Linux/DRA74: Linux: APPE 'per-channel EQ ' algorithm bug
Part Number: DRA74
Tool/software: Linux
In our system , VIS version " REL.VIS.01.50.23.01" , we have some test on APPE algorithm.We change Ch distribution from 5.1to 7.1(CHAN_CFG_8CHANNEL_SURROUND2). But in "per-channel EQ " test ; and two of eight CHs(Ls & Rb),the only fifth frequency band (about 512Hz ) , EQ don't work ,other bands are OK .Parameters we set on the RadioApp command line. I readback theparameter (I have writen) is OK by command line tool .
  • 01-01 08:41:36.782   386   403 E audio_appe: CLI:z 0 eqmultbndgn 6 6.0 -6.0 6.0 -6.0 6.0 -6.0 6.0 -6.0 6.0 -6.0
    01-01 08:41:36.783   386   402 E audio_appe:
    01-01 08:41:36.783   386   401 E audio_appe:
    01-01 08:41:36.783   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:41:36.807   386   402 E audio_appe: Algo Set params done
    01-01 08:41:43.848   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 65536 65536 65536 65536 65536 65536 65536 65536 65536
    01-01 08:41:43.849   386   402 E audio_appe:
    01-01 08:41:43.849   386   401 E audio_appe:
    01-01 08:41:43.849   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:41:43.865   386   402 E audio_appe: Algo Set params done
    01-01 08:41:48.515   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 65536 65536 65536 65536 65536 65536 65536 65536
    01-01 08:41:48.515   386   402 E audio_appe:
    01-01 08:41:48.515   386   401 E audio_appe:
    01-01 08:41:48.515   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:41:48.556   386   402 E audio_appe: Algo Set params done
    01-01 08:41:55.950   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 65536 65536 65536 65536 65536 65536 65536
    01-01 08:41:55.950   386   402 E audio_appe:
    01-01 08:41:55.950   386   401 E audio_appe:
    01-01 08:41:55.950   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:41:55.986   386   402 E audio_appe: Algo Set params done
    01-01 08:42:00.467   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 65536 65536 65536 65536 65536 65536
    01-01 08:42:00.467   386   402 E audio_appe:
    01-01 08:42:00.467   386   401 E audio_appe:
    01-01 08:42:00.467   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:00.493   386   402 E audio_appe: Algo Set params done
    01-01 08:42:04.932   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 65536 65536 65536 65536 65536
    01-01 08:42:04.932   386   402 E audio_appe:
    01-01 08:42:04.932   386   401 E audio_appe:
    01-01 08:42:04.932   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:04.949   386   402 E audio_appe: Algo Set params done
    01-01 08:42:09.214   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 262144 65536 65536 65536 65536
    01-01 08:42:09.215   386   402 E audio_appe:
    01-01 08:42:09.215   386   401 E audio_appe:
    01-01 08:42:09.215   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:09.221   386   402 E audio_appe: Algo Set params done
    01-01 08:42:13.516   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 262144 262144 65536 65536 65536
    01-01 08:42:13.516   386   402 E audio_appe:
    01-01 08:42:13.516   386   401 E audio_appe:
    01-01 08:42:13.516   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:13.543   386   402 E audio_appe: Algo Set params done
    01-01 08:42:18.232   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 262144 262144 262144 65536 65536
    01-01 08:42:18.232   386   402 E audio_appe:
    01-01 08:42:18.232   386   401 E audio_appe:
    01-01 08:42:18.232   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:18.285   386   402 E audio_appe: Algo Set params done
    01-01 08:42:22.948   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 262144 262144 262144 262144 65536
    01-01 08:42:22.948   386   402 E audio_appe:
    01-01 08:42:22.948   386   401 E audio_appe:
    01-01 08:42:22.948   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:22.967   386   402 E audio_appe: Algo Set params done
    01-01 08:42:30.381   386   403 E audio_appe: CLI:z 0 eqmultbndq 6 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144
    01-01 08:42:30.381   386   402 E audio_appe:
    01-01 08:42:30.382   386   401 E audio_appe:
    01-01 08:42:30.382   386   401 E audio_appe: SV: SV_SET_AUDIO_ALG
    01-01 08:42:30.397   386   402 E audio_appe: Algo Set params done
    01-01 08:49:43.196   386   403 E audio_appe: CLI:z 0 eqmultstatus
    01-01 08:49:43.196   386   402 E audio_appe:
    01-01 08:49:43.196   386   401 E audio_appe:
    01-01 08:49:43.196   386   401 E audio_appe: SV: SV_GET_AUDIO_ALG
    01-01 08:49:43.202   386   402 E audio_appe: Speaker Equalizer Status
    01-01 08:49:43.202   386   402 E audio_appe: ========================
    01-01 08:49:43.202   386   402 E audio_appe: Size           = 992
    01-01 08:49:43.202   386   402 E audio_appe: Number of Bands= 10
    01-01 08:49:43.202   386   402 E audio_appe: SampleRate     = 44100 Hz
    01-01 08:49:43.202   386   402 E audio_appe: ProcessChan    = 255
    01-01 08:49:43.202   386   402 E audio_appe: BandGains:
    01-01 08:49:43.202   386   402 E audio_appe: ----------
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 0 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 1 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 2 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 3 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 4 = 6.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 5 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 6 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 7 = 6.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 8 = 0.0 dB
    01-01 08:49:43.202   386   402 E audio_appe: Channel 0, Band 9 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 0 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 1 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 2 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 3 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 4 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 5 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 6 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 7 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 8 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 1, Band 9 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 0 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 1 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 2 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 3 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 4 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 5 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 6 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 7 = 0.0 dB
    01-01 08:49:43.204   386   402 E audio_appe: Channel 2, Band 8 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 2, Band 9 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 0 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 1 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 2 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 3 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 4 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 5 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 6 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 7 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 8 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 3, Band 9 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 0 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 1 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 2 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 3 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 4 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 5 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 6 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 7 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 8 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 4, Band 9 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 0 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 1 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 2 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 3 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 4 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 5 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 6 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 7 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 8 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 5, Band 9 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 0 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 1 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 2 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 3 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 4 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 5 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 6 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 7 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 8 = 6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 6, Band 9 = -6.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 0 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 1 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 2 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 3 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 4 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 5 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 6 = 0.0 dB
    01-01 08:49:43.205   386   402 E audio_appe: Channel 7, Band 7 = 0.0 dB
    01-01 08:49:43.206   386   402 E audio_appe: Channel 7, Band 8 = 0.0 dB
    01-01 08:49:43.206   386   402 E audio_appe: Channel 7, Band 9 = 0.0 dB
    01-01 08:49:43.206   386   402 E audio_appe: Band Center Frequncy:
    01-01 08:49:43.206   386   402 E audio_appe: ---------------------
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 3 = 256 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 4 = 512 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 5 = 1024 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 6 = 2048 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 7 = 4096 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 8 = 8192 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 0, Band 9 = 16384 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 3 = 256 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 4 = 512 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 5 = 1024 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 6 = 2048 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 7 = 4096 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 8 = 8192 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 1, Band 9 = 16384 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 3 = 256 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 4 = 512 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 5 = 1024 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 6 = 2048 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 7 = 4096 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 8 = 8192 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 2, Band 9 = 16384 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 3 = 256 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 4 = 512 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 5 = 1024 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 6 = 2048 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 7 = 4096 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 8 = 8192 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 3, Band 9 = 16384 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 3 = 256 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 4 = 512 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 5 = 1024 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 6 = 2048 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 7 = 4096 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 8 = 8192 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 4, Band 9 = 16384 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 5, Band 0 = 32 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 5, Band 1 = 64 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 5, Band 2 = 128 Hz
    01-01 08:49:43.206   386   402 E audio_appe: Channel 5, Band 3 = 256 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 4 = 512 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 5 = 1024 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 6 = 2048 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 7 = 4096 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 8 = 8192 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 5, Band 9 = 16384 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 0 = 32 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 1 = 64 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 2 = 128 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 3 = 256 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 4 = 512 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 5 = 1024 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 6 = 2048 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 7 = 4096 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 8 = 8192 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 6, Band 9 = 16384 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 0 = 32 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 1 = 64 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 2 = 128 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 3 = 256 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 4 = 512 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 5 = 1024 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 6 = 2048 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 7 = 4096 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 8 = 8192 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Channel 7, Band 9 = 16384 Hz
    01-01 08:49:43.207   386   402 E audio_appe: Band Quality Factor:
    01-01 08:49:43.207   386   402 E audio_appe: --------------------
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 0 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 1 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 2 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 3 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 4 = 4.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 5 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 6 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 7 = 4.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 8 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 0, Band 9 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 0 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 1 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 2 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 3 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 4 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 5 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 6 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 7 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 8 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 1, Band 9 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 2, Band 0 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 2, Band 1 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 2, Band 2 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 2, Band 3 = 1.000
    01-01 08:49:43.207   386   402 E audio_appe: Channel 2, Band 4 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 2, Band 5 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 2, Band 6 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 2, Band 7 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 2, Band 8 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 2, Band 9 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 0 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 1 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 2 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 3 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 4 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 5 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 6 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 7 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 8 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 3, Band 9 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 0 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 1 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 2 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 3 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 4 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 5 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 6 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 7 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 8 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 4, Band 9 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 0 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 1 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 2 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 3 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 4 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 5 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 6 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 7 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 8 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 5, Band 9 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 0 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 1 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 2 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 3 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 4 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 5 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 6 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 7 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 8 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 6, Band 9 = 4.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 0 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 1 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 2 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 3 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 4 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 5 = 1.000
    01-01 08:49:43.208   386   402 E audio_appe: Channel 7, Band 6 = 1.000
    01-01 08:49:43.209   386   402 E audio_appe: Channel 7, Band 7 = 1.000
    01-01 08:49:43.209   386   402 E audio_appe: Channel 7, Band 8 = 1.000
    01-01 08:49:43.209   386   402 E audio_appe: Channel 7, Band 9 = 1.000
    01-01 08:49:43.209   386   402 E audio_appe: Channel 0 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 1 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 2 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 3 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 4 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 5 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 6 Band Inversion BitMask = 0x0
    01-01 08:49:43.209   386   402 E audio_appe: Channel 7 Band Inversion BitMask = 0x0
    01-01 08:50:40.818   386   403 E audio_appe: CLI:z 0 eqmultstatus
    01-01 08:50:40.819   386   402 E audio_appe:
    01-01 08:50:40.819   386   401 E audio_appe:
    01-01 08:50:40.819   386   401 E audio_appe: SV: SV_GET_AUDIO_ALG
    01-01 08:50:40.833   386   402 E audio_appe: Speaker Equalizer Status
    01-01 08:50:40.833   386   402 E audio_appe: ========================
    01-01 08:50:40.833   386   402 E audio_appe: Size           = 992
    01-01 08:50:40.833   386   402 E audio_appe: Number of Bands= 10
    01-01 08:50:40.833   386   402 E audio_appe: SampleRate     = 44100 Hz
    01-01 08:50:40.833   386   402 E audio_appe: ProcessChan    = 255
    01-01 08:50:40.833   386   402 E audio_appe: BandGains:
    01-01 08:50:40.833   386   402 E audio_appe: ----------
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 0 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 1 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 2 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 3 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 4 = 6.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 5 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 6 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 7 = 6.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 8 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 0, Band 9 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 0 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 1 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 2 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 3 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 4 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 5 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 6 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 7 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 8 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 1, Band 9 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 2, Band 0 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 2, Band 1 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 2, Band 2 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 2, Band 3 = 0.0 dB
    01-01 08:50:40.833   386   402 E audio_appe: Channel 2, Band 4 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 2, Band 5 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 2, Band 6 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 2, Band 7 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 2, Band 8 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 2, Band 9 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 0 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 1 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 2 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 3 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 4 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 5 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 6 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 7 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 8 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 3, Band 9 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 0 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 1 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 2 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 3 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 4 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 5 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 6 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 7 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 8 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 4, Band 9 = 0.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 0 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 1 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 2 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 3 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 4 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 5 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 6 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 7 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 8 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 5, Band 9 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 0 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 1 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 2 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 3 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 4 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 5 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 6 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 7 = -6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 8 = 6.0 dB
    01-01 08:50:40.834   386   402 E audio_appe: Channel 6, Band 9 = -6.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 0 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 1 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 2 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 3 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 4 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 5 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 6 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 7 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 8 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Channel 7, Band 9 = 0.0 dB
    01-01 08:50:40.835   386   402 E audio_appe: Band Center Frequncy:
    01-01 08:50:40.835   386   402 E audio_appe: ---------------------
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 0 = 32 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 1 = 64 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 2 = 128 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 3 = 256 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 4 = 512 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 5 = 1024 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 6 = 2048 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 7 = 4096 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 8 = 8192 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 0, Band 9 = 16384 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 0 = 32 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 1 = 64 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 2 = 128 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 3 = 256 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 4 = 512 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 5 = 1024 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 6 = 2048 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 7 = 4096 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 8 = 8192 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 1, Band 9 = 16384 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 0 = 32 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 1 = 64 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 2 = 128 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 3 = 256 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 4 = 512 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 5 = 1024 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 6 = 2048 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 7 = 4096 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 8 = 8192 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 2, Band 9 = 16384 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 0 = 32 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 1 = 64 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 2 = 128 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 3 = 256 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 4 = 512 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 5 = 1024 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 6 = 2048 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 7 = 4096 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 8 = 8192 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 3, Band 9 = 16384 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 4, Band 0 = 32 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 4, Band 1 = 64 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 4, Band 2 = 128 Hz
    01-01 08:50:40.835   386   402 E audio_appe: Channel 4, Band 3 = 256 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 4 = 512 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 5 = 1024 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 6 = 2048 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 7 = 4096 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 8 = 8192 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 4, Band 9 = 16384 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 0 = 32 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 1 = 64 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 2 = 128 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 3 = 256 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 4 = 512 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 5 = 1024 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 6 = 2048 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 7 = 4096 Hz
    01-01 08:50:40.836   386   402 E audio_appe: Channel 5, Band 8 = 8192 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 5, Band 9 = 16384 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 0 = 32 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 1 = 64 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 2 = 128 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 3 = 256 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 4 = 512 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 5 = 1024 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 6 = 2048 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 7 = 4096 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 8 = 8192 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 6, Band 9 = 16384 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 0 = 32 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 1 = 64 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 2 = 128 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 3 = 256 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 4 = 512 Hz
    01-01 08:50:40.837   386   402 E audio_appe: Channel 7, Band 5 = 1024 Hz
    01-01 08:50:40.838   386   402 E audio_appe: Channel 7, Band 6 = 2048 Hz
    01-01 08:50:40.838   386   402 E audio_appe: Channel 7, Band 7 = 4096 Hz
    01-01 08:50:40.838   386   402 E audio_appe: Channel 7, Band 8 = 8192 Hz
    01-01 08:50:40.838   386   402 E audio_appe: Channel 7, Band 9 = 16384 Hz
    01-01 08:50:40.838   386   402 E audio_appe: Band Quality Factor:
    01-01 08:50:40.838   386   402 E audio_appe: --------------------
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 0 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 1 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 2 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 3 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 4 = 4.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 5 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 6 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 7 = 4.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 8 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 0, Band 9 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 0 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 1 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 2 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 3 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 4 = 1.000
    01-01 08:50:40.838   386   402 E audio_appe: Channel 1, Band 5 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 1, Band 6 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 1, Band 7 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 1, Band 8 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 1, Band 9 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 0 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 1 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 2 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 3 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 4 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 5 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 6 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 7 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 8 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 2, Band 9 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 0 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 1 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 2 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 3 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 4 = 4.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 5 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 6 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 7 = 4.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 8 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 3, Band 9 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 4, Band 0 = 1.000
    01-01 08:50:40.839   386   402 E audio_appe: Channel 4, Band 1 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 2 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 3 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 4 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 5 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 6 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 7 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 8 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 4, Band 9 = 1.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 0 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 1 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 2 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 3 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 4 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 5 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 6 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 7 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 8 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 5, Band 9 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 0 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 1 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 2 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 3 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 4 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 5 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 6 = 4.000
    01-01 08:50:40.840   386   402 E audio_appe: Channel 6, Band 7 = 4.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 6, Band 8 = 4.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 6, Band 9 = 4.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 0 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 1 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 2 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 3 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 4 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 5 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 6 = 1.000
    01-01 08:50:40.841   386   402 E audio_appe: Channel 7, Band 7 = 1.000
    01-01 08:50:40.842   386   402 E audio_appe: Channel 7, Band 8 = 1.000
    01-01 08:50:40.842   386   402 E audio_appe: Channel 7, Band 9 = 1.000
    01-01 08:50:40.842   386   402 E audio_appe: Channel 0 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 1 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 2 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 3 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 4 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 5 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 6 Band Inversion BitMask = 0x0
    01-01 08:50:40.842   386   402 E audio_appe: Channel 7 Band Inversion BitMask = 0x0
    This is RadioApp  command line and eqmultstatus.
  • Hi, Guangyu,
    Since the CHAN_CFG_8CHANNEL_SURROUND2 configuration is not a supported configuration on the Jacinto 6 + JAMR3 EVM (since that is limited to 6 outputs), can you first please share your additions that you made to create the CHAN_CFG_8CHANNEL_SURROUND2 configuration?
    Also, can you please provide recordings at the output (both digital output of APPE and analog output of your board) so that I can understand the behavior you are seeing.  Your description seems to indicate that all EQ_MULTI settings are getting properly set, but you are seeing that the analog output on Ls and Rb channels does not apply the 5th EQ band, correct?  If you can provide recordings, I think that would help us understand the issue better.
                    Danny
  • https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/FT.7z
    Ft.7z contains the following files:
    1. Source. Wav is the file we play.
    2. Record. Wav is the file we recorded.
    3. Status. TXT contains the results of eqmultstatus and getappeconfig.
    4.1.jpg is the result of our test.
    5. Cooledit.bmp is the result of record. Wav analysis.
    6.Vis. patch contains all our changes.
  • We found no such problem when all channel parameters were consistent.
  • Is there any progress on this issue?
  • Hi Danny:
  • Hi, Guangyu,
    I hope to look closer at this code over the next few days.  Is it possible to you to clean your build directories before generating the patch that you attach?  Your patch file includes all the automatically-generating files, which makes it more difficult for me to understand exactly which code you have modified.
    Also, just to confirm:  Is it only Channel 3 and Channel 5 that exhibit this behavior on your platform (and only for the 5th band on those channels)?  Do all the other bands on the other channels function correctly for you?
    I believe that you don't have any other algorithms in the playback pathway that should affect the audio signal, but please do confirm.
               Danny
  • Guangyu,
    Also, do you have a digital recording at the output of APPE (before it goes out the McASP to the audio codec)?
    Is this item just the analog recording of the Audio HW Codec?
    I want to separate out any possible Audio HW Codec effects from APPE.
    You should be able to use the APPE HAL capture card to gather this recording:
    appe_hal_cap <WAV file> -Dappeout0
    Danny
  • Record. Wav is recorded form appeout0 by command: appe_hal_cap /sdcard/ record.wav -Dappeout0 -c 8 -r 44100
  • https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/vis_5F00_NotCompiled.patch.7z
    Vis_NotCompiled. Patch.7z is the code patch that cleases the build directory。
  • No other channels found this problem.For example, channel 1 and channel 3 set the same parameters, only channel 3 failed.
  • Hi, Guangyu,
    I have started looking through the patch set that you sent yesterday.
    Can you please comment on why the following change was made?  I believe you generated the patch in reverse (i.e. all the "-" lines are the code currently, and the "+" lines are the original code).
    diff -uprN vis_sdk/vis/dsp/components/audio_pipeline/APP/AlgSource/ISA/C/app_ti.c vis_01.50.23.01/vis/dsp/components/audio_pipeline/APP/AlgSource/ISA/C/app_ti.c
    --- vis_sdk/vis/dsp/components/audio_pipeline/APP/AlgSource/ISA/C/app_ti.c	2019-02-25 10:51:55.144888237 +0800
    +++ vis_01.50.23.01/vis/dsp/components/audio_pipeline/APP/AlgSource/ISA/C/app_ti.c	2018-05-12 07:07:00.000000000 +0800
    @@ -86,8 +86,8 @@ const Int ccSatToChanMap[IAUD_CC_SUB_N][
             {CHAN_LEFT, CHAN_RGHT, CHAN_LSUR, CHAN_RSUR, CHAN_CNTR, CHAN_SUBW},
             			CHAN_LBAK, CHAN_CNTR, CHAN_SUBW},
    -        {CHAN_CNTR, CHAN_RGHT, CHAN_RSUR, CHAN_RBAK,CHAN_LEFT, CHAN_LSUR,
    -        			CHAN_LBAK, CHAN_SUBW},
    +        {CHAN_LEFT, CHAN_RGHT, CHAN_LSUR, CHAN_RSUR,
    +        			CHAN_LBAK, CHAN_RBAK, CHAN_CNTR, CHAN_SUBW},
             {CHAN_LEFT, CHAN_RGHT, CHAN_LSUR, CHAN_RSUR, CHAN_LEFT2, CHAN_RGHT2, CHAN_SUBW},
             {CHAN_LEFT, CHAN_RGHT, CHAN_LEFT2, CHAN_RGHT2, CHAN_CNTR, CHAN_SUBW},
             {CHAN_LEFT, CHAN_RGHT, CHAN_LSUR, CHAN_RSUR, CHAN_CNTR, CHAN_CNTR2, CHAN_SUBW}
  • The channel order is determined by the hardware.
    This is our hardware channel order.
  • I changed the channel order back. Problems remain
  • Hi, Guangyu,
    In general, it is a good idea to just use the standard multichannel configurations ccSatToChanMap in app_ti.c.  Then, if you have specific channel order changes that need to be done, they can be done in the interleaving step in APPE_appeDataFormat() before it is sent to IOA (within the  AUDIO_FormatData() function).  I mention this because changing the ccSatToChanMap could cause some algorithms not to function correctly.
    I do not think the EQ_MULTI is one of these that should be affected though.  I have not yet found any reason in the code for the issue you are seeing; I will keep looking.
    When you changed the ccSatToChanMap back to its original content, are you seeing the issue on Channels 3 and 5 still?  Or did the issue still remain on Ls and Rb channels?
            Danny
  • When I changed the ccSatToChanMap back to its original content, this bug still exists in channel 3 and channel 5.
  • I would like to ask if it is changed to 8-channel output on TI demo board. By recording appeout0, it should be possible to reproduce this problem, right?
  • Hi, Guangyu,
    Today, I started trying to reproduce this in a different way on the TI board (since I don't have 8-channel output configuration available).  I will continue to look at this more deeply tomorrow.
                   Danny
  • Hi, Guangyu,
    I've been generating some more test audio files on my side to test this out more thoroughly, and I will continue to explore this deeper.
    I just wanted to let you know that I will be out of the office most of next week, but I will return to investigating this late next week.
              Danny
  • Hi, Guangyu,
    Unfortunately, I have not yet been able to return to looking at this again since I returned to the office late last week.  I plan to return to this tomorrow.  Sorry for the delay in my investigation on my side.
    Danny
  • Hi, Guangyu,
    Unfortunately, I don't yet have news on this item, as I'm still working on generating more audio test files to first reproduce the issue.
    I hope to have some progress to report early next week.
        Danny
  • Hi Danny:
    Please give priority to solving this problem. The problem of noise caused by CO algorithm can be solved later.
    Thank you.
  • Is there a recurrence of this problem on the TI demo board?
  • Hi, Guangyu,
    I believe that I am able to reproduce something similar to this issue on the TI Jacinto 6 + JAMR3 daughtercard.  In addition, after debugging the EQ_MULTI code, I believe I have pinpointed the problem.
    I am querying our TI field team to determine the best way to get you an updated EQ_MULTI library binary for you to test in your system.  I will keep you updated.
         Danny
  • Good news.
    my email :yuekeyan@singulato.com .
    Thank you!
  • May I ask when we can get the patch? The problem is urgent.
  • Hi, Guangyu,
    We are still working with the TI China field team to determine the best way to deliver this patch to you.  Please contact Han Tao (tao-han@ti.com) for more details.
                Danny
  • Hi Guangyu,
    just to update you - we are still working on this, hopefully we will be ready next week.
    Yordan
  • Hi, Guangyu,
    Our TI China field team has contacted you separately about delivery of this patch.  Please try out this patch as soon as you can and confirm on this E2E thread if it fixes the issue on your system.  Thanks very much!
           Danny
  • Hi, Guangyu,
    Just wanted to follow up with you.  Do you have the patch, and have you had a chance to try it?  Please do let me know when you might have a chance to try it.  Thanks!
                Danny
  • I've got the patch and it will be verified next week.
  • This problem has been solved. Thank you very much.
