Could you tell me how to confirm program size of CCS Project I'm developing?
Where should I check in .map file?
U-SK
U-SK
In CCS, try clicking on View | Memory Allocation. If that doesn't solve the problem, consider using the command line utility sectti from the cg_xml package.
Thanks and regards,
-George
Instead of ofd6x, use the armofd command that comes the TI ARM compiler you use. A command like this will do ...
armofd -x file.out | sectti.exe
Replace file.out with your executable file. Find sectti.exe in the \bin directory of the cg_xml installation.
Thanks and regards,
-George
