Linux/BEAGLEBN: PWM not working
Part Number: BEAGLEBN
Tool/software: Linux
I have tried to get PWM working and am not having any success. I am using the TI SDK with a modified version of the am335x-boneblack.dts device tree (see below)
The PWM driver (ehrpwm1) probes correctly and appears in /sys/class/pwm/pwmchip0. Then, I configured the chip
cd /sys/class/pwm/pwmchip0
echo 0 > export
echo 1000000 > pwm0/period
echo 250000 > pwm0/duty_cycle
echo 1 > pwm0/enable
However, there is no PWM output. Am I missing something obvious?
/dts-v1/;
#include "am33xx.dtsi"
#include "am335x-bone-common.dtsi"
	model = "TI AM335x BeagleBone Black";
	compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
&ldo3_reg {
	regulator-min-microvolt = <1800000>;
	regulator-max-microvolt = <1800000>;
	regulator-always-on;
&mmc1 {
	vmmc-supply = <&vmmcsd_fixed>;
&mmc2 {
	pinctrl-names = "default";
	pinctrl-0 = <&emmc_pins>;
	bus-width = <8>;
	status = "okay";
&am33xx_pinmux {
	lcd_pins: lcd_pins {
		pinctrl-single,pins = <
			AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0) /* P9.45, lcd_data0 */
			AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0) /* P9.46, lcd_data1 */
			AM33XX_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0) /* P9.43, lcd_data2 */
			AM33XX_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0) /* P9.44, lcd_data3 */
			AM33XX_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0) /* P9.41, lcd_data4 */
			AM33XX_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0) /* P9.42, lcd_data5 */
			AM33XX_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0) /* P9.39, lcd_data6 */
			AM33XX_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0) /* P9.40, lcd_data7 */
			AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0) /* P9.37, lcd_data8 */
			AM33XX_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0) /* P9.38, lcd_data9 */
			AM33XX_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0) /* P9.36, lcd_data10 */
			AM33XX_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0) /* P9.34, lcd_data11 */
			AM33XX_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0) /* P9.35, lcd_data12 */
			AM33XX_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0) /* P9.33, lcd_data13 */
			AM33XX_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0) /* P9.31, lcd_data14 */
			AM33XX_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0) /* P9.32, lcd_data15 */
			AM33XX_IOPAD(0x820, PIN_OUTPUT | MUX_MODE1) /* P9.19, lcd_data23 */
			AM33XX_IOPAD(0x824, PIN_OUTPUT | MUX_MODE1) /* P9.13, lcd_data22 */
			AM33XX_IOPAD(0x828, PIN_OUTPUT | MUX_MODE1) /* P9.14, lcd_data21 */
			AM33XX_IOPAD(0x82c, PIN_OUTPUT | MUX_MODE1) /* P9.17, lcd_data20 */
			AM33XX_IOPAD(0x830, PIN_OUTPUT | MUX_MODE1) /* P9.12, lcd_data19 */
			AM33XX_IOPAD(0x834, PIN_OUTPUT | MUX_MODE1) /* P9.11, lcd_data18 */
			AM33XX_IOPAD(0x838, PIN_OUTPUT | MUX_MODE1) /* P9.16, lcd_data17 */
			AM33XX_IOPAD(0x83c, PIN_OUTPUT | MUX_MODE1) /* P9.15, lcd_data16 */
			AM33XX_IOPAD(0x8e0, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* P9.27, lcd_vsync */
			AM33XX_IOPAD(0x8e4, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* P9.29, lcd_hsync */
			AM33XX_IOPAD(0x8e8, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* P9.28, lcd_pclk */
			AM33XX_IOPAD(0x8ec, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* P9.30, lcd_ac_bias_en */
			/* LCD enable */
			AM33XX_IOPAD(0x88c, PIN_OUTPUT_PULLUP | MUX_MODE7) /* P8.19, gpio2[1] */
	backlight_pin: backlight_pin {
		pinctrl-single,pins = < AM33XX_IOPAD(0x848, PIN_OUTPUT | MUX_MODE6) >; /* P9.14, gpio1[18] */
	touchscreen_pins: touchscreen_pins {
		pinctrl-single,pins = < AM33XX_IOPAD(0x9a4, PIN_INPUT_PULLUP | MUX_MODE7) >; /* P9.27, gpio3[19] */
	dcan0_pins: dcan0_pins {
			AM33XX_IOPAD(0x97c, PIN_INPUT_PULLUP | MUX_MODE2) /* P9.19, ddcan0_rx */
			AM33XX_IOPAD(0x978, PIN_OUTPUT_PULLUP | MUX_MODE2) /* P9.20, ddcan0_tx */
	uart1_pins: uart1_pins {
			AM33XX_IOPAD(0x980, PIN_INPUT_PULLUP | MUX_MODE0) /* P9.26, uart1_rxd */
			AM33XX_IOPAD(0x984, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* P9.24, uart1_txd */
	uart2_pins: uart2_pins {
			AM33XX_IOPAD(0x950, PIN_INPUT_PULLUP | MUX_MODE1) /* P9.22, uart2_rxd */
			AM33XX_IOPAD(0x954, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* P9.21, uart2_txd */
	uart4_pins: uart4_pins {
			AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE6) /* P9.11, uart4_rxd */
			AM33XX_IOPAD(0x874, PIN_OUTPUT_PULLDOWN | MUX_MODE6) /* P9.13, uart4_txd */
	uart5_pins: uart5_pins {
			AM33XX_IOPAD(0x8c4, PIN_INPUT_PULLUP | MUX_MODE4) /* P8.38, uart5_rxd */
			AM33XX_IOPAD(0x8c0, PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* P8.37, uart5_txd */
	ehrpwm1_pins: ehrpwm1_pins {
			AM33XX_IOPAD(0x848, PIN_OUTPUT | MUX_MODE6) /* P9.14, EHRPWM1A */
			AM33XX_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE6) /* P9.16, EHRPWM1B */
&epwmss1 {
	status = "okay";
&ehrpwm1 {
	pinctrl-name = "default";
	pinctrl-0 = <&backlight_pin>;
	status = "okay";
&lcdc {
	status = "okay";
	blue-and-red-wiring = "crossed";
&sgx {
	status = "okay";
	lcd0: display {
		status = "okay";
		compatible = "ti,tilcdc,panel";
		label = "lcd";
		pinctrl-0 = <&lcd_pins>;
		enable-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>; /* P8.19 */
		panel-info {
			ac-bias = <255>;
			ac-bias-intrpt = <0>;
			dma-burst-sz = <16>;
			bpp = <32>;
			fdd = <0x80>;
			sync-edge = <0>;
			sync-ctrl = <0>;
			raster-order = <0>;
			fifo-th = <0>;
		display-timings {
			native-mode = <&timing0>;
			timing0: 800x480 {
				clock-frequency = <45000000>;
				hactive = <800>;
				vactive = <480>;
				hfront-porch = <40>;
				hback-porch = <40>;
				hsync-len = <48>;
				vback-porch = <29>;
				vfront-porch = <13>;
				vsync-len = <3>;
				hsync-active = <0>;
				vsync-active = <0>;
&i2c2 {
	polytouch: edt-ft5x06@38 {
		compatible = "edt,edt-ft5406", "edt,edt-ft5x06";
		reg = <0x38>;
		pinctrl-0 = <&touchscreen_pins>;
		interrupt-parent = <&gpio3>;
		interrupts = <19 0>; /* P9.27 */
		touchscreen-size-x = <799>;
		touchscreen-size-y = <479>;
		xfuzz = <0>;
		yfuzz = <0>;
&rtc {
	system-power-controller;
&dcan0 {
	status = "okay";
	pinctrl-0 = <&dcan0_pins>;
&uart1 {
	status = "okay";
	pinctrl-0 = <&uart1_pins>;
&uart2 {
	status = "okay";
	pinctrl-0 = <&uart2_pins>;
&uart4 {
	status = "okay";
	pinctrl-0 = <&uart4_pins>;
