Hi everyone,
I'm currently using an evm5515 board with tms320c5515 on it. And I'm using CodeComposer v6.2.
I'm new to DSP programming and I'm interfacing for the first time with hwafft. I need to take a 8192 points fourier transform. I know that is possible with multiple 2-radix FFT stages with 1024pts fft, but I don't know what files the program needs.
I saw the 4096pts example but it's not very useful, because it doesn't work (I found on the forum 3 file: test.c, test.cmd and twid4096.asm but I need more files for the program to run correctly).
If possible, I wanted to know how to assign the twiddle factor table to a pointer and how to create a twiddle factor table for 8192 points, if not already available somewhere else...
A working example with all the files it needs would be very useful.
Thank you very much!
Hi, thank's for the answer.
But I already read the sprabb6b document and even the 8k thread didn't answer my questions. I know how to perform a greater-than-1024 fourier transform but I don't know how to define the Twiddle parameter in the function. I know there is twid4096.asm, however the parameter Twiddle isn't linked with it. When I run the function and display Twiddle vector (or in the case of my function twiddle_buf) the program says that it's full of zeros because it can't track down the address where the asm file store the values. I dont' know the assembly code but for what I know the twid4096.asm file store the values in a section of the memory that it call ".twiddle" and then it should link the pointer "twiddle" to that section. But it doesn't find it.
Maybe it's something very stupid but I am new to this kind of programs.
Please, I need an answer to this problem...
We have tried to copy the values of twid4096.asm into a vector but it doesn't seem like the correct method.
