
    algo = "md5";
    hash@2 {
    algo = "sha1";
    ramdisk@1 {
    description = "Board ramdisk";
    type = "ramdisk";
    arch = "arm";
    os = "linux";
    load = <0x??000000>;
    entry = <0x??000000>;
    hash@1 {
    algo = "sha1";
    initrd {
    type = "ramdisk";
    load = <0x???0000>;
    arch = "arm";
    fdt@1 {
    type = "flat_dt";
    arch = "arm";
    hash@1 {
    algo = "crc32";
    fpga@1 {
    type = "fpga";
    arch = "arm";
    load = <0x30000000>;
    hash@1 {
    algo = "md5";
    configurations {
    config@2{
    description = "Board conf2";
    loadables = "firmware@1";
    config@1{
    description = "Board conf1";
    fdt = "fdt@1";
    For now starts but slowly, too slowly...
    Created: 2019-02-15 15:46:14 UTC
    Type: Kernel Image
    Architecture: ARM
    OS: Linux
    Hash algo: md5
    Hash algo: sha1
    ## Flattened Device Tree blob at 87000000
    Booting using the fdt blob at 0x87000000
    Loading Device Tree to 8fff3000, end 8ffff8cd ... OK
    Starting kernel ...
    DEBUG: >>>> skern_poweron_cpu(1) >>>>
    DEBUG: Message2 from Secure Mode: Core freq - -34707204Hz
    DEBUG: >>>> skern_poweron_cpu(2) >>>>
    DEBUG: >>>> skern_poweron_cpu(3) >>>>
    [ 0.000000] Booting Linux on physical CPU 0x0
    [ 0.000000] Linux version 4.14.40-rt29-gd5443cbd3b (xxxxxx) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT RT Thu Feb 14 12:33:14 CET 2019
    [ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
    [ 0.000000] CPU: div instructions available: patching division code
    Have you any idea for this problem?
    negative number, yesterday with more files I have seen this line:
    DEBUG: Message2 from Secure Mode: Core freq - 200000000Hz
    Dario
  • Hi again,
        I have solved the speed problem, in its file:
    data = /incbin/("./board-support/boot-monitor-4.0+gitAUTOINC+e1f885ab6d/skern-k2hk.bin");
    And in uboot shell now is possible to call the uboot mon_install command and set the correct speed:
    setenv run_mon_net mon_install \${addr_mon}
    In minicom shell:
    Starting kernel ...
    Dario
