Part Number: AM5728
Tool/software: TI-RTOS
Hello, TI Experts,
Our customer sent us question about "how to merge Board_init(boardCfg);" by using PROCESSOR-SDK-RTOS-AM57X.
They tried to design EcMaster product referring http://www.ti.com/lit/ug/tidubz1b/tidubz1b.pdf
Now they tried to create MLO for acontis EC-Master(EcMasterDemoICSS).
Then they found Board_init(boardCfg); function in both sbl_main.c in pdk and main.c in EcMasterDemoICSS like below.
-sbl_main.c
boardCfg |= BOARD_INIT_UNLOCK_MMR |
BOARD_INIT_MODULE_CLOCK |
BOARD_INIT_PINMUX_CONFIG |
BOARD_INIT_DDR |
BOARD_INIT_UART_STDIO |
BOARD_INIT_WATCHDOG_DISABLE;
-main.c in EcMasterDemoICSS
Board_initCfg boardCfg = BOARD_INIT_UNLOCK_MMR | BOARD_INIT_PINMUX_CONFIG |
BOARD_INIT_MODULE_CLOCK | BOARD_INIT_UART_STDIO;
Question:
Can we remove "Board_init(boardCfg);" of main.c in EcMasterDemoICSS?
(sbl_main.c seems to cover the same boardCfg function in main.c.)
We would like to attach both c-files as a reference.
If there are any notice or comment, please tell us.
* main.c startup file for ti rtos application
* Copyright acontis technologies GmbH, Weingarten, Germany
* Response Mikhail Ledyaev
* Description starts EcMainDemo function.
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/timers/dmtimer/Timer.h>
#include <ti/board/board.h>
#include <ti/drv/uart/UART_stdio.h>
#include <EcVersion.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
Timer_Handle g_auxClocksTimerHandle = 0;
//extern int EcMasterDemo(void);
extern int CatMasterMain(void);
extern void pcieMmuInitial(void);
#define BOARD_IDKAM571x 1
#define BOARD_IDKAM572x 2
void InitAuxClockTimer()
const UInt auxClockTimerInstance = 1; // instance number defined in EcMaster.cfg
g_auxClocksTimerHandle = Timer_getHandle(auxClockTimerInstance);
void TimerEmptyISR()
* �N����̏����^�X�N���C��
void TaskFxn(UArg a0, UArg a1)
InitAuxClockTimer();
UART_printf("\n\rSYS/BIOS EcMasterDemo ICSS Sample application\n\r");
// EcMasterDemo();
// EtherCat���C�����[�v�����B
CatMasterMain();
volatile int dbg_flg = 1;
int main()
Board_IDInfo info;
Error_Block eb;
uint8_t board_type = 0;
Task_Params taskParams;
while(dbg_flg);
// PCIe�Ɋ֘A����AMMU�ݒ�
// pcieMmuInitial();
memset(&info, 0,sizeof(Board_IDInfo));
Board_getIDInfo(&info);
UART_printf("boardName: %s\n", info.boardName);
if (!(strcmp(info.boardName, "AM571IDK")))
board_type =BOARD_IDKAM571x;
UART_printf("board type is AM571IDK\n");
else
board_type =BOARD_IDKAM572x;
UART_printf("board type is AM572IDK\n");
Task_Params_init(&taskParams);
taskParams.priority = 1;
taskParams.stackSize = 0x1400;
taskParams.instance->name = "MainTask";
Error_init(&eb);
Task_create (TaskFxn, &taskParams, &eb);
BIOS_start();
return(0);
* \file sbl_main.c
* \brief This file contain main function, call the Board Initialization
* functions & slave core boot-up functions in sequence.
* Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* TI RTOS header files */
#include <ti/csl/cslr_device.h>
#include <ti/drv/uart/UART.h>
#include <ti/drv/uart/src/UART_osal.h>
#include <ti/csl/tistdtypes.h>
#include <ti/csl/csl_a15.h>
#include "sbl_slave_core_boot.h"
#include "sbl_avs_config.h"
#include "sbl_ver.h"
************************** Macros ************************************
************************** Internal functions ************************
************************** Global Variables **************************
sblEntryPoint_t idkAM572xEntry;
typedef void (*EntryFunPtr_t)(void);
int main()
void (*func_ptr)(void);
Board_initCfg boardCfg;
uint32_t oppMode = OPP_MODE_NOM;
#if defined(OPP_HIGH)
boardCfg = BOARD_INIT_PLL_OPP_HIGH;
oppMode = OPP_MODE_HIGH;
#elif defined(OPP_OD)
boardCfg = BOARD_INIT_PLL_OPP_OD;
oppMode = OPP_MODE_OD;
#elif defined(OPP_NOM)
boardCfg = BOARD_INIT_PLL_OPP_NOM;
#endif
BOARD_INIT_DDR |
/* Configure AVS voltage for the selected OPP to the voltage rails. */
SBL_Configure_AVS(oppMode);
/* Board Library Init. */
/* enable clocks for slave core modules. */
SBL_SlaveCorePrcmEnable();
UART_printf("**** PDK SBL ****\n");
UART_printf("%s (%s - %s)\n", SBL_VERSION_STR, __DATE__, __TIME__);
UART_printf("Begin parsing user application\n");
/* Image Copy */
SBL_ImageCopy(&idkAM572xEntry);
/* Cache Write back after image copy to ensure the slave cores are brought
** out of reset correctly.
CSL_a15WbAllDataCache();
UART_printf("Jumping to user application...\n");
if (idkAM572xEntry.entryPoint_MPU_CPU1 != 0)
/* Bring the A15 CPU1 core out of reset. */
SBL_MPU_CPU1_BringUp(idkAM572xEntry.entryPoint_MPU_CPU1);
if (idkAM572xEntry.entryPoint_DSP1 != 0)
/* Release the DSP1 core out of reset */
SBL_DSP1_BringUp(idkAM572xEntry.entryPoint_DSP1);
if (idkAM572xEntry.entryPoint_DSP2 != 0)
/* Release the DSP2 core out of reset */
SBL_DSP2_BringUp(idkAM572xEntry.entryPoint_DSP2);
if (idkAM572xEntry.entryPoint_IPU1_CPU0 != 0)
/* Release the IPU1 core out of reset and set the Entry point */
SBL_IPU1_CPU0_BringUp(idkAM572xEntry.entryPoint_IPU1_CPU0);
if (idkAM572xEntry.entryPoint_IPU1_CPU1 != 0)
SBL_IPU1_CPU1_BringUp(idkAM572xEntry.entryPoint_IPU1_CPU1);
if (idkAM572xEntry.entryPoint_IPU2_CPU0 != 0)
/* Release the IPU2 core out of reset and set the Entry point */
SBL_IPU2_CPU0_BringUp(idkAM572xEntry.entryPoint_IPU2_CPU0);
if (idkAM572xEntry.entryPoint_IPU2_CPU1 != 0)
/* Release the IPU2 CPU1 core out of reset and set the Entry point */
SBL_IPU2_CPU1_BringUp(idkAM572xEntry.entryPoint_IPU2_CPU1);
/*Jump to MPU CPU0 APP*/
if (idkAM572xEntry.entryPoint_MPU_CPU0 != 0)
func_ptr = (EntryFunPtr_t) idkAM572xEntry.entryPoint_MPU_CPU0;
CSL_a15InvAllInstrCache();
__sync_synchronize();
func_ptr();
else
while(1);
return 0;
