Linux/DRA72: NDK can't to boot normally
Part Number: DRA72
Tool/software: Linux
The NDK cannot normal boot in VSDK
log:
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
 [HOST]  OSA: MEM: 0: Mapped 0xa0100000 to 0xb69bd000 of size 0x00100000
 [HOST]  OSA: MEM: 1: Mapped 0x84203000 to 0xa6fbd000 of size 0x0fa00000
 [HOST]  OSA: MEM: 2: Mapped 0xa0200000 to 0xa6efd000 of size 0x00040000
 [HOST]  OSA: MEM: 3: Mapped 0xa02c0000 to 0xa6f3d000 of size 0x00080000
 [HOST]  OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
 [HOST]  OSA: HOST Remote Log Shared Memory @ 0xa024f140
 [HOST]  OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
 [HOST]  OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
   35.654909] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[   35.693055] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[ HOST] [HOST  ]     41.216525 s:  SYSTEM: System A15 Init in proress !!!
 [HOST] [HOST  ]     41.216647 s:  SYSTEM: IPC: Init in progress !!!
 [HOST] [HOST  ]     41.216647 s:  SYSTEM: IPC: Notify init in progress !!!
 [HOST] [HOST  ]     41.217745 s:  SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
 [HOST] [HOST  ]     41.217775 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
 [HOST] [HOST  ]     41.217806 s:  SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
 [HOST] [HOST  ]     41.217806 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
 [HOST] [HOST  ]     41.218629 s:  SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
 [HOST] [HOST  ]     41.218660 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
 [HOST] [HOST  ]     41.218690 s:  SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
 [HOST] [HOST  ]     41.218690 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
 [HOST] [HOST  ]     41.218812 s:  SYSTEM: IPC: Notify init DONE !!!
 [HOST] [HOST  ]     41.218812 s:  SYSTEM: MSGQ: MsgQ init in progress !!!
 [HOST] [HOST  ]     41.218904 s:  SYSTEM: MSGQ: MsgQ init DONE !!!
 [HOST] [HOST  ]     41.218904 s:  SYSTEM: IPC: Init DONE !!!
 [HOST] [HOST  ]     41.218904 s:  SYSTEM: Initializing A15 Links !!!
 [HOST] [HOST  ]     41.218995 s:  IPC_OUT_0 : Init done - linkid-0x2000000
 [HOST] [HOST  ]     41.219056 s:  IPC_OUT_1 : Init done - linkid-0x2000001
 [HOST] [HOST  ]     41.219148 s:  IPC_OUT_2 : Init done - linkid-0x2000002
 [HOST] [HOST  ]     41.219209 s:  IPC_OUT_3 : Init done - linkid-0x2000003
 [HOST] [HOST  ]     41.219270 s:  IPC_OUT_4 : Init done - linkid-0x2000004
 [HOST] [HOST  ]     41.219361 s:  IPC_IN_0 : Init done - linkid-0x200000a
 [HOST] [HOST  ]     41.219453 s:  IPC_IN_1 : Init done - linkid-0x200000b
 [HOST] [HOST  ]     41.219544 s:  IPC_IN_2 : Init done - linkid-0x200000c
 [HOST] [HOST  ]     41.219605 s:  IPC_IN_3 : Init done - linkid-0x200000d
 [HOST] [HOST  ]     41.219697 s:  IPC_IN_4 : Init done - linkid-0x200000e
 [HOST] [HOST  ]     41.219788 s:  IPC_IN_5 : Init done - linkid-0x200000f
 [HOST] [HOST  ]     41.219849 s:  IPC_IN_6 : Init done - linkid-0x2000010
 [HOST] [HOST  ]     41.219941 s:  NULL_0 : Init done - linkid-0x2000014
 [HOST] [HOST  ]     41.220002 s:  NULL_1 : Init done - linkid-0x2000015
 [HOST] [HOST  ]     41.220124 s:  NULL_SRC_0 : Init done - linkid-0x2000039
 [HOST] [HOST  ]     41.220246 s:  DISP_DIST_SRC_0 : Init done - linkid-0x200005e
 [HOST] [HOST  ]     41.220307 s:  DISP_DIST_SRC_1 : Init done - linkid-0x200005f
 [HOST] [HOST  ]     41.220398 s:  DISP_DIST_SRC_2 : Init done - linkid-0x2000060
 [HOST] [HOST  ]     41.220459 s:  DISP_DIST_SRC_3 : Init done - linkid-0x2000061
 [HOST] [HOST  ]     41.220520 s:  DISP_DIST_SRC_4 : Init done - linkid-0x2000062
 [HOST] [HOST  ]     41.220612 s:  DISP_DIST_SRC_5 : Init done - linkid-0x2000063
 [HOST] [HOST  ]     41.220673 s:  DISP_DIST_SRC_6 : Init done - linkid-0x2000064
 [HOST] [HOST  ]     41.220734 s:  DISP_DIST_SRC_7 : Init done - linkid-0x2000065
 [HOST] [HOST  ]     41.220825 s:  SGX3DSRV_0 : Init done - linkid-0x2000047
 [HOST] [HOST  ]     41.220917 s:  ALGORITHM_0 : Init done - linkid-0x2000031
 [HOST] [HOST  ]     41.221008 s:  ALGORITHM_1 : Init done - linkid-0x2000032
 [HOST] [HOST  ]     41.221069 s:  ALGORITHM_2 : Init done - linkid-0x2000033
 [HOST] [HOST  ]     41.221161 s:  ALGORITHM_3 : Init done - linkid-0x2000034
 [HOST] [HOST  ]     41.221252 s:  ALGORITHM_4 : Init done - linkid-0x2000035
 [HOST] [HOST  ]     41.221313 s:  ALGORITHM_5 : Init done - linkid-0x2000036
 [HOST] [HOST  ]     41.221405 s:  ALGORITHM_6 : Init done - linkid-0x2000037
 [HOST] [HOST  ]     41.226621 s:  ALGORITHM_7 : Init done - linkid-0x2000038
 [HOST] [HOST  ]     41.226773 s:  DUP0 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.227719 s:  DUP1 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.227871 s:  DUP2 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.227993 s:  DUP3 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228115 s:  DUP4 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228207 s:  SYNC_0 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228268 s:  SYNC_1 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228359 s:  SYNC_2 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228451 s:  SYNC_3 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228542 s:  MERGE_0 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228634 s:  MERGE_1 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228725 s:  MERGE_2 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228817 s:  MERGE_3 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.228908 s:  MERGE_4 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229000 s:  SELECT_0 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229091 s:  SELECT_1 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229152 s:  GATE_0 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229213 s:  GATE_1 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229305 s:  GATE_2 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229366 s:  GATE_3 : Init done - linkid-0x0
 [HOST] [HOST  ]     41.229427 s:  SGXFRMCPY_0 : Init done - linkid-0x2000046
 [HOST] [HOST  ]     41.229427 s:  SYSTEM: Initializing A15 Links ... DONE !!!
 [HOST] [HOST  ]     41.232294 s:  OSA: Adjusting global time, timeH by 0 units!!!
 [HOST] [HOST  ]     41.232294 s:  SYSTEM: System A15 Init Done !!!
 [HOST] [HOST  ]     41.232477 s:  NETWORK_CTRL_LINUX_TSK: Starting Server (port=5000) !!!
 [HOST] [HOST  ]     41.232538 s:  NETWORK_CTRL_LINUX_TSK: Starting Server ... DONE (port=5000) !!!
 [HOST] [DSP1  ]     16.368449 s:  ***** DSP1 Firmware build time 10:07:47 Mar  5 2019
 [HOST] [DSP1  ]     16.368510 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
 [HOST] [DSP1  ]     16.368693 s:  SYSTEM: System Common Init in progress !!!
 [HOST] [DSP1  ]     16.368876 s:  UTILS: CIO: Init Done !!!
 [HOST] [DSP1  ]     16.368907 s:  SYSTEM: IPC init in progress !!!
 [HOST] [DSP1  ]     16.368907 s:  SYSTEM: Attaching to [IPU2] ...
 [HOST] [DSP1  ]     16.370859 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
 [HOST] [DSP1  ]     16.370890 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
 [HOST] [DSP1  ]     16.370920 s:  SYSTEM: Notify init done !!!
 [HOST] [DSP1  ]     16.371042 s:  SYSTEM: MsgQ init done !!!
 [HOST] [DSP1  ]     16.371103 s: RpmsgInit in progress...
 [HOST] [DSP1  ]     16.371164 s:  SYSTEM: IPC init DONE !!!
 [HOST] [DSP1  ]     16.371744 s:  SYSTEM: System Common Init Done !!!
 [HOST] [DSP1  ]     16.371774 s:  SYSTEM: System DSP Init in progress !!!
 [HOST] [DSP1  ]     16.371927 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
 [HOST] [DSP1  ]     16.371957 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
 [HOST] [DSP1  ]     16.372018 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 522056 B (509 KB)
 [HOST] [DSP1  ]     16.372049 s:  SYSTEM: Initializing Links !!!
 [HOST] [DSP1  ]     16.376136 s:
 [HOST] [DSP1  ]     16.378698 s:  SYSTEM: Initializing Links ... DONE !!!
 [HOST] [DSP1  ]     16.378759 s: lz4CompDecomp Init
 [HOST] [DSP1  ]     16.378759 s:  SYSTEM: System DSP Init Done !!!
 [HOST] [DSP1  ]     16.400689 s: Connection established with HLOS, calling rpmsgInit
 [HOST] [DSP1  ]     16.699719 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
 [HOST] [DSP1  ]     16.699749 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
 [HOST] [IPU2  ]     16.211584 s:  ***** IPU2 Firmware build time 10:09:20 Mar  5 2019
 [HOST] [IPU2  ]     16.211767 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
 [HOST] [IPU2  ]     16.221374 s:  SYSTEM: System Common Init in progress !!!
 [HOST] [IPU2  ]     16.232294 s:  UTILS: CIO: Init Done !!!
 [HOST] [IPU2  ]     16.232385 s:  SYSTEM: IPC init in progress !!!
 [HOST] [IPU2  ]     16.232446 s:  SYSTEM: Attaching to [DSP1] ...
 [HOST] [IPU2  ]     16.370859 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
 [HOST] [IPU2  ]     16.370951 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
 [HOST] [IPU2  ]     16.371103 s:  SYSTEM: Notify init done !!!
 [HOST] [IPU2  ]     16.372811 s:  SYSTEM: MsgQ init done !!!
 [HOST] [IPU2  ]     16.373757 s: RpmsgInit in progress...
 [HOST] [IPU2  ]     16.373848 s: Connection established with HLOS, calling rpmsgInit
 [HOST] [IPU2  ]     16.374550 s:  SYSTEM: IPC init DONE !!!
 [HOST] [IPU2  ]     16.379643 s:  SYSTEM: System Common Init Done !!!
 [HOST] [IPU2  ]     16.379735 s:  SYSTEM: System Init in progress !!!
 [HOST] [IPU2  ]     16.379796 s:  SYSTEM: BSP Common Init in progress !!!
 [HOST] [IPU2  ]     16.379857 s:  SYSTEM: BSP Common Init Done !!!
 [HOST] [IPU2  ]     16.379918 s:  SYSTEM: BSP Platform Init in progress !!!
 [HOST] [IPU2  ]     16.380040 s:  SYSTEM: BSP Platform Init Done !!!
 [HOST] [IPU2  ]     16.380131 s:  SYSTEM: FVID2 Init in progress !!!
 [HOST] [IPU2  ]     16.380284 s:  SYSTEM: FVID2 Init Done !!!
 [HOST] [IPU2  ]     16.380345 s:  SYSTEM: VPS Init in progress !!!
 [HOST] [IPU2  ]     16.380406 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
 [HOST] [IPU2  ]     16.383151 s: *** VPDMA Firmware Loading... ***
 [HOST] [IPU2  ]     16.383273 s: VPDMA Firmware Address = 0xa03597c0
 [HOST] [IPU2  ]     16.383364 s: VPDMA Load Address     = 0x4897d004
 [HOST] [IPU2  ]     16.383456 s: VPDMA Firmware Version = 0x4d0001b8
 [HOST] [IPU2  ]     16.383547 s: VPDMA List Busy Status = 0x00000000
 [HOST] [IPU2  ]     16.383608 s: *** VPDMA Firmware Load Success ***
 [HOST] [IPU2  ]     16.383913 s: *** VPDMA Firmware Loading... ***
 [HOST] [IPU2  ]     16.384005 s: VPDMA Firmware Address = 0xa03597c0
 [HOST] [IPU2  ]     16.384127 s: VPDMA Load Address     = 0x489dd004
 [HOST] [IPU2  ]     16.384218 s: VPDMA Firmware Version = 0x4d0001b8
 [HOST] [IPU2  ]     16.384310 s: VPDMA List Busy Status = 0x00000000
 [HOST] [IPU2  ]     16.384401 s: *** VPDMA Firmware Load Success ***
 [HOST] [IPU2  ]     16.419416 s:  SYSTEM: VPS Init Done !!!
 [HOST] [IPU2  ]     16.420331 s:  UTILS: DMA: HWI Create for INT25 !!!
 [HOST] [IPU2  ]     16.420575 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
 [HOST] [IPU2  ]     16.420697 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 236336 B (230 KB)
 [HOST] [IPU2  ]     16.420850 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
 [HOST] [IPU2  ]     16.420972 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 262144000 B (250 MB)
 [HOST] [IPU2  ]     16.421216 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1037824 B (0 MB)
 [HOST] [IPU2  ]     16.421368 s:  SYSTEM: Initializing Links !!!
 [HOST] [IPU2  ]     16.690294 s:  SYSTEM: Initializing Links ... DONE !!!
 [HOST] [IPU2  ]     16.699719 s:  CHAINS: Application Started !!!
 [HOST] [IPU2  ]     16.710516 s:  BOARD: Board Init in progress !!!
 [HOST] [IPU2  ]     16.710974 s:  BOARD: Board Init Done !!!
 [HOST] [IPU2  ]     16.719697 s:
 [HOST] [IPU2  ]     17.695113 s:  NETWORK_CONS_TX: Starting TX (port=9000) !!!
 [HOST] [IPU2  ]     17.695418 s:  NETWORK_CONS_TX: Starting TX ... DONE (port=9000) !!!
 [HOST] [IPU2  ]     17.696150 s:  NETWORK_CONS_RX: Starting RX (port=9001) !!!
 [HOST] [IPU2  ]     17.696364 s:  NETWORK_CONS_RX: Starting RX ... DONE (port=9001) !!!
 [HOST] [IPU2  ]     21.694229 s:  NETWORK_CTRL_TSK: Starting Server (port=5000) !!!
 [HOST] [IPU2  ]     21.694534 s:  NETWORK_CTRL_TSK: Starting Server ... DONE (port=5000) !!!
 [HOST] [HOST  ]     41.784694 s:
 [HOST] [HOST  ]
 [HOST] [HOST  ]  ====================
 [HOST] [HOST  ]  Vision SDK Usecases
 [HOST] [HOST  ]  1: Single Camera Usecases
 [HOST] [HOST  ]  2: Multi-Camera LVDS Usecases
 [HOST] [HOST  ]  3: Open-Compute Usecases
 [HOST] [HOST  ]  4: AVB RX Usecases, (TDA2x & TDA2Ex ONLY)
 [HOST] [HOST  ]
 [HOST] [HOST  ]  p: CPU Status
 [HOST] [HOST  ]  i: Show IP Addr (IPU + NDK + AVB)
 [HOST] [HOST  ]
 [HOST] [HOST  ]  s: System Settings
 [HOST] [HOST  ]
 [HOST] [HOST  ]  x: Exit
 [HOST] [HOST  ]  z: Exit - AND SHUTDOWN Remote CPUs
 [HOST] [HOST  ]
 [HOST] [HOST  ]  Enter Choice:
 [HOST] [HOST  ]
[   46.052350] random: nonblocking pool is initialized
i
 [HOST] [HOST  ]    124.617885 s:  Network IP address : 0.0.0.0
 [HOST] [HOST  ]    124.617916 s:
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
 [HOST] [HOST  ]
