Linux/TDA2: FLASHING TOOLS
Part Number: TDA2
Tool/software: Linux
Dear All,
I would like to know some of the below question answers
Q1:Way of flashing NAND/NOR for TDA2x evm - is there any tool ?
Q2:What is the size of MLO, uboot, linux and filesystem, - running on our current TDA2x EVM and also on D3 board.
Q3:Current DDR3 memory usage on TDA2x evm needs to be found
Q4: List of various drivers involved in TDA2x evm linux - eg: i2c, usb, camera, hdmi and so on…
    I'll let software teams comment regarding your other questions. But for Q1, one way to do it is via the flash tool. Here are a couple related forum posts:
    Alex
    Q2: here are some example sizes:
    MLO: 125K ; u-boot.img: 819K ; zImage: 3.4M
    note that this sizes may vary based on your config.
    the default rootfs from here:
    software-dl.ti.com/.../index_FDS.html
    has size 296M, you can add more features to it and size will increase.
    Q3: Please follow the document <VSDK_INST_DIR>/vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_UserGuide_MemoryMap.pdf for description of how to configure memory in VisionSDK. The default Linux configuration for TDA2x is 1GB.
    Q4: Linux version of VisionSDK is based on Processor SDK Linux Automotive (PSDKLA), so you can check the supported features in the Data Sheet:
    processors.wiki.ti.com/index.php
    Also helpful can be PSDKLA Developer guide and FAQ:
    Please let me know if you have any further questions.
    Yordan
  • Hello Yordan,
    RA72x Evaluation module is same a TDA2x EVM?
    i.e processors.wiki.ti.com/index.php
    I have a some more question on TDA2x board, please find below list .
    Q5:compile procedure for TDA2x rootfile system/Linux/Uboot?
    Q6:How to choose MLO for TDA2x? is it processor specific ?
    Q7:Flashing MLO/UBOOT/KERNEL/ROOTFS on NAND/NOR memory procedure?
    Q8:TDA2x EVM peripheral like i2c,spi,.... all soc peripherals test suite either unit/system testing procedure?
    Raghu
  • Raghu,
    Are you using Vision SDK? If so please follow the user guides provided along the SDK. There is a lot of information to answer your general questions above.
    thanks,
    Alex
  • Hello Alex,
    I am using vision DSK, but below some question required more information or any link to cover below please send me.
    Raghu
  • Hi Raghu,
    can you check here for flashing to NAND:
    processors.wiki.ti.com/.../Linux_Core_U-Boot_User's_Guide
    Yordan
